    4. Router gewechselt, kein Zugriff auf Weboberfläche mehr
    • Samson71
      Samson71 Global Moderator @fiedles last edited by
      @sebastian-fiedler
      Das ist nur der Summary. Die Helfer brauchen i.d.R. die Full Ausgabe. Den bitte auch in Code Tags. Hatte @Homoran weiter oben auch geschrieben.
      • fiedles
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 10 (buster)
                    Kernel: Linux 5.10.103-v7l+
              Architecture: arm
        Model           : Raspberry Pi 4 Model B Rev 1.4
        Docker          : false
        Virtualization  : none
        Kernel          : armv7l
        Userland        : armhf
        Systemuptime and Load:
         20:17:50 up 19:48,  1 user,  load average: 1.32, 1.07, 0.93
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        ~ Under-voltage has occurred
        ~ Arm frequency capping has occurred
        *** Time and Time Zones ***
                       Local time: Mon 2024-01-22 20:17:50 CET
                   Universal time: Mon 2024-01-22 19:17:50 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:           7.9G        1.7G        5.4G        8.0M        887M        6.0G
        Swap:           99M          0B         99M
        Total:         8.0G        1.7G        5.5G
                 7898 M total memory
                 1654 M used memory
                  533 M active memory
                 1788 M inactive memory
                 5356 M free memory
                  241 M buffer memory
                  646 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
        0 loaded units listed. Pass --all to see loaded but inactive units, too.
        To show all installed unit files use 'systemctl list-unit-files'.
        *** FILESYSTEM ***
        /dev/root      ext4      117G   13G  100G  12% /
        devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     3.9G  8.5M  3.9G   1% /run
        tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
        /dev/mmcblk0p1 vfat      253M   50M  203M  20% /boot
        tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
        [Mon Jan 22 00:28:53 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:F9:AF:43 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c5b1c200-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
        [Mon Jan 22 00:28:54 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
        [Mon Jan 22 00:28:54 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
        [Mon Jan 22 00:28:55 2024] EXT4-fs (mmcblk0p2): recovery complete
        [Mon Jan 22 00:28:55 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [Mon Jan 22 00:28:55 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Mon Jan 22 00:28:57 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        TARGET        SOURCE         FSTYPE OPTIONS
        /             /dev/mmcblk0p2 ext4   rw,noatime
        |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
        `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        347M    /var/
        151M    /var/cache
        145M    /var/cache/apt
        93M     /var/lib
        86M     /var/cache/apt/archives
        Archived and active journals take up 8.0M in the file system.
        /opt/iobroker/backups:
        5.5G    /opt/iobroker/backups/
        4.0K    /opt/iobroker/backups/redistmp
        /opt/iobroker/iobroker-data:
        707M    /opt/iobroker/iobroker-data/
        552M    /opt/iobroker/iobroker-data/files
        116M    /opt/iobroker/iobroker-data/backup-objects
        89M     /opt/iobroker/iobroker-data/files/echarts.admin
        57M     /opt/iobroker/iobroker-data/files/javascript.admin
        36M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
        24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.0
        /usr/bin/node           v18.19.0
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.0-1nodesource1
          Candidate: 18.19.0-1nodesource1
          Version table:
         *** 18.19.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                100 /var/lib/dpkg/status
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
             10.24.0~dfsg-1~deb10u3 500
        No problems detected
        Errors in npm tree:
        npm ERR! code ELSPROBLEMS
        npm ERR! missing: homebridge-fibaro-hc2@^2.4.3, required by iobroker.ham@5.3.1
        npm ERR! missing: homebridge@^1.5.0, required by iobroker.ham@5.3.1
        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-01-22T19_17_59_433Z-debug-0.log
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.17
        admin:          6.13.15
        javascript:     7.7.0
        Adapters from github:   0
        Adapter State
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.28, run as: admin
        + system.adapter.alarm.0                  : alarm                 : iobroker                                 -  enabled
        + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
          system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
        + system.adapter.broadlink2.0             : broadlink2            : iobroker                                 -  enabled
        + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
          system.adapter.devices.0                : devices               : iobroker                                 -  enabled
        + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
          system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
        + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
        + system.adapter.geofency.0               : geofency              : iobroker                                 -  enabled, port: 7999, bind: 0.0.0.0
        + system.adapter.ham.0                    : ham                   : iobroker                                 -  enabled
        + system.adapter.history.0                : history               : iobroker                                 -  enabled
        + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
        + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
        + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
        + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
        + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
        + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
        + system.adapter.onvif.0                  : onvif                 : iobroker                                 -  enabled
        + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
        + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
        + system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled
        + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
        + system.adapter.sony-bravia.0            : sony-bravia           : iobroker                                 -  enabled
        + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
        + system.adapter.systeminfo.0             : systeminfo            : iobroker                                 -  enabled
        + system.adapter.tado.0                   : tado                  : iobroker                                 -  enabled
        + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
          system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
          system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 -  enabled
          system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.yahka.0                  : yahka                 : iobroker                                 - disabled
          system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): beta
        Installed ioBroker-Instances
        Used repository: beta
        Adapter    "admin"        : 6.13.15  , installed 6.13.15
        Adapter    "alarm"        : 3.6.0    , installed 3.6.0
        Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
        Adapter    "backitup"     : 2.10.5   , installed 2.10.5
        Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
        Adapter    "echarts"      : 1.7.2    , installed 1.7.2
        Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
        Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
        Adapter    "geofency"     : 1.2.4    , installed 1.2.4
        Adapter    "ham"          : 5.3.1    , installed 5.3.1
        Adapter    "hue"          : 3.10.2   , installed 3.10.2
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
        Adapter    "javascript"   : 7.7.0    , installed 7.7.0
        Controller "js-controller": 5.0.17   , installed 5.0.17
        Adapter    "net-tools"    : 1.0.3    , installed 1.0.3
        Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
        Adapter    "onvif"        : 1.1.2    , installed 1.1.2
        Adapter    "pushover"     : 3.0.6    , installed 3.0.6
        Adapter    "roborock"     : 0.4.4    , installed 0.4.4
        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
        Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.9
        Adapter    "speedport"    : 0.0.3    , installed 0.0.3
        Adapter    "synology"     : 3.0.1    , installed 3.0.1
        Adapter    "systeminfo"   : 1.1.0    , installed 1.1.0
        Adapter    "tado"         : 0.5.1    , installed 0.5.1
        Adapter    "telegram"     : 3.0.1    , installed 3.0.1
        Adapter    "telegram-menu": 1.6.2    , installed 1.6.2
        Adapter    "text2command" : 3.0.3    , installed 3.0.3
        Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
        Adapter    "web"          : 6.2.3    , installed 6.2.3
        Adapter    "ws"           : 2.5.10   , installed 2.5.10
        Adapter    "yahka"        : 1.0.3    , installed 1.0.3
        Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
        Objects and States
        Objects:        9671
        States:         7613
        Hit:1 http://archive.raspberrypi.org/debian buster InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       47151      5047/io.jarvis.0
        tcp        0      0 192.168.178.28:8081     0.0.0.0:*               LISTEN      1001       38575      4099/io.admin.0
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17293      635/sshd
        tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       41311      4288/io.sonoff.0
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       40312      4081/iobroker.js-co
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       40305      4081/iobroker.js-co
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       45338      4697/io.web.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          17295      635/sshd
        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       45176      4641/io.simple-api.
        tcp6       0      0 :::39319                :::*                    LISTEN      1001       38762      4261/io.ham.0
        tcp6       0      0 :::7999                 :::*                    LISTEN      1001       38666      4200/io.geofency.0
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15973      627/dhcpcd
        udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       45685      4869/io.broadlink2.
        udp        0      0 0.0.0.0:34980           0.0.0.0:*                           108        16898      405/avahi-daemon: r
        udp        0      0 0.0.0.0:52438           0.0.0.0:*                           1001       45768      4869/io.broadlink2.
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       38763      4261/io.ham.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16896      405/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          14830      627/dhcpcd
        udp6       0      0 :::51405                :::*                                108        16899      405/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        16897      405/avahi-daemon: r
        2024-01-22 20:17:26.135  - error: tr-064.0 (16095) ~
        2024-01-22 20:17:26.137  - warn: tr-064.0 (16095) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
        2024-01-22 20:17:26.796  - error: host.iobroker instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2024-01-22 20:17:26.797  - info: host.iobroker Restart adapter system.adapter.tr-064.0 because enabled
        2024-01-22 20:17:56.934  - info: host.iobroker instance system.adapter.tr-064.0 started with pid 16300
        2024-01-22 20:18:00.803  - info: tr-064.0 (16300) starting. Version 4.2.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v18.19.0, js-controller: 5.0.17
        2024-01-22 20:18:01.139  - error: tr-064.0 (16300) Error: getaddrinfo ENOTFOUND http - {"errno":-3008,"code":"ENOTFOUND","syscall":"getaddrinfo","hostname":"http"}
        2024-01-22 20:18:01.140  - error: tr-064.0 (16300) ~
        2024-01-22 20:18:01.141  - error: tr-064.0 (16300) ~~ Fatal error. Can not connect to your FritzBox.
        2024-01-22 20:18:01.142  - error: tr-064.0 (16300) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
        2024-01-22 20:18:01.143  - error: tr-064.0 (16300) ~
        2024-01-22 20:18:01.145  - warn: tr-064.0 (16300) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
        2024-01-22 20:18:01.812  - error: host.iobroker instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2024-01-22 20:18:01.813  - info: host.iobroker Restart adapter system.adapter.tr-064.0 because enabled
        2024-01-22 20:18:31.936  - info: host.iobroker instance system.adapter.tr-064.0 started with pid 16451
        2024-01-22 20:18:35.612  - info: tr-064.0 (16451) starting. Version 4.2.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v18.19.0, js-controller: 5.0.17
        2024-01-22 20:18:35.943  - error: tr-064.0 (16451) Error: getaddrinfo ENOTFOUND http - {"errno":-3008,"code":"ENOTFOUND","syscall":"getaddrinfo","hostname":"http"}
        2024-01-22 20:18:35.944  - error: tr-064.0 (16451) ~
        2024-01-22 20:18:35.945  - error: tr-064.0 (16451) ~~ Fatal error. Can not connect to your FritzBox.
        2024-01-22 20:18:35.946  - error: tr-064.0 (16451) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
        2024-01-22 20:18:35.947  - error: tr-064.0 (16451) ~
        2024-01-22 20:18:35.949  - warn: tr-064.0 (16451) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
        2024-01-22 20:18:36.586  - error: host.iobroker instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        2024-01-22 20:18:36.586  - info: host.iobroker Restart adapter system.adapter.tr-064.0 because enabled
        2024-01-22 20:19:06.786  - info: host.iobroker instance system.adapter.tr-064.0 started with pid 16847
        Homoran Glasfaser 3 Replies Last reply Reply Quote 0
          Homoran Global Moderator Administrators @fiedles last edited by Homoran
          @sebastian-fiedler sagte in Router gewechselt, kein Zugriff auf Weboberfläche mehr:
          was ist das für eine IP?
          da hätte 0.0.0.0 hingehört
          • fiedles
            das ist die IP von meinem Netzwerk wie sie vorher war und die ich dann nochmal meinem Broker zugewiesen habe
              Thomas Braun Most Active @fiedles last edited by
              @sebastian-fiedler
              Jetzt hast du den ioBroker-Host an sich selber gebunden?
                ich finde den Befehl zum fixen nicht mehr.
                war etwas wie iob set admin bind 0.0.0.0
                aber ohne Gewähr
                EDIT:
                gefunden!
                @sebastian-fiedler iobroker set admin.0 --bind 0.0.0.0
                Bitte ausführen
                Glasfaser 1 Reply Last reply Reply Quote 1
                • Glasfaser
                  Glasfaser @Homoran last edited by
                    Homoran Global Moderator Administrators @Glasfaser last edited by
                    @glasfaser sagte in Router gewechselt, kein Zugriff auf Weboberfläche mehr:
                    jepp, hab's gerade editiert
                      bist du sicher?
                      du hast einige
                      getaddrinfo
                      Fehler im log.
                      läuft bei dir überhaupt noch IPv4?
                      • fiedles
                        hab den Befehl nicht ausgeführt, aber jetzt nochmal probiert auf die Weboberfläche zu kommen. Es geht nochmal. Fragt mich nicht warum, aber für mich war das soweit sinnvoll den Broker nochmal auf die alte IP zu stellen. Hat sich wohl in der Zwischenzeit seit gestern alles soweit erneuert, dass es jetzt nochmal geht.
                        danke euch für euren Support 👍 👍 👍
                          jetzt nochmal?
                          dann hatte sich wohl was verknotet
                          womöglich war die .28 bereits vergeben und musste neu verteilt werden.
                          aber ändere bitte sofort die Einstellungen im admin auf 0.0.0.0
                          fiedles 1 Reply Last reply Reply Quote 0
                          • fiedles
                            jetzt wo es funktioniert, sicher dass ich mir damit dann nix verschieße?
                            könnt ihr mir den Befehl bzw. den Hintergrund erklären bitte
                            Homoran Glasfaser 2 Replies Last reply Reply Quote 0
                              das kannst du ja jetzt in den Instanzen machen.
                              • fiedles
                                fiedles @Homoran last edited by
                                @homoran mag sein, dass der Speedport da ne ganze Weile gebraucht hat, denn ich musste den IP Bereich erweitern um dem Broker die 28 nochmal zuweisen zu können.
                                • Glasfaser
                                  Glasfaser @fiedles last edited by
                                  alle IP Adressen haben zugriff auf Admin
                                    @sebastian-fiedler
                                    https://www.iobroker.net/#de/adapters/adapterref/iobroker.admin/README.md?ip
                                    • fiedles
                                      pi@iobroker:~ $ iobroker set admin.0 --bind 0.0.0.0
                                      New bind for "admin.0" is: 0.0.0.0
                                      Instance settings for "admin.0" are changed.
                                        na gut, jetzt hast du es doch über die Konsole gemacht
                                          nee, du kannst den admin erreichen, egal welche IP er gerade hat.
                                          • Glasfaser
                                            https://forum.iobroker.net/post/141920
                                            94
                                            2755
