    4. Admin über iobroker.pro nicht aufrufbar?
      docsnyder7 @docsnyder7 last edited by docsnyder7
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: evccpi
               Icon name: computer
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       19:19:33 up  1:43,  3 users,  load average: 1.99, 1.34, 1.05
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Thu 2024-01-18 19:19:33 CET
                 Universal time: Thu 2024-01-18 18:19:33 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: yes
      Warning: The system is configured to read the RTC time in the local time zone.
               This mode cannot be fully supported. It will create various problems
               with time zone changes and daylight saving time adjustments. The RTC
               time is never updated, it relies on external facilities to maintain it.
               If at all possible, use RTC in UTC by calling
               'timedatectl set-local-rtc 0'.
      *** User and Groups ***
      docsn
      /home/docsn
      docsn adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            7.8G        2.3G        4.2G         21M        1.3G        5.4G
      Swap:            99M          0B         99M
      Total:          7.9G        2.3G        4.3G
               7811 M total memory
               2304 M used memory
               2734 M active memory
                572 M inactive memory
               4196 M free memory
                137 M buffer memory
               1171 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
        UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
      * deconz-init.service   loaded failed failed deCONZ: ZigBee gateway -- Initialisation
      * deconz-update.service loaded failed failed deCONZ: ZigBee gateway -- Update Service
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      2 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4      459G   12G  428G   3% /
      devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     1.6G  1.3M  1.6G   1% /run
      /dev/sda1      vfat      255M   31M  225M  13% /boot
      tmpfs          tmpfs     782M   20K  782M   1% /run/user/1000
      [Thu Jan 18 17:36:05 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:98:BE:6A vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=5f70fa40-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Thu Jan 18 17:36:08 2024] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
      [Thu Jan 18 17:36:08 2024] EXT4-fs (sda2): write access will be enabled during recovery
      [Thu Jan 18 17:36:09 2024] EXT4-fs (sda2): recovery complete
      [Thu Jan 18 17:36:09 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Thu Jan 18 17:36:09 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Thu Jan 18 17:36:11 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      5.3G    /var/
      4.4G    /var/log
      4.1G    /var/log/journal/82971e2b59e04cc6823b9b47e5bb8656
      619M    /var/cache
      Archived and active journals take up 4.0G in the file system.
      /opt/iobroker/backups:
      107M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      405M    /opt/iobroker/iobroker-data/
      333M    /opt/iobroker/iobroker-data/files
      67M     /opt/iobroker/iobroker-data/files/javascript.admin
      48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
      48M     /opt/iobroker/iobroker-data/backup-objects
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      22M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.b5f6766c.js.map
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      18M     /opt/iobroker/iobroker-data/objects.jsonl
      USB-Devices by-id:
      /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_A10MKTHB-if00-port0
      /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2598659-if00
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 1001
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.12.0
      javascript:     7.1.6
      Adapters from github:   4
      Adapter State
      + system.adapter.admin.0                  : admin                 : evccpi                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : evccpi                                   -  enabled
        system.adapter.awattar.0                : awattar               : evccpi                                   -  enabled
      + system.adapter.backitup.0               : backitup              : evccpi                                   -  enabled
      + system.adapter.cloud.0                  : cloud                 : evccpi                                   -  enabled
        system.adapter.daswetter.0              : daswetter             : evccpi                                   -  enabled
      + system.adapter.deconz.0                 : deconz                : evccpi                                   -  enabled, port: 80
        system.adapter.devices.0                : devices               : evccpi                                   -  enabled
      + system.adapter.discovery.0              : discovery             : evccpi                                   -  enabled
        system.adapter.dwd.0                    : dwd                   : evccpi                                   -  enabled
      + system.adapter.email.0                  : email                 : evccpi                                   -  enabled
      + system.adapter.evcc.0                   : evcc                  : evccpi                                   -  enabled, port: 7070
        system.adapter.feiertage.0              : feiertage             : evccpi                                   -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : evccpi                                   -  enabled
        system.adapter.fullybrowser.0           : fullybrowser          : evccpi                                   - disabled
      + system.adapter.geofency.0               : geofency              : evccpi                                   -  enabled, port: 7999, bind: 0.0.0.0
      + system.adapter.history.0                : history               : evccpi                                   -  enabled
      + system.adapter.homee.0                  : homee                 : evccpi                                   -  enabled
        system.adapter.ical.0                   : ical                  : evccpi                                   -  enabled
        system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : evccpi                                   -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : evccpi                                   -  enabled
      + system.adapter.iot.0                    : iot                   : evccpi                                   -  enabled
      + system.adapter.javascript.0             : javascript            : evccpi                                   -  enabled
      + system.adapter.modbus.0                 : modbus                : evccpi                                   -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : evccpi                                   -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.net-tools.0              : net-tools             : evccpi                                   - disabled
        system.adapter.ocpp.0                   : ocpp                  : evccpi                                   - disabled, port: 8887
      + system.adapter.onvif.0                  : onvif                 : evccpi                                   -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
        system.adapter.openweathermap.0         : openweathermap        : evccpi                                   -  enabled
        system.adapter.ping.0                   : ping                  : evccpi                                   - disabled
        system.adapter.psa.0                    : psa                   : evccpi                                   - disabled
        system.adapter.pushover.0               : pushover              : evccpi                                   - disabled
      + system.adapter.pvforecast.0             : pvforecast            : evccpi                                   -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : evccpi                                   -  enabled
      + system.adapter.scenes.0                 : scenes                : evccpi                                   -  enabled
        system.adapter.schoolfree.0             : schoolfree            : evccpi                                   -  enabled
      + system.adapter.shelly.0                 : shelly                : evccpi                                   -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shelly.1                 : shelly                : evccpi                                   -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shuttercontrol.0         : shuttercontrol        : evccpi                                   -  enabled
        system.adapter.telegram.0               : telegram              : evccpi                                   - disabled, port: 8443, bind: 0.0.0.0
      + system.adapter.time-switch.0            : time-switch           : evccpi                                   -  enabled
      + system.adapter.tr-064.0                 : tr-064                : evccpi                                   -  enabled
      + system.adapter.tr-064.1                 : tr-064                : evccpi                                   -  enabled
      + system.adapter.tr-064.2                 : tr-064                : evccpi                                   -  enabled
      + system.adapter.tr-064.3                 : tr-064                : evccpi                                   -  enabled
      + system.adapter.tr-064.5                 : tr-064                : evccpi                                   -  enabled
      + system.adapter.tr-064.6                 : tr-064                : evccpi                                   -  enabled
      + system.adapter.tr-064.7                 : tr-064                : evccpi                                   -  enabled
      + system.adapter.tr-064.8                 : tr-064                : evccpi                                   -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : evccpi                                   -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : evccpi                                   -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : evccpi                                   -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : evccpi                                   -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : evccpi                                   -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : evccpi                                   -  enabled
        system.adapter.vis-weather.0            : vis-weather           : evccpi                                   -  enabled
        system.adapter.vis.0                    : vis                   : evccpi                                   -  enabled
      + system.adapter.web.0                    : web                   : evccpi                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
      Adapter    "awattar"      : 1.0.6    , installed 1.0.6
      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
      Adapter    "daswetter"    : 3.1.12   , installed 3.1.12
      Adapter    "deconz"       : 1.3.23   , installed 1.3.23
      Adapter    "email"        : 1.2.1    , installed 1.2.1
      Adapter    "evcc"         : 0.1.1    , installed 0.1.1
      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
      Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
      Adapter    "fullybrowser" : 3.0.9    , installed 3.0.9
      Adapter    "geofency"     : 1.2.4    , installed 1.2.4
      Adapter    "homee"        : 1.2.0    , installed 1.2.0
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "modbus"       : 6.0.1    , installed 6.0.1
      Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
      Adapter    "ocpp"         : 0.12.5   , installed 0.12.5
      Adapter    "onvif"        : 1.1.1    , installed 1.1.1
      Adapter    "openweathermap": 0.4.5   , installed 0.4.5
      Adapter    "psa"          : 0.0.11   , installed 0.0.11
      Adapter    "pushover"     : 3.0.6    , installed 3.0.6
      Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
      Adapter    "schoolfree"   : 1.1.3    , installed 1.1.3
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
      Adapter    "telegram"     : 3.0.1    , installed 3.0.1
      Adapter    "trashschedule": 2.3.0    , installed 2.3.0
      Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
      Adapter    "vis-materialdesign": 0.5.9, installed 0.5.94
      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Objects and States
      Objects:        9093
      States:         7052
      Hit:1 http://deb.debian.org/debian bullseye InRelease
      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 https://apt.grafana.com stable InRelease
      Hit:6 http://phoscon.de/apt/deconz bullseye InRelease
      Get:7 https://dl.cloudsmith.io/public/evcc/stable/deb/debian bullseye InRelease [5127 B]
      Hit:8 https://deb.nodesource.com/node_18.x nodistro InRelease
      Fetched 5127 B in 2s (2236 B/s)
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       13901      437/deCONZ
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          3684       615/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          977        585/cupsd
      tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       15856      437/deCONZ
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       87708      7448/iobroker.js-co
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       87715      7448/iobroker.js-co
      tcp        0      0 127.0.0.1:6010          0.0.0.0:*               LISTEN      1000       21093      2542/sshd: docsn@pt
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       91169      7755/io.mqtt.0
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       91168      7755/io.mqtt.0
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       86999      7614/io.shelly.0
      tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          3758       614/vncserver-x11-c
      tcp6       0      0 :::7070                 :::*                    LISTEN      116        24628      2604/evcc
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        15664      595/influxd
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       88186      7467/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       89461      7906/io.web.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          3686       615/sshd: /usr/sbin
      tcp6       0      0 ::1:6010                :::*                    LISTEN      1000       21092      2542/sshd: docsn@pt
      tcp6       0      0 :::8887                 :::*                    LISTEN      116        23142      2604/evcc
      tcp6       0      0 :::5021                 :::*                    LISTEN      116        23141      2604/evcc
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          976        585/cupsd
      tcp6       0      0 :::5900                 :::*                    LISTEN      0          3757       614/vncserver-x11-c
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15555      494/dhcpcd
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          15538      639/cups-browsed
      udp        0      0 192.168.178.57:5353     0.0.0.0:*                           1001       85920      7554/io.tr-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        23484      2604/evcc
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        879        432/avahi-daemon: r
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       87964      7629/io.shelly.1
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       91616      8104/io.deconz.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       15871      437/deCONZ
      udp        0      0 0.0.0.0:55503           0.0.0.0:*                           108        881        432/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          15567      494/dhcpcd
      udp6       0      0 :::5353                 :::*                                116        23485      2604/evcc
      udp6       0      0 :::5353                 :::*                                108        880        432/avahi-daemon: r
      udp6       0      0 :::50542                :::*                                108        882        432/avahi-daemon: r
      udp6       0      0 :::1900                 :::*                                1001       91618      8104/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1001       91617      8104/io.deconz.0
      2024-01-18 19:16:17.662  - info: shelly.1 (7629) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2024-01-18 19:16:32.662  - info: shelly.1 (7629) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2024-01-18 19:16:47.667  - info: shelly.1 (7629) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2024-01-18 19:17:02.664  - info: shelly.1 (7629) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2024-01-18 19:17:17.675  - info: shelly.1 (7629) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2024-01-18 19:17:32.676  - info: shelly.1 (7629) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2024-01-18 19:17:47.673  - info: shelly.1 (7629) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2024-01-18 19:18:02.674  - info: shelly.1 (7629) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2024-01-18 19:18:17.670  - info: shelly.1 (7629) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2024-01-18 19:18:32.672  - info: shelly.1 (7629) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2024-01-18 19:18:47.671  - info: shelly.1 (7629) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2024-01-18 19:19:02.670  - info: shelly.1 (7629) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2024-01-18 19:19:17.674  - info: shelly.1 (7629) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2024-01-18 19:19:32.677  - info: shelly.1 (7629) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2024-01-18 19:20:00.018  - debug: shuttercontrol.0 (7937) calculate astrodata ...
      2024-01-18 19:20:00.019  - debug: shuttercontrol.0 (7937) Sun Azimut: 266.5°
      2024-01-18 19:20:00.019  - debug: shuttercontrol.0 (7937) Sun Elevation: -23.7°
      2024-01-18 19:20:00.072  - info: host.evccpi instance system.adapter.dwd.0 started with pid 10883
      2024-01-18 19:20:02.691  - info: shelly.1 (7629) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2024-01-18 19:20:03.931  - info: dwd.0 (10883) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.19.0, js-controller: 5.0.17
      2024-01-18 19:20:08.035  - info: dwd.0 (10883) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-01-18 19:20:08.667  - info: host.evccpi instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-01-18 19:20:17.697  - info: shelly.1 (7629) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2024-01-18 19:20:32.695  - info: shelly.1 (7629) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
      2024-01-18 19:20:47.709  - info: shelly.1 (7629) [CoAP Server] Device is blacklisted: SHPLG-S#3CE90EC7EC37#2
        Thomas Braun Most Active @docsnyder7 last edited by
        @docsnyder7
        X-Server:               true
        Boot Target:            graphical.target
        Desktop ausschalten.
        Die Echtzeituhr stellt man nicht auf die Lokalzeit sondern auf die Z-Zeit ein. Im Winter eine Stunde zurück.
          docsnyder7 @Thomas Braun last edited by
          @thomas-braun said in Admin über iobroker.pro nicht aufrufbar?:
          @docsnyder7
          >sudo systemctl set-default multi-user.target
          Damit?
          sudo timedatectl set-local-rtc 0
          Damit?
            Thomas Braun Most Active @docsnyder7 last edited by Thomas Braun
            @docsnyder7
            Ich denke ja. timectl müsste ich jetzt aber auch nachschauen. Kann man in der Regel auch irgendwo im BIOS/UEFI setzen.
            Edith! Das ist ein Pi mit Echtzeit? Keine Ahnung, hatte ich noch nicht unter den Fingern.
              docsnyder7 @Thomas Braun last edited by docsnyder7
              Hab ich alles erledigt... zugriff über iobroker.pro weiterhin nicht möglich mit og Meldung
              bekomme aber diese meldung im iobroker
              Admin instance not defined. Please specify the lovelace instance in settings
                Homoran Global Moderator Administrators @docsnyder7 last edited by
                @docsnyder7 sagte in Admin über iobroker.pro nicht aufrufbar?:
                von lovelace war bisher nicht die Rede.
                Wo spielt das denn mit?
                  docsnyder7 @Homoran last edited by docsnyder7
                  das weiß ich nicht.. hab mit loveace nicht annähernd was im Schilde
                  das sind die cloud einstellung die ich zu loveace gefunden habe
                    und da ist der zugriff auf admin verboten
                      Ok.. hab ich erlaubt...
                      Resultat:
                      Cannot activate admin.0 for cloud, because authentication is enabled. Please create extra instance for cloud
                      gab es da ne Veränderung?
                        nein, das war schon immer so.
                        die verwendete web Instanz darf kein https sein
                          dh in den Einstellungen der Instanz muss noch wie webinstanz angegeben werden?
                          muss da noch was geändert werden?
                          danke schonmal bis hierher @Homoran
                          soll es an der eingeschalteten authentification liegen? in der Admin instanz?
                            ja!
                            nein!
                            und nicht die wichtigsten Infos abschneiden!
                            Was steht in der Titelzeile?
                              was meinst du mit wichtigen Infos?
                                @homoran sagte in Admin über iobroker.pro nicht aufrufbar?:
                                jetzt ist es vollständig!
                                es geht um web! nicht um admin
                                  saar1and last edited by saar1and
                                  Ich würde mich hier gerne anhängen.
                                  Kann kein admin über die Iobroker Cloud mit Pro Zugang öffnen.
                                  Vis Editor und Float gehen nur bei Admin kommt Fehler 404.
                                  Gibt es hier mittlerweile eine Lösung?
                                  Edit: Lösung gefunden: Bei den Adpater Einstellungen von Admin Hacken bei
                                  Authentifizierung entfernen, Benutzer auswählen (nicht den Admin Benutzer) dann gings bei mir 😃
                                    docsnyder7 @saar1and last edited by
                                    @saar1and
                                    Jepp... genau das war der Haken zuviel
                                    501
