    4. Iobroker lässt sich nicht mehr starten.
    • Glasfaser
      Glasfaser @Borkenkäfer last edited by Glasfaser
      @borkenkäfer sagte in Iobroker lässt sich nicht mehr starten.:
      [Mon Jan 22 19:23:54 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      Hast du das Steckernetzteil gezogen !?
      EDIT :
      bzw. ein root Mount
        Borkenkäfer @Glasfaser last edited by
        @glasfaser
        Guten Abend
        Meldung nach cache clean
        ulli@raspberrypi:/opt/iobroker $ npm cache clean --force
        npm WARN using --force Recommended protections disabled.
        ulli@raspberrypi:/opt/iobroker $ sudo npm cache clean --force
          Thomas Braun Most Active @Borkenkäfer last edited by
          @borkenkäfer
          Wo stand denn was von sudo? Finger weg von root-Rechten, wenn es nicht unbedingt erforderlich ist.
          cd /opt/iobroker
          sudo -H -u iobroker npm install iobroker.js-controller --debug
          sagt nun?
            Borkenkäfer @Thomas Braun last edited by
            sorry
            meldung
            npm WARN deprecated har-validator@5.1.5: this library is no longer supported
            npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
            npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
            added 289 packages in 1m
            15 packages are looking for funding
              run `npm fund` for details
            ulli@raspberrypi:/opt/iobroker $ npm fund
            iobroker.core@1.0.0
            ├── https://github.com/sponsors/jaredhanson
            │   └── passport@0.6.0
            ├── https://github.com/sponsors/RubenVerborgh
            │   └── follow-redirects@1.15.5
            ├── https://opencollective.com/ioredis
            │   └── ioredis@4.28.5
            ├── https://github.com/sponsors/ljharb
            │   └── function-bind@1.1.2
            ├─┬ https://github.com/sindresorhus/execa?sponsor=1
            │ │ └── execa@5.1.1
            │ └── https://github.com/sponsors/sindresorhus
            │     └── get-stream@6.0.1, is-stream@2.0.1, onetime@5.1.2
            ├─┬ https://paulmillr.com/funding/
            │ │ └── chokidar@3.5.3
            │ └── https://github.com/sponsors/jonschlinkert
            │     └── picomatch@2.3.1
            ├─┬ https://github.com/chalk/wrap-ansi?sponsor=1
            │ │ └── wrap-ansi@7.0.0
            │ └── https://github.com/chalk/ansi-styles?sponsor=1
            │     └── ansi-styles@4.3.0
            ├── https://github.com/sponsors/sibiraj-s
            │   └── ci-info@3.9.0
            ├── https://github.com/sponsors/feross
            │   └── safe-buffer@5.2.1
            └── https://github.com/sponsors/epoberezkin
                └── ajv@6.12.6
            ulli@raspberrypi:/opt/iobroker $ ^C
              @borkenkäfer
              sudo systemctl set-default multi-user.target
              iobroker restart
              iob diag
                war kurz offline
                full
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                   Static hostname: raspberrypi
                         Icon name: computer
                  Operating System: Debian GNU/Linux 11 (bullseye)
                            Kernel: Linux 6.1.21-v8+
                      Architecture: arm64
                Model           : Raspberry Pi 4 Model B Rev 1.2
                Docker          : false
                Virtualization  : none
                Kernel          : aarch64
                Userland        : arm64
                Systemuptime and Load:
                 17:44:45 up 22:20,  3 users,  load average: 1.36, 0.68, 0.45
                CPU threads: 4
                *** RASPBERRY THROTTLING ***
                Current issues:
                Previously detected issues:
                *** Time and Time Zones ***
                               Local time: Tue 2024-01-23 17:44:45 CET
                           Universal time: Tue 2024-01-23 16:44:45 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                *** User and Groups ***
                ulli
                /home/ulli
                ulli adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
                *** X-Server-Setup ***
                X-Server:       true
                Desktop:
                Terminal:       tty
                Boot Target:    multi-user.target
                *** MEMORY ***
                Mem:            3.8G        807M        1.3G         38M        1.7G        2.9G
                Swap:            99M          0B         99M
                Total:          3.9G        807M        1.4G
                         3794 M total memory
                          807 M used memory
                         1516 M active memory
                          783 M inactive memory
                         1256 M free memory
                          170 M buffer memory
                         1560 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FAILED SERVICES ***
                0 loaded units listed.
                *** FILESYSTEM ***
                /dev/root      ext4       59G   12G   45G  20% /
                devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                tmpfs          tmpfs     759M  1.2M  758M   1% /run
                /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
                tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
                [Mon Jan 22 19:23:53 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:84:9D:5E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a9a74992-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                [Mon Jan 22 19:23:54 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                [Mon Jan 22 19:23:56 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                TARGET  SOURCE         FSTYPE OPTIONS
                /       /dev/mmcblk0p2 ext4   rw,noatime
                `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                /var:
                4.7G    /var/
                3.8G    /var/log
                3.2G    /var/log/journal/b741ffe02a684b9895597ea9866ca817
                641M    /var/cache
                Archived and active journals take up 3.1G in the file system.
                /opt/iobroker/backups:
                687M    /opt/iobroker/backups/
                343M    /opt/iobroker/backups/history
                268M    /opt/iobroker/backups/files
                88M     /opt/iobroker/backups/files/echarts.admin
                57M     /opt/iobroker/backups/files/echarts
                /opt/iobroker/iobroker-data:
                687M    /opt/iobroker/iobroker-data/
                347M    /opt/iobroker/iobroker-data/history
                294M    /opt/iobroker/iobroker-data/files
                89M     /opt/iobroker/iobroker-data/files/echarts.admin
                57M     /opt/iobroker/iobroker-data/files/echarts
                24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
                24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
                23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
                21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b756fe6.js.map
                USB-Devices by-id:
                /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_cc8e9ae92dd3eb11ac2234e8bf09e213-if00-port0
                *** NodeJS-Installation ***
                /usr/bin/nodejs         v18.19.0
                /usr/bin/node           v18.19.0
                /usr/bin/npm            10.2.3
                /usr/bin/npx            10.2.3
                /usr/bin/corepack       0.22.0
                nodejs:
                  Installed: 18.19.0-1nodesource1
                  Candidate: 18.19.0-1nodesource1
                  Version table:
                 *** 18.19.0-1nodesource1 600
                        100 /var/lib/dpkg/status
                     18.18.2-1nodesource1 600
                     18.18.1-1nodesource1 600
                     18.18.0-1nodesource1 600
                     18.17.1-1nodesource1 600
                     18.17.0-1nodesource1 600
                     18.16.1-1nodesource1 600
                     18.16.0-1nodesource1 600
                     18.15.0-1nodesource1 600
                     18.14.2-1nodesource1 600
                     18.14.1-1nodesource1 600
                     18.14.0-1nodesource1 600
                     18.13.0-1nodesource1 600
                     18.12.0-1nodesource1 600
                     18.11.0-1nodesource1 600
                     18.10.0-1nodesource1 600
                     18.9.1-1nodesource1 600
                     18.9.0-1nodesource1 600
                     18.8.0-1nodesource1 600
                     18.7.0-1nodesource1 600
                     18.6.0-1nodesource1 600
                     18.5.0-1nodesource1 600
                     18.4.0-1nodesource1 600
                     18.3.0-1nodesource1 600
                     18.2.0-1nodesource1 600
                     18.1.0-1nodesource1 600
                     18.0.0-1nodesource1 600
                     12.22.12~dfsg-1~deb11u4 500
                        500 http://deb.debian.org/debian bullseye/main arm64 Packages
                        500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                Temp directories causing npm8 problem: 75
                Some problems detected, please run iob fix
                Errors in npm tree:
                *** ioBroker-Installation ***
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                Core adapters versions
                js-controller:  5.0.17
                admin:          "admin" not found
                javascript:     "javascript" not found
                Adapters from github:   0
                Adapter State
                  system.adapter.admin.0                  : admin                 : raspberrypi                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                  system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                  system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
                  system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                  system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
                  system.adapter.evcc.0                   : evcc                  : raspberrypi                              -  enabled, port: 7070
                  system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
                  system.adapter.growatt.0                : growatt               : raspberrypi                              -  enabled
                  system.adapter.history.0                : history               : raspberrypi                              -  enabled
                  system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              - disabled
                  system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
                  system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
                  system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
                  system.adapter.parser.0                 : parser                : raspberrypi                              -  enabled
                + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                  system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
                + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
                  system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
                  system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                  system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                  system.adapter.tibberlink.0             : tibberlink            : raspberrypi                              -  enabled
                  system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                  system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                  system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                + instance is alive
                ioBroker-Repositories
                Active repo(s): stable
                Installed ioBroker-Instances
                Used repository: stable
                Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
                Controller "js-controller": 5.0.17   , installed 5.0.17
                Adapter    "meross"       : 1.17.0   , installed 1.17.0
                Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                Adapter    "tuya"         : 3.15.0   , installed 3.15.0
                Objects and States
                Objects:        2093
                States:         1702
                Hit:1 http://deb.debian.org/debian bullseye InRelease
                Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                Get:5 https://dl.cloudsmith.io/public/evcc/stable/deb/debian bullseye InRelease [5127 B]
                Hit:6 https://dl.yarnpkg.com/debian stable InRelease
                Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                Fetched 5127 B in 2s (2420 B/s)
                Reading package lists...
                Pending Updates: 0
                *** Listening Ports ***
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14242      600/sshd: /usr/sbin
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       749922     205370/iobroker.js-
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       748495     205370/iobroker.js-
                tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          170745     44884/cupsd
                tcp6       0      0 :::22                   :::*                    LISTEN      0          14253      600/sshd: /usr/sbin
                tcp6       0      0 :::4712                 :::*                    LISTEN      116        15709      576/evcc
                tcp6       0      0 ::1:631                 :::*                    LISTEN      0          170744     44884/cupsd
                tcp6       0      0 :::7070                 :::*                    LISTEN      116        15075      576/evcc
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12997      572/dhcpcd
                udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       758148     208071/io.tuya.0
                udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       758149     208071/io.tuya.0
                udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          174358     44885/cups-browsed
                udp        0      0 0.0.0.0:54194           0.0.0.0:*                           108        15460      386/avahi-daemon: r
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        17496      576/evcc
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15458      386/avahi-daemon: r
                udp6       0      0 :::546                  :::*                                0          13016      572/dhcpcd
                udp6       0      0 :::50063                :::*                                108        15461      386/avahi-daemon: r
                udp6       0      0 :::5353                 :::*                                116        17497      576/evcc
                udp6       0      0 :::5353                 :::*                                108        15459      386/avahi-daemon: r
                2024-01-23 17:45:33.753  - info: host.raspberrypi iobroker npm-install: upload [2] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/tuya.png tuya.png image/png
                2024-01-23 17:45:33.762  - info: host.raspberrypi iobroker npm-install: upload [1] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/warning.png warning.png image/png
                2024-01-23 17:45:33.775  - info: host.raspberrypi iobroker npm-install: upload [0] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/words.js words.js application/javascript
                2024-01-23 17:45:33.883  - info: host.raspberrypi iobroker npm-install: host.raspberrypi object system.adapter.tuya created/updated
                2024-01-23 17:45:37.269  - info: host.raspberrypi iobroker npm-install: exit 0
                2024-01-23 17:45:37.338  - info: host.raspberrypi instance system.adapter.tuya.0 started with pid 208071
                2024-01-23 17:45:38.269  - warn: host.raspberrypi startInstance cannot find adapter "discovery@4.2.0". Try to install it... 1 attempt
                2024-01-23 17:45:38.271  - info: host.raspberrypi iobroker install discovery@4.2.0 using installedFrom
                2024-01-23 17:45:42.973  - info: host.raspberrypi iobroker npm-install: NPM version: 10.2.3Installing iobroker.discovery@4.2.0... (System call)
                2024-01-23 17:45:55.711  - info: host.raspberrypi iobroker npm-install:
                2024-01-23 17:45:55.712  - info: host.raspberrypi iobroker npm-install: added 15 packages in 12s
                2024-01-23 17:45:55.713  - info: host.raspberrypi iobroker npm-install: 59 packages are looking for funding  run `npm fund` for details
                2024-01-23 17:45:55.780  - info: host.raspberrypi iobroker npm-install: host.raspberrypi install adapter discovery@4.2.0
                2024-01-23 17:45:55.892  - info: host.raspberrypi iobroker npm-install: upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                2024-01-23 17:45:55.917  - info: host.raspberrypi iobroker npm-install: upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                2024-01-23 17:45:55.931  - info: host.raspberrypi iobroker npm-install: upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                2024-01-23 17:45:55.946  - info: host.raspberrypi iobroker npm-install: upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                2024-01-23 17:45:55.957  - info: host.raspberrypi iobroker npm-install: upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                2024-01-23 17:45:55.970  - info: host.raspberrypi iobroker npm-install: upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                2024-01-23 17:45:55.981  - info: host.raspberrypi iobroker npm-install: upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                2024-01-23 17:45:56.083  - info: host.raspberrypi iobroker npm-install: host.raspberrypi object system.adapter.discovery created/updated
                2024-01-23 17:45:57.159  - info: host.raspberrypi iobroker npm-install: exit 0
                2024-01-23 17:45:57.209  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 209055
                2024-01-23 17:45:58.159  - warn: host.raspberrypi startInstance cannot find adapter "backitup@2.9.8". Try to install it... 1 attempt
                2024-01-23 17:45:58.160  - info: host.raspberrypi iobroker install backitup@2.9.8 using installedFrom
                  meine Internetleitung spinnt gerade
                  soll ich d
                  iob fix ausführen
                    Homoran Global Moderator Administrators @Borkenkäfer last edited by
                    soll ich d
                    iob fix ausführen
                    was soll der bringen?
                    wird da gerade ein Backup wiederhergestellt?
                      Borkenkäfer @Homoran last edited by
                      das steht im full drin
                        Borkenkäfer @Borkenkäfer last edited by
                        @borkenkäfer said in Iobroker lässt sich nicht mehr starten.:
                        ich mach sonst nichts, nur nach Anweisung
                          das sind Meldungen bei einem Restore
                            soll ich iobroker dann mal starten und schauen was passiert?
                              iobroker logs --watch
                                ein Auszug
                                das sind meine Blockly sripte
                                2024-01-23 18:45:15.004  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 294
                                2024-01-23 18:45:30.006  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 292
                                2024-01-23 18:45:33.099  - info: javascript.0 (212309) script.js.common.PV_Daten_auslesen:
                                 Error : Connect Failed
                                2024-01-23 18:45:45.003  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 293
                                2024-01-23 18:46:00.005  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 295
                                2024-01-23 18:46:03.115  - info: javascript.0 (212309) script.js.common.PV_Daten_auslesen:
                                2024-01-23 18:46:15.003  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 290
                                2024-01-23 18:46:30.006  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 292
                                2024-01-23 18:46:33.099  - info: javascript.0 (212309) script.js.common.PV_Daten_auslesen:
                                2024-01-23 18:46:45.003  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 255
                                2024-01-23 18:47:00.002  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 262
                                2024-01-23 18:47:03.085  - info: javascript.0 (212309) script.js.common.PV_Daten_auslesen:
                                  hier mal der Anfang
                                  2024-01-23 17:47:08.532  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.net-tools@0.2.0: 155
                                  2024-01-23 17:47:09.586  - info: host.raspberrypi iobroker npm-install: exit 25
                                  2024-01-23 17:47:10.587  - warn: host.raspberrypi startInstance cannot find adapter "fritzdect@2.5.9". Try to install it... 1 attempt
                                  2024-01-23 17:47:10.588  - info: host.raspberrypi iobroker install fritzdect@2.5.9 using installedFrom
                                  2024-01-23 17:47:14.249  - info: host.raspberrypi iobroker npm-install: NPM version: 10.2.3
                                  2024-01-23 17:47:14.252  - info: host.raspberrypi iobroker npm-install: Installing iobroker.fritzdect@2.5.9... (System call)
                                  2024-01-23 17:50:15.627  - info: host.raspberrypi iobroker npm-install:
                                  2024-01-23 17:50:15.628  - info: host.raspberrypi iobroker npm-install: added 22 packages, and removed 25 packages in 3m
                                  2024-01-23 17:50:15.630  - info: host.raspberrypi iobroker npm-install: 73 packages are looking for funding  run `npm fund` for details
                                  2024-01-23 17:50:15.677  - info: host.raspberrypi iobroker npm-install: host.raspberrypi install adapter fritzdect@2.5.9
                                  2024-01-23 17:50:15.788  - info: host.raspberrypi iobroker npm-install: upload [5] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/admin.d.ts admin.d.ts video/mp2t
                                  2024-01-23 17:50:15.815  - info: host.raspberrypi iobroker npm-install: upload [4] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/fritzdect_logo.png fritzdect_logo.png image/png
                                  2024-01-23 17:50:15.825  - info: host.raspberrypi iobroker npm-install: upload [3] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/index_m.html index_m.html text/html
                                  2024-01-23 17:50:15.836  - info: host.raspberrypi iobroker npm-install: upload [2] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/jsonConfig.json jsonConfig.json application/json
                                  2024-01-23 17:50:15.851  - info: host.raspberrypi iobroker npm-install: upload [1] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/style.css style.css text/css
                                  2024-01-23 17:50:15.862  - info: host.raspberrypi iobroker npm-install: upload [0] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/words.js words.js application/javascript
                                  2024-01-23 17:50:15.902  - info: host.raspberrypi "system.adapter.vis.0" disabled
                                  2024-01-23 17:50:15.912  - info: host.raspberrypi "system.adapter.vis.0" enabled
                                  2024-01-23 17:50:15.915  - info: host.raspberrypi iobroker npm-install: Adapter "system.adapter.vis.0" restarted.
                                  2024-01-23 17:50:15.969  - info: host.raspberrypi iobroker npm-install: host.raspberrypi object system.adapter.fritzdect created/updated
                                  2024-01-23 17:50:17.029  - info: host.raspberrypi iobroker npm-install: exit 0
                                  2024-01-23 17:50:17.077  - info: host.raspberrypi instance system.adapter.fritzdect.0 started with pid 210259
                                  2024-01-23 17:50:18.031  - warn: host.raspberrypi startInstance cannot find adapter "web@6.1.10". Try to install it... 1 attempt
                                  2024-01-23 17:50:18.032  - info: host.raspberrypi iobroker install web@6.1.10 using installedFrom
                                  2024-01-23 17:50:19.050  - info: fritzdect.0 (210259) starting. Version 2.5.9 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v18.19.0, js-controller: 5.0.17
                                  2024-01-23 17:50:19.083  - info: fritzdect.0 (210259) fritzdect entered ready
                                  2024-01-23 17:50:19.121  - info: fritzdect.0 (210259) fritzdect uses USER: admin
                                  2024-01-23 17:50:19.240  - error: fritzdect.0 (210259) --------------- error calling the fritzbox -----------
                                  2024-01-23 17:50:19.241  - error: fritzdect.0 (210259) API msg   => error calling executeCommand
                                  2024-01-23 17:50:19.242  - error: fritzdect.0 (210259) API funct => login_SID
                                  2024-01-23 17:50:19.243  - error: fritzdect.0 (210259) no response part in returned error message
                                  2024-01-23 17:50:19.243  - error: fritzdect.0 (210259) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"error http.request","function":"get_login_state","error":{"errno":-3008,"code":"ENOTFOUND","syscall":"getaddrinfo","hostname":"192.168.x.x"}}}
                                  2024-01-23 17:50:19.245  - error: fritzdect.0 (210259) login not possible, check user and permissions
                                  2024-01-23 17:50:20.812  - info: host.raspberrypi iobroker npm-install: host.raspberrypi Adapter "system.adapter.web.0" is stopped.
                                  2024-01-23 17:50:20.818  - info: host.raspberrypi "system.adapter.web.0" disabled
                                  2024-01-23 17:50:21.917  - info: host.raspberrypi iobroker npm-install: NPM version: 10.2.3
                                  2024-01-23 17:50:21.919  - info: host.raspberrypi iobroker npm-install: Installing iobroker.web@6.1.10... (System call)
                                  2024-01-23 17:50:46.063  - info: host.raspberrypi iobroker npm-install:
                                  2024-01-23 17:50:46.064  - info: host.raspberrypi iobroker npm-install: added 62 packages in 23s
                                  2024-01-23 17:50:46.065  - info: host.raspberrypi iobroker npm-install: 74 packages are looking for funding  run `npm fund` for details
                                  2024-01-23 17:50:46.117  - info: host.raspberrypi iobroker npm-install: host.raspberrypi install adapter web@6.1.10
                                  2024-01-23 17:50:47.032  - info: host.raspberrypi iobroker npm-install: upload [129] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
                                  2024-01-23 17:51:02.449  - info: host.raspberrypi iobroker npm-install: upload [100] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Computer.9558f6ee3941dba4e3c5.svg static/media/Computer.9558f6ee3941dba4e3c5.svg image/svg+xml
                                  2024-01-23 17:51:02.528  - info: host.raspberrypi iobroker npm-install: upload [90] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Dressing Room.5e6f8f64b0e8f91c473e.svg static/media/Dressing Room.5e6f8f64b0e8f91c473e.svg image/svg+xml
                                  2024-01-23 17:51:02.609  - info: host.raspberrypi iobroker npm-install: upload [80] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Garage.f7fc0a9b326d582afee6.svg static/media/Garage.f7fc0a9b326d582afee6.svg image/svg+xml
                                  2024-01-23 17:51:02.687  - info: host.raspberrypi iobroker npm-install: upload [70] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Hanging Lamps.0bd452fc843edd645c30.svg static/media/Hanging Lamps.0bd452fc843edd645c30.svg image/svg+xml
                                  2024-01-23 17:51:02.764  - info: host.raspberrypi iobroker npm-install: upload [60] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Led Strip.5cf2de461e29ffbaa5f0.svg static/media/Led Strip.5cf2de461e29ffbaa5f0.svg image/svg+xml
                                  2024-01-23 17:51:02.844  - info: host.raspberrypi iobroker npm-install: upload [50] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Nursery.9cecc0544bdb5c28500c.svg static/media/Nursery.9cecc0544bdb5c28500c.svg image/svg+xml
                                  2024-01-23 17:51:02.923  - info: host.raspberrypi iobroker npm-install: upload [40] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Rear Wall.38843c33f1ea1f575500.svg static/media/Rear Wall.38843c33f1ea1f575500.svg image/svg+xml
                                  2024-01-23 17:51:03.021  - info: host.raspberrypi iobroker npm-install: upload [30] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Sockets.8320e1a99be9de004629.svg static/media/Sockets.8320e1a99be9de004629.svg image/svg+xml
                                  2024-01-23 17:51:03.113  - info: host.raspberrypi iobroker npm-install: upload [20] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Terrace.d71d07d9290674f2ca20.svg static/media/Terrace.d71d07d9290674f2ca20.svg image/svg+xml
                                  2024-01-23 17:51:03.123  - info: host.raspberrypi iobroker npm-install: upload [19] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                                  2024-01-23 17:51:03.132  - info: host.raspberrypi iobroker npm-install: upload [18] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Tv.4e9745a548e57bfac0c7.svg static/media/Tv.4e9745a548e57bfac0c7.svg image/svg+xml
                                  2024-01-23 17:51:03.141  - info: host.raspberrypi iobroker npm-install: upload [17] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Upstairs.441813e54e0daca0882d.svg static/media/Upstairs.441813e54e0daca0882d.svg image/svg+xml
                                  2024-01-23 17:51:03.150  - info: host.raspberrypi iobroker npm-install: upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
                                  2024-01-23 17:51:03.158  - info: host.raspberrypi iobroker npm-install: upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Ventilation.c31761d86d67e245ac92.svg static/media/Ventilation.c31761d86d67e245ac92.svg image/svg+xml
                                  2024-01-23 17:51:03.167  - info: host.raspberrypi iobroker npm-install: upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Wardrobe.e8019970a2b51412cfdc.svg static/media/Wardrobe.e8019970a2b51412cfdc.svg image/svg+xml
                                  2024-01-23 17:51:03.177  - info: host.raspberrypi iobroker npm-install: upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Washing Machines.577f3acdb3cef002b523.svg static/media/Washing Machines.577f3acdb3cef002b523.svg image/svg+xml
                                  2024-01-23 17:51:03.185  - info: host.raspberrypi iobroker npm-install: upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Washroom.bfb54196f381f36de9d6.svg static/media/Washroom.bfb54196f381f36de9d6.svg image/svg+xml
                                  2024-01-23 17:51:03.195  - info: host.raspberrypi iobroker npm-install: upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Water Consumption.68891649591cc2434c5b.svg static/media/Water Consumption.68891649591cc2434c5b.svg image/svg+xml
                                  2024-01-23 17:51:03.203  - info: host.raspberrypi iobroker npm-
                                    die nächsten zwei
                                      einiger läuft schon mal wieder
                                      Homoran B 2 Replies Last reply Reply Quote 0
                                        @borkenkäfer so ein Neubau aller Adapter bei einem Restore kann auch mal gerne eine Stunde dauern.
                                        in der Zeit darf man nicht stören.
                                          einiges läuft schon mal wieder
                                          werde weiter testen
                                          Melde mich
                                          Danke für Eure Hilfe und eure unendliche Geduld
                                          schönen Abend
                                            hallo
                                            iobroker scheint zu funktionieren, die Scripte laufen und vis läuft auch
                                            aber ich komme nicht auf die WEB seite und es ist kein admin installiert
                                            nach dem Befehl iobroker add admin --port 8081 0der 8089 kommt folgende meldung
                                            ulli@raspberrypi:/opt/iobroker $ iobroker add admin --port 8081
                                            NPM version: 10.2.3
                                            Installing iobroker.admin@6.12.0... (System call)
                                            Try to solve ENOTEMPTY error automatically
                                            Could not handle ENOTEMPTY, because no deletable files were found
                                            npm ERR! code ENOTEMPTY
                                            npm ERR! syscall rename
                                            npm ERR! path /opt/iobroker/node_modules/@tootallnate/once
                                            npm ERR! dest /opt/iobroker/node_modules/@tootallnate/.once-ZoNnWMHe
                                            npm ERR! errno -39
                                            npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@tootallnate/once' -> '/opt/iobroker/node_modules/@tootallnate/.once-ZoNnWMHe'
                                            npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-24T17_00_04_975Z-debug-0.log
                                            host.raspberrypi Cannot install iobroker.admin@6.12.0: 217
                                            ulli@raspberrypi:/opt/iobroker $ iobroker add admin --port 8089
                                            NPM version: 10.2.3
                                            npm ERR! errno -39
                                            npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-24T17_00_32_891Z-debug-0.log
                                            3679
