    4. Kann VIS Editor nicht mehr aufrufen
      Thomas Braun Most Active @TimoWald last edited by
      @timowald
      Das ist nicht die Ausgabe von 'iob diag'.
        TimoWald @Thomas Braun last edited by Homoran
        @thomas-braun Ist das das hier?
        Skript v.2023-10-25
        *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer-container
                   Chassis: container
            Virtualization: lxc
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.5.11-7-pve
              Architecture: x86-64
        model name      : Intel(R) Core(TM) i3-4010U CPU @ 1.70GHz
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         12:24:28 up 1 day, 12:31,  1 user,  load average: 1.28, 1.05, 0.89
        CPU threads: 4
        *** Time and Time Zones ***
        x               Local time: Sun 2024-01-21 12:24:28 CET
                   Universal time: Sun 2024-01-21 11:24:28 UTC
                         RTC time: n/a
                      NTP service: inactive
                  RTC in local TZ: no
        *** User and Groups ***
        root
        /root
        root
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:
        *** MEMORY ***
        Mem:            7.8G        3.4G        4.1G        0.0K        366M        4.4G
        Swap:           7.0G        1.4G        5.6G
        Total:           14G        4.8G        9.7G
                 7828 M total memory
                 3381 M used memory
                 1913 M active memory
                 1536 M inactive memory
                 4080 M free memory
                    0 M buffer memory
                  366 M swap cache
                 7039 M total swap
                 1448 M used swap
                 5591 M free swap
        *** FAILED SERVICES ***
          UNIT                          LOAD   ACTIVE SUB    DESCRIPTION
        * run-rpc_pipefs.mount          loaded failed failed RPC Pipe File System
        * sys-kernel-config.mount       loaded failed failed Kernel Configuration File System
        * systemd-journald-audit.socket loaded failed failed Journal Audit Socket
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        3 loaded units listed.
        *** FILESYSTEM ***
        Filesystem                       Type      Size  Used Avail Use% Mounted on
        /dev/mapper/pve-vm--254--disk--0 ext4       16G  8.0G  6.8G  54% /
        none                             tmpfs     492K  4.0K  488K   1% /dev
        /dev/mapper/pve-root             ext4       24G   15G  7.9G  65% /dev/ttyACM0
        udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
        tmpfs                            tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs                            tmpfs     1.6G  100K  1.6G   1% /run
        tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
        Check not possible in LXC or Docker
        Show mounted filesystems:
        TARGET                                SOURCE                                             FSTYPE     OPTIONS
        /                                     /dev/mapper/pve-vm--254--disk--0                   ext4       rw,relatime,stripe=16
        |-/run                                tmpfs                                              tmpfs      rw,nosuid,nodev,size=1603352k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64
        | `-/run/lock                         tmpfs                                              tmpfs      rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64
        |-/dev                                none                                               tmpfs      rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
        | |-/dev/shm                          tmpfs                                              tmpfs      rw,nosuid,nodev,uid=100000,gid=100000,inode64
        | |-/dev/mqueue                       mqueue                                             mqueue     rw,nosuid,nodev,noexec,relatime
        | |-/dev/ttyACM0                      /dev/mapper/pve-root[/var/lib/lxc/254/devices/ttyACM0]
        | |        ext4       rw,relatime,errors=remount-ro
        | |-/dev/.lxc/proc                    proc                                               proc       rw,relatime
        | |-/dev/.lxc/sys                     sys                                                sysfs      rw,relatime
        | |-/dev/full                         udev[/full]                                        devtmpfs   rw,nosuid,relatime,size=3974572k,nr_inodes=993643,mode=755,inode64
        | |-/dev/null                         udev[/null]                                        devtmpfs   rw,nosuid,relatime,size=3974572k,nr_inodes=993643,mode=755,inode64
        | |-/dev/random                       udev[/random]                                      devtmpfs   rw,nosuid,relatime,size=3974572k,nr_inodes=993643,mode=755,inode64
        | |-/dev/tty                          udev[/tty]                                         devtmpfs   rw,nosuid,relatime,size=3974572k,nr_inodes=993643,mode=755,inode64
        | |-/dev/urandom                      udev[/urandom]                                     devtmpfs   rw,nosuid,relatime,size=3974572k,nr_inodes=993643,mode=755,inode64
        | |-/dev/zero                         udev[/zero]                                        devtmpfs   rw,nosuid,relatime,size=3974572k,nr_inodes=993643,mode=755,inode64
        | |-/dev/pts                          devpts                                             devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
        | |-/dev/ptmx                         devpts[/ptmx]                                      devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
        | |-/dev/console                      devpts[/0]                                         devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
        | |-/dev/tty1                         devpts[/1]                                         devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
        | `-/dev/tty2                         devpts[/2]                                         devpts     rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026
        |-/proc                               proc                                               proc       rw,nosuid,nodev,noexec,relatime
        | |-/proc/sys                         proc[/sys]                                         proc       ro,relatime
        | | |-/proc/sys/net                   proc[/sys/net]                                     proc       rw,nosuid,nodev,noexec,relatime
        | | `-/proc/sys/kernel/random/boot_id none[/.lxc-boot-id]                                tmpfs      ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64
        | |-/proc/sysrq-trigger               proc[/sysrq-trigger]                               proc       ro,relatime
        | |-/proc/cpuinfo                     lxcfs[/proc/cpuinfo]                               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/diskstats                   lxcfs[/proc/diskstats]                             fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/loadavg                     lxcfs[/proc/loadavg]                               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/meminfo                     lxcfs[/proc/meminfo]                               fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/slabinfo                    lxcfs[/proc/slabinfo]                              fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/stat                        lxcfs[/proc/stat]                                  fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | |-/proc/swaps                       lxcfs[/proc/swaps]                                 fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        | `-/proc/uptime                      lxcfs[/proc/uptime]                                fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        `-/sys                                sysfs                                              sysfs      ro,nosuid,nodev,noexec,relatime
          |-/sys/fs/fuse/connections          fusectl                                            fusectl    rw,nosuid,nodev,noexec,relatime
          |-/sys/devices/virtual/net          sysfs[/devices/virtual/net]                        sysfs      rw,nosuid,nodev,noexec,relatime
          |-/sys/fs/cgroup                    none                                               cgroup2    rw,nosuid,nodev,noexec,relatime
          `-/sys/devices/system/cpu           lxcfs[/sys/devices/system/cpu]                     fuse.lxcfs rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other
        /var:
        712M    /var/
        317M    /var/cache
        313M    /var/cache/apt
        258M    /var/log
        247M    /var/log/journal/e42f0ac6b105431aa6e42fb59b1f8fbf
        Archived and active journals take up 246.6M in the file system.
        /opt/iobroker/backups:
        493M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        i1.4G   /opt/iobroker/iobroker-data/
        842M    /opt/iobroker/iobroker-data/files
        267M    /opt/iobroker/iobroker-data/backup-objects
        177M    /opt/iobroker/iobroker-data/files/vis-2
        155M    /opt/iobroker/iobroker-data/node-red
        38M     /opt/iobroker/iobroker-data/states.jsonl
        34M     /opt/iobroker/iobroker-data/objects.jsonl
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
        24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2272728-if00
        *** NodeJS-Installation ***
        ./iob_diag: line 283: nodejs: command not found
        /usr/bin/node           v18.17.1
        /usr/bin/npm            9.6.7
        /usr/bin/npx            9.6.7
        /usr/bin/corepack       0.18.0
        ./iob_diag: line 294: nodejs: command not found
        *** nodejs is NOT correctly installed ***
        Run ob nodejs-update to fix it.
        nodejs:
          Installed: 18.17.1-deb-1nodesource1
          Candidate: 18.17.1-deb-1nodesource1
          Version table:
         *** 18.17.1-deb-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                100 /var/lib/dpkg/status
             12.22.12~dfsg-1~deb11u4 500
                500 http://ftp.debian.org/debian bullseye/main amd64 Packages
                500 http://security.debian.org bullseye-security/main amd64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.17
        admin:          6.12.0
        javascript:     7.1.6
        Adapters from github:   12
        Adapter State
        + system.adapter.adguard.0                : adguard               : iobroker                                 -  enabled, compact disabled
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled, compact disabled
        + system.adapter.alexa2.1                 : alexa2                : iobroker                                 -  enabled, compact disabled
          system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled, compact disabled
          system.adapter.apple-find-me.0          : apple-find-me         : iobroker                                 - disabled, compact disabled
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled, compact disabled
          system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled, compact disabled
          system.adapter.birthdays.1              : birthdays             : iobroker                                 -  enabled, compact disabled
        + system.adapter.bydhvs.0                 : bydhvs                : iobroker                                 -  enabled, compact disabled
        + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled, compact disabled
          system.adapter.device-watcher.0         : device-watcher        : iobroker                                 - disabled, compact disabled
        + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled, compact disabled
        + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled, compact disabled
        + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled, compact disabled
          system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: iobroker                                 - disabled, compact disabled
        + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled, compact disabled
          system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 - disabled, compact disabled
          system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
          system.adapter.fritzdect.0              : fritzdect             : iobroker                                 - disabled, compact disabled
        + system.adapter.fronius-solarweb.0       : fronius-solarweb      : iobroker                                 -  enabled, compact disabled
        + system.adapter.fronius.0                : fronius               : iobroker                                 -  enabled, compact disabled
        + system.adapter.hass.0                   : hass                  : iobroker                                 -  enabled, compact disabled, port: 8123
          system.adapter.hikvision-alarmserver.0  : hikvision-alarmserver : iobroker                                 - disabled, compact disabled, port: 8089, bind: 0.0.0.0
        + system.adapter.history.0                : history               : iobroker                                 -  enabled, compact disabled
        + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled, compact disabled
        + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled, compact disabled
          system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled, compact disabled
          system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
          system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
        + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, compact disabled, port: 8086
          system.adapter.innogy-smarthome.0       : innogy-smarthome      : iobroker                                 - disabled
        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled, compact disabled
        + system.adapter.iot.1                    : iot                   : iobroker                                 -  enabled, compact disabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled, compact disabled
          system.adapter.knx.0                    : knx                   : iobroker                                 - disabled, compact disabled, bind: 192.168.9.254
        + system.adapter.lg-thinq.0               : lg-thinq              : iobroker                                 -  enabled, compact disabled
          system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 - disabled, compact disabled, port: 54321
        + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled, compact disabled
        + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled, compact disabled
        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, compact disabled, port: 1883, bind: 0.0.0.0
        + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, compact disabled, port: 1880, bind: 192.168.9.254
        + system.adapter.openknx.0                : openknx               : iobroker                                 -  enabled, compact disabled
          system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled, compact disabled
        + system.adapter.philips-tv.0             : philips-tv            : iobroker                                 -  enabled, compact disabled
        + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, compact disabled, port: 8006
        + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled, compact disabled
        + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled, compact disabled
        + system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled, compact enabled (group 1)
        + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
          system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled, compact disabled, port: 0
        + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, compact disabled, port: 1883, bind: 0.0.0.0
        + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, compact disabled, port: 8087, bind: 0.0.0.0, run as: admin
          system.adapter.smartthings.0            : smartthings           : iobroker                                 - disabled, compact disabled
        + system.adapter.solax.0                  : solax                 : iobroker                                 -  enabled, compact disabled
        + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, compact disabled, port: 1884, bind: 0.0.0.0
        + system.adapter.sonos.0                  : sonos                 : iobroker                                 -  enabled, compact disabled
        + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, compact disabled, port: 5000
        + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled, compact disabled
          system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled, compact disabled
        + system.adapter.tradfri.0                : tradfri               : iobroker                                 -  enabled, compact disabled
        + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled, compact disabled
          system.adapter.tuya.0                   : tuya                  : iobroker                                 - disabled, compact disabled
          system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
          system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
          system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: iobroker                                 -  enabled
          system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
        + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled, compact disabled
          system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled, compact disabled
          system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled, compact disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled, compact disabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
          system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
          system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 -  enabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
          system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
          system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
          system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
          system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled, compact disabled
        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, compact disabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : iobroker                                 -  enabled, compact disabled
        + system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : iobroker                                 -  enabled, compact disabled
        + system.adapter.whatsapp-cmb.2           : whatsapp-cmb          : iobroker                                 -  enabled, compact disabled
        + system.adapter.wiobrowser.0             : wiobrowser            : iobroker                                 -  enabled, compact disabled, port: 5050
        + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled, compact disabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        ^AAdapter    "adguard"      : 0.0.8    , installed 0.0.8
        Adapter    "admin"        : 6.12.0   , installed 6.12.0
        Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
        Adapter    "backitup"     : 2.9.8    , installed 2.9.8
        Adapter    "birthdays"    : 2.4.1    , installed 2.4.1
        Adapter    "bydhvs"       : 1.5.0    , installed 1.5.0
        Adapter    "device-reminder": 3.0.0  , installed 3.0.0
        Adapter    "device-watcher": 2.9.6   , installed 2.9.6
        Adapter    "echarts"      : 1.7.2    , installed 1.7.2
        Adapter    "evcc"         : 0.1.1    , installed 0.1.1
        Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
        Adapter    "firetv"       : 2.0.2    , installed 2.0.2
        Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
        Adapter    "fronius"      : 2.0.2    , installed 2.0.2
        Adapter    "fronius-solarweb": 0.0.3 , installed 0.1.0
        Adapter    "gira-iot"     : 0.4.0    , installed 0.4.0
        Adapter    "hass"         : 1.4.0    , installed 1.4.0
        Adapter    "hikvision-alarmserver": 0.1.0, installed 0.1.0
        Adapter    "hmip"         : 1.21.0   , installed 1.21.0
        Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
        Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
        Adapter    "innogy-smarthome": 1.2.6 , installed 1.2.6
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
        Controller "js-controller": 5.0.17   , installed 5.0.17
        Adapter    "knx"          : 2.0.24   , installed 2.0.24
        Adapter    "lg-thinq"     : 0.3.2    , installed 0.3.2
        Adapter    "mihome-vacuum": 4.1.0    , installed 4.1.0
        Adapter    "modbus"       : 6.0.1    , installed 6.0.1
        Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
        Adapter    "node-red"     : 4.0.3    , installed 4.0.3
        Adapter    "openknx"      : 0.6.3    , installed 0.6.3
        Adapter    "openweathermap": 1.0.4   , installed 1.0.4
        Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
        Adapter    "proxmox"      : 2.2.2    , installed 2.2.2
        Adapter    "pushover"     : 3.0.6    , installed 3.0.6
        Adapter    "pvforecast"   : 2.9.1    , installed 2.9.1
        Adapter    "roborock"     : 0.4.4    , installed 0.4.4
        Adapter    "sayit"        : 3.0.5    , installed 3.0.5
        Adapter    "shelly"       : 6.6.1    , installed 6.6.1
        Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
        Adapter    "solax"        : 0.8.0    , installed 0.8.0
        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
        Adapter    "synology"     : 3.0.1    , installed 3.0.1
        Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
        Adapter    "trashschedule": 2.3.0    , installed 2.3.0
        Adapter    "tuya"         : 3.15.0   , installed 3.15.0
        Adapter    "vis-2"        : 2.9.11   , installed 2.9.17
        Adapter    "vis-2-widgets-energy": 0.3.9, installed 0.3.9
        Adapter    "vis-2-widgets-gauges": 1.0.2, installed 1.0.2
        Adapter    "vis-2-widgets-jaeger-design": 1.1.5, installed 1.1.5
        Adapter    "vis-2-widgets-material": 1.3.17, installed 1.3.17
        Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
        Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
        Adapter    "vis-materialdesign": 0.5.9, installed 0.5.86
        Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
        Adapter    "web"          : 6.1.10   , installed 6.1.10
        Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
        Adapter    "wiobrowser"   : 2.0.2    , installed 2.0.2
        Adapter    "wled"         : 0.7.2    , installed 0.7.2
        Adapter    "ws"           : 2.5.8    , installed 2.5.8
        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
        Objects and States
        Objects:        24409
        States:         20018
        Hit:1 http://ftp.debian.org/debian bullseye InRelease
        Hit:2 http://ftp.debian.org/debian bullseye-updates InRelease
        Hit:3 http://security.debian.org bullseye-security InRelease
        Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
        Reading package lists... Done
          @timowald
          Auch im Container wird NICHT als root herumgehampelt.
            @thomas-braun das heist ich sollte einen Benutzer anlegen und über diesen die Adapter installieren?
              @timowald sagte in Kann VIS Editor nicht mehr aufrufen:
              Grundsätzlich macht man das als aller erstes.
                @thomas-braun ok. Aber worin liegt das Problem das der VIS Editor nicht mehr geht?
                Thomas Braun DJMarc75 2 Replies Last reply Reply Quote 0
                  Keine Ahnung. Ich schau mir iob diag immer nur bis root an. Stell es richtig und dann rückst du mit einer frischen Ausgabe von
                  iob diag
                  an. In sauberen CodeTags, die Ausgabe beinhaltet die schon.
                  • DJMarc75
                    DJMarc75 @TimoWald last edited by
                    @timowald vis 1 oder vis 2 ?
                    Bei Dir scheint ja viel Beta installiert zu sein 🤔
                      TimoWald @DJMarc75 last edited by
                      @djmarc75 viel Beta eigentlich nicht. Die VIS 2 funktioniert aber bei der VIS 1 funktioniert der editor nicht.
                      Thomas Braun Feuersturm 2 Replies Last reply Reply Quote 0
                        @timowald
                        Nee, nur
                        • Feuersturm
                          Feuersturm @TimoWald last edited by
                          Hast du mal den Browsercache gelöscht?
                            TimoWald @Feuersturm last edited by
                            @feuersturm ja habe ich auch. Auch auf mehreren PCs probiert. Überall das selbe.
                              @timowald
                              User angelegt?
                              Als dieser user dann:
                              iob nodejs-update
                              iob diag
                                Homoran Global Moderator Administrators @TimoWald last edited by
                                @timowald da fehlt die Hälfte!
                                mehr Geduld!
                                  TimoWald @Homoran last edited by
                                  @homoran Habe jetzt noch einen dritten Rechner genommen und da kann ich alles noch normal aufrufen. Am Handy habe ich es auch mal versucht. Das geht auch. Was haben die beiden PCs für ein Problem? Egal welchen Browser ich nutze, der Editor öffnet sich nicht. (Chrome, Firefox, Edge)
                                  Homoran wendy2702 2 Replies Last reply Reply Quote 0
                                    das sollte im vollständigen Output von iob diag zu sehen sein.
                                      @homoran mit dem erstellen von dem iob diag bin ich glaube überfordert. Sorry.
                                      liv-in-sky Homoran 2 Replies Last reply Reply Quote 0
                                      • wendy2702
                                        wendy2702 @TimoWald last edited by
                                        @timowald möglicherweise:
                                        Firewall
                                        Antivirus
                                        As blocker
                                        Irgendwelche browser Erweiterungen
                                        Scheint ja jedenfalls ein Problem der PCs zu sein und nicht iobroker
                                          liv-in-sky @TimoWald last edited by
                                          @timowald
                                          probier mal (chrome):
                                          • vis aufrufen - dann irgendwo auf der seite mit rechter maustaste auf "untersuchen" gehen - es öffnet sich ein fenster, darin den tab: console waählen - dann refresh der seite und in dem console tab nachkucken, was da kommt
                                          oder
                                          eine erweiterung eines virenscanners oder ein blocker für scripte installiert
                                            TimoWald @liv-in-sky last edited by
                                            @liv-in-sky da kommt das wenn ich den Editor lade.
                                            1037
