    4. iob 3.3.4. Read-only state has been written without ack-flag
    • D3ltoroxp
      D3ltoroxp last edited by D3ltoroxp
        <block type="on_ext" id="::h9y24TVAGz[FtSo{t|" x="-87" y="-1087">
          <mutation xmlns="http://www.w3.org/1999/xhtml" items="4"></mutation>
          <value name="OID0">
            <shadow type="field_oid" id="ZAY6,?b^Z{9@*d-3,q*r">
              <field name="oid">calendar.0.YWtmZHQyMHUwZ3MxMzhxMTE4OW5xdn.1.events</field>
          <value name="OID1">
            <shadow type="field_oid" id="BymNer@sIyxitx@4Ajic">
              <field name="oid">calendar.0.YWtmZHQyMHUwZ3MxMzhxMTE4OW5xdn.2.events</field>
          <value name="OID2">
            <shadow type="field_oid" id="XQT{i`]oQsQK*x2!-I,%">
              <field name="oid">calendar.0.YWtmZHQyMHUwZ3MxMzhxMTE4OW5xdn.3.events</field>
          <value name="OID3">
            <shadow type="field_oid" id="{Cf!P2]@D6?KDFB`6@)C">
              <field name="oid">calendar.0.YWtmZHQyMHUwZ3MxMzhxMTE4OW5xdn.4.events</field>
            <block type="comment" id="4l%h$]#b}~ecx[8OHAH^">
              <field name="COMMENT">Papiertonne</field>
                <block type="controls_if" id="reT~O^XpYo+Fs[tu8iw:">
                    <block type="math_number_property" id="X2Me,vme^BLkr-/p5~G=">
                      <mutation divisor_input="false"></mutation>
                      <field name="PROPERTY">POSITIVE</field>
                      <value name="NUMBER_TO_CHECK">
                        <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number" id="#QaI[..Je5?,AXz:@XCk">
                          <field name="NUM">0</field>
                        <block type="text_indexOf" id="speN0grHA38fp44;#b}-">
                          <field name="END">FIRST</field>
                            <block type="get_value" id="8TZC]XITz@%z~BeQYvgr">
                              <field name="OID">calendar.0.YWtmZHQyMHUwZ3MxMzhxMTE4OW5xdn.4.events</field>
                          <value name="FIND">
                            <shadow type="text" id=")UGm;(Al80?Qe$jV2|IZ">
                              <field name="TEXT">Papiertonne</field>
                    <block type="control" id="$..+V;$!%4RMvduKZVzQ">
                      <field name="OID">0_userdata.0.Abfall.Papiertonne_Days_left</field>
                        <block type="math_number" id="_I:Z^{|Dq$]m1R0?ba+^">
                          <field name="NUM">3</field>
                        <block type="update" id="pp;^uPO[%[,1r[{23K:,">
                          <field name="OID">0_userdata.0.Abfall.Papiertonne_Text</field>
                            <block type="text" id="tJq{)IxAhPS-yat%;YkK">
                              <field name="TEXT">Papiertonne in 3 Tagen</field>
                    <block type="controls_if" id="tyYw*9wR#,Qs`aA$zp$7">
                        <block type="math_number_property" id="oA])+4U80NvxNt!(@g?S">
                            <block type="text_indexOf" id="r-)kqYJVjPO5d-C/C.+A">
                                <block type="get_value" id="D6hca.pLc$ms:^,:^xdz">
                                  <field name="OID">calendar.0.YWtmZHQyMHUwZ3MxMzhxMTE4OW5xdn.3.events</field>
                              <value name="FIND">
                                <shadow type="text" id="MkI;ApMu^`.6DX^}gj7e">
                        <block type="control" id=",ps1PA]:|-G5X`[0.*AA">
                            <block type="math_number" id="Z?;Ni.;6)Zj%H0+FPBXJ">
                              <field name="NUM">2</field>
                            <block type="update" id="z5F1}X7_/eU^?N{5~cgM">
                                <block type="text" id=".@I:IXRUT`OlEqud%,j`">
                                  <field name="TEXT">Papiertonne in 2 Tagen</field>
                        <block type="controls_if" id="{g%.!5tUKWyYmpof}$#C">
                            <block type="math_number_property" id="Fg|$$FSs7%*f//hq1P]o">
                                <block type="text_indexOf" id="G|,ub$/6Yypr!WZt]K.,">
                                    <block type="get_value" id="J2}/E.p@9r/jwE0fH7a[">
                                      <field name="OID">calendar.0.YWtmZHQyMHUwZ3MxMzhxMTE4OW5xdn.2.events</field>
                                  <value name="FIND">
                                    <shadow type="text" id="d-nzR{K@ocarrCRxI5A]">
                            <block type="control" id="o?cdb[!Ljp4v;5@S0Gck">
                                <block type="math_number" id="f;;nfPt?;eiD/%wG{`|q">
                                  <field name="NUM">1</field>
                                <block type="update" id="/8iucdiTaaA/B,2zXQx2">
                                    <block type="text" id="Fqe5bEn3T5MJ%D~uLBpP">
                                      <field name="TEXT">Morgen wird die Papiertonne abgeholt !</field>
                            <block type="controls_if" id="B%tdbZ+^`?kf:JOy-.CR">
                                <block type="math_number_property" id="mm$9WX+AO~E2Z}Xz`crL">
                                    <shadow xmlns="http://www.w3.org/1999/xhtml" type="math_number">
                                    <block type="text_indexOf" id="?fM@69;Z)G,k3:nM6w50">
                                        <block type="get_value" id="!@deUVaTYRSF}rf!.EOQ">
                                          <field name="OID">calendar.0.YWtmZHQyMHUwZ3MxMzhxMTE4OW5xdn.1.events</field>
                                      <value name="FIND">
                                        <shadow type="text" id="+-1)]mYhfaFEYxdr8UHJ">
                                <block type="control" id="5/Rs+,`aS_bX8~JMEz4K">
                                    <block type="math_number" id="x@8x|r-f*G-MXmlPGNz:">
                                    <block type="update" id="}V4X+`9oO6w-vkt:8(=p">
                                        <block type="text" id="U!(x+!={B6(;lB3|H:;k">
                                          <field name="TEXT">Nicht vergessen, heute wird die Papiertonne abgeholt !</field>
                                <block type="comment" id="ds4:O6dRZodP^3zea/f*">
                                  <field name="COMMENT">Gelber Sack</field>
                                    <block type="controls_if" id="om6sq=Xf;,B?Zi@Bj~C{">
                                        <block type="math_number_property" id=":[(B|]++3!~Yy;{0*!}{">
                                            <block type="text_indexOf" id="ZwPk4NqJfpf@pL%!+VrQ">
                                                <block type="get_value" id="6-g$]2dZ~b*A-GNXy!0K">
                                              <value name="FIND">
                                                <shadow type="text" id="x,{y(Id=wqv=OeQ8DOt+">
                                                  <field name="TEXT">Gelber Sack</field>
                                        <block type="control" id="kzR3=r.AU($%Pa2{UtN=">
                                          <field name="OID">0_userdata.0.Abfall.Gelber_Sack_Days_left</field>
                                            <block type="math_number" id=".ByLNO7F[nT_u5+m+qX2">
                                            <block type="update" id="0Kn`zj@k?cP-HMb-.(dt">
                                              <field name="OID">0_userdata.0.Abfall.Gelber_Sack_Text</field>
                                                <block type="text" id="lf9E3*vL|-|R2wU*p[(3">
                                                  <field name="TEXT">Gelber Sack in 3 Tagen</field>
                                        <block type="controls_if" id="78gh/g5cCJ}`%4si.T[u">
                                            <block type="math_number_property" id="=fK.qMLlu=o!|x_P|`8$">
                                                <block type="text_indexOf" id="+-fzJ)K@}`yZhFvA6m/Q">
                                                    <block type="get_value" id="p3[{_+I[2ma^@d_i25@?">
                                                  <value name="FIND">
                                                    <shadow type="text" id=";BaXtBk:uo$9e/DP!c%C">
                                            <block type="control" id="*Ii+`MFIjT}ai=Pd2#v;">
                                                <block type="math_number" id="sLpt?ZJ5x^ByJB^LRx,H">
                                                <block type="update" id="CsY%EJGCnlf{kM-uaoF4">
                                                    <block type="text" id="T4d,{c^v`$PyOys.fRY.">
                                                      <field name="TEXT">Gelber Sack in 2 Tagen</field>
                                            <block type="controls_if" id="BPQ*?}|(x(~,6OpqsGop">
                                                <block type="math_number_property" id="EAO?RGC~(8:NVzoa!ejP">
                                                    <block type="text_indexOf" id="bw$pXuGuhataW1bF0RjS">
                                                        <block type="get_value" id="g;B~a5]0mBAI;yUyb,.`">
                                                      <value name="FIND">
                                                        <shadow type="text" id="yCvyrB~UyoSvoTpL%[N[">
                                                <block type="control" id="?7AnyziEB~PPC?8B%(Ea">
                                                    <block type="math_number" id="XaKuX4IsuO|U^6/;TBJk">
                                                    <block type="update" id="t!8z2uY}lgtv1Aa/T-zz">
                                                        <block type="text" id="B)D~:ZoM_w:y#G?h4AZ]">
                                                          <field name="TEXT">Morgen wird der gelbe Sack abgeholt !</field>
                                                <block type="controls_if" id="l%yimr!`Y4P@|Ms7-)t!">
                                                    <block type="math_number_property" id="GW{@7|~0=GK8R;:b|)]K">
                                                        <block type="text_indexOf" id="-098|?ncu-myAn#?ccqk">
                                                            <block type="get_value" id="4+a.O;Fn2Csmq{lH7h*)">
                                                          <value name="FIND">
                                                            <shadow type="text" id=":?u3,xt!v~O71J_r6d2f">
                                                    <block type="control" id="5.o:ZigzT2#jw^7n$jRH">
                                                        <block type="math_number" id="wt!FuY-W:2Z(vrsD6#*t">
                                                        <block type="update" id="C=`lQ/6T3#Y)392fMnfH">
                                                            <block type="text" id="n:Fxvgs5?gxVD%cj{cJ)">
                                                              <field name="TEXT">Nicht vergessen, heute wird der gelbe Sack abgeholt !</field>
                                                    <block type="comment" id="xe`dN^Ixy{ae#4%?o!HV">
                                                      <field name="COMMENT">Restmüll</field>
                                                        <block type="controls_if" id="@.HqEy),J0U5+P{,C2S{">
                                                            <block type="math_number_property" id="]zYJN@9{lB2GRe_T%H=N">
        <block type="text_indexOf" id="`]?e%1Qo9Sr[e`xX8PGN">
        <block type="get_value" id=")hy9BRMv[FvtpuAwvf-p">
        <value name="FIND">
        <shadow type="text" id="g.m(YS:CMKOWs9^J:U{T">
        <field name="TEXT">Restmüllgefäß</field>
                                                            <block type="control" id="Q[r8U=PCBc-~kVsfCrmZ">
                                                              <field name="OID">0_userdata.0.Abfall.Restmüll_Days_left</field>
        <block type="math_number" id="m)X#/qe1aRg,_zG80;ZT">
        <block type="update" id="({BRLTtwTqD:Mmx,_YJ}">
        <field name="OID">0_userdata.0.Abfall.Restmüll_Text</field>
        <block type="text" id="j!OP9rAnmzUwK{)8Z@xj">
        <field name="TEXT">Restmüll in 3 Tagen</field>
                                                            <block type="controls_if" id=".sMIt;rGFzIx{t3iOn@5">
        <block type="math_number_property" id="l(y*~]fzkQ:+M9x6T;Vy">
        <block type="text_indexOf" id="e:Xw{*ukZ!q-q/:CoO3S">
        <block type="get_value" id="k:-4Xz4^n0VcAT`(8@5:">
        <value name="FIND">
        <shadow type="text" id="z[)K]{h!aPwH`?^JuoQ#">
        <block type="control" id="($j5ICM/A:QrlEgAbBbA">
        <block type="math_number" id="F;[0;?t9+eDB:(%t9nyh">
        <block type="update" id="D*@EN(5AZIdxs(Vha5:i">
        <block type="text" id="J;a[%iX9Przd*[%Cr??T">
        <field name="TEXT">Restmüll in 2 Tagen</field>
        <block type="controls_if" id="0As4KpHi@C[C9dCtjD-I">
        <block type="math_number_property" id="B$k#iBIOrPZP)F0iB~xN">
        <block type="text_indexOf" id=":=2Ca`pkw}]z*XRv#Pos">
        <block type="get_value" id=";3-XmD}XN$D6u!r/t]$$">
        <value name="FIND">
        <shadow type="text" id="`VLIXa*TSE-`3L78totp">
        <block type="control" id="s4S~IWl3=PmF,K3XM+:y">
        <block type="math_number" id="I6|Rhdh_Y^L!r?ii_NfQ">
        <block type="update" id="Mi3C(*Gb2y].Azq-!}~b">
        <block type="text" id="Glk[/;|O=8y^s}|/LRkm">
        <field name="TEXT">Morgen wird der Restmüll abgeholt !</field>
        <block type="controls_if" id="*R5a#=RKTEIJq5PQwIsh">
        <block type="math_number_property" id="aXv1Pay0)^$6({Pk@6-x">
        <block type="text_indexOf" id="AA=_{fJ1_fGy4/mE6q|g">
        <block type="get_value" id="|T`F[MN;BHEX?9N:1u27">
        <value name="FIND">
        <shadow type="text" id="982`Y}nO*X5OaLjN9R1e">
        <block type="control" id="/%#fLb-(tj~e@7REhg#K">
        <block type="math_number" id="pB+^u+ON%$*4!aZD);lc">
        <block type="update" id="vS^tykoA#HrT~cXK_sEn">
        <block type="text" id="}I!^JGUqIim`m0:mPpg9">
        <field name="TEXT">Nicht vergessen, heute wird der Restmüll abgeholt !</field>
        <block type="schedule" id="3Q?MsrXJcRqm9#X%!Thn" x="1013" y="-1087">
          <field name="SCHEDULE">{"time":{"exactTime":true,"start":"21:30"},"period":{"days":1}}</field>
            <block type="controls_if" id="n4rOXg_f^Bt?rv0U@BAw">
              <mutation elseif="2"></mutation>
                <block type="math_number_property" id="L?uQ!F50{H?vP%(F8SAn">
                    <block type="text_indexOf" id="2@]8Nhe,aHhSJWFg116q">
                        <block type="get_value" id="EO^5!q[gp`y@}9x*J6{t">
                      <value name="FIND">
                        <shadow type="text" id="y_tGj1$LGc#c*uwmlUq=">
                          <field name="TEXT">Morgen wird</field>
                <block type="control" id=")J1SMdg:E(%yysg~~FoB">
                  <field name="OID">alexa2.0.Echo-Devices.G090XG0900320E5H.Commands.announcement</field>
                    <block type="text" id="*a-]`Qy6Odr!bc3}xmMN">
                      <field name="TEXT">Nicht vergessen, morgen wird der Restmüll abgeholt !</field>
              <value name="IF1">
                <block type="math_number_property" id="Sn*oH`Ye3BEiQ0JANr#%">
                    <block type="text_indexOf" id="Py=Vot;zQxvE-Mm4YGIC">
                        <block type="get_value" id="C~`2K)t[vxau3YsGsA?[">
                      <value name="FIND">
                        <shadow type="text" id="/8uipN)cc?Kuy9FlsY_@">
              <statement name="DO1">
                <block type="control" id="s~|]M,Q2wHD{:4@gO7;5">
                    <block type="text" id="g^#O:kHi3+2RC6;[1WFQ">
                      <field name="TEXT">Nicht vergessen, morgen wird der gelbe Sack abgeholt !</field>
              <value name="IF2">
                <block type="math_number_property" id=",o3sTCEYStTpv(_X*pOE">
                    <block type="text_indexOf" id="qq`PTVMkdimk48)~FUyl">
                        <block type="get_value" id="ePXzire|($p*#qeWs2,y">
                      <value name="FIND">
                        <shadow type="text" id="qF^osV4hT_Fck7oX%T$6">
              <statement name="DO2">
                <block type="control" id="INKlz[-^7zfjgs=h(j[6">
                    <block type="text" id="RwJgAL$a~iURWmD8o#F%">
                      <field name="TEXT">Nicht vergessen, morgen wird die Papiertonne abgeholt !</field>
            <block type="comment" id="#:UgFmPoyub@,MDP_ZyW">
              <field name="COMMENT">Wenn in den nächsten Tagen keine Abholung, wird Text geschrieben</field>
                <block type="schedule" id="U87pxahO2.H^B:?ThwJ:">
                  <field name="SCHEDULE">{"time":{"exactTime":true,"start":"12:00"},"period":{"days":1}}</field>
                    <block type="controls_if" id="^6*6UL|V{hrQSvmhW9U.">
                        <block type="math_number_property" id="YXU_?T$#uY[lk4VYL[7m">
                            <block type="text_indexOf" id="w_mA8o;%Pg96vBQG0b_$">
                                <block type="get_value" id="gfRPIU|EIBUF9~D+ho8l">
                              <value name="FIND">
                                <shadow type="text" id="OPNDD~D5Ft@aF?[0$b%o">
                        <block type="update" id="Owk]6dkUB$!=f`XRIEFV">
                            <block type="text" id="D_rQq#*=f3mKxswuM?mu">
                              <field name="TEXT">In den nächsten Tagen, keine Abholung !</field>
                      <value name="IF1">
                        <block type="math_number_property" id="}bJWo1{BETFKX,DVr4IP">
                            <block type="text_indexOf" id="U1|}.!)ZyMDOT}Ase.]y">
                                <block type="get_value" id=":B@Uepk/O%J3v?kYfk/u">
                              <value name="FIND">
                                <shadow type="text" id="g0ZbedC4mSBL}zPJ4kf9">
                        <block type="update" id="*PUijXAomid]r(oHloRT">
                            <block type="text" id="M-xzOxlUan[(fvO!+q}]">
                      <value name="IF2">
                        <block type="math_number_property" id="URp/[z5bjnx!I00/?6Al">
                            <shadow type="math_number" id="+s^-{(S-wdz(v7aFx-s$">
                            <block type="text_indexOf" id="_Hr-$JAOZ1F(4DLpezO=">
                                <block type="get_value" id="y:.7vcnVB{QsI]1Krk%j">
                              <value name="FIND">
                                <shadow type="text" id="6*/Z8yr*38w0+/4v)}9z">
                        <block type="update" id="!pn5asTpIzt!sEL$$;83">
                            <block type="text" id="}!`E7oSZROOQk0o.2IrG">
      • D3ltoroxp
        Das ist das Script für den View wechsel, irgendwie habe ich den im Verdacht unter anderem... Die schleife ist raus. Aber der ist grad unter anderem aus, am Ram hat sich seit dem Einschalten nicht viel geändert.
          <variables>
            <variable type="timeout" id="Home Kalender">Home Kalender</variable>
            <variable type="timeout" id="Home Fenster Turen">Home Fenster Turen</variable>
            <variable type="timeout" id="Home Roborock">Home Roborock</variable>
            <variable type="timeout" id="Home Wetter">Home Wetter</variable>
            <variable type="timeout" id="Wiederholen">Wiederholen</variable>
          </variables>
          <block type="on" id="+~eoP#21u7X,=p;Jm!@^" x="-2387" y="-912">
            <field name="OID">fullybrowser.0.192_168_178_48.Info.screenOn</field>
              <block type="timeouts_cleartimeout" id="EE[=!lENE=(7VNpjwB(C">
                <field name="NAME">Home Wetter</field>
                  <block type="timeouts_cleartimeout" id="~d9[(hG__@V_RA~n_iC4">
                    <field name="NAME">Home Kalender</field>
                      <block type="timeouts_cleartimeout" id="t*EA%%#U5iF!bk?dp505">
                        <field name="NAME">Home Fenster Turen</field>
                          <block type="controls_if" id="/G`p/|k$0:EU~T[RBjOS">
                              <block type="logic_compare" id="[S[sYioYko@FZ4Aye_]-">
                                <field name="OP">EQ</field>
                                  <block type="on_source" id="q?DqqBuGg0ZD+M=*QjHB">
                                  <block type="logic_boolean" id="u9,jGapVe^T+;xW/Vfiv">
                              <block type="control" id="P|br)}YZc-o:w9F%=L~1">
                                <field name="OID">vis.0.control.instance</field>
                                <field name="DELAY_MS">500</field>
                                <field name="UNIT">ms</field>
                                  <block type="text" id="Z!6#[i.w::/M$!_5E8`Z">
                                    <field name="TEXT">FFFFFFFF</field>
                                  <block type="control" id="f|IODAm[+XjQrrIC/@{$">
                                    <field name="OID">vis.0.control.data</field>
                                    <field name="DELAY_MS">1000</field>
                                      <block type="text" id="{|4o?Eq1jfsJiOaxJ/=}">
                                        <field name="TEXT">main/home-wetter</field>
                                      <block type="control" id="+.?Gx,=:H~pWh774OD?j">
                                        <field name="OID">vis.0.control.command</field>
                                        <field name="DELAY_MS">1500</field>
                                          <block type="text" id="az,i4H$QDr2|4e@3|Crg">
                                            <field name="TEXT">changeView</field>
                                          <block type="timeouts_settimeout" id="=bK2tdUl_z)hQ}$E0C#4">
                                            <field name="DELAY">30</field>
                                              <block type="control" id="tR3PP%snPcKQZ(rojo4~">
                                                  <block type="text" id="H6-`umpke4hp]lriW.A7">
                                                  <block type="control" id="Z./AN5b=U5++mDoGx8QC">
                                                      <block type="text" id="GC%,?HJq{~6LCr$}+A%v">
                                                        <field name="TEXT">main/home-kalender</field>
                                                      <block type="control" id="}DlRg3pY@)CwI=M|iXF,">
                                                          <block type="text" id="gBn+Tonsfd2TDI#%lb$q">
                                                          <block type="timeouts_settimeout" id="`xJK3AM6C7:[YP[$5l-^">
                                                              <block type="control" id="X+#^5Ka2kFU,#KU=wnm$">
        <block type="text" id="gEa[*dyJv=L,Xpd4|m#X">
        <block type="control" id="+*9HzNg+z[BS8-Hcf#mO">
        <block type="text" id="XqhQe[HP#M(z6CFJTMOt">
        <field name="TEXT">main/home-fentuer</field>
        <block type="control" id="O*6!b;gKCy(isAoEnn-P">
        <block type="text" id="f#_RH9cC,ecJ5AytQ5AX">
        <block type="timeouts_settimeout" id="YY#d?gyg:0=kRwGGsti]">
        <field name="NAME">Home Roborock</field>
        <block type="control" id="^U^$/-}gChcvgN@CYvj$">
        <block type="text" id="(|/t_@3==|.rNv{m4tG{">
        <block type="control" id="^QGx{O#/ekXtq|_Q}iMh">
        <block type="text" id="2nm_9g82BQ0_#mMImd*v">
        <field name="TEXT">main/RoborockS50</field>
        <block type="control" id="{=]zq!Bom5vNgkAAPCM8">
        <block type="text" id="Pf0DDf[A8^Rk^d),knZ(">
        <block type="timeouts_settimeout" id="~Ls5H/j~YgJ.);QDf9]Q">
        <block type="control" id="z`Z0oY^0t(]qgS=4CISm">
        <block type="text" id="~3c#_[dy1JhKugCC~/)`">
        <block type="control" id="]B,8bx+[w4[L)+q!iJbv">
        <block type="text" id="Ih|IUj(F#1?Ysp0#REoy">
        <block type="control" id="60gMdZ.([/Oyj:To+Lx$">
        <block type="text" id="_11SeaRkW-:UO;s5e%;9">
        <block type="timeouts_settimeout" id="YR#n2Cyxd$DsOF_d|wh!">
        <field name="NAME">Wiederholen</field>
        <field name="DELAY">1</field>
          Homoran Global Moderator Administrators @D3ltoroxp last edited by
          @d3ltoroxp sagte in iob 3.3.4. Read-only state has been written without ack-flag:
          Blockly im nächsten Post, passt hier nicht mehr rein.
          bitte als Bild
          • D3ltoroxp
            D3ltoroxp @Homoran last edited by
            @homoran said in iob 3.3.4. Read-only state has been written without ack-flag:
            bitte als Bild
            Hab die beiden oberen Beiträge editiert. Das Bild für den Kalender bekomme ich leider nicht größer, sonst ist nicht alles drauf.
              Homoran Global Moderator Administrators @D3ltoroxp last edited by Homoran
              @d3ltoroxp auf die Schnelle vom Handy: du hast überall steuere für eigene Datenpunkte.
              Da gibt es nix zu steuern, die willst du nur aktualisieren.
              Bei steuere ist ACK= false
              der letzte timeout ist leer und nirgends ein stop timeout.
              den Trigger kenne ich nicht, und weiß daher nicht, ob er durch eine Aktion erneut triggert u d dadurch einen der timeouts erneut startet, obwohl dieser noch nicht beendet ist
              • D3ltoroxp
                Der Ram füllt sich langsam und die Log auch. Auch das System wird träger.
                dwd / daswetter hauen auch Fehlermeldungen in die Log, das die auf irgendwas nicht zugreifen können, aber auch hier sind die DP's vorhanden.
                daswetter.0
                	2022-01-02 11:47:37.117	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.clouds_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.clouds_value": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.116	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.clouds_value": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.116	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.pressure_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.pressure_value": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.115	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.pressure_value": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.115	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.humidity_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.humidity_value": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.114	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.humidity_value": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.114	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.rain_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.rain_value": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.114	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.rain_value": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.113	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.windgusts_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.windgusts_value": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.113	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.windgusts_value": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.112	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.windIconURL: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.windIconURL": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.112	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.windIconURL": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.111	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.wind_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.wind_value": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.111	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.wind_value": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.110	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.wind_dir: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.wind_dir": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.110	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.wind_dir": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.109	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.wind_symbol: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.wind_symbol": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.109	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.wind_symbol": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.108	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.wind_symbolB: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.wind_symbolB": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.108	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.wind_symbolB": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.107	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.iconURL: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.iconURL": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.107	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.iconURL": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.106	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.symbol_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.symbol_value": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.106	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.symbol_value": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.105	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.symbol_desc: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.symbol_desc": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.105	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.symbol_desc": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.104	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.symbol_value2: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.symbol_value2": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.104	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.symbol_value2": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.103	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.symbol_desc2: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.symbol_desc2": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.103	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.symbol_desc2": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.102	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.temp_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.temp_value": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.102	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.temp_value": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.101	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.hour_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.hour_value": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.101	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5.hour_value": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.100	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.100	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_5": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.099	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.windchill_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.windchill_value": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.099	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.windchill_value": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.098	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.snowline_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.snowline_value": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.098	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.snowline_value": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.097	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.clouds_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.clouds_value": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.097	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.clouds_value": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.096	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.pressure_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.pressure_value": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.096	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.pressure_value": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.095	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.humidity_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.humidity_value": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.094	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.humidity_value": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.093	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.rain_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.rain_value": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.093	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.rain_value": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.092	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.windgusts_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.windgusts_value": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.092	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.windgusts_value": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.091	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.windIconURL: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.windIconURL": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.090	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.windIconURL": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.089	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.wind_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.wind_value": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.089	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.wind_value": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.088	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.wind_dir: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.wind_dir": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.088	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.wind_dir": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.087	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.wind_symbol: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.wind_symbol": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.087	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.wind_symbol": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.086	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.wind_symbolB: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.wind_symbolB": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.086	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.wind_symbolB": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.085	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.iconURL: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.iconURL": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.085	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.iconURL": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.085	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.symbol_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.symbol_value": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.084	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.symbol_value": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.083	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.symbol_desc: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.symbol_desc": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.083	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.symbol_desc": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.082	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.symbol_value2: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.symbol_value2": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.082	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.symbol_value2": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.081	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.symbol_desc2: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.symbol_desc2": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.081	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.symbol_desc2": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.080	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.temp_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.temp_value": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.080	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.temp_value": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.079	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.hour_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.hour_value": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.079	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4.hour_value": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.078	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.078	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_4": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.077	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.windchill_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.windchill_value": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.077	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.windchill_value": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.076	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.snowline_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.snowline_value": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.076	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.snowline_value": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.075	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.clouds_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.clouds_value": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.075	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.clouds_value": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.074	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.pressure_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.pressure_value": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.074	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.pressure_value": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.073	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.humidity_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.humidity_value": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.073	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.humidity_value": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.072	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.rain_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.rain_value": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.071	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.rain_value": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.071	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.windgusts_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.windgusts_value": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.070	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.windgusts_value": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.070	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.windIconURL: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.windIconURL": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.069	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.windIconURL": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.069	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.wind_value: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.wind_value": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.068	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.wind_value": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.068	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.wind_dir: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.wind_dir": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.067	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.wind_dir": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.067	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.wind_symbol: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.wind_symbol": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.066	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.wind_symbol": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.066	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.wind_symbolB: Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.wind_symbolB": Connection is closed.]
                daswetter.0
                	2022-01-02 11:47:37.065	error	Cannot check object existence of "daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.wind_symbolB": Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.064	error	exception in await insertIntoList [Error: DB closed]
                daswetter.0
                	2022-01-02 11:47:37.064	warn	get state error: Connection is closed.
                daswetter.0
                	2022-01-02 11:47:37.063	warn	Could not perform strict object check of state daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_3.iconURL: Connection is closed.
                daswetter.0
                	2022-01-02 11:47:36.999	error	exception in await insertIntoList [Error: DB closed]
                daswetter.0
                	2022-01-02 11:47:36.474	warn	Terminated (UNKNOWN_ERROR): Without reason
                daswetter.0
                	2022-01-02 11:47:36.473	error	force terminate
                dwd.0
                	2022-01-02 12:04:05.693	error	DB closed
                dwd.0
                	2022-01-02 12:04:05.693	error	Error: DB closed at Redis.sendCommand (/opt/iobroker/node_modules/ioredis/built/redis/index.js:628:24) at Redis.get (/opt/iobroker/node_modules/ioredis/built/commander.js:122:25) at StateRedisClient.setState (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:479:40) at Adapter.setForeignState (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6531:35)
                dwd.0
                	2022-01-02 12:04:05.682	error	unhandled promise rejection: DB closed
                dwd.0
                	2022-01-02 12:04:05.677	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                dwd.0
                	2022-01-02 12:04:05.669	warn	get state error: Connection is closed.
                Steuern dann indem Fall nur Aktoren, Motoren usw. wenn ich Werte in deinen DP schreibe über aktualisieren, dann ändere ich das mal ab.
                Frag mich halt warum in der Log steht, das er die DP's nicht finden kann, aber dennoch da sind.
                Sollten hier nicht bei erneutem Triggern die Timer gestoppt werden ? Den letzten Timer hab ich gelöscht oben angepasst. Im Kalender Script habe ich auf aktualisieren gestellt.
                EDIT::
                Hab jetzt mal nebenher das alte System laufen,wenn ich dort unter Objekte etwas anklicke ist innerhalb einer Sekunde alles da, davor steht zwar auch kurz (null) aber danach sind alle DP's befüllt. Im neuen System dauert das schon merklich länger, bis dort Daten erscheinen.
                Hier scheint doch gewaltig was nicht zu stimmen, mehr Leistung und es läuft träger ?
                backitup.0
                	2022-01-02 13:26:26.450	warn	slow connection to states DB. Still waiting ...
                backitup.0
                	2022-01-02 13:26:21.462	warn	slow connection to objects DB. Still waiting ...
                host.iobroker
                	2022-01-02 13:26:14.953	info	instance system.adapter.backitup.0 started with pid 12231
                host.iobroker
                	2022-01-02 13:26:09.004	info	Do not restart adapter system.adapter.backitup.0 because desired by instance
                host.iobroker
                	2022-01-02 13:26:09.004	error	instance system.adapter.backitup.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                host.iobroker
                	2022-01-02 13:25:56.249	info	stopInstance system.adapter.backitup.0 killing pid 745
                host.iobroker
                	2022-01-02 13:25:54.793	info	stopInstance system.adapter.backitup.0 send kill signal
                Das spiegelt sich doch wieder an den DP's die so träge reagieren und die Werte zeigen, daher bestimmt auch die Fehler aus dem Script, das er den Punkt angeblich nicht finden kann.
                • H-a-m-i
                  H-a-m-i last edited by H-a-m-i
                  Guten Morgen,
                  ich nutze ein Skript hier ausm Forum und bekomme für jeden eingelesenen Datenpunkt immer den Fehler
                  javascript.0 2023-11-02 04:21:39.311	warn	Read-only state "javascript.0.GoogleSheets.........." has been written without ack-flag with value
                  Wie ich hier im Thread gelesen habe, liegt es wohl an, danach folgenden, Updates des js-controller. Ich habe keine Ahnung vom "Programmieren" und möchte den folgenden Post auf dieses Skript übernehmen:
                  @foxriver76 sagte in iob 3.3.4. Read-only state has been written without ack-flag:
                  @joergh sagte in iob 3.3.4. Read-only state has been written without ack-flag:
                  adapter.setState(path+'.currentPower', data["Watt"]);
                  adapter.setState(path+'.currentPower', data["Watt"], true);
                  in dem Skript befindet sich setState in den folgenden beiden Abschnitten:
                                              createState(lpFinalState, {'name':name + ': ' + cleanString2(arrTableHeader[k]), 'type':'string', 'read':true, 'write':false, 'role':'info', 'def':'' }, function() {
                                                  if (!isLikeEmpty(lpEntry && (typeof lpEntry === 'string') ) ) {
                                                      setState(lpFinalState, lpEntry);
                    jsonResult += ']';
                              createState(STATE_PATH + '.jsonTable', {'name':'JSON Table', 'type':'string', 'read':true, 'write':true, 'role':'state', 'def':'' }, function() {
                                  setState(STATE_PATH + '.jsonTable', jsonResult);
                  Muss ich das bei beiden ändern? Und kann mir bitte einer sagen, ob das dann so richtig wäre:
                                                      setState(lpFinalState, lpEntry, true);
                  und
                                  setState(STATE_PATH + '.jsonTable', jsonResult, true);
                  Nicht, dass ich damit mehr kaputt mache als ich repariere...
                    ticaki Developer @H-a-m-i last edited by
                    @h-a-m-i
                    Die Änderungen sind richtig.
                    • H-a-m-i
                      Prima, dankeschön!
                      blue231181 1 Reply Last reply Reply Quote 0
                      • blue231181
                        blue231181 @H-a-m-i last edited by blue231181
                        Hallo zusammen, ich hänge mich hier einmal an. Seit 3 Jahren lief mein Skript nun sehr gut. Jetzt bekomme ich folgende Fehlermeldung:
                        Read-only state "0_userdata.0.Alexa-History-Script.JSON_Table" has been written without ack-flag with value
                        Ich habe von Programmieren leider keine Ahnung, weis jemand wo ich was umschreiben muss...?
                        Edit:
                        Ich nutze dieses Skript:
                        https://github.com/Mic-M/iobroker-alexa-history-vis-script/blob/master/alexa-history-vis-script.js
                          ticaki Developer @blue231181 last edited by
                          @blue231181 sagte in iob 3.3.4. Read-only state has been written without ack-flag:
                          Ergänze/Ändere das object von 0_userdata.0.Alexa-History-Script.JSON_Table im Objektbrowser so das im common: auch write: true steht.
                          blue231181 1 Reply Last reply Reply Quote 1
                          • blue231181
                            blue231181 @ticaki last edited by
                            @ticaki
                            "common": "write: true"{
                            So? dann kann ich nicht speichern
                              ticaki Developer @blue231181 last edited by ticaki
                              @blue231181
                              common: {
                                write: true
                              den rest natürlich lassen du müsstest eigentlich nur write: true und einen Zeilenumbruch einfügen.
                              • blue231181
                                @ticaki Danke
                                51
                                7975
