    4. Net-Tools update auf 1.0.1 Fehler
      Homoran Global Moderator Administrators @teletapi last edited by
      @teletapi hab das abgetrennt!
      bitte provisorischen Threadtitel ändern
      teletapi 1 Reply Last reply Reply Quote 0
      • teletapi
        teletapi @Homoran last edited by
        hier mal ein IOB Diag ohne den Net-Tools Adapter
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.5
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : arm64
        Systemuptime and Load:
         12:19:28 up  2:09,  1 user,  load average: 1.08, 1.76, 1.75
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Sat 2024-01-20 12:19:29 CET
                   Universal time: Sat 2024-01-20 11:19:29 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            7.8G        2.7G        3.0G        1.0M        2.1G        5.0G
        Swap:            99M          0B         99M
        Total:          7.9G        2.7G        3.1G
                 7811 M total memory
                 2718 M used memory
                 3790 M active memory
                  799 M inactive memory
                 3030 M free memory
                  146 M buffer memory
                 1915 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4       59G  9.0G   47G  16% /
        devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
        /dev/sda1      vfat      255M   31M  225M  13% /boot
        tmpfs          tmpfs     782M   16K  782M   1% /run/user/1000
        [Sat Jan 20 10:09:40 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:13:A5:D1 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=2c0392e1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Sat Jan 20 10:09:42 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
        [Sat Jan 20 10:09:42 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
        [Sat Jan 20 10:09:43 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
        TARGET  SOURCE    FSTYPE OPTIONS
        /       /dev/sda2 ext4   rw,noatime
        `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        1.9G    /var/
        1.1G    /var/log/journal/a9f1eae0dc5a48ddbf0e2a62c2227673
        1.1G    /var/log
        620M    /var/lib
        Archived and active journals take up 1.0G in the file system.
        /opt/iobroker/backups:
        1.6G    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        370M    /opt/iobroker/iobroker-data/
        185M    /opt/iobroker/iobroker-data/files
        77M     /opt/iobroker/iobroker-data/backup-objects
        72M     /opt/iobroker/iobroker-data/node-red
        71M     /opt/iobroker/iobroker-data/node-red/node_modules
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
        19M     /opt/iobroker/iobroker-data/states.jsonl
        15M     /opt/iobroker/iobroker-data/objects.jsonl
        8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.0
        /usr/bin/node           v18.19.0
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.0-1nodesource1
          Candidate: 18.19.0-1nodesource1
          Version table:
         *** 18.19.0-1nodesource1 1001
                100 /var/lib/dpkg/status
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.17
        admin:          6.13.15
        javascript:     7.7.0
        Adapters from github:   2
        Adapter State
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
          system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
        + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
        + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 18701
        + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 12001
        + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 12010
        + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
        + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
        + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
        + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
        + system.adapter.opendtu.0                : opendtu               : iobroker                                 -  enabled
        + system.adapter.philips-tv.0             : philips-tv            : iobroker                                 -  enabled
        + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 192.168.178.82, run as: admin
        + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
        + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
        + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): beta
        Installed ioBroker-Instances
        Used repository: beta
        Adapter    "admin"        : 6.13.15  , installed 6.13.15
        Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
        Adapter    "backitup"     : 2.10.3   , installed 2.10.3
        Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
        Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
        Adapter    "hue"          : 3.10.2   , installed 3.10.2
        Adapter    "ical"         : 1.14.0   , installed 1.14.0
        Adapter    "iopooleco"    : 0.5.1    , installed 0.5.1
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "jarvis"       : 3.1.8    , installed 3.1.9-beta.3
        Adapter    "javascript"   : 7.7.0    , installed 7.7.0
        Controller "js-controller": 5.0.17   , installed 5.0.17
        Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
        Adapter    "node-red"     : 5.1.0    , installed 5.1.0
        Adapter    "nuki"         : 1.6.0    , installed 1.6.0
        Adapter    "opendtu"      : 1.0.1    , installed 1.0.1
        Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
        Adapter    "shelly"       : 6.7.0    , installed 6.7.0
        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
        Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
        Adapter    "telegram"     : 3.0.1    , installed 3.0.1
        Adapter    "web"          : 6.2.3    , installed 6.2.3
        Adapter    "ws"           : 2.5.10   , installed 2.5.10
        Objects and States
        Objects:        9642
        States:         9862
        Hit:1 http://deb.debian.org/debian bullseye InRelease
        Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:4 https://repos.influxdata.com/debian stable InRelease
        Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:6 https://apt.grafana.com stable InRelease
        Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 1
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13624      566/sshd: /usr/sbin
        tcp        0      0 192.168.178.82:18701    0.0.0.0:*               LISTEN      1001       179028     10408/io.hm-rpc.0
        tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       20230      1784/io.jarvis.0
        tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       16371      1498/io.sonoff.0
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      116        15086      560/mosquitto
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       19210      1552/io.shelly.0
        tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       18493      1235/node-red
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          13639      542/cupsd
        tcp        0      0 192.168.178.82:12001    0.0.0.0:*               LISTEN      1001       183523     10645/io.hm-rpc.1
        tcp        0      0 192.168.178.82:12010    0.0.0.0:*               LISTEN      1001       182669     10580/io.hm-rpc.2
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16481      658/iobroker.js-con
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16488      658/iobroker.js-con
        tcp        0      0 192.168.178.82:8087     0.0.0.0:*               LISTEN      1001       332089     19001/io.simple-api
        tcp        0      0 192.168.178.82:9092     0.0.0.0:*               LISTEN      1001       24665      1936/io.nuki.0
        tcp        0      0 192.168.178.82:2001     0.0.0.0:*               LISTEN      1001       180930     10538/io.hm-rpc.3
        tcp6       0      0 :::22                   :::*                    LISTEN      0          13626      566/sshd: /usr/sbin
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          13638      542/cupsd
        tcp6       0      0 :::1883                 :::*                    LISTEN      116        15087      560/mosquitto
        tcp6       0      0 :::3000                 :::*                    LISTEN      117        16385      657/grafana
        tcp6       0      0 :::8086                 :::*                    LISTEN      999        15160      547/influxd
        tcp6       0      0 :::8084                 :::*                    LISTEN      1001       24273      2330/io.socketio.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       333363     19065/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13958      982/io.admin.0
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          13654      617/cups-browsed
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14903      403/avahi-daemon: r
        udp        0      0 0.0.0.0:56063           0.0.0.0:*                           108        14905      403/avahi-daemon: r
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15209      480/dhcpcd
        udp6       0      0 :::546                  :::*                                0          15226      480/dhcpcd
        udp6       0      0 :::5353                 :::*                                108        14904      403/avahi-daemon: r
        udp6       0      0 :::46450                :::*                                108        14906      403/avahi-daemon: r
        2024-01-20 12:15:28.359  - info: admin.0 (982) ==> Connected system.user.admin from ::ffff:192.168.178.63
        2024-01-20 12:15:29.695  - info: admin.0 (982) <== Disconnect system.user.admin from ::ffff:192.168.178.63 admin
        2024-01-20 12:15:57.531  - info: web.0 (19065) <== Disconnect system.user.admin from ::ffff:192.168.178.63
        2024-01-20 12:16:01.702  - info: admin.0 (982) <== Disconnect system.user.admin from ::ffff:192.168.178.63 admin
        iob diag has finished.
        • Jey Cee
          Jey Cee Developer @teletapi last edited by
          @teletapi hi das ist unerfreulich ich hab geradr einen Notfall in der Familie. Sobald ich kann schau ich mir das an.
          3€ ist ein anderer Adapter.
          • Jey Cee
            @teletapi Ich hab es gefixt sollte bald die version 1.0.2 verfügbar sein.
            • teletapi
              teletapi @Jey Cee last edited by teletapi
              @jey-cee Ich habe jetzt gerade mal die 1.0.2 installiert, der Fehlker bleibt aber der gleiche Instanz startet garnicht erst und die gleichen fehler wie oben mit der 1.0.1
              2024-01-20 18:30:00.154 - info: host.iobroker instance system.adapter.ical.0 started with pid 74065
              2024-01-20 18:30:03.414 - info: ical.0 (74065) starting. Version 1.14.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
              2024-01-20 18:30:09.679 - info: ical.0 (74065) Terminated (NO_ERROR): Without reason
              2024-01-20 18:30:10.238 - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
              2024-01-20 19:00:00.201 - info: host.iobroker instance system.adapter.ical.0 started with pid 77844
              2024-01-20 19:00:03.294 - info: ical.0 (77844) starting. Version 1.14.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
              2024-01-20 19:00:09.573 - info: ical.0 (77844) Terminated (NO_ERROR): Without reason
              2024-01-20 19:00:10.138 - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
              2024-01-20 19:08:51.757 - info: nuki.0 (1936) status change received for NukiID 790083444: unlocked
              2024-01-20 19:08:51.758 - info: nuki.0 (1936) battery status received for NukiID 790083444: false
              2024-01-20 19:09:12.010 - info: nuki.0 (1936) status change received for NukiID 790083444: locking
              2024-01-20 19:09:12.011 - info: nuki.0 (1936) battery status received for NukiID 790083444: false
              2024-01-20 19:09:31.958 - info: nuki.0 (1936) status change received for NukiID 790083444: locked
              2024-01-20 19:09:31.959 - info: nuki.0 (1936) battery status received for NukiID 790083444: false
              2024-01-20 19:19:47.675 - info: nuki.0 (1936) status change received for NukiID 790083444: unlocked
              2024-01-20 19:19:47.675 - info: nuki.0 (1936) battery status received for NukiID 790083444: false
              2024-01-20 19:20:07.687 - info: nuki.0 (1936) status change received for NukiID 790083444: unlocked
              2024-01-20 19:20:07.688 - info: nuki.0 (1936) battery status received for NukiID 790083444: false
              2024-01-20 19:20:33.458 - info: admin.0 (982) ==> Connected system.user.admin from ::ffff:192.168.178.63
              2024-01-20 19:20:35.821 - info: host.iobroker Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
              2024-01-20 19:20:50.379 - info: admin.0 (982) <== Disconnect system.user.admin from ::ffff:192.168.178.63
              2024-01-20 19:28:26.897 - info: admin.0 (982) <== Disconnect system.user.admin from ::ffff:192.168.178.63 admin
              2024-01-20 19:30:00.146 - info: host.iobroker instance system.adapter.ical.0 started with pid 81588
              2024-01-20 19:30:03.101 - info: ical.0 (81588) starting. Version 1.14.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
              2024-01-20 19:30:09.531 - info: ical.0 (81588) Terminated (NO_ERROR): Without reason
              2024-01-20 19:30:10.107 - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
              2024-01-20 19:36:49.011 - info: nuki.0 (1936) status change received for NukiID 790083444: unlatched
              2024-01-20 19:36:49.012 - info: nuki.0 (1936) battery status received for NukiID 790083444: false
              2024-01-20 19:37:09.663 - info: nuki.0 (1936) status change received for NukiID 790083444: locking
              2024-01-20 19:37:09.664 - info: nuki.0 (1936) battery status received for NukiID 790083444: false
              2024-01-20 19:37:29.600 - info: nuki.0 (1936) status change received for NukiID 790083444: locked
              2024-01-20 19:37:29.601 - info: nuki.0 (1936) battery status received for NukiID 790083444: false
              2024-01-20 20:00:00.159 - info: host.iobroker instance system.adapter.ical.0 started with pid 85926
              2024-01-20 20:00:03.259 - info: ical.0 (85926) starting. Version 1.14.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
              2024-01-20 20:00:09.627 - info: ical.0 (85926) Terminated (NO_ERROR): Without reason
              2024-01-20 20:00:10.146 - warn: ical.0 (85926) get state error: Connection is closed.
              2024-01-20 20:00:10.233 - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
              2024-01-20 20:30:00.157 - info: host.iobroker instance system.adapter.ical.0 started with pid 89711
              2024-01-20 20:30:03.126 - info: ical.0 (89711) starting. Version 1.14.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
              2024-01-20 20:30:09.477 - info: ical.0 (89711) Terminated (NO_ERROR): Without reason
              2024-01-20 20:30:10.029 - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
              2024-01-20 20:34:57.068 - info: hm-rpc.1 (10645) Firmware update status of 3014F711A000021D89A1B02B changed to 1
              2024-01-20 21:00:00.159 - info: host.iobroker instance system.adapter.ical.0 started with pid 93560
              2024-01-20 21:00:03.182 - info: ical.0 (93560) starting. Version 1.14.0 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
              2024-01-20 21:00:09.549 - info: ical.0 (93560) Terminated (NO_ERROR): Without reason
              2024-01-20 21:00:10.098 - info: host.iobroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
              2024-01-20 21:03:48.746 - info: admin.0 (982) ==> Connected system.user.admin from ::ffff:192.168.178.63
              2024-01-20 21:04:00.066 - info: admin.0 (982) ==> Connected system.user.admin from ::ffff:192.168.178.63
              2024-01-20 21:04:02.059 - info: host.iobroker Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
              2024-01-20 21:04:14.219 - info: admin.0 (982) <== Disconnect system.user.admin from ::ffff:192.168.178.63
              2024-01-20 21:04:36.158 - info: host.iobroker iobroker add net-tools auto --host iobroker --debug
              2024-01-20 21:04:40.566 - info: host.iobroker iobroker NPM version: 10.2.3
              2024-01-20 21:04:40.570 - info: host.iobroker iobroker Installing iobroker.net-tools@1.0.2... (System call)
              2024-01-20 21:04:57.827 - info: host.iobroker iobroker
              2024-01-20 21:04:57.828 - info: host.iobroker iobroker added 27 packages, and changed 1 package in 16s141 packages are looking for funding run `npm fund` for details
              2024-01-20 21:04:57.877 - info: host.iobroker iobroker host.iobroker install adapter net-tools
              2024-01-20 21:04:57.980 - info: host.iobroker iobroker upload [12] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/de/translations.json i18n/de/translations.json application/json
              2024-01-20 21:04:58.036 - info: host.iobroker iobroker upload [11] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/en/translations.json i18n/en/translations.json application/json
              2024-01-20 21:04:58.091 - info: host.iobroker iobroker upload [10] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/es/translations.json i18n/es/translations.json application/json
              2024-01-20 21:04:58.106 - info: host.iobroker iobroker upload [9] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
              2024-01-20 21:04:58.125 - info: host.iobroker iobroker upload [8] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/it/translations.json i18n/it/translations.json application/json
              2024-01-20 21:04:58.149 - info: host.iobroker iobroker upload [7] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
              2024-01-20 21:04:58.161 - info: host.iobroker iobroker upload [6] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
              2024-01-20 21:04:58.171 - info: host.iobroker iobroker upload [5] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
              2024-01-20 21:04:58.189 - info: host.iobroker iobroker upload [4] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
              2024-01-20 21:04:58.212 - info: host.iobroker iobroker upload [3] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
              2024-01-20 21:04:58.228 - info: host.iobroker iobroker upload [2] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
              2024-01-20 21:04:58.244 - info: host.iobroker iobroker upload [1] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/jsonConfig.json jsonConfig.json application/json
              2024-01-20 21:04:58.259 - info: host.iobroker iobroker upload [0] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/net-tools.png net-tools.png image/png
              2024-01-20 21:04:58.415 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools created/updated
              2024-01-20 21:04:58.596 - info: host.iobroker iobroker host.iobroker create instance net-tools
              2024-01-20 21:04:58.616 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.alive created
              2024-01-20 21:04:58.630 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.connected created
              2024-01-20 21:04:58.646 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.compactMode created
              2024-01-20 21:04:58.670 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.cpu created
              2024-01-20 21:04:58.689 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.cputime created
              2024-01-20 21:04:58.720 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.memHeapUsed created
              2024-01-20 21:04:58.735 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.memHeapTotal created
              2024-01-20 21:04:58.748 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.memRss created
              2024-01-20 21:04:58.763 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.uptime created
              2024-01-20 21:04:58.777 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.inputCount created
              2024-01-20 21:04:58.792 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.outputCount created
              2024-01-20 21:04:58.805 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.eventLoopLag created
              2024-01-20 21:04:58.824 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.sigKill created
              2024-01-20 21:04:58.838 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0.logLevel created
              2024-01-20 21:04:58.851 - info: host.iobroker iobroker host.iobroker object net-tools.0.localhost created
              2024-01-20 21:04:58.865 - info: host.iobroker iobroker host.iobroker object net-tools.0.localhost.ports created
              2024-01-20 21:04:58.878 - info: host.iobroker iobroker host.iobroker object net-tools.0.discover created
              2024-01-20 21:04:58.897 - info: host.iobroker iobroker host.iobroker object system.adapter.net-tools.0 created
              2024-01-20 21:04:59.985 - info: host.iobroker iobroker exit 0
              2024-01-20 21:05:02.023 - info: host.iobroker instance system.adapter.net-tools.0 started with pid 94264
              2024-01-20 21:05:03.821 - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1137
              2024-01-20 21:05:03.821 - error: host.iobroker Caught by controller[0]: throw err;
              2024-01-20 21:05:03.821 - error: host.iobroker Caught by controller[0]: ^
              2024-01-20 21:05:03.822 - error: host.iobroker Caught by controller[0]: Error: Cannot find module '@all-smart/dm-utils'
              2024-01-20 21:05:03.822 - error: host.iobroker Caught by controller[0]: Require stack:
              2024-01-20 21:05:03.822 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js
              2024-01-20 21:05:03.822 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/main.js
              2024-01-20 21:05:03.822 - error: host.iobroker Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
              2024-01-20 21:05:03.822 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
              2024-01-20 21:05:03.822 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
              2024-01-20 21:05:03.823 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
              2024-01-20 21:05:03.823 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js:1:17)
              2024-01-20 21:05:03.823 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
              2024-01-20 21:05:03.823 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
              2024-01-20 21:05:03.823 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
              2024-01-20 21:05:03.823 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
              2024-01-20 21:05:03.823 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) {
              2024-01-20 21:05:03.824 - error: host.iobroker Caught by controller[0]: code: 'MODULE_NOT_FOUND',
              2024-01-20 21:05:03.824 - error: host.iobroker Caught by controller[0]: requireStack: [
              2024-01-20 21:05:03.824 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js',
              2024-01-20 21:05:03.824 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/main.js'
              2024-01-20 21:05:03.824 - error: host.iobroker Caught by controller[0]: ]
              2024-01-20 21:05:03.824 - error: host.iobroker Caught by controller[0]: }
              2024-01-20 21:05:03.824 - error: host.iobroker Caught by controller[0]: Node.js v18.19.0
              2024-01-20 21:05:03.825 - error: host.iobroker instance system.adapter.net-tools.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2024-01-20 21:05:03.825 - info: host.iobroker Adapter system.adapter.net-tools.0 needs rebuild and will be restarted afterwards.
              2024-01-20 21:05:03.825 - info: host.iobroker system.adapter.net-tools.0 will be rebuilt
              2024-01-20 21:05:03.827 - warn: host.iobroker adapter "net-tools" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
              2024-01-20 21:05:03.827 - info: host.iobroker iobroker rebuild
              2024-01-20 21:05:04.593 - warn: admin.0 (982) net-tools has an invalid jsonConfig: [{"instancePath":"/items/_deviceManager","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/then/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"innerStyle"},"message":"must NOT have additional properties"}]
              2024-01-20 21:05:05.684 - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
              2024-01-20 21:05:43.058 - info: host.iobroker iobroker npm-rebuild: rebuilt dependencies successfully
              2024-01-20 21:05:43.095 - info: host.iobroker iobroker npm-rebuild:
              2024-01-20 21:05:43.097 - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules done
              2024-01-20 21:05:44.111 - info: host.iobroker iobroker npm-rebuild: exit 0
              2024-01-20 21:05:44.279 - info: host.iobroker instance system.adapter.net-tools.0 started with pid 94760
              2024-01-20 21:05:45.548 - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1137
              2024-01-20 21:05:45.548 - error: host.iobroker Caught by controller[0]: throw err;
              2024-01-20 21:05:45.548 - error: host.iobroker Caught by controller[0]: ^
              2024-01-20 21:05:45.549 - error: host.iobroker Caught by controller[0]: Error: Cannot find module '@all-smart/dm-utils'
              2024-01-20 21:05:45.549 - error: host.iobroker Caught by controller[0]: Require stack:
              2024-01-20 21:05:45.549 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js
              2024-01-20 21:05:45.549 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/main.js
              2024-01-20 21:05:45.549 - error: host.iobroker Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
              2024-01-20 21:05:45.549 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
              2024-01-20 21:05:45.549 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
              2024-01-20 21:05:45.549 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
              2024-01-20 21:05:45.549 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js:1:17)
              2024-01-20 21:05:45.549 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
              2024-01-20 21:05:45.549 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
              2024-01-20 21:05:45.550 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
              2024-01-20 21:05:45.550 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
              2024-01-20 21:05:45.550 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) {
              2024-01-20 21:05:45.550 - error: host.iobroker Caught by controller[0]: code: 'MODULE_NOT_FOUND',
              2024-01-20 21:05:45.550 - error: host.iobroker Caught by controller[0]: requireStack: [
              2024-01-20 21:05:45.550 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js',
              2024-01-20 21:05:45.550 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/main.js'
              2024-01-20 21:05:45.550 - error: host.iobroker Caught by controller[0]: ]
              2024-01-20 21:05:45.550 - error: host.iobroker Caught by controller[0]: }
              2024-01-20 21:05:45.551 - error: host.iobroker Caught by controller[0]: Node.js v18.19.0
              2024-01-20 21:05:45.551 - error: host.iobroker instance system.adapter.net-tools.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2024-01-20 21:05:45.551 - info: host.iobroker Adapter system.adapter.net-tools.0 needs rebuild and will be restarted afterwards.
              2024-01-20 21:05:45.551 - info: host.iobroker system.adapter.net-tools.0 will be rebuilt
              2024-01-20 21:05:45.551 - warn: host.iobroker adapter "net-tools" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
              2024-01-20 21:05:45.551 - info: host.iobroker iobroker rebuild
              2024-01-20 21:05:46.971 - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
              2024-01-20 21:06:40.883 - info: host.iobroker iobroker npm-rebuild: rebuilt dependencies successfully
              2024-01-20 21:06:41.001 - info: host.iobroker iobroker npm-rebuild:
              2024-01-20 21:06:41.002 - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules done
              2024-01-20 21:06:42.023 - info: host.iobroker iobroker npm-rebuild: exit 0
              2024-01-20 21:06:42.253 - info: host.iobroker instance system.adapter.net-tools.0 started with pid 95354
              2024-01-20 21:06:44.790 - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1137
              2024-01-20 21:06:44.791 - error: host.iobroker Caught by controller[0]: throw err;
              2024-01-20 21:06:44.791 - error: host.iobroker Caught by controller[0]: ^
              2024-01-20 21:06:44.792 - error: host.iobroker Caught by controller[0]: Error: Cannot find module '@all-smart/dm-utils'
              2024-01-20 21:06:44.792 - error: host.iobroker Caught by controller[0]: Require stack:
              2024-01-20 21:06:44.793 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js
              2024-01-20 21:06:44.793 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/main.js
              2024-01-20 21:06:44.793 - error: host.iobroker Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
              2024-01-20 21:06:44.794 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
              2024-01-20 21:06:44.795 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
              2024-01-20 21:06:44.795 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
              2024-01-20 21:06:44.796 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js:1:17)
              2024-01-20 21:06:44.796 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
              2024-01-20 21:06:44.797 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
              2024-01-20 21:06:44.797 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
              2024-01-20 21:06:44.798 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
              2024-01-20 21:06:44.799 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) {
              2024-01-20 21:06:44.799 - error: host.iobroker Caught by controller[0]: code: 'MODULE_NOT_FOUND',
              2024-01-20 21:06:44.800 - error: host.iobroker Caught by controller[0]: requireStack: [
              2024-01-20 21:06:44.809 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js',
              2024-01-20 21:06:44.809 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/main.js'
              2024-01-20 21:06:44.809 - error: host.iobroker Caught by controller[0]: ]
              2024-01-20 21:06:44.809 - error: host.iobroker Caught by controller[0]: }
              2024-01-20 21:06:44.810 - error: host.iobroker Caught by controller[0]: Node.js v18.19.0
              2024-01-20 21:06:44.810 - error: host.iobroker instance system.adapter.net-tools.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2024-01-20 21:06:44.810 - info: host.iobroker Adapter system.adapter.net-tools.0 needs rebuild and will be restarted afterwards.
              2024-01-20 21:06:44.810 - info: host.iobroker system.adapter.net-tools.0 will be rebuilt
              2024-01-20 21:06:44.811 - warn: host.iobroker adapter "net-tools" seems to be installed for a different version of Node.js. Trying to rebuild it... 3 attempt
              2024-01-20 21:06:44.811 - info: host.iobroker iobroker rebuild
              2024-01-20 21:06:47.105 - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules ...
              2024-01-20 21:07:43.520 - info: host.iobroker stopInstance system.adapter.simple-api.0 (force=false, process=true)
              2024-01-20 21:07:43.669 - info: simple-api.0 (19001) Got terminate signal TERMINATE_YOURSELF
              2024-01-20 21:07:43.683 - info: simple-api.0 (19001) terminating http server on port 8087
              2024-01-20 21:07:43.685 - info: simple-api.0 (19001) terminating
              2024-01-20 21:07:43.688 - info: simple-api.0 (19001) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2024-01-20 21:07:43.704 - info: host.iobroker stopInstance system.adapter.simple-api.0 send kill signal
              2024-01-20 21:07:44.190 - info: simple-api.0 (19001) terminating
              2024-01-20 21:07:44.241 - error: cloud.0 (1676) Instance web.0 not enabled. Please enable this instance for cloud
              2024-01-20 21:07:44.252 - info: host.iobroker "system.adapter.web.0" disabled
              2024-01-20 21:07:44.252 - info: host.iobroker stopInstance system.adapter.web.0 (force=false, process=true)
              2024-01-20 21:07:44.244 - info: cloud.0 (1676) Reconnect because web instance stopped
              2024-01-20 21:07:44.383 - info: web.0 (19065) Got terminate signal TERMINATE_YOURSELF
              2024-01-20 21:07:44.384 - error: cloud.0 (1676) Instance web.0 not enabled. Please enable this instance for cloud
              2024-01-20 21:07:44.387 - info: cloud.0 (1676) Trying to connect as system.user.admin to cloud
              2024-01-20 21:07:44.406 - info: cloud.0 (1676) Reconnect because web instance started
              2024-01-20 21:07:44.429 - info: host.iobroker "system.adapter.web.0" enabled
              2024-01-20 21:07:44.430 - info: host.iobroker stopInstance system.adapter.web.0 (force=false, process=true)
              2024-01-20 21:07:44.437 - info: host.iobroker stopInstance system.adapter.web.0 send kill signal
              2024-01-20 21:07:44.493 - info: cloud.0 (1676) Trying to connect as system.user.admin to cloud
              2024-01-20 21:07:44.497 - info: web.0 (19065) Got terminate signal TERMINATE_YOURSELF
              2024-01-20 21:07:44.587 - info: host.iobroker instance system.adapter.simple-api.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2024-01-20 21:07:44.594 - info: host.iobroker stopInstance system.adapter.web.0 send kill signal
              2024-01-20 21:07:44.639 - info: web.0 (19065) terminated http server on port 8082
              2024-01-20 21:07:44.640 - info: web.0 (19065) terminating
              2024-01-20 21:07:44.642 - info: web.0 (19065) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2024-01-20 21:07:44.887 - info: web.0 (19065) terminating
              2024-01-20 21:07:45.378 - info: host.iobroker instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2024-01-20 21:07:46.832 - info: host.iobroker instance system.adapter.simple-api.0 started with pid 95868
              2024-01-20 21:07:47.740 - info: host.iobroker instance system.adapter.web.0 started with pid 95876
              2024-01-20 21:07:51.969 - info: simple-api.0 (95868) starting. Version 2.7.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v18.19.0, js-controller: 5.0.17
              2024-01-20 21:07:52.049 - warn: simple-api.0 (95868) Information for Developer: Using the direct "Let's encrypt" module import is deprecated and will be removed in the next js-controller version, use @iobroker/webserver instead
              2024-01-20 21:07:52.064 - info: simple-api.0 (95868) simpleAPI server listening on port 8087
              2024-01-20 21:07:52.067 - info: simple-api.0 (95868) Allow states only when user is owner: false
              2024-01-20 21:07:52.114 - info: simple-api.0 (95868) http server listening on port 8087
              2024-01-20 21:07:53.479 - info: web.0 (95876) starting. Version 6.2.3 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
              2024-01-20 21:07:54.626 - info: web.0 (95876) socket.io server listening on port 8082
              2024-01-20 21:07:54.653 - info: web.0 (95876) http server listening on port 8082
              2024-01-20 21:07:57.522 - info: host.iobroker iobroker npm-rebuild: rebuilt dependencies successfully
              2024-01-20 21:07:57.659 - info: host.iobroker iobroker npm-rebuild: Rebuilding native modules done
              2024-01-20 21:07:58.668 - info: host.iobroker iobroker npm-rebuild: exit 0
              2024-01-20 21:07:58.919 - info: host.iobroker instance system.adapter.net-tools.0 started with pid 95960
              2024-01-20 21:08:03.601 - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1137
              2024-01-20 21:08:03.602 - error: host.iobroker Caught by controller[0]: throw err;
              2024-01-20 21:08:03.602 - error: host.iobroker Caught by controller[0]: ^
              2024-01-20 21:08:03.602 - error: host.iobroker Caught by controller[0]: Error: Cannot find module '@all-smart/dm-utils'
              2024-01-20 21:08:03.602 - error: host.iobroker Caught by controller[0]: Require stack:
              2024-01-20 21:08:03.602 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js
              2024-01-20 21:08:03.603 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/main.js
              2024-01-20 21:08:03.603 - error: host.iobroker Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
              2024-01-20 21:08:03.603 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
              2024-01-20 21:08:03.603 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
              2024-01-20 21:08:03.603 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
              2024-01-20 21:08:03.603 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js:1:17)
              2024-01-20 21:08:03.603 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
              2024-01-20 21:08:03.603 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
              2024-01-20 21:08:03.603 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
              2024-01-20 21:08:03.604 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
              2024-01-20 21:08:03.604 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) {
              2024-01-20 21:08:03.604 - error: host.iobroker Caught by controller[0]: code: 'MODULE_NOT_FOUND',
              2024-01-20 21:08:03.604 - error: host.iobroker Caught by controller[0]: requireStack: [
              2024-01-20 21:08:03.604 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js',
              2024-01-20 21:08:03.604 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/main.js'
              2024-01-20 21:08:03.604 - error: host.iobroker Caught by controller[0]: ]
              2024-01-20 21:08:03.604 - error: host.iobroker Caught by controller[0]: }
              2024-01-20 21:08:03.604 - error: host.iobroker Caught by controller[0]: Node.js v18.19.0
              2024-01-20 21:08:03.605 - error: host.iobroker instance system.adapter.net-tools.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2024-01-20 21:08:03.605 - info: host.iobroker Rebuild for adapter system.adapter.net-tools.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
              2024-01-20 21:08:15.117 - error: cloud.0 (1676) Instance web.0 not enabled. Please enable this instance for cloud
              2024-01-20 21:08:15.126 - info: host.iobroker "system.adapter.web.0" disabled
              2024-01-20 21:08:15.127 - info: host.iobroker stopInstance system.adapter.web.0 (force=false, process=true)
              2024-01-20 21:08:15.121 - info: cloud.0 (1676) Reconnect because web instance stopped
              2024-01-20 21:08:15.249 - info: web.0 (95876) Got terminate signal TERMINATE_YOURSELF
              2024-01-20 21:08:15.263 - error: cloud.0 (1676) Instance web.0 not enabled. Please enable this instance for cloud
              2024-01-20 21:08:15.275 - info: cloud.0 (1676) Trying to connect as system.user.admin to cloud
              2024-01-20 21:08:15.281 - info: host.iobroker "system.adapter.web.0" enabled
              2024-01-20 21:08:15.282 - info: host.iobroker stopInstance system.adapter.web.0 (force=false, process=true)
              2024-01-20 21:08:15.286 - info: cloud.0 (1676) Reconnect because web instance started
              2024-01-20 21:08:15.290 - info: host.iobroker stopInstance system.adapter.web.0 send kill signal
              2024-01-20 21:08:15.316 - info: cloud.0 (1676) Trying to connect as system.user.admin to cloud
              2024-01-20 21:08:15.317 - info: web.0 (95876) Got terminate signal TERMINATE_YOURSELF
              2024-01-20 21:08:15.341 - info: host.iobroker stopInstance system.adapter.web.0 send kill signal
              2024-01-20 21:08:15.411 - info: web.0 (95876) terminated http server on port 8082
              2024-01-20 21:08:15.413 - info: web.0 (95876) terminating
              2024-01-20 21:08:15.415 - info: web.0 (95876) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2024-01-20 21:08:15.752 - info: web.0 (95876) terminating
              2024-01-20 21:08:16.045 - info: host.iobroker instance system.adapter.web.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2024-01-20 21:08:18.446 - info: host.iobroker instance system.adapter.web.0 started with pid 96037
              2024-01-20 21:08:22.117 - info: web.0 (96037) starting. Version 6.2.3 in /opt/iobroker/node_modules/iobroker.web, node: v18.19.0, js-controller: 5.0.17
              2024-01-20 21:08:22.474 - info: web.0 (96037) socket.io server listening on port 8082
              2024-01-20 21:08:22.497 - info: web.0 (96037) http server listening on port 8082
              2024-01-20 21:09:31.972 - info: host.iobroker instance system.adapter.net-tools.0 started with pid 96426
              2024-01-20 21:09:33.597 - error: host.iobroker Caught by controller[0]: node:internal/modules/cjs/loader:1137
              2024-01-20 21:09:33.597 - error: host.iobroker Caught by controller[0]: throw err;
              2024-01-20 21:09:33.598 - error: host.iobroker Caught by controller[0]: ^
              2024-01-20 21:09:33.598 - error: host.iobroker Caught by controller[0]: Error: Cannot find module '@all-smart/dm-utils'
              2024-01-20 21:09:33.598 - error: host.iobroker Caught by controller[0]: Require stack:
              2024-01-20 21:09:33.598 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js
              2024-01-20 21:09:33.598 - error: host.iobroker Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/main.js
              2024-01-20 21:09:33.598 - error: host.iobroker Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
              2024-01-20 21:09:33.598 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
              2024-01-20 21:09:33.598 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
              2024-01-20 21:09:33.598 - error: host.iobroker Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
              2024-01-20 21:09:33.598 - error: host.iobroker Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js:1:17)
              2024-01-20 21:09:33.599 - error: host.iobroker Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
              2024-01-20 21:09:33.599 - error: host.iobroker Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
              2024-01-20 21:09:33.599 - error: host.iobroker Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
              2024-01-20 21:09:33.599 - error: host.iobroker Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
              2024-01-20 21:09:33.599 - error: host.iobroker Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) {
              2024-01-20 21:09:33.599 - error: host.iobroker Caught by controller[0]: code: 'MODULE_NOT_FOUND',
              2024-01-20 21:09:33.599 - error: host.iobroker Caught by controller[0]: requireStack: [
              2024-01-20 21:09:33.599 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js',
              2024-01-20 21:09:33.599 - error: host.iobroker Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/main.js'
              2024-01-20 21:09:33.599 - error: host.iobroker Caught by controller[0]: ]
              2024-01-20 21:09:33.599 - error: host.iobroker Caught by controller[0]: }
              2024-01-20 21:09:33.600 - error: host.iobroker Caught by controller[0]: Node.js v18.19.0
              2024-01-20 21:09:33.600 - error: host.iobroker instance system.adapter.net-tools.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              2024-01-20 21:09:33.600 - info: host.iobroker Rebuild for adapter system.adapter.net-tools.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
              2024-01-20 21:10:01.096 - warn: admin.0 (982) net-tools has an invalid jsonConfig: [{"instancePath":"/items/_deviceManager","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/then/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"innerStyle"},"message":"must NOT have additional properties"}]
              Wenn ich den Adapter neu starten will, kommen folgende Fehler
              host.iobroker
              	2024-01-20 21:15:16.359	info	Rebuild for adapter system.adapter.net-tools.0 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
              host.iobroker
              	2024-01-20 21:15:16.359	error	instance system.adapter.net-tools.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
              host.iobroker
              	2024-01-20 21:15:16.359	error	Caught by controller[0]: Node.js v18.19.0
              host.iobroker
              	2024-01-20 21:15:16.359	error	Caught by controller[0]: }
              host.iobroker
              	2024-01-20 21:15:16.359	error	Caught by controller[0]: ]
              host.iobroker
              	2024-01-20 21:15:16.358	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/main.js'
              host.iobroker
              	2024-01-20 21:15:16.358	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js',
              host.iobroker
              	2024-01-20 21:15:16.358	error	Caught by controller[0]: requireStack: [
              host.iobroker
              	2024-01-20 21:15:16.358	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
              host.iobroker
              	2024-01-20 21:15:16.358	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19) {
              host.iobroker
              	2024-01-20 21:15:16.358	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:1013:12)
              host.iobroker
              	2024-01-20 21:15:16.358	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1197:32)
              host.iobroker
              	2024-01-20 21:15:16.358	error	Caught by controller[0]: at Module._extensions..js (node:internal/modules/cjs/loader:1414:10)
              host.iobroker
              	2024-01-20 21:15:16.358	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1356:14)
              host.iobroker
              	2024-01-20 21:15:16.358	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js:1:17)
              host.iobroker
              	2024-01-20 21:15:16.357	error	Caught by controller[0]: at require (node:internal/modules/helpers:177:18)
              host.iobroker
              	2024-01-20 21:15:16.357	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1225:19)
              host.iobroker
              	2024-01-20 21:15:16.357	error	Caught by controller[0]: at Module._load (node:internal/modules/cjs/loader:975:27)
              host.iobroker
              	2024-01-20 21:15:16.357	error	Caught by controller[0]: at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
              host.iobroker
              	2024-01-20 21:15:16.357	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/main.js
              host.iobroker
              	2024-01-20 21:15:16.357	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.net-tools/lib/devicemgmt.js
              host.iobroker
              	2024-01-20 21:15:16.357	error	Caught by controller[0]: Require stack:
              host.iobroker
              	2024-01-20 21:15:16.357	error	Caught by controller[0]: Error: Cannot find module '@all-smart/dm-utils'
              host.iobroker
              	2024-01-20 21:15:16.357	error	Caught by controller[0]: ^
              host.iobroker
              	2024-01-20 21:15:16.356	error	Caught by controller[0]: throw err;
              host.iobroker
              	2024-01-20 21:15:16.355	error	Caught by controller[0]: node:internal/modules/cjs/loader:1137
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              host.iobroker
              	2024-01-20 21:15:15.011	info	instance system.adapter.net-tools.0 started with pid 97263
              admin.0
              	2024-01-20 21:10:01.096	warn	net-tools has an invalid jsonConfig: [{"instancePath":"/items/_deviceManager","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/then/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"innerStyle"},"message":"must NOT have additional properties"}]
              Glasfaser Jey Cee 2 Replies Last reply Reply Quote 0
              • Glasfaser
                Glasfaser @teletapi last edited by Glasfaser
                @teletapi
                Editiere bitte dein Log mit den Privaten Daten von ical :
                z.B
                2024-01-20 19:30:03.805 - info: ical.0 (81588) processing URL: Wichtige Termine .....ics
                usw ...
                  Homoran Global Moderator Administrators @Glasfaser last edited by Homoran
                  @glasfaser sagte in Net-Tools update auf 1.0.1 Fehler:
                  @teletapi
                  z.B
                  usw ...
                  ich hoffe ich hab alles
                  am Handy eine Qual so lange logs zu editieren
                  Glasfaser 1 Reply Last reply Reply Quote 3
                  • Jey Cee
                    @teletapi das kommt davon wenn man das mal schnell macht wenn man im Stress ist.
                    • Glasfaser
                      Glasfaser @Homoran last edited by
                      @homoran sagte in Net-Tools update auf 1.0.1 Fehler:
                      • teletapi
                        teletapi @Glasfaser last edited by teletapi
                        Ich hab die 1.0.3 jetzt installiert und der Adapter startet auch wird auch grün und findet die Geräte, als Warnung habe ich im Protocol aber noch folgendes stehn
                        net-tools.0 2024-01-20 23:49:34.177 warn License Key is invalid
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                                 Icon name: computer
                              Architecture: arm64
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : arm64
                         23:57:58 up 13:48,  1 user,  load average: 0.93, 0.87, 0.94
                        CPU threads: 4
                        Current issues:
                                       Local time: Sat 2024-01-20 23:57:58 CET
                                   Universal time: Sat 2024-01-20 22:57:58 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        /home/pi
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            7.8G        3.1G        2.2G        1.0M        2.5G        4.5G
                        Swap:            99M          0B         99M
                        Total:          7.9G        3.1G        2.3G
                                 7811 M total memory
                                 3149 M used memory
                                 4172 M active memory
                                 1245 M inactive memory
                                 2157 M free memory
                                  170 M buffer memory
                                 2333 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /dev/root      ext4       59G  9.1G   47G  17% /
                        [Sat Jan 20 10:09:40 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.ma                                     caddr=D8:3A:DD:13:A5:D1 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=2c0392e1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                        /var:
                        2.0G    /var/
                        1.1G    /var/log
                        637M    /var/lib
                        382M    /opt/iobroker/iobroker-data/
                        37M     /opt/iobroker/iobroker-data/objects.jsonl
                        8.5M    /opt/iobroker/iobroker-data/states.jsonl
                        USB-Devices by-id:
                        /usr/bin/npm            10.2.3
                        /usr/bin/npx            10.2.3
                        nodejs:
                          Version table:
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.13.15
                        javascript:     7.7.0
                        Adapter State
                        + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
                        + instance is alive
                        Adapter    "net-tools"    : 1.0.2    , installed 1.0.3
                        Objects and States
                        Objects:        10002
                        States:         10092
                        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                        Hit:2 http://deb.debian.org/debian bullseye InRelease
                        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                        Hit:5 https://repos.influxdata.com/debian stable InRelease
                        Pending Updates: 0
                        tcp        0      0 192.168.178.82:8087     0.0.0.0:*               LISTEN      1001       1855617    95868/io.simple-api
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1857814    96037/io.web.0
                        2024-01-20 23:56:54.582  - info: host.iobroker stopInstance system.adapter.net-tools.0 (force=false, process=true)
                        2024-01-20 23:56:54.701  - info: net-tools.0 (121771) Got terminate signal TERMINATE_YOURSELF
                        2024-01-20 23:56:54.707  - info: host.iobroker stopInstance system.adapter.net-tools.0 send kill signal
                        2024-01-20 23:56:54.703  - info: net-tools.0 (121771) terminating
                        2024-01-20 23:56:54.705  - info: net-tools.0 (121771) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        2024-01-20 23:56:55.207  - info: net-tools.0 (121771) terminating
                        2024-01-20 23:56:55.308  - info: host.iobroker instance system.adapter.net-tools.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        2024-01-20 23:56:57.818  - info: host.iobroker instance system.adapter.net-tools.0 started with pid 122180
                        2024-01-20 23:57:00.543  - info: net-tools.0 (122180) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.net-tools, node: v18.19.0, js-controller: 5.0.17
                        2024-01-20 23:57:00.788  - info: net-tools.0 (122180) Scanning for open ports (20, 21, 22, 23, 25, 53, 80, 110, 119, 123, 143, 161, 162, 194, 443, 445, 3306, 3389, 5900, 6379, 8080, 8443, 9090, 9200, 9999) at localhost, please wait
                        2024-01-20 23:57:02.060  - warn: net-tools.0 (122180) License Key is invalid
                        2024-01-20 23:57:02.895  - info: net-tools.0 (122180) Port scan finished
                        • Jey Cee
                          @teletapi schick mir doch bitte eine mail an iobroker@all-smart.net, am besten von der email aus mit der du dich im shop registriert hast.
                          Dann schau ich obs am Lizenz server liegt.
                          • teletapi
                            @jey-cee said in Net-Tools update auf 1.0.1 Fehler:
                            Hab ich gerade gemacht
                            • teletapi
                              teletapi @teletapi last edited by
                              Ich hab heute morgen mal den Adapter neu suchen lassen und dabei stürzte der Adapter dann auch mal kurzfristig ab und es gab einige fehler und warnungen. Das gleiche wiederholt sich auch bei weiteren versuchen.
                              Es fehlen geräte und gelöschte bzw Geräte die ich in der Fritzbox umbenannt habe werden nicht (zumindest) automatisch gefunden
                              853
                              Log-Größe: 203.5 KB
                              Zeit
                              Nachricht
                              net-tools.0
                              	2024-01-21 12:09:12.893	info	Port scan finished
                              net-tools.0
                              	2024-01-21 12:09:11.856	warn	License Key is invalid
                              net-tools.0
                              	2024-01-21 12:09:10.728	info	Scanning for open ports (20, 21, 22, 23, 25, 53, 80, 110, 119, 123, 143, 161, 162, 194, 443, 445, 3306, 3389, 5900, 6379, 8080, 8443, 9090, 9200, 9999) at localhost, please wait
                              net-tools.0
                              	2024-01-21 12:09:10.462	info	starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.net-tools, node: v18.19.0, js-controller: 5.0.17
                              host.iobroker
                              	2024-01-21 12:09:08.144	info	instance system.adapter.net-tools.0 started with pid 24532
                              host.iobroker
                              	2024-01-21 12:08:38.035	info	Restart adapter system.adapter.net-tools.0 because enabled
                              host.iobroker
                              	2024-01-21 12:08:38.034	error	instance system.adapter.net-tools.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                              net-tools.0
                              	2024-01-21 12:08:37.922	info	Default value for state "net-tools.0.2462ab541893.time" could not be set: DB closed
                              net-tools.0
                              	2024-01-21 12:08:37.920	warn	get state error: Connection is closed.
                              net-tools.0
                              	2024-01-21 12:08:37.919	warn	Could not perform strict object check of state net-tools.0.2462ab541893.time: DB closed
                              net-tools.0
                              	2024-01-21 12:08:37.911	warn	redis get net-tools.0.2462ab541893.time, error - Connection is closed.
                              net-tools.0
                              	2024-01-21 12:08:37.898	info	terminating
                              net-tools.0
                              	2024-01-21 12:08:37.802	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.801	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.651	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.506	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.461	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.460	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.459	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.458	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.457	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              net-tools.0
                              	2024-01-21 12:08:37.456	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.455	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.453	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.452	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.451	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.450	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.448	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.447	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.445	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.444	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.442	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.441	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.438	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.436	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.435	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              net-tools.0
                              	2024-01-21 12:08:37.433	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.432	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              net-tools.0
                              	2024-01-21 12:08:37.431	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.430	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.429	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.428	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.427	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.426	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.425	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              net-tools.0
                              	2024-01-21 12:08:37.424	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.423	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.421	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.420	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.419	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.418	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              net-tools.0
                              	2024-01-21 12:08:37.417	warn	setTimeout called, but adapter is shutting down
                              net-tools.0
                              	2024-01-21 12:08:37.396	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                              net-tools.0
                              	2024-01-21 12:08:37.394	info	terminating
                              net-tools.0
                              	2024-01-21 12:08:37.050	error	Cannot read properties of undefined (reading 'stateAlive')
                              net-tools.0
                              	2024-01-21 12:08:37.048	error	TypeError: Cannot read properties of undefined (reading 'stateAlive') at /opt/iobroker/node_modules/iobroker.net-tools/main.js:523:35 at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/ping.js:144:15) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                              net-tools.0
                              	2024-01-21 12:08:37.047	error	uncaught exception: Cannot read properties of undefined (reading 'stateAlive')
                              net-tools.0
                              	2024-01-21 12:08:37.044	error	Cannot read properties of undefined (reading 'stateAlive')
                              net-tools.0
                              	2024-01-21 12:08:37.043	error	TypeError: Cannot read properties of undefined (reading 'stateAlive') at /opt/iobroker/node_modules/iobroker.net-tools/main.js:523:35 at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/ping.js:144:15) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                              net-tools.0
                              	2024-01-21 12:08:37.041	error	uncaught exception: Cannot read properties of undefined (reading 'stateAlive')
                              discovery.0
                              	2024-01-21 12:08:12.374	info	Discovery finished
                              discovery.0
                              	2024-01-21 12:08:12.179	info	Discovery finished. Found new or modified 13 instances
                              net-tools.0
                              	2024-01-21 12:07:01.161	warn	Unknown message origin: 1777722
                              discovery.0
                              	2024-01-21 12:04:35.882	info	Found 43 addresses
                              discovery.0
                              	2024-01-21 12:04:35.720	info	Done discovering ping devices. 42 packages received
                              discovery.0
                              	2024-01-21 12:04:09.872	info	Discovering ping devices...
                              net-tools.0
                              	2024-01-21 12:04:08.806	error	Error: No outstanding message, can't send a new one
                              admin.0
                              	2024-01-21 12:03:54.291	warn	net-tools has an invalid jsonConfig: [{"instancePath":"/items/_deviceManager","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/8/then/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"innerStyle"},"message":"must NOT have additional properties"}]
                              host.iobroker
                              	2024-01-21 12:00:10.219	info	instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                              ical.0
                              	2024-01-21 12:00:10.057	warn	get state error: Connection is closed.
                              • Jey Cee
                                @teletapi sagte in Net-Tools update auf 1.0.1 Fehler:
                                Das Geräte Fehlen kann daran liegen das sie nicht auf den Ping reagieren. Es gab auch früher Meldungen das Geräte nicht gefunden wurden obwohl sie per Ping erreichbar sind. Dieses Problem betrifft auch drn Ping Adapter und die Ursache hab ich bisher nicht finden können.
                                Hier hilft es nur die Geräte von Hand an zu legen.
                                Warum gelöschte Geräte nicht gefunden werden können ergibt für mich erst mal keinen Sinn. Das muss ich versuchen Nach zu stellen.
                                Da Geräte mit ihrer Mac im Adapter angelegt werden hat der Name keinen Einfluss. Es kann sein das der Name nicht in den Adapter übernommen wird, dennoch sollte es weiterhin im Adapter zu sehen sein, wenn es nicht gelöscht wurde.
                                Die Fehlermeldungen sehe ich mir an.
                                teletapi 1 Reply Last reply Reply Quote 0
                                • teletapi
                                  @jey-cee
                                  Ja ich lösch den Adapter jetzt, das hier macht irgendwie so garkeinen Sinn
                                  2999+
                                  Log-Größe: 54.1 KB
                                  Zeit
                                  Nachricht
                                  admin.0
                                  	2024-01-21 15:03:27.368	info	<== Disconnect system.user.admin from ::ffff:192.168.178.63
                                  admin.0
                                  	2024-01-21 15:02:18.027	info	==> Connected system.user.admin from ::ffff:192.168.178.63
                                  net-tools.0
                                  	2024-01-21 15:01:32.871	info	Port scan finished
                                  net-tools.0
                                  	2024-01-21 15:01:31.880	warn	License Key is invalid
                                  net-tools.0
                                  	2024-01-21 15:01:30.741	info	Scanning for open ports (20, 21, 22, 23, 25, 53, 80, 110, 119, 123, 143, 161, 162, 194, 443, 445, 3306, 3389, 5900, 6379, 8080, 8443, 9090, 9200, 9999) at localhost, please wait
                                  net-tools.0
                                  	2024-01-21 15:01:30.553	info	starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.net-tools, node: v18.19.0, js-controller: 5.0.17
                                  host.iobroker
                                  	2024-01-21 15:01:28.059	info	instance system.adapter.net-tools.0 started with pid 50632
                                  host.iobroker
                                  	2024-01-21 15:00:57.972	info	Restart adapter system.adapter.net-tools.0 because enabled
                                  host.iobroker
                                  	2024-01-21 15:00:57.971	error	instance system.adapter.net-tools.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                  net-tools.0
                                  	2024-01-21 15:00:57.824	warn	setTimeout called, but adapter is shutting down
                                  net-tools.0
                                  	2024-01-21 15:00:57.822	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.821	warn	Could not perform strict object check of state net-tools.0.2462ab541893.rps: DB closed
                                  net-tools.0
                                  	2024-01-21 15:00:57.821	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.820	warn	Could not perform strict object check of state net-tools.0.2462ab541893.time: DB closed
                                  net-tools.0
                                  	2024-01-21 15:00:57.819	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.819	warn	Could not perform strict object check of state net-tools.0.aafe8b6946e4.rps: DB closed
                                  net-tools.0
                                  	2024-01-21 15:00:57.818	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.818	warn	Could not perform strict object check of state net-tools.0.aafe8b6946e4.time: DB closed
                                  net-tools.0
                                  	2024-01-21 15:00:57.817	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.817	warn	Could not perform strict object check of state net-tools.0.aafe8b6946e4.alive: DB closed
                                  net-tools.0
                                  	2024-01-21 15:00:57.816	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.816	warn	Could not perform strict object check of state net-tools.0.c45bbe556fde.rps: DB closed
                                  net-tools.0
                                  	2024-01-21 15:00:57.815	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.814	warn	Could not perform strict object check of state net-tools.0.c45bbe556fde.time: DB closed
                                  net-tools.0
                                  	2024-01-21 15:00:57.814	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.813	warn	Could not perform strict object check of state net-tools.0.c45bbe556fde.alive: DB closed
                                  net-tools.0
                                  	2024-01-21 15:00:57.812	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.812	warn	Could not perform strict object check of state net-tools.0.308398a2f258.rps: DB closed
                                  net-tools.0
                                  	2024-01-21 15:00:57.811	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.810	warn	Could not perform strict object check of state net-tools.0.308398a2f258.time: DB closed
                                  net-tools.0
                                  	2024-01-21 15:00:57.810	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.809	warn	Could not perform strict object check of state net-tools.0.308398a2f258.alive: DB closed
                                  net-tools.0
                                  	2024-01-21 15:00:57.808	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.808	warn	Could not perform strict object check of state net-tools.0.b48a0ac70e0e.rps: DB closed
                                  net-tools.0
                                  	2024-01-21 15:00:57.807	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.806	warn	Could not perform strict object check of state net-tools.0.b48a0ac70e0e.time: DB closed
                                  net-tools.0
                                  	2024-01-21 15:00:57.805	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.804	warn	Could not perform strict object check of state net-tools.0.b48a0ac70e0e.alive: DB closed
                                  net-tools.0
                                  	2024-01-21 15:00:57.804	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.803	warn	Could not perform strict object check of state net-tools.0.70039f01361f.rps: DB closed
                                  net-tools.0
                                  	2024-01-21 15:00:57.802	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.802	warn	Could not perform strict object check of state net-tools.0.70039f01361f.time: DB closed
                                  net-tools.0
                                  	2024-01-21 15:00:57.800	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.798	warn	Could not perform strict object check of state net-tools.0.70039f01361f.alive: DB closed
                                  net-tools.0
                                  	2024-01-21 15:00:57.797	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.797	warn	Could not perform strict object check of state net-tools.0.ec94cb7b5908.rps: DB closed
                                  net-tools.0
                                  	2024-01-21 15:00:57.796	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.795	warn	Could not perform strict object check of state net-tools.0.ec94cb7b5908.time: DB closed
                                  net-tools.0
                                  	2024-01-21 15:00:57.795	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.794	warn	Could not perform strict object check of state net-tools.0.ec94cb7b5908.alive: DB closed
                                  net-tools.0
                                  	2024-01-21 15:00:57.793	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.792	warn	Could not perform strict object check of state net-tools.0.d85ed3f769e8.rps: DB closed
                                  net-tools.0
                                  	2024-01-21 15:00:57.792	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.791	warn	Could not perform strict object check of state net-tools.0.d85ed3f769e8.time: DB closed
                                  net-tools.0
                                  	2024-01-21 15:00:57.790	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.790	warn	Could not perform strict object check of state net-tools.0.d85ed3f769e8.alive: DB closed
                                  net-tools.0
                                  	2024-01-21 15:00:57.789	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.788	warn	Could not perform strict object check of state net-tools.0.c45bbe5536ee.rps: DB closed
                                  net-tools.0
                                  	2024-01-21 15:00:57.788	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.787	warn	Could not perform strict object check of state net-tools.0.c45bbe5536ee.time: DB closed
                                  net-tools.0
                                  	2024-01-21 15:00:57.786	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.785	warn	Could not perform strict object check of state net-tools.0.c45bbe5536ee.alive: DB closed
                                  net-tools.0
                                  	2024-01-21 15:00:57.785	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.784	warn	Could not perform strict object check of state net-tools.0.4827e22eda50.rps: DB closed
                                  net-tools.0
                                  	2024-01-21 15:00:57.783	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.783	warn	Could not perform strict object check of state net-tools.0.4827e22eda50.time: DB closed
                                  net-tools.0
                                  	2024-01-21 15:00:57.782	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.781	warn	Could not perform strict object check of state net-tools.0.4827e22eda50.alive: DB closed
                                  net-tools.0
                                  	2024-01-21 15:00:57.758	warn	get state error: Connection is closed.
                                  net-tools.0
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.757	warn	get state error: Connection is closed.
                                  net-tools.0
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.756	warn	get state error: Connection is closed.
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.755	warn	get state error: Connection is closed.
                                  net-tools.0
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.754	warn	get state error: Connection is closed.
                                  net-tools.0
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.753	warn	get state error: Connection is closed.
                                  net-tools.0
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.752	warn	get state error: Connection is closed.
                                  net-tools.0
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.751	warn	get state error: Connection is closed.
                                  net-tools.0
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.750	warn	get state error: Connection is closed.
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.749	warn	get state error: Connection is closed.
                                  net-tools.0
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.748	warn	get state error: Connection is closed.
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.747	warn	get state error: Connection is closed.
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.746	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.745	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.744	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.743	warn	get state error: Connection is closed.
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.742	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.741	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.740	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.739	warn	get state error: Connection is closed.
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.738	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.737	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.736	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.735	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.734	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.733	warn	get state error: Connection is closed.
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.732	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.731	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.730	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.729	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.728	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.727	warn	get state error: Connection is closed.
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.726	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.725	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.724	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.723	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.722	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.711	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.710	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.709	warn	get state error: Connection is closed.
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.708	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.707	warn	get state error: Connection is closed.
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.706	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.705	warn	get state error: Connection is closed.
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.704	warn	get state error: Connection is closed.
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.703	warn	get state error: Connection is closed.
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.702	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.701	warn	get state error: Connection is closed.
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.700	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.699	warn	get state error: Connection is closed.
                                  net-tools.0
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.698	warn	get state error: Connection is closed.
                                  net-tools.0
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.697	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.695	warn	get state error: Connection is closed.
                                  net-tools.0
                                  	2024-01-21 15:00:57.694	warn	get state error: Connection is closed.
                                  net-tools.0
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.693	warn	get state error: Connection is closed.
                                  net-tools.0
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.692	warn	get state error: Connection is closed.
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.691	warn	get state error: Connection is closed.
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.645	warn	setTimeout called, but adapter is shutting down
                                  net-tools.0
                                  	2024-01-21 15:00:57.644	warn	setTimeout called, but adapter is shutting down
                                  net-tools.0
                                  	2024-01-21 15:00:57.643	warn	setTimeout called, but adapter is shutting down
                                  net-tools.0
                                  	2024-01-21 15:00:57.642	warn	setTimeout called, but adapter is shutting down
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.641	warn	setTimeout called, but adapter is shutting down
                                  net-tools.0
                                  	2024-01-21 15:00:57.640	warn	setTimeout called, but adapter is shutting down
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.639	warn	setTimeout called, but adapter is shutting down
                                  net-tools.0
                                  	2024-01-21 15:00:57.638	warn	setTimeout called, but adapter is shutting down
                                  net-tools.0
                                  	2024-01-21 15:00:57.637	warn	setTimeout called, but adapter is shutting down
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.636	warn	setTimeout called, but adapter is shutting down
                                  net-tools.0
                                  	2024-01-21 15:00:57.635	warn	setTimeout called, but adapter is shutting down
                                  net-tools.0
                                  	2024-01-21 15:00:57.634	warn	setTimeout called, but adapter is shutting down
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.633	warn	setTimeout called, but adapter is shutting down
                                  net-tools.0
                                  	2024-01-21 15:00:57.632	warn	setTimeout called, but adapter is shutting down
                                  net-tools.0
                                  	2024-01-21 15:00:57.631	warn	setTimeout called, but adapter is shutting down
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.629	warn	setTimeout called, but adapter is shutting down
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.628	warn	setTimeout called, but adapter is shutting down
                                  net-tools.0
                                  	2024-01-21 15:00:57.627	warn	setTimeout called, but adapter is shutting down
                                  net-tools.0
                                  	2024-01-21 15:00:57.626	warn	setTimeout called, but adapter is shutting down
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.625	warn	setTimeout called, but adapter is shutting down
                                  net-tools.0
                                  	2024-01-21 15:00:57.624	warn	setTimeout called, but adapter is shutting down
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.623	warn	setTimeout called, but adapter is shutting down
                                  net-tools.0
                                  	2024-01-21 15:00:57.622	warn	setTimeout called, but adapter is shutting down
                                  net-tools.0
                                  	2024-01-21 15:00:57.621	warn	setTimeout called, but adapter is shutting down
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.620	warn	setTimeout called, but adapter is shutting down
                                  net-tools.0
                                  	2024-01-21 15:00:57.619	warn	setTimeout called, but adapter is shutting down
                                  net-tools.0
                                  net-tools.0
                                  	2024-01-21 15:00:57.618	warn	setTimeout called, but adapter is shutting down
                                  net-tools.0
                                  	2024-01-21 15:00:57.617	warn	setTimeout called, but adapter is shutting down
                                  net-tools.0
                                  	2024-01-21 15:00:57.616	warn	setTimeout called, but adapter is shutting down
                                  net-tools.0
                                  	2024-01-21 15:00:57.615	warn	setTimeout called, but adapter is shutting down
                                  net-tools.0
                                  	2024-01-21 15:00:57.614	warn	setTimeout called, but adapter is shutting down
                                  net-tools.0
                                  	2024-01-21 15:00:57.613	warn	setTimeout called, but adapter is shutting down
                                  net-tools.0
                                  	2024-01-21 15:00:57.593	info	terminating
                                  net-tools.0
                                  	2024-01-21 15:00:57.021	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                  net-tools.0
                                  	2024-01-21 15:00:57.019	info	terminating
                                  net-tools.0
                                  	2024-01-21 15:00:56.980	error	Cannot read properties of undefined (reading 'stateAlive')
                                  net-tools.0
                                  	2024-01-21 15:00:56.979	error	uncaught exception: Cannot read properties of undefined (reading 'stateAlive') at /opt/iobroker/node_modules/iobroker.net-tools/main.js:523:35 at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/ping.js:144:15) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                                  net-tools.0
                                  	2024-01-21 15:00:56.978	error	Cannot read properties of undefined (reading 'stateAlive')
                                  net-tools.0
                                  	2024-01-21 15:00:56.979	error	TypeError: Cannot read properties of undefined (reading 'stateAlive')
                                  net-tools.0
                                  	2024-01-21 15:00:56.977	error	uncaught exception: Cannot read properties of undefined (reading 'stateAlive') at /opt/iobroker/node_modules/iobroker.net-tools/main.js:523:35 at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/ping.js:144:15) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                                  net-tools.0
                                  	2024-01-21 15:00:56.976	error	Cannot read properties of undefined (reading 'stateAlive')
                                  net-tools.0
                                  	2024-01-21 15:00:56.977	error	TypeError: Cannot read properties of undefined (reading 'stateAlive')
                                  net-tools.0
                                  	2024-01-21 15:00:56.975	error	uncaught exception: Cannot read properties of undefined (reading 'stateAlive') at /opt/iobroker/node_modules/iobroker.net-tools/main.js:523:35 at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/ping.js:144:15) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                                  net-tools.0
                                  	2024-01-21 15:00:56.974	error	Cannot read properties of undefined (reading 'stateAlive')
                                  net-tools.0
                                  	2024-01-21 15:00:56.975	error	TypeError: Cannot read properties of undefined (reading 'stateAlive')
                                  net-tools.0
                                  	2024-01-21 15:00:56.973	error	uncaught exception: Cannot read properties of undefined (reading 'stateAlive') at /opt/iobroker/node_modules/iobroker.net-tools/main.js:523:35 at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/ping.js:144:15) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                                  net-tools.0
                                  	2024-01-21 15:00:56.972	error	Cannot read properties of undefined (reading 'stateAlive')
                                  net-tools.0
                                  	2024-01-21 15:00:56.973	error	TypeError: Cannot read properties of undefined (reading 'stateAlive')
                                  net-tools.0
                                  	2024-01-21 15:00:56.971	error	uncaught exception: Cannot read properties of undefined (reading 'stateAlive') at /opt/iobroker/node_modules/iobroker.net-tools/main.js:523:35 at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/ping.js:144:15) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                                  net-tools.0
                                  	2024-01-21 15:00:56.970	error	Cannot read properties of undefined (reading 'stateAlive')
                                  net-tools.0
                                  	2024-01-21 15:00:56.971	error	TypeError: Cannot read properties of undefined (reading 'stateAlive')
                                  net-tools.0
                                  	2024-01-21 15:00:56.969	error	TypeError: Cannot read properties of undefined (reading 'stateAlive') at /opt/iobroker/node_modules/iobroker.net-tools/main.js:523:35 at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/ping.js:144:15) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                                  net-tools.0
                                  	2024-01-21 15:00:56.969	error	uncaught exception: Cannot read properties of undefined (reading 'stateAlive')
                                  net-tools.0
                                  	2024-01-21 15:00:56.968	error	TypeError: Cannot read properties of undefined (reading 'stateAlive') at /opt/iobroker/node_modules/iobroker.net-tools/main.js:523:35 at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/ping.js:144:15) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                                  net-tools.0
                                  	2024-01-21 15:00:56.967	error	uncaught exception: Cannot read properties of undefined (reading 'stateAlive')
                                  net-tools.0
                                  	2024-01-21 15:00:56.968	error	Cannot read properties of undefined (reading 'stateAlive')
                                  net-tools.0
                                  	2024-01-21 15:00:56.966	error	Cannot read properties of undefined (reading 'stateAlive')
                                  net-tools.0
                                  	2024-01-21 15:00:56.966	error	TypeError: Cannot read properties of undefined (reading 'stateAlive') at /opt/iobroker/node_modules/iobroker.net-tools/main.js:523:35 at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/ping.js:144:15) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                                  net-tools.0
                                  	2024-01-21 15:00:56.965	error	uncaught exception: Cannot read properties of undefined (reading 'stateAlive')
                                  net-tools.0
                                  	2024-01-21 15:00:56.964	error	TypeError: Cannot read properties of undefined (reading 'stateAlive') at /opt/iobroker/node_modules/iobroker.net-tools/main.js:523:35 at ChildProcess.<anonymous> (/opt/iobroker/node_modules/iobroker.net-tools/lib/ping.js:144:15) at ChildProcess.emit (node:events:517:28) at ChildProcess._handle.onexit (node:internal/child_process:292:12)
                                  net-tools.0
                                  	2024-01-21 15:00:56.964	error	uncaught exception: Cannot read properties of undefined (reading 'stateAlive')
                                  net-tools.0
                                  	2024-01-21 15:00:56.964	error	Cannot read properties of undefined (reading 'stateAlive')
                                  net-tools.0
                                  	2024-01-21 15:00:56.963	error	Cannot read properties of undefined (reading 'stateAlive')
                                  • teletapi
                                    teletapi @teletapi last edited by teletapi
                                    Morjen, ich denke ich weiß jetzt woher die Fehler und warnungen kommen.
                                    Ich hab heute morgen gesehen das der "Net-tools" Adapter in der version 1.03 vorhanden ist und hab den nochmal installiert, eigentlich wollte ich damit nur schauen ob ich vielleicht einen fehler bei der Installation über die Katze ein Fehler gemacht habe. Nach der Installation blieben die Fehler und Warnungen aber die gleichen.
                                    Dabei hab ich im Protocol aber gesehen das der Discovery Adapter scheinbar immer mit reagiert wenn ich die Gerätesuche im Net-Tools adapter starte.
                                    Dann hab ich nochmal bei den Instanzen geschaut und da fielen mir die beiden Adapter "Ping" und "Discovery" auf und habe diese einfach mal gestoppt und dann den Net-tools Adapter laufen lassen neu gestartet und die Geräte suche laufen lassen, dabei wurden alle Geräte gefunden. Seiddem hat der Adapter keinen fehler mehr gezeigt
                                    Den Ping Adapter habe ich mittlerweile wieder aktiviert und beide Adapter mal unabhängig voneinander neu gestartet das scheint den Net-tools Adapter aber nicht zu stören. Dürfte dann also der "Discovery Adapter" sein der hier in Verbindung mit dem Net-tools Adapter Probleme macht.
                                    Sobald ich dann die Gerätesuche im Net-tools Adapter starte startet auch der Discovery Adapter neu und die Fehler sind wieder da
                                    Skript v.2023-10-10
                                    *** BASE SYSTEM ***
                                       Static hostname: iobroker
                                             Icon name: computer
                                      Operating System: Debian GNU/Linux 11 (bullseye)
                                                Kernel: Linux 6.1.21-v8+
                                          Architecture: arm64
                                    Model           : Raspberry Pi 4 Model B Rev 1.5
                                    Docker          : false
                                    Virtualization  : none
                                    Kernel          : aarch64
                                    Userland        : arm64
                                    Systemuptime and Load:
                                     10:46:21 up 34 min,  1 user,  load average: 1.39, 1.25, 1.20
                                    CPU threads: 4
                                    *** RASPBERRY THROTTLING ***
                                    Current issues:
                                    Previously detected issues:
                                    *** Time and Time Zones ***
                                                   Local time: Mon 2024-01-22 10:46:21 CET
                                               Universal time: Mon 2024-01-22 09:46:21 UTC
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    *** User and Groups ***
                                    pi
                                    /home/pi
                                    pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                                    *** X-Server-Setup ***
                                    X-Server:       false
                                    Desktop:
                                    Terminal:       tty
                                    Boot Target:    multi-user.target
                                    *** MEMORY ***
                                    Mem:            7.8G        2.3G        3.7G        1.0M        1.7G        5.3G
                                    Swap:            99M          0B         99M
                                    Total:          7.9G        2.3G        3.8G
                                             7811 M total memory
                                             2343 M used memory
                                             3335 M active memory
                                              583 M inactive memory
                                             3727 M free memory
                                              121 M buffer memory
                                             1619 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FAILED SERVICES ***
                                    0 loaded units listed.
                                    *** FILESYSTEM ***
                                    /dev/root      ext4       59G  9.2G   47G  17% /
                                    devtmpfs       devtmpfs  3.6G     0  3.6G   0% /dev
                                    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                                    tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
                                    /dev/sda1      vfat      255M   31M  225M  13% /boot
                                    tmpfs          tmpfs     782M   16K  782M   1% /run/user/1000
                                    [Mon Jan 22 10:12:17 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:13:A5:D1 vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=tty1 root=PARTUUID=2c0392e1-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                    [Mon Jan 22 10:12:19 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                                    [Mon Jan 22 10:12:19 2024] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                                    [Mon Jan 22 10:12:20 2024] EXT4-fs (sda2): re-mounted. Quota mode: none.
                                    TARGET  SOURCE    FSTYPE OPTIONS
                                    /       /dev/sda2 ext4   rw,noatime
                                    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                    /var:
                                    1.9G    /var/
                                    1.1G    /var/log/journal/a9f1eae0dc5a48ddbf0e2a62c2227673
                                    1.1G    /var/log
                                    619M    /var/lib
                                    Archived and active journals take up 1.0G in the file system.
                                    /opt/iobroker/backups:
                                    1.8G    /opt/iobroker/backups/
                                    /opt/iobroker/iobroker-data:
                                    352M    /opt/iobroker/iobroker-data/
                                    181M    /opt/iobroker/iobroker-data/files
                                    77M     /opt/iobroker/iobroker-data/backup-objects
                                    72M     /opt/iobroker/iobroker-data/node-red
                                    71M     /opt/iobroker/iobroker-data/node-red/node_modules
                                    33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                                    22M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js.map
                                    15M     /opt/iobroker/iobroker-data/objects.jsonl
                                    8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
                                    8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.c05ba1d3.js
                                    USB-Devices by-id:
                                    *** NodeJS-Installation ***
                                    /usr/bin/nodejs         v18.19.0
                                    /usr/bin/node           v18.19.0
                                    /usr/bin/npm            10.2.3
                                    /usr/bin/npx            10.2.3
                                    /usr/bin/corepack       0.22.0
                                    nodejs:
                                      Installed: 18.19.0-1nodesource1
                                      Candidate: 18.19.0-1nodesource1
                                      Version table:
                                     *** 18.19.0-1nodesource1 1001
                                            100 /var/lib/dpkg/status
                                         18.18.2-1nodesource1 1001
                                         18.18.1-1nodesource1 1001
                                         18.18.0-1nodesource1 1001
                                         18.17.1-1nodesource1 1001
                                         18.17.0-1nodesource1 1001
                                         18.16.1-1nodesource1 1001
                                         18.16.0-1nodesource1 1001
                                         18.15.0-1nodesource1 1001
                                         18.14.2-1nodesource1 1001
                                         18.14.1-1nodesource1 1001
                                         18.14.0-1nodesource1 1001
                                         18.13.0-1nodesource1 1001
                                         18.12.0-1nodesource1 1001
                                         18.11.0-1nodesource1 1001
                                         18.10.0-1nodesource1 1001
                                         18.9.1-1nodesource1 1001
                                         18.9.0-1nodesource1 1001
                                         18.8.0-1nodesource1 1001
                                         18.7.0-1nodesource1 1001
                                         18.6.0-1nodesource1 1001
                                         18.5.0-1nodesource1 1001
                                         18.4.0-1nodesource1 1001
                                         18.3.0-1nodesource1 1001
                                         18.2.0-1nodesource1 1001
                                         18.1.0-1nodesource1 1001
                                         18.0.0-1nodesource1 1001
                                         12.22.12~dfsg-1~deb11u4 500
                                            500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                    No problems detected
                                    Errors in npm tree:
                                    *** ioBroker-Installation ***
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Core adapters versions
                                    admin:          6.13.15
                                    javascript:     7.7.0
                                    Adapters from github:   2
                                    Adapter State
                                    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                                      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
                                    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                                      system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                                    + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
                                    + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
                                    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                                    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 18701
                                    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 12001
                                    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 12010
                                    + system.adapter.hm-rpc.3                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                    + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
                                      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                    + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                                    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                                    + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                                    + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
                                    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                    + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
                                    + system.adapter.nuki.0                   : nuki                  : iobroker                                 -  enabled
                                    + system.adapter.opendtu.0                : opendtu               : iobroker                                 -  enabled
                                    + system.adapter.philips-tv.0             : philips-tv            : iobroker                                 -  enabled
                                      system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
                                    + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
                                    + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 192.168.178.82, run as: admin
                                    + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                                    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
                                    + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                                    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                                    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                                    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                    + instance is alive
                                    ioBroker-Repositories
                                    Active repo(s): beta
                                    Installed ioBroker-Instances
                                    Used repository: beta
                                    Adapter    "admin"        : 6.13.15  , installed 6.13.15
                                    Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
                                    Adapter    "backitup"     : 2.10.4   , installed 2.10.4
                                    Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
                                    Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                                    Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
                                    Adapter    "hue"          : 3.10.2   , installed 3.10.2
                                    Adapter    "ical"         : 1.14.0   , installed 1.14.0
                                    Adapter    "iot"          : 2.0.11   , installed 2.0.11
                                    Adapter    "jarvis"       : 3.1.8    , installed 3.1.9-beta.3
                                    Adapter    "javascript"   : 7.7.0    , installed 7.7.0
                                    Controller "js-controller": 5.0.17   , installed 5.0.17
                                    Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
                                    Adapter    "net-tools"    : 1.0.3    , installed 1.0.3
                                    Adapter    "node-red"     : 5.1.0    , installed 5.1.0
                                    Adapter    "nuki"         : 1.6.0    , installed 1.6.0
                                    Adapter    "opendtu"      : 1.0.1    , installed 1.0.1
                                    Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
                                    Adapter    "shelly"       : 6.7.0    , installed 6.7.0
                                    Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                                    Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                                    Adapter    "telegram"     : 3.0.1    , installed 3.0.1
                                    Adapter    "web"          : 6.2.3    , installed 6.2.3
                                    Adapter    "ws"           : 2.5.10   , installed 2.5.10
                                    Objects and States
                                    Objects:        10033
                                    States:         10104
                                    Hit:1 http://deb.debian.org/debian bullseye InRelease
                                    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                                    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                                    Hit:5 https://apt.grafana.com stable InRelease
                                    Hit:6 https://repos.influxdata.com/debian stable InRelease
                                    Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                                    Reading package lists...
                                    Pending Updates: 0
                                    *** Listening Ports ***
                                    tcp        0      0 192.168.178.82:12010    0.0.0.0:*               LISTEN      1001       17711      1371/io.hm-rpc.2
                                    tcp        0      0 192.168.178.82:12001    0.0.0.0:*               LISTEN      1001       16319      1349/io.hm-rpc.1
                                    tcp        0      0 192.168.178.82:8087     0.0.0.0:*               LISTEN      1001       19209      1936/io.simple-api.
                                    tcp        0      0 192.168.178.82:18701    0.0.0.0:*               LISTEN      1001       17018      1328/io.hm-rpc.0
                                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16412      540/cupsd
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11882      576/sshd: /usr/sbin
                                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14752      657/iobroker.js-con
                                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       12133      657/iobroker.js-con
                                    tcp        0      0 192.168.178.82:2001     0.0.0.0:*               LISTEN      1001       17184      1425/io.hm-rpc.3
                                    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       23289      1856/io.jarvis.0
                                    tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       17603      1247/node-red
                                    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       18758      1561/io.shelly.0
                                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      116        15492      558/mosquitto
                                    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       18120      1498/io.sonoff.0
                                    tcp        0      0 192.168.178.82:9092     0.0.0.0:*               LISTEN      1001       24733      1922/io.nuki.0
                                    tcp6       0      0 :::3000                 :::*                    LISTEN      117        14648      656/grafana
                                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15817      1079/io.admin.0
                                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21540      1656/io.web.0
                                    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       24693      2164/io.socketio.0
                                    tcp6       0      0 :::8086                 :::*                    LISTEN      999        11946      549/influxd
                                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16411      540/cupsd
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          11884      576/sshd: /usr/sbin
                                    tcp6       0      0 :::1883                 :::*                    LISTEN      116        15493      558/mosquitto
                                    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          11920      617/cups-browsed
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11257      401/avahi-daemon: r
                                    udp        0      0 0.0.0.0:48832           0.0.0.0:*                           108        11259      401/avahi-daemon: r
                                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14641      461/dhcpcd
                                    udp6       0      0 :::546                  :::*                                0          14661      461/dhcpcd
                                    udp6       0      0 :::5353                 :::*                                108        11258      401/avahi-daemon: r
                                    udp6       0      0 :::53051                :::*                                108        11260      401/avahi-daemon: r
                                    2024-01-22 10:39:04.632  - info: host.iobroker stopInstance system.adapter.net-tools.0 (force=false, process=true)
                                    2024-01-22 10:39:04.766  - info: net-tools.0 (8472) Got terminate signal TERMINATE_YOURSELF
                                    2024-01-22 10:39:04.771  - info: host.iobroker stopInstance system.adapter.net-tools.0 send kill signal
                                    2024-01-22 10:39:04.772  - info: net-tools.0 (8472) terminating
                                    2024-01-22 10:39:04.774  - info: net-tools.0 (8472) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2024-01-22 10:39:05.276  - info: net-tools.0 (8472) terminating
                                    2024-01-22 10:39:05.434  - info: host.iobroker instance system.adapter.net-tools.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2024-01-22 10:39:07.862  - info: host.iobroker instance system.adapter.net-tools.0 started with pid 8574
                                    2024-01-22 10:39:10.364  - info: net-tools.0 (8574) starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.net-tools, node: v18.19.0, js-controller: 5.0.17
                                    2024-01-22 10:39:10.579  - info: net-tools.0 (8574) License Key is valid
                                    2024-01-22 10:39:10.587  - info: net-tools.0 (8574) Scanning for open ports (20, 21, 22, 23, 25, 53, 80, 110, 119, 123, 143, 161, 162, 194, 443, 445, 3306, 3389, 5900, 6379, 8080, 8443, 9090, 9200, 9999) at localhost, please wait
                                    2024-01-22 10:39:13.207  - info: net-tools.0 (8574) Port scan finished
                                    Jey Cee mcm1957 2 Replies Last reply Reply Quote 0
                                    • Jey Cee
                                      Jey Cee Developer @teletapi last edited by
                                      @teletapi das ist gut zu wissen. Der discovery adapter ist als dependency eingetragen und sollte so bei bedarf mit installiert werden, falls er nich da ist. Gestartet wird er Automatisch wenn er nicht läuft.
                                      Da muss ich also noch zusätzlich Warnmeldungen einbauen.
                                      • mcm1957
                                        mcm1957 @teletapi last edited by
                                        @teletapi said in Net-Tools update auf 1.0.1 Fehler:
                                        Ping und net-tools sollten sich in keiner Weise gegenseitig beeinflussen.
                                        Da meines Wissens nach net-tools die Funktion(en) des discovery Adapters zur Gerätesuche verwendet ist dieses Verhalten logisch erklärbar. Genau aus diesem Grunde setzt ja net-tools auch die INstallation von discovery voraus.
                                        • teletapi
                                          teletapi @mcm1957 last edited by teletapi
                                          @mcm57 Das war mir natürlich so nicht ganz bewusst und hab ich erst im Nachgang einigermaßen verstanden. Die Fehler die dann dabei entstehen versteh ich halt nicht...... Wie ich sovieles noch immer nicht verstehe was alle Adapter,abhängigkeiten usw. angeht. Da bin ich ganz auf euer aller Hilfe angewiesen
                                          • mcm1957
                                            Ja passt schon.
                                            Jey-Cee wird sich die Fehler garantiert zeitnahe ansehen.
                                            1457
