    4. Iobroker lässt sich nicht mehr starten.
      Borkenkäfer @Glasfaser last edited by
      @glasfaser
      das sollte es sein
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.2
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       19:00:44 up 58 min,  3 users,  load average: 0.00, 0.00, 0.00
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Mon 2024-01-22 19:00:44 CET
                 Universal time: Mon 2024-01-22 18:00:44 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      ulli
      /home/ulli
      ulli adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            3.8G        298M        2.7G         35M        803M        3.4G
      Swap:            99M          0B         99M
      Total:          3.9G        298M        2.8G
               3794 M total memory
                298 M used memory
                594 M active memory
                343 M inactive memory
               2692 M free memory
                 49 M buffer memory
                753 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      /dev/root      ext4       59G   11G   46G  20% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     759M  1.2M  758M   1% /run
      /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
      tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
      [Mon Jan 22 18:02:06 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:84:9D:5E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a9a74992-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Mon Jan 22 18:02:07 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Mon Jan 22 18:02:07 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Mon Jan 22 18:02:09 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      4.3G    /var/
      3.4G    /var/log
      2.9G    /var/log/journal/b741ffe02a684b9895597ea9866ca817
      641M    /var/cache
      Archived and active journals take up 2.8G in the file system.
      /opt/iobroker/backups:
      687M    /opt/iobroker/backups/
      343M    /opt/iobroker/backups/history
      268M    /opt/iobroker/backups/files
      88M     /opt/iobroker/backups/files/echarts.admin
      57M     /opt/iobroker/backups/files/echarts
      /opt/iobroker/iobroker-data:
      683M    /opt/iobroker/iobroker-data/
      347M    /opt/iobroker/iobroker-data/history
      294M    /opt/iobroker/iobroker-data/files
      89M     /opt/iobroker/iobroker-data/files/echarts.admin
      57M     /opt/iobroker/iobroker-data/files/echarts
      24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
      23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b756fe6.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_cc8e9ae92dd3eb11ac2234e8bf09e213-if00-port0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 600
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 600
           18.18.1-1nodesource1 600
           18.18.0-1nodesource1 600
           18.17.1-1nodesource1 600
           18.17.0-1nodesource1 600
           18.16.1-1nodesource1 600
           18.16.0-1nodesource1 600
           18.15.0-1nodesource1 600
           18.14.2-1nodesource1 600
           18.14.1-1nodesource1 600
           18.14.0-1nodesource1 600
           18.13.0-1nodesource1 600
           18.12.0-1nodesource1 600
           18.11.0-1nodesource1 600
           18.10.0-1nodesource1 600
           18.9.1-1nodesource1 600
           18.9.0-1nodesource1 600
           18.8.0-1nodesource1 600
           18.7.0-1nodesource1 600
           18.6.0-1nodesource1 600
           18.5.0-1nodesource1 600
           18.4.0-1nodesource1 600
           18.3.0-1nodesource1 600
           18.2.0-1nodesource1 600
           18.1.0-1nodesource1 600
           18.0.0-1nodesource1 600
           12.22.12~dfsg-1~deb11u4 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
      find: '/opt/iobroker/node_modules': No such file or directory
      No problems detected
      Errors in npm tree:
      npm ERR! code ELSPROBLEMS
      npm ERR! missing: iobroker.admin@6.12.0, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.backitup@2.9.8, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.cloud@4.4.1, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.discovery@4.2.0, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.echarts@1.7.2, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.evcc@0.1.1, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.fritzdect@2.5.9, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.growatt@3.2.1, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.history@3.0.1, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.homeconnect@1.3.0, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.jarvis@3.1.8, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.javascript@7.1.4, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.js-controller@5.0.17, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.meross@1.17.0, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.net-tools@0.2.0, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.parser@2.0.7, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.ping@1.6.2, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.pvforecast@2.9.1, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.rpi2@1.3.2, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.smartmeter@3.4.0, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.socketio@6.6.0, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.terminal@1.0.0, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.tibberlink@2.0.0, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.tuya@3.15.0, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.vis@1.5.4, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.web@6.1.10, required by iobroker.inst@3.0.0
      npm ERR! missing: iobroker.ws@2.5.8, required by iobroker.inst@3.0.0
      npm ERR! missing: node-forge@^1.3.1, required by iobroker.inst@3.0.0
      npm ERR! A complete log of this run can be found in: /home/ulli/.npm/_logs/2024-01-22T18_00_50_882Z-debug-0.log
      *** ioBroker-Installation ***
      ioBroker Status
      node:internal/modules/cjs/loader:1137
        throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
          at Module._load (node:internal/modules/cjs/loader:975:27)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
          at node:internal/main/run_main_module:28:49 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      Node.js v18.19.0
      Core adapters versions
        throw err;
        requireStack: []
      Node.js v18.19.0
      js-controller:
        throw err;
        requireStack: []
      Node.js v18.19.0
      admin:
        throw err;
        requireStack: []
      Node.js v18.19.0
      javascript:
      npm ERR! A complete log of this run can be found in: /home/ulli/.npm/_logs/2024-01-22T18_00_53_223Z-debug-0.log
      Adapters from github:   0
      Adapter State
        throw err;
        requireStack: []
      Node.js v18.19.0
        throw err;
        requireStack: []
      Node.js v18.19.0
      ioBroker-Repositories
        throw err;
        requireStack: []
      Node.js v18.19.0
      Installed ioBroker-Instances
        throw err;
        requireStack: []
      Node.js v18.19.0
      Objects and States
      Objects:        0
      States:         0
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
      Get:5 https://dl.cloudsmith.io/public/evcc/stable/deb/debian bullseye InRelease [5127 B]
      Hit:6 https://dl.yarnpkg.com/debian stable InRelease
      Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
      Fetched 5127 B in 2s (2925 B/s)
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14598      600/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          12272      561/cupsd
      tcp6       0      0 :::4712                 :::*                    LISTEN      116        15382      566/evcc
      tcp6       0      0 :::7070                 :::*                    LISTEN      116        17751      566/evcc
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          12271      561/cupsd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14600      600/sshd: /usr/sbin
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          1972       506/dhcpcd
      udp        0      0 0.0.0.0:39128           0.0.0.0:*                           108        1869       431/avahi-daemon: r
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          14632      635/cups-browsed
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        16667      566/evcc
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        1867       431/avahi-daemon: r
      udp6       0      0 :::47247                :::*                                108        1870       431/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          1984       506/dhcpcd
      udp6       0      0 :::5353                 :::*                                116        16668      566/evcc
      udp6       0      0 :::5353                 :::*                                108        1868       431/avahi-daemon: r
      2024-01-13 12:30:55.092  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
      2024-01-13 12:30:55.093  - info: host.raspberrypi stopInstance system.adapter.ping.0 killing pid 1094779
      2024-01-13 12:30:55.095  - info: host.raspberrypi stopInstance system.adapter.net-tools.0 killing pid 1094912
      2024-01-13 12:30:55.095  - info: host.raspberrypi stopInstance system.adapter.web.0 killing pid 1094943
      2024-01-13 12:30:55.095  - info: host.raspberrypi stopInstance system.adapter.echarts.0 killing pid 1187136
      2024-01-13 12:30:55.096  - info: host.raspberrypi stopInstance system.adapter.parser.0 killing pid 1095017
      2024-01-13 12:30:55.136  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
      2024-01-13 12:30:55.137  - info: host.raspberrypi instance system.adapter.socketio.0 terminated with code 0 (NO_ERROR)
      2024-01-13 12:30:55.139  - info: host.raspberrypi instance system.adapter.terminal.0 terminated with code 0 (NO_ERROR)
      2024-01-13 12:30:55.228  - info: host.raspberrypi instance system.adapter.history.0 terminated with code 0 (NO_ERROR)
      2024-01-13 12:30:55.230  - info: host.raspberrypi instance system.adapter.jarvis.0 terminated with code 0 (NO_ERROR)
      2024-01-13 12:30:55.293  - warn: host.raspberrypi instance system.adapter.parser.0 terminated due to SIGTERM
      2024-01-13 12:30:55.293  - info: host.raspberrypi instance system.adapter.parser.0 terminated with code null ()
      2024-01-13 12:30:55.294  - warn: host.raspberrypi instance system.adapter.ping.0 terminated due to SIGTERM
      2024-01-13 12:30:55.294  - info: host.raspberrypi instance system.adapter.ping.0 terminated with code null ()
      2024-01-13 12:30:55.365  - warn: host.raspberrypi instance system.adapter.net-tools.0 terminated due to SIGTERM
      2024-01-13 12:30:55.365  - info: host.raspberrypi instance system.adapter.net-tools.0 terminated with code null ()
      2024-01-13 12:30:55.366  - warn: host.raspberrypi instance system.adapter.web.0 terminated due to SIGTERM
      2024-01-13 12:30:55.366  - info: host.raspberrypi instance system.adapter.web.0 terminated with code null ()
      2024-01-13 12:30:55.366  - warn: host.raspberrypi instance system.adapter.echarts.0 terminated due to SIGTERM
      2024-01-13 12:30:55.366  - info: host.raspberrypi instance system.adapter.echarts.0 terminated with code null ()
      2024-01-13 12:30:57.358  - info: host.raspberrypi instance system.adapter.tuya.0 terminated with code 0 (NO_ERROR)
      2024-01-13 12:30:58.585  - info: host.raspberrypi instance system.adapter.meross.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-01-13 12:30:58.586  - info: host.raspberrypi All instances are stopped.
      2024-01-13 12:30:58.850  - info: host.raspberrypi terminated
        Homoran Global Moderator Administrators @Borkenkäfer last edited by
        @borkenkäfer jepp, dann jag jetzt
        @glasfaser sagte in Iobroker lässt sich nicht mehr starten.:
        @borkenkäfer sagte in Iobroker lässt sich nicht mehr starten.:
        leider nicht hin
        wie schon erwähnt die Full Ausgabe wäre besser :
        sonst
        cd /opt/iobroker
        sudo -H -u iobroker npm install iobroker.js-controller
        Edit :
        den Befehl über deine Installation
        B Homoran 2 Replies Last reply Reply Quote 0
          Borkenkäfer @Homoran last edited by
          schon mehrfach ausgeführt
          kommt leider
          ulli@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
          npm ERR! Invalid Version:
          npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-22T18_06_44_901Z-debug-0.log
          • Glasfaser
            Glasfaser @Borkenkäfer last edited by
            zeige mal den Inhalt davon
              Homoran Global Moderator Administrators @Homoran last edited by
              @homoran sagte in Iobroker lässt sich nicht mehr starten.:
              sudo -H -u iobroker npm install iobroker.js-controller --debug
              nach das mal mit debug option. was da die falsche version haben soll
                @glasfaser
                ist es das hier??
                ulli@raspberrypi:/home/iobroker $ cat /home/iobroker/.npm/_logs/2024-01-22T18_06_44_901Z-debug-0.log
                0 verbose cli /usr/bin/node /usr/bin/npm
                1 info using npm@10.2.3
                2 info using node@v18.19.0
                3 timing npm:load:whichnode Completed in 3ms
                4 timing config:load:defaults Completed in 7ms
                5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 12ms
                6 timing config:load:builtin Completed in 13ms
                7 timing config:load:cli Completed in 15ms
                8 timing config:load:env Completed in 1ms
                9 timing config:load:file:/opt/iobroker/.npmrc Completed in 5ms
                10 timing config:load:project Completed in 8ms
                11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
                12 timing config:load:user Completed in 1ms
                13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
                14 timing config:load:global Completed in 1ms
                15 timing config:load:setEnvs Completed in 4ms
                16 timing config:load Completed in 51ms
                17 timing npm:load:configload Completed in 51ms
                18 timing config:load:flatten Completed in 9ms
                19 timing npm:load:mkdirpcache Completed in 2ms
                20 timing npm:load:mkdirplogs Completed in 1ms
                21 verbose title npm install iobroker.js-controller
                22 verbose argv "install" "iobroker.js-controller"
                23 timing npm:load:setTitle Completed in 4ms
                24 timing npm:load:display Completed in 2ms
                25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2024-01-22T18_06_44_901Z-
                26 verbose logfile /home/iobroker/.npm/_logs/2024-01-22T18_06_44_901Z-debug-0.log
                27 timing npm:load:logFile Completed in 29ms
                28 timing npm:load:timers Completed in 0ms
                29 timing npm:load:configScope Completed in 1ms
                30 timing npm:load Completed in 147ms
                31 timing arborist:ctor Completed in 3ms
                32 silly logfile start cleaning logs, removing 1 files
                33 silly logfile done cleaning log files
                34 timing idealTree:init Completed in 1707ms
                35 timing idealTree:userRequests Completed in 5ms
                36 silly idealTree buildDeps
                37 silly fetch manifest iobroker.js-controller@5.0.17
                38 http fetch GET 200 https://registry.npmjs.org/iobroker.js-controller 647ms (cache revalidated)
                39 silly placeDep ROOT iobroker.js-controller@5.0.17 REPLACE for: iobroker.inst@3.0.0 want: 5.0.17
                40 timing idealTree:#root Completed in 749ms
                41 silly fetch manifest esbuild@^0.11.5
                42 http fetch GET 200 https://registry.npmjs.org/esbuild 80ms (cache revalidated)
                43 silly fetch manifest jsonc-parser@^3.0.0
                44 http fetch GET 200 https://registry.npmjs.org/jsonc-parser 70ms (cache revalidated)
                45 silly placeDep ROOT esbuild@0.11.23 OK for: @alcalzone/esbuild-register@2.5.1-1 want: ^0.11.5
                46 timing idealTree Completed in 2675ms
                47 timing command:install Completed in 2708ms
                48 verbose stack TypeError: Invalid Version:
                48 verbose stack     at new SemVer (/usr/lib/node_modules/npm/node_modules/semver/classes/semver.js:38:13)
                48 verbose stack     at compare (/usr/lib/node_modules/npm/node_modules/semver/functions/compare.js:3:32)
                48 verbose stack     at Object.gte (/usr/lib/node_modules/npm/node_modules/semver/functions/gte.js:2:30)
                48 verbose stack     at Node.canDedupe (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/node.js:1079:32)
                48 verbose stack     at PlaceDep.pruneDedupable (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/place-dep.js:426:14)
                48 verbose stack     at new PlaceDep (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/place-dep.js:278:14)
                48 verbose stack     at #buildDepStep (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:933:18)
                48 verbose stack     at async Arborist.buildIdealTree (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:196:7)
                48 verbose stack     at async Promise.all (index 1)
                48 verbose stack     at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:159:5)
                49 verbose cwd /opt/iobroker
                50 verbose Linux 6.1.21-v8+
                51 verbose node v18.19.0
                52 verbose npm  v10.2.3
                53 error Invalid Version:
                54 verbose exit 1
                55 timing npm Completed in 3498ms
                56 verbose unfinished npm timer reify 1705946805688
                57 verbose unfinished npm timer reify:loadTrees 1705946805706
                58 verbose unfinished npm timer idealTree:buildDeps 1705946807423
                59 verbose unfinished npm timer idealTree:node_modules/@alcalzone/esbuild-register 1705946808178
                60 verbose code 1
                61 error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-22T18_06_44_901Z-debug-0.log
                Glasfaser B 2 Replies Last reply Reply Quote 0
                • Glasfaser
                  @borkenkäfer
                  Sehr komisch ..
                  Teste :
                  iob stop
                  rm /opt/iobroker/package*
                  sudo reboot
                  danach
                  cd /opt/iobroker
                    Borkenkäfer @Borkenkäfer last edited by
                    @borkenkäfer said in Iobroker lässt sich nicht mehr starten.:
                    @glasfaser
                    ist es das hier??
                    54 verbose exit 1
                    60 verbose code 1
                    Muß für Heute leider schluß machen
                    Melde mich morgen wieder
                    danke für Eure Hilfe
                    • Glasfaser
                      http fetch GET 200
                      Da stimmt auch etwas nicht !
                      https://forum.iobroker.net/post/441199
                        @glasfaser
                        es kommt das
                        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                        added 299 packages in 1m
                        14 packages are looking for funding
                          run `npm fund` for details
                        • Glasfaser
                          Glasfaser @Borkenkäfer last edited by Glasfaser
                          @borkenkäfer
                          sieht gut aus !
                          ... und Funktioniert es wieder !?
                            @glasfaser
                            nach iob start komme ich über port 8081 noch nicht drauf
                            • Glasfaser
                              @borkenkäfer
                              Full
                              iob diag
                              zeigen !
                                @glasfaser
                                und bei iob Update kommt
                                iob update
                                  throw err;
                                  requireStack: []
                                Node.js v18.19.0
                                  @glasfaser
                                  einmal full
                                  Skript v.2023-10-10
                                  *** BASE SYSTEM ***
                                           Icon name: computer
                                        Architecture: arm64
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : arm64
                                   19:36:21 up 12 min,  3 users,  load average: 0.03, 0.24, 0.27
                                  CPU threads: 4
                                  Current issues:
                                                 Local time: Mon 2024-01-22 19:36:21 CET
                                             Universal time: Mon 2024-01-22 18:36:21 UTC
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  ulli
                                  /home/ulli
                                  X-Server:       true
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Mem:            3.8G        284M        2.7G         38M        855M        3.4G
                                  Swap:            99M          0B         99M
                                  Total:          3.9G        284M        2.8G
                                           3794 M total memory
                                            284 M used memory
                                            583 M active memory
                                            396 M inactive memory
                                           2654 M free memory
                                             54 M buffer memory
                                            800 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FILESYSTEM ***
                                  [Mon Jan 22 19:23:53 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:84:9D:5E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a9a74992-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                                  [Mon Jan 22 19:23:54 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                  [Mon Jan 22 19:23:54 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                  [Mon Jan 22 19:23:56 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                  /var:
                                  4.3G    /var/
                                  3.4G    /var/log
                                  641M    /var/cache
                                  USB-Devices by-id:
                                  /usr/bin/npm            10.2.3
                                  /usr/bin/npx            10.2.3
                                  nodejs:
                                    Version table:
                                  Errors in npm tree:
                                  ioBroker Status
                                    throw err;
                                    requireStack: []
                                  Node.js v18.19.0
                                    throw err;
                                    requireStack: []
                                  Node.js v18.19.0
                                  js-controller:
                                    throw err;
                                    requireStack: []
                                  Node.js v18.19.0
                                  admin:
                                    throw err;
                                    requireStack: []
                                  Node.js v18.19.0
                                  javascript:
                                  Adapter State
                                    throw err;
                                    requireStack: []
                                  Node.js v18.19.0
                                    throw err;
                                    requireStack: []
                                  Node.js v18.19.0
                                    throw err;
                                    requireStack: []
                                  Node.js v18.19.0
                                    throw err;
                                    requireStack: []
                                  Node.js v18.19.0
                                  Objects and States
                                  Objects:        0
                                  States:         0
                                  Hit:1 http://deb.debian.org/debian bullseye InRelease
                                  Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                                  Fetched 5127 B in 2s (2790 B/s)
                                  Pending Updates: 0
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14242      600/sshd: /usr/sbin
                                  tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          12977      557/cupsd
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          14253      600/sshd: /usr/sbin
                                  tcp6       0      0 :::4712                 :::*                    LISTEN      116        15709      576/evcc
                                  tcp6       0      0 ::1:631                 :::*                    LISTEN      0          12976      557/cupsd
                                  tcp6       0      0 :::7070                 :::*                    LISTEN      116        15075      576/evcc
                                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12997      572/dhcpcd
                                  udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          12989      622/cups-browsed
                                  udp        0      0 0.0.0.0:54194           0.0.0.0:*                           108        15460      386/avahi-daemon: r
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        17496      576/evcc
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15458      386/avahi-daemon: r
                                  udp6       0      0 :::546                  :::*                                0          13016      572/dhcpcd
                                  udp6       0      0 :::50063                :::*                                108        15461      386/avahi-daemon: r
                                  udp6       0      0 :::5353                 :::*                                116        17497      576/evcc
                                  udp6       0      0 :::5353                 :::*                                108        15459      386/avahi-daemon: r
                                  2024-01-22 19:29:28.262  - info: host.raspberrypi stopInstance system.adapter.ping.0 (force=false, process=false)
                                  2024-01-22 19:29:28.262  - info: host.raspberrypi stopInstance system.adapter.meross.0 (force=false, process=false)
                                  2024-01-22 19:29:28.262  - info: host.raspberrypi stopInstance system.adapter.rpi2.0 (force=false, process=false)
                                  2024-01-22 19:29:28.263  - info: host.raspberrypi stopInstance system.adapter.tuya.0 (force=false, process=false)
                                  2024-01-22 19:29:28.263  - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=false)
                                  2024-01-22 19:29:28.264  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=false)
                                  2024-01-22 19:29:28.265  - info: host.raspberrypi stopInstance system.adapter.net-tools.0 (force=false, process=false)
                                  2024-01-22 19:29:28.265  - info: host.raspberrypi stopInstance system.adapter.fritzdect.0 (force=false, process=false)
                                  2024-01-22 19:29:28.265  - info: host.raspberrypi stopInstance system.adapter.web.0 (force=false, process=false)
                                  2024-01-22 19:29:28.266  - info: host.raspberrypi stopInstance system.adapter.jarvis.0 (force=false, process=false)
                                  2024-01-22 19:29:28.266  - info: host.raspberrypi stopInstance system.adapter.vis.0 (force=false, process=false)
                                  2024-01-22 19:29:28.267  - info: host.raspberrypi stopInstance system.adapter.echarts.0 (force=false, process=false)
                                  2024-01-22 19:29:28.267  - info: host.raspberrypi stopInstance system.adapter.parser.0 (force=false, process=false)
                                  2024-01-22 19:29:28.267  - info: host.raspberrypi stopInstance system.adapter.simple-api.0 (force=false, process=false)
                                  2024-01-22 19:29:28.268  - info: host.raspberrypi stopInstance system.adapter.socketio.0 (force=false, process=false)
                                  2024-01-22 19:29:28.268  - info: host.raspberrypi stopInstance system.adapter.growatt.0 (force=false, process=false)
                                  2024-01-22 19:29:28.268  - info: host.raspberrypi stopInstance system.adapter.terminal.0 (force=false, process=false)
                                  2024-01-22 19:29:28.269  - info: host.raspberrypi stopInstance system.adapter.cloud.0 (force=false, process=false)
                                  2024-01-22 19:29:28.269  - info: host.raspberrypi stopInstance system.adapter.pvforecast.0 (force=false, process=false)
                                  2024-01-22 19:29:28.269  - info: host.raspberrypi stopInstance system.adapter.evcc.0 (force=false, process=false)
                                  2024-01-22 19:29:28.269  - info: host.raspberrypi stopInstance system.adapter.homeconnect.0 (force=false, process=false)
                                  2024-01-22 19:29:28.270  - info: host.raspberrypi stopInstance system.adapter.tibberlink.0 (force=false, process=false)
                                  2024-01-22 19:29:28.752  - info: host.raspberrypi terminated
                                  2024-01-22 19:29:29.215  - warn: host.raspberrypi startInstance cannot find adapter "history@3.0.1". Try to install it... 1 attempt
                                  2024-01-22 19:29:29.216  - info: host.raspberrypi iobroker install history@3.0.1 using installedFrom
                                  Glasfaser 2 Replies Last reply Reply Quote 0
                                  • Glasfaser
                                    @borkenkäfer
                                    nochmal
                                    cd /opt/iobroker
                                    npm cache clean --force
                                    • Glasfaser
                                      Hast du das Steckernetzteil gezogen !?
                                      EDIT :
                                      bzw. ein root Mount
                                        @glasfaser
                                        Guten Abend
                                        Meldung nach cache clean
                                        ulli@raspberrypi:/opt/iobroker $ npm cache clean --force
                                        npm WARN using --force Recommended protections disabled.
                                        ulli@raspberrypi:/opt/iobroker $ sudo npm cache clean --force
                                          Thomas Braun Most Active @Borkenkäfer last edited by
                                          @borkenkäfer
                                          Wo stand denn was von sudo? Finger weg von root-Rechten, wenn es nicht unbedingt erforderlich ist.
                                          cd /opt/iobroker
                                          sagt nun?
                                            Borkenkäfer @Thomas Braun last edited by
                                            sorry
                                            meldung
                                            added 289 packages in 1m
                                            15 packages are looking for funding
                                            ulli@raspberrypi:/opt/iobroker $ npm fund
                                            iobroker.core@1.0.0
                                            ├── https://github.com/sponsors/jaredhanson
                                            │   └── passport@0.6.0
                                            ├── https://github.com/sponsors/RubenVerborgh
                                            │   └── follow-redirects@1.15.5
                                            ├── https://opencollective.com/ioredis
                                            │   └── ioredis@4.28.5
                                            ├── https://github.com/sponsors/ljharb
                                            │   └── function-bind@1.1.2
                                            ├─┬ https://github.com/sindresorhus/execa?sponsor=1
                                            │ │ └── execa@5.1.1
                                            │ └── https://github.com/sponsors/sindresorhus
                                            │     └── get-stream@6.0.1, is-stream@2.0.1, onetime@5.1.2
                                            ├─┬ https://paulmillr.com/funding/
                                            │ │ └── chokidar@3.5.3
                                            │ └── https://github.com/sponsors/jonschlinkert
                                            │     └── picomatch@2.3.1
                                            ├─┬ https://github.com/chalk/wrap-ansi?sponsor=1
                                            │ │ └── wrap-ansi@7.0.0
                                            │ └── https://github.com/chalk/ansi-styles?sponsor=1
                                            │     └── ansi-styles@4.3.0
                                            ├── https://github.com/sponsors/sibiraj-s
                                            │   └── ci-info@3.9.0
                                            ├── https://github.com/sponsors/feross
                                            │   └── safe-buffer@5.2.1
                                            └── https://github.com/sponsors/epoberezkin
                                                └── ajv@6.12.6
                                            ulli@raspberrypi:/opt/iobroker $ ^C
                                            3684
