    4. Iobroker lässt sich nicht mehr starten.
    • Glasfaser
      Glasfaser @Borkenkäfer last edited by
      @borkenkäfer
      du darfst gere den Befehl ausführen den ich oben gepostet habe ... da geht nichts kapput 🙂
        Borkenkäfer @Glasfaser last edited by
        @glasfaser
        das sollte es sein
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: raspberrypi
                 Icon name: computer
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.2
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : arm64
        Systemuptime and Load:
         19:00:44 up 58 min,  3 users,  load average: 0.00, 0.00, 0.00
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Mon 2024-01-22 19:00:44 CET
                   Universal time: Mon 2024-01-22 18:00:44 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        ulli
        /home/ulli
        ulli adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       true
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            3.8G        298M        2.7G         35M        803M        3.4G
        Swap:            99M          0B         99M
        Total:          3.9G        298M        2.8G
                 3794 M total memory
                  298 M used memory
                  594 M active memory
                  343 M inactive memory
                 2692 M free memory
                   49 M buffer memory
                  753 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4       59G   11G   46G  20% /
        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        tmpfs          tmpfs     759M  1.2M  758M   1% /run
        /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
        tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
        [Mon Jan 22 18:02:06 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:84:9D:5E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a9a74992-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Mon Jan 22 18:02:07 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Mon Jan 22 18:02:07 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Mon Jan 22 18:02:09 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        TARGET  SOURCE         FSTYPE OPTIONS
        /       /dev/mmcblk0p2 ext4   rw,noatime
        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        4.3G    /var/
        3.4G    /var/log
        2.9G    /var/log/journal/b741ffe02a684b9895597ea9866ca817
        641M    /var/cache
        Archived and active journals take up 2.8G in the file system.
        /opt/iobroker/backups:
        687M    /opt/iobroker/backups/
        343M    /opt/iobroker/backups/history
        268M    /opt/iobroker/backups/files
        88M     /opt/iobroker/backups/files/echarts.admin
        57M     /opt/iobroker/backups/files/echarts
        /opt/iobroker/iobroker-data:
        683M    /opt/iobroker/iobroker-data/
        347M    /opt/iobroker/iobroker-data/history
        294M    /opt/iobroker/iobroker-data/files
        89M     /opt/iobroker/iobroker-data/files/echarts.admin
        57M     /opt/iobroker/iobroker-data/files/echarts
        24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
        24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
        23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
        17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b756fe6.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_cc8e9ae92dd3eb11ac2234e8bf09e213-if00-port0
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.0
        /usr/bin/node           v18.19.0
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.0-1nodesource1
          Candidate: 18.19.0-1nodesource1
          Version table:
         *** 18.19.0-1nodesource1 600
                100 /var/lib/dpkg/status
             18.18.2-1nodesource1 600
             18.18.1-1nodesource1 600
             18.18.0-1nodesource1 600
             18.17.1-1nodesource1 600
             18.17.0-1nodesource1 600
             18.16.1-1nodesource1 600
             18.16.0-1nodesource1 600
             18.15.0-1nodesource1 600
             18.14.2-1nodesource1 600
             18.14.1-1nodesource1 600
             18.14.0-1nodesource1 600
             18.13.0-1nodesource1 600
             18.12.0-1nodesource1 600
             18.11.0-1nodesource1 600
             18.10.0-1nodesource1 600
             18.9.1-1nodesource1 600
             18.9.0-1nodesource1 600
             18.8.0-1nodesource1 600
             18.7.0-1nodesource1 600
             18.6.0-1nodesource1 600
             18.5.0-1nodesource1 600
             18.4.0-1nodesource1 600
             18.3.0-1nodesource1 600
             18.2.0-1nodesource1 600
             18.1.0-1nodesource1 600
             18.0.0-1nodesource1 600
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
        find: '/opt/iobroker/node_modules': No such file or directory
        No problems detected
        Errors in npm tree:
        npm ERR! code ELSPROBLEMS
        npm ERR! missing: iobroker.admin@6.12.0, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.backitup@2.9.8, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.cloud@4.4.1, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.discovery@4.2.0, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.echarts@1.7.2, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.evcc@0.1.1, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.fritzdect@2.5.9, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.growatt@3.2.1, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.history@3.0.1, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.homeconnect@1.3.0, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.jarvis@3.1.8, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.javascript@7.1.4, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.js-controller@5.0.17, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.meross@1.17.0, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.net-tools@0.2.0, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.parser@2.0.7, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.ping@1.6.2, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.pvforecast@2.9.1, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.rpi2@1.3.2, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.smartmeter@3.4.0, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.socketio@6.6.0, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.terminal@1.0.0, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.tibberlink@2.0.0, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.tuya@3.15.0, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.vis@1.5.4, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.web@6.1.10, required by iobroker.inst@3.0.0
        npm ERR! missing: iobroker.ws@2.5.8, required by iobroker.inst@3.0.0
        npm ERR! missing: node-forge@^1.3.1, required by iobroker.inst@3.0.0
        npm ERR! A complete log of this run can be found in: /home/ulli/.npm/_logs/2024-01-22T18_00_50_882Z-debug-0.log
        *** ioBroker-Installation ***
        ioBroker Status
        node:internal/modules/cjs/loader:1137
          throw err;
        Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
            at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
            at Module._load (node:internal/modules/cjs/loader:975:27)
            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
            at node:internal/main/run_main_module:28:49 {
          code: 'MODULE_NOT_FOUND',
          requireStack: []
        Node.js v18.19.0
        Core adapters versions
          throw err;
          requireStack: []
        Node.js v18.19.0
        js-controller:
          throw err;
          requireStack: []
        Node.js v18.19.0
        admin:
          throw err;
          requireStack: []
        Node.js v18.19.0
        javascript:
        npm ERR! A complete log of this run can be found in: /home/ulli/.npm/_logs/2024-01-22T18_00_53_223Z-debug-0.log
        Adapters from github:   0
        Adapter State
          throw err;
          requireStack: []
        Node.js v18.19.0
          throw err;
          requireStack: []
        Node.js v18.19.0
        ioBroker-Repositories
          throw err;
          requireStack: []
        Node.js v18.19.0
        Installed ioBroker-Instances
          throw err;
          requireStack: []
        Node.js v18.19.0
        Objects and States
        Objects:        0
        States:         0
        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
        Get:5 https://dl.cloudsmith.io/public/evcc/stable/deb/debian bullseye InRelease [5127 B]
        Hit:6 https://dl.yarnpkg.com/debian stable InRelease
        Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
        Fetched 5127 B in 2s (2925 B/s)
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14598      600/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          12272      561/cupsd
        tcp6       0      0 :::4712                 :::*                    LISTEN      116        15382      566/evcc
        tcp6       0      0 :::7070                 :::*                    LISTEN      116        17751      566/evcc
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          12271      561/cupsd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          14600      600/sshd: /usr/sbin
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1972       506/dhcpcd
        udp        0      0 0.0.0.0:39128           0.0.0.0:*                           108        1869       431/avahi-daemon: r
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14632      635/cups-browsed
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        16667      566/evcc
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1867       431/avahi-daemon: r
        udp6       0      0 :::47247                :::*                                108        1870       431/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          1984       506/dhcpcd
        udp6       0      0 :::5353                 :::*                                116        16668      566/evcc
        udp6       0      0 :::5353                 :::*                                108        1868       431/avahi-daemon: r
        2024-01-13 12:30:55.092  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
        2024-01-13 12:30:55.093  - info: host.raspberrypi stopInstance system.adapter.ping.0 killing pid 1094779
        2024-01-13 12:30:55.095  - info: host.raspberrypi stopInstance system.adapter.net-tools.0 killing pid 1094912
        2024-01-13 12:30:55.095  - info: host.raspberrypi stopInstance system.adapter.web.0 killing pid 1094943
        2024-01-13 12:30:55.095  - info: host.raspberrypi stopInstance system.adapter.echarts.0 killing pid 1187136
        2024-01-13 12:30:55.096  - info: host.raspberrypi stopInstance system.adapter.parser.0 killing pid 1095017
        2024-01-13 12:30:55.136  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
        2024-01-13 12:30:55.137  - info: host.raspberrypi instance system.adapter.socketio.0 terminated with code 0 (NO_ERROR)
        2024-01-13 12:30:55.139  - info: host.raspberrypi instance system.adapter.terminal.0 terminated with code 0 (NO_ERROR)
        2024-01-13 12:30:55.228  - info: host.raspberrypi instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
        2024-01-13 12:30:55.230  - info: host.raspberrypi instance system.adapter.jarvis.0 terminated with code 0 (NO_ERROR)
        2024-01-13 12:30:55.293  - warn: host.raspberrypi instance system.adapter.parser.0 terminated due to SIGTERM
        2024-01-13 12:30:55.293  - info: host.raspberrypi instance system.adapter.parser.0 terminated with code null ()
        2024-01-13 12:30:55.294  - warn: host.raspberrypi instance system.adapter.ping.0 terminated due to SIGTERM
        2024-01-13 12:30:55.294  - info: host.raspberrypi instance system.adapter.ping.0 terminated with code null ()
        2024-01-13 12:30:55.365  - warn: host.raspberrypi instance system.adapter.net-tools.0 terminated due to SIGTERM
        2024-01-13 12:30:55.365  - info: host.raspberrypi instance system.adapter.net-tools.0 terminated with code null ()
        2024-01-13 12:30:55.366  - warn: host.raspberrypi instance system.adapter.web.0 terminated due to SIGTERM
        2024-01-13 12:30:55.366  - info: host.raspberrypi instance system.adapter.web.0 terminated with code null ()
        2024-01-13 12:30:55.366  - warn: host.raspberrypi instance system.adapter.echarts.0 terminated due to SIGTERM
        2024-01-13 12:30:55.366  - info: host.raspberrypi instance system.adapter.echarts.0 terminated with code null ()
        2024-01-13 12:30:57.358  - info: host.raspberrypi instance system.adapter.tuya.0 terminated with code 0 (NO_ERROR)
        2024-01-13 12:30:58.585  - info: host.raspberrypi instance system.adapter.meross.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2024-01-13 12:30:58.586  - info: host.raspberrypi All instances are stopped.
        2024-01-13 12:30:58.850  - info: host.raspberrypi terminated
          Homoran Global Moderator Administrators @Borkenkäfer last edited by
          @borkenkäfer jepp, dann jag jetzt
          @glasfaser sagte in Iobroker lässt sich nicht mehr starten.:
          @borkenkäfer sagte in Iobroker lässt sich nicht mehr starten.:
          leider nicht hin
          wie schon erwähnt die Full Ausgabe wäre besser :
          sonst
          cd /opt/iobroker
          sudo -H -u iobroker npm install iobroker.js-controller
          Edit :
          den Befehl über deine Installation
          B Homoran 2 Replies Last reply Reply Quote 0
            Borkenkäfer @Homoran last edited by
            schon mehrfach ausgeführt
            kommt leider
            ulli@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
            npm ERR! Invalid Version:
            npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-22T18_06_44_901Z-debug-0.log
            • Glasfaser
              zeige mal den Inhalt davon
                Homoran Global Moderator Administrators @Homoran last edited by
                @homoran sagte in Iobroker lässt sich nicht mehr starten.:
                sudo -H -u iobroker npm install iobroker.js-controller --debug
                nach das mal mit debug option. was da die falsche version haben soll
                  @glasfaser
                  ist es das hier??
                  ulli@raspberrypi:/home/iobroker $ cat /home/iobroker/.npm/_logs/2024-01-22T18_06_44_901Z-debug-0.log
                  0 verbose cli /usr/bin/node /usr/bin/npm
                  1 info using npm@10.2.3
                  2 info using node@v18.19.0
                  3 timing npm:load:whichnode Completed in 3ms
                  4 timing config:load:defaults Completed in 7ms
                  5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 12ms
                  6 timing config:load:builtin Completed in 13ms
                  7 timing config:load:cli Completed in 15ms
                  8 timing config:load:env Completed in 1ms
                  9 timing config:load:file:/opt/iobroker/.npmrc Completed in 5ms
                  10 timing config:load:project Completed in 8ms
                  11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
                  12 timing config:load:user Completed in 1ms
                  13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
                  14 timing config:load:global Completed in 1ms
                  15 timing config:load:setEnvs Completed in 4ms
                  16 timing config:load Completed in 51ms
                  17 timing npm:load:configload Completed in 51ms
                  18 timing config:load:flatten Completed in 9ms
                  19 timing npm:load:mkdirpcache Completed in 2ms
                  20 timing npm:load:mkdirplogs Completed in 1ms
                  21 verbose title npm install iobroker.js-controller
                  22 verbose argv "install" "iobroker.js-controller"
                  23 timing npm:load:setTitle Completed in 4ms
                  24 timing npm:load:display Completed in 2ms
                  25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2024-01-22T18_06_44_901Z-
                  26 verbose logfile /home/iobroker/.npm/_logs/2024-01-22T18_06_44_901Z-debug-0.log
                  27 timing npm:load:logFile Completed in 29ms
                  28 timing npm:load:timers Completed in 0ms
                  29 timing npm:load:configScope Completed in 1ms
                  30 timing npm:load Completed in 147ms
                  31 timing arborist:ctor Completed in 3ms
                  32 silly logfile start cleaning logs, removing 1 files
                  33 silly logfile done cleaning log files
                  34 timing idealTree:init Completed in 1707ms
                  35 timing idealTree:userRequests Completed in 5ms
                  36 silly idealTree buildDeps
                  37 silly fetch manifest iobroker.js-controller@5.0.17
                  38 http fetch GET 200 https://registry.npmjs.org/iobroker.js-controller 647ms (cache revalidated)
                  39 silly placeDep ROOT iobroker.js-controller@5.0.17 REPLACE for: iobroker.inst@3.0.0 want: 5.0.17
                  40 timing idealTree:#root Completed in 749ms
                  41 silly fetch manifest esbuild@^0.11.5
                  42 http fetch GET 200 https://registry.npmjs.org/esbuild 80ms (cache revalidated)
                  43 silly fetch manifest jsonc-parser@^3.0.0
                  44 http fetch GET 200 https://registry.npmjs.org/jsonc-parser 70ms (cache revalidated)
                  45 silly placeDep ROOT esbuild@0.11.23 OK for: @alcalzone/esbuild-register@2.5.1-1 want: ^0.11.5
                  46 timing idealTree Completed in 2675ms
                  47 timing command:install Completed in 2708ms
                  48 verbose stack TypeError: Invalid Version:
                  48 verbose stack     at new SemVer (/usr/lib/node_modules/npm/node_modules/semver/classes/semver.js:38:13)
                  48 verbose stack     at compare (/usr/lib/node_modules/npm/node_modules/semver/functions/compare.js:3:32)
                  48 verbose stack     at Object.gte (/usr/lib/node_modules/npm/node_modules/semver/functions/gte.js:2:30)
                  48 verbose stack     at Node.canDedupe (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/node.js:1079:32)
                  48 verbose stack     at PlaceDep.pruneDedupable (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/place-dep.js:426:14)
                  48 verbose stack     at new PlaceDep (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/place-dep.js:278:14)
                  48 verbose stack     at #buildDepStep (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:933:18)
                  48 verbose stack     at async Arborist.buildIdealTree (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:196:7)
                  48 verbose stack     at async Promise.all (index 1)
                  48 verbose stack     at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:159:5)
                  49 verbose cwd /opt/iobroker
                  50 verbose Linux 6.1.21-v8+
                  51 verbose node v18.19.0
                  52 verbose npm  v10.2.3
                  53 error Invalid Version:
                  54 verbose exit 1
                  55 timing npm Completed in 3498ms
                  56 verbose unfinished npm timer reify 1705946805688
                  57 verbose unfinished npm timer reify:loadTrees 1705946805706
                  58 verbose unfinished npm timer idealTree:buildDeps 1705946807423
                  59 verbose unfinished npm timer idealTree:node_modules/@alcalzone/esbuild-register 1705946808178
                  60 verbose code 1
                  61 error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-22T18_06_44_901Z-debug-0.log
                  Glasfaser B 2 Replies Last reply Reply Quote 0
                  • Glasfaser
                    @borkenkäfer
                    Sehr komisch ..
                    Teste :
                    iob stop
                    rm /opt/iobroker/package*
                    sudo reboot
                    danach
                    cd /opt/iobroker
                      Borkenkäfer @Borkenkäfer last edited by
                      @borkenkäfer said in Iobroker lässt sich nicht mehr starten.:
                      @glasfaser
                      ist es das hier??
                      54 verbose exit 1
                      60 verbose code 1
                      Muß für Heute leider schluß machen
                      Melde mich morgen wieder
                      danke für Eure Hilfe
                      • Glasfaser
                        http fetch GET 200
                        Da stimmt auch etwas nicht !
                        https://forum.iobroker.net/post/441199
                          @glasfaser
                          es kommt das
                          npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                          npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                          npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                          added 299 packages in 1m
                          14 packages are looking for funding
                            run `npm fund` for details
                          mikeal created this issue in request/request
                          open Request’s Past, Present and Future #3142
                          • Glasfaser
                            Glasfaser @Borkenkäfer last edited by Glasfaser
                            @borkenkäfer
                            sieht gut aus !
                            ... und Funktioniert es wieder !?
                              @glasfaser
                              nach iob start komme ich über port 8081 noch nicht drauf
                              • Glasfaser
                                @borkenkäfer
                                Full
                                iob diag
                                zeigen !
                                  @glasfaser
                                  und bei iob Update kommt
                                  iob update
                                    throw err;
                                    requireStack: []
                                  Node.js v18.19.0
                                    @glasfaser
                                    einmal full
                                    Skript v.2023-10-10
                                    *** BASE SYSTEM ***
                                             Icon name: computer
                                          Architecture: arm64
                                    Docker          : false
                                    Kernel          : aarch64
                                    Userland        : arm64
                                     19:36:21 up 12 min,  3 users,  load average: 0.03, 0.24, 0.27
                                    CPU threads: 4
                                    Current issues:
                                                   Local time: Mon 2024-01-22 19:36:21 CET
                                               Universal time: Mon 2024-01-22 18:36:21 UTC
                                                     RTC time: n/a
                                                  NTP service: active
                                              RTC in local TZ: no
                                    ulli
                                    /home/ulli
                                    X-Server:       true
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Mem:            3.8G        284M        2.7G         38M        855M        3.4G
                                    Swap:            99M          0B         99M
                                    Total:          3.9G        284M        2.8G
                                             3794 M total memory
                                              284 M used memory
                                              583 M active memory
                                              396 M inactive memory
                                             2654 M free memory
                                               54 M buffer memory
                                              800 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    Raspberry only:
                                    oom events: 0
                                    *** FILESYSTEM ***
                                    [Mon Jan 22 19:23:53 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:84:9D:5E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a9a74992-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                    [Mon Jan 22 19:23:54 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                    [Mon Jan 22 19:23:54 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                    [Mon Jan 22 19:23:56 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                    /var:
                                    4.3G    /var/
                                    3.4G    /var/log
                                    641M    /var/cache
                                    USB-Devices by-id:
                                    /usr/bin/npm            10.2.3
                                    /usr/bin/npx            10.2.3
                                    nodejs:
                                      Version table:
                                    Errors in npm tree:
                                    ioBroker Status
                                      throw err;
                                      requireStack: []
                                    Node.js v18.19.0
                                      throw err;
                                      requireStack: []
                                    Node.js v18.19.0
                                    js-controller:
                                      throw err;
                                      requireStack: []
                                    Node.js v18.19.0
                                    admin:
                                      throw err;
                                      requireStack: []
                                    Node.js v18.19.0
                                    javascript:
                                    Adapter State
                                      throw err;
                                      requireStack: []
                                    Node.js v18.19.0
                                      throw err;
                                      requireStack: []
                                    Node.js v18.19.0
                                      throw err;
                                      requireStack: []
                                    Node.js v18.19.0
                                      throw err;
                                      requireStack: []
                                    Node.js v18.19.0
                                    Objects and States
                                    Objects:        0
                                    States:         0
                                    Hit:1 http://deb.debian.org/debian bullseye InRelease
                                    Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                                    Fetched 5127 B in 2s (2790 B/s)
                                    Pending Updates: 0
                                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14242      600/sshd: /usr/sbin
                                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          12977      557/cupsd
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          14253      600/sshd: /usr/sbin
                                    tcp6       0      0 :::4712                 :::*                    LISTEN      116        15709      576/evcc
                                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          12976      557/cupsd
                                    tcp6       0      0 :::7070                 :::*                    LISTEN      116        15075      576/evcc
                                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12997      572/dhcpcd
                                    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          12989      622/cups-browsed
                                    udp        0      0 0.0.0.0:54194           0.0.0.0:*                           108        15460      386/avahi-daemon: r
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        17496      576/evcc
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15458      386/avahi-daemon: r
                                    udp6       0      0 :::546                  :::*                                0          13016      572/dhcpcd
                                    udp6       0      0 :::50063                :::*                                108        15461      386/avahi-daemon: r
                                    udp6       0      0 :::5353                 :::*                                116        17497      576/evcc
                                    udp6       0      0 :::5353                 :::*                                108        15459      386/avahi-daemon: r
                                    2024-01-22 19:29:28.262  - info: host.raspberrypi stopInstance system.adapter.ping.0 (force=false, process=false)
                                    2024-01-22 19:29:28.262  - info: host.raspberrypi stopInstance system.adapter.meross.0 (force=false, process=false)
                                    2024-01-22 19:29:28.262  - info: host.raspberrypi stopInstance system.adapter.rpi2.0 (force=false, process=false)
                                    2024-01-22 19:29:28.263  - info: host.raspberrypi stopInstance system.adapter.tuya.0 (force=false, process=false)
                                    2024-01-22 19:29:28.263  - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=false)
                                    2024-01-22 19:29:28.264  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=false)
                                    2024-01-22 19:29:28.265  - info: host.raspberrypi stopInstance system.adapter.net-tools.0 (force=false, process=false)
                                    2024-01-22 19:29:28.265  - info: host.raspberrypi stopInstance system.adapter.fritzdect.0 (force=false, process=false)
                                    2024-01-22 19:29:28.265  - info: host.raspberrypi stopInstance system.adapter.web.0 (force=false, process=false)
                                    2024-01-22 19:29:28.266  - info: host.raspberrypi stopInstance system.adapter.jarvis.0 (force=false, process=false)
                                    2024-01-22 19:29:28.266  - info: host.raspberrypi stopInstance system.adapter.vis.0 (force=false, process=false)
                                    2024-01-22 19:29:28.267  - info: host.raspberrypi stopInstance system.adapter.echarts.0 (force=false, process=false)
                                    2024-01-22 19:29:28.267  - info: host.raspberrypi stopInstance system.adapter.parser.0 (force=false, process=false)
                                    2024-01-22 19:29:28.267  - info: host.raspberrypi stopInstance system.adapter.simple-api.0 (force=false, process=false)
                                    2024-01-22 19:29:28.268  - info: host.raspberrypi stopInstance system.adapter.socketio.0 (force=false, process=false)
                                    2024-01-22 19:29:28.268  - info: host.raspberrypi stopInstance system.adapter.growatt.0 (force=false, process=false)
                                    2024-01-22 19:29:28.268  - info: host.raspberrypi stopInstance system.adapter.terminal.0 (force=false, process=false)
                                    2024-01-22 19:29:28.269  - info: host.raspberrypi stopInstance system.adapter.cloud.0 (force=false, process=false)
                                    2024-01-22 19:29:28.269  - info: host.raspberrypi stopInstance system.adapter.pvforecast.0 (force=false, process=false)
                                    2024-01-22 19:29:28.269  - info: host.raspberrypi stopInstance system.adapter.evcc.0 (force=false, process=false)
                                    2024-01-22 19:29:28.269  - info: host.raspberrypi stopInstance system.adapter.homeconnect.0 (force=false, process=false)
                                    2024-01-22 19:29:28.270  - info: host.raspberrypi stopInstance system.adapter.tibberlink.0 (force=false, process=false)
                                    2024-01-22 19:29:28.752  - info: host.raspberrypi terminated
                                    2024-01-22 19:29:29.215  - warn: host.raspberrypi startInstance cannot find adapter "history@3.0.1". Try to install it... 1 attempt
                                    2024-01-22 19:29:29.216  - info: host.raspberrypi iobroker install history@3.0.1 using installedFrom
                                    Glasfaser 2 Replies Last reply Reply Quote 0
                                    • Glasfaser
                                      @borkenkäfer
                                      nochmal
                                      cd /opt/iobroker
                                      npm cache clean --force
                                      • Glasfaser
                                        Hast du das Steckernetzteil gezogen !?
                                        EDIT :
                                        bzw. ein root Mount
                                          @glasfaser
                                          Guten Abend
                                          Meldung nach cache clean
                                          ulli@raspberrypi:/opt/iobroker $ npm cache clean --force
                                          npm WARN using --force Recommended protections disabled.
                                          ulli@raspberrypi:/opt/iobroker $ sudo npm cache clean --force
                                            Thomas Braun Most Active @Borkenkäfer last edited by
                                            @borkenkäfer
                                            Wo stand denn was von sudo? Finger weg von root-Rechten, wenn es nicht unbedingt erforderlich ist.
                                            cd /opt/iobroker
                                            sagt nun?
                                            3684
