    4. Iobroker lässt sich nicht mehr starten.
      Borkenkäfer @Borkenkäfer last edited by
      @borkenkäfer said in Iobroker lässt sich nicht mehr starten.:
      @glasfaser
      ist es das hier??
      ulli@raspberrypi:/home/iobroker $ cat /home/iobroker/.npm/_logs/2024-01-22T18_06_44_901Z-debug-0.log
      0 verbose cli /usr/bin/node /usr/bin/npm
      1 info using npm@10.2.3
      2 info using node@v18.19.0
      3 timing npm:load:whichnode Completed in 3ms
      4 timing config:load:defaults Completed in 7ms
      5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 12ms
      6 timing config:load:builtin Completed in 13ms
      7 timing config:load:cli Completed in 15ms
      8 timing config:load:env Completed in 1ms
      9 timing config:load:file:/opt/iobroker/.npmrc Completed in 5ms
      10 timing config:load:project Completed in 8ms
      11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
      12 timing config:load:user Completed in 1ms
      13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
      14 timing config:load:global Completed in 1ms
      15 timing config:load:setEnvs Completed in 4ms
      16 timing config:load Completed in 51ms
      17 timing npm:load:configload Completed in 51ms
      18 timing config:load:flatten Completed in 9ms
      19 timing npm:load:mkdirpcache Completed in 2ms
      20 timing npm:load:mkdirplogs Completed in 1ms
      21 verbose title npm install iobroker.js-controller
      22 verbose argv "install" "iobroker.js-controller"
      23 timing npm:load:setTitle Completed in 4ms
      24 timing npm:load:display Completed in 2ms
      25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2024-01-22T18_06_44_901Z-
      26 verbose logfile /home/iobroker/.npm/_logs/2024-01-22T18_06_44_901Z-debug-0.log
      27 timing npm:load:logFile Completed in 29ms
      28 timing npm:load:timers Completed in 0ms
      29 timing npm:load:configScope Completed in 1ms
      30 timing npm:load Completed in 147ms
      31 timing arborist:ctor Completed in 3ms
      32 silly logfile start cleaning logs, removing 1 files
      33 silly logfile done cleaning log files
      34 timing idealTree:init Completed in 1707ms
      35 timing idealTree:userRequests Completed in 5ms
      36 silly idealTree buildDeps
      37 silly fetch manifest iobroker.js-controller@5.0.17
      38 http fetch GET 200 https://registry.npmjs.org/iobroker.js-controller 647ms (cache revalidated)
      39 silly placeDep ROOT iobroker.js-controller@5.0.17 REPLACE for: iobroker.inst@3.0.0 want: 5.0.17
      40 timing idealTree:#root Completed in 749ms
      41 silly fetch manifest esbuild@^0.11.5
      42 http fetch GET 200 https://registry.npmjs.org/esbuild 80ms (cache revalidated)
      43 silly fetch manifest jsonc-parser@^3.0.0
      44 http fetch GET 200 https://registry.npmjs.org/jsonc-parser 70ms (cache revalidated)
      45 silly placeDep ROOT esbuild@0.11.23 OK for: @alcalzone/esbuild-register@2.5.1-1 want: ^0.11.5
      46 timing idealTree Completed in 2675ms
      47 timing command:install Completed in 2708ms
      48 verbose stack TypeError: Invalid Version:
      48 verbose stack     at new SemVer (/usr/lib/node_modules/npm/node_modules/semver/classes/semver.js:38:13)
      48 verbose stack     at compare (/usr/lib/node_modules/npm/node_modules/semver/functions/compare.js:3:32)
      48 verbose stack     at Object.gte (/usr/lib/node_modules/npm/node_modules/semver/functions/gte.js:2:30)
      48 verbose stack     at Node.canDedupe (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/node.js:1079:32)
      48 verbose stack     at PlaceDep.pruneDedupable (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/place-dep.js:426:14)
      48 verbose stack     at new PlaceDep (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/place-dep.js:278:14)
      48 verbose stack     at #buildDepStep (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:933:18)
      48 verbose stack     at async Arborist.buildIdealTree (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:196:7)
      48 verbose stack     at async Promise.all (index 1)
      48 verbose stack     at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:159:5)
      49 verbose cwd /opt/iobroker
      50 verbose Linux 6.1.21-v8+
      51 verbose node v18.19.0
      52 verbose npm  v10.2.3
      53 error Invalid Version:
      54 verbose exit 1
      55 timing npm Completed in 3498ms
      56 verbose unfinished npm timer reify 1705946805688
      57 verbose unfinished npm timer reify:loadTrees 1705946805706
      58 verbose unfinished npm timer idealTree:buildDeps 1705946807423
      59 verbose unfinished npm timer idealTree:node_modules/@alcalzone/esbuild-register 1705946808178
      60 verbose code 1
      61 error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-22T18_06_44_901Z-debug-0.log
      Muß für Heute leider schluß machen
      Melde mich morgen wieder
      danke für Eure Hilfe
      • Glasfaser
        Glasfaser last edited by
        @borkenkäfer sagte in Iobroker lässt sich nicht mehr starten.:
        http fetch GET 200
        Da stimmt auch etwas nicht !
        https://forum.iobroker.net/post/441199
          Borkenkäfer @Glasfaser last edited by
          @glasfaser
          es kommt das
           sudo -H -u iobroker npm install iobroker.js-controller
          npm WARN deprecated har-validator@5.1.5: this library is no longer supported
          npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
          npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
          added 299 packages in 1m
          14 packages are looking for funding
            run `npm fund` for details
          mikeal created this issue in request/request
          open Request’s Past, Present and Future #3142
          • Glasfaser
            Glasfaser @Borkenkäfer last edited by Glasfaser
            @borkenkäfer
            sieht gut aus !
            ... und Funktioniert es wieder !?
              @glasfaser
              nach iob start komme ich über port 8081 noch nicht drauf
              Glasfaser B 2 Replies Last reply Reply Quote 0
              • Glasfaser
                @borkenkäfer
                Full
                iob diag
                zeigen !
                  @glasfaser
                  und bei iob Update kommt
                  iob update
                  node:internal/modules/cjs/loader:1137
                    throw err;
                  Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                      at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
                      at Module._load (node:internal/modules/cjs/loader:975:27)
                      at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                      at node:internal/main/run_main_module:28:49 {
                    code: 'MODULE_NOT_FOUND',
                    requireStack: []
                  Node.js v18.19.0
                    @glasfaser
                    einmal full
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                       Static hostname: raspberrypi
                             Icon name: computer
                      Operating System: Debian GNU/Linux 11 (bullseye)
                                Kernel: Linux 6.1.21-v8+
                          Architecture: arm64
                    Model           : Raspberry Pi 4 Model B Rev 1.2
                    Docker          : false
                    Virtualization  : none
                    Kernel          : aarch64
                    Userland        : arm64
                    Systemuptime and Load:
                     19:36:21 up 12 min,  3 users,  load average: 0.03, 0.24, 0.27
                    CPU threads: 4
                    *** RASPBERRY THROTTLING ***
                    Current issues:
                    Previously detected issues:
                    *** Time and Time Zones ***
                                   Local time: Mon 2024-01-22 19:36:21 CET
                               Universal time: Mon 2024-01-22 18:36:21 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    *** User and Groups ***
                    ulli
                    /home/ulli
                    ulli adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                    *** X-Server-Setup ***
                    X-Server:       true
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            3.8G        284M        2.7G         38M        855M        3.4G
                    Swap:            99M          0B         99M
                    Total:          3.9G        284M        2.8G
                             3794 M total memory
                              284 M used memory
                              583 M active memory
                              396 M inactive memory
                             2654 M free memory
                               54 M buffer memory
                              800 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FAILED SERVICES ***
                    0 loaded units listed.
                    *** FILESYSTEM ***
                    /dev/root      ext4       59G   11G   46G  20% /
                    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                    tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                    tmpfs          tmpfs     759M  1.2M  758M   1% /run
                    /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                    tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
                    [Mon Jan 22 19:23:53 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:84:9D:5E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a9a74992-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                    [Mon Jan 22 19:23:54 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                    [Mon Jan 22 19:23:54 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                    [Mon Jan 22 19:23:56 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                    TARGET  SOURCE         FSTYPE OPTIONS
                    /       /dev/mmcblk0p2 ext4   rw,noatime
                    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                    /var:
                    4.3G    /var/
                    3.4G    /var/log
                    2.9G    /var/log/journal/b741ffe02a684b9895597ea9866ca817
                    641M    /var/cache
                    Archived and active journals take up 2.8G in the file system.
                    /opt/iobroker/backups:
                    687M    /opt/iobroker/backups/
                    343M    /opt/iobroker/backups/history
                    268M    /opt/iobroker/backups/files
                    88M     /opt/iobroker/backups/files/echarts.admin
                    57M     /opt/iobroker/backups/files/echarts
                    /opt/iobroker/iobroker-data:
                    683M    /opt/iobroker/iobroker-data/
                    347M    /opt/iobroker/iobroker-data/history
                    294M    /opt/iobroker/iobroker-data/files
                    89M     /opt/iobroker/iobroker-data/files/echarts.admin
                    57M     /opt/iobroker/iobroker-data/files/echarts
                    24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
                    24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
                    23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
                    21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                    17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b756fe6.js.map
                    USB-Devices by-id:
                    /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_cc8e9ae92dd3eb11ac2234e8bf09e213-if00-port0
                    *** NodeJS-Installation ***
                    /usr/bin/nodejs         v18.19.0
                    /usr/bin/node           v18.19.0
                    /usr/bin/npm            10.2.3
                    /usr/bin/npx            10.2.3
                    /usr/bin/corepack       0.22.0
                    nodejs:
                      Installed: 18.19.0-1nodesource1
                      Candidate: 18.19.0-1nodesource1
                      Version table:
                     *** 18.19.0-1nodesource1 600
                            100 /var/lib/dpkg/status
                         18.18.2-1nodesource1 600
                         18.18.1-1nodesource1 600
                         18.18.0-1nodesource1 600
                         18.17.1-1nodesource1 600
                         18.17.0-1nodesource1 600
                         18.16.1-1nodesource1 600
                         18.16.0-1nodesource1 600
                         18.15.0-1nodesource1 600
                         18.14.2-1nodesource1 600
                         18.14.1-1nodesource1 600
                         18.14.0-1nodesource1 600
                         18.13.0-1nodesource1 600
                         18.12.0-1nodesource1 600
                         18.11.0-1nodesource1 600
                         18.10.0-1nodesource1 600
                         18.9.1-1nodesource1 600
                         18.9.0-1nodesource1 600
                         18.8.0-1nodesource1 600
                         18.7.0-1nodesource1 600
                         18.6.0-1nodesource1 600
                         18.5.0-1nodesource1 600
                         18.4.0-1nodesource1 600
                         18.3.0-1nodesource1 600
                         18.2.0-1nodesource1 600
                         18.1.0-1nodesource1 600
                         18.0.0-1nodesource1 600
                         12.22.12~dfsg-1~deb11u4 500
                            500 http://deb.debian.org/debian bullseye/main arm64 Packages
                            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                    No problems detected
                    Errors in npm tree:
                    *** ioBroker-Installation ***
                    ioBroker Status
                      throw err;
                      requireStack: []
                    Node.js v18.19.0
                    Core adapters versions
                      throw err;
                      requireStack: []
                    Node.js v18.19.0
                    js-controller:
                      throw err;
                      requireStack: []
                    Node.js v18.19.0
                    admin:
                      throw err;
                      requireStack: []
                    Node.js v18.19.0
                    javascript:
                    Adapters from github:   0
                    Adapter State
                      throw err;
                      requireStack: []
                    Node.js v18.19.0
                      throw err;
                      requireStack: []
                    Node.js v18.19.0
                    ioBroker-Repositories
                      throw err;
                      requireStack: []
                    Node.js v18.19.0
                    Installed ioBroker-Instances
                      throw err;
                      requireStack: []
                    Node.js v18.19.0
                    Objects and States
                    Objects:        0
                    States:         0
                    Hit:1 http://deb.debian.org/debian bullseye InRelease
                    Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                    Get:5 https://dl.cloudsmith.io/public/evcc/stable/deb/debian bullseye InRelease [5127 B]
                    Hit:6 https://dl.yarnpkg.com/debian stable InRelease
                    Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Fetched 5127 B in 2s (2790 B/s)
                    Reading package lists...
                    Pending Updates: 0
                    *** Listening Ports ***
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14242      600/sshd: /usr/sbin
                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          12977      557/cupsd
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          14253      600/sshd: /usr/sbin
                    tcp6       0      0 :::4712                 :::*                    LISTEN      116        15709      576/evcc
                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          12976      557/cupsd
                    tcp6       0      0 :::7070                 :::*                    LISTEN      116        15075      576/evcc
                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12997      572/dhcpcd
                    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          12989      622/cups-browsed
                    udp        0      0 0.0.0.0:54194           0.0.0.0:*                           108        15460      386/avahi-daemon: r
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        17496      576/evcc
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15458      386/avahi-daemon: r
                    udp6       0      0 :::546                  :::*                                0          13016      572/dhcpcd
                    udp6       0      0 :::50063                :::*                                108        15461      386/avahi-daemon: r
                    udp6       0      0 :::5353                 :::*                                116        17497      576/evcc
                    udp6       0      0 :::5353                 :::*                                108        15459      386/avahi-daemon: r
                    2024-01-22 19:29:28.262  - info: host.raspberrypi stopInstance system.adapter.ping.0 (force=false, process=false)
                    2024-01-22 19:29:28.262  - info: host.raspberrypi stopInstance system.adapter.meross.0 (force=false, process=false)
                    2024-01-22 19:29:28.262  - info: host.raspberrypi stopInstance system.adapter.rpi2.0 (force=false, process=false)
                    2024-01-22 19:29:28.263  - info: host.raspberrypi stopInstance system.adapter.tuya.0 (force=false, process=false)
                    2024-01-22 19:29:28.263  - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=false)
                    2024-01-22 19:29:28.264  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=false)
                    2024-01-22 19:29:28.265  - info: host.raspberrypi stopInstance system.adapter.net-tools.0 (force=false, process=false)
                    2024-01-22 19:29:28.265  - info: host.raspberrypi stopInstance system.adapter.fritzdect.0 (force=false, process=false)
                    2024-01-22 19:29:28.265  - info: host.raspberrypi stopInstance system.adapter.web.0 (force=false, process=false)
                    2024-01-22 19:29:28.266  - info: host.raspberrypi stopInstance system.adapter.jarvis.0 (force=false, process=false)
                    2024-01-22 19:29:28.266  - info: host.raspberrypi stopInstance system.adapter.vis.0 (force=false, process=false)
                    2024-01-22 19:29:28.267  - info: host.raspberrypi stopInstance system.adapter.echarts.0 (force=false, process=false)
                    2024-01-22 19:29:28.267  - info: host.raspberrypi stopInstance system.adapter.parser.0 (force=false, process=false)
                    2024-01-22 19:29:28.267  - info: host.raspberrypi stopInstance system.adapter.simple-api.0 (force=false, process=false)
                    2024-01-22 19:29:28.268  - info: host.raspberrypi stopInstance system.adapter.socketio.0 (force=false, process=false)
                    2024-01-22 19:29:28.268  - info: host.raspberrypi stopInstance system.adapter.growatt.0 (force=false, process=false)
                    2024-01-22 19:29:28.268  - info: host.raspberrypi stopInstance system.adapter.terminal.0 (force=false, process=false)
                    2024-01-22 19:29:28.269  - info: host.raspberrypi stopInstance system.adapter.cloud.0 (force=false, process=false)
                    2024-01-22 19:29:28.269  - info: host.raspberrypi stopInstance system.adapter.pvforecast.0 (force=false, process=false)
                    2024-01-22 19:29:28.269  - info: host.raspberrypi stopInstance system.adapter.evcc.0 (force=false, process=false)
                    2024-01-22 19:29:28.269  - info: host.raspberrypi stopInstance system.adapter.homeconnect.0 (force=false, process=false)
                    2024-01-22 19:29:28.270  - info: host.raspberrypi stopInstance system.adapter.tibberlink.0 (force=false, process=false)
                    2024-01-22 19:29:28.752  - info: host.raspberrypi terminated
                    2024-01-22 19:29:29.215  - warn: host.raspberrypi startInstance cannot find adapter "history@3.0.1". Try to install it... 1 attempt
                    2024-01-22 19:29:29.216  - info: host.raspberrypi iobroker install history@3.0.1 using installedFrom
                    Glasfaser 2 Replies Last reply Reply Quote 0
                    • Glasfaser
                      @borkenkäfer
                      nochmal
                      cd /opt/iobroker
                      npm cache clean --force
                      sudo -H -u iobroker npm install iobroker.js-controller --debug
                      • Glasfaser
                        Hast du das Steckernetzteil gezogen !?
                        EDIT :
                        bzw. ein root Mount
                          @glasfaser
                          Guten Abend
                          Meldung nach cache clean
                          ulli@raspberrypi:/opt/iobroker $ npm cache clean --force
                          npm WARN using --force Recommended protections disabled.
                          ulli@raspberrypi:/opt/iobroker $ sudo npm cache clean --force
                            Thomas Braun Most Active @Borkenkäfer last edited by
                            @borkenkäfer
                            Wo stand denn was von sudo? Finger weg von root-Rechten, wenn es nicht unbedingt erforderlich ist.
                            cd /opt/iobroker
                            sagt nun?
                              Borkenkäfer @Thomas Braun last edited by
                              sorry
                              meldung
                              added 289 packages in 1m
                              15 packages are looking for funding
                              ulli@raspberrypi:/opt/iobroker $ npm fund
                              iobroker.core@1.0.0
                              ├── https://github.com/sponsors/jaredhanson
                              │   └── passport@0.6.0
                              ├── https://github.com/sponsors/RubenVerborgh
                              │   └── follow-redirects@1.15.5
                              ├── https://opencollective.com/ioredis
                              │   └── ioredis@4.28.5
                              ├── https://github.com/sponsors/ljharb
                              │   └── function-bind@1.1.2
                              ├─┬ https://github.com/sindresorhus/execa?sponsor=1
                              │ │ └── execa@5.1.1
                              │ └── https://github.com/sponsors/sindresorhus
                              │     └── get-stream@6.0.1, is-stream@2.0.1, onetime@5.1.2
                              ├─┬ https://paulmillr.com/funding/
                              │ │ └── chokidar@3.5.3
                              │ └── https://github.com/sponsors/jonschlinkert
                              │     └── picomatch@2.3.1
                              ├─┬ https://github.com/chalk/wrap-ansi?sponsor=1
                              │ │ └── wrap-ansi@7.0.0
                              │ └── https://github.com/chalk/ansi-styles?sponsor=1
                              │     └── ansi-styles@4.3.0
                              ├── https://github.com/sponsors/sibiraj-s
                              │   └── ci-info@3.9.0
                              ├── https://github.com/sponsors/feross
                              │   └── safe-buffer@5.2.1
                              └── https://github.com/sponsors/epoberezkin
                                  └── ajv@6.12.6
                              ulli@raspberrypi:/opt/iobroker $ ^C
                                @borkenkäfer
                                sudo systemctl set-default multi-user.target
                                iobroker restart
                                iob diag
                                  war kurz offline
                                  full
                                  Skript v.2023-10-10
                                  *** BASE SYSTEM ***
                                           Icon name: computer
                                        Architecture: arm64
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : arm64
                                   17:44:45 up 22:20,  3 users,  load average: 1.36, 0.68, 0.45
                                  CPU threads: 4
                                  Current issues:
                                                 Local time: Tue 2024-01-23 17:44:45 CET
                                             Universal time: Tue 2024-01-23 16:44:45 UTC
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  ulli
                                  /home/ulli
                                  X-Server:       true
                                  Desktop:
                                  Terminal:       tty
                                  Boot Target:    multi-user.target
                                  *** MEMORY ***
                                  Mem:            3.8G        807M        1.3G         38M        1.7G        2.9G
                                  Swap:            99M          0B         99M
                                  Total:          3.9G        807M        1.4G
                                           3794 M total memory
                                            807 M used memory
                                           1516 M active memory
                                            783 M inactive memory
                                           1256 M free memory
                                            170 M buffer memory
                                           1560 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FILESYSTEM ***
                                  /dev/root      ext4       59G   12G   45G  20% /
                                  /var:
                                  4.7G    /var/
                                  3.8G    /var/log
                                  3.2G    /var/log/journal/b741ffe02a684b9895597ea9866ca817
                                  641M    /var/cache
                                  Archived and active journals take up 3.1G in the file system.
                                  687M    /opt/iobroker/iobroker-data/
                                  USB-Devices by-id:
                                  /usr/bin/npm            10.2.3
                                  /usr/bin/npx            10.2.3
                                  nodejs:
                                    Version table:
                                  Temp directories causing npm8 problem: 75
                                  Some problems detected, please run iob fix
                                  Errors in npm tree:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  js-controller:  5.0.17
                                  admin:          "admin" not found
                                  javascript:     "javascript" not found
                                  Adapter State
                                    system.adapter.admin.0                  : admin                 : raspberrypi                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                    system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
                                    system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                                    system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
                                    system.adapter.evcc.0                   : evcc                  : raspberrypi                              -  enabled, port: 7070
                                    system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
                                    system.adapter.growatt.0                : growatt               : raspberrypi                              -  enabled
                                    system.adapter.history.0                : history               : raspberrypi                              -  enabled
                                    system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              - disabled
                                    system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
                                    system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                                  + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
                                    system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
                                    system.adapter.parser.0                 : parser                : raspberrypi                              -  enabled
                                  + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                                    system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
                                  + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                                    system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                  + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
                                    system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                                    system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                                    system.adapter.tibberlink.0             : tibberlink            : raspberrypi                              -  enabled
                                    system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                                    system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                                    system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                  + instance is alive
                                  Active repo(s): stable
                                  Used repository: stable
                                  Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
                                  Controller "js-controller": 5.0.17   , installed 5.0.17
                                  Adapter    "meross"       : 1.17.0   , installed 1.17.0
                                  Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                                  Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                                  Objects and States
                                  Objects:        2093
                                  States:         1702
                                  Fetched 5127 B in 2s (2420 B/s)
                                  Pending Updates: 0
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       749922     205370/iobroker.js-
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       748495     205370/iobroker.js-
                                  tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          170745     44884/cupsd
                                  tcp6       0      0 ::1:631                 :::*                    LISTEN      0          170744     44884/cupsd
                                  udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       758148     208071/io.tuya.0
                                  udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       758149     208071/io.tuya.0
                                  udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          174358     44885/cups-browsed
                                  2024-01-23 17:45:33.753  - info: host.raspberrypi iobroker npm-install: upload [2] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/tuya.png tuya.png image/png
                                  2024-01-23 17:45:33.762  - info: host.raspberrypi iobroker npm-install: upload [1] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/warning.png warning.png image/png
                                  2024-01-23 17:45:33.775  - info: host.raspberrypi iobroker npm-install: upload [0] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/words.js words.js application/javascript
                                  2024-01-23 17:45:33.883  - info: host.raspberrypi iobroker npm-install: host.raspberrypi object system.adapter.tuya created/updated
                                  2024-01-23 17:45:37.269  - info: host.raspberrypi iobroker npm-install: exit 0
                                  2024-01-23 17:45:37.338  - info: host.raspberrypi instance system.adapter.tuya.0 started with pid 208071
                                  2024-01-23 17:45:38.269  - warn: host.raspberrypi startInstance cannot find adapter "discovery@4.2.0". Try to install it... 1 attempt
                                  2024-01-23 17:45:38.271  - info: host.raspberrypi iobroker install discovery@4.2.0 using installedFrom
                                  2024-01-23 17:45:42.973  - info: host.raspberrypi iobroker npm-install: NPM version: 10.2.3Installing iobroker.discovery@4.2.0... (System call)
                                  2024-01-23 17:45:55.711  - info: host.raspberrypi iobroker npm-install:
                                  2024-01-23 17:45:55.712  - info: host.raspberrypi iobroker npm-install: added 15 packages in 12s
                                  2024-01-23 17:45:55.713  - info: host.raspberrypi iobroker npm-install: 59 packages are looking for funding  run `npm fund` for details
                                  2024-01-23 17:45:55.780  - info: host.raspberrypi iobroker npm-install: host.raspberrypi install adapter discovery@4.2.0
                                  2024-01-23 17:45:55.892  - info: host.raspberrypi iobroker npm-install: upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                                  2024-01-23 17:45:55.917  - info: host.raspberrypi iobroker npm-install: upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                                  2024-01-23 17:45:55.931  - info: host.raspberrypi iobroker npm-install: upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                                  2024-01-23 17:45:55.946  - info: host.raspberrypi iobroker npm-install: upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                                  2024-01-23 17:45:55.957  - info: host.raspberrypi iobroker npm-install: upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                                  2024-01-23 17:45:55.970  - info: host.raspberrypi iobroker npm-install: upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                                  2024-01-23 17:45:55.981  - info: host.raspberrypi iobroker npm-install: upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                                  2024-01-23 17:45:56.083  - info: host.raspberrypi iobroker npm-install: host.raspberrypi object system.adapter.discovery created/updated
                                  2024-01-23 17:45:57.159  - info: host.raspberrypi iobroker npm-install: exit 0
                                  2024-01-23 17:45:57.209  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 209055
                                  2024-01-23 17:45:58.159  - warn: host.raspberrypi startInstance cannot find adapter "backitup@2.9.8". Try to install it... 1 attempt
                                  2024-01-23 17:45:58.160  - info: host.raspberrypi iobroker install backitup@2.9.8 using installedFrom
                                    meine Internetleitung spinnt gerade
                                    soll ich d
                                    iob fix ausführen
                                      Homoran Global Moderator Administrators @Borkenkäfer last edited by
                                      soll ich d
                                      iob fix ausführen
                                      was soll der bringen?
                                      wird da gerade ein Backup wiederhergestellt?
                                        Borkenkäfer @Homoran last edited by
                                        das steht im full drin
                                          ich mach sonst nichts, nur nach Anweisung
                                            das sind Meldungen bei einem Restore
                                            3688
