      ticaki Developer @docf last edited by ticaki
      @docf
      lösche mal das <PageItem> . Die könntest du mit suchen und entfernen alle aus der config oben rauswerfen, dieses erzwungene Überschreiben der Typprüfung macht nur Probleme.
      javascript.2 (728) script.js.NsPanel.nsPanel1: TypeScript compilation failed: let Alexa: PageType = { ^ ERROR: Type '{ type: "cardMedia"; heading: string; items: [NSPanel.PageItem]; }' is not assignable to type 'PageType'. Types of property ''items'' are incompatible. Type '[PageItem]' is not assignable to type '[PageMediaItem] & PageItem[]'. Type '[PageItem]' is not assignable to type '[PageMediaItem]'. Type 'PageItem' is not assignable to type 'PageMediaItem'. Type 'PageBaseItem' is not assignable to type 'PageMediaItem'. Property 'adapterPlayerInstance' is missing in type 'PageBaseItem' but required in type '{ adapterPlayerInstance: adapterPlayerInstanceType; mediaDevice?: string; colorMediaIcon?: RGB; colorMediaArtist?: RGB; colorMediaTitle?: RGB; ... 5 more ...; crossfade?: boolean; }'.
        docf @ticaki last edited by
        @ticaki
        Super Danke hat das Problem bzw. die Fehlermeldungen behoben.
          TT-Tom @docf last edited by
          @docf
          // Hauptseite
           var Seite1 = <PageGrid>
          Das hast du auch angepasst?
          let Seite1: PageType
            docf @TT-Tom last edited by
            @tt-tom
            wenn ich von
            auf
            ändere bekomme ich diesen Fehler?
            javascript.0 (1526) script.js.NS_Panels.NSPPanel43336_Test: TypeScript compilation failed: "cardGrid", ^ ERROR: Left side of comma operator is unused and has no side effects. "Erster Test", ^ ERROR: Left side of comma operator is unused and has no side effects. false, ^ ERROR: Left side of comma operator is unused and has no side effects. undefined, ^ ERROR: Left side of comma operator is unused and has no side effects.
              @docf
              Er hat das = vergessen also let Seite1: PageType =
              • Armilar
                Armilar Most Active Forum Testing @docf last edited by
                @docf
                sieht bei mir so aus und läuft damit...
                let Sonos: PageType =
                    'type': 'cardMedia',
                    'heading': 'Sonos Player',
                    'items': [{
                                id: AliasPath + 'Media.PlayerSonos',
                                adapterPlayerInstance: 'sonos.0.',
                                mediaDevice: '192_168_1_212',
                                speakerList: ['Terrasse'],
                                playList: ['Hartmann','Armilars Playlist'],
                                colorMediaIcon: colorSonos,
                                colorMediaArtist: Yellow,
                                colorMediaTitle: Yellow,
                                //crossfade: true,
                                alwaysOnDisplay: true,
                                autoCreateALias: true
                  @ticaki
                  Ach sorry habe ich ganz übersehen
                  Jetzt läuft alles
                  Danke euch
                    Kunibert last edited by Kunibert
                    Hi zusammen,
                    jetzt brauche ich doch auch nochmal Support von euch. Ich steuere alle meine Panels fehlerfrei mit Skriptversion 4.3.3.36 und wollte gerade auf die 38 updaten. Habe den Teil ab "Ab hier keine Konfiguration mehr" ausgetauscht, mein Skript läuft aber gleich auf Fehler.
                    Ich habe testweise überall <PageItem> vor { id:... entfernt, das ändert aber nichts am Fehlerbild.
                    Bedeutet es, dass sich zwischen der V36 und der V38 etwas geändert hat, was eigene Skriptanpassungen erfordert?
                    Mein Fehler:
                    10:49:53.428 error javascript.0 (205) script.js.common.Panels.PanelEG1_4_3_3_38: TypeScript compilation failed: let L6xFahrplan: PageType = { ^ ERROR: Type '{ type: "cardEntities"; heading: string; useColor: true; subPage: true; parent: NSPanel.PageGrid; next: string; nextIcon: string; items: [NSPanel.PageItem, NSPanel.PageItem, NSPanel.PageItem, NSPanel.PageItem, NSPanel.PageItem, NSPanel.PageItem]; }' is not assignable to type 'PageType'. Types of property ''items'' are incompatible. Type '[PageItem, PageItem, PageItem, PageItem, PageItem, PageItem]' is not assignable to type '[PageItem?, PageItem?, PageItem?, PageItem?, PageItem?] & PageItem[]'. Type '[PageItem, PageItem, PageItem, PageItem, PageItem, PageItem]' is not assignable to type '[PageItem?, PageItem?, PageItem?, PageItem?, PageItem?]'. Source has 6 element(s) but target allows only 5.
                    TypeScript v4.3.3.38 zur Steuerung des SONOFF NSPanel mit dem ioBroker by @Armilar / @TT-Tom / @ticaki / @Britzelpuf / @Sternmiere / @ravenS0ne
                    - abgestimmt auf TFT 53 / v4.3.3 / BerryDriver 9 / Tasmota 13.3.0
                    @joBr99 Projekt: https://github.com/joBr99/nspanel-lovelace-ui/tree/main/ioBroker
                    NsPanelTs.ts (dieses TypeScript in ioBroker) Stable: https://github.com/joBr99/nspanel-lovelace-ui/blob/main/ioBroker/NsPanelTs.ts
                    icon_mapping.ts: https://github.com/joBr99/nspanel-lovelace-ui/blob/main/ioBroker/icon_mapping.ts (TypeScript muss in global liegen)
                    ioBroker-Unterstützung: https://forum.iobroker.net/topic/50888/sonoff-nspanel
                    @Kuckuckmann: WIKI zu diesem Projekt unter: https://github.com/joBr99/nspanel-lovelace-ui/wiki (siehe Sidebar)
                    Achtung: Keine Beispiele mehr im Script. Die Beispiele sind jetzt unter nachfolgendem Link zu finden:
                    -  https://github.com/joBr99/nspanel-lovelace-ui/wiki/NSPanel-Page-%E2%80%90-Typen_How-2_Beispiele
                    Icons unter: https://htmlpreview.github.io/?https://github.com/jobr99/Generate-HASP-Fonts/blob/master/cheatsheet.html
                    Achtung Änderung des Sonoff ESP-Temperatursensors
                    !!! Bitte "SetOption146 1" in der Tasmota-Console ausführen !!!
                    In bestimmten Situationen kommt es vor, dass sich das Panel mit FlashNextion
                    unter Tasmota > 12.2.0 nicht flashen lässt. Für den Fall ein Tasmota Downgrade
                    durchführen und FlashNextion wiederholen.
                    Ab Tasmota > 13.0.0 ist für ein Upgrade ggfs. eine Umpartitionierung erforderlich
                    https://github.com/joBr99/nspanel-lovelace-ui/wiki/NSPanel-Tasmota-FAQ#3-tasmota-update-probleme
                    Ab Script Version 4.3.2.1 muss in der JavaScript Instanz die npm Module 'moment', 'moment-parseformat' und 'dayjs' eingetragen sein
                    https://github.com/joBr99/nspanel-lovelace-ui/wiki/iobroker---Basisinstallation#8--einstellungen-in-js-adapter-instanz
                    ReleaseNotes:
                        Bugfixes und Erweiterungen:
                    	See ChangeLog all Release Notes: https://github.com/joBr99/nspanel-lovelace-ui/wiki/Release-Notes
                            - 08.11.2023 - v4.3.3    Upgrade TFT 53 / 4.3.3
                            - 11.11.2023 - v4.3.3.1  Fix for Issues #1020 HandleHardwareButton buttonConfig.mode -> 'toggle' and 'set'
                            - 12.11.2023 - v4.3.3.2  Add autoCreateALias to cardUnlock
                            - 12.11.2023 - v4.3.3.2  Change NodeJS to at least v18.X.X
                            - 13.11.2023 - v4.3.3.3  if setOption = false, do not create autoAlias (Functional/Servicemenu) and Datapoints
                            - 15.11.2023 - v4.3.3.4  New Service Page -> ioBroker Info
                            - 16.11.2023 - v4.3.3.5  Add Multilingualism to Service Menu (39 languages)
                         	- 17.11.2023 - v4.3.3.5  Add Multilingualism to cardUnlock, cardQR, popupFan, popupTimer (39 languages)
                            - 18.11.2023 - v4.3.3.6  Add autoCreateALias to PageAlarm
                            - 20.11.2023 - v4.3.3.6  Add actionStringArray to PageAlarm
                            - 20.11.2023 - v4.3.3.6  Add Multilingualism to cardAlarm (39 languages)
                            - 20.11.2023 - v4.3.3.7  Add Multilingualism to cardMedia (39 languages)
                            - 20.11.2023 - v4.3.3.8  Add Method dayjs (Multilingualism)
                            - 20.11.2023 - v4.3.3.9  Add ScreensaverEntityOnColor, ...OffColor, ...OnText, ...OffText
                            - 23.11.2023 - v4.3.3.10 Code Optimization in Config Area
                            - 24.11.2023 - v4.3.3.11 Add autoCreateALias to PageQR
                            - 24.11.2023 - v4.3.3.12 Separation of page creation and page updates in cardPower
                            - 24.11.2023 - v4.3.3.12 Add alwaysOnDisplay to cardPower - Leave display on if the alwaysOnDisplay parameter is "true"
                            - 25.11.2023 - v4.3.3.13 Separation of page creation and page updates in cardMedia
                            - 25.11.2023 - v4.3.3.13 Add alwaysOnDisplay to cardMedia - Leave display on if the alwaysOnDisplay parameter is "true"
                            - 25.11.2023 - v4.3.3.13 Fix Sonos Repeat/Shuffle
                            - 25.11.2023 - v4.3.3.14 Refactoring Sonos-Player (with Playlist, Tracklist, Favorites, Eqalizer (if no Favorites))
                            - 29.11.2023 - v4.3.3.15 Fix cardMedia Volume-Slider / Add Init Release to Startup
                            - 30.11.2023 - v4.3.3.16 Beautification of the Sonos player Strings / Add Duration & Elapsed
                            - 01.12.2023 - v4.3.3.16 Fix Datapoints with Value null
                            - 02.12.2023 - v4.3.3.16 Request replaced by Axios
                            - 04.12.2023 - v4.3.3.17 Add SEEK and CROSSFADE to Sonos cardMedia
                            - 05.12.2023 - v4.3.3.18 Add (ELAPSED/DURATION) to v2Adapter alexa2
                            - 06.12.2023 - v4.3.3.18 Replace missing Type console.log --> log(message, 'serverity')
                            - 07.12.2023 - v4.3.3.19 Fix Trigger activeDimmodeBrightness if Dimmode = -1
                            - 08.12.2023 - v4.3.3.20 add Role AlarmTime for Alarm Clock
                            - 09.12.2023 - v4.3.3.21 Add createAutoAlias to popupTimer only for Time
                            - 14.12.2023 - v4.3.3.22 Add UpdateMessage => disable the update messages
                            - 14.12.2023 - v4.3.3.22 Fix name by static Navi Icon
                            - 17.12.2023 - v4.3.3.23 Optimization of the blind control (enable or disable Up/Stop/Down)
                            - 18.12.2023 - v4.3.3.24 Hotfix Update Message / Add Icon Colors to Entity Button
                            - 21.12.2023 - v4.3.3.25 Add switch of cardQR by hidePassword: true
                            - 26.12.2023 - v4.3.3.26 Fix Log output payload -> Json.stringify
                            - 28.12.2023 - v4.3.3.27 Fix Payload (pageItem.id -> placeId) by Function CreateEntity
                            - 28.12.2023 - v4.3.3.27 Fix Fallback PageItem.name by Function CreateEntity --> Many Bugs
                            - 30.12.2023 - v4.3.3.28 Fix short ID's in v4.3.3.27
                            - 30.12.2023 - v4.3.3.28 Fix window Icons in CreateEntity
                            - 30.12.2023 - v4.3.3.28 Add MQTT-Client Check
                            - 02.01.2024 - v4.3.3.29 Add Tasmota Buzzer for NotifyPage
                            - 02.02.2024 - v4.3.3.29 Fix ThermoPage -> UnSubScribsWatcher
                            - 02.02.2024 - v4.3.3.30 Add stronger config type checks
                            - 03.02.2024 - v4.3.3.31 Remove: autoCreateAlias from cardMedia
                            - 03.02.2024 - v4.3.3.31 Remove: adapterPlayerInstance from every card except cardMedia
                            - 03.02.2024 - v4.3.3.31 [dev]: optional with type - cardMedia has adapterPlayerInstance all other not
                            - 03.02.2024 - v4.3.3.31 [dev]: add PlayerType some more work to do
                            - 03.02.2024 - v4.3.3.31 changed: adapterPlayerInstance instance 0-9 allowed. Always require a '.' at the end.
                            - 04.01.2024 - v4.3.3.32 Hotfix Spotify
                            - 04.01.2024 - v4.3.3.32 [DEV] Add Types see commits
                            - 04.01.2024 - v4.3.3.32 Add more details to types for: leftScreensaverEntity, indicatorScreensaverEntity, PageThermo, PageMedia
                            - 04.01.2024 - v4.3.3.32 Remove not uses propertys from PageItem
                            - 05.01.2024 - v4.3.3.32 Add Body for BoseSoundtouch-Player
                            - 05.01.2024 - v4.3.3.33 Add BoseSoundtouch Functions
                            - 05.01.2024 - v4.3.3.33 Screensaver Fix max Number of indicatorScreensaverEntity
                            - 07.01.2024 - v4.3.3.33 Fix BoseSoundtouch Proto
                            - 08.01.2024 - v4.3.3.34 Fix: Disabled Icon Status for Blinds while bug in updating data points in ioBroker (reason unknown)
                            - 08.01.2024 - v4.3.3.35 Add: relay.1/relay.2 show the confirmed status
                            - 09.01.2024 - v4.3.3.36 Fix: change ScreensaverTimeout and activeBrightness
                            - 09.01.2024 - v4.3.3.36 Fix: schedule SendTime
                            - 09.01.2024 - v4.3.3.36 Fix: Function _schedule SummerTime/WinterTime
                            - 15.01.2024 - v4.3.3.37 Change: Allow data points to be flushed for popUpNotify. Activate screensaver with one click.
                            - 16.01.2024 - v4.3.3.38 Fix: joBr99#1098
                            - 16.01.2024 - v4.3.3.38 Types: Number of PageItems defined & HandleScreensaverStatusIcons rewritten
                            - 16.01.2024 - v4.3.3.38 Optimate: function SendTime()
                            - 17.01.2024 - v4.3.3.38 Add: ScreensaverEntityIconSelect for MRIcons is like common.states for states.
                            - 17.01.2024 - v4.3.3.38 Add: Changing the ScreensaverEntityValue value updates the screensaver.
                    	- 19.01.2024 - v4.3.3.38 Change: yAxisTicks parameter is not required in cardLChart PageItem
                            - 20.01.2024 - v4.3.3.38 Add: click on indicatorIcon navigate to Page
                            Todo:
                            - XX.XX.XXXX - v5.0.0    Change the bottomScreensaverEntity (rolling) if more than 6 entries are defined
                    * DE: Für die Erstellung der Aliase durch das Skript, muss in der JavaScript Instanz "setObject" gesetzt sein! *
                    * EN: In order for the script to create the aliases, “setObject” must be set in the JavaScript instance!       *
                    Wenn Rule definiert, dann können die Hardware-Tasten ebenfalls für Seitensteuerung (dann nicht mehr als Relais) genutzt werden
                    Tasmota Konsole:
                        Rule2 on Button1#state do Publish %topic%/tele/RESULT {"CustomRecv":"event,button1"} endon on Button2#state do Publish %topic%/tele/RESULT {"CustomRecv":"event,button2"} endon
                        Rule2 1 (Rule aktivieren)
                        Rule2 0 (Rule deaktivieren)
                    Mögliche Seiten-Ansichten:
                        screensaver Page    - wird nach definiertem Zeitraum (config) mit Dimm-Modus aktiv (Uhrzeit, Datum, Aktuelle Temperatur mit Symbol)
                                              (die 4 kleineren Icons können als Wetter-Vorschau + 4Tage (Symbol + Höchsttemperatur) oder zur Anzeige definierter Infos konfiguriert werden)
                        cardEntities Page   - 4 vertikale angeordnete Steuerelemente - auch als Subpage
                        cardGrid Page       - 6 horizontal angeordnete Steuerelemente in 2 Reihen a 3 Steuerelemente - auch als Subpage
                        cardGrid2 Page      - 8 horizontal angeordnete Steuerelemente in 2 Reihen a 4 Steuerelemente - auch als Subpage
                        cardThermo Page     - Thermostat mit Solltemperatur, Isttemperatur, Mode - Weitere Eigenschaften können im Alias definiert werden
                        cardMedia Page      - Mediaplayer - Ausnahme: Alias sollte mit Alias-Manager automatisch über Alexa-Verzeichnis Player angelegt werden
                        cardAlarm Page      - Alarmseite mit Zustand und Tastenfeld
                        cardPower Page      - Energiefluss
                        cardChart Page      - Balken-Diagramme aus History, SQL oder InfluxDB
                        cardLChart Page     - Linien-Diagramme aus History, SQL oder InfluxDB
                        Vollständige Liste zur Einrichtung unter:
                        https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-Card-Definitionen-(Seiten)
                    Popup-Pages:
                        popupLight Page     - in Abhängigkeit zum gewählten Alias werden "Helligkeit", "Farbtemperatur" und "Farbauswahl" bereitgestellt
                        popupShutter Page   - die Shutter-Position (Rollo, Jalousie, Markise, Leinwand, etc.) kann über einen Slider verändert werden.
                        popupNotify Page    - Info - Seite mit Headline Text und Buttons - Intern für manuelle Updates / Extern zur Befüllung von Datenpunkten unter 0_userdata
                        screensaver Notify  - Über zwei externe Datenpunkte in 0_userdata können "Headline" und "Text" an den Screensaver zur Info gesendet werden
                        popupInSel Page     - Auswahlliste (InputSelect)
                    Mögliche Aliase: (Vorzugsweise mit ioBroker-Adapter "Geräte verwalten" konfigurieren, da SET, GET, ACTUAL, etc. verwendet werden)
                        Info                - Werte aus Datenpunkt
                        Schieberegler       - Slider numerische Werte (SET/ACTUAL)
                        Lautstärke          - Volume (SET/ACTUAL) und MUTE
                        Lautstärke-Gruppe   - analog Lautstärke
                        Licht               - An/Aus (Schalter)
                        Steckdose           - An/Aus (Schalter)
                        Dimmer              - An/Aus, Brightness
                        Farbtemperatur      - An/Aus, Farbtemperatur und Brightness
                        HUE-Licht           - Zum Schalten von Color-Leuchtmitteln über HUE-Wert, Brightness, Farbtemperatur, An/Aus (HUE kann auch fehlen)
                        RGB-Licht           - RGB-Leuchtmitteln/Stripes welche Rot/Grün/ und Blau separat benötigen (Tasmota, WifiLight, etc.) + Brightness, Farbtemperatur
                        RGB-Licht-einzeln   - RGB-Leuchtmitteln/Stripes welche HEX-Farbwerte benötigen (Tasmota, WifiLight, etc.) + Brightness, Farbtemperatur
                        Jalousien           - Up, Stop, Down, Position
                        Fenster             - Sensor open
                        Tür                 - Sensor open
                        Tor                 - Sensor open
                        Bewegung            - Sensor Presence
                        Verschluss          - Türschloss SET/ACTUAL/OPEN
                        Taste               - Für Szenen oder Radiosender, etc. --> Nur Funktionsaufruf - Kein Taster wie MonoButton - True/False
                        Tastensensor        - Für Auswahlmenü (popupInSel)
                        Thermostat          - Aktuelle Raumtemperatur, Setpoint, etc.
                        Temperatur          - Temperatur aus Datenpunkt, analog Info
                        Klimaanlage         - Buttons zur Steuerung der Klimaanlage im unteren Bereich
                        Temperatur          - Anzeige von Temperatur - Datenpunkten, analog Info
                        Feuchtigkeit        - Anzeige von Humidity - Datenpunkten, analog Info
                        Medien              - Steuerung von Alexa, etc. - Über Alias-Manager im Verzeichnis Player automatisch anlegen (Geräte-Manager funktioniert nicht)
                        Wettervorhersage    - Aktuelle Außen-Temperatur (Temp) und aktuelles AccuWeather-Icon (Icon) für Screensaver
                        Warnung             - Abfall, etc. -- Info mit IconColor
                        Timer (siehe Wiki)
                        https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-ALIAS-Definitionen
                    Interne Sonoff-Sensoren (über Tasmota):
                        ESP-Temperatur      - wird in 0_userdata.0. abgelegt, kann als Alias importiert werden --> SetOption146 1
                        Temperatur          - Raumtemperatur - wird in 0_userdata.0. abgelegt, kann als Alias importiert werden
                                              (!!! Achtung: der interne Sonoff-Sensor liefert keine exakten Daten, da das NSPanel-Board und der ESP selbst Hitze produzieren !!!
                                              ggf. Offset einplanen oder besser einen externen Sensor über Zigbee etc. verwenden)
                        Timestamp           - wird in 0_userdata.0. Zeitpunkt der letzten Sensorübertragung
                    Tasmota-Status0 - (zyklische Ausführung)
                        liefert relevanten Tasmota-Informationen und kann bei Bedarf in "function get_tasmota_status0()" erweitert werden. Daten werden in 0_userdata.0. abgelegt
                    Erforderliche Adapter:
                        AccuWeather oder DasWetter: - Bei Nutzung der Wetterfunktionen (und zur Icon-Konvertierung) im Screensaver
                        Alexa2:                     - Bei Nutzung der dynamischen SpeakerList in der cardMedia
                        Geräte verwalten            - Für Erstellung der Aliase
                        MQTT-Adapter                - Für Kommunikation zwischen Skript und Tasmota
                        JavaScript-Adapter
                    Upgrades in Konsole:
                        Tasmota BerryDriver     : Backlog UpdateDriverVersion https://raw.githubusercontent.com/joBr99/nspanel-lovelace-ui/main/tasmota/autoexec.be; Restart 1
                        TFT EU STABLE Version   : FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-v4.3.3.tft
                    /******************************* Begin CONFIG Parameter *******************************/
                    // DE: liefert bei true detailliertere Meldundgen im Log.
                    // EN: if true, provides more detailed messages in the log.
                    let Debug: boolean = false;
                    /***** 1. Tasmota-Config *****/
                        // DE: Anpassen an die Verzeichnisse der MQTT-Adapter-Instanz
                        // EN: Adapt to the MQTT adapter instance directories
                        const NSPanelReceiveTopic: string = 'mqtt.0.Panels.PanelEG1.tele.RESULT';
                        const NSPanelSendTopic: string = 'mqtt.0.Panels.PanelEG1.cmnd.CustomSend';
                        // DE: nur ändern, falls der User im Tasmota vor dem Kompilieren umbenannt wurde (Standard Tasmota: admin)
                        // EN: only change if the user was renamed in Tasmota before compiling (default Tasmota: admin)
                        const tasmota_web_admin_user: string = 'admin';
                        // DE: setzten, falls "Web Admin Password" in Tasmota vergeben
                        // EN set if "Web Admin Password" is assigned in Tasmota
                        const tasmota_web_admin_password: string = '';
                        // DE: Setzen der bevorzugten Tasmota32-Version (für Updates)
                        // EN: Set preferred Tasmota32 version (for updates)
                        const tasmotaOtaVersion: string = 'tasmota32-DE.bin';
                            // DE: Es können ebenfalls andere Versionen verwendet werden wie zum Beispiel:
                            // EN: Other versions can also be used, such as:
                            // 'tasmota32-nspanel.bin' or 'tasmota32.bin' or 'tasmota32-DE.bin' or etc.
                    /***** 2. Directories in 0_userdata.0... *****/
                        // DE: Anpassen an das jeweilige NSPanel
                        // EN: Adapt to the respective NSPanel
                        const NSPanel_Path = '0_userdata.0.Panels.PanelEG1.';
                        // DE: Pfad für gemeinsame Nutzung durch mehrere Panels (bei Nutzung der cardAlarm/cardUnlock)
                        // EN: Path for sharing between multiple panels (when using cardAlarm/cardUnlock)
                        const NSPanel_Alarm_Path = '0_userdata.0.Panels.';
                    /***** 3. Weather adapter Config *****/
                        // DE: Mögliche Wetteradapter 'accuweather.0.' oder 'daswetter.0.'
                        // EN: Possible weather adapters 'accuweather.0.' or 'the weather.0.'
                        const weatherAdapterInstance: string = 'accuweather.0.';
                        // DE: Mögliche Werte: 'Min', 'Max' oder 'MinMax' im Screensaver
                        // EN: Possible values: 'Min', 'Max' or 'MinMax' in the screensaver
                        const weatherScreensaverTempMinMax: string = 'MinMax';
                        // DE: Dieser Alias wird automatisch für den gewählten Wetter erstellt und kann entsprechend angepasst werden
                        // EN: This alias is automatically created for the selected weather and can be adjusted accordingly
                        const weatherEntityPath: string = 'alias.0.Wetter';
                    /***** 4. Color constants for use in the PageItems *****/
                        // DE: Bei Bedarf können weitere Farben definiert werden
                        // EN: If necessary, additional colors can be defined
                        const HMIOff:           RGB = { red:  68, green: 115, blue: 158 };     // Blue-Off - Original Entity Off
                        const HMIOn:            RGB = { red:   3, green: 169, blue: 244 };     // Blue-On
                        const HMIDark:          RGB = { red:  29, green:  29, blue:  29 };     // Original Background Color
                            const Off:          RGB = { red: 200, green: 200, blue: 200 };     // Orange-Off - schönere Farbübergänge. Angepasst, vorher: 253 128 0
                        const On:               RGB = { red: 253, green: 216, blue:  53 };
                        const MSRed:            RGB = { red: 251, green: 105, blue:  98 };
                        const MSYellow:         RGB = { red: 255, green: 235, blue: 156 };
                        const MSGreen:          RGB = { red: 121, green: 222, blue: 121 };
                        const Red:              RGB = { red: 255, green:   0, blue:   0 };
                        const White:            RGB = { red: 255, green: 255, blue: 255 };
                        const Yellow:           RGB = { red: 255, green: 255, blue:   0 };
                        const Green:            RGB = { red:   0, green: 255, blue:   0 };
                        const Blue:             RGB = { red:   0, green:   0, blue: 255 };
                        const DarkBlue:         RGB = { red:   0, green:   0, blue: 136 };
                        const Gray:             RGB = { red: 136, green: 136, blue: 136 };
                        const Black:            RGB = { red:   0, green:   0, blue:   0 };
                        const colorSpotify:     RGB = { red:  30, green: 215, blue:  96 };
                        const colorAlexa:       RGB = { red:  49, green: 196, blue: 243 };
                        const colorRadio:       RGB = { red: 255, green: 127, blue:   0 };
                        const BatteryFull:      RGB = { red:  96, green: 176, blue:  62 };
                        const BatteryEmpty:     RGB = { red: 179, green:  45, blue:  25 };
                        //Menu Icon Colors
                        const Menu:             RGB = { red: 150, green: 150, blue: 100 };
                        const MenuLowInd:       RGB = { red: 255, green: 235, blue: 156 };
                        const MenuHighInd:      RGB = { red: 251, green: 105, blue:  98 };
                        //Dynamische Indikatoren (Abstufung grün nach gelb nach rot)
                        const colorScale0:      RGB = { red:  99, green: 190, blue: 123 };
                        const colorScale1:      RGB = { red: 129, green: 199, blue: 126 };
                        const colorScale2:      RGB = { red: 161, green: 208, blue: 127 };
                        const colorScale3:      RGB = { red: 129, green: 217, blue: 126 };
                        const colorScale4:      RGB = { red: 222, green: 226, blue: 131 };
                        const colorScale5:      RGB = { red: 254, green: 235, blue: 132 };
                        const colorScale6:      RGB = { red: 255, green: 210, blue: 129 };
                        const colorScale7:      RGB = { red: 251, green: 185, blue: 124 };
                        const colorScale8:      RGB = { red: 251, green: 158, blue: 117 };
                        const colorScale9:      RGB = { red: 248, green: 131, blue: 111 };
                        const colorScale10:     RGB = { red: 248, green: 105, blue: 107 };
                        //Screensaver Default Theme Colors
                        const scbackground:     RGB = { red:   0, green:   0, blue:   0};
                        const scbackgroundInd1: RGB = { red: 255, green:   0, blue:   0};
                        const scbackgroundInd2: RGB = { red: 121, green: 222, blue: 121};
                        const scbackgroundInd3: RGB = { red: 255, green: 255, blue:   0};
                        const sctime:           RGB = { red: 255, green: 255, blue: 255};
                        const sctimeAMPM:       RGB = { red: 255, green: 255, blue: 255};
                        const scdate:           RGB = { red: 255, green: 255, blue: 255};
                        const sctMainIcon:      RGB = { red: 255, green: 255, blue: 255};
                        const sctMainText:      RGB = { red: 255, green: 255, blue: 255};
                        const sctForecast1:     RGB = { red: 255, green: 255, blue: 255};
                        const sctForecast2:     RGB = { red: 255, green: 255, blue: 255};
                        const sctForecast3:     RGB = { red: 255, green: 255, blue: 255};
                        const sctForecast4:     RGB = { red: 255, green: 255, blue: 255};
                        const sctF1Icon:        RGB = { red: 255, green: 235, blue: 156};
                        const sctF2Icon:        RGB = { red: 255, green: 235, blue: 156};
                        const sctF3Icon:        RGB = { red: 255, green: 235, blue: 156};
                        const sctF4Icon:        RGB = { red: 255, green: 235, blue: 156};
                        const sctForecast1Val:  RGB = { red: 255, green: 255, blue: 255};
                        const sctForecast2Val:  RGB = { red: 255, green: 255, blue: 255};
                        const sctForecast3Val:  RGB = { red: 255, green: 255, blue: 255};
                        const sctForecast4Val:  RGB = { red: 255, green: 255, blue: 255};
                        const scbar:            RGB = { red: 255, green: 255, blue: 255};
                        const sctMainIconAlt:   RGB = { red: 255, green: 255, blue: 255};
                        const sctMainTextAlt:   RGB = { red: 255, green: 255, blue: 255};
                        const sctTimeAdd:       RGB = { red: 255, green: 255, blue: 255};
                        //Auto-Weather-Colors
                        const swClearNight:     RGB = { red: 150, green: 150, blue: 100};
                        const swCloudy:         RGB = { red:  75, green:  75, blue:  75};
                        const swExceptional:    RGB = { red: 255, green:  50, blue:  50};
                        const swFog:            RGB = { red: 150, green: 150, blue: 150};
                        const swHail:           RGB = { red: 200, green: 200, blue: 200};
                        const swLightning:      RGB = { red: 200, green: 200, blue:   0};
                        const swLightningRainy: RGB = { red: 200, green: 200, blue: 150};
                        const swPartlycloudy:   RGB = { red: 150, green: 150, blue: 150};
                        const swPouring:        RGB = { red:  50, green:  50, blue: 255};
                        const swRainy:          RGB = { red: 100, green: 100, blue: 255};
                        const swSnowy:          RGB = { red: 150, green: 150, blue: 150};
                        const swSnowyRainy:     RGB = { red: 150, green: 150, blue: 255};
                        const swSunny:          RGB = { red: 255, green: 255, blue:   0};
                        const swWindy:          RGB = { red: 150, green: 150, blue: 150};
                    /***** 5. Script - Parameters *****/
                        // DE: Für diese Option muss der Haken in setObjects in deiner javascript.X. Instanz gesetzt sein.
                        // EN: This option requires the check mark in setObjects in your javascript.X. instance must be set.
                        const autoCreateAlias = true;
                        // DE: Verzeichnis für Auto-Aliase (wird per Default aus dem NSPanel-Verzeichnis gebildet und muss nicht verändert werden)
                        // EN: Directory for auto aliases (is created by default from the NSPanel directory and does not need to be changed)
                        const AliasPath: string = 'alias.0.' + NSPanel_Path.substring(13, NSPanel_Path.length);
                        // DE: Default-Farbe für Off-Zustände
                        // EN: Default color for off states
                        const defaultOffColorParam: any = Off;
                        // DE: Default-Farbe für On-Zustände
                        // EN: Default color for on states
                        const defaultOnColorParam: any = On;
                        const defaultColorParam: any = Off;
                        // DE: Default-Hintergrundfarbe HMIDark oder Black
                        // EN: Default background color HMIDark or Black
                        const defaultBackgroundColorParam: any = HMIDark;
                    /******************************** End CONFIG Parameter ********************************/
                    //-- Anfang für eigene Seiten -- z.T. selbstdefinierte Aliase erforderlich ----------------
                    //-- Start for your own pages -- some self-defined aliases required ----------------
                    	//-- https://github.com/joBr99/nspanel-lovelace-ui/wiki/NSPanel-Page-%E2%80%90-Typen_How-2_Beispiele
                    let L10Start: PageType =
                    //var L10Start = <PageGrid>
                        "type": "cardGrid",
                        "heading": "Erdgeschoss",
                        "useColor": true,
                        "items": [
                            <PageItem>{ id: 'alias.0.Licht.Licht_Küche_Hochschränke', name: "Küche", interpolateColor: true, minValueBrightness: 0, maxValueBrightness: 100 },
                            <PageItem>{ id: 'alias.0.Licht.Licht_Küche_Arbeitsplatte', name: "Küche", icon: 'vanity-light'},
                            <PageItem>{ id: 'alias.0.Licht.Licht_Essbereich_Esstisch', name: "Esstisch", interpolateColor: true, minValueBrightness: 0, maxValueBrightness: 100 },
                            <PageItem>{ id: 'alias.0.Licht.Licht_Wohnbereich_Decke', name: "Decke", icon: 'dome-light', interpolateColor: true, minValueBrightness: 0, maxValueBrightness: 100 },
                            <PageItem>{ id: 'alias.0.Licht.Licht_Wohnbereich_Spots', name: "Spots", icon: 'track-light', interpolateColor: true, minValueBrightness: 0, maxValueBrightness: 100 },
                            <PageItem>{ id: 'alias.0.Licht.Licht_Wohnbereich_TV', name: "TV", icon: 'television-ambient-light', interpolateColor: true, minValueBrightness: 0, maxValueBrightness: 100 },
                    let L20StartDetails: PageType =
                    //var L20StartDetails = <PageGrid>
                        "type": "cardGrid",
                        "heading": "Erdgeschoss Detail",
                        "useColor": true,
                        "items": [
                            <PageItem>{ id: 'alias.0.Licht.Licht_Tischlampe', name: "Tischlampe", icon: 'lamp', interpolateColor: true},
                            <PageItem>{ id: 'alias.0.Licht.Licht_Wohnbereich_Stehlampe', name: "Stehlampe", icon: 'floor-lamp',  minValueLevel: 0, maxValueLevel: 100},
                            <PageItem>{ id: 'alias.0.Panels.Steuerungs-Szenen.Erdgeschoss_Rolladen_hoch', name: "Rolladen hoch", icon: 'blinds'},
                            <PageItem>{ id: 'alias.0.Panels.Status.Nachtmodus', name: "Nachtmodus", icon: "power-sleep"},
                    let L25StartErdgeschoss: PageType =
                    //let L25StartErdgeschoss = <PageGrid>
                        'type': "cardGrid",
                        'heading': "Steuerung Erdgeschoss",
                        'useColor': true,
                        "items": [
                            <PageItem>{ navigate: true, targetPage: 'L25StartErdgeschossSteckdosen', name: 'Steckdosen' , icon: 'power-plug'},
                            <PageItem>{ navigate: true, targetPage: 'L25StartErdgeschossRolladen', name: 'Rolladen' , icon: 'blinds'},
                            <PageItem>{ navigate: true, targetPage: 'L25StartErdgeschossSzenen', name: 'Szenen' , icon: 'format-paint'},
                            <PageItem>{ navigate: true, targetPage: 'L25StartErdgeschossAussen', name: 'Aussen' , icon: 'flower'},
                            <PageItem>{ navigate: true, targetPage: 'L25StartErdgeschossZutritt', name: 'Zutritt' , icon: 'fingerprint'},
                    let L25StartErdgeschossSteckdosen: PageType =
                    //let L25StartErdgeschossSteckdosen = <PageGrid>
                        'type': "cardGrid",
                        'heading': "Steckdosen EG",
                        'useColor': true,
                        'subPage': true,
                        'parent': L25StartErdgeschoss,
                        'next': 'L25StartErdgeschossRolladen',
                        'nextIcon': 'blinds',
                        "items": [
                            <PageItem>{ id: 'alias.0.Steckdosen.Steckdosen_Küche', name: "Küche", icon: 'power-plug' },
                            <PageItem>{ id: 'alias.0.Steckdosen.Steckdose_Kueche_Media', name: "Google", icon: 'google-home'},
                            <PageItem>{ id: 'alias.0.Steckdosen.Steckdose_Spülmaschine', name: "Spülmaschine", icon: 'dishwasher'},
                            <PageItem>{ id: 'alias.0.Steckdosen.Steckdose_Spülmaschine', name: "Staubsauger", icon: 'robot-vacuum'},
                            <PageItem>{ id: 'alias.0.Steckdosen.Steckdosen_Entertainment', name: "Entertainment", icon: 'youtube-tv'},
                    let L25StartErdgeschossRolladen: PageType =
                    //let L25StartErdgeschossRolladen = <PageGrid>
                        'type': "cardGrid",
                        'heading': "Rolladen EG",
                        'useColor': true,
                        'subPage': true,
                        'next': 'L25StartErdgeschossSzenen',
                        'nextIcon': 'format-paint',
                        "items": [
                            <PageItem>{ id: 'alias.0.Rolladen.Rollade_Terrasse', name: "Terrasse", minValueLevel: 0, maxValueLevel: 100},
                            <PageItem>{ id: 'alias.0.Rolladen.Rollade_Küche', name: "Küche", minValueLevel: 0, maxValueLevel: 100},
                            <PageItem>{ id: 'alias.0.Rolladen.Rollade_Esstisch_vorne', name: "Esstisch vorne", minValueLevel: 0, maxValueLevel: 100},
                            <PageItem>{ id: 'alias.0.Rolladen.Rollade_Esstisch_hinten', name: "Esstisch hinten", minValueLevel: 0, maxValueLevel: 100},
                            <PageItem>{ id: 'alias.0.Rolladen.Rollade_Gäste-WC', name: "Gäste-WC", minValueLevel: 100, maxValueLevel: 0}, //zum Testen getauscht
                    let L25StartErdgeschossSzenen: PageType =
                    //var L25StartErdgeschossSzenen = <PageGrid>
                        "type": "cardGrid",
                        "heading": "Lichtszenen",
                        "useColor": true,
                        'subPage': true,
                        'next': 'L25StartErdgeschossAussen',
                        'nextIcon': 'flower',
                        "items": [
                            <PageItem>{ id: 'alias.0.Lichtszenen.Erdgeschoss_Szene_1', name: "1: Szene 1", icon: 'format-paint' },
                            <PageItem>{ id: 'alias.0.Lichtszenen.Erdgeschoss_Szene_2', name: "2: Szene 2", icon: 'format-paint' },
                            <PageItem>{ id: 'alias.0.Lichtszenen.Erdgeschoss_Szene_3', name: "3: EFFZEH", icon: 'soccer' },
                            <PageItem>{ id: 'alias.0.Lichtszenen.Erdgeschoss_Szene_4', name: "4: Tokio", icon: 'format-paint' },
                            <PageItem>{ id: 'alias.0.Lichtszenen.Erdgeschoss_Szene_5', name: "5: Osaka", icon: 'format-paint' },
                            <PageItem>{ id: 'alias.0.Lichtszenen.Erdgeschoss_Szene_6', name: "6: Herbstgold", icon: 'format-paint' },
                    let L25StartErdgeschossAussen: PageType =
                    //var L25StartErdgeschossAussen = <PageGrid>
                        "type": "cardGrid",
                        "heading": "Steuerung Aussen",
                        "useColor": true,
                        'subPage': true,
                        'next': 'L25StartErdgeschossZutritt',
                        'nextIcon': 'fingerprint',
                        "items": [
                            <PageItem>{ navigate: true, targetPage: 'L25StartErdgeschossAussenLicht', name: 'Licht' , icon: 'coach-lamp'},
                            <PageItem>{ navigate: true, targetPage: 'L25StartErdgeschossAussenSteckdosen', name: 'Steckdosen' , icon: 'power-plug'},
                    let L25StartErdgeschossAussenLicht: PageType =
                    //var L25StartErdgeschossAussenLicht = <PageGrid>
                        "type": "cardGrid",
                        "heading": "Licht Aussen",
                        "useColor": true,
                        'subPage': true,
                        'parent': L25StartErdgeschossAussen,
                        'next': 'L25StartErdgeschossAussenSteckdosen',
                        'nextIcon': 'power-plug',
                        "items": [
                            <PageItem>{ id: 'alias.0.Licht.Licht_Aussen_Gartenbeleuchtung', name: "Garten", icon: 'flower-tulip-outline' },
                            <PageItem>{ id: 'alias.0.Licht.Licht_Aussen_Hausnummer', name: "Hausnummer", icon: 'outdoor-lamp' },
                            <PageItem>{ id: 'alias.0.Licht.Licht_Aussen_Überstand', name: "Überstand", icon: 'track-light' },
                            <PageItem>{ id: 'alias.0.Licht.Licht_Aussen_Durchgang', name: "Durchgang", icon: 'coach-lamp' },
                            <PageItem>{ id: 'alias.0.Licht.Licht_Aussen_Terrasse', name: "Terrasse", icon: 'coach-lamp' },
                    let L25StartErdgeschossAussenSteckdosen: PageType =
                    //var L25StartErdgeschossAussenSteckdosen = <PageEntities>
                        "type": "cardEntities",
                        "heading": "Steckdosen Aussen",
                        "useColor": true,
                        'subPage': true,
                        "items": [
                            <PageItem>{ id: 'alias.0.Steckdosen.Steckdosen_Terrasse_Gartenhaus', name: "Gartenhaus (always-on)", icon: 'greenhouse' },
                            <PageItem>{ id: 'alias.0.Steckdosen.Steckdosen_Aussen_Vorne_links', name: "Vorne links", icon: 'power-plug' },
                            <PageItem>{ id: 'alias.0.Steckdosen.Steckdosen_Aussen_Vorne_rechts', name: "Vorne rechts", icon: 'power-plug' },
                            <PageItem>{ id: 'alias.0.Steckdosen.Steckdose_Doorbird', name: "Doorbird (always-on)", icon: 'bird' },
                    let L25StartErdgeschossZutritt: PageType =
                    //var L25StartErdgeschossZutritt = <PageEntities>
                        "heading": "Zutritt",
                        "useColor": true,
                        'subPage': true,
                        "items": [
                            <PageItem>{ id: 'alias.0.Security.Urlaubsmodus', name: "Urlaub", icon: 'beach' },
                            <PageItem>{ id: 'alias.0.Security.Fingerprint-Sensor', name: "Fingerabdruck-Sensor", icon: 'fingerprint' },
                            <PageItem>{ id: 'alias.0.Security.Doorbird-Aufschliessmodus', name: "Doorbird-Aufschließmodus", icon: 'bird' },
                    /******************************** Seiten für alle Panels ********************************/
                    /******************************** Anpassungen  ********************************/
                    let L60Uebersicht: PageType =
                    //let L60Uebersicht = <PageGrid>
                        "type": "cardGrid",
                        "heading": "Home & More",
                        "useColor": true,
                        "items": [
                            <PageItem>{ navigate: true, targetPage: 'L6xEnergie', name: 'Energy' , icon: 'lightning-bolt-outline'},
                            <PageItem>{ navigate: true, targetPage: 'L6xWasser', name: 'Wasser' , icon: 'water-thermometer'},
                            <PageItem>{ navigate: true, targetPage: 'L6xLueftersteuerung', name: 'Lüftersteuerung' , icon: 'fan'},
                            <PageItem>{ navigate: true, targetPage: 'L6xWetter', name: 'Wetter & Klima' , icon: 'weather-partly-cloudy'},
                            <PageItem>{ navigate: true, targetPage: 'L6xFahrplan', name: 'Linie 1' , icon: 'tram'},
                            <PageItem>{ navigate: true, targetPage: 'L6xWLAN', name: 'Gäste-WiFi' , icon: 'qrcode-scan'},
                    let L6xEnergie: PageType =
                        'type': 'cardPower',
                        'heading': 'Energy',
                        'subPage': true,
                        'parent': L60Uebersicht,
                        'next': 'L6xWasser',
                        'nextIcon': 'water-thermometer',
                        'items': [
                            <PageItem>{ id: 'alias.0.Panels.Energiedaten.Datenpunkt-Energiefluss',
                                        alwaysOnDisplay: false }
                    let L6xWasser: PageType =
                        'type': 'cardEntities',
                        'heading': 'Wasser',
                        'useColor': true,
                        'subPage': true,
                        'next': 'L6xLueftersteuerung',
                        'nextIcon': 'fan',
                        'items': [
                            <PageItem>{ id: "alias.0.Panels.Wasserdaten.Wasser-Temperatur_Ist", name: "Warmwasser-Ist", unit: "°C", icon: 'water-thermometer', offColor: Black, onColor: Red, useValue: false, fontSize: 4, colorScale: {'val_min': 38, 'val_max': 50, 'val_best': 43}},
                            <PageItem>{ id: "alias.0.Panels.Wärmepumpe.Wärmepumpe_Warmwasser_Soll-Temperatur", name: "Warmwasser-Soll", unit: "°C", icon: 'water-thermometer',fontSize: 4,},
                            <PageItem>{ id: "alias.0.Panels.Wasserdaten.Wasser-Verbrauch_15-Minuten", name: "Verbrauch <15 Min.", unit: "Liter", icon: 'clock-time-three-outline', useValue: false, fontSize: 4},
                            <PageItem>{ id: "alias.0.Panels.Wasserdaten.Wasser-Verbrauch_Heute", name: "Verbrauch Heute", unit: "Liter", icon: 'clock-time-twelve-outline', useValue: false},
                    let L6x Lueftersteuerung: PageType =
                        'heading': 'Lüftersteuerung',
                        'useColor': true,
                        'subPage': true,
                        'next': 'L6xWetter',
                        'nextIcon': 'weather-partly-cloudy',
                        'items': [
                            <PageItem>{ id: "alias.0.Panels.Lueftersteuerung.Lüftung_Badezimmer", name: "Lüftung Badezimmer", offColor: Gray, onColor: MSRed, icon: 'fan', icon2: 'fan-off'},
                            <PageItem>{ id: "alias.0.Panels.Lueftersteuerung.Lüftung_Technikkeller", name: "Lüftung Technikkeller", offColor: Gray, onColor: MSRed, icon: 'fan', icon2: 'fan-off'},
                            <PageItem>{ id: "alias.0.Panels.Lueftersteuerung.Lüfterstufe_Haus", name: "Lüfterstufe Haus",icon: 'fan-auto'},
                    let L6xWetter: PageType =
                        'type': 'cardGrid2',
                        'heading': 'Wetter Heute',
                        'useColor': true,
                        'subPage': true,
                        'next': 'L6xFahrplan',
                        'nextIcon': 'tram',
                        'items': [
                            <PageItem>{ id: 'alias.0.Panels.Klimadaten.Forecast-Today-Temp-Max', name: 'Max°C', offColor: MSRed, onColor: MSGreen, useValue: true, fontSize: 4, colorScale: {'val_min': -20, 'val_max': 40, 'val_best': 20} },
                            <PageItem>{ id: 'alias.0.Panels.Klimadaten.Forecast-Today-Temp-Min', name: 'Min°C', offColor: MSRed, onColor: MSGreen, useValue: true, fontSize: 4, colorScale: {'val_min': -20, 'val_max': 40, 'val_best': 20} },
                            <PageItem>{ id: 'alias.0.Panels.Klimadaten.Forecast-Today-Humidity', name: 'Luftfeuchte %', offColor: MSYellow, onColor: MSYellow , useValue: true, fontSize: 4, colorScale: {'val_min': 0, 'val_max': 100, 'val_best': 65} },
                            <PageItem>{ id: 'alias.0.Panels.Klimadaten.Today-Humidity-Absolut', name: 'Abs. Luftfeuchte', offColor: MSYellow, onColor: MSYellow , useValue: true, fontSize: 2, colorScale: {'val_min': 0, 'val_max': 12, 'val_best': 7} },
                            <PageItem>{ id: 'alias.0.Panels.Klimadaten.Today-Regenmenge', name: 'Regen FC', offColor: Blue, onColor: Blue, useValue: true, fontSize: 3},
                            <PageItem>{ id: 'alias.0.Panels.Klimadaten.Forecast-Today-Regenmenge', name: 'Regen mm', offColor: Blue, onColor: Blue, useValue: true, fontSize: 3},
                            <PageItem>{ id: 'alias.0.Panels.Klimadaten.Forecast-Today-Windgusts', name: 'Wind km/h', offColor: White , onColor: White, useValue: true, fontSize: 3},
                        'heading': 'Haltestelle Refrath',
                        'useColor': true,
                        'subPage': true,
                        'next': 'L6xWLAN',
                        'nextIcon': 'qrcode-scan',
                        'items': [
                            <PageItem>{ id: 'alias.0.Panels.FahrplanAnzeiger.Haltestelle0.Abfahrt0'},
                            <PageItem>{ id: 'alias.0.Panels.FahrplanAnzeiger.Haltestelle0.Abfahrt1'},
                            <PageItem>{ id: 'alias.0.Panels.FahrplanAnzeiger.Haltestelle0.Abfahrt2'},
                            <PageItem>{ id: 'alias.0.Panels.FahrplanAnzeiger.Haltestelle0.Abfahrt3'},
                            <PageItem>{ id: 'alias.0.Panels.FahrplanAnzeiger.Haltestelle0.Abfahrt4'},
                            <PageItem>{ id: 'alias.0.Panels.FahrplanAnzeiger.Haltestelle0.Abfahrt5'}
                    let L6xWLAN: PageType =
                        'type': 'cardQR',
                        'heading': 'Gäste WLAN',
                        'subPage': true,
                         'items': [<PageItem>{ id: 'alias.0.Panels.Status.Gäste-WLAN', hidePassword: false }]
                    //-- ENDE für eigene Seiten -- z.T. selbstdefinierte Aliase erforderlich -------------------------
                    //-- END for your own pages -- some self-defined aliases required ------------------------
                     **  Service Pages mit Auto-Alias (Nachfolgende Seiten werden mit Alias automatisch angelegt) **
                     **  https://github.com/joBr99/nspanel-lovelace-ui/wiki/NSPanel-Service-Men%C3%BC             **
                    /* DE: German
                       Wenn das Service Menü abgesichert werden soll, kann eine cardUnlock vorgeschaltet werden.
                       Für diesen Fall ist folgende Vorgehensweise erforderlich:
                       - cardUnlock Seite "Unlock_Service" in der Config unter pages auskommentieren ("//" entfernen)
                       - Servicemenü aus pages "NSPanel_Service" unter pages kommentieren ("//" hinzufügen)
                      ** Service pages with auto alias (subsequent pages are automatically created with alias)      **
                    /* EN: English
                        If the service menu needs to be secured, a cardUnlock can be installed upstream.
                        In this case, the following procedure is required:
                        - comment out cardUnlock page "Unlock_Service" in the config under pages (remove "//")
                        - Comment service menu from pages "NSPanel_Service" under pages (add "//")
                    //Level 0 (if service pages are used with cardUnlock)
                    let Unlock_Service: PageType =
                        'type': 'cardUnlock',
                        'heading': findLocaleServMenu('service_pages'),
                        'useColor': true,
                        'items': [/*PageItem*/{ id: 'alias.0.NSPanel.Unlock',
                                              targetPage: 'NSPanel_Service_SubPage',
                                              autoCreateALias: true }
                    //Level_0 (if service pages are used without cardUnlock)
                    let NSPanel_Service: PageType =
                        'heading': findLocaleServMenu('service_menu'),
                        'useColor': true,
                        'items': [
                            /*PageItem*/{ navigate: true, id: 'NSPanel_Infos', icon: 'information-outline', offColor: Menu, onColor: Menu, name: findLocaleServMenu('infos'), buttonText: findLocaleServMenu('more')},
                            /*PageItem*/{ navigate: true, id: 'NSPanel_Einstellungen', icon: 'monitor-edit', offColor: Menu, onColor: Menu, name: findLocaleServMenu('settings'), buttonText: findLocaleServMenu('more')},
                            /*PageItem*/{ navigate: true, id: 'NSPanel_Firmware', icon: 'update', offColor: Menu, onColor: Menu, name: findLocaleServMenu('firmware'), buttonText: findLocaleServMenu('more')},
                            /*PageItem*/{ id: AliasPath + 'Config.rebootNSPanel', name: findLocaleServMenu('reboot') ,icon: 'refresh', offColor: MSRed, onColor: MSGreen, buttonText: findLocaleServMenu('start')},
                    //Level_0 (if service pages are used with cardUnlock)
                    let NSPanel_Service_SubPage: PageType =
                        'useColor': true,
                        'subPage': true,
                        'parent': Unlock_Service,
                        'home': 'Unlock_Service',
                        'items': [
                            //Level_1
                            let NSPanel_Infos: PageType =
                                'heading': findLocaleServMenu('nspanel_infos'),
                                'useColor': true,
                                'subPage': true,
                                'parent': NSPanel_Service,
                                'home': 'NSPanel_Service',
                                'items': [
                                    /*PageItem*/{ navigate: true, id: 'NSPanel_Wifi_Info_1', icon: 'wifi', offColor: Menu, onColor: Menu, name: findLocaleServMenu('wifi'), buttonText: findLocaleServMenu('more')},
                                    /*PageItem*/{ navigate: true, id: 'NSPanel_Sensoren', icon: 'memory', offColor: Menu, onColor: Menu, name: findLocaleServMenu('sensors_hardware'), buttonText: findLocaleServMenu('more')},
                                    /*PageItem*/{ navigate: true, id: 'NSPanel_IoBroker', icon: 'information-outline', offColor: Menu, onColor: Menu, name: findLocaleServMenu('info_iobroker'), buttonText: findLocaleServMenu('more')},
                                    /*PageItem*/{ id: AliasPath + 'Config.Update.UpdateMessage', name: findLocaleServMenu('update_message') ,icon: 'message-alert-outline', offColor: HMIOff, onColor: MSGreen},
                                    //Level_2
                                    let NSPanel_Wifi_Info_1: PageType =
                                        'heading': findLocaleServMenu('nspanel_wifi1'),
                                        'useColor': true,
                                        'subPage': true,
                                        'parent': NSPanel_Infos,
                                        'next': 'NSPanel_Wifi_Info_2',
                                        'items': [
                                            /*PageItem*/{ id: AliasPath + 'ipAddress', name: findLocaleServMenu('ip_address'), icon: 'ip-network-outline', offColor: Menu, onColor: Menu },
                                            /*PageItem*/{ id: AliasPath + 'Tasmota.Wifi.BSSId', name: findLocaleServMenu('mac_address'), icon: 'check-network', offColor: Menu, onColor: Menu },
                                            /*PageItem*/{ id: AliasPath + 'Tasmota.Wifi.RSSI', name: findLocaleServMenu('rssi'), icon: 'signal', unit: '%', colorScale: {'val_min': 100, 'val_max': 0} },
                                            /*PageItem*/{ id: AliasPath + 'Tasmota.Wifi.Signal', name: findLocaleServMenu('wifi_signal'), icon: 'signal-distance-variant', unit: 'dBm', colorScale: {'val_min': 0, 'val_max': -100} },
                                    let NSPanel_Wifi_Info_2: PageType =
                                        'heading': findLocaleServMenu('nspanel_wifi2'),
                                        'useColor': true,
                                        'subPage': true,
                                        'prev': 'NSPanel_Wifi_Info_1',
                                        'items': [
                                            /*PageItem*/{ id: AliasPath + 'Tasmota.Wifi.SSId', name: findLocaleServMenu('ssid'), icon: 'signal-distance-variant', offColor: Menu, onColor: Menu },
                                            /*PageItem*/{ id: AliasPath + 'Tasmota.Wifi.Mode', name: findLocaleServMenu('mode'), icon: 'signal-distance-variant', offColor: Menu, onColor: Menu },
                                            /*PageItem*/{ id: AliasPath + 'Tasmota.Wifi.Channel', name: findLocaleServMenu('channel'), icon: 'timeline-clock-outline', offColor: Menu, onColor: Menu },
                                            /*PageItem*/{ id: AliasPath + 'Tasmota.Wifi.AP', name: findLocaleServMenu('accesspoint'), icon: 'router-wireless-settings', offColor: Menu, onColor: Menu },
                                    let NSPanel_Sensoren: PageType =
                                        'heading': findLocaleServMenu('sensors1'),
                                        'useColor': true,
                                        'subPage': true,
                                        'next': 'NSPanel_Hardware',
                                        'items': [
                                            /*PageItem*/{ id: AliasPath + 'Sensor.ANALOG.Temperature', name: findLocaleServMenu('room_temperature'), icon: 'home-thermometer-outline', unit: '°C', colorScale: {'val_min': 0, 'val_max': 40, 'val_best': 22 } },
                                            /*PageItem*/{ id: AliasPath + 'Sensor.ESP32.Temperature', name: findLocaleServMenu('esp_temperature'), icon: 'thermometer', unit: '°C', colorScale: {'val_min': 0, 'val_max': 100, 'val_best': 50 } },
                                            /*PageItem*/{ id: AliasPath + 'Sensor.TempUnit', name: findLocaleServMenu('temperature_unit'), icon: 'temperature-celsius', offColor: Menu, onColor: Menu },
                                            /*PageItem*/{ id: AliasPath + 'Sensor.Time', name: findLocaleServMenu('refresh'), icon: 'clock-check-outline', offColor: Menu, onColor: Menu },
                                    let NSPanel_Hardware: PageEntities =
                                        'heading': findLocaleServMenu('hardware2'),
                                        'useColor': true,
                                        'subPage': true,
                                        'prev': 'NSPanel_Sensoren',
                                        'items': [
                                            /*PageItem*/{ id: AliasPath + 'Tasmota.Product', name: findLocaleServMenu('product'), icon: 'devices', offColor: Menu, onColor: Menu },
                                            /*PageItem*/{ id: AliasPath + 'Tasmota.Hardware', name: findLocaleServMenu('esp32_hardware'), icon: 'memory', offColor: Menu, onColor: Menu },
                                            /*PageItem*/{ id: AliasPath + 'Display.Model', name: findLocaleServMenu('nspanel_version'), offColor: Menu, onColor: Menu },
                                            /*PageItem*/{ id: AliasPath + 'Tasmota.Uptime', name: findLocaleServMenu('operating_time'), icon: 'timeline-clock-outline', offColor: Menu, onColor: Menu },
                                    let NSPanel_IoBroker: PageType =
                                        'heading': findLocaleServMenu('info_iobroker'),
                                        'useColor': true,
                                        'subPage': true,
                                        'items': [
                                            /*PageItem*/{ id: AliasPath + 'IoBroker.ScriptVersion', name: findLocaleServMenu('script_version_nspanelts'), offColor: Menu, onColor: Menu },
                                            /*PageItem*/{ id: AliasPath + 'IoBroker.NodeJSVersion', name: findLocaleServMenu('nodejs_version'), offColor: Menu, onColor: Menu },
                                            /*PageItem*/{ id: AliasPath + 'IoBroker.JavaScriptVersion', name: findLocaleServMenu('instance_javascript'), offColor: Menu, onColor: Menu },
                            //Level_1
                            let NSPanel_Einstellungen: PageType =
                                    'type': 'cardGrid',
                                    'heading': findLocaleServMenu('settings'),
                                    'useColor': true,
                                    'subPage': true,
                                    'items': [
                                        /*PageItem*/{ navigate: true, id: 'NSPanel_Screensaver', icon: 'monitor-dashboard',offColor: Menu, onColor: Menu, name: findLocaleServMenu('screensaver'), buttonText: findLocaleServMenu('more')},
                                        /*PageItem*/{ navigate: true, id: 'NSPanel_Relays', icon: 'electric-switch', offColor: Menu, onColor: Menu, name: findLocaleServMenu('relays'), buttonText: findLocaleServMenu('more')},
                                        /*PageItem*/{ id:AliasPath + 'Config.temperatureUnitNumber', icon: 'gesture-double-tap', name: findLocaleServMenu('temp_unit'), offColor: Menu, onColor: Menu,
                                        modeList: ['°C', '°F', 'K']},
                                        /*PageItem*/{ id: AliasPath + 'Config.localeNumber', icon: 'select-place', name: findLocaleServMenu('language'), offColor: Menu, onColor: Menu,
                                        modeList: ['en-US', 'de-DE', 'nl-NL', 'da-DK', 'es-ES', 'fr-FR', 'it-IT', 'ru-RU', 'nb-NO', 'nn-NO', 'pl-PL', 'pt-PT', 'af-ZA', 'ar-SY',
                                                   'bg-BG', 'ca-ES', 'cs-CZ', 'el-GR', 'et-EE', 'fa-IR', 'fi-FI', 'he-IL', 'hr-xx', 'hu-HU', 'hy-AM', 'id-ID', 'is-IS', 'lb-xx',
                                                   'lt-LT', 'ro-RO', 'sk-SK', 'sl-SI', 'sv-SE', 'th-TH', 'tr-TR', 'uk-UA', 'vi-VN', 'zh-CN', 'zh-TW']},
                                       /*PageItem*/{ navigate: true, id: 'NSPanel_Script', icon: 'code-json',offColor: Menu, onColor: Menu, name: findLocaleServMenu('script'), buttonText: findLocaleServMenu('more')},
                                    //Level_2
                                    let NSPanel_Screensaver: PageType =
                                        'type': 'cardGrid',
                                        'heading': findLocaleServMenu('screensaver'),
                                        'useColor': true,
                                        'subPage': true,
                                        'parent': NSPanel_Einstellungen,
                                        'items': [
                                            /*PageItem*/{ navigate: true, id: 'NSPanel_ScreensaverDimmode', icon: 'sun-clock', offColor: Menu, onColor: Menu, name: findLocaleServMenu('dimmode')},
                                            /*PageItem*/{ navigate: true, id: 'NSPanel_ScreensaverBrightness', icon: 'brightness-5', offColor: Menu, onColor: Menu, name: findLocaleServMenu('brightness')},
                                            /*PageItem*/{ navigate: true, id: 'NSPanel_ScreensaverLayout', icon: 'page-next-outline', offColor: Menu, onColor: Menu, name: findLocaleServMenu('layout')},
                                            /*PageItem*/{ navigate: true, id: 'NSPanel_ScreensaverWeather', icon: 'weather-partly-rainy', offColor: Menu, onColor: Menu, name: findLocaleServMenu('weather')},
                                            /*PageItem*/{ navigate: true, id: 'NSPanel_ScreensaverDateformat', icon: 'calendar-expand-horizontal', offColor: Menu, onColor: Menu, name: findLocaleServMenu('date_format')},
                                            /*PageItem*/{ navigate: true, id: 'NSPanel_ScreensaverIndicators', icon: 'monitor-edit', offColor: Menu, onColor: Menu, name: findLocaleServMenu('indicators')}
                                            //Level_3
                                            let NSPanel_ScreensaverDimmode: PageType =
                                                'heading': findLocaleServMenu('dimmode'),
                                                'useColor': true,
                                                'subPage': true,
                                                'parent': NSPanel_Screensaver,
                                                'items': [
                                                    /*PageItem*/{ id: AliasPath + 'Dimmode.brightnessDay', name: findLocaleServMenu('brightness_day'), icon: 'brightness-5', offColor: Menu, onColor: Menu, minValue: 5, maxValue: 10},
                                                    /*PageItem*/{ id: AliasPath + 'Dimmode.brightnessNight', name: findLocaleServMenu('brightness_night'), icon: 'brightness-4', offColor: Menu, onColor: Menu, minValue: 0, maxValue: 4},
                                                    /*PageItem*/{ id: AliasPath + 'Dimmode.hourDay', name: findLocaleServMenu('hour_day'), icon: 'sun-clock', offColor: Menu, onColor: Menu, minValue: 0, maxValue: 23},
                                                    /*PageItem*/{ id: AliasPath + 'Dimmode.hourNight', name: findLocaleServMenu('hour_night'), icon: 'sun-clock-outline', offColor: Menu, onColor: Menu, minValue: 0, maxValue: 23}
                                            //Level_3
                                            let NSPanel_ScreensaverBrightness: PageType =
                                                'heading': findLocaleServMenu('brightness'),
                                                'useColor': true,
                                                'subPage': true,
                                                'items': [
                                                    /*PageItem*/{ id: AliasPath + 'ScreensaverInfo.activeBrightness', name: findLocaleServMenu('brightness_activ'), icon: 'brightness-5', offColor: Menu, onColor: Menu, minValue: 20, maxValue: 100},
                                                    /*PageItem*/{ id: AliasPath + 'Config.Screensaver.timeoutScreensaver', name: findLocaleServMenu('screensaver_timeout'), icon: 'clock-end', offColor: Menu, onColor: Menu, minValue: 0, maxValue: 60},
                                                    /*PageItem*/{ id: AliasPath + 'Config.Screensaver.screenSaverDoubleClick', name: findLocaleServMenu('wakeup_doublecklick') ,icon: 'gesture-two-double-tap', offColor: HMIOff, onColor: HMIOn}
                                            //Level_3
                                            let NSPanel_ScreensaverLayout: PageType =
                                                'heading': findLocaleServMenu('layout'),
                                                'useColor': true,
                                                'subPage': true,
                                                'items': [
                                                    /*PageItem*/{ id: AliasPath + 'Config.Screensaver.alternativeScreensaverLayout', name: findLocaleServMenu('alternative_layout') ,icon: 'page-previous-outline', offColor: HMIOff, onColor: HMIOn},
                                                    /*PageItem*/{ id: AliasPath + 'Config.Screensaver.ScreensaverAdvanced', name: findLocaleServMenu('advanced_layout') ,icon: 'page-next-outline', offColor: HMIOff, onColor: HMIOn},
                                            //Level_3
                                            let NSPanel_ScreensaverWeather: PageType =
                                                'heading': findLocaleServMenu('weather_parameters'),
                                                'useColor': true,
                                                'subPage': true,
                                                'items': [
                                                    /*PageItem*/{ id: AliasPath + 'ScreensaverInfo.weatherForecast', name: findLocaleServMenu('weather_forecast_offon') ,icon: 'weather-sunny-off', offColor: HMIOff, onColor: HMIOn},
                                                    /*PageItem*/{ id: AliasPath + 'ScreensaverInfo.weatherForecastTimer', name: findLocaleServMenu('weather_forecast_change_switch') ,icon: 'devices', offColor: HMIOff, onColor: HMIOn},
                                                    /*PageItem*/{ id: AliasPath + 'ScreensaverInfo.entityChangeTime', name: findLocaleServMenu('weather_forecast_change_time'), icon: 'cog-sync', offColor: Menu, onColor: Menu, minValue: 15, maxValue: 60},
                                                    /*PageItem*/{ id: AliasPath + 'Config.Screensaver.autoWeatherColorScreensaverLayout', name: findLocaleServMenu('weather_forecast_icon_colors') ,icon: 'format-color-fill', offColor: HMIOff, onColor: HMIOn},
                                            //Level_3
                                            let NSPanel_ScreensaverDateformat: PageType =
                                                'heading': findLocaleServMenu('date_format'),
                                                'useColor': true,
                                                'subPage': true,
                                                'items': [
                                                    /*PageItem*/{ id: AliasPath + 'Config.Dateformat.Switch.weekday', name: findLocaleServMenu('weekday_large') ,icon: 'calendar-expand-horizontal', offColor: HMIOff, onColor: HMIOn},
                                                    /*PageItem*/{ id: AliasPath + 'Config.Dateformat.Switch.month', name: findLocaleServMenu('month_large') ,icon: 'calendar-expand-horizontal', offColor: HMIOff, onColor: HMIOn},
                                            //Level_3
                                            let NSPanel_ScreensaverIndicators: PageType =
                                                'heading': findLocaleServMenu('indicators'),
                                                'useColor': true,
                                                'subPage': true,
                                                'items': [
                                                    /*PageItem*/{ id: AliasPath + 'Config.MRIcons.alternateMRIconSize.1', name: findLocaleServMenu('mr_icon1_size') ,icon: 'format-size', offColor: HMIOff, onColor: HMIOn},
                                                    /*PageItem*/{ id: AliasPath + 'Config.MRIcons.alternateMRIconSize.2', name: findLocaleServMenu('mr_icon2_size') ,icon: 'format-size', offColor: HMIOff, onColor: HMIOn},
                                    //Level_2
                                    let NSPanel_Relays: PageType =
                                        'heading': findLocaleServMenu('relays'),
                                        'useColor': true,
                                        'subPage': true,
                                        'items': [
                                            /*PageItem*/{ id: AliasPath + 'Relay.1', name: findLocaleServMenu('relay1_onoff'), icon: 'power', offColor: HMIOff, onColor: HMIOn},
                                            /*PageItem*/{ id: AliasPath + 'Relay.2', name: findLocaleServMenu('relay2_onoff'), icon: 'power', offColor: HMIOff, onColor: HMIOn},
                                    //Level_2
                                    let NSPanel_Script: PageType =
                                        'heading': findLocaleServMenu('script'),
                                        'useColor': true,
                                        'subPage': true,
                                        'items': [
                                            /*PageItem*/{ id: AliasPath + 'Config.ScripgtDebugStatus', name: findLocaleServMenu('debugmode_offon') ,icon: 'code-tags-check', offColor: HMIOff, onColor: HMIOn},
                                            /*PageItem*/{ id: AliasPath + 'Config.MQTT.portCheck', name: findLocaleServMenu('port_check_offon') ,icon: 'check-network', offColor: HMIOff, onColor: HMIOn},
                            //Level_1
                            let NSPanel_Firmware: PageType =
                                    'heading': findLocaleServMenu('firmware'),
                                    'useColor': true,
                                    'subPage': true,
                                    'items': [
                                        /*PageItem*/{ id: AliasPath + 'autoUpdate', name: findLocaleServMenu('automatically_updates') ,icon: 'power', offColor: HMIOff, onColor: HMIOn},
                                        /*PageItem*/{ navigate: true, id: 'NSPanel_FirmwareTasmota', icon: 'usb-flash-drive', offColor: Menu, onColor: Menu, name: findLocaleServMenu('tasmota_firmware'), buttonText: findLocaleServMenu('more')},
                                        /*PageItem*/{ navigate: true, id: 'NSPanel_FirmwareBerry', icon: 'usb-flash-drive', offColor: Menu, onColor: Menu, name: findLocaleServMenu('berry_driver'), buttonText: findLocaleServMenu('more')},
                                        /*PageItem*/{ navigate: true, id: 'NSPanel_FirmwareNextion', icon: 'cellphone-cog', offColor: Menu, onColor: Menu, name: findLocaleServMenu('nextion_tft_firmware'), buttonText: findLocaleServMenu('more')}
                                    let NSPanel_FirmwareTasmota: PageType =
                                        'heading': findLocaleServMenu('tasmota'),
                                        'useColor': true,
                                        'subPage': true,
                                        'parent': NSPanel_Firmware,
                                        'items': [
                                            /*PageItem*/{ id: AliasPath + 'Tasmota.Version', name: findLocaleServMenu('installed_release'), offColor: Menu, onColor: Menu },
                                            /*PageItem*/{ id: AliasPath + 'Tasmota_Firmware.onlineVersion', name: findLocaleServMenu('available_release'), offColor: Menu, onColor: Menu },
                                            /*PageItem*/{ id: 'Divider' },
                                            /*PageItem*/{ id: AliasPath + 'Config.Update.UpdateTasmota', name: findLocaleServMenu('update_tasmota') ,icon: 'refresh', offColor: HMIOff, onColor: MSGreen, buttonText: findLocaleServMenu('start')},
                                    let NSPanel_FirmwareBerry: PageType =
                                        'heading': findLocaleServMenu('berry_driver'),
                                        'useColor': true,
                                        'subPage': true,
                                        'items': [
                                            /*PageItem*/{ id: AliasPath + 'Display.BerryDriver', name: findLocaleServMenu('installed_release'), offColor: Menu, onColor: Menu },
                                            /*PageItem*/{ id: AliasPath + 'Berry_Driver.onlineVersion', name: findLocaleServMenu('available_release'), offColor: Menu, onColor: Menu},
                                            /*PageItem*/{ id: AliasPath + 'Config.Update.UpdateBerry', name: findLocaleServMenu('update_berry_driver') ,icon: 'refresh', offColor: HMIOff, onColor: MSGreen, buttonText: findLocaleServMenu('start')},
                                    let NSPanel_FirmwareNextion: PageType =
                                        'heading': findLocaleServMenu('nextion_tft'),
                                        'useColor': true,
                                        'subPage': true,
                                        'items': [
                                            /*PageItem*/{ id: AliasPath + 'Display_Firmware.TFT.currentVersion', name: findLocaleServMenu('installed_release'), offColor: Menu, onColor: Menu },
                                            /*PageItem*/{ id: AliasPath + 'Display_Firmware.TFT.desiredVersion', name: findLocaleServMenu('desired_release'), offColor: Menu, onColor: Menu },
                                            /*PageItem*/{ id: AliasPath + 'Display.Model', name: findLocaleServMenu('nspanel_model'), offColor: Menu, onColor: Menu },
                                            /*PageItem*/{ id: AliasPath + 'Config.Update.UpdateNextion', name: 'Nextion TFT Update' ,icon: 'refresh', offColor: HMIOff, onColor: MSGreen, buttonText: findLocaleServMenu('start')},
                    // End of Service Pages
                     **                           Configuration                           **
                    export const config: Config = {
                        // Seiteneinteilung / Page division
                        // Hauptseiten / Mainpages
                        pages: [
                            L10Start,
                            L20StartDetails,
                            L60Uebersicht,
                            NSPanel_Service,         	//Auto-Alias Service Page
                    	    //Unlock_Service            //Auto-Alias Service Page (Service Pages used with cardUnlock)
                        // Unterseiten / Subpages
                        subPages: [
                                    NSPanel_Service_SubPage,                //Auto-Alias Service Page (only used with cardUnlock)
                                    NSPanel_Infos,                          //Auto-Alias Service Page
                                        NSPanel_Wifi_Info_1,                //Auto-Alias Service Page
                                        NSPanel_Wifi_Info_2,                //Auto-Alias Service Page
                                        NSPanel_Sensoren,                   //Auto-Alias Service Page
                                        NSPanel_Hardware,                   //Auto-Alias Service Page
                                        NSPanel_IoBroker,                   //Auot-Alias Service Page
                                    NSPanel_Einstellungen,                  //Auto-Alias Service Page
                                        NSPanel_Screensaver,                //Auto-Alias Service Page
                                            NSPanel_ScreensaverDimmode,     //Auto-Alias Service Page
                                            NSPanel_ScreensaverBrightness,  //Auto-Alias Service Page
                                            NSPanel_ScreensaverLayout,      //Auto-Alias Service Page
                                            NSPanel_ScreensaverWeather,     //Auto-Alias Service Page
                                            NSPanel_ScreensaverDateformat,  //Auto-Alias Service Page
                                            NSPanel_ScreensaverIndicators,  //Auto-Alias Service Page
                                        NSPanel_Relays,                     //Auto-Alias Service Page
                                        NSPanel_Script,                     //Auto-Alias Service Page
                                    NSPanel_Firmware,                       //Auto-Alias Service Page
                                        NSPanel_FirmwareTasmota,            //Auto-Alias Service Page
                                        NSPanel_FirmwareBerry,              //Auto-Alias Service Page
                                        NSPanel_FirmwareNextion,            //Auto-Alias Service Page
                     **                    Screensaver Configuration                      **
                         leftScreensaverEntity:
                                // leftScreensaverEntity 1 (only Advanced Screensaver)
                                    ScreensaverEntity: 'linkeddevices.0.Klima.Wohnbereich.Temperature',
                                    ScreensaverEntityFactor: 1,
                                    ScreensaverEntityDecimalPlaces: 1,
                                    ScreensaverEntityIconOn: 'thermometer',
                                    ScreensaverEntityIconOff: null,
                                    ScreensaverEntityText: 'Temperatur',
                                    ScreensaverEntityUnitText: '°C',
                                    ScreensaverEntityIconColor: {'val_min': 16, 'val_max': 30, 'val_best': 20}
                                // leftScreensaverEntity 2 (only Advanced Screensaver)
                                    ScreensaverEntity: 'linkeddevices.0.Klima.Wohnbereich.Humidity',
                                    ScreensaverEntityDecimalPlaces: 0,
                                    ScreensaverEntityIconOn: 'water-percent',
                                    ScreensaverEntityText: 'Humidity',
                                    ScreensaverEntityUnitText: ' %',
                                    ScreensaverEntityIconColor: {'val_min': 40, 'val_max': 70, 'val_best': 55}
                                // leftScreensaverEntity 3 (only Advanced Screensaver)
                                    ScreensaverEntity: 'linkeddevices.0.Klima.Wohnbereich.CO2',
                                    ScreensaverEntityIconOn: 'molecule-co2',
                                    ScreensaverEntityText: 'CO2',
                                    ScreensaverEntityUnitText: ' ppm',
                                    ScreensaverEntityIconColor: {'val_min': 400, 'val_max': 1200, 'val_best': 700}
                        bottomScreensaverEntity :
                                // bottomScreensaverEntity 1
                                    ScreensaverEntity: 'linkeddevices.0.Energie.Live-Verbrauch.EnergyUsingTotal',
                                    ScreensaverEntityIconOn: 'power-plug',
                                    ScreensaverEntityText: 'Strom',
                                    ScreensaverEntityUnitText: 'W',
                                    ScreensaverEntityIconColor: {'val_min': 250, 'val_max': 1000, 'val_best': 450}
                                // bottomScreensaverEntity 2
                                    ScreensaverEntity: 'linkeddevices.0.Energie.Kosten.Tibber-Stundenpreis',
                                    ScreensaverEntityDecimalPlaces: 2,
                                    ScreensaverEntityIconOn: 'currency-eur',
                                    ScreensaverEntityText: 'Preis/kWh',
                                    ScreensaverEntityUnitText: '€',
                                    ScreensaverEntityIconColor: {'val_min': 0.14, 'val_max': 0.35, 'val_best': 0.22}
                                // bottomScreensaverEntity 3
                                    ScreensaverEntity: 'linkeddevices.0.Energie.Live-Verbrauch.EnergyPVGenerating',
                                    ScreensaverEntityIconOn: 'solar-power-variant',
                                    ScreensaverEntityText: 'Solar',
                                    ScreensaverEntityIconColor: {'val_min': 100, 'val_max': 7500, 'val_best': 1200}
                                // bottomScreensaverEntity 4
                                   ScreensaverEntity: 'linkeddevices.0.Klima.Aussen.Now.Regenmenge-heute',
                                    ScreensaverEntityIconOn: 'weather-rainy',
                                    ScreensaverEntityText: 'Regen',
                                    ScreensaverEntityUnitText: 'mm',
                                    ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 20}
                                // bottomScreensaverEntity 5 (for Alternative and Advanced Screensaver)
                                    ScreensaverEntity: 'alias.0.Panels.Wasserdaten.Wasser-Temperatur_Ist.ACTUAL',
                                    ScreensaverEntityIconOn: 'water-thermometer',
                                    ScreensaverEntityText: 'Wasser',
                                    ScreensaverEntityIconColor: {'val_min': 36, 'val_max': 55, 'val_best': 44}
                                   ScreensaverEntity: 'linkeddevices.0.Lüftung.Haus.Lüfterstufe',
                                    ScreensaverEntityIconOn: 'fan',
                                    ScreensaverEntityText: 'Lüfter',
                                    ScreensaverEntityUnitText: '.Stufe',
                                    //ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 6, 'val_best': 1}
                                 // Examples for Advanced-Screensaver: https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-Config-Screensaver#entity-status-icons-ab-v400
                        indicatorScreensaverEntity:
                                    ScreensaverEntity: 'alias.0.Steckdosen.Steckdose_WLAN_Obergeschoss.ACTUAL',
                                    ScreensaverEntityIconOn: 'wifi',
                                    ScreensaverEntityIconOff: 'wifi-off',
                                    ScreensaverEntityText: 'WLAN',
                                    ScreensaverEntityUnitText: null,
                                    ScreensaverEntityOnColor: Green,
                                    ScreensaverEntityOffColor: Red,
                                    ScreensaverEntity: 'alias.0.Steckdosen.Steckdose_WLAN_Dachgeschoss.ACTUAL',
                                    ScreensaverEntity: 'javascript.0.Status.Lueftung.Luftfeuchte.Raum.EG-Wohnbereich.DETAILS_Lüftungsempfehlung.Lüften_b1_Entfeuchten',
                                    ScreensaverEntityIconOn: 'window-open-variant',
                                    ScreensaverEntityIconOff: 'window-close-variant',
                                    ScreensaverEntityText: 'Fenster',
                                    //ScreensaverEntityUnitText: '%',
                                    ScreensaverEntityIconColor: { 'val_min': 0, 'val_max': 1 }
                                    ScreensaverEntity: 'alias.0.Steckdosen.Steckdose_Drucker.SET',
                                    ScreensaverEntityIconOn: 'printer',
                                    ScreensaverEntityIconOff: 'printer-off',
                                    ScreensaverEntityText: 'Drucker',
                                    ScreensaverEntityOnColor: Red,
                                    ScreensaverEntityOffColor: Green
                                    //ScreensaverEntityIconColor: {'val_best': 0}
                                    //Bei True = Grün
                                    ScreensaverEntity: 'alias.0.Bewegungsmelder.Bewegungsmelder_Aussen_Wärmepumpe.ACTUAL',
                                    ScreensaverEntityIconOn: 'motion-sensor',
                                    ScreensaverEntityIconOff: 'motion-sensor-off',
                                    ScreensaverEntityText: 'Bewegung',
                                  //  ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 1}
                                    ScreensaverEntity: 'alias.0.Panels.Wärmepumpe.Wärmepumpe_Warmwasser_aktiv.ACTUAL',
                                    ScreensaverEntityIconOff: 'water-thermometer-outline',
                                    ScreensaverEntityText: 'WP Warmwasser',
                                   // ScreensaverEntityIconColor: {'val_best': 0}
                                    ScreensaverEntity: 'alias.0.Panels.Wärmepumpe.Wärmepumpe_Heizung_aktiv.ACTUAL',
                                    ScreensaverEntityIconOn: 'heat-pump',
                                    ScreensaverEntityIconOff: 'heat-pump-outline',
                                    ScreensaverEntityText: 'WP Heizung',
                            // indicatorScreensaverEntity 2 (only Advanced Screensaver)
                        mrIcon1ScreensaverEntity:
                                /* ScreensaverEntity: 'alias.0.Licht.Licht_Essbereich_Esstisch.ON',
                                ScreensaverEntityFactor: 1, //Anpassung für neue Skript-Version 4.3.3.33
                                ScreensaverEntityDecimalPlaces: 0, //Anpassung für neue Skript-Version 4.3.3.33
                                ScreensaverEntityIconOn: 'lightbulb',
                                ScreensaverEntityIconOff: 'lightbulb',
                                ScreensaverEntityText: 'Esstisch', //Anpassung für neue Skript-Version 4.3.3.33
                                ScreensaverEntityUnitText: '', //Anpassung für neue Skript-Version 4.3.3.33
                                ScreensaverEntityOnColor: On,
                                ScreensaverEntityOffColor: HMIOff */
                                ScreensaverEntityValue: null,
                                ScreensaverEntityValueDecimalPlace: null,
                                ScreensaverEntityValueUnit: null,
                        mrIcon2ScreensaverEntity:
                                /*ScreensaverEntity: 'alias.0.Licht.Licht_Küche_Hochschränke.ON',
                    // ------ DE: Ende der Screensaver Einstellungen --------------------
                    // ------ EN: End of screensaver settings ---------------------------
                    //-------DE: Anfang Einstellungen für Hardware Button, wenn Sie softwareseitig genutzt werden (Rule2) -------------
                    //-------EN: Start Settings for Hardware Button, if used in software (Rule2) --------------------------------------
                        // DE: Konfiguration des linken Schalters des NSPanels
                        // EN: Configuration of the left switch of the NSPanel
                        button1: {
                            // DE: Mögliche Werte wenn Rule2 definiert: 'page', 'toggle', 'set' - Wenn nicht definiert --> mode: null
                            // EN: Possible values if Rule2 defined: 'page', 'toggle', 'set' - If not defined --> mode: null
                            mode: 'toggle',
                            // DE: Zielpage - Verwendet wenn mode = page
                            // EN: Target page - Used if mode = page
                            page: null,
                            // DE: Zielentity - Verwendet wenn mode = set oder toggle
                            // EN: Target entity - Used if mode = set or toggle
                            entity: 'alias.0.Licht.Licht_Essbereich_Esstisch.ON',
                            // DE: Zielwert - Verwendet wenn mode = set
                            // EN: Target value - Used if mode = set
                            setValue: null
                        // DE: Konfiguration des rechten Schalters des NSPanels
                        // EN: Configuration of the right switch of the NSPanel
                        button2: {
                            mode: 'toggle',
                            page: null,
                            entity: 'alias.0.Licht.Licht_Küche_Hochschränke.ON',
                            setValue: null
                    //--------- DE: Ende - Einstellungen für Hardware Button, wenn Sie softwareseitig genutzt werden (Rule2) -------------
                    //--------- EN: End - settings for hardware button if they are used in software (Rule2) ------------------------------
                        // DE: WICHTIG !! Parameter nicht ändern  WICHTIG!!
                        // EN: IMPORTANT !! Do not change parameters IMPORTANT!!
                        panelRecvTopic: NSPanelReceiveTopic,
                        panelSendTopic: NSPanelSendTopic,
                        weatherEntity: weatherEntityPath,
                        defaultOffColor: defaultOffColorParam,
                        defaultOnColor: defaultOnColorParam,
                        defaultColor: defaultColorParam,
                        defaultBackgroundColor: defaultBackgroundColorParam,
                      TT-Tom last edited by TT-Tom
                      @kunibert
                      Ja der Fehler liegt in der Fahrplan Seite. Es dürfen nur 4 PageItem sein. Da die cardEntity nur 4 anzeigen kann.
                      Das PageItem kannst du trotzdem entfernen überall.
                        Doggie last edited by
                        ich brauche nochmal die Hilfe der Sonoff NSPanel Experten.
                        Ich möchte die Verbrauchswerte meiner Gasheizung auf dem Panel darstellen. Also: Verbrauch heute, gestern, im Monat und Kosten usw.
                        Der Zählerwert wird mit einer Kamera erfasst und die weiteren Werte in einem Blockly-Script errechnet.
                        Was mir fehlt ist ein passender Alias-Typ und auch die passenden Datenpunkte. Kann man den Alias-Typ selbst erstellen? Oder irgendeinen ungefähr passenden nehmen?
                        Als Seite habe ich mir die PageGrid vorgestellt.
                        Kann mir jemand helfen?
                          ticaki Developer @Doggie last edited by
                          @doggie
                          Schaue dir mal z.B. let NSPanel_Hardware und die Aliase dazu an.
                          Geht auf die selbe Art aber auch mit PageGrid @Armilar @TT-Tom sollen mich korrigieren, wenn ich mich irre.
                            @doggie
                            Der Alias Typ ist Info und der Datenpunkt ACTUAL.
                            Hier im Wiki findest du noch Infos.
                            Ansonsten nochmal nach fragen.
                            • Armilar
                              Armilar Most Active Forum Testing @Kunibert last edited by
                              @kunibert sagte in SONOFF NSPanel mit Lovelace UI:
                              für us-p Version so:
                              let L6xFahrplan: PageType =
                                  'useColor': true,
                                  'subPage': true,
                                  'next': 'L6xWLAN',
                                  'items': [
                              für eu und us-L - Version so:
                                  'useColor': true,
                                  'subPage': true,
                                  'next': 'L6xWLAN',
                                  'items': [
                              Armilar D 2 Replies Last reply Reply Quote 2
                              • theknut
                                theknut last edited by
                                Hi zusammen,
                                ich habe bei mir ein paar Buttons zu denen ich mittels Event noch was dazu machen muss. Also bspw. wenn ich den "Alle Lichter im Wohnzimmer aus" Knopf drücke, dann will ich, dass wenn es dunkel draußen ist noch zusätzlich das Licht im Flur angeht. Dazu hatte ich immer das CustomRecv überprüft und geschaut, ob da der Name des Alias auftaucht, wenn ja, dann ggf. Licht an. Seit dem Update auf die letzte Version wird aber nur noch der Index des Items auf der Page geliefert und demnach habe ich keine zuverlässige Variante, um zu schauen, welcher Button das war. Ich könnte meine Bedingung auch noch an den Page Index koppeln, aber wenn ich mal was verschiebe, dann müsste ich es dort auch nachziehen. In der aktuellen Struktur der NSPanel States konnte ich nichts finden.
                                Meine Frage daher: Wäre es möglich die Information welcher Button geklickt wurde auch noch mit rausschreiben, so dass man ggf. drauf reagieren kann? Lokal habe ich das bei mir so gelöst, dass ich bei Button Events zusätzliche States schreibe. Das habe ich in function HandleButtonEvent(words: any): void umgesetzt:
                                        if (Debug) {
                                            log('HandleButtonEvent übergebene Werte ' + words[0] + ' - ' + words[1] + ' - ' + words[2] + ' - ' + words[3] + ' - ' + words[4] + ' - PageId: ' + pageId, 'info');
                                        setOrCreate(NSPanel_Path + "Event.Button.Action", buttonAction ?? words[2]);
                                        setOrCreate(NSPanel_Path + "Event.Button.Value", words[4]);
                                        setOrCreate(NSPanel_Path + "Event.Button.Id", id);
                                        if ((words[2]).substring(0, 8) == 'navigate') {
                                            GeneratePage(eval((words[2]).substring(9, (words[2]).length)));
                                            return;
                                Und dann der entsprechende Trigger dazu in einem anderen Skript
                                on("0_userdata.0.NSPanel.1.Event.Button.Id", "any", (obj) => {
                                    if (!obj.id) {
                                        return;
                                    switch(obj.state.val) {
                                        case "alias.0.Rooms.Wohnzimmer.Lichter_Aus":
                                        if (getState("alias.0.Rooms.Draußen.Dunkel.ACTUAL").val
                                            && !getState("alias.0.EnOcean.Licht.EG.Flur.ON_ACTUAL").val) {
                                            setState("alias.0.EnOcean.Licht.EG.Flur.SET", true);
                                        break;
                                Ich finde es von der Sache her nicht schlecht, man könnte da auch weitere Events für bspw. Hardware Button und Co. anlegen. Passt gut in die Struktur rein. Was haltet ihr davon?
                                Armilar 1 Reply Last reply Reply Quote 1
                                • Armilar
                                  Armilar Most Active Forum Testing @Armilar last edited by Armilar
                                  Update v4.3.3.38
                                  Steht sonst immer weiter unten, ist dieses Mal aber abweichend! - daher zuerst:
                                  da die Funktionen für den Screensaver nicht im TFT v4.3.3 stable sind und die TFT v4.3.4 noch nicht verfügbar ist, bitte ein DEV TFT Upgrade machen - also nicht über das Service-Menü, sondern über die Tasmota-Konsole:
                                  FlashNextion http://nspanel.pky.eu/lui.tft
                                  Was hat sich im allgemeinen geändert?
                                  • Die Screensaver Notification erlaubt jetzt ein Leeren der Datenpunkte, d.h. es wird nur eine Nachricht erzeugt, wenn Headline und Text gefüllt sind.
                                  • Die cardLChart benötigt keine yAxisTicks mehr, d.h. wenn der Parameter in der Seitendefinition (Variable) nicht gesetzt ist, errechnet das Script den minimalen- und den maximalen Wert für die Y-Achse.
                                    Beispiel (yAxisTicks auskommentiert):
                                    let CardLChartExample: PageType =
                                        'type': 'cardLChart',
                                        'heading': 'Büro Temperatur',
                                        'items': [{
                                                    yAxis: 'Temperatur [°C]',
                                                    //yAxisTicks: [-250, -200, -150, -100,-50, 0, 50, 100, 150, 200, 250, 300],
                                                    onColor: Yellow
                                  • Über die 5 Indicator Entitäten (im Advanced Screensaver) hat man jetzt die Möglichkeit, direkt zu einer Seite zu gelangen. Hierfür muss wie im nachfolgenden Beispiel der Parameter ScreensaverEntityNaviToPage hinzugefügt werden und auf eine existierende Seitenvariable zeigen:
                                    Beispiel mit ScreensaverEntityNaviToPage
                                             // indicatorScreensaverEntity 1 (only Advanced Screensaver)
                                                 ScreensaverEntity: '0_userdata.0.NSPanel.Indicators.Haus',
                                                 ScreensaverEntityIconOff: 'window-closed-variant',
                                                 ScreensaverEntityIconColor: { 'val_min': 0, 'val_max': 1 },
                                                 ScreensaverEntityNaviToPage: Fenster_1
                                    Im folgenden Beispiel werden z.B. offene Fenster duch den Indikator signalisiert. Mit Klick auf das Icon im Screensaver wird z.B. die Seite (page oder subPage möglich) Fenster_1 geöffnet, in der eine detaillierte Übersicht der (geöffneten) Fenster und Türen zu sehen ist.
                                    Ist diese Funktion für das Icon nicht hinterlegt, wird für den Button ein normales verlassen des Screensavers emuliert.
                                  Wie funktioniert das Update?
                                  Wenn aktuelle Version ab v4.3.3.30, dann unteren Teil des NSPanelTs.ts ab:
                                  // ________________ DE: Ab hier keine Konfiguration mehr _______________
                                  austauschen
                                  https://github.com/joBr99/nspanel-lovelace-ui/blob/main/ioBroker/NsPanelTs.ts
                                  Wenn aktuelle Version bis v4.3.3.29, dann Updateaneitung befolgen:
                                  https://github.com/joBr99/nspanel-lovelace-ui/wiki/NSPanel-Starthilfe-FAQ#hilfe-bei-update--upgrade
                                  VG
                                  @ticaki , @TT-Tom & @Armilar 😊
                                  • Armilar
                                    Armilar Most Active Forum Testing @theknut last edited by
                                    @theknut
                                    Ist eine folge der überlangen Alias-Namen gewesen. Daher sind wir ja auf eine sehr viel kürzere id umgestiegen.
                                    Von meiner Seite, auch wenn ich aktuell keinen Anwendungsfall finde, spricht nichts dagegen 3 weitere Datenpunkte mit diesen Events zu erzeugen...
                                    Werde es mit @ticaki und mit @TT-Tom kurz erörtern...
                                    • theknut
                                      K, dann mach ich heute Abend einen PR, dann hast du keinen Aufwand, falls ihr es übernehmen wollt.
                                      Armilar T 2 Replies Last reply Reply Quote 1
                                      • Armilar
                                        @theknut sagte in SONOFF NSPanel mit Lovelace UI:
                                        perfekt, wir besprechen es im PR...
                                          ticaki Developer @theknut last edited by
                                          @theknut
                                          Bitte poste den Link hier:)
                                          Ich würde aber dringend raten 5 Datenfelder anzulegen {type: boolean, role:'button', read: true, write:false} und diese bei einem touch auf true zu setzen. Abfragen muß man die dann mit change: any, val: true. Das wäre nach den Definitionen.
                                          theknut 1 Reply Last reply Reply Quote 0
                                          • theknut
                                            theknut @ticaki last edited by
                                            @ticaki sorry, verstehe ich nicht. Wieso boolean und wieso 5?!
                                            1.0k
                                            lovelace ui nspanel sonoff
                                            270
                                            7656
                                            6410711
