    3. Off Topic
    4. InfluxDB
    5. Keinen zugriff auf Influx DB
      Thomas Braun Most Active @Herrx last edited by
      @herrx
      Grafana:
      sudo apt-get install -y apt-transport-https
      sudo apt-get install -y software-properties-common wget
      sudo wget -q -O /usr/share/keyrings/grafana.key https://apt.grafana.com/gpg.key
      echo "deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main" | sudo tee /etc/apt/sources.list.d/grafana.list
      sudo apt update
      sudo apt install grafana
        Herrx @Thomas Braun last edited by
        @thomas-braun said in Keinen zugriff auf Influx DB:
        sudo apt update        sudo apt install grafana
        pi@raspberrypi:~ $ sudo apt-get install -y apt-transport-https
        Reading package lists... Done
        Building dependency tree... Done
        apt-transport-https is already the newest version (2.6.1).
        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
        software-properties-common is already the newest version (0.99.30-4).
        wget is already the newest version (1.21.3-1+b1).
        pi@raspberrypi:~ $ sudo apt update
        Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
        Hit:5 https://repos.influxdata.com/debian stable InRelease
        Hit:6 https://apt.grafana.com stable InRelease
        Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
        All packages are up to date.
        grafana is already the newest version (10.2.3).
        Super Danke. Aber Grafana kann ich ebenfalls nicht über die RPI-IP:3000 erreichen.
          @herrx
          systemctl status grafana
            Herrx @Thomas Braun last edited by Herrx
            pi@raspberrypi:~ $ systemctl status grafana
            Unit grafana.service could not be found.
            pi@raspberrypi:~ $
            ?? Aber die Installation war doch ohne Probleme ?
              @herrx
              systemctl status grafana*
                pi@raspberrypi:~ $ systemctl status grafana*
                pi@raspberrypi:~ $
                  @herrx
                  sudo apt update
                  apt policy grafana*
                    @herrx
                    Bzw:
                    sudo systemctl daemon-reload
                    sudo systemctl start grafana-server
                    sudo systemctl status grafana-server
                      ● grafana-server.service - Grafana instance
                           Loaded: loaded (/lib/systemd/system/grafana-server.service; disabled; preset: enabled)
                           Active: active (running) since Tue 2024-01-23 00:04:49 CET; 34s ago
                             Docs: http://docs.grafana.org
                         Main PID: 19823 (grafana)
                            Tasks: 15 (limit: 457)
                              CPU: 9.853s
                           CGroup: /system.slice/grafana-server.service
                                   └─19823 /usr/share/grafana/bin/grafana server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb cfg:default.pat>
                      Jan 23 00:05:10 raspberrypi grafana[19823]: logger=provisioning.alerting t=2024-01-23T00:05:10.484274781+01:00 level=info msg="finished to provision alerting"
                      Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ngalert.state.manager t=2024-01-23T00:05:10.487621618+01:00 level=info msg="Warming state cache for startup"
                      Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ngalert.state.manager t=2024-01-23T00:05:10.489519141+01:00 level=info msg="State cache has been initialized" state>
                      Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ngalert.scheduler t=2024-01-23T00:05:10.489682063+01:00 level=info msg="Starting scheduler" tickInterval=10s
                      Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ticker t=2024-01-23T00:05:10.498451052+01:00 level=info msg=starting first_tick=2024-01-23T00:05:20+01:00
                      Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ngalert.multiorg.alertmanager t=2024-01-23T00:05:10.498873707+01:00 level=info msg="Starting MultiOrg Alertmanager"
                      Jan 23 00:05:10 raspberrypi grafana[19823]: logger=grafanaStorageLogger t=2024-01-23T00:05:10.505991925+01:00 level=info msg="Storage starting"
                      Jan 23 00:05:10 raspberrypi grafana[19823]: logger=http.server t=2024-01-23T00:05:10.531073444+01:00 level=info msg="HTTP Server Listen" address=[::]:3000 protocol=ht>
                      Jan 23 00:05:10 raspberrypi grafana[19823]: logger=grafana.update.checker t=2024-01-23T00:05:10.849257594+01:00 level=info msg="Update check succeeded" duration=342.5>
                      Jan 23 00:05:10 raspberrypi grafana[19823]: logger=plugins.update.checker t=2024-01-23T00:05:10.868909627+01:00 level=info msg="Update check succeeded" d
                      Sehr cool danke. Jetzt geht es.
                        Thomas Braun Most Active last edited by
                        @herrx
                        Schau mal ob der auch nach einem Neustart auf die Beine kommt.
                          @thomas-braun ok da kommt mein Grafana nicht wieder auf die Beine
                            @herrx
                            sudo systemctl enable grafana-server.service
                            sudo systemctl start grafana-server.service
                              @thomas-braun Super Danke das hat geholfen. Muss ich das nach jedem reboot wieder eingeben?
                              jetzt habe ich die Grafana anzeige wieder. Allerdings gibt mir mein Solarman nur alle 6min den aktuellen Leistungswert. Kann ich die Punkte dazwischen interpolieren? oder zumindest die Punkte verbinden?
                                @herrx sagte in Keinen zugriff auf Influx DB:
                                Nein, der Service sollte nun beim booten gestartet werden.
                                1412
