    4. Admin startet nicht - buanet image[gelöst]
      HMuser @Glasfaser last edited by
      @glasfaser
      Skript v.2023-10-10
      *** BASE SYSTEM ***
      Hardware Vendor : Intel Corporation
      Kernel          : x86_64
      Userland        : amd64
      Docker          : v9.1.0
      Virtualization  : Docker
      Kernel          : x86_64
      Userland        : amd64
      Systemuptime and Load:
       21:34:54 up 4 days,  7:01,  0 user,  load average: 2.68, 2.29, 2.18
      CPU threads: 4
      *** Time and Time Zones ***
      Tue Jan 23 20:34:54 UTC 2024
      Tue Jan 23 21:34:54 CET 2024
      CET +0100
      Etc/UTC
      *** User and Groups ***
      root
      /root
      root
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:
      *** MEMORY ***
      Mem:            1.0G        915M        120M        3.0M        230M        120M
      Swap:           2.8G        727M        2.0G
      Total:          3.8G        1.6G        2.2G
                988 M total memory
                873 M used memory
                195 M active memory
                239 M inactive memory
                115 M free memory
                  8 M buffer memory
                211 M swap cache
               2641 M total swap
                693 M used swap
               1948 M free swap
      *** FILESYSTEM ***
      Filesystem             Type   Size  Used Avail Use% Mounted on
      none                   aufs   3.6T  1.7T  2.0T  47% /
      tmpfs                  tmpfs   64M     0   64M   0% /dev
      tmpfs                  tmpfs  495M     0  495M   0% /sys/fs/cgroup
      shm                    tmpfs   64M     0   64M   0% /dev/shm
      /dev/mapper/cachedev_0 ext4   3.6T  1.7T  2.0T  47% /opt/iobroker
      tmpfs                  tmpfs  495M     0  495M   0% /proc/acpi
      tmpfs                  tmpfs  495M     0  495M   0% /proc/scsi
      tmpfs                  tmpfs  495M     0  495M   0% /sys/firmware
      [Fri Jan 19 14:34:06 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
      [Fri Jan 19 14:34:08 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
      [Fri Jan 19 14:34:08 2024] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
      [Fri Jan 19 14:34:13 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null)
      [Fri Jan 19 14:34:14 2024] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
      [Fri Jan 19 14:34:34 2024] EXT4-fs (dm-0): barriers disabled
      [Fri Jan 19 14:34:35 2024] EXT4-fs (dm-0): mounted filesystem with writeback data mode. Opts: usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl,oldalloc
      [Fri Jan 19 14:34:49 2024] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
      TARGET             SOURCE        FSTYPE OPTIONS
      /                  none        aufs   rw,relatime,si=e20874a68cf9f35,dio,dirperm1
      |-/opt/iobroker    /dev/mapper/cachedev_0[/docker/iobroker_data]        ext4   rw,nodev,relatime,journal_checksum,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
      |-/etc/resolv.conf /dev/mapper/cachedev_0[/@docker/containers/b7b29cf44ccd7e3917f6654705dce653b19400dcfc8a57fc13178d0aa6077bba/resolv.conf] ext4   rw,nodev,relatime,journal_checksum,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
      |-/etc/hostname    /dev/mapper/cachedev_0[/@docker/containers/b7b29cf44ccd7e3917f6654705dce653b19400dcfc8a57fc13178d0aa6077bba/hostname]    ext4   rw,nodev,relatime,journal_checksum,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
      `-/etc/hosts       /dev/mapper/cachedev_0[/@docker/containers/b7b29cf44ccd7e3917f6654705dce653b19400dcfc8a57fc13178d0aa6077bba/hosts]       ext4   rw,nodev,relatime,journal_checksum,synoacl,jqfmt=vfsv0,usrjquota=aquota.user,grpjquota=aquota.group
      /var:
      38M     /var/
      35M     /var/lib
      19M     /var/lib/apt/lists
      19M     /var/lib/apt
      17M     /var/lib/dpkg
      /opt/iobroker/backups:
      54M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      114M    /opt/iobroker/iobroker-data/
      62M     /opt/iobroker/iobroker-data/files
      34M     /opt/iobroker/iobroker-data/backup-objects
      30M     /opt/iobroker/iobroker-data/files/web.admin/static
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      13M     /opt/iobroker/iobroker-data/objects.jsonl
      8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
      6.7M    /opt/iobroker/iobroker-data/states.jsonl
      6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
           18.19.0+dfsg-6~deb12u1 500
              500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
       *** 18.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.12.0
      javascript:     "javascript" not found
      Adapters from github:   0
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.admin.1                  : admin                 : iobroker                                 - disabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.backitup.0               : backitup              : iobroker                                 - disabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        system.adapter.hm-rega.0                : hm-rega               : iobroker                                 - disabled
        system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 - disabled, port: 0
        system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 - disabled, port: 0
        system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
        system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
        system.adapter.web.0                    : web                   : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
      Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Objects and States
      Objects:        299
      States:         271
      Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       17400825   -
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       17407578   -
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       19043686   -
      udp        0      0 0.0.0.0:8472            0.0.0.0:*                           0          17394061   -
      2024-01-23 21:22:27.635  - info: admin.1 (227) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-01-23 21:22:27.532  - info: host.iobroker stopInstance system.adapter.admin.1 (force=false, process=true)
      2024-01-23 21:22:27.666  - info: host.iobroker stopInstance system.adapter.admin.1 send kill signal
      2024-01-23 21:22:28.138  - info: admin.1 (227) terminating
      2024-01-23 21:22:28.201  - error: admin.1 (227) Cannot find view "system" for search "instance" : Connection is closed.
      2024-01-23 21:22:28.692  - info: host.iobroker stopInstance system.adapter.admin.1 killing pid 227
      2024-01-23 21:22:29.192  - info: host.iobroker instance system.adapter.admin.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-01-23 21:24:09.233  - info: host.iobroker "system.adapter.admin.0" enabled
      2024-01-23 21:24:09.473  - info: host.iobroker instance system.adapter.admin.0 started with pid 24575
      2024-01-23 21:24:16.245  - info: admin.0 (24575) starting. Version 6.12.0 in /opt/iobroker/node_modules/iobroker.admin, node: v18.19.0, js-controller: 5.0.17
      2024-01-23 21:24:16.315  - info: admin.0 (24575) requesting all objects
      2024-01-23 21:24:18.107  - info: admin.0 (24575) received all objects
      2024-01-23 21:24:19.773  - info: admin.0 (24575) Request actual repository...
      2024-01-23 21:24:19.983  - error: host.iobroker cannot call visUtils: Not exists
      2024-01-23 21:24:20.046  - info: admin.0 (24575) socket.io server listening on port 8081
      2024-01-23 21:24:20.151  - info: admin.0 (24575) http server listening on port 8081
      2024-01-23 21:24:20.152  - info: admin.0 (24575) Use link "http://127.0.0.1:8081" to configure.
      2024-01-23 21:24:21.041  - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      2024-01-23 21:24:29.941  - info: admin.0 (24575) Repository received successfully.
      2024-01-23 21:24:31.334  - info: admin.0 (24575) failed connection to socket.io from ::ffff:172.17.0.1: Passport was not initialized
      2024-01-23 21:24:42.251  - info: admin.0 (24575) ==> Connected system.user.admin from ::ffff:172.17.0.1
      2024-01-23 21:24:51.278  - error: host.iobroker cannot call visUtils: Not exists
      2024-01-23 21:25:27.271  - error: host.iobroker cannot call visUtils: Not exists
      2024-01-23 21:33:39.133  - info: admin.0 (24575) <== Disconnect system.user.admin from ::ffff:172.17.0.1 admin
      2024-01-23 21:35:17.076  - info: admin.0 (24575) failed connection to socket.io from ::ffff:172.17.0.1: Passport was not initialized
        @glasfaser
        Jetzt läuft soweit alles - das einzige was mir noch unklar ist: Im docker ist nur der portainer als Container sichtbar, iobroker nicht: das kenne ich von einer anderen Installation nicht so.
        • Glasfaser
          Glasfaser @HMuser last edited by
          @hmuser
          Hattest du nicht schonmal diese Problem !?
          Würde mal Portainer als app deinstallieren , neustes Image laden und dann neu installieren
            @glasfaser
            Nein, das hatte ich noch nicht.
            Portainer habe ich über die Konsole installiert, ist das auch eine app auf der Synology?
            Glasfaser 2 Replies Last reply Reply Quote 0
            • Glasfaser
              @hmuser
              Einfach den Container löschen ... über die Syn Docker Konsole
              • Glasfaser
                @hmuser sagte in Admin startet nicht - buanet image:
                Das war doch hier
                https://forum.iobroker.net/topic/45625/gelöst-iobroker-container-in-portainer-verschwunden
                Zitat :
                Von einem Tag auf den anderen "fehlt" der Container ioBroker im Portainer.
                  @glasfaser
                  Also nicht Container in der Docker app löschen sondern über die Konsole der Syno ?
                    @glasfaser
                    Nein, jetzt ist es ja anders herum: Im Portier da (und läuft!) aber nicht sichtbar unter docker...
                    • Glasfaser
                      Achso !?
                      Also im Syn Container Manager . nicht sichtbar / aufgeführt.
                        @glasfaser
                        Ist bei mir noch docker. Weiss nicht warum DSM das nicht Updated. Bei einer anderen Syno hat das Funktioniert. Auf dieser ist DSM 7.1.1 installiert, etwas neueres bietet er mir nicht an.
                          @glasfaser
                          Genau: nicht sichtbar
                          • Glasfaser
                            Ich kenne dein Syn nicht , laut Signatur die DS713+ aber die meinst du ja nicht .
                            Schau mal hier nach ..
                            https://www.synology.com/de-de/support/download/DS713+?version=7.1#system
                            sollte es aber als download geben
                              @glasfaser
                              exakt: 713+
                              Schaue mir das mal an, danke
                                @glasfaser
                                Wennn ich das richtig verstehe habe ich die neueste installiert: 7.1.1-42962 Update 6
                                • Glasfaser
                                  @hmuser
                                  Jipp , sehe es auch gerade , eine andere gibt es nicht .
                                    @glasfaser
                                    Die andere Syno ist eine 720+, wahrscheinlich deshalb.
                                    Setzt das aktuelle buanet image 7.2x voraus?
                                    • Glasfaser
                                      NEIN , es gibt keine Abhängigkeit !
                                      Der Fehler liegt an etwas anderes Portainer / Syn Docker und nicht am Image !
                                        @glasfaser
                                        Okay, alles klar. Docker App und Portainer sind gerade frisch aufgesetzt. Wenn ich portainer lösche und neu installiere muss ich iobroker auch wieder neu installieren- glaube das tue ich mir jetzt nicht an. Trotzdem Danke!
                                        • Glasfaser
                                          Portainer ist nur eine Weboberfläche / Hilfe mehr nicht , sowie auch der Syn Container Manager .
                                            @glasfaser
                                            Das bedeutet dass ich Portainer und Docker löschen und neu installieren kann ohne die ioBroker Installation/ Container zu beeinflussen?
                                            Wenn das so ist: mit welchen Befehlen würde ich auf der Syno Konsole das Löschen/ die Neuinstallation durchführen?
                                            2805
