    4. Ziggbe sendet nicht mehr an empfängt aber noch Daten
      Tapdance 0 @Thomas Braun last edited by
      Der neue Zigbee stick ist da und angeschlossen, doch jetzt startet der Zigbee Adapter wieder nicht 😥
      Hoffe ihr könnt noch mal helfen.
      DANKE
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.1.0-rpi7-rpi-v8
          Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       16:32:45 up 3 min,  3 users,  load average: 1.29, 1.41, 0.63
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Sun 2024-01-21 16:32:45 CET
                 Universal time: Sun 2024-01-21 15:32:45 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      PI
      /home/PI
      PI adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            4.0G        1.6G        2.0G        1.3M        417M        2.3G
      Swap:           104M          0B        104M
      Total:          4.1G        1.6G        2.1G
               3793 M total memory
               1567 M used memory
               1595 M active memory
                164 M inactive memory
               1903 M free memory
                 39 M buffer memory
                358 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     380M  1.2M  379M   1% /run
      /dev/mmcblk0p2 ext4       28G  7.0G   20G  27% /
      tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
      /dev/mmcblk0p1 vfat      510M   73M  438M  15% /boot/firmware
      tmpfs          tmpfs     380M   32K  380M   1% /run/user/1000
      [Sun Jan 21 16:28:52 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:64:62:CC vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9515910b-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Sun Jan 21 16:28:56 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sun Jan 21 16:28:59 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET           SOURCE         FSTYPE OPTIONS
      /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      643M    /var/
      194M    /var/lib
      185M    /var/cache
      172M    /var/cache/apt
      163M    /var/log
      Archived and active journals take up 161.5M in the file system.
      /opt/iobroker/backups:
      4.0K    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      369M    /opt/iobroker/iobroker-data/
      270M    /opt/iobroker/iobroker-data/files
      78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
      73M     /opt/iobroker/iobroker-data/backup-objects
      67M     /opt/iobroker/iobroker-data/files/javascript.admin
      22M     /opt/iobroker/iobroker-data/objects.jsonl
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
      7.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/691.26ff76ce.chunk.js.map
      7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.d3cce782.chunk.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_8eb6f719a99ded11ad35dca5a7669f5d-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
           18.19.0+dfsg-6~deb12u1 500
       *** 18.19.0-1nodesource1 1001
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1 500
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.12.0
      javascript:     7.1.6
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alarm.0                  : alarm                 : raspberrypi                              -  enabled
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
      + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
      + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
        system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
      + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.synology.0               : synology              : raspberrypi                              -  enabled, port: 5000
      + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 192.168.2.4, run as: admin
      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
        system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
        system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
      + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
      + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00
      + instance is alive
      ioBroker-Repositories
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Stable (default): http://download.iobroker.net/sources-dist.json
      Active repo(s): Stable (default)
      Installed ioBroker-Instances
      Used repository: Stable (default)
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "alarm"        : 3.6.0    , installed 3.6.0
      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "mobile"       : 1.0.1    , installed 1.0.1
      Adapter    "sayit"        : 3.0.5    , installed 3.0.5
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "synology"     : 3.0.1    , installed 3.0.1
      Adapter    "telegram"     : 3.0.1    , installed 1.16.0 [Updatable]
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Adapter    "zigbee"       : 1.10.1   , installed 1.9.7  [Updatable]
      Objects and States
      Objects:        5503
      States:         4905
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 1
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       18072      1133/io.sonoff.0
      tcp        0      0 192.168.2.4:2010        0.0.0.0:*               LISTEN      1001       15234      1081/io.hm-rpc.1
      tcp        0      0 192.168.2.4:2001        0.0.0.0:*               LISTEN      1001       18000      1057/io.hm-rpc.0
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15659      783/cupsd
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       17317      784/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15044      784/iobroker.js-con
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14884      796/sshd: /usr/sbin
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20375      1964/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       15912      962/io.admin.0
      tcp6       0      0 :::8088                 :::*                    LISTEN      1001       20131      1544/io.terminal.0
      tcp6       0      0 :::37485                :::*                    LISTEN      1001       21491      2003/io.yahka.0
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15658      783/cupsd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14886      796/sshd: /usr/sbin
      udp        0      0 0.0.0.0:41433           0.0.0.0:*                           1001       27228      3290/io.broadlink2.
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14975      863/cups-browsed
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       28156      3290/io.broadlink2.
      udp        0      0 0.0.0.0:52376           0.0.0.0:*                           1001       27229      3290/io.broadlink2.
      udp        0      0 192.168.2.4:5353        0.0.0.0:*                           1001       16153      1165/io.tr-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        15556      523/avahi-daemon: r
      udp        0      0 0.0.0.0:60813           0.0.0.0:*                           104        15558      523/avahi-daemon: r
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       18051      1106/io.shelly.0
      udp6       0      0 :::39207                :::*                                104        15559      523/avahi-daemon: r
      udp6       0      0 fe80::67d1:e1cb:7ef:546 :::*                                0          17307      664/NetworkManager
      udp6       0      0 :::5353                 :::*                                104        15557      523/avahi-daemon: r
      2024-01-21 16:34:01.381  - warn: sonoff.0 (1133) Client [Muschel Terrasse] has invalid password or username
      2024-01-21 16:34:01.418  - warn: sonoff.0 (1133) Client [Pavillon Beleuchtung] has invalid password or username
      2024-01-21 16:34:01.764  - info: host.raspberrypi instance system.adapter.broadlink2.0 started with pid 3290
      2024-01-21 16:34:02.379  - warn: sonoff.0 (1133) Client [Wohnzimmer-Vitrine] has invalid password or username
      2024-01-21 16:34:02.422  - warn: sonoff.0 (1133) Client [Pool Beleuchtung] has invalid password or username
      2024-01-21 16:34:02.488  - warn: sonoff.0 (1133) Client [PC-Buero] has invalid password or username
      2024-01-21 16:34:05.121  - warn: sonoff.0 (1133) Client [Pool Pumpe] has invalid password or username
      2024-01-21 16:34:06.343  - warn: shelly.0 (1106) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-21 16:34:07.510  - warn: shelly.0 (1106) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-21 16:34:08.211  - info: broadlink2.0 (3290) starting. Version 2.1.5 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v18.19.0, js-controller: 5.0.17
      2024-01-21 16:34:07.671  - warn: shelly.0 (1106) [authEnabled] 192.168.2.226 (shellydimmer2 / shellydimmer2-8CAAB54C4E21 / SHDM-2#8CAAB54C4E21#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-21 16:34:07.683  - warn: shelly.0 (1106) State value to set for "shelly.0.SHDM-1#D3E918#1.temperatureF" has value "101.66" greater than max "100"
      2024-01-21 16:34:08.481  - info: broadlink2.0 (3290) broadlink2 initialization started...
      2024-01-21 16:34:08.486  - info: broadlink2.0 (3290) Scanning additional IP's: 192.168.2.169
      2024-01-21 16:34:08.487  - info: broadlink2.0 (3290) Devices to add: 0xabcd=RM4
      2024-01-21 16:34:08.489  - info: broadlink2.0 (3290) Devices to rename: LB:hostName-aa-bb-cc=LB:SmartBulb
      2024-01-21 16:34:08.492  - info: broadlink2.0 (3290) broadlink2 has 3 old devices!
      2024-01-21 16:34:08.497  - info: broadlink2.0 (3290) interface to be used: { netmaskBits: 24, address: '192.168.2.4/24', addrs: [ 192, 168, 2, 4 ], cidr: '192.168.2.4/24', bcaddr: '192.168.2.255'
      2024-01-21 16:34:08.498  - info: broadlink2.0 (3290) macObjects: [ '24:df:a7:b1:1a:8d', 'a0:43:b0:14:80:2b', 'b4:43:0d:aa:80:31' ]
      2024-01-21 16:34:08.502  - info: broadlink2.0 (3290) Discover Broadlink devices for 10sec on broadlink2.0
      2024-01-21 16:34:08.590  - info: broadlink2.0 (3290) interface to be used: { netmaskBits: 24, address: '192.168.2.4/24', addrs: [ 192, 168, 2, 4 ], cidr: '192.168.2.4/24', bcaddr: '192.168.2.255'
      2024-01-21 16:34:08.593  - info: broadlink2.0 (3290) discover  [ '192.168.2.255', '255.255.255.255', '224.0.0.251' ] from 0.0.0.0:41433
      2024-01-21 16:34:09.382  - info: broadlink2.0 (3290) Device RM:RMPRO-MOVE315-b1-1a-8d detected: address=192.168.2.169, mac=24:df:a7:b1:1a:8d, typ=RMP, id=0x27a9 devtype=RM3 Pro Plus
      iob diag has finished.
                              v.2023-10-10
             Icon name: computer
          Architecture: arm64
      Installation:           native
      Kernel:                 aarch64
      Userland:               arm64
      Timezone:               Europe/Berlin (CET, +0100)
      User-ID:                1000
      X-Server:               false
      Pending OS-Updates:     1
      Pending iob updates:    2
      Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                              /usr/bin/npm            10.2.3
                              /usr/bin/npx            10.2.3
      Recommended versions are nodejs 18.19.0 and npm 10.2.3
      MEMORY:
      Mem:            4.0G        1.7G        1.6G        1.3M        765M        2.3G
      Swap:           104M          0B        104M
      Total:          4.1G        1.7G        1.7G
      Active iob-Instances:   25
      ioBroker Core:          js-controller           5.0.17
                              admin                   6.12.0
      Objects type: jsonl
      States  type: jsonl
      Objects:                5503
      States:                 4905
      Size of iob-Database:
      5.3M    /opt/iobroker/iobroker-data/states.jsonl
      PI@raspberrypi:~ $ iob logs | grep zigbee
      2024-01-21 16:24:16.091  - debug: zigbee.0 (2837) DeviceAvailability:Publish available for 0xf4b3b1fffef87315 = false
      2024-01-21 16:24:16.105  - debug: zigbee.0 (2837) DeviceAvailability:Publish LQ for 0xf4b3b1fffef87315 = 0
      2024-01-21 16:24:16.109  - debug: zigbee.0 (2837) DeviceAvailability:Publish available for 0xf4b3b1fffef8731e = false
      2024-01-21 16:24:16.122  - debug: zigbee.0 (2837) DeviceAvailability:Publish LQ for 0xf4b3b1fffef8731e = 0
      2024-01-21 16:24:16.127  - debug: zigbee.0 (2837) DeviceAvailability:Publish available for 0xf4b3b1fffef84d2d = false
      2024-01-21 16:24:16.138  - debug: zigbee.0 (2837) DeviceAvailability:Publish LQ for 0xf4b3b1fffef84d2d = 0
      2024-01-21 16:24:16.143  - debug: zigbee.0 (2837) DeviceAvailability:Publish available for 0xf4b3b1fffef87b6a = false
      2024-01-21 16:24:16.148  - debug: zigbee.0 (2837) DeviceAvailability:Publish LQ for 0xf4b3b1fffef87b6a = 0
      2024-01-21 16:24:16.152  - debug: zigbee.0 (2837) DeviceAvailability:Publish available for 0xf4b3b1fffef853ac = false
      2024-01-21 16:24:16.176  - debug: zigbee.0 (2837) DeviceAvailability:Publish LQ for 0xf4b3b1fffef853ac = 0
      2024-01-21 16:24:16.181  - debug: zigbee.0 (2837) DeviceAvailability:Publish available for 0x04cd15fffefe9ca8 = false
      2024-01-21 16:24:16.185  - debug: zigbee.0 (2837) DeviceAvailability:Publish LQ for 0x04cd15fffefe9ca8 = 0
      2024-01-21 16:24:16.191  - debug: zigbee.0 (2837) DeviceAvailability:Publish available for 0xa4c138c66404899e = false
      2024-01-21 16:24:16.198  - debug: zigbee.0 (2837) DeviceAvailability:Publish LQ for 0xa4c138c66404899e = 0
      2024-01-21 16:24:16.215  - info: zigbee.0 (2837) Zigbee: disabling joining new devices.
      2024-01-21 16:24:19.977  - warn: zigbee.0 (2837) Failed to stop zigbee during startup
      2024-01-21 16:24:20.282  - warn: host.raspberrypi instance system.adapter.zigbee.0 terminated due to SIGTERM
      2024-01-21 16:24:20.282  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code null ()
      2024-01-21 16:30:15.740  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1209
      2024-01-21 16:30:22.216  - debug: zigbee.0 (1209) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2024-01-21 16:30:22.270  - debug: zigbee.0 (1209) Objects client ready ... initialize now
      2024-01-21 16:30:22.274  - debug: zigbee.0 (1209) Objects create System PubSub Client
      2024-01-21 16:30:22.275  - debug: zigbee.0 (1209) Objects create User PubSub Client
      2024-01-21 16:30:22.336  - debug: zigbee.0 (1209) Objects client initialize lua scripts
      2024-01-21 16:30:22.348  - debug: zigbee.0 (1209) Objects connected to redis: 127.0.0.1:9001
      2024-01-21 16:30:22.403  - debug: zigbee.0 (1209) Redis States: Use Redis connection: 127.0.0.1:9000
      2024-01-21 16:30:22.433  - debug: zigbee.0 (1209) States create System PubSub Client
      2024-01-21 16:30:22.435  - debug: zigbee.0 (1209) States create User PubSub Client
      2024-01-21 16:30:22.509  - debug: zigbee.0 (1209) States connected to redis: 127.0.0.1:9000
      2024-01-21 16:30:22.575  - debug: zigbee.0 (1209) Plugin sentry Initialize Plugin (enabled=true)
      2024-01-21 16:30:23.292  - info: zigbee.0 (1209) starting. Version 1.9.7 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
      2024-01-21 16:30:23.324  - debug: zigbee.0 (1209) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false},"legacy":false}
      2024-01-21 16:30:23.412  - info: zigbee.0 (1209) delete old Backup files. keep only last 10
      2024-01-21 16:30:23.414  - info: zigbee.0 (1209) Starting Zigbee  npm ...
      2024-01-21 16:30:23.462  - debug: zigbee.0 (1209) Starting zigbee-herdsman...
      2024-01-21 16:30:24.299  - error: zigbee.0 (1209) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00'"
      2024-01-21 16:30:24.300  - error: zigbee.0 (1209) Failed to start Zigbee
      2024-01-21 16:30:24.300  - error: zigbee.0 (1209) Error herdsman start
      2024-01-21 16:30:24.327  - info: zigbee.0 (1209) Installed Version: iobroker.zigbee@1.9.7
      2024-01-21 16:30:24.887  - debug: zigbee.0 (1209) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2024_01_21-16_30_23.tar.gz success
      2024-01-21 16:30:34.304  - info: zigbee.0 (1209) Try to reconnect. 1 attempts left
      2024-01-21 16:30:34.305  - info: zigbee.0 (1209) Starting Zigbee  npm ...
      2024-01-21 16:30:34.311  - debug: zigbee.0 (1209) Starting zigbee-herdsman...
      2024-01-21 16:30:34.321  - error: zigbee.0 (1209) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00'"
      2024-01-21 16:30:34.323  - error: zigbee.0 (1209) Failed to start Zigbee
      2024-01-21 16:30:34.323  - error: zigbee.0 (1209) Error herdsman start
      2024-01-21 16:30:34.332  - info: zigbee.0 (1209) Installed Version: iobroker.zigbee@1.9.7
      PI@raspberrypi:~ $ ^C
        Thomas Braun Most Active @Tapdance 0 last edited by Thomas Braun
        @tapdance-0 sagte in Ziggbe sendet nicht mehr an empfängt aber noch Daten:
        Trag beim Comport ein:
        Bei dir steht der alte Stick noch drin.
        Und bring alles auf Stand.
        sudo apt full-upgrade
        iob update all
          das Update hatte ich doch gestern schon angestoßen. Habe ich gerade noch mal angestoßen.
          Wie ändere ich den Eintrag beim Comport?
          Sorry bin kein kein Linux und Kommandozeilen Typ
          Thomas Braun T 2 Replies Last reply Reply Quote 0
            In den Einstellungen des zigbee-Adapters. Ganz ohne Kommandozeile...
              Tapdance 0 @Tapdance 0 last edited by
              Das kommt wenn ich den update Befehl ausführe.
              PI@raspberrypi:~ $ sudo apt full-upgrade
              iob update all
              Reading package lists... Done
              Building dependency tree... Done
              Calculating upgrade... Done
              The following packages were automatically installed and are no longer required:
                gtk2-engines-clearlookspix libcamera-apps libpisp0.0.1
              Use 'sudo apt autoremove' to remove them.
              The following packages will be upgraded:
                pixflat-icons
              1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
              Need to get 1,120 kB of archives.
              After this operation, 209 kB of additional disk space will be used.
              Do you want to continue? [Y/n] y
              Get:1 http://archive.raspberrypi.com/debian bookworm/main arm64 pixflat-icons all 0.24 [1,120 kB]
              Fetched 1,120 kB in 0s (3,370 kB/s)
              Reading changelogs... Done
              (Reading database ... 155651 files and directories currently installed.)
              Preparing to unpack .../pixflat-icons_0.24_all.deb ...
              Unpacking pixflat-icons (0.24) over (0.23) ...
              Setting up pixflat-icons (0.24) ...
              gtk-update-icon-cache: Cache file created successfully.
              Used repository: all
              Error: unknown repository is active - "all". Known: Beta (latest), Stable (default)
                @tapdance-0
                Vertan.
                iobroker upgrade all
                  Updates müssten jetzt glaube ich alle durch sein. Wie ich den Pfad beim Comport eintrage weiß ich nicht hier die aktuellen Logs noch mal
                  Skript v.2023-10-10
                  *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                  Docker          : false
                  Kernel          : aarch64
                  Userland        : arm64
                   17:06:09 up 6 min,  3 users,  load average: 0.55, 0.84, 0.47
                  CPU threads: 4
                  Current issues:
                                 Local time: Sun 2024-01-21 17:06:09 CET
                             Universal time: Sun 2024-01-21 16:06:09 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  PI
                  /home/PI
                  PI adm dialout cdrom sudo audio video plugdev games users input render netdev lp        admin gpio i2c spi iobroker
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            4.0G        1.7G        1.9G        1.3M        423M        2.3G
                  Swap:           104M          0B        104M
                  Total:          4.1G        1.7G        2.1G
                           3793 M total memory
                           1606 M used memory
                           1636 M active memory
                            170 M inactive memory
                           1858 M free memory
                             40 M buffer memory
                            363 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  Raspberry only:
                  oom events: 0
                  *** FILESYSTEM ***
                  /dev/mmcblk0p2 ext4       28G  7.1G   20G  27% /
                  [Sun Jan 21 16:59:56 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:64:62:CC vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty        1 root=PARTUUID=9515910b-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splas        h plymouth.ignore-serial-consoles
                  [Sun Jan 21 16:59:59 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
                  [Sun Jan 21 17:00:02 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                  `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepag        e=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                  /var:
                  651M    /var/
                  194M    /var/lib
                  185M    /var/cache
                  172M    /var/cache/apt
                  171M    /var/log
                  Archived and active journals take up 169.5M in the file system.
                  373M    /opt/iobroker/iobroker-data/
                  23M     /opt/iobroker/iobroker-data/objects.jsonl
                  7.2M    /opt/iobroker/iobroker-data/states.jsonl
                  USB-Devices by-id:
                  /usr/bin/npm            10.2.3
                  /usr/bin/npx            10.2.3
                  nodejs:
                    Version table:
                       18.13.0+dfsg1-1 500
                  Errors in npm tree:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.12.0
                  javascript:     7.1.6
                  Adapter State
                  + instance is alive
                  Adapter    "telegram"     : 3.0.1    , installed 3.0.1
                  Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
                  Objects and States
                  Objects:        5503
                  States:         4905
                  Pending Updates: 0
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18478      778/sshd: /usr/sbin
                  tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          17466      768/cupsd
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16860      769/iobroker.js-con
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       17647      769/iobroker.js-con
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       17854      1111/io.sonoff.0
                  tcp        0      0 192.168.2.4:2001        0.0.0.0:*               LISTEN      1001       16989      1042/io.hm-rpc.0
                  tcp        0      0 192.168.2.4:2010        0.0.0.0:*               LISTEN      1001       15037      1049/io.hm-rpc.1
                  tcp6       0      0 ::1:631                 :::*                    LISTEN      0          17465      768/cupsd
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          18480      778/sshd: /usr/sbin
                  tcp6       0      0 :::8088                 :::*                    LISTEN      1001       22647      1525/io.terminal.0
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17701      946/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       22866      1945/io.web.0
                  tcp6       0      0 :::38469                :::*                    LISTEN      1001       20981      1983/io.yahka.0
                  udp        0      0 0.0.0.0:44484           0.0.0.0:*                           104        17409      580/avahi-daemon: r
                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       17826      1091/io.shelly.0
                  udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16777      818/cups-browsed
                  udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       17236      1286/io.broadlink2.
                  udp        0      0 0.0.0.0:44173           0.0.0.0:*                           1001       17239      1286/io.broadlink2.
                  udp        0      0 0.0.0.0:56537           0.0.0.0:*                           1001       23299      1286/io.broadlink2.
                  udp        0      0 192.168.2.4:5353        0.0.0.0:*                           1001       19061      1146/io.tr-064.0
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        12287      580/avahi-daemon: r
                  udp6       0      0 :::50851                :::*                                104        17410      580/avahi-daemon: r
                  udp6       0      0 fe80::67d1:e1cb:7ef:546 :::*                                0          17623      706/NetworkManager
                  udp6       0      0 :::5353                 :::*                                104        12288      580/avahi-daemon: r
                  2024-01-21 17:06:49.735  - warn: sonoff.0 (1111) Client [Pool Pumpe] has invalid password or username
                  2024-01-21 17:06:51.462  - warn: sonoff.0 (1111) Client [Muschel Terrasse] has invalid password or username
                  2024-01-21 17:06:52.102  - warn: sonoff.0 (1111) Client [Pavillon Beleuchtung] has invalid password or username
                  2024-01-21 17:06:54.224  - warn: shelly.0 (1091) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-01-21 17:06:54.227  - warn: sonoff.0 (1111) Client [Taster-Schlafzimmer-Bett-L] has invalid password or username
                  2024-01-21 17:06:54.230  - warn: sonoff.0 (1111) Client [Wohnzimmer-Vitrine] has invalid password or username
                  2024-01-21 17:06:54.288  - warn: shelly.0 (1091) [authEnabled] 192.168.2.226 (shellydimmer2 / shellydimmer2-8CAAB54C4E21 / SHDM-2#8CAAB54C4E21#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-01-21 17:06:54.315  - warn: shelly.0 (1091) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-01-21 17:06:56.433  - warn: sonoff.0 (1111) Client [PC-Buero] has invalid password or username
                  2024-01-21 17:07:03.413  - warn: shelly.0 (1091) State value to set for "shelly.0.SHDM-2#8CAAB54C4E21#1.temperatureF" has value "141.05" greater than max "100"
                  2024-01-21 17:07:06.195  - warn: shelly.0 (1091) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-01-21 17:07:06.513  - warn: shelly.0 (1091) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-01-21 17:07:07.480  - warn: shelly.0 (1091) [authEnabled] 192.168.2.226 (shellydimmer2 / shellydimmer2-8CAAB54C4E21 / SHDM-2#8CAAB54C4E21#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-01-21 17:07:14.240  - warn: sonoff.0 (1111) Client [Pool Beleuchtung] has invalid password or username
                  2024-01-21 17:07:15.493  - warn: sonoff.0 (1111) Client [Pool Pumpe] has invalid password or username
                  2024-01-21 17:07:17.252  - warn: sonoff.0 (1111) Client [Muschel Terrasse] has invalid password or username
                  2024-01-21 17:07:17.896  - warn: sonoff.0 (1111) Client [Pavillon Beleuchtung] has invalid password or username
                  2024-01-21 17:07:18.796  - warn: shelly.0 (1091) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-01-21 17:07:20.186  - warn: sonoff.0 (1111) Client [Wohnzimmer-Vitrine] has invalid password or username
                  2024-01-21 17:07:20.188  - warn: sonoff.0 (1111) Client [Taster-Schlafzimmer-Bett-L] has invalid password or username
                  2024-01-21 17:07:20.405  - warn: shelly.0 (1091) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-01-21 17:07:22.524  - warn: sonoff.0 (1111) Client [PC-Buero] has invalid password or username
                  2024-01-21 17:07:26.175  - warn: shelly.0 (1091) [authEnabled] 192.168.2.226 (shellydimmer2 / shellydimmer2-8CAAB54C4E21 / SHDM-2#8CAAB54C4E21#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-01-21 17:07:32.167  - warn: shelly.0 (1091) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-01-21 17:07:33.565  - warn: shelly.0 (1091) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
                  2024-01-21 16:58:32.729  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
                  2024-01-21 16:58:32.736  - info: zigbee.0 (5918) Got terminate signal TERMINATE_YOURSELF
                  2024-01-21 16:58:32.855  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
                  2024-01-21 16:58:33.857  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 killing pid 5918
                  2024-01-21 16:58:35.954  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 6066
                  2024-01-21 16:58:32.738  - info: zigbee.0 (5918) cleaned everything up...
                  2024-01-21 16:58:32.772  - info: zigbee.0 (5918) Zigbee: disabling joining new devices.
                  2024-01-21 16:58:32.773  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d00044d8e0b = false
                  2024-01-21 16:58:32.785  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d00044d8e0b = 0
                  2024-01-21 16:58:32.797  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d000257bae7 = false
                  2024-01-21 16:58:32.810  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d000257bae7 = 0
                  2024-01-21 16:58:32.820  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d00045f7cee = false
                  2024-01-21 16:58:32.825  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d00045f7cee = 0
                  2024-01-21 16:58:32.831  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d0004521481 = false
                  2024-01-21 16:58:32.836  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d0004521481 = 0
                  2024-01-21 16:58:32.843  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d000461b53e = false
                  2024-01-21 16:58:32.849  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d000461b53e = 0
                  2024-01-21 16:58:32.855  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x680ae2fffec91ea4 = false
                  2024-01-21 16:58:32.860  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x680ae2fffec91ea4 = 0
                  2024-01-21 16:58:32.867  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x588e81fffe2b8762 = false
                  2024-01-21 16:58:32.873  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x588e81fffe2b8762 = 0
                  2024-01-21 16:58:32.880  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x680ae2fffe924d57 = false
                  2024-01-21 16:58:32.885  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x680ae2fffe924d57 = 0
                  2024-01-21 16:58:32.892  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d00045eb708 = false
                  2024-01-21 16:58:32.897  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d00045eb708 = 0
                  2024-01-21 16:58:32.905  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d0002a71e25 = false
                  2024-01-21 16:58:32.909  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d0002a71e25 = 0
                  2024-01-21 16:58:32.915  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x04cf8cdf3c794764 = false
                  2024-01-21 16:58:32.919  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x04cf8cdf3c794764 = 0
                  2024-01-21 16:58:32.925  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x04cf8cdf3c7946a1 = false
                  2024-01-21 16:58:32.929  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7946a1 = 0
                  2024-01-21 16:58:32.933  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d00045f8d3d = false
                  2024-01-21 16:58:32.938  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d00045f8d3d = 0
                  2024-01-21 16:58:32.943  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d0004597653 = false
                  2024-01-21 16:58:32.947  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d0004597653 = 0
                  2024-01-21 16:58:32.952  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x842e14fffe768d41 = false
                  2024-01-21 16:58:32.956  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x842e14fffe768d41 = 0
                  2024-01-21 16:58:32.962  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0xbc33acfffe2ab392 = false
                  2024-01-21 16:58:32.965  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0xbc33acfffe2ab392 = 0
                  2024-01-21 16:58:32.970  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x04cf8cdf3c7b5255 = false
                  2024-01-21 16:58:32.974  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b5255 = 0
                  2024-01-21 16:58:32.980  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x04cf8cdf3c7b51f7 = false
                  2024-01-21 16:58:32.985  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b51f7 = 0
                  2024-01-21 16:58:32.990  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x04cf8cdf3c78b7ba = false
                  2024-01-21 16:58:32.993  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x04cf8cdf3c78b7ba = 0
                  2024-01-21 16:58:32.998  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x00158d000461da61 = false
                  2024-01-21 16:58:33.001  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x00158d000461da61 = 0
                  2024-01-21 16:58:33.005  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0xf4b3b1fffef87315 = false
                  2024-01-21 16:58:33.008  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0xf4b3b1fffef87315 = 0
                  2024-01-21 16:58:33.012  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0xf4b3b1fffef8731e = false
                  2024-01-21 16:58:33.016  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0xf4b3b1fffef8731e = 0
                  2024-01-21 16:58:33.019  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0xf4b3b1fffef84d2d = false
                  2024-01-21 16:58:33.022  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0xf4b3b1fffef84d2d = 0
                  2024-01-21 16:58:33.027  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0xf4b3b1fffef87b6a = false
                  2024-01-21 16:58:33.030  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0xf4b3b1fffef87b6a = 0
                  2024-01-21 16:58:33.033  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0xf4b3b1fffef853ac = false
                  2024-01-21 16:58:33.036  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0xf4b3b1fffef853ac = 0
                  2024-01-21 16:58:33.040  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0x04cd15fffefe9ca8 = false
                  2024-01-21 16:58:33.043  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0x04cd15fffefe9ca8 = 0
                  2024-01-21 16:58:33.046  - debug: zigbee.0 (5918) DeviceAvailability:Publish available for 0xa4c138c66404899e = false
                  2024-01-21 16:58:33.049  - debug: zigbee.0 (5918) DeviceAvailability:Publish LQ for 0xa4c138c66404899e = 0
                  2024-01-21 16:58:39.403  - warn: zigbee.0 (5918) Failed to stop zigbee during startup
                  2024-01-21 16:58:39.405  - info: zigbee.0 (5918) terminating
                  2024-01-21 16:58:39.408  - debug: zigbee.0 (5918) Plugin sentry destroyed
                  2024-01-21 16:58:39.409  - info: zigbee.0 (5918) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2024-01-21 16:58:39.412  - info: zigbee.0 (5918) terminating
                  2024-01-21 16:58:39.502  - warn: zigbee.0 (5918) Got terminate signal. Checking desired PID: 0 vs own PID 5918
                  2024-01-21 16:58:39.504  - warn: zigbee.0 (5918) Got terminate signal. Checking desired PID: 6066 vs own PID 5918
                  2024-01-21 16:58:39.560  - info: zigbee.0 (5918) debug devices set to []
                  2024-01-21 16:58:40.065  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                  2024-01-21 16:58:40.065  - info: host.raspberrypi Do not restart adapter system.adapter.zigbee.0 because desired by instance
                  2024-01-21 16:58:40.406  - debug: zigbee.0 (6066) Redis Objects: Use Redis connection: 127.0.0.1:9001
                  2024-01-21 16:58:40.452  - debug: zigbee.0 (6066) Objects client ready ... initialize now
                  2024-01-21 16:58:40.455  - debug: zigbee.0 (6066) Objects create System PubSub Client
                  2024-01-21 16:58:40.457  - debug: zigbee.0 (6066) Objects create User PubSub Client
                  2024-01-21 16:58:40.538  - debug: zigbee.0 (6066) Objects client initialize lua scripts
                  2024-01-21 16:58:40.549  - debug: zigbee.0 (6066) Objects connected to redis: 127.0.0.1:9001
                  2024-01-21 16:58:40.596  - debug: zigbee.0 (6066) Redis States: Use Redis connection: 127.0.0.1:9000
                  2024-01-21 16:58:40.616  - debug: zigbee.0 (6066) States create System PubSub Client
                  2024-01-21 16:58:40.617  - debug: zigbee.0 (6066) States create User PubSub Client
                  2024-01-21 16:58:40.688  - debug: zigbee.0 (6066) States connected to redis: 127.0.0.1:9000
                  2024-01-21 16:58:40.742  - debug: zigbee.0 (6066) Plugin sentry Initialize Plugin (enabled=true)
                  2024-01-21 16:58:41.361  - info: zigbee.0 (6066) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
                  2024-01-21 16:58:41.396  - debug: zigbee.0 (6066) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false},"legacy":false}
                  2024-01-21 16:58:41.477  - info: zigbee.0 (6066) delete old Backup files. keep only last 10
                  2024-01-21 16:58:41.480  - info: zigbee.0 (6066) Starting Zigbee  npm ...
                  2024-01-21 16:58:41.526  - debug: zigbee.0 (6066) Starting zigbee-herdsman...
                  2024-01-21 16:58:41.876  - error: zigbee.0 (6066) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00'"
                  2024-01-21 16:58:41.877  - error: zigbee.0 (6066) Failed to start Zigbee
                  2024-01-21 16:58:41.877  - error: zigbee.0 (6066) Error herdsman start
                  2024-01-21 16:58:41.881  - info: zigbee.0 (6066) Installed Version: iobroker.zigbee@1.10.1
                  2024-01-21 16:58:42.387  - debug: zigbee.0 (6066) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2024_01_21-16_58_41.tar.gz success
                  2024-01-21 16:58:51.881  - info: zigbee.0 (6066) Try to reconnect. 1 attempts left
                  2024-01-21 16:58:51.882  - info: zigbee.0 (6066) Starting Zigbee  npm ...
                  2024-01-21 16:58:51.887  - debug: zigbee.0 (6066) Starting zigbee-herdsman...
                  2024-01-21 16:58:51.898  - error: zigbee.0 (6066) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00'"
                  2024-01-21 16:58:51.899  - error: zigbee.0 (6066) Failed to start Zigbee
                  2024-01-21 16:58:51.899  - error: zigbee.0 (6066) Error herdsman start
                  2024-01-21 16:58:51.907  - info: zigbee.0 (6066) Installed Version: iobroker.zigbee@1.10.1
                  2024-01-21 16:59:25.780  - info: zigbee.0 (6066) cleaned everything up...
                  2024-01-21 16:59:25.828  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=false)
                  2024-01-21 16:59:25.876  - info: zigbee.0 (6066) Zigbee: disabling joining new devices.
                  2024-01-21 16:59:25.877  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d00044d8e0b = false
                  2024-01-21 16:59:25.893  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d00044d8e0b = 0
                  2024-01-21 16:59:25.905  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d000257bae7 = false
                  2024-01-21 16:59:25.916  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d000257bae7 = 0
                  2024-01-21 16:59:25.928  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d00045f7cee = false
                  2024-01-21 16:59:25.934  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d00045f7cee = 0
                  2024-01-21 16:59:25.964  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d0004521481 = false
                  2024-01-21 16:59:25.968  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d0004521481 = 0
                  2024-01-21 16:59:25.974  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d000461b53e = false
                  2024-01-21 16:59:25.979  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d000461b53e = 0
                  2024-01-21 16:59:25.993  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x680ae2fffec91ea4 = false
                  2024-01-21 16:59:26.015  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x680ae2fffec91ea4 = 0
                  2024-01-21 16:59:26.024  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x588e81fffe2b8762 = false
                  2024-01-21 16:59:26.030  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x588e81fffe2b8762 = 0
                  2024-01-21 16:59:26.038  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x680ae2fffe924d57 = false
                  2024-01-21 16:59:26.044  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x680ae2fffe924d57 = 0
                  2024-01-21 16:59:26.063  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d00045eb708 = false
                  2024-01-21 16:59:26.071  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d00045eb708 = 0
                  2024-01-21 16:59:26.077  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d0002a71e25 = false
                  2024-01-21 16:59:26.082  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d0002a71e25 = 0
                  2024-01-21 16:59:26.088  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x04cf8cdf3c794764 = false
                  2024-01-21 16:59:26.092  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x04cf8cdf3c794764 = 0
                  2024-01-21 16:59:26.096  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x04cf8cdf3c7946a1 = false
                  2024-01-21 16:59:26.103  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7946a1 = 0
                  2024-01-21 16:59:26.109  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d00045f8d3d = false
                  2024-01-21 16:59:26.112  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d00045f8d3d = 0
                  2024-01-21 16:59:26.125  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d0004597653 = false
                  2024-01-21 16:59:26.129  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d0004597653 = 0
                  2024-01-21 16:59:26.134  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x842e14fffe768d41 = false
                  2024-01-21 16:59:26.139  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x842e14fffe768d41 = 0
                  2024-01-21 16:59:26.144  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0xbc33acfffe2ab392 = false
                  2024-01-21 16:59:26.147  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0xbc33acfffe2ab392 = 0
                  2024-01-21 16:59:26.155  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x04cf8cdf3c7b5255 = false
                  2024-01-21 16:59:26.161  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b5255 = 0
                  2024-01-21 16:59:26.167  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x04cf8cdf3c7b51f7 = false
                  2024-01-21 16:59:26.173  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b51f7 = 0
                  2024-01-21 16:59:26.182  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x04cf8cdf3c78b7ba = false
                  2024-01-21 16:59:26.186  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x04cf8cdf3c78b7ba = 0
                  2024-01-21 16:59:26.197  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x00158d000461da61 = false
                  2024-01-21 16:59:26.201  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x00158d000461da61 = 0
                  2024-01-21 16:59:26.206  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0xf4b3b1fffef87315 = false
                  2024-01-21 16:59:26.211  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0xf4b3b1fffef87315 = 0
                  2024-01-21 16:59:26.216  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0xf4b3b1fffef8731e = false
                  2024-01-21 16:59:26.220  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0xf4b3b1fffef8731e = 0
                  2024-01-21 16:59:26.225  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0xf4b3b1fffef84d2d = false
                  2024-01-21 16:59:26.229  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0xf4b3b1fffef84d2d = 0
                  2024-01-21 16:59:26.234  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0xf4b3b1fffef87b6a = false
                  2024-01-21 16:59:26.238  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0xf4b3b1fffef87b6a = 0
                  2024-01-21 16:59:26.246  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0xf4b3b1fffef853ac = false
                  2024-01-21 16:59:26.249  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0xf4b3b1fffef853ac = 0
                  2024-01-21 16:59:26.257  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0x04cd15fffefe9ca8 = false
                  2024-01-21 16:59:26.261  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0x04cd15fffefe9ca8 = 0
                  2024-01-21 16:59:26.268  - debug: zigbee.0 (6066) DeviceAvailability:Publish available for 0xa4c138c66404899e = false
                  2024-01-21 16:59:26.271  - debug: zigbee.0 (6066) DeviceAvailability:Publish LQ for 0xa4c138c66404899e = 0
                  2024-01-21 16:59:31.550  - warn: zigbee.0 (6066) Failed to stop zigbee during startup
                  2024-01-21 16:59:31.682  - error: zigbee.0 (6066) Objects database error: write EPIPE
                  2024-01-21 16:59:31.751  - info: zigbee.0 (6066) terminating
                  2024-01-21 16:59:31.752  - debug: zigbee.0 (6066) Plugin sentry destroyed
                  2024-01-21 16:59:31.753  - info: zigbee.0 (6066) Terminated (NO_ERROR): Without reason
                  2024-01-21 16:59:31.753  - info: zigbee.0 (6066) terminating
                  2024-01-21 16:59:32.687  - info: zigbee.0 (6066) terminating with timeout
                  2024-01-21 17:01:20.456  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1190
                  2024-01-21 17:01:27.027  - debug: zigbee.0 (1190) Redis Objects: Use Redis connection: 127.0.0.1:9001
                  2024-01-21 17:01:27.080  - debug: zigbee.0 (1190) Objects client ready ... initialize now
                  2024-01-21 17:01:27.084  - debug: zigbee.0 (1190) Objects create System PubSub Client
                  2024-01-21 17:01:27.086  - debug: zigbee.0 (1190) Objects create User PubSub Client
                  2024-01-21 17:01:27.162  - debug: zigbee.0 (1190) Objects client initialize lua scripts
                  2024-01-21 17:01:27.176  - debug: zigbee.0 (1190) Objects connected to redis: 127.0.0.1:9001
                  2024-01-21 17:01:27.225  - debug: zigbee.0 (1190) Redis States: Use Redis connection: 127.0.0.1:9000
                  2024-01-21 17:01:27.247  - debug: zigbee.0 (1190) States create System PubSub Client
                  2024-01-21 17:01:27.248  - debug: zigbee.0 (1190) States create User PubSub Client
                  2024-01-21 17:01:27.339  - debug: zigbee.0 (1190) States connected to redis: 127.0.0.1:9000
                  2024-01-21 17:01:27.397  - debug: zigbee.0 (1190) Plugin sentry Initialize Plugin (enabled=true)
                  2024-01-21 17:01:28.242  - info: zigbee.0 (1190) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
                  2024-01-21 17:01:28.283  - debug: zigbee.0 (1190) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false},"legacy":false}
                  2024-01-21 17:01:28.387  - info: zigbee.0 (1190) delete old Backup files. keep only last 10
                  2024-01-21 17:01:28.390  - info: zigbee.0 (1190) Starting Zigbee  npm ...
                  2024-01-21 17:01:28.468  - debug: zigbee.0 (1190) Starting zigbee-herdsman...
                  2024-01-21 17:01:29.117  - error: zigbee.0 (1190) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00'"
                  2024-01-21 17:01:29.118  - error: zigbee.0 (1190) Failed to start Zigbee
                  2024-01-21 17:01:29.118  - error: zigbee.0 (1190) Error herdsman start
                  2024-01-21 17:01:29.123  - info: zigbee.0 (1190) Installed Version: iobroker.zigbee@1.10.1
                  2024-01-21 17:01:29.643  - debug: zigbee.0 (1190) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2024_01_21-17_01_28.tar.gz success
                  2024-01-21 17:01:39.122  - info: zigbee.0 (1190) Try to reconnect. 1 attempts left
                  2024-01-21 17:01:39.123  - info: zigbee.0 (1190) Starting Zigbee  npm ...
                  2024-01-21 17:01:39.128  - debug: zigbee.0 (1190) Starting zigbee-herdsman...
                  2024-01-21 17:01:39.139  - error: zigbee.0 (1190) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00'"
                  2024-01-21 17:01:39.140  - error: zigbee.0 (1190) Failed to start Zigbee
                  2024-01-21 17:01:39.141  - error: zigbee.0 (1190) Error herdsman start
                  2024-01-21 17:01:39.149  - info: zigbee.0 (1190) Installed Version: iobroker.zigbee@1.10.1
                  2024-01-21 17:04:17.656  - error: zigbee.0 (1190) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                  2024-01-21 17:04:18.043  - info: zigbee.0 (1190) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"8eb6f719a99ded11ad35dca5a7669f5d","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_8eb6f719a99ded11ad35dca5a7669f5d-if00-port0","vendorId":"10c4","productId":"ea60"}]
                    Da:
                    das eintragen:
                      geht leider nicht da der Adapter nicht startet.
                      Bekomme immer folgende Meldung wenn ich darauf gehe.
                      You need save and run adapter before pairing!
                      T Asgothian 2 Replies Last reply Reply Quote 0
                        @tapdance-0
                        starte das System noch mal komplett neu mit
                        sudo reboot
                        • Asgothian
                          Asgothian Developer @Tapdance 0 last edited by
                          Das ist normal. Du solltest trotzdem auf die Seite zum konfigurieren kommen um da Einstellungen zu machen.
                          A.
                            Tapdance 0 @Asgothian last edited by
                            @asgothian
                            leider nicht
                              @tapdance-0
                              Neustart hat auch nichts gebracht
                              2024-01-21 17:16:30.300  - error: zigbee.0 (1190) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                              2024-01-21 17:16:30.544  - info: zigbee.0 (1190) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"8eb6f719a99ded11ad35dca5a7669f5d","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_8eb6f719a99ded11ad35dca5a7669f5d-if00-port0","vendorId":"10c4","productId":"ea60"}]
                              2024-01-21 17:16:55.971  - error: zigbee.0 (1190) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                              2024-01-21 17:16:56.206  - info: zigbee.0 (1190) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"8eb6f719a99ded11ad35dca5a7669f5d","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_8eb6f719a99ded11ad35dca5a7669f5d-if00-port0","vendorId":"10c4","productId":"ea60"}]
                              2024-01-21 17:18:59.211  - info: zigbee.0 (1190) cleaned everything up...
                              2024-01-21 17:18:59.251  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
                              2024-01-21 17:18:59.762  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
                              2024-01-21 17:19:00.770  - info: host.raspberrypi stopInstance system.adapter.zigbee.0 killing pid 1190
                              2024-01-21 17:18:59.315  - info: zigbee.0 (1190) Zigbee: disabling joining new devices.
                              2024-01-21 17:18:59.317  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d00044d8e0b = false
                              2024-01-21 17:18:59.332  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d00044d8e0b = 0
                              2024-01-21 17:18:59.344  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d000257bae7 = false
                              2024-01-21 17:18:59.360  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d000257bae7 = 0
                              2024-01-21 17:18:59.382  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d00045f7cee = false
                              2024-01-21 17:18:59.386  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d00045f7cee = 0
                              2024-01-21 17:18:59.392  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d0004521481 = false
                              2024-01-21 17:18:59.396  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d0004521481 = 0
                              2024-01-21 17:18:59.411  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d000461b53e = false
                              2024-01-21 17:18:59.429  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d000461b53e = 0
                              2024-01-21 17:18:59.435  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x680ae2fffec91ea4 = false
                              2024-01-21 17:18:59.438  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x680ae2fffec91ea4 = 0
                              2024-01-21 17:18:59.444  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x588e81fffe2b8762 = false
                              2024-01-21 17:18:59.455  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x588e81fffe2b8762 = 0
                              2024-01-21 17:18:59.463  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x680ae2fffe924d57 = false
                              2024-01-21 17:18:59.467  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x680ae2fffe924d57 = 0
                              2024-01-21 17:18:59.474  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d00045eb708 = false
                              2024-01-21 17:18:59.479  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d00045eb708 = 0
                              2024-01-21 17:18:59.490  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d0002a71e25 = false
                              2024-01-21 17:18:59.494  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d0002a71e25 = 0
                              2024-01-21 17:18:59.499  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x04cf8cdf3c794764 = false
                              2024-01-21 17:18:59.502  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x04cf8cdf3c794764 = 0
                              2024-01-21 17:18:59.507  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x04cf8cdf3c7946a1 = false
                              2024-01-21 17:18:59.510  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7946a1 = 0
                              2024-01-21 17:18:59.515  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d00045f8d3d = false
                              2024-01-21 17:18:59.518  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d00045f8d3d = 0
                              2024-01-21 17:18:59.523  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d0004597653 = false
                              2024-01-21 17:18:59.528  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d0004597653 = 0
                              2024-01-21 17:18:59.539  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x842e14fffe768d41 = false
                              2024-01-21 17:18:59.542  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x842e14fffe768d41 = 0
                              2024-01-21 17:18:59.549  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0xbc33acfffe2ab392 = false
                              2024-01-21 17:18:59.555  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0xbc33acfffe2ab392 = 0
                              2024-01-21 17:18:59.562  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x04cf8cdf3c7b5255 = false
                              2024-01-21 17:18:59.565  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b5255 = 0
                              2024-01-21 17:18:59.570  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x04cf8cdf3c7b51f7 = false
                              2024-01-21 17:18:59.574  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b51f7 = 0
                              2024-01-21 17:18:59.579  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x04cf8cdf3c78b7ba = false
                              2024-01-21 17:18:59.583  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x04cf8cdf3c78b7ba = 0
                              2024-01-21 17:18:59.588  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x00158d000461da61 = false
                              2024-01-21 17:18:59.591  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x00158d000461da61 = 0
                              2024-01-21 17:18:59.595  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0xf4b3b1fffef87315 = false
                              2024-01-21 17:18:59.599  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0xf4b3b1fffef87315 = 0
                              2024-01-21 17:18:59.604  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0xf4b3b1fffef8731e = false
                              2024-01-21 17:18:59.608  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0xf4b3b1fffef8731e = 0
                              2024-01-21 17:18:59.613  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0xf4b3b1fffef84d2d = false
                              2024-01-21 17:18:59.623  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0xf4b3b1fffef84d2d = 0
                              2024-01-21 17:18:59.637  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0xf4b3b1fffef87b6a = false
                              2024-01-21 17:18:59.652  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0xf4b3b1fffef87b6a = 0
                              2024-01-21 17:18:59.655  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0xf4b3b1fffef853ac = false
                              2024-01-21 17:18:59.670  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0xf4b3b1fffef853ac = 0
                              2024-01-21 17:18:59.689  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0x04cd15fffefe9ca8 = false
                              2024-01-21 17:18:59.692  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0x04cd15fffefe9ca8 = 0
                              2024-01-21 17:18:59.696  - debug: zigbee.0 (1190) DeviceAvailability:Publish available for 0xa4c138c66404899e = false
                              2024-01-21 17:18:59.700  - debug: zigbee.0 (1190) DeviceAvailability:Publish LQ for 0xa4c138c66404899e = 0
                              2024-01-21 17:19:03.382  - warn: zigbee.0 (1190) Failed to stop zigbee during startup
                              2024-01-21 17:19:03.714  - warn: host.raspberrypi instance system.adapter.zigbee.0 terminated due to SIGTERM
                              2024-01-21 17:19:03.714  - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code null ()
                              2024-01-21 17:20:50.131  - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1208
                              2024-01-21 17:20:57.122  - debug: zigbee.0 (1208) Redis Objects: Use Redis connection: 127.0.0.1:9001
                              2024-01-21 17:20:57.175  - debug: zigbee.0 (1208) Objects client ready ... initialize now
                              2024-01-21 17:20:57.178  - debug: zigbee.0 (1208) Objects create System PubSub Client
                              2024-01-21 17:20:57.179  - debug: zigbee.0 (1208) Objects create User PubSub Client
                              2024-01-21 17:20:57.241  - debug: zigbee.0 (1208) Objects client initialize lua scripts
                              2024-01-21 17:20:57.260  - debug: zigbee.0 (1208) Objects connected to redis: 127.0.0.1:9001
                              2024-01-21 17:20:57.320  - debug: zigbee.0 (1208) Redis States: Use Redis connection: 127.0.0.1:9000
                              2024-01-21 17:20:57.346  - debug: zigbee.0 (1208) States create System PubSub Client
                              2024-01-21 17:20:57.348  - debug: zigbee.0 (1208) States create User PubSub Client
                              2024-01-21 17:20:57.441  - debug: zigbee.0 (1208) States connected to redis: 127.0.0.1:9000
                              2024-01-21 17:20:57.535  - debug: zigbee.0 (1208) Plugin sentry Initialize Plugin (enabled=true)
                              2024-01-21 17:20:58.509  - info: zigbee.0 (1208) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
                              2024-01-21 17:20:58.553  - debug: zigbee.0 (1208) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false},"legacy":false}
                              2024-01-21 17:20:58.661  - info: zigbee.0 (1208) delete old Backup files. keep only last 10
                              2024-01-21 17:20:58.663  - info: zigbee.0 (1208) Starting Zigbee  npm ...
                              2024-01-21 17:20:58.724  - debug: zigbee.0 (1208) Starting zigbee-herdsman...
                              2024-01-21 17:21:00.498  - error: zigbee.0 (1208) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00'"
                              2024-01-21 17:21:00.499  - error: zigbee.0 (1208) Failed to start Zigbee
                              2024-01-21 17:21:00.499  - error: zigbee.0 (1208) Error herdsman start
                              2024-01-21 17:21:00.507  - info: zigbee.0 (1208) Installed Version: iobroker.zigbee@1.10.1
                              2024-01-21 17:21:01.087  - debug: zigbee.0 (1208) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2024_01_21-17_20_58.tar.gz success
                              2024-01-21 17:21:10.505  - info: zigbee.0 (1208) Try to reconnect. 1 attempts left
                              2024-01-21 17:21:10.506  - info: zigbee.0 (1208) Starting Zigbee  npm ...
                              2024-01-21 17:21:10.512  - debug: zigbee.0 (1208) Starting zigbee-herdsman...
                              2024-01-21 17:21:10.524  - error: zigbee.0 (1208) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E2F56A-if00'"
                              2024-01-21 17:21:10.525  - error: zigbee.0 (1208) Failed to start Zigbee
                              2024-01-21 17:21:10.526  - error: zigbee.0 (1208) Error herdsman start
                              2024-01-21 17:21:10.535  - info: zigbee.0 (1208) Installed Version: iobroker.zigbee@1.10.1
                              2024-01-21 17:25:54.886  - error: zigbee.0 (1208) getGroups: caught error: TypeError: Cannot read properties of undefined (reading 'getGroups')
                              2024-01-21 17:25:55.156  - info: zigbee.0 (1208) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"8eb6f719a99ded11ad35dca5a7669f5d","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_8eb6f719a99ded11ad35dca5a7669f5d-if00-port0","vendorId":"10c4","productId":"ea60"}]
                                Du hast da immer noch den alten Stick in den Einstellungen. Das muss durch den aktuellen Link ersetzt werden.
                                Edit:
                                Okay, hier scheint es nun drin zu sein:
                                  Tapdance 0 @Thomas Braun last edited by
                                  habe den Punkt zum eintragen des Pfades gefunden. Der wird nur angezeigt wenn man über die Instanz in Menü geht. Pfad ist eingetragen Adapter ist grün, aber leider funktioniert noch nichts.
                                  Skript v.2023-10-10
                                  *** BASE SYSTEM ***
                                   Static hostname: raspberrypi
                                         Icon name: computer
                                            Kernel: Linux 6.1.0-rpi7-rpi-v8
                                      Architecture: arm64
                                  Model           : Raspberry Pi 4 Model B Rev 1.1
                                  Docker          : false
                                  Virtualization  : none
                                  Kernel          : aarch64
                                  Userland        : arm64
                                  Systemuptime and Load:
                                   17:39:43 up 6 min,  3 users,  load average: 0.52, 0.90, 0.57
                                  CPU threads: 4
                                  *** RASPBERRY THROTTLING ***
                                  Current issues:
                                  Previously detected issues:
                                  *** Time and Time Zones ***
                                                 Local time: Sun 2024-01-21 17:39:43 CET
                                             Universal time: Sun 2024-01-21 16:39:43 UTC
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  *** User and Groups ***
                                  PI
                                  /home/PI
                                  PI adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                                  *** X-Server-Setup ***
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  Boot Target:    multi-user.target
                                  *** MEMORY ***
                                  Mem:            4.0G        1.6G        2.0G        1.3M        420M        2.3G
                                  Swap:           104M          0B        104M
                                  Total:          4.1G        1.6G        2.1G
                                           3793 M total memory
                                           1571 M used memory
                                           1603 M active memory
                                            166 M inactive memory
                                           1897 M free memory
                                             40 M buffer memory
                                            359 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FAILED SERVICES ***
                                  0 loaded units listed.
                                  *** FILESYSTEM ***
                                  udev           devtmpfs  1.6G     0  1.6G   0% /dev
                                  tmpfs          tmpfs     380M  1.2M  379M   1% /run
                                  tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
                                  /dev/mmcblk0p1 vfat      510M   73M  438M  15% /boot/firmware
                                  tmpfs          tmpfs     380M   32K  380M   1% /run/user/1000
                                  [Sun Jan 21 17:32:52 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:64:62:CC vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9515910b-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                  [Sun Jan 21 17:32:56 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                  [Sun Jan 21 17:32:59 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                  TARGET           SOURCE         FSTYPE OPTIONS
                                  /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
                                  `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                  /var:
                                  667M    /var/
                                  194M    /var/lib
                                  187M    /var/log
                                  186M    /var/log/journal/67fa5cc7176343b98d5ef1e5e5a27de6
                                  Archived and active journals take up 185.5M in the file system.
                                  /opt/iobroker/backups:
                                  4.0K    /opt/iobroker/backups/
                                  /opt/iobroker/iobroker-data:
                                  368M    /opt/iobroker/iobroker-data/
                                  270M    /opt/iobroker/iobroker-data/files
                                  78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                                  73M     /opt/iobroker/iobroker-data/backup-objects
                                  67M     /opt/iobroker/iobroker-data/files/javascript.admin
                                  24M     /opt/iobroker/iobroker-data/objects.jsonl
                                  21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                                  8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
                                  7.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/691.26ff76ce.chunk.js.map
                                  7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.d3cce782.chunk.js.map
                                  USB-Devices by-id:
                                  /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_8eb6f719a99ded11ad35dca5a7669f5d-if00-port0
                                  *** NodeJS-Installation ***
                                  /usr/bin/node           v18.19.0
                                  /usr/bin/npm            10.2.3
                                  /usr/bin/npx            10.2.3
                                  /usr/bin/corepack       0.22.0
                                  nodejs:
                                    Installed: 18.19.0-1nodesource1
                                    Candidate: 18.19.0-1nodesource1
                                    Version table:
                                       18.19.0+dfsg-6~deb12u1 500
                                   *** 18.19.0-1nodesource1 1001
                                          100 /var/lib/dpkg/status
                                       18.18.2-1nodesource1 1001
                                       18.18.1-1nodesource1 1001
                                       18.18.0-1nodesource1 1001
                                       18.17.1-1nodesource1 1001
                                       18.17.0-1nodesource1 1001
                                       18.16.1-1nodesource1 1001
                                       18.16.0-1nodesource1 1001
                                       18.15.0-1nodesource1 1001
                                       18.14.2-1nodesource1 1001
                                       18.14.1-1nodesource1 1001
                                       18.14.0-1nodesource1 1001
                                       18.13.0+dfsg1-1 500
                                       18.13.0-1nodesource1 1001
                                       18.12.0-1nodesource1 1001
                                       18.11.0-1nodesource1 1001
                                       18.10.0-1nodesource1 1001
                                       18.9.1-1nodesource1 1001
                                       18.9.0-1nodesource1 1001
                                       18.8.0-1nodesource1 1001
                                       18.7.0-1nodesource1 1001
                                       18.6.0-1nodesource1 1001
                                       18.5.0-1nodesource1 1001
                                       18.4.0-1nodesource1 1001
                                       18.3.0-1nodesource1 1001
                                       18.2.0-1nodesource1 1001
                                       18.1.0-1nodesource1 1001
                                       18.0.0-1nodesource1 1001
                                  No problems detected
                                  Errors in npm tree:
                                  *** ioBroker-Installation ***
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Core adapters versions
                                  admin:          6.12.0
                                  javascript:     7.1.6
                                  Adapters from github:   0
                                  Adapter State
                                  + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                  + system.adapter.alarm.0                  : alarm                 : raspberrypi                              -  enabled
                                  + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                  + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
                                  + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
                                  + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                                  + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                                  + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
                                  + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                                  + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                                    system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
                                    system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
                                    system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
                                  + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                                  + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                                    system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
                                  + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                                  + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled
                                  + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                                  + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                                  + system.adapter.synology.0               : synology              : raspberrypi                              -  enabled, port: 5000
                                  + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
                                  + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 192.168.2.4, run as: admin
                                  + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                                    system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
                                    system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
                                    system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
                                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                                    system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                                    system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
                                    system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                                  + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                  + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
                                  + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
                                  + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
                                  + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_8eb6f719a99ded11ad35dca5a7669f5d-if00-port0
                                  + instance is alive
                                  ioBroker-Repositories
                                  Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                                  Stable (default): http://download.iobroker.net/sources-dist.json
                                  Active repo(s): Stable (default)
                                  Installed ioBroker-Instances
                                  Used repository: Stable (default)
                                  Adapter    "admin"        : 6.12.0   , installed 6.12.0
                                  Adapter    "alarm"        : 3.6.0    , installed 3.6.0
                                  Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                                  Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
                                  Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                                  Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                                  Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                                  Controller "js-controller": 5.0.17   , installed 5.0.17
                                  Adapter    "mobile"       : 1.0.1    , installed 1.0.1
                                  Adapter    "sayit"        : 3.0.5    , installed 3.0.5
                                  Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                                  Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                                  Adapter    "synology"     : 3.0.1    , installed 3.0.1
                                  Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                                  Adapter    "web"          : 6.1.10   , installed 6.1.10
                                  Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                                  Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
                                  Adapter    "ws"           : 2.5.8    , installed 2.5.8
                                  Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                                  Objects and States
                                  Objects:        5503
                                  States:         4905
                                  Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                                  Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                                  Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                                  Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                                  Pending Updates: 0
                                  *** Listening Ports ***
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12153      804/sshd: /usr/sbin
                                  tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16485      794/cupsd
                                  tcp        0      0 192.168.2.4:2001        0.0.0.0:*               LISTEN      1001       19586      1091/io.hm-rpc.0
                                  tcp        0      0 192.168.2.4:2010        0.0.0.0:*               LISTEN      1001       16840      1092/io.hm-rpc.1
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16343      795/iobroker.js-con
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18476      795/iobroker.js-con
                                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       18056      1150/io.sonoff.0
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          12155      804/sshd: /usr/sbin
                                  tcp6       0      0 :::39615                :::*                    LISTEN      1001       19369      1962/io.yahka.0
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20340      1882/io.web.0
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17851      969/io.admin.0
                                  tcp6       0      0 :::8088                 :::*                    LISTEN      1001       17327      1565/io.terminal.0
                                  tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16484      794/cupsd
                                  udp        0      0 0.0.0.0:36784           0.0.0.0:*                           104        16424      573/avahi-daemon: r
                                  udp        0      0 0.0.0.0:34788           0.0.0.0:*                           1001       20998      1325/io.broadlink2.
                                  udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16262      844/cups-browsed
                                  udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       20995      1325/io.broadlink2.
                                  udp        0      0 0.0.0.0:58383           0.0.0.0:*                           1001       22993      1325/io.broadlink2.
                                  udp        0      0 192.168.2.4:5353        0.0.0.0:*                           1001       18718      1181/io.tr-064.0
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        16422      573/avahi-daemon: r
                                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       18034      1116/io.shelly.0
                                  udp6       0      0 fe80::67d1:e1cb:7ef:546 :::*                                0          12279      733/NetworkManager
                                  udp6       0      0 :::50277                :::*                                104        16425      573/avahi-daemon: r
                                  udp6       0      0 :::5353                 :::*                                104        16423      573/avahi-daemon: r
                                  2024-01-21 17:40:28.300  - debug: zigbee.0 (1229) DeviceAvailability:Non-pingable device 0x00158d000461da61 lumi.sensor_magnet was last seen '34744106.67' seconds ago.
                                  2024-01-21 17:40:28.329  - debug: zigbee.0 (1229) DeviceAvailability:Non-pingable device 0x04cd15fffefe9ca8 ZBMINIL2 was last seen '5227.093' seconds ago.
                                  2024-01-21 17:40:28.907  - warn: shelly.0 (1116) [authEnabled] 192.168.2.226 (shellydimmer2 / shellydimmer2-8CAAB54C4E21 / SHDM-2#8CAAB54C4E21#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2024-01-21 17:40:37.805  - warn: sonoff.0 (1150) Client [Pavillon Beleuchtung] has invalid password or username
                                  2024-01-21 17:40:38.241  - warn: shelly.0 (1116) State value to set for "shelly.0.SHDM-1#D3E918#1.temperatureF" has value "102.12" greater than max "100"
                                  2024-01-21 17:40:38.726  - warn: sonoff.0 (1150) Client [Pool Beleuchtung] has invalid password or username
                                  2024-01-21 17:40:38.782  - warn: sonoff.0 (1150) Client [Muschel Terrasse] has invalid password or username
                                  2024-01-21 17:40:38.794  - warn: shelly.0 (1116) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2024-01-21 17:40:38.899  - warn: shelly.0 (1116) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2024-01-21 17:40:40.448  - warn: sonoff.0 (1150) Client [Pool Pumpe] has invalid password or username
                                  2024-01-21 17:40:43.820  - warn: sonoff.0 (1150) Client [Taster-Schlafzimmer-Bett-L] has invalid password or username
                                  2024-01-21 17:40:44.160  - warn: shelly.0 (1116) [authEnabled] 192.168.2.226 (shellydimmer2 / shellydimmer2-8CAAB54C4E21 / SHDM-2#8CAAB54C4E21#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2024-01-21 17:40:44.159  - warn: sonoff.0 (1150) Client [Wohnzimmer-Vitrine] has invalid password or username
                                  2024-01-21 17:40:44.733  - warn: sonoff.0 (1150) Client [PC-Buero] has invalid password or username
                                  2024-01-21 17:40:51.475  - warn: shelly.0 (1116) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2024-01-21 17:40:51.688  - warn: shelly.0 (1116) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2024-01-21 17:40:51.753  - warn: shelly.0 (1116) State value to set for "shelly.0.SHDM-2#8CAAB54C4B57#1.temperatureF" has value "106.96" greater than max "100"
                                  2024-01-21 17:40:55.957  - warn: shelly.0 (1116) [authEnabled] 192.168.2.226 (shellydimmer2 / shellydimmer2-8CAAB54C4E21 / SHDM-2#8CAAB54C4E21#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2024-01-21 17:41:03.864  - warn: sonoff.0 (1150) Client [Pavillon Beleuchtung] has invalid password or username
                                  2024-01-21 17:41:04.546  - warn: sonoff.0 (1150) Client [Pool Beleuchtung] has invalid password or username
                                  2024-01-21 17:41:05.691  - warn: shelly.0 (1116) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2024-01-21 17:41:05.875  - warn: shelly.0 (1116) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
                                  2024-01-21 17:41:06.282  - warn: sonoff.0 (1150) Client [Pool Pumpe] has invalid password or username
                                  2024-01-21 17:41:07.007  - warn: shelly.0 (1116) State value to set for "shelly.0.SHDM-2#8CAAB54C4B57#1.temperatureF" has value "107.08" greater than max "100"
                                  2024-01-21 17:41:07.280  - warn: sonoff.0 (1150) Client [Muschel Terrasse] has invalid password or username
                                  iob diag has finished.
                                  Press any key for a summary
                                  PI@raspberrypi:~ $ iob logs | grep zigbee
                                  2024-01-21 17:34:16.171 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1229
                                  2024-01-21 17:34:22.326 - debug: zigbee.0 (1229) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                  2024-01-21 17:34:22.397 - debug: zigbee.0 (1229) Objects client ready ... initialize now
                                  2024-01-21 17:34:22.400 - debug: zigbee.0 (1229) Objects create System PubSub Client
                                  2024-01-21 17:34:22.402 - debug: zigbee.0 (1229) Objects create User PubSub Client
                                  2024-01-21 17:34:22.481 - debug: zigbee.0 (1229) Objects client initialize lua scripts
                                  2024-01-21 17:34:22.495 - debug: zigbee.0 (1229) Objects connected to redis: 127.0.0.1:9001
                                  2024-01-21 17:34:22.546 - debug: zigbee.0 (1229) Redis States: Use Redis connection: 127.0.0.1:9000
                                  2024-01-21 17:34:22.625 - debug: zigbee.0 (1229) States create System PubSub Client
                                  2024-01-21 17:34:22.627 - debug: zigbee.0 (1229) States create User PubSub Client
                                  2024-01-21 17:34:22.711 - debug: zigbee.0 (1229) States connected to redis: 127.0.0.1:9000
                                  2024-01-21 17:34:22.780 - debug: zigbee.0 (1229) Plugin sentry Initialize Plugin (enabled=true)
                                  2024-01-21 17:34:23.636 - info: zigbee.0 (1229) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
                                  2024-01-21 17:34:23.678 - debug: zigbee.0 (1229) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_8eb6f719a99ded11ad35dca5a7669f5d-if00-port0","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false},"legacy":false}
                                  2024-01-21 17:34:23.787 - info: zigbee.0 (1229) delete old Backup files. keep only last 10
                                  2024-01-21 17:34:23.790 - info: zigbee.0 (1229) Starting Zigbee npm ...
                                  2024-01-21 17:34:23.867 - debug: zigbee.0 (1229) Starting zigbee-herdsman...
                                  2024-01-21 17:34:24.431 - info: zigbee.0 (1229) Installed Version: iobroker.zigbee@1.10.1
                                  2024-01-21 17:34:25.075 - debug: zigbee.0 (1229) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2024_01_21-17_34_23.tar.gz success
                                  2024-01-21 17:34:28.117 - debug: zigbee.0 (1229) zigbee-herdsman started
                                  2024-01-21 17:34:28.120 - info: zigbee.0 (1229) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
                                  2024-01-21 17:34:28.129 - debug: zigbee.0 (1229) Zigbee network parameters: panID=6754 channel=11 extendedPanID=dddddddddddddddd
                                  2024-01-21 17:34:28.130 - info: zigbee.0 (1229) Disable LED
                                  2024-01-21 17:34:28.131 - info: zigbee.0 (1229) Unable to disable LED, unsupported function.
                                  2024-01-21 17:34:28.151 - info: zigbee.0 (1229) --> transmitPower : normal
                                  2024-01-21 17:34:28.194 - info: zigbee.0 (1229) Currently 28 devices are joined:
                                  2024-01-21 17:34:28.195 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d00044d8e0b = true
                                  2024-01-21 17:34:28.203 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d00044d8e0b = 10
                                  2024-01-21 17:34:28.211 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d000257bae7 = true
                                  2024-01-21 17:34:28.218 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d000257bae7 = 10
                                  2024-01-21 17:34:28.221 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d00045f7cee = true
                                  2024-01-21 17:34:28.225 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d00045f7cee = 10
                                  2024-01-21 17:34:28.228 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d0004521481 = true
                                  2024-01-21 17:34:28.232 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d0004521481 = 10
                                  2024-01-21 17:34:28.235 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d000461b53e = true
                                  2024-01-21 17:34:28.239 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d000461b53e = 10
                                  2024-01-21 17:34:28.243 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x680ae2fffec91ea4 = true
                                  2024-01-21 17:34:28.247 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x680ae2fffec91ea4 = 10
                                  2024-01-21 17:34:28.250 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x588e81fffe2b8762 = true
                                  2024-01-21 17:34:28.254 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x588e81fffe2b8762 = 10
                                  2024-01-21 17:34:28.258 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d00045eb708 = true
                                  2024-01-21 17:34:28.261 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d00045eb708 = 10
                                  2024-01-21 17:34:28.265 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d0002a71e25 = true
                                  2024-01-21 17:34:28.269 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d0002a71e25 = 10
                                  2024-01-21 17:34:28.273 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x04cf8cdf3c794764 = true
                                  2024-01-21 17:34:28.277 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x04cf8cdf3c794764 = 10
                                  2024-01-21 17:34:28.280 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x04cf8cdf3c7946a1 = true
                                  2024-01-21 17:34:28.284 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7946a1 = 10
                                  2024-01-21 17:34:28.288 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d00045f8d3d = true
                                  2024-01-21 17:34:28.291 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d00045f8d3d = 10
                                  2024-01-21 17:34:28.295 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d0004597653 = true
                                  2024-01-21 17:34:28.299 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d0004597653 = 10
                                  2024-01-21 17:34:28.314 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0xbc33acfffe2ab392 = true
                                  2024-01-21 17:34:28.318 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0xbc33acfffe2ab392 = 10
                                  2024-01-21 17:34:28.322 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x04cf8cdf3c7b5255 = true
                                  2024-01-21 17:34:28.326 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b5255 = 10
                                  2024-01-21 17:34:28.330 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x04cf8cdf3c7b51f7 = true
                                  2024-01-21 17:34:28.334 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b51f7 = 10
                                  2024-01-21 17:34:28.338 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x04cf8cdf3c78b7ba = true
                                  2024-01-21 17:34:28.341 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x04cf8cdf3c78b7ba = 10
                                  2024-01-21 17:34:28.345 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d000461da61 = true
                                  2024-01-21 17:34:28.349 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d000461da61 = 10
                                  2024-01-21 17:34:28.354 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x04cd15fffefe9ca8 = true
                                  2024-01-21 17:34:28.358 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x04cd15fffefe9ca8 = 10
                                  grep: (standard input): binary file matches
                                  code_text
                                    Thomas Braun Most Active @Tapdance 0 last edited by
                                    @tapdance-0 sagte in Ziggbe sendet nicht mehr an empfängt aber noch Daten:
                                    Läuft doch.
                                      firmware version: "revision":20210708
                                      Ist allerdings steinalt. Würde ich aktualisieren.
                                        Aber kein Gerät reagiert, selbst die nicht die vorher noch funktioniert haben.
                                          Tapdance 0 @Tapdance 0 last edited by
                                          @tapdance-0
                                          PI@raspberrypi:~ $ ^C
                                          2024-01-21 17:36:23.926  - debug: zigbee.0 (1229) Failed to execute LQI for '0xf4b3b1fffef8731e'. "Error: AREQ - ZDO - mgmtLqiRsp after 10000ms\n    at Object.start (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:63:23)\n    at request (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:582:47)\n    at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:604:28\n    at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20)\n    at ZigbeeController.getMap (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:721:30)"
                                          PI@raspberrypi:~ $
                                            Ok und wie mache ich das mit der Firmware Version?
                                            Jetzt bin ich wieder bei meinem Ursprungsproblem alles hat sich eingependelt und läuft außer.
                                            bei "MOES ZigBee Mini Smart" da kann ich keine Daten mehr senden kann nur empfangen.
                                            Ich kann im IO Broker aber den Status der Geräte sehen der Empfang der daten funktioniert also. Beispiel ich ändere am Schalter manuell die Helligkeit dann sehe ich im IOBrocker die aktuelle Prozentzahl der Helligkeit. Andere Zigbee Komponenten wie meine Bewegungsmelder von Acera scheinen nicht betroffen zu sein.
                                            3129
