    4. Frigate Adapter für ioBroker
    • Wal
      Wal Developer @dragst3r last edited by
      @dragst3r ,
      schau ich mir mal zeitnah an.
        dragst3r @Wal last edited by
        @wal ,
        falls meine Änderungen in Github nicht abgeschickt worden sind, reicht schon folgendes, markiert mit // NEU bzw. anders
         async onEventChange(obj) {
                const extractedJSON = JSON.parse(obj.val);
                const beforecamera = extractedJSON.before.camera;
                const before = extractedJSON.before; // NEU
                const beforelabel = extractedJSON.before.label;
                const afterid = extractedJSON.after.id;
                const topscore = extractedJSON.after.top_score;
                const eventtype = extractedJSON.type;
                const id1 = beforecamera + '.event';
                const id2 = beforecamera + '.objects.' + beforelabel;
                const websnap = weburl + '/api/events/' + afterid + '/snapshot.jpg';
                const webclip = weburl + '/api/events/' + afterid + '/clip.mp4';
                const bsnap = before.has_snapshot; // NEU bzw. anders
                const bclip = before.has_clip; // NEU bzw. anders
                if ((bsnap == null) || (bclip == null)) {
                    this.log.info('restart MQTT Broker please !!!');
                    return;
                this.log.debug(`Snap: ${bsnap}`);
                this.log.debug(`Clip: ${bclip}`);
                this.log.debug(`changed: ${obj.val}`);
                try {
                    if (eventtype == 'new') {
                        //      Bewegung erkannt
                        this.setState('event', { val: true, ack: true });
                        //       Kamera erkannt
                        await this.setObjectNotExistsAsync(id1, {
                            type: 'state',
                            common: {
                                name: 'Camera detected',
                                type: 'boolean',
                                role: 'indicator',
                                read: true,
                                write: false,
                                def: false
                            native: {},
                        this.setState(id1, { val: true, ack: true });
                        //       Objekt erkannt
                        await this.setObjectNotExistsAsync(id2 + '.event', {
                            type: 'state',
                            common: {
                                name: beforelabel + ' detected',
                                type: 'boolean',
                                role: 'indicator',
                                read: true,
                                write: false,
                                def: false
                            native: {},
                        this.setState(id2 + '.event', { val: true, ack: true });
                    } else if (eventtype == 'end') {
                        //         Event ID
                        await this.setObjectNotExistsAsync(id2 + '.id', {
                            type: 'state',
                            common: {
                                type: 'string',
                                role: 'value',
                                read: true,
                                write: false,
                                def: 'none'
                            native: {},
                        this.setState(id2 + '.id', { val: afterid, ack: true });
                        //         Cam + Event ID
                        await this.setObjectNotExistsAsync(id2 + '.camid', {
                            type: 'state',
                            common: {
                                type: 'string',
                                role: 'value',
                                read: true,
                                write: false,
                                def: 'none'
                            native: {},
                        this.setState(id2 + '.camid', { val: beforecamera + '-' + afterid, ack: true });
                        this.setState('lastcamid', { val: beforecamera + '-' + afterid, ack: true });
                        this.setState('lastidurl', { val: websnap, ack: true });
                        //           WebURL
                        const anz = this.config.webnum;
                        if (bsnap == true) { // NEU bzw. anders
                            for (let i = 0; i < anz; i++)
                                await this.setObjectNotExistsAsync(id2 + '.web.snap.snap_' + i.toString(), {
                                    type: 'state',
                                    common: {
                                        name: 'Snapshot WebUrl ' + i.toString(),
                                        type: 'string',
                                        role: 'value',
                                        read: true,
                                        write: false,
                                        def: ''
                                    native: {},
                            for (let i = anz - 1; i > -1; i--) {
                                if (i == 0) {
                                    this.setState(id2 + '.web.snap.snap_' + i.toString(), { val: websnap, ack: true });
                                } else {
                                    const str = await this.getStateAsync(id2 + '.web.snap.snap_' + (i - 1).toString());
                                    if (str != null)
                                        this.setState(id2 + '.web.snap.snap_' + i.toString(), { val: str.val, ack: true });
                        if (bclip == true) { // NEU bzw. anders
                                await this.setObjectNotExistsAsync(id2 + '.web.clip.clip_' + i.toString(), {
                                    type: 'state',
                                    common: {
                                        name: 'Clip WebUrl ' + i.toString(),
                                        type: 'string',
                                        role: 'value',
                                        read: true,
                                        write: false,
                                        def: ''
                                    native: {},
                                if (i == 0) {
                                    this.setState(id2 + '.web.clip.clip_' + i.toString(), { val: webclip, ack: true });
                                } else {
                                    const str = await this.getStateAsync(id2 + '.web.clip.clip_' + (i - 1).toString());
                                    if (str != null)
                                        this.setState(id2 + '.web.clip.clip_' + i.toString(), { val: str.val, ack: true });
                        //       Erkennungsrate
                        await this.setObjectNotExistsAsync(id2 + '.score', {
                            type: 'state',
                            common: {
                                type: 'number',
                                read: true,
                                write: false,
                                role: 'value.score',
                                unit: '%',
                                def: 0
                            native: {},
                        this.setState(id2 + '.score', { val: Math.round(topscore * 100), ack: true });
                        //      Reset Event States
                        this.setState('event', { val: false, ack: true });
                        this.setState(id1, { val: false, ack: true });
                        this.setState(id2 + '.event', { val: false, ack: true });
                } catch (error) {
                    this.log.error(error);
        • Wal
          Wal Developer last edited by
          Version 2.8 mit den Änderungen von @dragst3r erstellt.
            @wal danke, bei Github heiße ich allerdings anders 🙂 und zwar Obsthaendler falls es wichtig ist.
            • U
              uwe72 @dragst3r last edited by
              Kann mir jemand helfen? Frigate läuft. In ioBroker habe ich den Frigate Adapter installiert.
              Was muss ich noch machen. MQTT-Client Adapter installieren? Wie muss ich den konfigurieren?
              Möchte benachrichtigt werden, wenn Frigate einen Alarm auslöst.
              DANKE!
              • Wal
                Wal Developer @uwe72 last edited by Wal
                @uwe72 ,
                wenn du noch kein MQTT-Broker am laufen hast, den MQTT-Adapter als Server einrichten.
                Danach Frigate so einrichten das er sich am MQTT-Server anmeldet und wenn das läuft den Frigate-Adapter auf "mqtt.0.frigate" incl. IP/Port von Frigate konfigurieren.
                • U
                  uwe72 @Wal last edited by
                  @wal Sorry, ich wollte fragen, ob Du mir helfen kannst den MQTT-Server einzurichten? Hast Du mir Screenshots von den 3 Reitern?
                  • Wal
                    @uwe72 ,
                    müsste so passen, ohne Gewähr.
                    wendy2702 U 2 Replies Last reply Reply Quote 0
                    • wendy2702
                      wendy2702 @Wal last edited by
                      @wal Sorry: Offtopic aber hattest du nicht ne Anleitung zu Frigate installation Proxmox mit Corel USB erstellt?
                      Habe mir heute auch den Corel USB bestellt und wollte Frigate mal testen bevor ich Motioneye in Rente schicke.
                      Hast du zufällig den Link dahin parat?
                      Wal M 2 Replies Last reply Reply Quote 0
                      • Wal
                        Wal Developer @wendy2702 last edited by
                        @wendy2702 sagte in Test Frigate Adapter 0.2.8:
                        Nein,war eine für eine coral dual tpu.
                          martinschm @wendy2702 last edited by
                          @wendy2702 said in Test Frigate Adapter 0.2.8:
                          Hab den USB Coral und hab damit auch motioneye in Rente geschickt. Leider hab ich die Schritte nicht dokumentiert, da ich mich selber ein wenig durch gewurschtelt habe. Insgesamt war ich als Docker und frigate Newbie aber überrascht, das ich es so schnell ans Laufen bekommen habe.
                          Bin bisher super zufrieden, die Erkennung is echt gut und endlich werde ich nicht mehr bei jeder "Bewegung" vor der Haustür mit Bildern per Telegram bombardiert.
                          • U
                            uwe72 @Wal last edited by uwe72
                            @wal DANKE!
                            Ich scheine einen Schritt weiter zu sein.
                              tombox @Wal last edited by tombox
                              @Wal
                              Ich habe den Adapter neu geschrieben.
                              • Er kommt ohne MQTT adapter aus, somit werden die Daten schneller transportiert
                              • Die snapshots können direkt in die vis integriert werden
                              • Integrierte Notification Funktion für Snapshots und Clips
                              Achtung bei der Installations werden die alten Datenpunkte gelöscht es muss also Anpassung für Skripte oder Vis durchgeführt werden
                              Installation für Test:
                              1. Unter Adapter Experten Modus aktivieren:
                              2. Unter Adapter das Github Icon klicken:
                              3. Benutzerdefiniert auswählen und die Url https://github.com/iobroker-community-adapters/ioBroker.frigate einfügen.
                              Bitte testen und gerne zusätzliche Features äußern.
                              Anleitung:
                              https://github.com/iobroker-community-adapters/ioBroker.frigate/blob/main/README.md
                              Wal H 2 Replies Last reply Reply Quote 2
                              • Wal
                                Wal Developer @tombox last edited by
                                @tombox,
                                sehr gut gemacht.
                                @tombox sagte in Test Frigate Adapter 0.2.8:
                                Die Möglichkeit erst ab einem bestimmten Score die z.B. Telegram Nachricht zu senden und wenn man die die letzten Urls im Ringpuffer auch wieder hätten wäre auch nicht schlecht.
                                  @wal minimum score habe ich eingebaut und die letzten events sind unter events.history bzw als json events.history.json
                                  Wal 3 Replies Last reply Reply Quote 1
                                  • Wal
                                    Hatte ich glatt übersehen, danke.
                                    • Wal
                                      Score funktioniert, saubere Arbeit.
                                        @wal Du kannst ja noch ein wenig testen ob was fehlt oder nicht funktioniert. Wenn es für dich ok ist würden wir das als 1.0.0 Release mit dem Update Hinweis das die alte Struktur gelöscht wird
                                        Wal 2 Replies Last reply Reply Quote 0
                                        • Wal
                                          Machst du dann noch einen neuen Support Thread auf ? Würde dann hier auf den verlinken.
                                          • Wal
                                            @tombox ,
                                            habe jetzt die Anbindung in vis und die Erkennung getestet, das funktioniert alles perfekt.
                                            Ich wüsste auch nicht was man noch verbessern könnte, Respekt was du da in 1Woche erstellt hast.
                                            Die Benachrichtigung direkt an Telegramm bei einem bestimmten Score finde ich super.
                                            Ich denke du kannst die 1.0.0 Release auf die Menschheit loslassen. 😉
                                            367
                                            98772
