    4. Iobroker lässt sich nicht mehr starten.
      Homoran Global Moderator Administrators @Borkenkäfer last edited by
      @borkenkäfer sagte in Iobroker lässt sich nicht mehr starten.:
      das komplette Summary
      wieso nur das Summary?
      Aber da hat dir anscheinend irgendwas deine Installation ziemlich zerschossen
      • Glasfaser
        Glasfaser @Borkenkäfer last edited by
        @glasfaser
        hallo
        bekomme das komplette Summary not gespoilert
        ERROR forbidden ?
        Einfach die Seite reloaden ... der Post Inhalt bleibt !
          Borkenkäfer @Glasfaser last edited by
          @glasfaser
                                  v.2023-10-10
             Static hostname: raspberrypi
                   Icon name: computer
            Operating System: Debian GNU/Linux 11 (bullseye)
                      Kernel: Linux 6.1.21-v8+
                Architecture: arm64
          Installation:           native
          Kernel:                 aarch64
          Userland:               arm64
          Timezone:               Europe/Berlin (CET, +0100)
          User-ID:                1000
          X-Server:               true
          Boot Target:            graphical.target
          Pending OS-Updates:     0
          node:internal/modules/cjs/loader:1137
            throw err;
          Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
              at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
              at Module._load (node:internal/modules/cjs/loader:975:27)
              at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
              at node:internal/main/run_main_module:28:49 {
            code: 'MODULE_NOT_FOUND',
            requireStack: []
          Node.js v18.19.0
          Pending iob updates:    0
          Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                  /usr/bin/node           v18.19.0
                                  /usr/bin/npm            10.2.3
                                  /usr/bin/npx            10.2.3
                                  /usr/bin/corepack       0.22.0
          Recommended versions are nodejs  and npm
          MEMORY:
          Mem:            3.8G        297M        2.7G         35M        801M        3.4G
          Swap:            99M          0B         99M
          Total:          3.9G        297M        2.8G
            throw err;
            requireStack: []
          Node.js v18.19.0
          Active iob-Instances:   0
            throw err;
            requireStack: []
          Node.js v18.19.0
            throw err;
            requireStack: []
          Node.js v18.19.0
          ioBroker Core:          js-controller
            throw err;
            requireStack: []
          Node.js v18.19.0
                                  admin
            throw err;
            requireStack: []
          Node.js v18.19.0
          ioBroker Status:
            throw err;
            requireStack: []
          Node.js v18.19.0
          Objects:                0
          States:                 0
          Size of iob-Database:
          5.8M    /opt/iobroker/iobroker-data/objects.jsonl
          420K    /opt/iobroker/iobroker-data/states.jsonl
          • Glasfaser
            SUMMARY
            die Full am Anfang brauche ich
            Homoran B 2 Replies Last reply Reply Quote 0
              Homoran Global Moderator Administrators @Glasfaser last edited by
              @glasfaser da hat's anscheinend due Dateien vom Controller gefetzt
                Borkenkäfer @Homoran last edited by
                leider ja
                bekomme es mit dem Fixer leider nicht hin
                Glasfaser Homoran 2 Replies Last reply Reply Quote 0
                • Codierknecht
                  Codierknecht Developer Most Active last edited by
                  X-Server:               true
                  Das hat auf 'nem Server auch nix zu suchen.
                  • Glasfaser
                    Glasfaser @Borkenkäfer last edited by Glasfaser
                    leider nicht hin
                    wie schon erwähnt die Full Ausgabe wäre besser :
                    sonst
                    cd /opt/iobroker
                    sudo -H -u iobroker npm install iobroker.js-controller
                    Edit :
                      der ist ja auch für anderes zuständig
                        @glasfaser
                        weiß leider nicht genau was du mit full meinst
                        ulli@raspberrypi:/opt/iobroker $ iob full
                          throw err;
                          requireStack: []
                        Node.js v18.19.0
                        Homoran Glasfaser 3 Replies Last reply Reply Quote 0
                          Homoran Global Moderator Administrators @Borkenkäfer last edited by Homoran
                          iob diag liefert erst eine Langfassung.
                          die bitte posten
                          das Summary kommt erst danach, wenn eine Taste gedrückt wird
                          • Glasfaser
                            @borkenkäfer
                            Es kommt erst die lange Ausgabe ....
                            von
                            iob diag
                            dann auf abbrechen . diese brauche ich
                            sonst kommt die Summary
                            • Glasfaser
                              @borkenkäfer
                              du darfst gere den Befehl ausführen den ich oben gepostet habe ... da geht nichts kapput 🙂
                                @glasfaser
                                das sollte es sein
                                Skript v.2023-10-10
                                *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                Model           : Raspberry Pi 4 Model B Rev 1.2
                                Docker          : false
                                Virtualization  : none
                                Kernel          : aarch64
                                Userland        : arm64
                                Systemuptime and Load:
                                 19:00:44 up 58 min,  3 users,  load average: 0.00, 0.00, 0.00
                                CPU threads: 4
                                *** RASPBERRY THROTTLING ***
                                Current issues:
                                Previously detected issues:
                                *** Time and Time Zones ***
                                               Local time: Mon 2024-01-22 19:00:44 CET
                                           Universal time: Mon 2024-01-22 18:00:44 UTC
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                *** User and Groups ***
                                ulli
                                /home/ulli
                                ulli adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                                *** X-Server-Setup ***
                                X-Server:       true
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:            3.8G        298M        2.7G         35M        803M        3.4G
                                Swap:            99M          0B         99M
                                Total:          3.9G        298M        2.8G
                                         3794 M total memory
                                          298 M used memory
                                          594 M active memory
                                          343 M inactive memory
                                         2692 M free memory
                                           49 M buffer memory
                                          753 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                Raspberry only:
                                oom events: 0
                                *** FAILED SERVICES ***
                                0 loaded units listed.
                                *** FILESYSTEM ***
                                /dev/root      ext4       59G   11G   46G  20% /
                                devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                                tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                                tmpfs          tmpfs     759M  1.2M  758M   1% /run
                                /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                                tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
                                [Mon Jan 22 18:02:06 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:84:9D:5E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a9a74992-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                [Mon Jan 22 18:02:07 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                [Mon Jan 22 18:02:07 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                [Mon Jan 22 18:02:09 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                TARGET  SOURCE         FSTYPE OPTIONS
                                /       /dev/mmcblk0p2 ext4   rw,noatime
                                `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                /var:
                                4.3G    /var/
                                3.4G    /var/log
                                2.9G    /var/log/journal/b741ffe02a684b9895597ea9866ca817
                                641M    /var/cache
                                Archived and active journals take up 2.8G in the file system.
                                /opt/iobroker/backups:
                                687M    /opt/iobroker/backups/
                                343M    /opt/iobroker/backups/history
                                268M    /opt/iobroker/backups/files
                                88M     /opt/iobroker/backups/files/echarts.admin
                                57M     /opt/iobroker/backups/files/echarts
                                /opt/iobroker/iobroker-data:
                                683M    /opt/iobroker/iobroker-data/
                                347M    /opt/iobroker/iobroker-data/history
                                294M    /opt/iobroker/iobroker-data/files
                                89M     /opt/iobroker/iobroker-data/files/echarts.admin
                                57M     /opt/iobroker/iobroker-data/files/echarts
                                24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
                                24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
                                23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
                                21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                                17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b756fe6.js.map
                                USB-Devices by-id:
                                /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_cc8e9ae92dd3eb11ac2234e8bf09e213-if00-port0
                                *** NodeJS-Installation ***
                                /usr/bin/npm            10.2.3
                                /usr/bin/npx            10.2.3
                                nodejs:
                                  Installed: 18.19.0-1nodesource1
                                  Candidate: 18.19.0-1nodesource1
                                  Version table:
                                 *** 18.19.0-1nodesource1 600
                                        100 /var/lib/dpkg/status
                                     18.18.2-1nodesource1 600
                                     18.18.1-1nodesource1 600
                                     18.18.0-1nodesource1 600
                                     18.17.1-1nodesource1 600
                                     18.17.0-1nodesource1 600
                                     18.16.1-1nodesource1 600
                                     18.16.0-1nodesource1 600
                                     18.15.0-1nodesource1 600
                                     18.14.2-1nodesource1 600
                                     18.14.1-1nodesource1 600
                                     18.14.0-1nodesource1 600
                                     18.13.0-1nodesource1 600
                                     18.12.0-1nodesource1 600
                                     18.11.0-1nodesource1 600
                                     18.10.0-1nodesource1 600
                                     18.9.1-1nodesource1 600
                                     18.9.0-1nodesource1 600
                                     18.8.0-1nodesource1 600
                                     18.7.0-1nodesource1 600
                                     18.6.0-1nodesource1 600
                                     18.5.0-1nodesource1 600
                                     18.4.0-1nodesource1 600
                                     18.3.0-1nodesource1 600
                                     18.2.0-1nodesource1 600
                                     18.1.0-1nodesource1 600
                                     18.0.0-1nodesource1 600
                                     12.22.12~dfsg-1~deb11u4 500
                                        500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                        500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                find: '/opt/iobroker/node_modules': No such file or directory
                                No problems detected
                                Errors in npm tree:
                                npm ERR! code ELSPROBLEMS
                                npm ERR! missing: iobroker.admin@6.12.0, required by iobroker.inst@3.0.0
                                npm ERR! missing: iobroker.backitup@2.9.8, required by iobroker.inst@3.0.0
                                npm ERR! missing: iobroker.cloud@4.4.1, required by iobroker.inst@3.0.0
                                npm ERR! missing: iobroker.discovery@4.2.0, required by iobroker.inst@3.0.0
                                npm ERR! missing: iobroker.echarts@1.7.2, required by iobroker.inst@3.0.0
                                npm ERR! missing: iobroker.evcc@0.1.1, required by iobroker.inst@3.0.0
                                npm ERR! missing: iobroker.fritzdect@2.5.9, required by iobroker.inst@3.0.0
                                npm ERR! missing: iobroker.growatt@3.2.1, required by iobroker.inst@3.0.0
                                npm ERR! missing: iobroker.history@3.0.1, required by iobroker.inst@3.0.0
                                npm ERR! missing: iobroker.homeconnect@1.3.0, required by iobroker.inst@3.0.0
                                npm ERR! missing: iobroker.jarvis@3.1.8, required by iobroker.inst@3.0.0
                                npm ERR! missing: iobroker.javascript@7.1.4, required by iobroker.inst@3.0.0
                                npm ERR! missing: iobroker.js-controller@5.0.17, required by iobroker.inst@3.0.0
                                npm ERR! missing: iobroker.meross@1.17.0, required by iobroker.inst@3.0.0
                                npm ERR! missing: iobroker.net-tools@0.2.0, required by iobroker.inst@3.0.0
                                npm ERR! missing: iobroker.parser@2.0.7, required by iobroker.inst@3.0.0
                                npm ERR! missing: iobroker.ping@1.6.2, required by iobroker.inst@3.0.0
                                npm ERR! missing: iobroker.pvforecast@2.9.1, required by iobroker.inst@3.0.0
                                npm ERR! missing: iobroker.rpi2@1.3.2, required by iobroker.inst@3.0.0
                                npm ERR! missing: iobroker.smartmeter@3.4.0, required by iobroker.inst@3.0.0
                                npm ERR! missing: iobroker.socketio@6.6.0, required by iobroker.inst@3.0.0
                                npm ERR! missing: iobroker.terminal@1.0.0, required by iobroker.inst@3.0.0
                                npm ERR! missing: iobroker.tibberlink@2.0.0, required by iobroker.inst@3.0.0
                                npm ERR! missing: iobroker.tuya@3.15.0, required by iobroker.inst@3.0.0
                                npm ERR! missing: iobroker.vis@1.5.4, required by iobroker.inst@3.0.0
                                npm ERR! missing: iobroker.web@6.1.10, required by iobroker.inst@3.0.0
                                npm ERR! missing: iobroker.ws@2.5.8, required by iobroker.inst@3.0.0
                                npm ERR! missing: node-forge@^1.3.1, required by iobroker.inst@3.0.0
                                npm ERR! A complete log of this run can be found in: /home/ulli/.npm/_logs/2024-01-22T18_00_50_882Z-debug-0.log
                                *** ioBroker-Installation ***
                                ioBroker Status
                                  throw err;
                                  requireStack: []
                                Node.js v18.19.0
                                Core adapters versions
                                  throw err;
                                  requireStack: []
                                Node.js v18.19.0
                                js-controller:
                                  throw err;
                                  requireStack: []
                                Node.js v18.19.0
                                admin:
                                  throw err;
                                  requireStack: []
                                Node.js v18.19.0
                                javascript:
                                npm ERR! A complete log of this run can be found in: /home/ulli/.npm/_logs/2024-01-22T18_00_53_223Z-debug-0.log
                                Adapters from github:   0
                                Adapter State
                                  throw err;
                                  requireStack: []
                                Node.js v18.19.0
                                  throw err;
                                  requireStack: []
                                Node.js v18.19.0
                                ioBroker-Repositories
                                  throw err;
                                  requireStack: []
                                Node.js v18.19.0
                                Installed ioBroker-Instances
                                  throw err;
                                  requireStack: []
                                Node.js v18.19.0
                                Objects and States
                                Objects:        0
                                States:         0
                                Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                                Hit:2 http://deb.debian.org/debian bullseye InRelease
                                Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                                Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                                Get:5 https://dl.cloudsmith.io/public/evcc/stable/deb/debian bullseye InRelease [5127 B]
                                Hit:6 https://dl.yarnpkg.com/debian stable InRelease
                                Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                                Fetched 5127 B in 2s (2925 B/s)
                                Reading package lists...
                                Pending Updates: 0
                                *** Listening Ports ***
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14598      600/sshd: /usr/sbin
                                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          12272      561/cupsd
                                tcp6       0      0 :::4712                 :::*                    LISTEN      116        15382      566/evcc
                                tcp6       0      0 :::7070                 :::*                    LISTEN      116        17751      566/evcc
                                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          12271      561/cupsd
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          14600      600/sshd: /usr/sbin
                                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1972       506/dhcpcd
                                udp        0      0 0.0.0.0:39128           0.0.0.0:*                           108        1869       431/avahi-daemon: r
                                udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14632      635/cups-browsed
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        16667      566/evcc
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1867       431/avahi-daemon: r
                                udp6       0      0 :::47247                :::*                                108        1870       431/avahi-daemon: r
                                udp6       0      0 :::546                  :::*                                0          1984       506/dhcpcd
                                udp6       0      0 :::5353                 :::*                                116        16668      566/evcc
                                udp6       0      0 :::5353                 :::*                                108        1868       431/avahi-daemon: r
                                2024-01-13 12:30:55.092  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
                                2024-01-13 12:30:55.093  - info: host.raspberrypi stopInstance system.adapter.ping.0 killing pid 1094779
                                2024-01-13 12:30:55.095  - info: host.raspberrypi stopInstance system.adapter.net-tools.0 killing pid 1094912
                                2024-01-13 12:30:55.095  - info: host.raspberrypi stopInstance system.adapter.web.0 killing pid 1094943
                                2024-01-13 12:30:55.095  - info: host.raspberrypi stopInstance system.adapter.echarts.0 killing pid 1187136
                                2024-01-13 12:30:55.096  - info: host.raspberrypi stopInstance system.adapter.parser.0 killing pid 1095017
                                2024-01-13 12:30:55.136  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                                2024-01-13 12:30:55.137  - info: host.raspberrypi instance system.adapter.socketio.0 terminated with code 0 (NO_ERROR)
                                2024-01-13 12:30:55.139  - info: host.raspberrypi instance system.adapter.terminal.0 terminated with code 0 (NO_ERROR)
                                2024-01-13 12:30:55.228  - info: host.raspberrypi instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
                                2024-01-13 12:30:55.230  - info: host.raspberrypi instance system.adapter.jarvis.0 terminated with code 0 (NO_ERROR)
                                2024-01-13 12:30:55.293  - warn: host.raspberrypi instance system.adapter.parser.0 terminated due to SIGTERM
                                2024-01-13 12:30:55.293  - info: host.raspberrypi instance system.adapter.parser.0 terminated with code null ()
                                2024-01-13 12:30:55.294  - warn: host.raspberrypi instance system.adapter.ping.0 terminated due to SIGTERM
                                2024-01-13 12:30:55.294  - info: host.raspberrypi instance system.adapter.ping.0 terminated with code null ()
                                2024-01-13 12:30:55.365  - warn: host.raspberrypi instance system.adapter.net-tools.0 terminated due to SIGTERM
                                2024-01-13 12:30:55.365  - info: host.raspberrypi instance system.adapter.net-tools.0 terminated with code null ()
                                2024-01-13 12:30:55.366  - warn: host.raspberrypi instance system.adapter.web.0 terminated due to SIGTERM
                                2024-01-13 12:30:55.366  - info: host.raspberrypi instance system.adapter.web.0 terminated with code null ()
                                2024-01-13 12:30:55.366  - warn: host.raspberrypi instance system.adapter.echarts.0 terminated due to SIGTERM
                                2024-01-13 12:30:55.366  - info: host.raspberrypi instance system.adapter.echarts.0 terminated with code null ()
                                2024-01-13 12:30:57.358  - info: host.raspberrypi instance system.adapter.tuya.0 terminated with code 0 (NO_ERROR)
                                2024-01-13 12:30:58.585  - info: host.raspberrypi instance system.adapter.meross.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2024-01-13 12:30:58.586  - info: host.raspberrypi All instances are stopped.
                                2024-01-13 12:30:58.850  - info: host.raspberrypi terminated
                                  @borkenkäfer jepp, dann jag jetzt
                                  @glasfaser sagte in Iobroker lässt sich nicht mehr starten.:
                                  leider nicht hin
                                  sonst
                                  cd /opt/iobroker
                                  Edit :
                                  den Befehl über deine Installation
                                  B Homoran 2 Replies Last reply Reply Quote 0
                                    schon mehrfach ausgeführt
                                    kommt leider
                                    ulli@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                                    npm ERR! Invalid Version:
                                    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-22T18_06_44_901Z-debug-0.log
                                    • Glasfaser
                                      zeige mal den Inhalt davon
                                        Homoran Global Moderator Administrators @Homoran last edited by
                                        @homoran sagte in Iobroker lässt sich nicht mehr starten.:
                                        sudo -H -u iobroker npm install iobroker.js-controller --debug
                                        nach das mal mit debug option. was da die falsche version haben soll
                                          @glasfaser
                                          ist es das hier??
                                          ulli@raspberrypi:/home/iobroker $ cat /home/iobroker/.npm/_logs/2024-01-22T18_06_44_901Z-debug-0.log
                                          0 verbose cli /usr/bin/node /usr/bin/npm
                                          1 info using npm@10.2.3
                                          2 info using node@v18.19.0
                                          3 timing npm:load:whichnode Completed in 3ms
                                          4 timing config:load:defaults Completed in 7ms
                                          5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 12ms
                                          6 timing config:load:builtin Completed in 13ms
                                          7 timing config:load:cli Completed in 15ms
                                          8 timing config:load:env Completed in 1ms
                                          9 timing config:load:file:/opt/iobroker/.npmrc Completed in 5ms
                                          10 timing config:load:project Completed in 8ms
                                          11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
                                          12 timing config:load:user Completed in 1ms
                                          13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
                                          14 timing config:load:global Completed in 1ms
                                          15 timing config:load:setEnvs Completed in 4ms
                                          16 timing config:load Completed in 51ms
                                          17 timing npm:load:configload Completed in 51ms
                                          18 timing config:load:flatten Completed in 9ms
                                          19 timing npm:load:mkdirpcache Completed in 2ms
                                          20 timing npm:load:mkdirplogs Completed in 1ms
                                          21 verbose title npm install iobroker.js-controller
                                          22 verbose argv "install" "iobroker.js-controller"
                                          23 timing npm:load:setTitle Completed in 4ms
                                          24 timing npm:load:display Completed in 2ms
                                          25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2024-01-22T18_06_44_901Z-
                                          26 verbose logfile /home/iobroker/.npm/_logs/2024-01-22T18_06_44_901Z-debug-0.log
                                          27 timing npm:load:logFile Completed in 29ms
                                          28 timing npm:load:timers Completed in 0ms
                                          29 timing npm:load:configScope Completed in 1ms
                                          30 timing npm:load Completed in 147ms
                                          31 timing arborist:ctor Completed in 3ms
                                          32 silly logfile start cleaning logs, removing 1 files
                                          33 silly logfile done cleaning log files
                                          34 timing idealTree:init Completed in 1707ms
                                          35 timing idealTree:userRequests Completed in 5ms
                                          36 silly idealTree buildDeps
                                          37 silly fetch manifest iobroker.js-controller@5.0.17
                                          38 http fetch GET 200 https://registry.npmjs.org/iobroker.js-controller 647ms (cache revalidated)
                                          39 silly placeDep ROOT iobroker.js-controller@5.0.17 REPLACE for: iobroker.inst@3.0.0 want: 5.0.17
                                          40 timing idealTree:#root Completed in 749ms
                                          41 silly fetch manifest esbuild@^0.11.5
                                          42 http fetch GET 200 https://registry.npmjs.org/esbuild 80ms (cache revalidated)
                                          43 silly fetch manifest jsonc-parser@^3.0.0
                                          44 http fetch GET 200 https://registry.npmjs.org/jsonc-parser 70ms (cache revalidated)
                                          45 silly placeDep ROOT esbuild@0.11.23 OK for: @alcalzone/esbuild-register@2.5.1-1 want: ^0.11.5
                                          46 timing idealTree Completed in 2675ms
                                          47 timing command:install Completed in 2708ms
                                          48 verbose stack TypeError: Invalid Version:
                                          48 verbose stack     at new SemVer (/usr/lib/node_modules/npm/node_modules/semver/classes/semver.js:38:13)
                                          48 verbose stack     at compare (/usr/lib/node_modules/npm/node_modules/semver/functions/compare.js:3:32)
                                          48 verbose stack     at Object.gte (/usr/lib/node_modules/npm/node_modules/semver/functions/gte.js:2:30)
                                          48 verbose stack     at Node.canDedupe (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/node.js:1079:32)
                                          48 verbose stack     at PlaceDep.pruneDedupable (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/place-dep.js:426:14)
                                          48 verbose stack     at new PlaceDep (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/place-dep.js:278:14)
                                          48 verbose stack     at #buildDepStep (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:933:18)
                                          48 verbose stack     at async Arborist.buildIdealTree (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:196:7)
                                          48 verbose stack     at async Promise.all (index 1)
                                          48 verbose stack     at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:159:5)
                                          49 verbose cwd /opt/iobroker
                                          50 verbose Linux 6.1.21-v8+
                                          51 verbose node v18.19.0
                                          52 verbose npm  v10.2.3
                                          53 error Invalid Version:
                                          54 verbose exit 1
                                          55 timing npm Completed in 3498ms
                                          56 verbose unfinished npm timer reify 1705946805688
                                          57 verbose unfinished npm timer reify:loadTrees 1705946805706
                                          58 verbose unfinished npm timer idealTree:buildDeps 1705946807423
                                          59 verbose unfinished npm timer idealTree:node_modules/@alcalzone/esbuild-register 1705946808178
                                          60 verbose code 1
                                          61 error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-22T18_06_44_901Z-debug-0.log
                                          Glasfaser B 2 Replies Last reply Reply Quote 0
                                          • Glasfaser
                                            @borkenkäfer
                                            Sehr komisch ..
                                            Teste :
                                            iob stop
                                            rm /opt/iobroker/package*
                                            sudo reboot
                                            danach
                                            cd /opt/iobroker
                                            3683
