    3. Off Topic
    4. InfluxDB
    5. Keinen zugriff auf Influx DB
      Thomas Braun Most Active @Herrx last edited by Thomas Braun
      @herrx sagte in Keinen zugriff auf Influx DB:
      Was kann ich dagegen machen?
      Erstmal kein Filmchen von juhtjube anschauen. Die allerwenigsten sind gut.
      sudo rm /etc/apt/sources.list.d/influx*
      wget -q https://repos.influxdata.com/influxdata-archive_compat.key
      echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null
      echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
      rm influxdata-archive_compat.ke*
      Dann
      sudo apt update
      apt policy influx*
        Herrx @Thomas Braun last edited by Herrx
        @thomas-braun said in Keinen zugriff auf Influx DB:
        sudo rm /etc/apt/sources.list.d/influx* wget -q https://repos.influxdata.com/influxdata-archive_compat.key echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list rm influxdata-archive_compat.ke*
        pi@raspberrypi:~ $ sudo rm /etc/apt/sources.list.d/influx*
        influxdata-archive_compat.key: OK
        pi@raspberrypi:~ $
        pi@raspberrypi:~ $ sudo apt update
        apt policy influx*
        Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
        Hit:2 http://deb.debian.org/debian bookworm InRelease
        Get:4 http://deb.debian.org/debian bookworm-updates InRelease [52.1 kB]
        Hit:5 https://repos.influxdata.com/debian stable InRelease
        Hit:6 https://apt.grafana.com stable InRelease
        Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
        Fetched 52.1 kB in 2s (26.4 kB/s)
        Reading package lists... Done
        Building dependency tree... Done
        All packages are up to date.
        influxdb2-cli:
          Installed: (none)
          Candidate: 2.7.3-1
          Version table:
             2.7.3-1 500
                500 https://repos.influxdata.com/debian stable/main arm64 Packages
             2.7.1-2 500
             2.6.1 500
             2.6.0 500
             2.5.0 500
             2.4.0 500
             2.3.0 500
        influxdb-client:
          Installed: (none)
          Candidate: 1.6.7~rc0-1+b13
          Version table:
             1.6.7~rc0-1+b13 500
        influxdb-dev:
          Installed: (none)
          Candidate: (none)
          Version table:
        influxdb2-client:
          Installed: (none)
          Candidate: 2.7.1-1
          Version table:
             2.7.1-1 500
        influxdb:
          Installed: 1.8.10-1
          Candidate: 1.8.10-1
          Version table:
         *** 1.8.10-1 500
                100 /var/lib/dpkg/status
             1.6.7~rc0-1+b13 500
        influxctl:
          Installed: (none)
          Candidate: 2.4.3
          Version table:
             2.4.3 500
             2.4.2 500
             2.4.1 500
             2.4.0 500
             2.3.1 500
             2.3.0 500
             2.2.0 500
             2.1.0 500
             2.0.4 500
             2.0.3 500
             2.0.2 500
             2.0.1 500
             2.0.0 500
        influxdb2:
          Installed: (none)
          Candidate: 2.7.5-1
          Version table:
             2.7.5-1 500
             2.7.4-1 500
             2.7.3-1 500
             2.7.1-1 500
             2.7.0-1 500
             2.6.1-1 500
             2.6.0-1 500
             2.5.1-1 500
             2.4.0-1 500
             2.3.0-1 500
             2.2.0 500
        pi@raspberrypi:~ $
        pi@raspberrypi:~ $ cat /etc/apt/sources.list.d/influxdb.list
        cat: /etc/apt/sources.list.d/influxdb.list: No such file or directory
          Richtig. Das heißt ja auch
          cat /etc/apt/sources.list.d/influxdata.list
            @thomas-braun Aber ich komme immer noch nicht auf das interface via http://RPI-IP:8086
              @herrx
              Wenn ich auf die Webseite gehe http://RPI-IP:8086 bekomme ich den Fehler 404 page not found.
              Kann ja auch nix kommen, die influxdb 1.8 hat auch kein WebGUI.
              Gibt es erst ab influxdb2.
                @thomas-braun Ah ok das macht Sinn. Hast du noch eine Anleitung um Grafana zu installieren =! Youtube?
                  @herrx
                  Grafana:
                  sudo apt-get install -y apt-transport-https
                  sudo apt-get install -y software-properties-common wget
                  sudo wget -q -O /usr/share/keyrings/grafana.key https://apt.grafana.com/gpg.key
                  echo "deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main" | sudo tee /etc/apt/sources.list.d/grafana.list
                  sudo apt update
                  sudo apt install grafana
        sudo apt update        sudo apt install grafana
                    pi@raspberrypi:~ $ sudo apt-get install -y apt-transport-https
                    apt-transport-https is already the newest version (2.6.1).
                    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                    software-properties-common is already the newest version (0.99.30-4).
                    wget is already the newest version (1.21.3-1+b1).
                    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                    Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                    grafana is already the newest version (10.2.3).
                    Super Danke. Aber Grafana kann ich ebenfalls nicht über die RPI-IP:3000 erreichen.
                      @herrx
                      systemctl status grafana
                        pi@raspberrypi:~ $ systemctl status grafana
                        Unit grafana.service could not be found.
                        pi@raspberrypi:~ $
                        ?? Aber die Installation war doch ohne Probleme ?
                          @herrx
                          systemctl status grafana*
                            pi@raspberrypi:~ $ systemctl status grafana*
                            pi@raspberrypi:~ $
                              @herrx
                              sudo apt update
                              apt policy grafana*
                                @herrx
                                Bzw:
                                sudo systemctl daemon-reload
                                sudo systemctl start grafana-server
                                sudo systemctl status grafana-server
                                  ● grafana-server.service - Grafana instance
                                       Loaded: loaded (/lib/systemd/system/grafana-server.service; disabled; preset: enabled)
                                       Active: active (running) since Tue 2024-01-23 00:04:49 CET; 34s ago
                                         Docs: http://docs.grafana.org
                                     Main PID: 19823 (grafana)
                                        Tasks: 15 (limit: 457)
                                          CPU: 9.853s
                                       CGroup: /system.slice/grafana-server.service
                                               └─19823 /usr/share/grafana/bin/grafana server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb cfg:default.pat>
                                  Jan 23 00:05:10 raspberrypi grafana[19823]: logger=provisioning.alerting t=2024-01-23T00:05:10.484274781+01:00 level=info msg="finished to provision alerting"
                                  Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ngalert.state.manager t=2024-01-23T00:05:10.487621618+01:00 level=info msg="Warming state cache for startup"
                                  Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ngalert.state.manager t=2024-01-23T00:05:10.489519141+01:00 level=info msg="State cache has been initialized" state>
                                  Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ngalert.scheduler t=2024-01-23T00:05:10.489682063+01:00 level=info msg="Starting scheduler" tickInterval=10s
                                  Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ticker t=2024-01-23T00:05:10.498451052+01:00 level=info msg=starting first_tick=2024-01-23T00:05:20+01:00
                                  Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ngalert.multiorg.alertmanager t=2024-01-23T00:05:10.498873707+01:00 level=info msg="Starting MultiOrg Alertmanager"
                                  Jan 23 00:05:10 raspberrypi grafana[19823]: logger=grafanaStorageLogger t=2024-01-23T00:05:10.505991925+01:00 level=info msg="Storage starting"
                                  Jan 23 00:05:10 raspberrypi grafana[19823]: logger=http.server t=2024-01-23T00:05:10.531073444+01:00 level=info msg="HTTP Server Listen" address=[::]:3000 protocol=ht>
                                  Jan 23 00:05:10 raspberrypi grafana[19823]: logger=grafana.update.checker t=2024-01-23T00:05:10.849257594+01:00 level=info msg="Update check succeeded" duration=342.5>
                                  Jan 23 00:05:10 raspberrypi grafana[19823]: logger=plugins.update.checker t=2024-01-23T00:05:10.868909627+01:00 level=info msg="Update check succeeded" d
                                  Sehr cool danke. Jetzt geht es.
                                    Thomas Braun Most Active last edited by
                                    @herrx
                                    Schau mal ob der auch nach einem Neustart auf die Beine kommt.
                                      @thomas-braun ok da kommt mein Grafana nicht wieder auf die Beine
                                        @herrx
                                        sudo systemctl enable grafana-server.service
                                        sudo systemctl start grafana-server.service
                                          @thomas-braun Super Danke das hat geholfen. Muss ich das nach jedem reboot wieder eingeben?
                                          jetzt habe ich die Grafana anzeige wieder. Allerdings gibt mir mein Solarman nur alle 6min den aktuellen Leistungswert. Kann ich die Punkte dazwischen interpolieren? oder zumindest die Punkte verbinden?
                                            Nein, der Service sollte nun beim booten gestartet werden.
                                            1439
