    4. Test Adapter jablotron v.0.1.x
    • Codierknecht
      Codierknecht Developer Most Active last edited by
      Wäre schön, wenn die Tester hier nochmal ihr Fazit posten könnten.
      Dann könnte der Adapter ins Stable-Repo wandern.
      T Hant0r 2 Replies Last reply Reply Quote 1
        tritor @Codierknecht last edited by tritor
        @codierknecht
        bei mir steht der Adpater fast täglich, brauch dann manuellen Restart.
        hier das log bevor der Adapter sich verabschiedet hat:
        2024-01-15 05:57:32.713 - debug: jablotron.0 (1764400) thermoDevicesGet: {"data":{"service-states":{"last-event-time":"2024-01-15T04:41:42+0100","service-name":"xxxxxxx"},"states":[]},"http-code":200}
        2024-01-15 05:58:14.580 - debug: jablotron.0 (1764400) Fetch data from jablonet.net
        2024-01-15 05:58:14.586 - error: jablotron.0 (1764400) getServices: Error: getaddrinfo EAI_AGAIN api.jablonet.net
        2024-01-15 05:58:14.586 - error: jablotron.0 (1764400) getExtendedData: Error: getaddrinfo EAI_AGAIN api.jablonet.net
        2024-01-15 05:58:14.587 - error: jablotron.0 (1764400) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2024-01-15 05:58:14.587 - error: jablotron.0 (1764400) unhandled promise rejection: getaddrinfo EAI_AGAIN api.jablonet.net
        2024-01-15 05:58:14.587 - error: jablotron.0 (1764400) Error: getaddrinfo EAI_AGAIN api.jablonet.net
        at AxiosError.from (/opt/iobroker/node_modules/iobroker.jablotron/node_modules/axios/dist/node/axios.cjs:837:14)
        at RedirectableRequest.handleRequestError (/opt/iobroker/node_modules/iobroker.jablotron/node_modules/axios/dist/node/axios.cjs:3083:25)
        2024-01-15 05:58:14.587 - error: jablotron.0 (1764400) Exception-Code: EAI_AGAIN: getaddrinfo EAI_AGAIN api.jablonet.net
        2024-01-15 05:58:14.591 - info: jablotron.0 (1764400) terminating
        2024-01-15 05:58:14.591 - warn: jablotron.0 (1764400) Terminated (UNCAUGHT_EXCEPTION): Without reason
        2024-01-15 05:58:15.090 - info: jablotron.0 (1764400) terminating
        2024-01-15 05:58:15.144 - error: host.ioBroker-prox instance system.adapter.jablotron.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        2024-01-15 05:58:15.145 - info: host.ioBroker-prox Restart adapter system.adapter.jablotron.0 because enabled
        2024-01-15 05:58:45.202 - info: host.ioBroker-prox instance system.adapter.jablotron.0 started with pid 1813150
        2024-01-15 05:58:45.561 - info: jablotron.0 (1813150) setState not processed because States database not connected
        2024-01-15 05:58:45.646 - debug: jablotron.0 (1813150) Redis Objects: Use Redis connection: 127.0.0.1:9001
        2024-01-15 05:58:45.659 - debug: jablotron.0 (1813150) Objects client ready ... initialize now
        2024-01-15 05:58:45.661 - debug: jablotron.0 (1813150) Objects create System PubSub Client
        2024-01-15 05:58:45.661 - debug: jablotron.0 (1813150) Objects create User PubSub Client
        2024-01-15 05:58:45.679 - debug: jablotron.0 (1813150) Objects client initialize lua scripts
        2024-01-15 05:58:45.682 - debug: jablotron.0 (1813150) Objects connected to redis: 127.0.0.1:9001
        2024-01-15 05:58:45.704 - debug: jablotron.0 (1813150) Redis States: Use Redis connection: 127.0.0.1:6379
        2024-01-15 05:58:45.706 - debug: jablotron.0 (1813150) States create System PubSub Client
        2024-01-15 05:58:45.707 - debug: jablotron.0 (1813150) States create User PubSub Client
        2024-01-15 05:58:45.714 - debug: jablotron.0 (1813150) States connected to redis: 127.0.0.1:6379
        2024-01-15 05:58:45.764 - info: jablotron.0 (1813150) starting. Version 0.1.1 in /opt/iobroker/node_modules/iobroker.jablotron, node: v18.19.0, js-controller: 5.0.17
        2024-01-15 05:58:45.772 - debug: jablotron.0 (1813150) Fetching new session id
        2024-01-15 05:58:45.833 - error: jablotron.0 (1813150) Error: getaddrinfo EAI_AGAIN api.jablonet.net
        2024-01-15 05:58:45.834 - error: jablotron.0 (1813150) Error in onReady: Error: Not connect to jablonet.net
        • Hant0r
          Hant0r @Codierknecht last edited by
          @codierknecht
          Sorry, bei mir ist es so, dass der Adapter irgendwann auf gelb steht und nicht mehr funktioniert.
          Schätzungsweise einmal pro Tag. Habe ihn aber als "Info" laufen und im Log steht nichts.
          Wenn es hilft, lasse ich ihn mal die ganze Zeit mit "debug" laufen, spammt dann nur sehr das Log zu. 🙂
          • Codierknecht
            Codierknecht Developer Most Active @tritor last edited by
            @tritor sagte in Test Adapter jablotron v.0.1.x:
            EAI_AGAIN
            Das sieht nach einem DNS-Problem aus.
            Da muss ich mal die Kollegen fragen, wie man sowas am besten umgeht.
            Es wird dann vermutlich in Kürze eine neue Version geben.
            • Codierknecht
              Codierknecht Developer Most Active @Hant0r last edited by
              @hant0r sagte in Test Adapter jablotron v.0.1.x:
              Ich lasse den mal bei mir 'ne Weile laufen.
              Wenn's nur ein kurzer Stolperer beim DNS-Lookup ist, sollte das zu verschmerzen sein.
              Sollte ich dann vielleicht hochzählen und bei mehr als X aufeinanderfolgenden DNS-Fehlern aussteigen.
              • Codierknecht
                Das Portal des Herstellers scheint recht empfindlich zu sein.
                Auf GitHub findet ihr eine Version mit "Selbstheilungskräften". Die aktualisiert auch zur Sicherheit mal jede Stunde ihre Session-ID.
                • Codierknecht
                  Codierknecht Developer Most Active @Codierknecht last edited by
                  Wartet noch mit der neuen Version - da stimmt noch etwas nicht so ganz 😞
                  • Codierknecht
                    Das stündliche Aktualisieren der Session-ID - also quasi im "vorauseilenden Gehorsam" - funktioniert nicht so wie gewünscht.
                    Das habe ich jetzt wieder rausgenommen. Die ID wird nur noch nach einem HTTP 401 (not authorized) neu geholt.
                    Ich werde das noch eine Weile beobachten und dann die Version einchecken.
                    Ich gebe Bescheid, wenn es etwas zu testen gibt.
                    • Codierknecht
                      Aktuell sieht's recht vielversprechend aus ...
                      Ich gebe Bescheid, wenn's etwas zu installieren gibt.
                      • Codierknecht
                        Heute läuft er seit > 10 Std. durch.
                        Das Portal des Herstellers zickt aber zwischendurch immer mal wieder rum.
                        • Codierknecht
                          So - auf GitHub wurde gerade Version 0.1.3 veröffentlicht.
                          Die sollte in Kürze auch im Beta-Repository erscheinen.
                          Diese Version läuft jetzt seit einigen Tagen stabil durch.
                          Bitte bei Gelegenheit testen und hier Feedback geben, damit der Adapter dann auch ins Stable-Repo gehen kann.
                          T mike2507 2 Replies Last reply Reply Quote 2
                          • mike2507
                            mike2507 last edited by
                            @codierknecht
                            Danke für diesen Adapter.
                            Habe schon lange darauf gewartet.
                            Bis jetzt habe ich es über ham Adapter gelöst.
                            Werde den Adapter mal Testen und berichten.
                              @codierknecht
                              läuft seit gestern stabil. vielen Dank!
                              3.Feb.: immer noch alles paletti!
                              • mike2507
                                mike2507 @Codierknecht last edited by
                                @codierknecht
                                bei mir läuft auch alles stabil.
                                • Codierknecht
                                  Version 0.1.3 sollte in Kürze im Stable-Repository auftauchen 🙂
                                  Allen Testern an dieser Stelle schon mal einen großen Dank!
                                  • Hant0r
                                    Hant0r last edited by Hant0r
                                    Moin,
                                    Im Log kommt leider nur noch folgendes:
                                    jablotron.0 2024-03-04 09:46:19.655	warn	Communication error 400 (ERR_BAD_REQUEST).
                                    jablotron.0 2024-03-04 09:46:09.652	warn	Communication error 400 (ERR_BAD_REQUEST).
                                    jablotron.0 2024-03-04 09:45:59.646	warn	Communication error 400 (ERR_BAD_REQUEST).
                                    jablotron.0 2024-03-04 09:45:49.644	warn	Communication error 400 (ERR_BAD_REQUEST).
                                    Status vom Adapter ist grün.
                                    Nach einem Adapter-Neustart kommt nur noch das:
                                    jablotron.0 2024-03-04 09:46:27.153	error	Error in onReady: Error: Not connect to jablonet.net
                                    jablotron.0 2024-03-04 09:46:27.150	error	AxiosError: Request failed with status code 405
                                    jablotron.0 2024-03-04 09:46:26.827	info	starting. Version 0.1.3 (non-npm: DEV2DEV-DE/ioBroker.jablotron) in /opt/iobroker/node_modules/iobroker.jablotron, node: v18.19.1, js-controller: 5.0.19
                                    jablotron.0 2024-03-04 09:46:21.105	info	terminating
                                    jablotron.0 2024-03-04 09:46:20.767	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    jablotron.0 2024-03-04 09:46:20.766	info	terminating
                                    jablotron.0 2024-03-04 09:46:20.602	info	Got terminate signal TERMINATE_YOURSELF
                                    • Codierknecht
                                      Codierknecht Developer Most Active @Hant0r last edited by Codierknecht
                                      @hant0r
                                      Status 405 bedeutet "Method not allowed".
                                      Vermutlich hat Jablotron das API geändert.
                                      Mal sehen, ob ich herausbekomme was die da gemacht haben.
                                      Gab es vor kurzem mal ein Update der App?
                                      Hant0r 1 Reply Last reply Reply Quote 0
                                      • Codierknecht
                                        Scheinbar funktioniert der Adapter wieder.
                                        Möglicherweise nur Wartungsarbeiten bei Jablotron?
                                        Man weiß es nicht ;-(
                                        • Hant0r
                                          @codierknecht sagte in Test Adapter jablotron v.0.1.x:
                                          Letzte Aktualisierung war der 02.02.24
                                          Finde dazu leider nichts
                                          • O
                                            observer last edited by
                                            Der Vollständigkeit halber sei angemerkt, dass der Adapter nicht zur älteren Produktlinie OASIS-80 (auch bekannt als INDEXA System 8000) kompatibel ist.
                                            Ich habe es gerade eben getestet. Offenbar nutzt der Hersteller unterschiedliche Cloud-Implementationen.
                                            jablotron alarm system test
                                            3222
