    4. Iobroker lässt sich nicht mehr starten.
      Borkenkäfer @Homoran last edited by
      schon mehrfach ausgeführt
      kommt leider
      ulli@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
      npm ERR! Invalid Version:
      npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-22T18_06_44_901Z-debug-0.log
      • Glasfaser
        Glasfaser @Borkenkäfer last edited by
        @borkenkäfer sagte in Iobroker lässt sich nicht mehr starten.:
        zeige mal den Inhalt davon
          Homoran Global Moderator Administrators @Homoran last edited by
          @homoran sagte in Iobroker lässt sich nicht mehr starten.:
          sudo -H -u iobroker npm install iobroker.js-controller --debug
          nach das mal mit debug option. was da die falsche version haben soll
            Borkenkäfer @Glasfaser last edited by
            @glasfaser
            ist es das hier??
            ulli@raspberrypi:/home/iobroker $ cat /home/iobroker/.npm/_logs/2024-01-22T18_06_44_901Z-debug-0.log
            0 verbose cli /usr/bin/node /usr/bin/npm
            1 info using npm@10.2.3
            2 info using node@v18.19.0
            3 timing npm:load:whichnode Completed in 3ms
            4 timing config:load:defaults Completed in 7ms
            5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 12ms
            6 timing config:load:builtin Completed in 13ms
            7 timing config:load:cli Completed in 15ms
            8 timing config:load:env Completed in 1ms
            9 timing config:load:file:/opt/iobroker/.npmrc Completed in 5ms
            10 timing config:load:project Completed in 8ms
            11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
            12 timing config:load:user Completed in 1ms
            13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
            14 timing config:load:global Completed in 1ms
            15 timing config:load:setEnvs Completed in 4ms
            16 timing config:load Completed in 51ms
            17 timing npm:load:configload Completed in 51ms
            18 timing config:load:flatten Completed in 9ms
            19 timing npm:load:mkdirpcache Completed in 2ms
            20 timing npm:load:mkdirplogs Completed in 1ms
            21 verbose title npm install iobroker.js-controller
            22 verbose argv "install" "iobroker.js-controller"
            23 timing npm:load:setTitle Completed in 4ms
            24 timing npm:load:display Completed in 2ms
            25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2024-01-22T18_06_44_901Z-
            26 verbose logfile /home/iobroker/.npm/_logs/2024-01-22T18_06_44_901Z-debug-0.log
            27 timing npm:load:logFile Completed in 29ms
            28 timing npm:load:timers Completed in 0ms
            29 timing npm:load:configScope Completed in 1ms
            30 timing npm:load Completed in 147ms
            31 timing arborist:ctor Completed in 3ms
            32 silly logfile start cleaning logs, removing 1 files
            33 silly logfile done cleaning log files
            34 timing idealTree:init Completed in 1707ms
            35 timing idealTree:userRequests Completed in 5ms
            36 silly idealTree buildDeps
            37 silly fetch manifest iobroker.js-controller@5.0.17
            38 http fetch GET 200 https://registry.npmjs.org/iobroker.js-controller 647ms (cache revalidated)
            39 silly placeDep ROOT iobroker.js-controller@5.0.17 REPLACE for: iobroker.inst@3.0.0 want: 5.0.17
            40 timing idealTree:#root Completed in 749ms
            41 silly fetch manifest esbuild@^0.11.5
            42 http fetch GET 200 https://registry.npmjs.org/esbuild 80ms (cache revalidated)
            43 silly fetch manifest jsonc-parser@^3.0.0
            44 http fetch GET 200 https://registry.npmjs.org/jsonc-parser 70ms (cache revalidated)
            45 silly placeDep ROOT esbuild@0.11.23 OK for: @alcalzone/esbuild-register@2.5.1-1 want: ^0.11.5
            46 timing idealTree Completed in 2675ms
            47 timing command:install Completed in 2708ms
            48 verbose stack TypeError: Invalid Version:
            48 verbose stack     at new SemVer (/usr/lib/node_modules/npm/node_modules/semver/classes/semver.js:38:13)
            48 verbose stack     at compare (/usr/lib/node_modules/npm/node_modules/semver/functions/compare.js:3:32)
            48 verbose stack     at Object.gte (/usr/lib/node_modules/npm/node_modules/semver/functions/gte.js:2:30)
            48 verbose stack     at Node.canDedupe (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/node.js:1079:32)
            48 verbose stack     at PlaceDep.pruneDedupable (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/place-dep.js:426:14)
            48 verbose stack     at new PlaceDep (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/place-dep.js:278:14)
            48 verbose stack     at #buildDepStep (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:933:18)
            48 verbose stack     at async Arborist.buildIdealTree (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:196:7)
            48 verbose stack     at async Promise.all (index 1)
            48 verbose stack     at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:159:5)
            49 verbose cwd /opt/iobroker
            50 verbose Linux 6.1.21-v8+
            51 verbose node v18.19.0
            52 verbose npm  v10.2.3
            53 error Invalid Version:
            54 verbose exit 1
            55 timing npm Completed in 3498ms
            56 verbose unfinished npm timer reify 1705946805688
            57 verbose unfinished npm timer reify:loadTrees 1705946805706
            58 verbose unfinished npm timer idealTree:buildDeps 1705946807423
            59 verbose unfinished npm timer idealTree:node_modules/@alcalzone/esbuild-register 1705946808178
            60 verbose code 1
            61 error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-22T18_06_44_901Z-debug-0.log
            Glasfaser B 2 Replies Last reply Reply Quote 0
            • Glasfaser
              @borkenkäfer
              Sehr komisch ..
              Teste :
              iob stop
              rm /opt/iobroker/package*
              sudo reboot
              danach
              cd /opt/iobroker
                Borkenkäfer @Borkenkäfer last edited by
                @borkenkäfer said in Iobroker lässt sich nicht mehr starten.:
                @glasfaser
                ist es das hier??
                54 verbose exit 1
                60 verbose code 1
                Muß für Heute leider schluß machen
                Melde mich morgen wieder
                danke für Eure Hilfe
                • Glasfaser
                  http fetch GET 200
                  Da stimmt auch etwas nicht !
                  https://forum.iobroker.net/post/441199
                    @glasfaser
                    es kommt das
                    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                    added 299 packages in 1m
                    14 packages are looking for funding
                      run `npm fund` for details
                    • Glasfaser
                      Glasfaser @Borkenkäfer last edited by Glasfaser
                      @borkenkäfer
                      sieht gut aus !
                      ... und Funktioniert es wieder !?
                        @glasfaser
                        nach iob start komme ich über port 8081 noch nicht drauf
                        • Glasfaser
                          @borkenkäfer
                          Full
                          iob diag
                          zeigen !
                            @glasfaser
                            und bei iob Update kommt
                            iob update
                            node:internal/modules/cjs/loader:1137
                              throw err;
                            Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                                at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
                                at Module._load (node:internal/modules/cjs/loader:975:27)
                                at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                                at node:internal/main/run_main_module:28:49 {
                              code: 'MODULE_NOT_FOUND',
                              requireStack: []
                            Node.js v18.19.0
                              @glasfaser
                              einmal full
                              Skript v.2023-10-10
                              *** BASE SYSTEM ***
                                 Static hostname: raspberrypi
                                       Icon name: computer
                                Operating System: Debian GNU/Linux 11 (bullseye)
                                          Kernel: Linux 6.1.21-v8+
                                    Architecture: arm64
                              Model           : Raspberry Pi 4 Model B Rev 1.2
                              Docker          : false
                              Virtualization  : none
                              Kernel          : aarch64
                              Userland        : arm64
                              Systemuptime and Load:
                               19:36:21 up 12 min,  3 users,  load average: 0.03, 0.24, 0.27
                              CPU threads: 4
                              *** RASPBERRY THROTTLING ***
                              Current issues:
                              Previously detected issues:
                              *** Time and Time Zones ***
                                             Local time: Mon 2024-01-22 19:36:21 CET
                                         Universal time: Mon 2024-01-22 18:36:21 UTC
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              *** User and Groups ***
                              ulli
                              /home/ulli
                              ulli adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                              *** X-Server-Setup ***
                              X-Server:       true
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Mem:            3.8G        284M        2.7G         38M        855M        3.4G
                              Swap:            99M          0B         99M
                              Total:          3.9G        284M        2.8G
                                       3794 M total memory
                                        284 M used memory
                                        583 M active memory
                                        396 M inactive memory
                                       2654 M free memory
                                         54 M buffer memory
                                        800 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FAILED SERVICES ***
                              0 loaded units listed.
                              *** FILESYSTEM ***
                              /dev/root      ext4       59G   11G   46G  20% /
                              devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                              tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                              tmpfs          tmpfs     759M  1.2M  758M   1% /run
                              /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                              tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
                              [Mon Jan 22 19:23:53 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:84:9D:5E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a9a74992-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                              [Mon Jan 22 19:23:54 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                              [Mon Jan 22 19:23:54 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                              [Mon Jan 22 19:23:56 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                              TARGET  SOURCE         FSTYPE OPTIONS
                              /       /dev/mmcblk0p2 ext4   rw,noatime
                              `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                              /var:
                              4.3G    /var/
                              3.4G    /var/log
                              2.9G    /var/log/journal/b741ffe02a684b9895597ea9866ca817
                              641M    /var/cache
                              Archived and active journals take up 2.8G in the file system.
                              /opt/iobroker/backups:
                              687M    /opt/iobroker/backups/
                              343M    /opt/iobroker/backups/history
                              268M    /opt/iobroker/backups/files
                              88M     /opt/iobroker/backups/files/echarts.admin
                              57M     /opt/iobroker/backups/files/echarts
                              /opt/iobroker/iobroker-data:
                              683M    /opt/iobroker/iobroker-data/
                              347M    /opt/iobroker/iobroker-data/history
                              294M    /opt/iobroker/iobroker-data/files
                              89M     /opt/iobroker/iobroker-data/files/echarts.admin
                              57M     /opt/iobroker/iobroker-data/files/echarts
                              24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
                              24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
                              23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
                              21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                              17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b756fe6.js.map
                              USB-Devices by-id:
                              /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_cc8e9ae92dd3eb11ac2234e8bf09e213-if00-port0
                              *** NodeJS-Installation ***
                              /usr/bin/nodejs         v18.19.0
                              /usr/bin/node           v18.19.0
                              /usr/bin/npm            10.2.3
                              /usr/bin/npx            10.2.3
                              /usr/bin/corepack       0.22.0
                              nodejs:
                                Installed: 18.19.0-1nodesource1
                                Candidate: 18.19.0-1nodesource1
                                Version table:
                               *** 18.19.0-1nodesource1 600
                                      100 /var/lib/dpkg/status
                                   18.18.2-1nodesource1 600
                                   18.18.1-1nodesource1 600
                                   18.18.0-1nodesource1 600
                                   18.17.1-1nodesource1 600
                                   18.17.0-1nodesource1 600
                                   18.16.1-1nodesource1 600
                                   18.16.0-1nodesource1 600
                                   18.15.0-1nodesource1 600
                                   18.14.2-1nodesource1 600
                                   18.14.1-1nodesource1 600
                                   18.14.0-1nodesource1 600
                                   18.13.0-1nodesource1 600
                                   18.12.0-1nodesource1 600
                                   18.11.0-1nodesource1 600
                                   18.10.0-1nodesource1 600
                                   18.9.1-1nodesource1 600
                                   18.9.0-1nodesource1 600
                                   18.8.0-1nodesource1 600
                                   18.7.0-1nodesource1 600
                                   18.6.0-1nodesource1 600
                                   18.5.0-1nodesource1 600
                                   18.4.0-1nodesource1 600
                                   18.3.0-1nodesource1 600
                                   18.2.0-1nodesource1 600
                                   18.1.0-1nodesource1 600
                                   18.0.0-1nodesource1 600
                                   12.22.12~dfsg-1~deb11u4 500
                                      500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                      500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                              No problems detected
                              Errors in npm tree:
                              *** ioBroker-Installation ***
                              ioBroker Status
                                throw err;
                                requireStack: []
                              Node.js v18.19.0
                              Core adapters versions
                                throw err;
                                requireStack: []
                              Node.js v18.19.0
                              js-controller:
                                throw err;
                                requireStack: []
                              Node.js v18.19.0
                              admin:
                                throw err;
                                requireStack: []
                              Node.js v18.19.0
                              javascript:
                              Adapters from github:   0
                              Adapter State
                                throw err;
                                requireStack: []
                              Node.js v18.19.0
                                throw err;
                                requireStack: []
                              Node.js v18.19.0
                              ioBroker-Repositories
                                throw err;
                                requireStack: []
                              Node.js v18.19.0
                              Installed ioBroker-Instances
                                throw err;
                                requireStack: []
                              Node.js v18.19.0
                              Objects and States
                              Objects:        0
                              States:         0
                              Hit:1 http://deb.debian.org/debian bullseye InRelease
                              Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                              Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                              Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                              Get:5 https://dl.cloudsmith.io/public/evcc/stable/deb/debian bullseye InRelease [5127 B]
                              Hit:6 https://dl.yarnpkg.com/debian stable InRelease
                              Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                              Fetched 5127 B in 2s (2790 B/s)
                              Reading package lists...
                              Pending Updates: 0
                              *** Listening Ports ***
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14242      600/sshd: /usr/sbin
                              tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          12977      557/cupsd
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          14253      600/sshd: /usr/sbin
                              tcp6       0      0 :::4712                 :::*                    LISTEN      116        15709      576/evcc
                              tcp6       0      0 ::1:631                 :::*                    LISTEN      0          12976      557/cupsd
                              tcp6       0      0 :::7070                 :::*                    LISTEN      116        15075      576/evcc
                              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12997      572/dhcpcd
                              udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          12989      622/cups-browsed
                              udp        0      0 0.0.0.0:54194           0.0.0.0:*                           108        15460      386/avahi-daemon: r
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        17496      576/evcc
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15458      386/avahi-daemon: r
                              udp6       0      0 :::546                  :::*                                0          13016      572/dhcpcd
                              udp6       0      0 :::50063                :::*                                108        15461      386/avahi-daemon: r
                              udp6       0      0 :::5353                 :::*                                116        17497      576/evcc
                              udp6       0      0 :::5353                 :::*                                108        15459      386/avahi-daemon: r
                              2024-01-22 19:29:28.262  - info: host.raspberrypi stopInstance system.adapter.ping.0 (force=false, process=false)
                              2024-01-22 19:29:28.262  - info: host.raspberrypi stopInstance system.adapter.meross.0 (force=false, process=false)
                              2024-01-22 19:29:28.262  - info: host.raspberrypi stopInstance system.adapter.rpi2.0 (force=false, process=false)
                              2024-01-22 19:29:28.263  - info: host.raspberrypi stopInstance system.adapter.tuya.0 (force=false, process=false)
                              2024-01-22 19:29:28.263  - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=false)
                              2024-01-22 19:29:28.264  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=false)
                              2024-01-22 19:29:28.265  - info: host.raspberrypi stopInstance system.adapter.net-tools.0 (force=false, process=false)
                              2024-01-22 19:29:28.265  - info: host.raspberrypi stopInstance system.adapter.fritzdect.0 (force=false, process=false)
                              2024-01-22 19:29:28.265  - info: host.raspberrypi stopInstance system.adapter.web.0 (force=false, process=false)
                              2024-01-22 19:29:28.266  - info: host.raspberrypi stopInstance system.adapter.jarvis.0 (force=false, process=false)
                              2024-01-22 19:29:28.266  - info: host.raspberrypi stopInstance system.adapter.vis.0 (force=false, process=false)
                              2024-01-22 19:29:28.267  - info: host.raspberrypi stopInstance system.adapter.echarts.0 (force=false, process=false)
                              2024-01-22 19:29:28.267  - info: host.raspberrypi stopInstance system.adapter.parser.0 (force=false, process=false)
                              2024-01-22 19:29:28.267  - info: host.raspberrypi stopInstance system.adapter.simple-api.0 (force=false, process=false)
                              2024-01-22 19:29:28.268  - info: host.raspberrypi stopInstance system.adapter.socketio.0 (force=false, process=false)
                              2024-01-22 19:29:28.268  - info: host.raspberrypi stopInstance system.adapter.growatt.0 (force=false, process=false)
                              2024-01-22 19:29:28.268  - info: host.raspberrypi stopInstance system.adapter.terminal.0 (force=false, process=false)
                              2024-01-22 19:29:28.269  - info: host.raspberrypi stopInstance system.adapter.cloud.0 (force=false, process=false)
                              2024-01-22 19:29:28.269  - info: host.raspberrypi stopInstance system.adapter.pvforecast.0 (force=false, process=false)
                              2024-01-22 19:29:28.269  - info: host.raspberrypi stopInstance system.adapter.evcc.0 (force=false, process=false)
                              2024-01-22 19:29:28.269  - info: host.raspberrypi stopInstance system.adapter.homeconnect.0 (force=false, process=false)
                              2024-01-22 19:29:28.270  - info: host.raspberrypi stopInstance system.adapter.tibberlink.0 (force=false, process=false)
                              2024-01-22 19:29:28.752  - info: host.raspberrypi terminated
                              2024-01-22 19:29:29.215  - warn: host.raspberrypi startInstance cannot find adapter "history@3.0.1". Try to install it... 1 attempt
                              2024-01-22 19:29:29.216  - info: host.raspberrypi iobroker install history@3.0.1 using installedFrom
                              Glasfaser 2 Replies Last reply Reply Quote 0
                              • Glasfaser
                                @borkenkäfer
                                nochmal
                                cd /opt/iobroker
                                npm cache clean --force
                                • Glasfaser
                                  Hast du das Steckernetzteil gezogen !?
                                  EDIT :
                                  bzw. ein root Mount
                                    @glasfaser
                                    Guten Abend
                                    Meldung nach cache clean
                                    ulli@raspberrypi:/opt/iobroker $ npm cache clean --force
                                    npm WARN using --force Recommended protections disabled.
                                    ulli@raspberrypi:/opt/iobroker $ sudo npm cache clean --force
                                      Thomas Braun Most Active @Borkenkäfer last edited by
                                      @borkenkäfer
                                      Wo stand denn was von sudo? Finger weg von root-Rechten, wenn es nicht unbedingt erforderlich ist.
                                      cd /opt/iobroker
                                      sagt nun?
                                        Borkenkäfer @Thomas Braun last edited by
                                        sorry
                                        meldung
                                        added 289 packages in 1m
                                        15 packages are looking for funding
                                        ulli@raspberrypi:/opt/iobroker $ npm fund
                                        iobroker.core@1.0.0
                                        ├── https://github.com/sponsors/jaredhanson
                                        │   └── passport@0.6.0
                                        ├── https://github.com/sponsors/RubenVerborgh
                                        │   └── follow-redirects@1.15.5
                                        ├── https://opencollective.com/ioredis
                                        │   └── ioredis@4.28.5
                                        ├── https://github.com/sponsors/ljharb
                                        │   └── function-bind@1.1.2
                                        ├─┬ https://github.com/sindresorhus/execa?sponsor=1
                                        │ │ └── execa@5.1.1
                                        │ └── https://github.com/sponsors/sindresorhus
                                        │     └── get-stream@6.0.1, is-stream@2.0.1, onetime@5.1.2
                                        ├─┬ https://paulmillr.com/funding/
                                        │ │ └── chokidar@3.5.3
                                        │ └── https://github.com/sponsors/jonschlinkert
                                        │     └── picomatch@2.3.1
                                        ├─┬ https://github.com/chalk/wrap-ansi?sponsor=1
                                        │ │ └── wrap-ansi@7.0.0
                                        │ └── https://github.com/chalk/ansi-styles?sponsor=1
                                        │     └── ansi-styles@4.3.0
                                        ├── https://github.com/sponsors/sibiraj-s
                                        │   └── ci-info@3.9.0
                                        ├── https://github.com/sponsors/feross
                                        │   └── safe-buffer@5.2.1
                                        └── https://github.com/sponsors/epoberezkin
                                            └── ajv@6.12.6
                                        ulli@raspberrypi:/opt/iobroker $ ^C
                                          @borkenkäfer
                                          sudo systemctl set-default multi-user.target
                                          iobroker restart
                                          iob diag
                                            war kurz offline
                                            full
                                            Skript v.2023-10-10
                                            *** BASE SYSTEM ***
                                                     Icon name: computer
                                                  Architecture: arm64
                                            Docker          : false
                                            Kernel          : aarch64
                                            Userland        : arm64
                                             17:44:45 up 22:20,  3 users,  load average: 1.36, 0.68, 0.45
                                            CPU threads: 4
                                            Current issues:
                                                           Local time: Tue 2024-01-23 17:44:45 CET
                                                       Universal time: Tue 2024-01-23 16:44:45 UTC
                                                             RTC time: n/a
                                                          NTP service: active
                                                      RTC in local TZ: no
                                            ulli
                                            /home/ulli
                                            X-Server:       true
                                            Desktop:
                                            Terminal:       tty
                                            Boot Target:    multi-user.target
                                            *** MEMORY ***
                                            Mem:            3.8G        807M        1.3G         38M        1.7G        2.9G
                                            Swap:            99M          0B         99M
                                            Total:          3.9G        807M        1.4G
                                                     3794 M total memory
                                                      807 M used memory
                                                     1516 M active memory
                                                      783 M inactive memory
                                                     1256 M free memory
                                                      170 M buffer memory
                                                     1560 M swap cache
                                                       99 M total swap
                                                        0 M used swap
                                                       99 M free swap
                                            Raspberry only:
                                            oom events: 0
                                            *** FILESYSTEM ***
                                            /dev/root      ext4       59G   12G   45G  20% /
                                            /var:
                                            4.7G    /var/
                                            3.8G    /var/log
                                            3.2G    /var/log/journal/b741ffe02a684b9895597ea9866ca817
                                            641M    /var/cache
                                            Archived and active journals take up 3.1G in the file system.
                                            687M    /opt/iobroker/iobroker-data/
                                            USB-Devices by-id:
                                            /usr/bin/npm            10.2.3
                                            /usr/bin/npx            10.2.3
                                            nodejs:
                                              Version table:
                                            Temp directories causing npm8 problem: 75
                                            Some problems detected, please run iob fix
                                            Errors in npm tree:
                                            ioBroker Status
                                            Objects type: jsonl
                                            States  type: jsonl
                                            js-controller:  5.0.17
                                            admin:          "admin" not found
                                            javascript:     "javascript" not found
                                            Adapter State
                                              system.adapter.admin.0                  : admin                 : raspberrypi                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                                              system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                              system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
                                              system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                                              system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
                                              system.adapter.evcc.0                   : evcc                  : raspberrypi                              -  enabled, port: 7070
                                              system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
                                              system.adapter.growatt.0                : growatt               : raspberrypi                              -  enabled
                                              system.adapter.history.0                : history               : raspberrypi                              -  enabled
                                              system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              - disabled
                                              system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
                                              system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                                            + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
                                              system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
                                              system.adapter.parser.0                 : parser                : raspberrypi                              -  enabled
                                            + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                                              system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
                                            + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                                              system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                            + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
                                              system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                                              system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                                              system.adapter.tibberlink.0             : tibberlink            : raspberrypi                              -  enabled
                                              system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                                              system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                                              system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                            + instance is alive
                                            Active repo(s): stable
                                            Used repository: stable
                                            Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
                                            Controller "js-controller": 5.0.17   , installed 5.0.17
                                            Adapter    "meross"       : 1.17.0   , installed 1.17.0
                                            Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                                            Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                                            Objects and States
                                            Objects:        2093
                                            States:         1702
                                            Fetched 5127 B in 2s (2420 B/s)
                                            Pending Updates: 0
                                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       749922     205370/iobroker.js-
                                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       748495     205370/iobroker.js-
                                            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          170745     44884/cupsd
                                            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          170744     44884/cupsd
                                            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       758148     208071/io.tuya.0
                                            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       758149     208071/io.tuya.0
                                            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          174358     44885/cups-browsed
                                            2024-01-23 17:45:33.753  - info: host.raspberrypi iobroker npm-install: upload [2] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/tuya.png tuya.png image/png
                                            2024-01-23 17:45:33.762  - info: host.raspberrypi iobroker npm-install: upload [1] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/warning.png warning.png image/png
                                            2024-01-23 17:45:33.775  - info: host.raspberrypi iobroker npm-install: upload [0] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/words.js words.js application/javascript
                                            2024-01-23 17:45:33.883  - info: host.raspberrypi iobroker npm-install: host.raspberrypi object system.adapter.tuya created/updated
                                            2024-01-23 17:45:37.269  - info: host.raspberrypi iobroker npm-install: exit 0
                                            2024-01-23 17:45:37.338  - info: host.raspberrypi instance system.adapter.tuya.0 started with pid 208071
                                            2024-01-23 17:45:38.269  - warn: host.raspberrypi startInstance cannot find adapter "discovery@4.2.0". Try to install it... 1 attempt
                                            2024-01-23 17:45:38.271  - info: host.raspberrypi iobroker install discovery@4.2.0 using installedFrom
                                            2024-01-23 17:45:42.973  - info: host.raspberrypi iobroker npm-install: NPM version: 10.2.3Installing iobroker.discovery@4.2.0... (System call)
                                            2024-01-23 17:45:55.711  - info: host.raspberrypi iobroker npm-install:
                                            2024-01-23 17:45:55.712  - info: host.raspberrypi iobroker npm-install: added 15 packages in 12s
                                            2024-01-23 17:45:55.713  - info: host.raspberrypi iobroker npm-install: 59 packages are looking for funding  run `npm fund` for details
                                            2024-01-23 17:45:55.780  - info: host.raspberrypi iobroker npm-install: host.raspberrypi install adapter discovery@4.2.0
                                            2024-01-23 17:45:55.892  - info: host.raspberrypi iobroker npm-install: upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                                            2024-01-23 17:45:55.917  - info: host.raspberrypi iobroker npm-install: upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                                            2024-01-23 17:45:55.931  - info: host.raspberrypi iobroker npm-install: upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                                            2024-01-23 17:45:55.946  - info: host.raspberrypi iobroker npm-install: upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                                            2024-01-23 17:45:55.957  - info: host.raspberrypi iobroker npm-install: upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                                            2024-01-23 17:45:55.970  - info: host.raspberrypi iobroker npm-install: upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                                            2024-01-23 17:45:55.981  - info: host.raspberrypi iobroker npm-install: upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                                            2024-01-23 17:45:56.083  - info: host.raspberrypi iobroker npm-install: host.raspberrypi object system.adapter.discovery created/updated
                                            2024-01-23 17:45:57.159  - info: host.raspberrypi iobroker npm-install: exit 0
                                            2024-01-23 17:45:57.209  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 209055
                                            2024-01-23 17:45:58.159  - warn: host.raspberrypi startInstance cannot find adapter "backitup@2.9.8". Try to install it... 1 attempt
                                            2024-01-23 17:45:58.160  - info: host.raspberrypi iobroker install backitup@2.9.8 using installedFrom
                                            3684
