    4. iobroker + docker + MACVLAN - fixe IP für bridge möglich ?
    • stephan1827
      stephan1827 @Marc Berg last edited by
      @marc-berg anscheinend kann der container sich nicht mehr mit der Datenbank verbinden, das verstehe ich nicht denn die Datenbank ist die interne von iobroker
      -------------------------     2024-01-19 18:54:37      -------------------------
      -----              Welcome to your ioBroker Docker container!              -----
      -----                    Startupscript is now running!                     -----
      -----                          Please be patient!                          -----
      -----                          System Information                          -----
      -----                    arch:                x86_64                       -----
      -----                    hostname:            iobroker                     -----
      -----                          Version Information                         -----
      -----                    image:               v9.1.0                       -----
      -----                    build:               2024-01-19T13:46:03+00:00    -----
      -----                    node:                v18.19.0                     -----
      -----                    npm:                 9.2.0                        -----
      -----                        Environment Variables                         -----
      -----                    DEBUG:               true                         -----
      -----                    SETGID:              1000                         -----
      -----                    SETUID:              1000                         -----
      !!!!                            DEBUG LOG ACTIVE                            !!!!
      !!!!               Environment variable DEBUG is set to true.               !!!!
      !!!! This will extend the logging output and may slow down container start. !!!!
      !!!!          Please make sure to deactivate if no longer needed.           !!!!
      !!!!     For more information see ioBroker Docker image documentation:      !!!!
      !!!!           https://docs.buanet.de/iobroker-docker-image/docs/           !!!!
      -----                   Step 1 of 5: Preparing Container                   -----
      -----             Step 2 of 5: Detecting ioBroker Installation             -----
      Existing installation of ioBroker detected in "/opt/iobroker".
      -----             Step 3 of 5: Checking ioBroker Installation              -----
      (Re)setting permissions (This might take a while! Please be patient!)... Done.
      [DEBUG] Checking multihost settings...
      [DEBUG] No multihost settings detected.
      [DEBUG] Done.
      [DEBUG] Checking custom objects db settings...
      [DEBUG] No custom objects db settings detected.
      [DEBUG] Done.
      [DEBUG] Checking custom states db settings...
      [DEBUG] No custom states db settings detected.
      [DEBUG] Done.
      Checking database connection... Failed.
      [DEBUG] Error message:
      [DEBUG] No connection to databases possible ...
      Please check your configuration and try again.
      For more information see ioBroker Docker image docs (https://docs.buanet.de/iobroker-docker-image/docs).
      [DEBUG] Debug mode prevents the container from exiting on errors.
      [DEBUG] This enables you to investigate or fix your issue on the command line.
      [DEBUG] If you want to stop or restart your container you have to do it manually.
      [DEBUG] IoBroker is not running!
      Glasfaser 2 Replies Last reply Reply Quote 0
      • Glasfaser
        Glasfaser @stephan1827 last edited by
        @stephan1827 sagte in iobroker + docker + MACVLAN - fixe IP für bridge möglich ?:
        ich tippe mal ...
        es funktioniert mit einem neuen ioBroker Container , ohne den alten Ordner zu mappen !
        stephan1827 1 Reply Last reply Reply Quote 0
        • stephan1827
          stephan1827 @Glasfaser last edited by
          @glasfaser sagte in iobroker + docker + MACVLAN - fixe IP für bridge möglich ?:
          ich tippe mal ...
          Das mag sein, aber das hilft mir leider nicht weiter. Ich möchte gerne den bestehenden Container behalten.
          • Glasfaser
            Das mag sein,
            selber mal getestet ... ob es auch so bei dir ist !?
              drapo @stephan1827 last edited by drapo
              @stephan1827 also nur um es zu verstehen. Dein iobroker läuft nicht auf der redis DB sondern mit der standard DB von iobroker korrekt?
              hast du dem iobroker auch mal das interne bridge netzwerk hinzugefügt damit er intern mit den anderen containern kommunizieren kann?
              ausserdem würde ich dir vorschlagen den alten container nochmal laufen zu lassen und deine daten auf einem laufwerk auf dem nas zu mappen. dann kannst du den container immer updaten ohne deine daten zu verlieren. siehe bild
              • Marc Berg
                Marc Berg Most Active last edited by
                Ich kenne diesen Fehler nur daher, dass die lokalen Ports 9000/9001 nicht erreichbar sind, denn darauf hört die lokale Datenbank. Das passiert gern mal, wenn auf Host umgestellt wird, der Host aber die Ports schon anderweitig belegt. Das kann ja aber bei dir nicht der Fall sein. Trotzdem tippe ich auf irgendwelchen Netzwerktrouble. Ist der Container über die MACVLAN Schnittstelle erreichbar? Was sagt netstat?
                • stephan1827
                  stephan1827 @drapo last edited by
                  @drapo sagte in iobroker + docker + MACVLAN - fixe IP für bridge möglich ?:
                  Das stimmt
                  Eine bridge habe ich
                  Das ist bei mir schon so
                  • Glasfaser
                    Glasfaser @Glasfaser last edited by
                    @stephan1827
                    Bitte jede Frage beantworten ! , auf spekulationen kommen wir hier nicht weiter
                    Was ist hiermit :
                    Das mag sein,
                    • Glasfaser
                      @stephan1827
                      Zeige mal die Ausgabe von :
                      docker ps
                      • stephan1827
                        So ich habe jetzt mal parallel einen docker mit macvlan neu aufgesetzt und der läuft einwandfrei bis ich die Backup wieder herstelle. Danach habe ich wieder das gleiche Problem wie vorher. Ich habe darauf geachtet das npm, node und js controller die gleiche Version haben wie vorher.
                        strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/certificatesProps" (strictTypes)
                        strict mode: missing type "object" for keyword "properties" at "#/definitions/certificatesProps" (strictTypes)
                        strict mode: missing type "object" for keyword "required" at "#/definitions/instanceProps" (strictTypes)
                        strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/instanceProps" (strictTypes)
                        strict mode: missing type "object" for keyword "properties" at "#/definitions/instanceProps" (strictTypes)
                        strict mode: missing type "object" for keyword "required" at "#/definitions/objectIdProps" (strictTypes)
                        strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/objectIdProps" (strictTypes)
                        strict mode: missing type "object" for keyword "properties" at "#/definitions/objectIdProps" (strictTypes)
                        ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
                        ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
                        Terminated
                        -------------------------     2024-01-20 12:33:53      -------------------------
                        This is not the first run of this container. Skipping first run preparation.
                        [DEBUG] Done.
                        [DEBUG] Done.
                        [DEBUG] Done.
                        • Glasfaser
                          Glasfaser @stephan1827 last edited by Glasfaser
                          Neuer Container !
                          image: v9.1.0
                          da passt was nicht zusammen ...
                          ich wette du hast diesen Fehler vorhanden :
                          https://forum.iobroker.net/topic/71461/dfsg-nodejs-eingehandelt-hier-die-korrektur
                          Schau nach mit
                          iob diag
                          da kommt bestimmt das raus :
                          NodeJS-Installation
                          usrbinnodejs v18.19.0
                          usrbinnode v18.19.0
                          usrbinnpm 9.2.0
                          usrbinnpx 9.2.0
                          homeiobroker.diag.sh line 281 corepack command not found
                          nodejs is NOT correctly installed
                          nodejs
                          Installed 18.19.0+dfsg-6~deb12u1
                          Candidate 18.19.0+dfsg-6~deb12u1
                          Version table
                          18.19.0+dfsg-6~deb12u1 500
                          500 httpdeb.debian.orgdebian-security bookworm-securitymain amd64 Packages
                          100 varlibdpkgstatus
                          18.19.0-1nodesource1 500
                          500 httpsdeb.nodesource.comnode_18.x nodistromain amd64 Packages
                          • stephan1827
                            @glasfaser Ich habe das mal probiert aber das Ergebnis ist das gleiche. Der Container funktioniert ja auch soweit bis versuche die Backup wieder herzustellen.
                            • Glasfaser
                              Zeige bitte die aktuelle Full Ausgabe von
                              iob diag
                              wo du dein Backup her hast . ( Container )
                              • stephan1827
                                @glasfaser hier ist die Ausgabe von Diag. Wie gesagt, das Ganze läuft, bis ich das Backup zurückspiele. Ist es eigentlich möglich nur einzelne Adapter das Backup zurückzuspielen? Dann könnte ich versuchen das Ganze Stück für Stück zurückzuspielen um zu sehen das die Instanz kaputt macht.
                                Skript v.2023-10-10
                                *** BASE SYSTEM ***
                                Hardware Vendor : Synology
                                Kernel          : x86_64
                                Userland        : amd64
                                Docker          : v9.1.0
                                Virtualization  : Docker
                                Kernel          : x86_64
                                Userland        : amd64
                                Systemuptime and Load:
                                 06:52:15 up 6 days, 15:46,  0 user,  load average: 0.43, 0.62, 0.79
                                CPU threads: 4
                                *** Time and Time Zones ***
                                Wed Jan 24 05:52:15 UTC 2024
                                Wed Jan 24 06:52:15 CET 2024
                                CET +0100
                                Etc/UTC
                                *** User and Groups ***
                                root
                                /root
                                root
                                *** X-Server-Setup ***
                                X-Server:       false
                                Desktop:
                                Terminal:
                                *** MEMORY ***
                                Mem:             12G        5.1G        672M        605M        7.6G        7.3G
                                Swap:           2.1G        1.9G        230M
                                Total:           14G        7.0G        902M
                                        11812 M total memory
                                         4854 M used memory
                                         5216 M active memory
                                         4144 M inactive memory
                                          641 M free memory
                                           21 M buffer memory
                                         7263 M swap cache
                                         2047 M total swap
                                         1828 M used swap
                                          219 M free swap
                                *** FILESYSTEM ***
                                Filesystem             Type   Size  Used Avail Use% Mounted on
                                /dev/mapper/cachedev_0 btrfs  5.3T  3.4T  1.9T  65% /
                                tmpfs                  tmpfs   64M     0   64M   0% /dev
                                tmpfs                  tmpfs  5.8G     0  5.8G   0% /sys/fs/cgroup
                                shm                    tmpfs   64M     0   64M   0% /dev/shm
                                /dev/mapper/cachedev_0 btrfs  5.3T  3.4T  1.9T  65% /opt/iobroker
                                /dev/mapper/cachedev_0 btrfs  5.3T  3.4T  1.9T  65% /etc/hosts
                                tmpfs                  tmpfs  5.8G     0  5.8G   0% /proc/acpi
                                tmpfs                  tmpfs  5.8G     0  5.8G   0% /proc/scsi
                                tmpfs                  tmpfs  5.8G     0  5.8G   0% /sys/firmware
                                TARGET             SOURCE        FSTYPE OPTIONS
                                /                  /dev/mapper/cachedev_0[/@syno/@docker/btrfs/subvolumes/8f61f99191ae24afec750236d3556bdb71cf468d8ad1a1f67b4ce1d5aaaf95ad]       btrfs  rw,nodev,relatime,ssd,synoacl,nospace_cache,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=11933,subvol=/@syno/@docker/btrfs/subvolumes/8f61f99191ae24afec750236d3556bdb71cf468d8ad1a1f67b4ce1d5aaaf95ad
                                |-/opt/iobroker    /dev/mapper/cachedev_0[/@syno/docker/iobroker]        btrfs  rw,nodev,relatime,ssd,synoacl,nospace_cache,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=259,subvol=/@syno/docker
                                |-/etc/resolv.conf /dev/mapper/cachedev_0[/@syno/@docker/containers/6fb14c1d0acc003618c8dd804f894f67ff863ff6c8226945827e6173e507bc0b/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,nospace_cache,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno
                                |-/etc/hostname    /dev/mapper/cachedev_0[/@syno/@docker/containers/6fb14c1d0acc003618c8dd804f894f67ff863ff6c8226945827e6173e507bc0b/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,nospace_cache,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno
                                `-/etc/hosts       /dev/mapper/cachedev_0[/@syno/@docker/containers/6fb14c1d0acc003618c8dd804f894f67ff863ff6c8226945827e6173e507bc0b/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,nospace_cache,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno
                                /var:
                                38M     /var/
                                35M     /var/lib
                                19M     /var/lib/apt/lists
                                19M     /var/lib/apt
                                17M     /var/lib/dpkg
                                /opt/iobroker/backups:
                                4.0G    /opt/iobroker/backups/
                                /opt/iobroker/iobroker-data:
                                50M     /opt/iobroker/iobroker-data/
                                16M     /opt/iobroker/iobroker-data/files
                                13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                                28M     /opt/iobroker/iobroker-data/objects.jsonl
                                6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                                5.2M    /opt/iobroker/iobroker-data/states.jsonl
                                2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                                1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
                                USB-Devices by-id:
                                *** NodeJS-Installation ***
                                /usr/bin/nodejs         v18.19.0
                                /usr/bin/node           v18.19.0
                                /usr/bin/npm            10.2.3
                                /usr/bin/npx            10.2.3
                                /usr/bin/corepack       0.22.0
                                nodejs:
                                  Installed: 18.19.0-1nodesource1
                                  Candidate: 18.19.0-1nodesource1
                                  Version table:
                                        500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
                                 *** 18.19.0-1nodesource1 1001
                                        500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                                        100 /var/lib/dpkg/status
                                     18.18.2-1nodesource1 1001
                                     18.18.1-1nodesource1 1001
                                     18.18.0-1nodesource1 1001
                                     18.17.1-1nodesource1 1001
                                     18.17.0-1nodesource1 1001
                                     18.16.1-1nodesource1 1001
                                     18.16.0-1nodesource1 1001
                                     18.15.0-1nodesource1 1001
                                     18.14.2-1nodesource1 1001
                                     18.14.1-1nodesource1 1001
                                     18.14.0-1nodesource1 1001
                                     18.13.0+dfsg1-1 500
                                        500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                     18.13.0-1nodesource1 1001
                                     18.12.0-1nodesource1 1001
                                     18.11.0-1nodesource1 1001
                                     18.10.0-1nodesource1 1001
                                     18.9.1-1nodesource1 1001
                                     18.9.0-1nodesource1 1001
                                     18.8.0-1nodesource1 1001
                                     18.7.0-1nodesource1 1001
                                     18.6.0-1nodesource1 1001
                                     18.5.0-1nodesource1 1001
                                     18.4.0-1nodesource1 1001
                                     18.3.0-1nodesource1 1001
                                     18.2.0-1nodesource1 1001
                                     18.1.0-1nodesource1 1001
                                     18.0.0-1nodesource1 1001
                                No problems detected
                                Errors in npm tree:
                                *** ioBroker-Installation ***
                                ioBroker Status
                                Core adapters versions
                                js-controller:  4.0.24
                                admin:          6.12.0
                                javascript:     "javascript" not found
                                Adapters from github:   0
                                Adapter State
                                ioBroker-Repositories
                                Installed ioBroker-Instances
                                Objects and States
                                Objects:        1
                                States:         1
                                Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                                Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                                Reading package lists...
                                Pending Updates: 0
                                *** Listening Ports ***
                                tcp        0      0 127.0.0.11:44047        0.0.0.0:*               LISTEN      0          99628225   -
                                udp        0      0 127.0.0.11:60690        0.0.0.0:*                           0          99628224   -
                                2024-01-21 17:35:41.819  - info: admin.0 (234) ==> Connected system.user.admin from ::ffff:192.168.86.90
                                2024-01-21 17:35:47.365  - info: admin.0 (234) ==> Connected system.user.admin from ::ffff:192.168.86.90
                                2024-01-21 17:36:06.719  - info: host.iobroker received SIGTERM
                                2024-01-21 17:36:06.722  - info: host.iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
                                2024-01-21 17:36:06.722  - info: host.iobroker stopInstance system.adapter.discovery.0 (force=false, process=true)
                                2024-01-21 17:36:06.723  - info: host.iobroker stopInstance system.adapter.backitup.0 (force=false, process=true)
                                2024-01-21 17:36:06.730  - info: discovery.0 (261) Got terminate signal TERMINATE_YOURSELF
                                2024-01-21 17:36:06.732  - info: discovery.0 (261) terminating
                                2024-01-21 17:36:06.733  - info: discovery.0 (261) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2024-01-21 17:36:06.734  - info: admin.0 (234) Got terminate signal TERMINATE_YOURSELF
                                2024-01-21 17:36:06.738  - info: backitup.0 (276) Got terminate signal TERMINATE_YOURSELF
                                2024-01-21 17:36:06.739  - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
                                2024-01-21 17:36:06.740  - info: host.iobroker stopInstance system.adapter.discovery.0 send kill signal
                                2024-01-21 17:36:06.741  - info: host.iobroker stopInstance system.adapter.backitup.0 send kill signal
                                2024-01-21 17:36:06.738  - info: admin.0 (234) terminating http server on port 8081
                                2024-01-21 17:36:06.743  - info: admin.0 (234) terminating
                                2024-01-21 17:36:06.744  - info: admin.0 (234) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2024-01-21 17:36:06.739  - info: backitup.0 (276) cleaned everything up...
                                2024-01-21 17:36:06.739  - info: backitup.0 (276) terminating
                                2024-01-21 17:36:06.740  - info: backitup.0 (276) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2024-01-21 17:36:07.278  - info: host.iobroker instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2024-01-21 17:36:07.287  - info: host.iobroker instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2024-01-21 17:36:07.305  - info: host.iobroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2024-01-21 17:36:07.307  - info: host.iobroker All instances are stopped.
                                2024-01-21 17:36:07.358  - info: host.iobroker terminated
                                iob diag has finished.
                                                        v.2023-10-10
                                model name      : Intel(R) Celeron(R) J4125 CPU @ 2.00GHz
                                Kernel          : x86_64
                                Userland        : amd64
                                Docker          : v9.1.0
                                Installation:           Docker
                                Kernel:                 x86_64
                                Userland:               amd64
                                Timezone:               Etc/UTC
                                User-ID:                0
                                X-Server:               false
                                Pending OS-Updates:     0
                                Pending iob updates:    0
                                Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                                        /usr/bin/npm            10.2.3
                                                        /usr/bin/npx            10.2.3
                                Recommended versions are nodejs No connection to databases possible ... and npm No connection to databases possible ...
                                MEMORY:
                                Mem:             12G        5.1G        696M        605M        7.6G        7.3G
                                Swap:           2.1G        1.9G        228M
                                Total:           14G        7.0G        924M
                                Active iob-Instances:   0
                                ioBroker Core:          js-controller           4.0.24
                                                        admin                   6.12.0
                                ioBroker Status:        No connection to databases possible ...
                                Objects:                1
                                States:                 1
                                Size of iob-Database:
                                === Mark text until here for copying ===
                                • Marc Berg
                                  Marc Berg Most Active @stephan1827 last edited by
                                  @stephan1827
                                  Das frische Image kommt mit js-Controller Version 5.x. In dem diag Auszug sehe ich aber 4.0.24. Von welcher Version wurde das Backup erzeugt?
                                  • stephan1827
                                    @marc-berg Ich installiere den neuen Docker mit der Version 7.2.0 die den js controller 4.0.024 enthält.
                                    • Glasfaser
                                      So ganz passt das alles nicht !
                                      in den Log´s ist das ioBroker Docker Image 9.1.0 , angezeigt und also das aktuellste .
                                      du schreibts von "neuen Docker ... Version 7.2.0" , das wäre ab die Synology DSM Version 7.2.0 ( auch nicht aktuell ) das hat aber nichts mit dem Container Image zu tun .
                                      dann zu 4.0.24 , dann würdest du es selbstständig auf diese Version bringen , denn :
                                      @marc-berg sagte in iobroker + docker + MACVLAN - fixe IP für bridge möglich ?:
                                      und ein Backup würde gar nicht von 5.x. auf 4.x funktionieren , da mußt du selber Hand anlegen.
                                      Hier liegt ein ganz Großes ? vor .
                                      Hier wird nur vom neuen Container ... von dir gezeigt ,
                                      aber wie ist der Stand vom alten vorhandenen Container .
                                      stephan1827 1 Reply Last reply Reply Quote 1
                                      • stephan1827
                                        @glasfaser Der Grund für diesen Unterschied ist vermutlich, das der alte Docker zwar auf dem neusten Image beruht (weil er zwischendurch immer wieder geupdated wurde), aber noch den alten js-controller verwendet. Ich habe den früher schon mal versucht js abzudaten, aber das produziert bei mir ohne Ende Fehler. Deswegen ist der noch auf dem alten Stand.
                                        • OliverIO
                                          OliverIO @stephan1827 last edited by OliverIO
                                          @stephan1827
                                          irgendwie bekomme ich deine terminologie nicht mit der realen welt in überdeckung. um es evtl etwas abzugrenzen, hier mal die verschiedenen ebenen über die man sprechen kann
                                          1. host-betriebssystem
                                          2. container management software
                                          3. docker-virtualisierung
                                          4. container/image
                                          5. container betriebssystem
                                          6. software im container
                                          jedes dieser ebenen kann mindestens eine versionsnummer haben
                                          bei dir vermute ich folgendes
                                          1. synology dsm 7.2.0
                                          2. sonology dsm 7.2.0
                                          3. docker ?, aber egal, das was mit dsm 7.2.0 mitkommt
                                          4. hier wäre es interessant welches image und welche version. nie neueste wäre buanet 9.1.1
                                          5. egal, wenn du buanet verwendets
                                          6. version deines iobrokers
                                          und nun nochmal zu deinem satz
                                          wenn du schreibst, ich habe immer wieder geupdatet, meinst du dann
                                          4 oder 6? oder noch schlimmer 5?
                                          von welcher version auf welche version?
                                          was sind die fehlermeldungen?
                                          irgendwie ist ja was verkorxt und dann sollte man das grundübel erstmal reparieren, bevor man irgendwie rumdoktert
                                          IM container wird nie durch irgendwelche befehle das betriebssystem oder node aktualisiert. das bringt chaos. diese dinge werden nur aktualisiert, in dem man das komplette image aktualisiert. welches betriebssystem und node da dann drin steckt bestimmt buanet.
                                          alle diese änderungen überleben eine container aktualisierung nicht
                                          iobroker IM container kann aktualisiert werden, aber auch nur weil alles in einer definierten volume steckt und die dann auch eine containeraktualisierung überlebt.
                                          Glasfaser 1 Reply Last reply Reply Quote 1
                                          • Glasfaser
                                            Glasfaser @OliverIO last edited by
                                            @oliverio sagte in iobroker + docker + MACVLAN - fixe IP für bridge möglich ?:
                                            Richtig ...
                                            und alles was hier @stephan1827 schreibt , versteht keiner bzw. versuchen WIR hier ins Klare zu rücken .
                                            @stephan1827
                                            Ich finde es sehr schade ...
                                            wir hier im Forum opfern unsere Freizeit und bekommen erst nach und nach Infos die überhaupt nicht im zusammenhand zu diesem eigentlichen Thread sind ,
                                            bzw. stellt sich herraus , das dein System verkorxt ist .
                                            2443
