    4. Iobroker lässt sich nicht mehr starten.
      Borkenkäfer @Borkenkäfer last edited by
      @borkenkäfer said in Iobroker lässt sich nicht mehr starten.:
      @glasfaser
      nach iob start komme ich über port 8081 noch nicht drauf
      und bei iob Update kommt
      iob update
      node:internal/modules/cjs/loader:1137
        throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
          at Module._load (node:internal/modules/cjs/loader:975:27)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
          at node:internal/main/run_main_module:28:49 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      Node.js v18.19.0
        Borkenkäfer @Glasfaser last edited by
        @glasfaser
        einmal full
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: raspberrypi
                 Icon name: computer
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.2
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : arm64
        Systemuptime and Load:
         19:36:21 up 12 min,  3 users,  load average: 0.03, 0.24, 0.27
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Mon 2024-01-22 19:36:21 CET
                   Universal time: Mon 2024-01-22 18:36:21 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        ulli
        /home/ulli
        ulli adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       true
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            3.8G        284M        2.7G         38M        855M        3.4G
        Swap:            99M          0B         99M
        Total:          3.9G        284M        2.8G
                 3794 M total memory
                  284 M used memory
                  583 M active memory
                  396 M inactive memory
                 2654 M free memory
                   54 M buffer memory
                  800 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4       59G   11G   46G  20% /
        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        tmpfs          tmpfs     759M  1.2M  758M   1% /run
        /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
        tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
        [Mon Jan 22 19:23:53 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:84:9D:5E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a9a74992-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Mon Jan 22 19:23:54 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Mon Jan 22 19:23:54 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Mon Jan 22 19:23:56 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        TARGET  SOURCE         FSTYPE OPTIONS
        /       /dev/mmcblk0p2 ext4   rw,noatime
        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        4.3G    /var/
        3.4G    /var/log
        2.9G    /var/log/journal/b741ffe02a684b9895597ea9866ca817
        641M    /var/cache
        Archived and active journals take up 2.8G in the file system.
        /opt/iobroker/backups:
        687M    /opt/iobroker/backups/
        343M    /opt/iobroker/backups/history
        268M    /opt/iobroker/backups/files
        88M     /opt/iobroker/backups/files/echarts.admin
        57M     /opt/iobroker/backups/files/echarts
        /opt/iobroker/iobroker-data:
        683M    /opt/iobroker/iobroker-data/
        347M    /opt/iobroker/iobroker-data/history
        294M    /opt/iobroker/iobroker-data/files
        89M     /opt/iobroker/iobroker-data/files/echarts.admin
        57M     /opt/iobroker/iobroker-data/files/echarts
        24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
        24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
        23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
        17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b756fe6.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_cc8e9ae92dd3eb11ac2234e8bf09e213-if00-port0
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.0
        /usr/bin/node           v18.19.0
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.0-1nodesource1
          Candidate: 18.19.0-1nodesource1
          Version table:
         *** 18.19.0-1nodesource1 600
                100 /var/lib/dpkg/status
             18.18.2-1nodesource1 600
             18.18.1-1nodesource1 600
             18.18.0-1nodesource1 600
             18.17.1-1nodesource1 600
             18.17.0-1nodesource1 600
             18.16.1-1nodesource1 600
             18.16.0-1nodesource1 600
             18.15.0-1nodesource1 600
             18.14.2-1nodesource1 600
             18.14.1-1nodesource1 600
             18.14.0-1nodesource1 600
             18.13.0-1nodesource1 600
             18.12.0-1nodesource1 600
             18.11.0-1nodesource1 600
             18.10.0-1nodesource1 600
             18.9.1-1nodesource1 600
             18.9.0-1nodesource1 600
             18.8.0-1nodesource1 600
             18.7.0-1nodesource1 600
             18.6.0-1nodesource1 600
             18.5.0-1nodesource1 600
             18.4.0-1nodesource1 600
             18.3.0-1nodesource1 600
             18.2.0-1nodesource1 600
             18.1.0-1nodesource1 600
             18.0.0-1nodesource1 600
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
          throw err;
          requireStack: []
        Node.js v18.19.0
        Core adapters versions
          throw err;
          requireStack: []
        Node.js v18.19.0
        js-controller:
          throw err;
          requireStack: []
        Node.js v18.19.0
        admin:
          throw err;
          requireStack: []
        Node.js v18.19.0
        javascript:
        Adapters from github:   0
        Adapter State
          throw err;
          requireStack: []
        Node.js v18.19.0
          throw err;
          requireStack: []
        Node.js v18.19.0
        ioBroker-Repositories
          throw err;
          requireStack: []
        Node.js v18.19.0
        Installed ioBroker-Instances
          throw err;
          requireStack: []
        Node.js v18.19.0
        Objects and States
        Objects:        0
        States:         0
        Hit:1 http://deb.debian.org/debian bullseye InRelease
        Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
        Get:5 https://dl.cloudsmith.io/public/evcc/stable/deb/debian bullseye InRelease [5127 B]
        Hit:6 https://dl.yarnpkg.com/debian stable InRelease
        Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
        Fetched 5127 B in 2s (2790 B/s)
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14242      600/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          12977      557/cupsd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          14253      600/sshd: /usr/sbin
        tcp6       0      0 :::4712                 :::*                    LISTEN      116        15709      576/evcc
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          12976      557/cupsd
        tcp6       0      0 :::7070                 :::*                    LISTEN      116        15075      576/evcc
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12997      572/dhcpcd
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          12989      622/cups-browsed
        udp        0      0 0.0.0.0:54194           0.0.0.0:*                           108        15460      386/avahi-daemon: r
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        17496      576/evcc
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15458      386/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          13016      572/dhcpcd
        udp6       0      0 :::50063                :::*                                108        15461      386/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                116        17497      576/evcc
        udp6       0      0 :::5353                 :::*                                108        15459      386/avahi-daemon: r
        2024-01-22 19:29:28.262  - info: host.raspberrypi stopInstance system.adapter.ping.0 (force=false, process=false)
        2024-01-22 19:29:28.262  - info: host.raspberrypi stopInstance system.adapter.meross.0 (force=false, process=false)
        2024-01-22 19:29:28.262  - info: host.raspberrypi stopInstance system.adapter.rpi2.0 (force=false, process=false)
        2024-01-22 19:29:28.263  - info: host.raspberrypi stopInstance system.adapter.tuya.0 (force=false, process=false)
        2024-01-22 19:29:28.263  - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=false)
        2024-01-22 19:29:28.264  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=false)
        2024-01-22 19:29:28.265  - info: host.raspberrypi stopInstance system.adapter.net-tools.0 (force=false, process=false)
        2024-01-22 19:29:28.265  - info: host.raspberrypi stopInstance system.adapter.fritzdect.0 (force=false, process=false)
        2024-01-22 19:29:28.265  - info: host.raspberrypi stopInstance system.adapter.web.0 (force=false, process=false)
        2024-01-22 19:29:28.266  - info: host.raspberrypi stopInstance system.adapter.jarvis.0 (force=false, process=false)
        2024-01-22 19:29:28.266  - info: host.raspberrypi stopInstance system.adapter.vis.0 (force=false, process=false)
        2024-01-22 19:29:28.267  - info: host.raspberrypi stopInstance system.adapter.echarts.0 (force=false, process=false)
        2024-01-22 19:29:28.267  - info: host.raspberrypi stopInstance system.adapter.parser.0 (force=false, process=false)
        2024-01-22 19:29:28.267  - info: host.raspberrypi stopInstance system.adapter.simple-api.0 (force=false, process=false)
        2024-01-22 19:29:28.268  - info: host.raspberrypi stopInstance system.adapter.socketio.0 (force=false, process=false)
        2024-01-22 19:29:28.268  - info: host.raspberrypi stopInstance system.adapter.growatt.0 (force=false, process=false)
        2024-01-22 19:29:28.268  - info: host.raspberrypi stopInstance system.adapter.terminal.0 (force=false, process=false)
        2024-01-22 19:29:28.269  - info: host.raspberrypi stopInstance system.adapter.cloud.0 (force=false, process=false)
        2024-01-22 19:29:28.269  - info: host.raspberrypi stopInstance system.adapter.pvforecast.0 (force=false, process=false)
        2024-01-22 19:29:28.269  - info: host.raspberrypi stopInstance system.adapter.evcc.0 (force=false, process=false)
        2024-01-22 19:29:28.269  - info: host.raspberrypi stopInstance system.adapter.homeconnect.0 (force=false, process=false)
        2024-01-22 19:29:28.270  - info: host.raspberrypi stopInstance system.adapter.tibberlink.0 (force=false, process=false)
        2024-01-22 19:29:28.752  - info: host.raspberrypi terminated
        2024-01-22 19:29:29.215  - warn: host.raspberrypi startInstance cannot find adapter "history@3.0.1". Try to install it... 1 attempt
        2024-01-22 19:29:29.216  - info: host.raspberrypi iobroker install history@3.0.1 using installedFrom
        Glasfaser 2 Replies Last reply Reply Quote 0
        • Glasfaser
          Glasfaser @Borkenkäfer last edited by Glasfaser
          @borkenkäfer
          nochmal
          cd /opt/iobroker
          npm cache clean --force
          sudo -H -u iobroker npm install iobroker.js-controller --debug
          • Glasfaser
            @borkenkäfer sagte in Iobroker lässt sich nicht mehr starten.:
            Hast du das Steckernetzteil gezogen !?
            EDIT :
            bzw. ein root Mount
              @glasfaser
              Guten Abend
              Meldung nach cache clean
              ulli@raspberrypi:/opt/iobroker $ npm cache clean --force
              npm WARN using --force Recommended protections disabled.
              ulli@raspberrypi:/opt/iobroker $ sudo npm cache clean --force
                Thomas Braun Most Active @Borkenkäfer last edited by
                @borkenkäfer
                Wo stand denn was von sudo? Finger weg von root-Rechten, wenn es nicht unbedingt erforderlich ist.
                cd /opt/iobroker
                sagt nun?
                  Borkenkäfer @Thomas Braun last edited by
                  sorry
                  meldung
                  npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                  npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
                  npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
                  added 289 packages in 1m
                  15 packages are looking for funding
                    run `npm fund` for details
                  ulli@raspberrypi:/opt/iobroker $ npm fund
                  iobroker.core@1.0.0
                  ├── https://github.com/sponsors/jaredhanson
                  │   └── passport@0.6.0
                  ├── https://github.com/sponsors/RubenVerborgh
                  │   └── follow-redirects@1.15.5
                  ├── https://opencollective.com/ioredis
                  │   └── ioredis@4.28.5
                  ├── https://github.com/sponsors/ljharb
                  │   └── function-bind@1.1.2
                  ├─┬ https://github.com/sindresorhus/execa?sponsor=1
                  │ │ └── execa@5.1.1
                  │ └── https://github.com/sponsors/sindresorhus
                  │     └── get-stream@6.0.1, is-stream@2.0.1, onetime@5.1.2
                  ├─┬ https://paulmillr.com/funding/
                  │ │ └── chokidar@3.5.3
                  │ └── https://github.com/sponsors/jonschlinkert
                  │     └── picomatch@2.3.1
                  ├─┬ https://github.com/chalk/wrap-ansi?sponsor=1
                  │ │ └── wrap-ansi@7.0.0
                  │ └── https://github.com/chalk/ansi-styles?sponsor=1
                  │     └── ansi-styles@4.3.0
                  ├── https://github.com/sponsors/sibiraj-s
                  │   └── ci-info@3.9.0
                  ├── https://github.com/sponsors/feross
                  │   └── safe-buffer@5.2.1
                  └── https://github.com/sponsors/epoberezkin
                      └── ajv@6.12.6
                  ulli@raspberrypi:/opt/iobroker $ ^C
                  mikeal created this issue in request/request
                  open Request’s Past, Present and Future #3142
                    @borkenkäfer
                    sudo systemctl set-default multi-user.target
                    iobroker restart
                    iob diag
                      war kurz offline
                      full
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                      Docker          : false
                      Kernel          : aarch64
                      Userland        : arm64
                       17:44:45 up 22:20,  3 users,  load average: 1.36, 0.68, 0.45
                      CPU threads: 4
                      Current issues:
                                     Local time: Tue 2024-01-23 17:44:45 CET
                                 Universal time: Tue 2024-01-23 16:44:45 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      ulli
                      /home/ulli
                      X-Server:       true
                      Desktop:
                      Terminal:       tty
                      Boot Target:    multi-user.target
                      *** MEMORY ***
                      Mem:            3.8G        807M        1.3G         38M        1.7G        2.9G
                      Swap:            99M          0B         99M
                      Total:          3.9G        807M        1.4G
                               3794 M total memory
                                807 M used memory
                               1516 M active memory
                                783 M inactive memory
                               1256 M free memory
                                170 M buffer memory
                               1560 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FILESYSTEM ***
                      /dev/root      ext4       59G   12G   45G  20% /
                      /var:
                      4.7G    /var/
                      3.8G    /var/log
                      3.2G    /var/log/journal/b741ffe02a684b9895597ea9866ca817
                      641M    /var/cache
                      Archived and active journals take up 3.1G in the file system.
                      687M    /opt/iobroker/iobroker-data/
                      USB-Devices by-id:
                      /usr/bin/npm            10.2.3
                      /usr/bin/npx            10.2.3
                      nodejs:
                        Version table:
                      Temp directories causing npm8 problem: 75
                      Some problems detected, please run iob fix
                      Errors in npm tree:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      js-controller:  5.0.17
                      admin:          "admin" not found
                      javascript:     "javascript" not found
                      Adapter State
                        system.adapter.admin.0                  : admin                 : raspberrypi                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                        system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                        system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
                        system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                        system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
                        system.adapter.evcc.0                   : evcc                  : raspberrypi                              -  enabled, port: 7070
                        system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
                        system.adapter.growatt.0                : growatt               : raspberrypi                              -  enabled
                        system.adapter.history.0                : history               : raspberrypi                              -  enabled
                        system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              - disabled
                        system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
                        system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                      + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
                        system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
                        system.adapter.parser.0                 : parser                : raspberrypi                              -  enabled
                      + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                        system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
                      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                        system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                      + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
                        system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                        system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                        system.adapter.tibberlink.0             : tibberlink            : raspberrypi                              -  enabled
                        system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                        system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + instance is alive
                      Active repo(s): stable
                      Used repository: stable
                      Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
                      Controller "js-controller": 5.0.17   , installed 5.0.17
                      Adapter    "meross"       : 1.17.0   , installed 1.17.0
                      Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                      Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                      Objects and States
                      Objects:        2093
                      States:         1702
                      Fetched 5127 B in 2s (2420 B/s)
                      Pending Updates: 0
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       749922     205370/iobroker.js-
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       748495     205370/iobroker.js-
                      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          170745     44884/cupsd
                      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          170744     44884/cupsd
                      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       758148     208071/io.tuya.0
                      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       758149     208071/io.tuya.0
                      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          174358     44885/cups-browsed
                      2024-01-23 17:45:33.753  - info: host.raspberrypi iobroker npm-install: upload [2] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/tuya.png tuya.png image/png
                      2024-01-23 17:45:33.762  - info: host.raspberrypi iobroker npm-install: upload [1] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/warning.png warning.png image/png
                      2024-01-23 17:45:33.775  - info: host.raspberrypi iobroker npm-install: upload [0] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/words.js words.js application/javascript
                      2024-01-23 17:45:33.883  - info: host.raspberrypi iobroker npm-install: host.raspberrypi object system.adapter.tuya created/updated
                      2024-01-23 17:45:37.269  - info: host.raspberrypi iobroker npm-install: exit 0
                      2024-01-23 17:45:37.338  - info: host.raspberrypi instance system.adapter.tuya.0 started with pid 208071
                      2024-01-23 17:45:38.269  - warn: host.raspberrypi startInstance cannot find adapter "discovery@4.2.0". Try to install it... 1 attempt
                      2024-01-23 17:45:38.271  - info: host.raspberrypi iobroker install discovery@4.2.0 using installedFrom
                      2024-01-23 17:45:42.973  - info: host.raspberrypi iobroker npm-install: NPM version: 10.2.3Installing iobroker.discovery@4.2.0... (System call)
                      2024-01-23 17:45:55.711  - info: host.raspberrypi iobroker npm-install:
                      2024-01-23 17:45:55.712  - info: host.raspberrypi iobroker npm-install: added 15 packages in 12s
                      2024-01-23 17:45:55.713  - info: host.raspberrypi iobroker npm-install: 59 packages are looking for funding  run `npm fund` for details
                      2024-01-23 17:45:55.780  - info: host.raspberrypi iobroker npm-install: host.raspberrypi install adapter discovery@4.2.0
                      2024-01-23 17:45:55.892  - info: host.raspberrypi iobroker npm-install: upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                      2024-01-23 17:45:55.917  - info: host.raspberrypi iobroker npm-install: upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                      2024-01-23 17:45:55.931  - info: host.raspberrypi iobroker npm-install: upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                      2024-01-23 17:45:55.946  - info: host.raspberrypi iobroker npm-install: upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                      2024-01-23 17:45:55.957  - info: host.raspberrypi iobroker npm-install: upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                      2024-01-23 17:45:55.970  - info: host.raspberrypi iobroker npm-install: upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                      2024-01-23 17:45:55.981  - info: host.raspberrypi iobroker npm-install: upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                      2024-01-23 17:45:56.083  - info: host.raspberrypi iobroker npm-install: host.raspberrypi object system.adapter.discovery created/updated
                      2024-01-23 17:45:57.159  - info: host.raspberrypi iobroker npm-install: exit 0
                      2024-01-23 17:45:57.209  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 209055
                      2024-01-23 17:45:58.159  - warn: host.raspberrypi startInstance cannot find adapter "backitup@2.9.8". Try to install it... 1 attempt
                      2024-01-23 17:45:58.160  - info: host.raspberrypi iobroker install backitup@2.9.8 using installedFrom
                        meine Internetleitung spinnt gerade
                        soll ich d
                        iob fix ausführen
                          Homoran Global Moderator Administrators @Borkenkäfer last edited by
                          soll ich d
                          iob fix ausführen
                          was soll der bringen?
                          wird da gerade ein Backup wiederhergestellt?
                            Borkenkäfer @Homoran last edited by
                            das steht im full drin
                              ich mach sonst nichts, nur nach Anweisung
                                das sind Meldungen bei einem Restore
                                  soll ich iobroker dann mal starten und schauen was passiert?
                                    iobroker logs --watch
                                      ein Auszug
                                      das sind meine Blockly sripte
                                      2024-01-23 18:45:15.004  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 294
                                      2024-01-23 18:45:30.006  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 292
                                      2024-01-23 18:45:33.099  - info: javascript.0 (212309) script.js.common.PV_Daten_auslesen:
                                       Error : Connect Failed
                                      2024-01-23 18:45:45.003  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 293
                                      2024-01-23 18:46:00.005  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 295
                                      2024-01-23 18:46:03.115  - info: javascript.0 (212309) script.js.common.PV_Daten_auslesen:
                                      2024-01-23 18:46:15.003  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 290
                                      2024-01-23 18:46:30.006  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 292
                                      2024-01-23 18:46:33.099  - info: javascript.0 (212309) script.js.common.PV_Daten_auslesen:
                                      2024-01-23 18:46:45.003  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 255
                                      2024-01-23 18:47:00.002  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 262
                                      2024-01-23 18:47:03.085  - info: javascript.0 (212309) script.js.common.PV_Daten_auslesen:
                                        hier mal der Anfang
                                        2024-01-23 17:47:08.532  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.net-tools@0.2.0: 155
                                        2024-01-23 17:47:09.586  - info: host.raspberrypi iobroker npm-install: exit 25
                                        2024-01-23 17:47:10.587  - warn: host.raspberrypi startInstance cannot find adapter "fritzdect@2.5.9". Try to install it... 1 attempt
                                        2024-01-23 17:47:10.588  - info: host.raspberrypi iobroker install fritzdect@2.5.9 using installedFrom
                                        2024-01-23 17:47:14.249  - info: host.raspberrypi iobroker npm-install: NPM version: 10.2.3
                                        2024-01-23 17:47:14.252  - info: host.raspberrypi iobroker npm-install: Installing iobroker.fritzdect@2.5.9... (System call)
                                        2024-01-23 17:50:15.627  - info: host.raspberrypi iobroker npm-install:
                                        2024-01-23 17:50:15.628  - info: host.raspberrypi iobroker npm-install: added 22 packages, and removed 25 packages in 3m
                                        2024-01-23 17:50:15.630  - info: host.raspberrypi iobroker npm-install: 73 packages are looking for funding  run `npm fund` for details
                                        2024-01-23 17:50:15.677  - info: host.raspberrypi iobroker npm-install: host.raspberrypi install adapter fritzdect@2.5.9
                                        2024-01-23 17:50:15.788  - info: host.raspberrypi iobroker npm-install: upload [5] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/admin.d.ts admin.d.ts video/mp2t
                                        2024-01-23 17:50:15.815  - info: host.raspberrypi iobroker npm-install: upload [4] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/fritzdect_logo.png fritzdect_logo.png image/png
                                        2024-01-23 17:50:15.825  - info: host.raspberrypi iobroker npm-install: upload [3] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/index_m.html index_m.html text/html
                                        2024-01-23 17:50:15.836  - info: host.raspberrypi iobroker npm-install: upload [2] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/jsonConfig.json jsonConfig.json application/json
                                        2024-01-23 17:50:15.851  - info: host.raspberrypi iobroker npm-install: upload [1] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/style.css style.css text/css
                                        2024-01-23 17:50:15.862  - info: host.raspberrypi iobroker npm-install: upload [0] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/words.js words.js application/javascript
                                        2024-01-23 17:50:15.902  - info: host.raspberrypi "system.adapter.vis.0" disabled
                                        2024-01-23 17:50:15.912  - info: host.raspberrypi "system.adapter.vis.0" enabled
                                        2024-01-23 17:50:15.915  - info: host.raspberrypi iobroker npm-install: Adapter "system.adapter.vis.0" restarted.
                                        2024-01-23 17:50:15.969  - info: host.raspberrypi iobroker npm-install: host.raspberrypi object system.adapter.fritzdect created/updated
                                        2024-01-23 17:50:17.029  - info: host.raspberrypi iobroker npm-install: exit 0
                                        2024-01-23 17:50:17.077  - info: host.raspberrypi instance system.adapter.fritzdect.0 started with pid 210259
                                        2024-01-23 17:50:18.031  - warn: host.raspberrypi startInstance cannot find adapter "web@6.1.10". Try to install it... 1 attempt
                                        2024-01-23 17:50:18.032  - info: host.raspberrypi iobroker install web@6.1.10 using installedFrom
                                        2024-01-23 17:50:19.050  - info: fritzdect.0 (210259) starting. Version 2.5.9 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v18.19.0, js-controller: 5.0.17
                                        2024-01-23 17:50:19.083  - info: fritzdect.0 (210259) fritzdect entered ready
                                        2024-01-23 17:50:19.121  - info: fritzdect.0 (210259) fritzdect uses USER: admin
                                        2024-01-23 17:50:19.240  - error: fritzdect.0 (210259) --------------- error calling the fritzbox -----------
                                        2024-01-23 17:50:19.241  - error: fritzdect.0 (210259) API msg   => error calling executeCommand
                                        2024-01-23 17:50:19.242  - error: fritzdect.0 (210259) API funct => login_SID
                                        2024-01-23 17:50:19.243  - error: fritzdect.0 (210259) no response part in returned error message
                                        2024-01-23 17:50:19.243  - error: fritzdect.0 (210259) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"error http.request","function":"get_login_state","error":{"errno":-3008,"code":"ENOTFOUND","syscall":"getaddrinfo","hostname":"192.168.x.x"}}}
                                        2024-01-23 17:50:19.245  - error: fritzdect.0 (210259) login not possible, check user and permissions
                                        2024-01-23 17:50:20.812  - info: host.raspberrypi iobroker npm-install: host.raspberrypi Adapter "system.adapter.web.0" is stopped.
                                        2024-01-23 17:50:20.818  - info: host.raspberrypi "system.adapter.web.0" disabled
                                        2024-01-23 17:50:21.917  - info: host.raspberrypi iobroker npm-install: NPM version: 10.2.3
                                        2024-01-23 17:50:21.919  - info: host.raspberrypi iobroker npm-install: Installing iobroker.web@6.1.10... (System call)
                                        2024-01-23 17:50:46.063  - info: host.raspberrypi iobroker npm-install:
                                        2024-01-23 17:50:46.064  - info: host.raspberrypi iobroker npm-install: added 62 packages in 23s
                                        2024-01-23 17:50:46.065  - info: host.raspberrypi iobroker npm-install: 74 packages are looking for funding  run `npm fund` for details
                                        2024-01-23 17:50:46.117  - info: host.raspberrypi iobroker npm-install: host.raspberrypi install adapter web@6.1.10
                                        2024-01-23 17:50:47.032  - info: host.raspberrypi iobroker npm-install: upload [129] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
                                        2024-01-23 17:51:02.449  - info: host.raspberrypi iobroker npm-install: upload [100] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Computer.9558f6ee3941dba4e3c5.svg static/media/Computer.9558f6ee3941dba4e3c5.svg image/svg+xml
                                        2024-01-23 17:51:02.528  - info: host.raspberrypi iobroker npm-install: upload [90] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Dressing Room.5e6f8f64b0e8f91c473e.svg static/media/Dressing Room.5e6f8f64b0e8f91c473e.svg image/svg+xml
                                        2024-01-23 17:51:02.609  - info: host.raspberrypi iobroker npm-install: upload [80] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Garage.f7fc0a9b326d582afee6.svg static/media/Garage.f7fc0a9b326d582afee6.svg image/svg+xml
                                        2024-01-23 17:51:02.687  - info: host.raspberrypi iobroker npm-install: upload [70] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Hanging Lamps.0bd452fc843edd645c30.svg static/media/Hanging Lamps.0bd452fc843edd645c30.svg image/svg+xml
                                        2024-01-23 17:51:02.764  - info: host.raspberrypi iobroker npm-install: upload [60] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Led Strip.5cf2de461e29ffbaa5f0.svg static/media/Led Strip.5cf2de461e29ffbaa5f0.svg image/svg+xml
                                        2024-01-23 17:51:02.844  - info: host.raspberrypi iobroker npm-install: upload [50] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Nursery.9cecc0544bdb5c28500c.svg static/media/Nursery.9cecc0544bdb5c28500c.svg image/svg+xml
                                        2024-01-23 17:51:02.923  - info: host.raspberrypi iobroker npm-install: upload [40] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Rear Wall.38843c33f1ea1f575500.svg static/media/Rear Wall.38843c33f1ea1f575500.svg image/svg+xml
                                        2024-01-23 17:51:03.021  - info: host.raspberrypi iobroker npm-install: upload [30] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Sockets.8320e1a99be9de004629.svg static/media/Sockets.8320e1a99be9de004629.svg image/svg+xml
                                        2024-01-23 17:51:03.113  - info: host.raspberrypi iobroker npm-install: upload [20] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Terrace.d71d07d9290674f2ca20.svg static/media/Terrace.d71d07d9290674f2ca20.svg image/svg+xml
                                        2024-01-23 17:51:03.123  - info: host.raspberrypi iobroker npm-install: upload [19] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                                        2024-01-23 17:51:03.132  - info: host.raspberrypi iobroker npm-install: upload [18] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Tv.4e9745a548e57bfac0c7.svg static/media/Tv.4e9745a548e57bfac0c7.svg image/svg+xml
                                        2024-01-23 17:51:03.141  - info: host.raspberrypi iobroker npm-install: upload [17] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Upstairs.441813e54e0daca0882d.svg static/media/Upstairs.441813e54e0daca0882d.svg image/svg+xml
                                        2024-01-23 17:51:03.150  - info: host.raspberrypi iobroker npm-install: upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
                                        2024-01-23 17:51:03.158  - info: host.raspberrypi iobroker npm-install: upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Ventilation.c31761d86d67e245ac92.svg static/media/Ventilation.c31761d86d67e245ac92.svg image/svg+xml
                                        2024-01-23 17:51:03.167  - info: host.raspberrypi iobroker npm-install: upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Wardrobe.e8019970a2b51412cfdc.svg static/media/Wardrobe.e8019970a2b51412cfdc.svg image/svg+xml
                                        2024-01-23 17:51:03.177  - info: host.raspberrypi iobroker npm-install: upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Washing Machines.577f3acdb3cef002b523.svg static/media/Washing Machines.577f3acdb3cef002b523.svg image/svg+xml
                                        2024-01-23 17:51:03.185  - info: host.raspberrypi iobroker npm-install: upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Washroom.bfb54196f381f36de9d6.svg static/media/Washroom.bfb54196f381f36de9d6.svg image/svg+xml
                                        2024-01-23 17:51:03.195  - info: host.raspberrypi iobroker npm-install: upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Water Consumption.68891649591cc2434c5b.svg static/media/Water Consumption.68891649591cc2434c5b.svg image/svg+xml
                                        2024-01-23 17:51:03.203  - info: host.raspberrypi iobroker npm-
                                          die nächsten zwei
                                            einiger läuft schon mal wieder
                                            Homoran B 2 Replies Last reply Reply Quote 0
                                            3679
