    3. Entwicklung
    4. Adapter Entwicklung - Adapter disabled
      Marcolotti last edited by
      wie umgehe ich "Adapter Disabled" wegen Tests? Arbeite gerade an einem Adapter und er wurde disabled. 😞
      Gruß Marco
      • Jey Cee
        Hi Marco,
        wie meinst du disabled?
        Ist dein Adapter ein daemon?
        Gesendet von Unterwegs
          Hallo JeyCee,
          ja, es ist ein Daemon….zur Zeit noch ein böser Dämon.
          Gruß Marco
          • Jey Cee
            OK dann treiben wir ihn mal aus 😉
            Wann bekommst du den die Meldung?
              pv-calc.0	2017-12-08 13:16:57.308	error	adapter disabled
              pv-calc.0	2017-12-08 13:16:57.282	debug	statesDB connected
              pv-calc.0	2017-12-08 13:16:57.234	debug	objectDB connected
              pv-calc.0	2017-12-08 13:16:24.882	info	starting. Version 0.0.1 in D:/iobroker/node_modules/iobroker.pv-calc, node: v4.5.0
              pv-calc.0	2017-12-08 13:16:24.851	debug	statesDB connected
              pv-calc.0	2017-12-08 13:16:24.820	debug	objectDB connected
              pv-calc.0	2017-12-08 13:15:53.364	info	cleaned everything up...
              pv-calc.0	2017-12-08 13:15:53.364	error	at Manager. (D:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\node_modules\component-bind\index.js:21:15)
              pv-calc.0	2017-12-08 13:15:53.364	error	at Socket.onpacket (D:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\socket.js:236:12)
              pv-calc.0	2017-12-08 13:15:53.364	error	at Socket.onack (D:\iobroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\socket.js:312:9)
              pv-calc.0	2017-12-08 13:15:53.364	error	at Socket. (D:\iobroker\node_modules\iobroker.js-controller\lib\adapter.js:710:25)
              pv-calc.0	2017-12-08 13:15:53.364	error	at initAdapter (D:\iobroker\node_modules\iobroker.js-controller\lib\adapter.js:4659:18)
              pv-calc.0	2017-12-08 13:15:53.364	error	at Adapter.emit (events.js:166:7)
              pv-calc.0	2017-12-08 13:15:53.364	error	at emitNone (events.js:67:13)
              pv-calc.0	2017-12-08 13:15:53.364	error	at Adapter. (D:\iobroker\node_modules\iobroker.pv-calc\main.js:67:5)
              pv-calc.0	2017-12-08 13:15:53.364	error	at main (D:\iobroker\node_modules\iobroker.pv-calc\main.js:79:5)
              pv-calc.0	2017-12-08 13:15:53.364	error	at readwr (D:\iobroker\node_modules\iobroker.pv-calc\main.js:114:40)
              pv-calc.0	2017-12-08 13:15:53.364	error	TypeError: Cannot read property 'pvleistung' of undefined
              pv-calc.0	2017-12-08 13:15:53.364	error	uncaught exception: Cannot read property 'pvleistung' of undefined
              pv-calc.0	2017-12-08 13:15:53.364	debug	2
              pv-calc.0	2017-12-08 13:15:53.364	debug	Start
              pv-calc.0	2017-12-08 13:15:53.364	debug	Main
              pv-calc.0	2017-12-08 13:15:53.349	info	starting. Version 0.0.1 in D:/iobroker/node_modules/iobroker.pv-calc, node: v4.5.0
              So kann ich nicht arbeiten. 😢
              • Jey Cee
                Hast du den code auf github?
                  apollon77 last edited by
                  An sich einfach per Admin wieder einschalten. Nach 3 mal starten mit direktem „Crash“ wegen Fehler schaltet js-Controller den Adapter aus.
                  • frankjoke
                    frankjoke last edited by
                    Du kannst Adapter von Hand starten, auch wenn sie disabled sind:
                    sudo node --inspect-brk=0.0.0.0:9229  /opt/iobroker/node_modules/iobroker.systeminfo/systeminfo.js --logs --force
                    Ich debugge sie mit dem chrome broser wie oben. Du kannst –inspect... weglassen wenn du nur starten aber nicht debuggen willst.
                    Das wichtige für dich ist --force, das bringt ioBroker dazu den Adapter zu starten auch wenn er disabled ist!
