    4. Router gewechselt, kein Zugriff auf Weboberfläche mehr
    • fiedles
      fiedles last edited by
      Skript v.2023-10-10
      *** BASE SYSTEM ***
         Static hostname: iobroker
               Icon name: computer
        Operating System: Raspbian GNU/Linux 10 (buster)
                  Kernel: Linux 5.10.103-v7l+
            Architecture: arm
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Docker          : false
      Virtualization  : none
      Kernel          : armv7l
      Userland        : armhf
      Systemuptime and Load:
       20:17:50 up 19:48,  1 user,  load average: 1.32, 1.07, 0.93
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      ~ Under-voltage has occurred
      ~ Arm frequency capping has occurred
      *** Time and Time Zones ***
                     Local time: Mon 2024-01-22 20:17:50 CET
                 Universal time: Mon 2024-01-22 19:17:50 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:           7.9G        1.7G        5.4G        8.0M        887M        6.0G
      Swap:           99M          0B         99M
      Total:         8.0G        1.7G        5.5G
               7898 M total memory
               1654 M used memory
                533 M active memory
               1788 M inactive memory
               5356 M free memory
                241 M buffer memory
                646 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed. Pass --all to see loaded but inactive units, too.
      To show all installed unit files use 'systemctl list-unit-files'.
      *** FILESYSTEM ***
      /dev/root      ext4      117G   13G  100G  12% /
      devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     3.9G  8.5M  3.9G   1% /run
      tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
      /dev/mmcblk0p1 vfat      253M   50M  203M  20% /boot
      tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
      [Mon Jan 22 00:28:53 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:F9:AF:43 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c5b1c200-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
      [Mon Jan 22 00:28:54 2024] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
      [Mon Jan 22 00:28:54 2024] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
      [Mon Jan 22 00:28:55 2024] EXT4-fs (mmcblk0p2): recovery complete
      [Mon Jan 22 00:28:55 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
      [Mon Jan 22 00:28:55 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Mon Jan 22 00:28:57 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
      TARGET        SOURCE         FSTYPE OPTIONS
      /             /dev/mmcblk0p2 ext4   rw,noatime
      |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
      `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      347M    /var/
      151M    /var/cache
      145M    /var/cache/apt
      93M     /var/lib
      86M     /var/cache/apt/archives
      Archived and active journals take up 8.0M in the file system.
      /opt/iobroker/backups:
      5.5G    /opt/iobroker/backups/
      4.0K    /opt/iobroker/backups/redistmp
      /opt/iobroker/iobroker-data:
      707M    /opt/iobroker/iobroker-data/
      552M    /opt/iobroker/iobroker-data/files
      116M    /opt/iobroker/iobroker-data/backup-objects
      89M     /opt/iobroker/iobroker-data/files/echarts.admin
      57M     /opt/iobroker/iobroker-data/files/javascript.admin
      36M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
      35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
      24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
       *** 18.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
           10.24.0~dfsg-1~deb10u3 500
      No problems detected
      Errors in npm tree:
      npm ERR! code ELSPROBLEMS
      npm ERR! missing: homebridge-fibaro-hc2@^2.4.3, required by iobroker.ham@5.3.1
      npm ERR! missing: homebridge@^1.5.0, required by iobroker.ham@5.3.1
      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-01-22T19_17_59_433Z-debug-0.log
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.13.15
      javascript:     7.7.0
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.28, run as: admin
      + system.adapter.alarm.0                  : alarm                 : iobroker                                 -  enabled
      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
        system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
      + system.adapter.broadlink2.0             : broadlink2            : iobroker                                 -  enabled
      + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
        system.adapter.devices.0                : devices               : iobroker                                 -  enabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
      + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
        system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
      + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
      + system.adapter.geofency.0               : geofency              : iobroker                                 -  enabled, port: 7999, bind: 0.0.0.0
      + system.adapter.ham.0                    : ham                   : iobroker                                 -  enabled
      + system.adapter.history.0                : history               : iobroker                                 -  enabled
      + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
      + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
      + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
      + system.adapter.onvif.0                  : onvif                 : iobroker                                 -  enabled
      + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
      + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
      + system.adapter.roborock.0               : roborock              : iobroker                                 -  enabled
      + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
      + system.adapter.sony-bravia.0            : sony-bravia           : iobroker                                 -  enabled
      + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
      + system.adapter.systeminfo.0             : systeminfo            : iobroker                                 -  enabled
      + system.adapter.tado.0                   : tado                  : iobroker                                 -  enabled
      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
        system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
        system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 -  enabled
        system.adapter.vis-metro.0              : vis-metro             : iobroker                                 -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.yahka.0                  : yahka                 : iobroker                                 - disabled
        system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): beta
      Installed ioBroker-Instances
      Used repository: beta
      Adapter    "admin"        : 6.13.15  , installed 6.13.15
      Adapter    "alarm"        : 3.6.0    , installed 3.6.0
      Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
      Adapter    "backitup"     : 2.10.5   , installed 2.10.5
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "echarts"      : 1.7.2    , installed 1.7.2
      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
      Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
      Adapter    "geofency"     : 1.2.4    , installed 1.2.4
      Adapter    "ham"          : 5.3.1    , installed 5.3.1
      Adapter    "hue"          : 3.10.2   , installed 3.10.2
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 7.7.0    , installed 7.7.0
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "net-tools"    : 1.0.3    , installed 1.0.3
      Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
      Adapter    "onvif"        : 1.1.2    , installed 1.1.2
      Adapter    "pushover"     : 3.0.6    , installed 3.0.6
      Adapter    "roborock"     : 0.4.4    , installed 0.4.4
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.9
      Adapter    "speedport"    : 0.0.3    , installed 0.0.3
      Adapter    "synology"     : 3.0.1    , installed 3.0.1
      Adapter    "systeminfo"   : 1.1.0    , installed 1.1.0
      Adapter    "tado"         : 0.5.1    , installed 0.5.1
      Adapter    "telegram"     : 3.0.1    , installed 3.0.1
      Adapter    "telegram-menu": 1.6.2    , installed 1.6.2
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
      Adapter    "web"          : 6.2.3    , installed 6.2.3
      Adapter    "ws"           : 2.5.10   , installed 2.5.10
      Adapter    "yahka"        : 1.0.3    , installed 1.0.3
      Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
      Objects and States
      Objects:        9671
      States:         7613
      Hit:1 http://archive.raspberrypi.org/debian buster InRelease
      Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       47151      5047/io.jarvis.0
      tcp        0      0 192.168.178.28:8081     0.0.0.0:*               LISTEN      1001       38575      4099/io.admin.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17293      635/sshd
      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       41311      4288/io.sonoff.0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       40312      4081/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       40305      4081/iobroker.js-co
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       45338      4697/io.web.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          17295      635/sshd
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       45176      4641/io.simple-api.
      tcp6       0      0 :::39319                :::*                    LISTEN      1001       38762      4261/io.ham.0
      tcp6       0      0 :::7999                 :::*                    LISTEN      1001       38666      4200/io.geofency.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          15973      627/dhcpcd
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       45685      4869/io.broadlink2.
      udp        0      0 0.0.0.0:34980           0.0.0.0:*                           108        16898      405/avahi-daemon: r
      udp        0      0 0.0.0.0:52438           0.0.0.0:*                           1001       45768      4869/io.broadlink2.
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       38763      4261/io.ham.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        16896      405/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          14830      627/dhcpcd
      udp6       0      0 :::51405                :::*                                108        16899      405/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        16897      405/avahi-daemon: r
      2024-01-22 20:17:26.135  - error: tr-064.0 (16095) ~
      2024-01-22 20:17:26.137  - warn: tr-064.0 (16095) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
      2024-01-22 20:17:26.796  - error: host.iobroker instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-01-22 20:17:26.797  - info: host.iobroker Restart adapter system.adapter.tr-064.0 because enabled
      2024-01-22 20:17:56.934  - info: host.iobroker instance system.adapter.tr-064.0 started with pid 16300
      2024-01-22 20:18:00.803  - info: tr-064.0 (16300) starting. Version 4.2.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v18.19.0, js-controller: 5.0.17
      2024-01-22 20:18:01.139  - error: tr-064.0 (16300) Error: getaddrinfo ENOTFOUND http - {"errno":-3008,"code":"ENOTFOUND","syscall":"getaddrinfo","hostname":"http"}
      2024-01-22 20:18:01.140  - error: tr-064.0 (16300) ~
      2024-01-22 20:18:01.141  - error: tr-064.0 (16300) ~~ Fatal error. Can not connect to your FritzBox.
      2024-01-22 20:18:01.142  - error: tr-064.0 (16300) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
      2024-01-22 20:18:01.143  - error: tr-064.0 (16300) ~
      2024-01-22 20:18:01.145  - warn: tr-064.0 (16300) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
      2024-01-22 20:18:01.812  - error: host.iobroker instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-01-22 20:18:01.813  - info: host.iobroker Restart adapter system.adapter.tr-064.0 because enabled
      2024-01-22 20:18:31.936  - info: host.iobroker instance system.adapter.tr-064.0 started with pid 16451
      2024-01-22 20:18:35.612  - info: tr-064.0 (16451) starting. Version 4.2.18 in /opt/iobroker/node_modules/iobroker.tr-064, node: v18.19.0, js-controller: 5.0.17
      2024-01-22 20:18:35.943  - error: tr-064.0 (16451) Error: getaddrinfo ENOTFOUND http - {"errno":-3008,"code":"ENOTFOUND","syscall":"getaddrinfo","hostname":"http"}
      2024-01-22 20:18:35.944  - error: tr-064.0 (16451) ~
      2024-01-22 20:18:35.945  - error: tr-064.0 (16451) ~~ Fatal error. Can not connect to your FritzBox.
      2024-01-22 20:18:35.946  - error: tr-064.0 (16451) ~~ If configuration, network, IP address, etc. ok, try to restart your FritzBox
      2024-01-22 20:18:35.947  - error: tr-064.0 (16451) ~
      2024-01-22 20:18:35.949  - warn: tr-064.0 (16451) Terminated (JS_CONTROLLER_STOPPED): Fatal error. Can not connect to your FritzBox.
      2024-01-22 20:18:36.586  - error: host.iobroker instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2024-01-22 20:18:36.586  - info: host.iobroker Restart adapter system.adapter.tr-064.0 because enabled
      2024-01-22 20:19:06.786  - info: host.iobroker instance system.adapter.tr-064.0 started with pid 16847
      Homoran Glasfaser 3 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @fiedles last edited by Homoran
        @sebastian-fiedler sagte in Router gewechselt, kein Zugriff auf Weboberfläche mehr:
        was ist das für eine IP?
        da hätte 0.0.0.0 hingehört
        • fiedles
          das ist die IP von meinem Netzwerk wie sie vorher war und die ich dann nochmal meinem Broker zugewiesen habe
            Thomas Braun Most Active @fiedles last edited by
            @sebastian-fiedler
            Jetzt hast du den ioBroker-Host an sich selber gebunden?
              ich finde den Befehl zum fixen nicht mehr.
              war etwas wie iob set admin bind 0.0.0.0
              aber ohne Gewähr
              EDIT:
              gefunden!
              @sebastian-fiedler iobroker set admin.0 --bind 0.0.0.0
              Bitte ausführen
              Glasfaser 1 Reply Last reply Reply Quote 1
              • Glasfaser
                Glasfaser @Homoran last edited by
                  Homoran Global Moderator Administrators @Glasfaser last edited by
                  @glasfaser sagte in Router gewechselt, kein Zugriff auf Weboberfläche mehr:
                  jepp, hab's gerade editiert
                    bist du sicher?
                    du hast einige
                    getaddrinfo
                    Fehler im log.
                    läuft bei dir überhaupt noch IPv4?
                    • fiedles
                      hab den Befehl nicht ausgeführt, aber jetzt nochmal probiert auf die Weboberfläche zu kommen. Es geht nochmal. Fragt mich nicht warum, aber für mich war das soweit sinnvoll den Broker nochmal auf die alte IP zu stellen. Hat sich wohl in der Zwischenzeit seit gestern alles soweit erneuert, dass es jetzt nochmal geht.
                      danke euch für euren Support 👍 👍 👍
                        jetzt nochmal?
                        dann hatte sich wohl was verknotet
                        womöglich war die .28 bereits vergeben und musste neu verteilt werden.
                        aber ändere bitte sofort die Einstellungen im admin auf 0.0.0.0
                        fiedles 1 Reply Last reply Reply Quote 0
                        • fiedles
                          jetzt wo es funktioniert, sicher dass ich mir damit dann nix verschieße?
                          könnt ihr mir den Befehl bzw. den Hintergrund erklären bitte
                          Homoran Glasfaser 2 Replies Last reply Reply Quote 0
                            das kannst du ja jetzt in den Instanzen machen.
                            • fiedles
                              fiedles @Homoran last edited by
                              @homoran mag sein, dass der Speedport da ne ganze Weile gebraucht hat, denn ich musste den IP Bereich erweitern um dem Broker die 28 nochmal zuweisen zu können.
                              • Glasfaser
                                Glasfaser @fiedles last edited by
                                alle IP Adressen haben zugriff auf Admin
                                  @sebastian-fiedler
                                  https://www.iobroker.net/#de/adapters/adapterref/iobroker.admin/README.md?ip
                                  • fiedles
                                    pi@iobroker:~ $ iobroker set admin.0 --bind 0.0.0.0
                                    New bind for "admin.0" is: 0.0.0.0
                                    Instance settings for "admin.0" are changed.
                                      na gut, jetzt hast du es doch über die Konsole gemacht
                                        nee, du kannst den admin erreichen, egal welche IP er gerade hat.
                                        • Glasfaser
                                          https://forum.iobroker.net/post/141920
                                            Homoran Global Moderator Administrators @Glasfaser last edited by Homoran
                                            Archäologe!
                                            seitdem man mich nach diesem Post mehrfach belehrt hat, dass das falsch war, habe ich mich jetzt gemäß der Aussage der anderen angepasst.
                                            Wenn man es nachvollzieht und bei verschiedene nNetzwerkschnittstellen auf eine beschränken will, erhibt das sogar Sinn.
                                            94
                                            2755
