    4. Iobroker lässt sich nicht mehr starten.
      Thomas Braun Most Active @Borkenkäfer last edited by
      @borkenkäfer
      sudo systemctl set-default multi-user.target
      iobroker restart
      iob diag
        Borkenkäfer @Thomas Braun last edited by
        war kurz offline
        full
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: raspberrypi
                 Icon name: computer
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.2
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : arm64
        Systemuptime and Load:
         17:44:45 up 22:20,  3 users,  load average: 1.36, 0.68, 0.45
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Tue 2024-01-23 17:44:45 CET
                   Universal time: Tue 2024-01-23 16:44:45 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        ulli
        /home/ulli
        ulli adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       true
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            3.8G        807M        1.3G         38M        1.7G        2.9G
        Swap:            99M          0B         99M
        Total:          3.9G        807M        1.4G
                 3794 M total memory
                  807 M used memory
                 1516 M active memory
                  783 M inactive memory
                 1256 M free memory
                  170 M buffer memory
                 1560 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        /dev/root      ext4       59G   12G   45G  20% /
        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        tmpfs          tmpfs     759M  1.2M  758M   1% /run
        /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
        tmpfs          tmpfs     380M   20K  380M   1% /run/user/1000
        [Mon Jan 22 19:23:53 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:84:9D:5E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a9a74992-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Mon Jan 22 19:23:54 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Mon Jan 22 19:23:54 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Mon Jan 22 19:23:56 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        TARGET  SOURCE         FSTYPE OPTIONS
        /       /dev/mmcblk0p2 ext4   rw,noatime
        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        4.7G    /var/
        3.8G    /var/log
        3.2G    /var/log/journal/b741ffe02a684b9895597ea9866ca817
        641M    /var/cache
        Archived and active journals take up 3.1G in the file system.
        /opt/iobroker/backups:
        687M    /opt/iobroker/backups/
        343M    /opt/iobroker/backups/history
        268M    /opt/iobroker/backups/files
        88M     /opt/iobroker/backups/files/echarts.admin
        57M     /opt/iobroker/backups/files/echarts
        /opt/iobroker/iobroker-data:
        687M    /opt/iobroker/iobroker-data/
        347M    /opt/iobroker/iobroker-data/history
        294M    /opt/iobroker/iobroker-data/files
        89M     /opt/iobroker/iobroker-data/files/echarts.admin
        57M     /opt/iobroker/iobroker-data/files/echarts
        24M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
        24M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
        23M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
        17M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.1b756fe6.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_cc8e9ae92dd3eb11ac2234e8bf09e213-if00-port0
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.0
        /usr/bin/node           v18.19.0
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.0-1nodesource1
          Candidate: 18.19.0-1nodesource1
          Version table:
         *** 18.19.0-1nodesource1 600
                100 /var/lib/dpkg/status
             18.18.2-1nodesource1 600
             18.18.1-1nodesource1 600
             18.18.0-1nodesource1 600
             18.17.1-1nodesource1 600
             18.17.0-1nodesource1 600
             18.16.1-1nodesource1 600
             18.16.0-1nodesource1 600
             18.15.0-1nodesource1 600
             18.14.2-1nodesource1 600
             18.14.1-1nodesource1 600
             18.14.0-1nodesource1 600
             18.13.0-1nodesource1 600
             18.12.0-1nodesource1 600
             18.11.0-1nodesource1 600
             18.10.0-1nodesource1 600
             18.9.1-1nodesource1 600
             18.9.0-1nodesource1 600
             18.8.0-1nodesource1 600
             18.7.0-1nodesource1 600
             18.6.0-1nodesource1 600
             18.5.0-1nodesource1 600
             18.4.0-1nodesource1 600
             18.3.0-1nodesource1 600
             18.2.0-1nodesource1 600
             18.1.0-1nodesource1 600
             18.0.0-1nodesource1 600
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
        Temp directories causing npm8 problem: 75
        Some problems detected, please run iob fix
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.17
        admin:          "admin" not found
        javascript:     "javascript" not found
        Adapters from github:   0
        Adapter State
          system.adapter.admin.0                  : admin                 : raspberrypi                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
          system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
          system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
          system.adapter.echarts.0                : echarts               : raspberrypi                              -  enabled
          system.adapter.evcc.0                   : evcc                  : raspberrypi                              -  enabled, port: 7070
          system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
          system.adapter.growatt.0                : growatt               : raspberrypi                              -  enabled
          system.adapter.history.0                : history               : raspberrypi                              -  enabled
          system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              - disabled
          system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled
          system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
          system.adapter.net-tools.0              : net-tools             : raspberrypi                              -  enabled
          system.adapter.parser.0                 : parser                : raspberrypi                              -  enabled
        + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
          system.adapter.pvforecast.0             : pvforecast            : raspberrypi                              -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
          system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
          system.adapter.socketio.0               : socketio              : raspberrypi                              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
          system.adapter.terminal.0               : terminal              : raspberrypi                              -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
          system.adapter.tibberlink.0             : tibberlink            : raspberrypi                              -  enabled
          system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
          system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
          system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "homeconnect"  : 1.3.0    , installed 1.3.0
        Controller "js-controller": 5.0.17   , installed 5.0.17
        Adapter    "meross"       : 1.17.0   , installed 1.17.0
        Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
        Adapter    "tuya"         : 3.15.0   , installed 3.15.0
        Objects and States
        Objects:        2093
        States:         1702
        Hit:1 http://deb.debian.org/debian bullseye InRelease
        Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
        Get:5 https://dl.cloudsmith.io/public/evcc/stable/deb/debian bullseye InRelease [5127 B]
        Hit:6 https://dl.yarnpkg.com/debian stable InRelease
        Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
        Fetched 5127 B in 2s (2420 B/s)
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14242      600/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       749922     205370/iobroker.js-
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       748495     205370/iobroker.js-
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          170745     44884/cupsd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          14253      600/sshd: /usr/sbin
        tcp6       0      0 :::4712                 :::*                    LISTEN      116        15709      576/evcc
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          170744     44884/cupsd
        tcp6       0      0 :::7070                 :::*                    LISTEN      116        15075      576/evcc
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12997      572/dhcpcd
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       758148     208071/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       758149     208071/io.tuya.0
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          174358     44885/cups-browsed
        udp        0      0 0.0.0.0:54194           0.0.0.0:*                           108        15460      386/avahi-daemon: r
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        17496      576/evcc
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15458      386/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          13016      572/dhcpcd
        udp6       0      0 :::50063                :::*                                108        15461      386/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                116        17497      576/evcc
        udp6       0      0 :::5353                 :::*                                108        15459      386/avahi-daemon: r
        2024-01-23 17:45:33.753  - info: host.raspberrypi iobroker npm-install: upload [2] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/tuya.png tuya.png image/png
        2024-01-23 17:45:33.762  - info: host.raspberrypi iobroker npm-install: upload [1] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/warning.png warning.png image/png
        2024-01-23 17:45:33.775  - info: host.raspberrypi iobroker npm-install: upload [0] tuya.admin /opt/iobroker/node_modules/iobroker.tuya/admin/words.js words.js application/javascript
        2024-01-23 17:45:33.883  - info: host.raspberrypi iobroker npm-install: host.raspberrypi object system.adapter.tuya created/updated
        2024-01-23 17:45:37.269  - info: host.raspberrypi iobroker npm-install: exit 0
        2024-01-23 17:45:37.338  - info: host.raspberrypi instance system.adapter.tuya.0 started with pid 208071
        2024-01-23 17:45:38.269  - warn: host.raspberrypi startInstance cannot find adapter "discovery@4.2.0". Try to install it... 1 attempt
        2024-01-23 17:45:38.271  - info: host.raspberrypi iobroker install discovery@4.2.0 using installedFrom
        2024-01-23 17:45:42.973  - info: host.raspberrypi iobroker npm-install: NPM version: 10.2.3Installing iobroker.discovery@4.2.0... (System call)
        2024-01-23 17:45:55.711  - info: host.raspberrypi iobroker npm-install:
        2024-01-23 17:45:55.712  - info: host.raspberrypi iobroker npm-install: added 15 packages in 12s
        2024-01-23 17:45:55.713  - info: host.raspberrypi iobroker npm-install: 59 packages are looking for funding  run `npm fund` for details
        2024-01-23 17:45:55.780  - info: host.raspberrypi iobroker npm-install: host.raspberrypi install adapter discovery@4.2.0
        2024-01-23 17:45:55.892  - info: host.raspberrypi iobroker npm-install: upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
        2024-01-23 17:45:55.917  - info: host.raspberrypi iobroker npm-install: upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
        2024-01-23 17:45:55.931  - info: host.raspberrypi iobroker npm-install: upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
        2024-01-23 17:45:55.946  - info: host.raspberrypi iobroker npm-install: upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
        2024-01-23 17:45:55.957  - info: host.raspberrypi iobroker npm-install: upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
        2024-01-23 17:45:55.970  - info: host.raspberrypi iobroker npm-install: upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
        2024-01-23 17:45:55.981  - info: host.raspberrypi iobroker npm-install: upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
        2024-01-23 17:45:56.083  - info: host.raspberrypi iobroker npm-install: host.raspberrypi object system.adapter.discovery created/updated
        2024-01-23 17:45:57.159  - info: host.raspberrypi iobroker npm-install: exit 0
        2024-01-23 17:45:57.209  - info: host.raspberrypi instance system.adapter.discovery.0 started with pid 209055
        2024-01-23 17:45:58.159  - warn: host.raspberrypi startInstance cannot find adapter "backitup@2.9.8". Try to install it... 1 attempt
        2024-01-23 17:45:58.160  - info: host.raspberrypi iobroker install backitup@2.9.8 using installedFrom
          meine Internetleitung spinnt gerade
          soll ich d
          iob fix ausführen
            Homoran Global Moderator Administrators @Borkenkäfer last edited by
            @borkenkäfer sagte in Iobroker lässt sich nicht mehr starten.:
            soll ich d
            iob fix ausführen
            was soll der bringen?
            wird da gerade ein Backup wiederhergestellt?
              Borkenkäfer @Homoran last edited by
              das steht im full drin
                Borkenkäfer @Borkenkäfer last edited by
                @borkenkäfer said in Iobroker lässt sich nicht mehr starten.:
                ich mach sonst nichts, nur nach Anweisung
                  das sind Meldungen bei einem Restore
                    soll ich iobroker dann mal starten und schauen was passiert?
                      iobroker logs --watch
                        ein Auszug
                        das sind meine Blockly sripte
                        2024-01-23 18:45:15.004  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 294
                        2024-01-23 18:45:30.006  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 292
                        2024-01-23 18:45:33.099  - info: javascript.0 (212309) script.js.common.PV_Daten_auslesen:
                         Error : Connect Failed
                        2024-01-23 18:45:45.003  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 293
                        2024-01-23 18:46:00.005  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 295
                        2024-01-23 18:46:03.115  - info: javascript.0 (212309) script.js.common.PV_Daten_auslesen:
                        2024-01-23 18:46:15.003  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 290
                        2024-01-23 18:46:30.006  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 292
                        2024-01-23 18:46:33.099  - info: javascript.0 (212309) script.js.common.PV_Daten_auslesen:
                        2024-01-23 18:46:45.003  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 255
                        2024-01-23 18:47:00.002  - info: javascript.0 (212309) script.js.common.einfach_Priosteuerung: 262
                        2024-01-23 18:47:03.085  - info: javascript.0 (212309) script.js.common.PV_Daten_auslesen:
                          hier mal der Anfang
                          2024-01-23 17:47:08.532  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.net-tools@0.2.0: 155
                          2024-01-23 17:47:09.586  - info: host.raspberrypi iobroker npm-install: exit 25
                          2024-01-23 17:47:10.587  - warn: host.raspberrypi startInstance cannot find adapter "fritzdect@2.5.9". Try to install it... 1 attempt
                          2024-01-23 17:47:10.588  - info: host.raspberrypi iobroker install fritzdect@2.5.9 using installedFrom
                          2024-01-23 17:47:14.249  - info: host.raspberrypi iobroker npm-install: NPM version: 10.2.3
                          2024-01-23 17:47:14.252  - info: host.raspberrypi iobroker npm-install: Installing iobroker.fritzdect@2.5.9... (System call)
                          2024-01-23 17:50:15.627  - info: host.raspberrypi iobroker npm-install:
                          2024-01-23 17:50:15.628  - info: host.raspberrypi iobroker npm-install: added 22 packages, and removed 25 packages in 3m
                          2024-01-23 17:50:15.630  - info: host.raspberrypi iobroker npm-install: 73 packages are looking for funding  run `npm fund` for details
                          2024-01-23 17:50:15.677  - info: host.raspberrypi iobroker npm-install: host.raspberrypi install adapter fritzdect@2.5.9
                          2024-01-23 17:50:15.788  - info: host.raspberrypi iobroker npm-install: upload [5] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/admin.d.ts admin.d.ts video/mp2t
                          2024-01-23 17:50:15.815  - info: host.raspberrypi iobroker npm-install: upload [4] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/fritzdect_logo.png fritzdect_logo.png image/png
                          2024-01-23 17:50:15.825  - info: host.raspberrypi iobroker npm-install: upload [3] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/index_m.html index_m.html text/html
                          2024-01-23 17:50:15.836  - info: host.raspberrypi iobroker npm-install: upload [2] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/jsonConfig.json jsonConfig.json application/json
                          2024-01-23 17:50:15.851  - info: host.raspberrypi iobroker npm-install: upload [1] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/style.css style.css text/css
                          2024-01-23 17:50:15.862  - info: host.raspberrypi iobroker npm-install: upload [0] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/words.js words.js application/javascript
                          2024-01-23 17:50:15.902  - info: host.raspberrypi "system.adapter.vis.0" disabled
                          2024-01-23 17:50:15.912  - info: host.raspberrypi "system.adapter.vis.0" enabled
                          2024-01-23 17:50:15.915  - info: host.raspberrypi iobroker npm-install: Adapter "system.adapter.vis.0" restarted.
                          2024-01-23 17:50:15.969  - info: host.raspberrypi iobroker npm-install: host.raspberrypi object system.adapter.fritzdect created/updated
                          2024-01-23 17:50:17.029  - info: host.raspberrypi iobroker npm-install: exit 0
                          2024-01-23 17:50:17.077  - info: host.raspberrypi instance system.adapter.fritzdect.0 started with pid 210259
                          2024-01-23 17:50:18.031  - warn: host.raspberrypi startInstance cannot find adapter "web@6.1.10". Try to install it... 1 attempt
                          2024-01-23 17:50:18.032  - info: host.raspberrypi iobroker install web@6.1.10 using installedFrom
                          2024-01-23 17:50:19.050  - info: fritzdect.0 (210259) starting. Version 2.5.9 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v18.19.0, js-controller: 5.0.17
                          2024-01-23 17:50:19.083  - info: fritzdect.0 (210259) fritzdect entered ready
                          2024-01-23 17:50:19.121  - info: fritzdect.0 (210259) fritzdect uses USER: admin
                          2024-01-23 17:50:19.240  - error: fritzdect.0 (210259) --------------- error calling the fritzbox -----------
                          2024-01-23 17:50:19.241  - error: fritzdect.0 (210259) API msg   => error calling executeCommand
                          2024-01-23 17:50:19.242  - error: fritzdect.0 (210259) API funct => login_SID
                          2024-01-23 17:50:19.243  - error: fritzdect.0 (210259) no response part in returned error message
                          2024-01-23 17:50:19.243  - error: fritzdect.0 (210259) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"error http.request","function":"get_login_state","error":{"errno":-3008,"code":"ENOTFOUND","syscall":"getaddrinfo","hostname":"192.168.x.x"}}}
                          2024-01-23 17:50:19.245  - error: fritzdect.0 (210259) login not possible, check user and permissions
                          2024-01-23 17:50:20.812  - info: host.raspberrypi iobroker npm-install: host.raspberrypi Adapter "system.adapter.web.0" is stopped.
                          2024-01-23 17:50:20.818  - info: host.raspberrypi "system.adapter.web.0" disabled
                          2024-01-23 17:50:21.917  - info: host.raspberrypi iobroker npm-install: NPM version: 10.2.3
                          2024-01-23 17:50:21.919  - info: host.raspberrypi iobroker npm-install: Installing iobroker.web@6.1.10... (System call)
                          2024-01-23 17:50:46.063  - info: host.raspberrypi iobroker npm-install:
                          2024-01-23 17:50:46.064  - info: host.raspberrypi iobroker npm-install: added 62 packages in 23s
                          2024-01-23 17:50:46.065  - info: host.raspberrypi iobroker npm-install: 74 packages are looking for funding  run `npm fund` for details
                          2024-01-23 17:50:46.117  - info: host.raspberrypi iobroker npm-install: host.raspberrypi install adapter web@6.1.10
                          2024-01-23 17:50:47.032  - info: host.raspberrypi iobroker npm-install: upload [129] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
                          2024-01-23 17:51:02.449  - info: host.raspberrypi iobroker npm-install: upload [100] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Computer.9558f6ee3941dba4e3c5.svg static/media/Computer.9558f6ee3941dba4e3c5.svg image/svg+xml
                          2024-01-23 17:51:02.528  - info: host.raspberrypi iobroker npm-install: upload [90] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Dressing Room.5e6f8f64b0e8f91c473e.svg static/media/Dressing Room.5e6f8f64b0e8f91c473e.svg image/svg+xml
                          2024-01-23 17:51:02.609  - info: host.raspberrypi iobroker npm-install: upload [80] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Garage.f7fc0a9b326d582afee6.svg static/media/Garage.f7fc0a9b326d582afee6.svg image/svg+xml
                          2024-01-23 17:51:02.687  - info: host.raspberrypi iobroker npm-install: upload [70] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Hanging Lamps.0bd452fc843edd645c30.svg static/media/Hanging Lamps.0bd452fc843edd645c30.svg image/svg+xml
                          2024-01-23 17:51:02.764  - info: host.raspberrypi iobroker npm-install: upload [60] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Led Strip.5cf2de461e29ffbaa5f0.svg static/media/Led Strip.5cf2de461e29ffbaa5f0.svg image/svg+xml
                          2024-01-23 17:51:02.844  - info: host.raspberrypi iobroker npm-install: upload [50] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Nursery.9cecc0544bdb5c28500c.svg static/media/Nursery.9cecc0544bdb5c28500c.svg image/svg+xml
                          2024-01-23 17:51:02.923  - info: host.raspberrypi iobroker npm-install: upload [40] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Rear Wall.38843c33f1ea1f575500.svg static/media/Rear Wall.38843c33f1ea1f575500.svg image/svg+xml
                          2024-01-23 17:51:03.021  - info: host.raspberrypi iobroker npm-install: upload [30] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Sockets.8320e1a99be9de004629.svg static/media/Sockets.8320e1a99be9de004629.svg image/svg+xml
                          2024-01-23 17:51:03.113  - info: host.raspberrypi iobroker npm-install: upload [20] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Terrace.d71d07d9290674f2ca20.svg static/media/Terrace.d71d07d9290674f2ca20.svg image/svg+xml
                          2024-01-23 17:51:03.123  - info: host.raspberrypi iobroker npm-install: upload [19] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                          2024-01-23 17:51:03.132  - info: host.raspberrypi iobroker npm-install: upload [18] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Tv.4e9745a548e57bfac0c7.svg static/media/Tv.4e9745a548e57bfac0c7.svg image/svg+xml
                          2024-01-23 17:51:03.141  - info: host.raspberrypi iobroker npm-install: upload [17] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Upstairs.441813e54e0daca0882d.svg static/media/Upstairs.441813e54e0daca0882d.svg image/svg+xml
                          2024-01-23 17:51:03.150  - info: host.raspberrypi iobroker npm-install: upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
                          2024-01-23 17:51:03.158  - info: host.raspberrypi iobroker npm-install: upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Ventilation.c31761d86d67e245ac92.svg static/media/Ventilation.c31761d86d67e245ac92.svg image/svg+xml
                          2024-01-23 17:51:03.167  - info: host.raspberrypi iobroker npm-install: upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Wardrobe.e8019970a2b51412cfdc.svg static/media/Wardrobe.e8019970a2b51412cfdc.svg image/svg+xml
                          2024-01-23 17:51:03.177  - info: host.raspberrypi iobroker npm-install: upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Washing Machines.577f3acdb3cef002b523.svg static/media/Washing Machines.577f3acdb3cef002b523.svg image/svg+xml
                          2024-01-23 17:51:03.185  - info: host.raspberrypi iobroker npm-install: upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Washroom.bfb54196f381f36de9d6.svg static/media/Washroom.bfb54196f381f36de9d6.svg image/svg+xml
                          2024-01-23 17:51:03.195  - info: host.raspberrypi iobroker npm-install: upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Water Consumption.68891649591cc2434c5b.svg static/media/Water Consumption.68891649591cc2434c5b.svg image/svg+xml
                          2024-01-23 17:51:03.203  - info: host.raspberrypi iobroker npm-
                            die nächsten zwei
                              einiger läuft schon mal wieder
                              Homoran B 2 Replies Last reply Reply Quote 0
                                @borkenkäfer so ein Neubau aller Adapter bei einem Restore kann auch mal gerne eine Stunde dauern.
                                in der Zeit darf man nicht stören.
                                  einiges läuft schon mal wieder
                                  werde weiter testen
                                  Melde mich
                                  Danke für Eure Hilfe und eure unendliche Geduld
                                  schönen Abend
                                    hallo
                                    iobroker scheint zu funktionieren, die Scripte laufen und vis läuft auch
                                    aber ich komme nicht auf die WEB seite und es ist kein admin installiert
                                    nach dem Befehl iobroker add admin --port 8081 0der 8089 kommt folgende meldung
                                    ulli@raspberrypi:/opt/iobroker $ iobroker add admin --port 8081
                                    NPM version: 10.2.3
                                    Installing iobroker.admin@6.12.0... (System call)
                                    Try to solve ENOTEMPTY error automatically
                                    Could not handle ENOTEMPTY, because no deletable files were found
                                    npm ERR! code ENOTEMPTY
                                    npm ERR! syscall rename
                                    npm ERR! path /opt/iobroker/node_modules/@tootallnate/once
                                    npm ERR! dest /opt/iobroker/node_modules/@tootallnate/.once-ZoNnWMHe
                                    npm ERR! errno -39
                                    npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@tootallnate/once' -> '/opt/iobroker/node_modules/@tootallnate/.once-ZoNnWMHe'
                                    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-24T17_00_04_975Z-debug-0.log
                                    host.raspberrypi Cannot install iobroker.admin@6.12.0: 217
                                    ulli@raspberrypi:/opt/iobroker $ iobroker add admin --port 8089
                                    NPM version: 10.2.3
                                    npm ERR! errno -39
                                    npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-24T17_00_32_891Z-debug-0.log
                                      Thomas Braun Most Active @Borkenkäfer last edited by Thomas Braun
                                      @borkenkäfer
                                      iob stop
                                      iob fix
                                      iob add admin
                                        funktioniert?
                                        was habe ich falsche gemacht das alles abgestürzt ist
                                        danke und schönen Abend
                                        B Thomas Braun 2 Replies Last reply Reply Quote 0
                                          funktioniert!
                                            @borkenkäfer
                                            Ich kann mit deiner Frage nicht viel anfangen...
                                            Funktioniert die Installation jetzt oder nicht?
                                            3679
