    4. Fehlermeldungen beim Biobroker Update
      Thomas Braun Most Active @Volleyhomer last edited by
      @volleyhomer sagte in Fehlermeldungen beim Biobroker Update:
      Exakt gleich wie weiter oben beschrieben.
      Du sollst es auch nicht nacherzählen oder beschreiben sondern immer den Output im Terminal zeigen. Dann sehe ich was da passiert.
      curl -L https://iobroker.net/fix.sh | bash -
      • V
        Volleyhomer @Thomas Braun last edited by
        @thomas-braun said in Fehlermeldungen beim Biobroker Update:
        pi@rock64:~$ curl -L https://iobroker.net/fix.sh | bash -
          % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                         Dload  Upload   Total   Spent    Left  Speed
          0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
        curl: (60) SSL certificate problem: certificate has expired
        More details here: https://curl.haxx.se/docs/sslcerts.html
        curl performs SSL certificate verification by default, using a "bundle"
         of Certificate Authority (CA) public keys (CA certs). If the default
         bundle file isn't adequate, you can specify an alternate file
         using the --cacert option.
        If this HTTPS server uses a certificate signed by a CA represented in
         the bundle, the certificate verification probably failed due to a
         problem with the certificate (it might be expired, or the name might
         not match the domain name in the URL).
        If you'd like to turn off curl's verification of the certificate, use
         the -k (or --insecure) option.
          @volleyhomer
          Auch das ist eine Folge von deiner Update-Faulheit...
          sudo apt update
          V 1 Reply Last reply Reply Quote 1
          • V
            @volleyhomer
            sudo apt update
            pi@rock64:~$ sudo apt update
            [sudo] password for pi:
            Ign:1 http://httpredir.debian.org/debian stretch InRelease
            Ign:2 http://security.debian.org stretch/updates InRelease
            Err:3 http://security.debian.org stretch/updates Release
              404  Not Found [IP: 146.75.122.132 80]
            Ign:4 http://httpredir.debian.org/debian stretch-updates InRelease
            Ign:5 http://httpredir.debian.org/debian stretch-backports InRelease
            Err:6 http://httpredir.debian.org/debian stretch Release
            Err:7 http://httpredir.debian.org/debian stretch-updates Release
            Err:8 http://httpredir.debian.org/debian stretch-backports Release
            Ign:9 http://apt.armbian.com stretch InRelease
            Hit:10 https://deb.nodesource.com/node_14.x stretch InRelease
            Err:11 http://apt.armbian.com stretch Release
              502  Bad Gateway [IP: 130.185.239.78 80]
            Reading package lists... Done
            E: The repository 'http://security.debian.org stretch/updates Release' does no longer have a Release file.
            N: Updating from such a repository can't be done securely, and is therefore disabled by default.
            N: See apt-secure(8) manpage for repository creation and user configuration details.
            E: The repository 'http://httpredir.debian.org/debian stretch Release' does no longer have a Release file.
            E: The repository 'http://httpredir.debian.org/debian stretch-updates Release' does no longer have a Release file.
            E: The repository 'http://httpredir.debian.org/debian stretch-backports Release' does no longer have a Release file.
            E: The repository 'http://apt.armbian.com stretch Release' does no longer have a Release file.
              curl -kL https://iobroker.net/fix.sh | bash -
              • V
                Das lief scheinbar durch.
                pi@rock64:~$ curl -kL https://iobroker.net/fix.sh | bash -
                100   185  100   185    0     0    916      0 --:--:-- --:--:-- --:--:--   915
                100 39849  100 39849    0     0  59580      0 --:--:-- --:--:-- --:--:-- 59580
                library: loaded
                Library version=2024-01-04
                    Welcome to the ioBroker installation fixer!
                    Script version: 2024-01-04
                    You might need to enter your password a couple of times.
                    Installing prerequisites (1/5)
                Ign:1 http://security.debian.org stretch/updates InRelease
                Ign:2 http://httpredir.debian.org/debian stretch InRelease
                Hit:9 http://fi.mirror.armbian.de/apt stretch InRelease
                Installed libcairo2-dev
                Installed libpango1.0-dev
                Installed libjpeg-dev
                Installed libgif-dev
                Installed librsvg2-dev
                Installed libpixman-1-dev
                Installed cmake
                    Checking ioBroker user and directory permissions (2/5)
                Created /etc/sudoers.d/iobroker
                Fixing directory permissions...
                    Check and cleanup npm temporary directories (3/5)
                Done.
                    Database maintenance (4/5)
                Checking for uncompressed JSONL databases... This might take a while!
                npx: installed 12 in 14.437s
                No path given, using /opt/iobroker/iobroker-data
                Compressing /opt/iobroker/iobroker-data/states.jsonl
                Compressing /opt/iobroker/iobroker-data/objects.jsonl
                Compressed 2 JSONL files. Done
                    Checking autostart (5/5)
                Enabling autostart...
                Autostart enabled!
                    Your installation was fixed successfully
                    Run iobroker start to start ioBroker again!
                  @volleyhomer
                  Die ganzen Stretch-Quellen sind natürlich vor geraumer Zeit trockengelegt worden... Never change a running system, was?
                  Funktioniert
                  iob nodejs-update 16
                  denn nun?
                  • V
                    Volleyhomer @Thomas Braun last edited by Volleyhomer
                    @volleyhomer
                    Funktioniert
                    denn nun?
                    Es gibt keine Fehlermeldung mehr. Muss iobroker dafür laufen? Is ja aktuell noch gestoppt.
                    pi@rock64:~$ iob nodejs-update 16
                    pi@rock64:~$
                    Ist das Problem denn jetzt die alte debian oder die alte npm, node, etc. Version?
                      Alles zusammen. Da ist ja gar nix aktuell bei dir.
                        @volleyhomer
                        Versuch:
                        NODE_MAJOR=16
                        sudo apt update
                        sudo apt install -y ca-certificates curl gnupg
                        sudo mkdir -p /etc/apt/keyrings
                        curl -kL https://deb.nodesource.com/gpgkey/nodesource-repo.gpg.key | sudo gpg --dearmor -o /etc/apt/keyrings/nodesource.gpg
                        echo "deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_${NODE_MAJOR}.x nodistro main" | sudo tee /etc/apt/sources.list.d/nodesource.list
                        echo -e "Package: nodejs\nPin: origin deb.nodesource.com\nPin-Priority: 1001" | sudo tee /etc/apt/preferences.d/nodejs.pref
                        sudo apt update
                        sudo apt install nodejs
                        • V
                          NODE_MAJOR=16
                          Hagelt Fehlermeldungen. Ich glaube ich muss mir dann mal ein Wochenende frei nehmen, die Kinder ausquartieren und in Ruhe mich einlesen und alles neu aufsetzen.
                          NodeJS Update scheint aber geklappt zu haben.
                          pi@rock64:~$ NODE_MAJOR=16
                          Hit:9 http://mirrors.dotsrc.org/armbian-apt stretch InRelease
                          pi@rock64:~$ sudo apt install -y ca-certificates curl gnupg
                          Building dependency tree
                          gnupg is already the newest version (2.1.18-8~deb9u4).
                          The following packages will be upgraded:
                            ca-certificates curl libcurl3
                          3 upgraded, 0 newly installed, 0 to remove and 132 not upgraded.
                          Need to get 652 kB of archives.
                          After this operation, 35.8 kB of additional disk space will be used.
                          Ign:1 http://security.debian.org stretch/updates/main arm64 ca-certificates all 20200601~deb9u2
                          Err:2 http://security.debian.org stretch/updates/main arm64 curl arm64 7.52.1-5+deb9u16
                          Err:3 http://security.debian.org stretch/updates/main arm64 libcurl3 arm64 7.52.1-5+deb9u16
                          Err:1 http://security.debian.org stretch/updates/main armhf ca-certificates all 20200601~deb9u2
                          E: Failed to fetch http://security.debian.org/pool/updates/main/c/ca-certificates/ca-certificates_20200601~deb9u2_all.deb  404  Not Found [IP: 146.75.122.132 80]
                          E: Failed to fetch http://security.debian.org/pool/updates/main/c/curl/curl_7.52.1-5+deb9u16_arm64.deb  404  Not Found [IP: 146.75.122.132 80]
                          E: Failed to fetch http://security.debian.org/pool/updates/main/c/curl/libcurl3_7.52.1-5+deb9u16_arm64.deb  404  Not Found [IP: 146.75.122.132 80]
                          E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
                          pi@rock64:~$ sudo mkdir -p /etc/apt/keyrings
                          pi@rock64:~$
                          pi@rock64:~$ curl -kL https://deb.nodesource.com/gpgkey/nodesource-repo.gpg.key | sudo gpg --dearmor -o /etc/apt/keyrings/nodesource.gpg
                          100  1684  100  1684    0     0   7395      0 --:--:-- --:--:-- --:--:--  7385
                          pi@rock64:~$ echo "deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_${NODE_MAJOR}.x nodistro main" | sudo tee /etc/apt/sources.list.d/nodesource.list
                          deb [signed-by=/etc/apt/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x nodistro main
                          pi@rock64:~$ echo -e "Package: nodejs\nPin: origin deb.nodesource.com\nPin-Priority: 1001" | sudo tee /etc/apt/preferences.d/nodejs.pref
                          Package: nodejs
                          Pin-Priority: 1001
                          Ign:3 http://httpredir.debian.org/debian stretch-updates InRelease
                          Err:4 http://security.debian.org stretch/updates Release
                          Get:10 https://deb.nodesource.com/node_16.x nodistro InRelease [12.1 kB]
                          Get:11 https://deb.nodesource.com/node_16.x nodistro/main armhf Packages [7469 B]
                          Get:12 https://deb.nodesource.com/node_16.x nodistro/main arm64 Packages [7485 B]
                          Get:13 https://deb.nodesource.com/node_16.x nodistro/main arm64 Contents (deb) [19.5 kB]
                          Get:14 https://deb.nodesource.com/node_16.x nodistro/main armhf Contents (deb) [19.5 kB]
                          pi@rock64:~$ sudo apt install nodejs
                            nodejs
                          1 upgraded, 0 newly installed, 0 to remove and 135 not upgraded.
                          Need to get 27.2 MB of archives.
                          After this operation, 7285 kB of additional disk space will be used.
                          Get:1 https://deb.nodesource.com/node_16.x nodistro/main arm64 nodejs arm64 16.20.2-1nodesource1 [27.2 MB]
                          Fetched 27.2 MB in 6s (3939 kB/s)
                          (Reading database ... 38255 files and directories currently installed.)
                          Preparing to unpack .../nodejs_16.20.2-1nodesource1_arm64.deb ...
                          Detected old npm client, removing...
                          Unpacking nodejs (16.20.2-1nodesource1) over (14.21.3-1nodesource1) ...
                          Setting up nodejs (16.20.2-1nodesource1) ...
                          Processing triggers for man-db (2.7.6.1-2) ...
                          pi@rock64:~$
                          • V
                            Volleyhomer @Volleyhomer last edited by
                            @volleyhomer said in Fehlermeldungen beim Biobroker Update:
                            NODE_MAJOR=16
                            pi@rock64:~$
                            Package: nodejs
                            Pin-Priority: 1001
                              nodejs
                            pi@rock64:~$
                            Obwohl...
                            pi@rock64:~$ type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            /usr/bin/npx
                            v16.20.2
                            v16.20.2
                            8.19.4
                            8.19.4
                            pi@rock64:~$
                              Homoran Global Moderator Administrators @Volleyhomer last edited by Homoran
                              Obwohl
                              dann besteht Hoffnung die wichtigsten Komponenten von iobroker relativ aktuell zu bekommen.
                              dann backup
                              Neuinstallation
                              Restore
                              am besten jetzt das erste backup starten und an sicherer Stelle extern speichern
                              geht denn jetzt iob diag?
                                @volleyhomer
                                Natürlich...
                                Aber nodejs@16 ist jetzt drauf, das ist die höchste Version die du da drauf bekommst. Alles andere braucht auch ein aktuelleres Betriebssystem.
                                iob stop
                                iob update
                                iob upgrade self
                                • V
                                  Volleyhomer @Homoran last edited by
                                  @homoran said in Fehlermeldungen beim Biobroker Update:
                                  Obwohl
                                  dann backup
                                  Neuinstallation
                                  Restore
                                  Nein, geht nicht.
                                  pi@rock64:~$ iob diag
                                  pi@rock64:~$
                                  Backups kopiere ich nach dem erstellen immer direkt via filezilla in die icloud. Normalerweise via backitup auch auf das NAS.
                                  • V
                                    @volleyhomer
                                    Natürlich...
                                    iob stop
                                    iob update
                                    iob upgrade self
                                    Ich hab gerade kurz bzgl. debian Update gegoogelt. Habe ich keine Ahnung von, scheint ja aber nicht wild zu sein. Geht sowas "am offenen Herzen"? Ich bekomme nächste Woche eine neue eMMC für den ROCK64 und werde damit dann alles nochmal neu aufsetzen.
                                      Thomas Braun Most Active @Volleyhomer last edited by Thomas Braun
                                      Aber nicht über drei Releases aus einer Ruine heraus.
                                      Bring den iobroker jetzt auf den höchstmöglichen Stand, zieh ein Backup und dann spielst du das sauber in ein frisch installiertes Debian 12 'Bookworm' wieder ein.
                                      • V
                                        Okay. Das werde ich dann irgendwann die nächsten Tage angehen. Vielen Dank für deine Mühe, Zeit und Hilfe!
                                        • V
                                          Volleyhomer last edited by Volleyhomer
                                          @Thomas-Braun :
                                          Ein Problem habe ich jetzt noch. Wenn ich Adapter updaten will (u.a. auch Admin) dann wird mir in der iobroker UI folgendes angezeigt.
                                          Dependencies
                                          js-controller (>=3.3.0): 4.0.24
                                          admin (>=5.1.28): 6.3.5
                                          node (>=16): 14.21.3
                                          angezeigt. Version ist laut Kommando Zeile aber:
                                          pi@rock64:~$ node -v
                                          v16.20.2
                                          pi@rock64:~$
                                          Muss man da noch irgendwas reseten? Neu starten? Oder ähnliches?
                                            Neu starten?
                                            Würde ich machen.
                                            Und dann nochmal
                                            iob diag
                                            1691
