    4. Ziggbe sendet nicht mehr an empfängt aber noch Daten
      Tapdance 0 @Thomas Braun last edited by
      habe den Punkt zum eintragen des Pfades gefunden. Der wird nur angezeigt wenn man über die Instanz in Menü geht. Pfad ist eingetragen Adapter ist grün, aber leider funktioniert noch nichts.
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.1.0-rpi7-rpi-v8
          Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       17:39:43 up 6 min,  3 users,  load average: 0.52, 0.90, 0.57
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Sun 2024-01-21 17:39:43 CET
                 Universal time: Sun 2024-01-21 16:39:43 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      PI
      /home/PI
      PI adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            4.0G        1.6G        2.0G        1.3M        420M        2.3G
      Swap:           104M          0B        104M
      Total:          4.1G        1.6G        2.1G
               3793 M total memory
               1571 M used memory
               1603 M active memory
                166 M inactive memory
               1897 M free memory
                 40 M buffer memory
                359 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     380M  1.2M  379M   1% /run
      /dev/mmcblk0p2 ext4       28G  7.1G   20G  27% /
      tmpfs          tmpfs     1.9G  8.0K  1.9G   1% /dev/shm
      /dev/mmcblk0p1 vfat      510M   73M  438M  15% /boot/firmware
      tmpfs          tmpfs     380M   32K  380M   1% /run/user/1000
      [Sun Jan 21 17:32:52 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:64:62:CC vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9515910b-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Sun Jan 21 17:32:56 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sun Jan 21 17:32:59 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET           SOURCE         FSTYPE OPTIONS
      /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      667M    /var/
      194M    /var/lib
      187M    /var/log
      186M    /var/log/journal/67fa5cc7176343b98d5ef1e5e5a27de6
      Archived and active journals take up 185.5M in the file system.
      /opt/iobroker/backups:
      4.0K    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      368M    /opt/iobroker/iobroker-data/
      270M    /opt/iobroker/iobroker-data/files
      78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
      73M     /opt/iobroker/iobroker-data/backup-objects
      67M     /opt/iobroker/iobroker-data/files/javascript.admin
      24M     /opt/iobroker/iobroker-data/objects.jsonl
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
      7.5M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/691.26ff76ce.chunk.js.map
      7.1M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.d3cce782.chunk.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_8eb6f719a99ded11ad35dca5a7669f5d-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
           18.19.0+dfsg-6~deb12u1 500
       *** 18.19.0-1nodesource1 1001
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1 500
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.12.0
      javascript:     7.1.6
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alarm.0                  : alarm                 : raspberrypi                              -  enabled
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
      + system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
      + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
      + system.adapter.history.0                : history               : raspberrypi                              -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
        system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi                              - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              - disabled
      + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
      + system.adapter.sayit.0                  : sayit                 : raspberrypi                              -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.synology.0               : synology              : raspberrypi                              -  enabled, port: 5000
      + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 192.168.2.4, run as: admin
      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
        system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
        system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
      + system.adapter.wifilight.0              : wifilight             : raspberrypi                              -  enabled
      + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_8eb6f719a99ded11ad35dca5a7669f5d-if00-port0
      + instance is alive
      ioBroker-Repositories
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      Stable (default): http://download.iobroker.net/sources-dist.json
      Active repo(s): Stable (default)
      Installed ioBroker-Instances
      Used repository: Stable (default)
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "alarm"        : 3.6.0    , installed 3.6.0
      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "mobile"       : 1.0.1    , installed 1.0.1
      Adapter    "sayit"        : 3.0.5    , installed 3.0.5
      Adapter    "shelly"       : 6.6.1    , installed 6.6.1
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "synology"     : 3.0.1    , installed 3.0.1
      Adapter    "telegram"     : 3.0.1    , installed 3.0.1
      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
      Objects and States
      Objects:        5503
      States:         4905
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12153      804/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          16485      794/cupsd
      tcp        0      0 192.168.2.4:2001        0.0.0.0:*               LISTEN      1001       19586      1091/io.hm-rpc.0
      tcp        0      0 192.168.2.4:2010        0.0.0.0:*               LISTEN      1001       16840      1092/io.hm-rpc.1
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16343      795/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18476      795/iobroker.js-con
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       18056      1150/io.sonoff.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          12155      804/sshd: /usr/sbin
      tcp6       0      0 :::39615                :::*                    LISTEN      1001       19369      1962/io.yahka.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       20340      1882/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       17851      969/io.admin.0
      tcp6       0      0 :::8088                 :::*                    LISTEN      1001       17327      1565/io.terminal.0
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          16484      794/cupsd
      udp        0      0 0.0.0.0:36784           0.0.0.0:*                           104        16424      573/avahi-daemon: r
      udp        0      0 0.0.0.0:34788           0.0.0.0:*                           1001       20998      1325/io.broadlink2.
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          16262      844/cups-browsed
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       20995      1325/io.broadlink2.
      udp        0      0 0.0.0.0:58383           0.0.0.0:*                           1001       22993      1325/io.broadlink2.
      udp        0      0 192.168.2.4:5353        0.0.0.0:*                           1001       18718      1181/io.tr-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        16422      573/avahi-daemon: r
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       18034      1116/io.shelly.0
      udp6       0      0 fe80::67d1:e1cb:7ef:546 :::*                                0          12279      733/NetworkManager
      udp6       0      0 :::50277                :::*                                104        16425      573/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        16423      573/avahi-daemon: r
      2024-01-21 17:40:28.300  - debug: zigbee.0 (1229) DeviceAvailability:Non-pingable device 0x00158d000461da61 lumi.sensor_magnet was last seen '34744106.67' seconds ago.
      2024-01-21 17:40:28.329  - debug: zigbee.0 (1229) DeviceAvailability:Non-pingable device 0x04cd15fffefe9ca8 ZBMINIL2 was last seen '5227.093' seconds ago.
      2024-01-21 17:40:28.907  - warn: shelly.0 (1116) [authEnabled] 192.168.2.226 (shellydimmer2 / shellydimmer2-8CAAB54C4E21 / SHDM-2#8CAAB54C4E21#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-21 17:40:37.805  - warn: sonoff.0 (1150) Client [Pavillon Beleuchtung] has invalid password or username
      2024-01-21 17:40:38.241  - warn: shelly.0 (1116) State value to set for "shelly.0.SHDM-1#D3E918#1.temperatureF" has value "102.12" greater than max "100"
      2024-01-21 17:40:38.726  - warn: sonoff.0 (1150) Client [Pool Beleuchtung] has invalid password or username
      2024-01-21 17:40:38.782  - warn: sonoff.0 (1150) Client [Muschel Terrasse] has invalid password or username
      2024-01-21 17:40:38.794  - warn: shelly.0 (1116) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-21 17:40:38.899  - warn: shelly.0 (1116) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-21 17:40:40.448  - warn: sonoff.0 (1150) Client [Pool Pumpe] has invalid password or username
      2024-01-21 17:40:43.820  - warn: sonoff.0 (1150) Client [Taster-Schlafzimmer-Bett-L] has invalid password or username
      2024-01-21 17:40:44.160  - warn: shelly.0 (1116) [authEnabled] 192.168.2.226 (shellydimmer2 / shellydimmer2-8CAAB54C4E21 / SHDM-2#8CAAB54C4E21#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-21 17:40:44.159  - warn: sonoff.0 (1150) Client [Wohnzimmer-Vitrine] has invalid password or username
      2024-01-21 17:40:44.733  - warn: sonoff.0 (1150) Client [PC-Buero] has invalid password or username
      2024-01-21 17:40:51.475  - warn: shelly.0 (1116) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-21 17:40:51.688  - warn: shelly.0 (1116) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-21 17:40:51.753  - warn: shelly.0 (1116) State value to set for "shelly.0.SHDM-2#8CAAB54C4B57#1.temperatureF" has value "106.96" greater than max "100"
      2024-01-21 17:40:55.957  - warn: shelly.0 (1116) [authEnabled] 192.168.2.226 (shellydimmer2 / shellydimmer2-8CAAB54C4E21 / SHDM-2#8CAAB54C4E21#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-21 17:41:03.864  - warn: sonoff.0 (1150) Client [Pavillon Beleuchtung] has invalid password or username
      2024-01-21 17:41:04.546  - warn: sonoff.0 (1150) Client [Pool Beleuchtung] has invalid password or username
      2024-01-21 17:41:05.691  - warn: shelly.0 (1116) [authEnabled] 192.168.2.180 (shellydimmer / shellydimmer-D3E918 / SHDM-1#D3E918#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-21 17:41:05.875  - warn: shelly.0 (1116) [authEnabled] 192.168.2.214 (shellydimmer2 / shellydimmer2-8CAAB54C4B57 / SHDM-2#8CAAB54C4B57#1): This device is not protected via restricted login (see adapter documentation for details)
      2024-01-21 17:41:06.282  - warn: sonoff.0 (1150) Client [Pool Pumpe] has invalid password or username
      2024-01-21 17:41:07.007  - warn: shelly.0 (1116) State value to set for "shelly.0.SHDM-2#8CAAB54C4B57#1.temperatureF" has value "107.08" greater than max "100"
      2024-01-21 17:41:07.280  - warn: sonoff.0 (1150) Client [Muschel Terrasse] has invalid password or username
      iob diag has finished.
      Press any key for a summary
      PI@raspberrypi:~ $ iob logs | grep zigbee
      2024-01-21 17:34:16.171 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 1229
      2024-01-21 17:34:22.326 - debug: zigbee.0 (1229) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2024-01-21 17:34:22.397 - debug: zigbee.0 (1229) Objects client ready ... initialize now
      2024-01-21 17:34:22.400 - debug: zigbee.0 (1229) Objects create System PubSub Client
      2024-01-21 17:34:22.402 - debug: zigbee.0 (1229) Objects create User PubSub Client
      2024-01-21 17:34:22.481 - debug: zigbee.0 (1229) Objects client initialize lua scripts
      2024-01-21 17:34:22.495 - debug: zigbee.0 (1229) Objects connected to redis: 127.0.0.1:9001
      2024-01-21 17:34:22.546 - debug: zigbee.0 (1229) Redis States: Use Redis connection: 127.0.0.1:9000
      2024-01-21 17:34:22.625 - debug: zigbee.0 (1229) States create System PubSub Client
      2024-01-21 17:34:22.627 - debug: zigbee.0 (1229) States create User PubSub Client
      2024-01-21 17:34:22.711 - debug: zigbee.0 (1229) States connected to redis: 127.0.0.1:9000
      2024-01-21 17:34:22.780 - debug: zigbee.0 (1229) Plugin sentry Initialize Plugin (enabled=true)
      2024-01-21 17:34:23.636 - info: zigbee.0 (1229) starting. Version 1.10.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v18.19.0, js-controller: 5.0.17
      2024-01-21 17:34:23.678 - debug: zigbee.0 (1229) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_8eb6f719a99ded11ad35dca5a7669f5d-if00-port0","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false},"legacy":false}
      2024-01-21 17:34:23.787 - info: zigbee.0 (1229) delete old Backup files. keep only last 10
      2024-01-21 17:34:23.790 - info: zigbee.0 (1229) Starting Zigbee npm ...
      2024-01-21 17:34:23.867 - debug: zigbee.0 (1229) Starting zigbee-herdsman...
      2024-01-21 17:34:24.431 - info: zigbee.0 (1229) Installed Version: iobroker.zigbee@1.10.1
      2024-01-21 17:34:25.075 - debug: zigbee.0 (1229) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2024_01_21-17_34_23.tar.gz success
      2024-01-21 17:34:28.117 - debug: zigbee.0 (1229) zigbee-herdsman started
      2024-01-21 17:34:28.120 - info: zigbee.0 (1229) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
      2024-01-21 17:34:28.129 - debug: zigbee.0 (1229) Zigbee network parameters: panID=6754 channel=11 extendedPanID=dddddddddddddddd
      2024-01-21 17:34:28.130 - info: zigbee.0 (1229) Disable LED
      2024-01-21 17:34:28.131 - info: zigbee.0 (1229) Unable to disable LED, unsupported function.
      2024-01-21 17:34:28.151 - info: zigbee.0 (1229) --> transmitPower : normal
      2024-01-21 17:34:28.194 - info: zigbee.0 (1229) Currently 28 devices are joined:
      2024-01-21 17:34:28.195 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d00044d8e0b = true
      2024-01-21 17:34:28.203 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d00044d8e0b = 10
      2024-01-21 17:34:28.211 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d000257bae7 = true
      2024-01-21 17:34:28.218 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d000257bae7 = 10
      2024-01-21 17:34:28.221 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d00045f7cee = true
      2024-01-21 17:34:28.225 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d00045f7cee = 10
      2024-01-21 17:34:28.228 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d0004521481 = true
      2024-01-21 17:34:28.232 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d0004521481 = 10
      2024-01-21 17:34:28.235 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d000461b53e = true
      2024-01-21 17:34:28.239 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d000461b53e = 10
      2024-01-21 17:34:28.243 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x680ae2fffec91ea4 = true
      2024-01-21 17:34:28.247 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x680ae2fffec91ea4 = 10
      2024-01-21 17:34:28.250 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x588e81fffe2b8762 = true
      2024-01-21 17:34:28.254 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x588e81fffe2b8762 = 10
      2024-01-21 17:34:28.258 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d00045eb708 = true
      2024-01-21 17:34:28.261 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d00045eb708 = 10
      2024-01-21 17:34:28.265 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d0002a71e25 = true
      2024-01-21 17:34:28.269 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d0002a71e25 = 10
      2024-01-21 17:34:28.273 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x04cf8cdf3c794764 = true
      2024-01-21 17:34:28.277 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x04cf8cdf3c794764 = 10
      2024-01-21 17:34:28.280 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x04cf8cdf3c7946a1 = true
      2024-01-21 17:34:28.284 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7946a1 = 10
      2024-01-21 17:34:28.288 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d00045f8d3d = true
      2024-01-21 17:34:28.291 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d00045f8d3d = 10
      2024-01-21 17:34:28.295 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d0004597653 = true
      2024-01-21 17:34:28.299 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d0004597653 = 10
      2024-01-21 17:34:28.314 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0xbc33acfffe2ab392 = true
      2024-01-21 17:34:28.318 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0xbc33acfffe2ab392 = 10
      2024-01-21 17:34:28.322 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x04cf8cdf3c7b5255 = true
      2024-01-21 17:34:28.326 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b5255 = 10
      2024-01-21 17:34:28.330 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x04cf8cdf3c7b51f7 = true
      2024-01-21 17:34:28.334 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x04cf8cdf3c7b51f7 = 10
      2024-01-21 17:34:28.338 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x04cf8cdf3c78b7ba = true
      2024-01-21 17:34:28.341 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x04cf8cdf3c78b7ba = 10
      2024-01-21 17:34:28.345 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x00158d000461da61 = true
      2024-01-21 17:34:28.349 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x00158d000461da61 = 10
      2024-01-21 17:34:28.354 - debug: zigbee.0 (1229) DeviceAvailability:Publish available for 0x04cd15fffefe9ca8 = true
      2024-01-21 17:34:28.358 - debug: zigbee.0 (1229) DeviceAvailability:Publish LQ for 0x04cd15fffefe9ca8 = 10
      grep: (standard input): binary file matches
      code_text
        Thomas Braun Most Active @Tapdance 0 last edited by
        @tapdance-0 sagte in Ziggbe sendet nicht mehr an empfängt aber noch Daten:
        Läuft doch.
          firmware version: "revision":20210708
          Ist allerdings steinalt. Würde ich aktualisieren.
            Aber kein Gerät reagiert, selbst die nicht die vorher noch funktioniert haben.
              Tapdance 0 @Tapdance 0 last edited by
              @tapdance-0
              PI@raspberrypi:~ $ ^C
              2024-01-21 17:36:23.926  - debug: zigbee.0 (1229) Failed to execute LQI for '0xf4b3b1fffef8731e'. "Error: AREQ - ZDO - mgmtLqiRsp after 10000ms\n    at Object.start (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:63:23)\n    at request (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:582:47)\n    at /opt/iobroker/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:604:28\n    at Queue.execute (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/queue.ts:35:20)\n    at ZigbeeController.getMap (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:721:30)"
              PI@raspberrypi:~ $
                Ok und wie mache ich das mit der Firmware Version?
                Jetzt bin ich wieder bei meinem Ursprungsproblem alles hat sich eingependelt und läuft außer.
                bei "MOES ZigBee Mini Smart" da kann ich keine Daten mehr senden kann nur empfangen.
                Ich kann im IO Broker aber den Status der Geräte sehen der Empfang der daten funktioniert also. Beispiel ich ändere am Schalter manuell die Helligkeit dann sehe ich im IOBrocker die aktuelle Prozentzahl der Helligkeit. Andere Zigbee Komponenten wie meine Bewegungsmelder von Acera scheinen nicht betroffen zu sein.
                  @tapdance-0
                  https://www.zigbee2mqtt.io/guide/adapters/flashing/flashing_via_cc2538-bsl.html
                    Method without Docker
                    Prepare your system (debian based)
                    Ist debian = RasperyPI
                      @tapdance-0
                      Ja, Raspberry OS basiert auf Debian.
                        Bis Download the Firmware verstehe ich das aber wie lade ich dann die firmware von der webseite runter und bringe sie in den Raspberry?
                        Meister Mopper Thomas Braun 2 Replies Last reply Reply Quote 0
                        • Meister Mopper
                          Meister Mopper @Tapdance 0 last edited by Meister Mopper
                          Du solltest die Firmware des Geräts aktualisieren, nicht die des Raspi.
                            @tapdance-0
                            Mach es danach:
                            https://forum.iobroker.net/topic/50180/anleitung-zigbee-firmware-auf-der-kommandozeile-flashen
                            Achtung! Du brauchst für den Stick andere Firmware. Und eine zusätzliche Option beim flash.
                              @thomas-braun sagte in Ziggbe sendet nicht mehr an empfängt aber noch Daten:
                              Sory das ich mich so dumm anstelle, aber in der Anleitung steht doch:
                              Für den Sonoff-Stick:
                              wget https://github.com/Koenkk/Z-Stack-firmware/raw/Z-Stack_3.x.0_coordinator_20230507/coordinator/Z-Stack_3.x.0/bin/CC1352P2_CC2652P_launchpad_coordinator_20230507.zip
                              unzip CC1352P2_CC2652P_launchpad_coordinator_20230507.zip
                              und das ist jetzt nicht dir richtige???? Und welch Option, da steht so viel in der Beschreibung beziehungsweise darunter? Verstehe gerade nur Bahnhof. 😞
                                Habe ich gerade als Service da eingetragen.
                                  also
                                  Skript herunterladen per
                                  wget https://raw.githubusercontent.com/JelmerT/cc2538-bsl/master/cc2538-bsl.py
                                  nächster Schritt
                                  sudo apt update && sudo apt install python3-serial python3-intelhex python3-magic
                                  dann
                                  Den verwendeten Port in Erfahrung bringen:
                                  echad@chet:~/HowTo-zigbee_FWupdate $ ls -l /dev/serial/by-id/
                                  total 0
                                  lrwxrwxrwx 1 root root 13 Dec 10 19:35 usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0 -> ../../ttyUSB0
                                  Wo sehe ich jetzt den Port und was muss ich mit dem Wissen machen?
                                    Der steht dann in der Ausgabe.
                                    Oder hiernach:
                                    find /dev/serial/by-id/ -maxdepth 1 -mindepth 1
                                      Ok dann Zigbee Adapter über das Web interface anhalten und dann
                                      --------------------------------------------Gilt das zwischen den Linien für alle adapter?---------------------------_
                                      Dann der eigentliche Flash:
                                      chmod +x cc2538-bsl.py
                                      ./cc2538-bsl.py -p “comport” -evw “fw-file”
                                      danach dann (oder soll man das beim Sonoff statt des Teils zwischen den Strichen oben machen?)
                                      Der sonoff (Firmware: CC1352P2_CC2652P_launchpad_coordinator ) wird so geflasht:
                                      select all
                                      ./cc2538-bsl.py -ewv -p "comport" --bootloader-sonoff-usb “fw-file”
                                      Und dann ist man fertig?
                                        @tapdance-0
                                        Und wofür brauchte ich jetzt den Port oben?
                                          Den trägst du statt des Platzhalters "comport" ein.
                                          Auch "fw-file" ist ein Platzhalter und muss durch den richtigen Dateinamen ersetzt werden.
                                            fw-file
                                            Ok jetzt habe ich es dann ja fast zusammen "Comport" bei alle Befehlen entsprechend ersetzen jetzt muss ich nur noch wissen woher ich den Dateinamen für "fw-fiele" bekomme und ich kann anfangen.
                                            T Thomas Braun 2 Replies Last reply Reply Quote 0
                                            3123
