    3. Off Topic
    4. InfluxDB
    5. Keinen zugriff auf Influx DB
      Herrx @Thomas Braun last edited by Herrx
      @thomas-braun said in Keinen zugriff auf Influx DB:
      sudo rm /etc/apt/sources.list.d/influx* wget -q https://repos.influxdata.com/influxdata-archive_compat.key echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /usr/share/keyrings/influxdata-archive_compat.gpg > /dev/null echo 'deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list rm influxdata-archive_compat.ke*
      pi@raspberrypi:~ $ sudo rm /etc/apt/sources.list.d/influx*
      influxdata-archive_compat.key: OK
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ sudo apt update
      apt policy influx*
      Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Get:4 http://deb.debian.org/debian bookworm-updates InRelease [52.1 kB]
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Hit:6 https://apt.grafana.com stable InRelease
      Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
      Fetched 52.1 kB in 2s (26.4 kB/s)
      Reading package lists... Done
      Building dependency tree... Done
      All packages are up to date.
      influxdb2-cli:
        Installed: (none)
        Candidate: 2.7.3-1
        Version table:
           2.7.3-1 500
              500 https://repos.influxdata.com/debian stable/main arm64 Packages
           2.7.1-2 500
           2.6.1 500
           2.6.0 500
           2.5.0 500
           2.4.0 500
           2.3.0 500
      influxdb-client:
        Installed: (none)
        Candidate: 1.6.7~rc0-1+b13
        Version table:
           1.6.7~rc0-1+b13 500
      influxdb-dev:
        Installed: (none)
        Candidate: (none)
        Version table:
      influxdb2-client:
        Installed: (none)
        Candidate: 2.7.1-1
        Version table:
           2.7.1-1 500
      influxdb:
        Installed: 1.8.10-1
        Candidate: 1.8.10-1
        Version table:
       *** 1.8.10-1 500
              100 /var/lib/dpkg/status
           1.6.7~rc0-1+b13 500
      influxctl:
        Installed: (none)
        Candidate: 2.4.3
        Version table:
           2.4.3 500
           2.4.2 500
           2.4.1 500
           2.4.0 500
           2.3.1 500
           2.3.0 500
           2.2.0 500
           2.1.0 500
           2.0.4 500
           2.0.3 500
           2.0.2 500
           2.0.1 500
           2.0.0 500
      influxdb2:
        Installed: (none)
        Candidate: 2.7.5-1
        Version table:
           2.7.5-1 500
           2.7.4-1 500
           2.7.3-1 500
           2.7.1-1 500
           2.7.0-1 500
           2.6.1-1 500
           2.6.0-1 500
           2.5.1-1 500
           2.4.0-1 500
           2.3.0-1 500
           2.2.0 500
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ cat /etc/apt/sources.list.d/influxdb.list
      cat: /etc/apt/sources.list.d/influxdb.list: No such file or directory
        Thomas Braun Most Active @Herrx last edited by
        @herrx sagte in Keinen zugriff auf Influx DB:
        Richtig. Das heißt ja auch
        cat /etc/apt/sources.list.d/influxdata.list
          @thomas-braun Aber ich komme immer noch nicht auf das interface via http://RPI-IP:8086
            Thomas Braun Most Active @Herrx last edited by Thomas Braun
            @herrx
            Wenn ich auf die Webseite gehe http://RPI-IP:8086 bekomme ich den Fehler 404 page not found.
            Kann ja auch nix kommen, die influxdb 1.8 hat auch kein WebGUI.
            Gibt es erst ab influxdb2.
              @thomas-braun Ah ok das macht Sinn. Hast du noch eine Anleitung um Grafana zu installieren =! Youtube?
                @herrx
                Grafana:
                sudo apt-get install -y apt-transport-https
                sudo apt-get install -y software-properties-common wget
                sudo wget -q -O /usr/share/keyrings/grafana.key https://apt.grafana.com/gpg.key
                echo "deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main" | sudo tee /etc/apt/sources.list.d/grafana.list
                sudo apt update
                sudo apt install grafana
        sudo apt update        sudo apt install grafana
                  pi@raspberrypi:~ $ sudo apt-get install -y apt-transport-https
                  apt-transport-https is already the newest version (2.6.1).
                  0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                  software-properties-common is already the newest version (0.99.30-4).
                  wget is already the newest version (1.21.3-1+b1).
                  Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                  Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                  Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                  grafana is already the newest version (10.2.3).
                  Super Danke. Aber Grafana kann ich ebenfalls nicht über die RPI-IP:3000 erreichen.
                    @herrx
                    systemctl status grafana
                      pi@raspberrypi:~ $ systemctl status grafana
                      Unit grafana.service could not be found.
                      pi@raspberrypi:~ $
                      ?? Aber die Installation war doch ohne Probleme ?
                        @herrx
                        systemctl status grafana*
                          pi@raspberrypi:~ $ systemctl status grafana*
                          pi@raspberrypi:~ $
                            @herrx
                            sudo apt update
                            apt policy grafana*
                              @herrx
                              Bzw:
                              sudo systemctl daemon-reload
                              sudo systemctl start grafana-server
                              sudo systemctl status grafana-server
                                ● grafana-server.service - Grafana instance
                                     Loaded: loaded (/lib/systemd/system/grafana-server.service; disabled; preset: enabled)
                                     Active: active (running) since Tue 2024-01-23 00:04:49 CET; 34s ago
                                       Docs: http://docs.grafana.org
                                   Main PID: 19823 (grafana)
                                      Tasks: 15 (limit: 457)
                                        CPU: 9.853s
                                     CGroup: /system.slice/grafana-server.service
                                             └─19823 /usr/share/grafana/bin/grafana server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb cfg:default.pat>
                                Jan 23 00:05:10 raspberrypi grafana[19823]: logger=provisioning.alerting t=2024-01-23T00:05:10.484274781+01:00 level=info msg="finished to provision alerting"
                                Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ngalert.state.manager t=2024-01-23T00:05:10.487621618+01:00 level=info msg="Warming state cache for startup"
                                Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ngalert.state.manager t=2024-01-23T00:05:10.489519141+01:00 level=info msg="State cache has been initialized" state>
                                Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ngalert.scheduler t=2024-01-23T00:05:10.489682063+01:00 level=info msg="Starting scheduler" tickInterval=10s
                                Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ticker t=2024-01-23T00:05:10.498451052+01:00 level=info msg=starting first_tick=2024-01-23T00:05:20+01:00
                                Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ngalert.multiorg.alertmanager t=2024-01-23T00:05:10.498873707+01:00 level=info msg="Starting MultiOrg Alertmanager"
                                Jan 23 00:05:10 raspberrypi grafana[19823]: logger=grafanaStorageLogger t=2024-01-23T00:05:10.505991925+01:00 level=info msg="Storage starting"
                                Jan 23 00:05:10 raspberrypi grafana[19823]: logger=http.server t=2024-01-23T00:05:10.531073444+01:00 level=info msg="HTTP Server Listen" address=[::]:3000 protocol=ht>
                                Jan 23 00:05:10 raspberrypi grafana[19823]: logger=grafana.update.checker t=2024-01-23T00:05:10.849257594+01:00 level=info msg="Update check succeeded" duration=342.5>
                                Jan 23 00:05:10 raspberrypi grafana[19823]: logger=plugins.update.checker t=2024-01-23T00:05:10.868909627+01:00 level=info msg="Update check succeeded" d
                                Sehr cool danke. Jetzt geht es.
                                  Thomas Braun Most Active last edited by
                                  @herrx
                                  Schau mal ob der auch nach einem Neustart auf die Beine kommt.
                                    @thomas-braun ok da kommt mein Grafana nicht wieder auf die Beine
                                      @herrx
                                      sudo systemctl enable grafana-server.service
                                      sudo systemctl start grafana-server.service
                                        @thomas-braun Super Danke das hat geholfen. Muss ich das nach jedem reboot wieder eingeben?
                                        jetzt habe ich die Grafana anzeige wieder. Allerdings gibt mir mein Solarman nur alle 6min den aktuellen Leistungswert. Kann ich die Punkte dazwischen interpolieren? oder zumindest die Punkte verbinden?
                                          Nein, der Service sollte nun beim booten gestartet werden.
                                          1412
