    4. Passwort Problem im mqtt Adapter
      Felix18 last edited by
      @codierknecht
      Hallo es war nicht meien absicht diesen post 3 mal abzuschicken!! Ich bin mit der app noch nicht ganz firm.
      Ich habe bereits den Browserchache gelöscht, leider ändert es nichts an der sache...
      crunchip F 2 Replies Last reply Reply Quote 0
        crunchip Forum Testing Most Active @Felix18 last edited by
        @felix18 sagte in Passwort Problem im mqtt Adapter:
        Dann vllt mal mehr Info zu deinem System
        Zeig die Ausgabe von
        iob diag
          Felix18 @Felix18 last edited by
          @felix18
          Skript v.2023-10-10
          *** BASE SYSTEM ***
           Static hostname: raspberrypi5
                 Icon name: computer
                    Kernel: Linux 6.1.0-rpi7-rpi-2712
              Architecture: arm64
          Model		: Raspberry Pi 5 Model B Rev 1.0
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : arm64
          Systemuptime and Load:
           13:32:10 up 23:08,  3 users,  load average: 0.99, 0.93, 0.94
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Wed 2024-01-24 13:32:10 CET
                     Universal time: Wed 2024-01-24 12:32:10 UTC
                           RTC time: Wed 2024-01-24 12:32:10
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server: 	false
          Desktop: 	LXDE-pi-wayfire
          Terminal: 	wayland
          Boot Target: 	graphical.target
          *** MEMORY ***
          Mem:            8.4G        6.3G        1.4G        1.4G        2.3G        2.2G
          Swap:           104M         98M        6.6M
          Total:          8.5G        6.4G        1.4G
                   8049 M total memory
                   5972 M used memory
                   1255 M active memory
                   3786 M inactive memory
                   1309 M free memory
                     67 M buffer memory
                   2087 M swap cache
                     99 M total swap
                     93 M used swap
                      6 M free swap
          Raspberry only:
          vc_gencmd_read_response returned -1
          error=1 error_msg="Command not registered"
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          udev           devtmpfs  3.8G     0  3.8G   0% /dev
          tmpfs          tmpfs     805M  6.1M  799M   1% /run
          /dev/mmcblk0p2 ext4      116G  8.6G  101G   8% /
          tmpfs          tmpfs     4.0G   84M  3.9G   3% /dev/shm
          tmpfs          tmpfs     5.0M   64K  5.0M   2% /run/lock
          /dev/mmcblk0p1 vfat      510M   73M  438M  15% /boot/firmware
          tmpfs          tmpfs     805M  144K  805M   1% /run/user/1000
          [Tue Jan 23 14:23:17 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=D8:3A:DD:BB:0D:24 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=e2eee0c6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
          [Tue Jan 23 14:23:20 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
          [Tue Jan 23 14:23:20 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          TARGET               SOURCE         FSTYPE      OPTIONS
          /                    /dev/mmcblk0p2 ext4        rw,noatime
          |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
          `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          807M	/var/
          255M	/var/cache
          249M	/var/log
          248M	/var/log/journal/ebc8e9f468b04fc0a8c5561fdead68d6
          Archived and active journals take up 247.8M in the file system.
          /opt/iobroker/backups:
          67M	/opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          705M	/opt/iobroker/iobroker-data/
          578M	/opt/iobroker/iobroker-data/files
          141M	/opt/iobroker/iobroker-data/files/vis-2
          103M	/opt/iobroker/iobroker-data/backup-objects
          89M	/opt/iobroker/iobroker-data/files/echarts.admin
          35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
          33M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
          24M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
          24M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
          23M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
          USB-Devices by-id:
          /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_a4dc61b289d8ed11876c736162c613ac-if00-port0
          *** NodeJS-Installation ***
          /usr/bin/nodejs 	v18.19.0
          /usr/bin/node 		v18.19.0
          /usr/bin/npm 		10.2.3
          /usr/bin/npx 		10.2.3
          /usr/bin/corepack 	0.22.0
          nodejs:
            Installed: 18.19.0-1nodesource1
            Candidate: 18.19.0-1nodesource1
            Version table:
               18.19.0+dfsg-6~deb12u1 500
           *** 18.19.0-1nodesource1 1001
                  100 /var/lib/dpkg/status
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0+dfsg1-1 500
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller: 	5.0.17
          admin: 		6.13.15
          javascript: 	7.7.0
          Adapters from github: 	1
          Adapter State
          + system.adapter.admin.0                  : admin                 : raspberrypi5                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : raspberrypi5                             -  enabled
          + system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi5                             -  enabled
          + system.adapter.backitup.0               : backitup              : raspberrypi5                             -  enabled
            system.adapter.birthdays.0              : birthdays             : raspberrypi5                             -  enabled
            system.adapter.chromecast.0             : chromecast            : raspberrypi5                             - disabled
            system.adapter.cloud.0                  : cloud                 : raspberrypi5                             - disabled
          + system.adapter.denon.0                  : denon                 : raspberrypi5                             -  enabled
            system.adapter.device-reminder.0        : device-reminder       : raspberrypi5                             - disabled
            system.adapter.devices.0                : devices               : raspberrypi5                             - disabled
            system.adapter.discovery.0              : discovery             : raspberrypi5                             - disabled
            system.adapter.echarts.0                : echarts               : raspberrypi5                             - disabled
          + system.adapter.energiefluss.0           : energiefluss          : raspberrypi5                             -  enabled
          + system.adapter.enocean.0                : enocean               : raspberrypi5                             -  enabled
          + system.adapter.ham.0                    : ham                   : raspberrypi5                             -  enabled
            system.adapter.heos.0                   : heos                  : raspberrypi5                             - disabled
            system.adapter.history.0                : history               : raspberrypi5                             - disabled
            system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi5                             - disabled, port: 0
            system.adapter.ical.0                   : ical                  : raspberrypi5                             -  enabled
          + system.adapter.info.0                   : info                  : raspberrypi5                             -  enabled
            system.adapter.iot.0                    : iot                   : raspberrypi5                             - disabled
          + system.adapter.iqontrol.0               : iqontrol              : raspberrypi5                             -  enabled
          + system.adapter.jarvis.0                 : jarvis                : raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.javascript.0             : javascript            : raspberrypi5                             -  enabled
            system.adapter.lgtv.0                   : lgtv                  : raspberrypi5                             - disabled
            system.adapter.mediola-gateway.0        : mediola-gateway       : raspberrypi5                             - disabled
            system.adapter.mihome-cloud.0           : mihome-cloud          : raspberrypi5                             - disabled
          + system.adapter.mqtt.0                   : mqtt                  : raspberrypi5                             -  enabled, port: 1883, bind: 0.0.0.0
            system.adapter.net-tools.0              : net-tools             : raspberrypi5                             - disabled
            system.adapter.parcel.0                 : parcel                : raspberrypi5                             - disabled
            system.adapter.ping.0                   : ping                  : raspberrypi5                             - disabled
            system.adapter.pushover.0               : pushover              : raspberrypi5                             - disabled
            system.adapter.sainlogic.0              : sainlogic             : raspberrypi5                             - disabled, port: 45000, bind: 0.0.0.0
          + system.adapter.shelly.1                 : shelly                : raspberrypi5                             -  enabled, port: 1882, bind: 0.0.0.0
          + system.adapter.shelly.2                 : shelly                : raspberrypi5                             -  enabled, port: 1881, bind: 0.0.0.0
            system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi5                             - disabled
            system.adapter.smartthings.0            : smartthings           : raspberrypi5                             - disabled
          + system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi5                             -  enabled
          + system.adapter.telegram.0               : telegram              : raspberrypi5                             -  enabled, port: 8443, bind: 0.0.0.0
            system.adapter.trashschedule.0          : trashschedule         : raspberrypi5                             - disabled
            system.adapter.vis-2-widgets-sweethome3d.0: vis-2-widgets-sweethome3d: raspberrypi5                             -  enabled
          + system.adapter.vis-2.0                  : vis-2                 : raspberrypi5                             -  enabled
            system.adapter.vis.0                    : vis                   : raspberrypi5                             -  enabled
            system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi5                             - disabled
          + system.adapter.web.0                    : web                   : raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi5                             -  enabled
          + system.adapter.yahka.0                  : yahka                 : raspberrypi5                             -  enabled
          + system.adapter.zigbee.0                 : zigbee                : raspberrypi5                             -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_a4dc61b289d8ed11876c736162c613ac-if00-port0
          + instance is alive
          ioBroker-Repositories
          Active repo(s): beta
          Installed ioBroker-Instances
          Used repository: beta
          Adapter    "admin"        : 6.13.15  , installed 6.13.15
          Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
          Adapter    "awtrix-light" : 0.11.0   , installed 0.11.0
          Adapter    "backitup"     : 2.10.5   , installed 2.10.2 [Updatable]
          Adapter    "birthdays"    : 2.4.1    , installed 2.4.1
          Adapter    "chromecast"   : 3.2.0    , installed 3.0.3  [Updatable]
          Adapter    "contactid"    : 1.0.2    , installed 1.0.2
          Adapter    "denon"        : 1.15.5   , installed 1.15.5
          Adapter    "device-reminder": 3.1.2  , installed 3.1.1  [Updatable]
          Adapter    "echarts"      : 1.7.2    , installed 1.7.2
          Adapter    "energiefluss" : 3.6.0    , installed 3.6.0
          Adapter    "enocean"      : 0.9.3    , installed 0.9.3
          Adapter    "ham"          : 5.3.1    , installed 5.3.1
          Adapter    "heos"         : 2.2.1    , installed 2.2.1
          Adapter    "hm-rpc"       : 1.16.0   , installed 1.16.0
          Adapter    "ical"         : 1.14.0   , installed 1.14.0
          Adapter    "iot"          : 2.0.11   , installed 2.0.11
          Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
          Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
          Adapter    "javascript"   : 7.7.0    , installed 7.7.0
          Controller "js-controller": 5.0.17   , installed 5.0.17
          Adapter    "lcn"          : 1.1.8    , installed 1.1.8
          Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
          Adapter    "mediola-gateway": 1.1.0  , installed 1.0.1  [Updatable]
          Adapter    "mihome-cloud" : 0.1.1    , installed 0.1.1
          Adapter    "mqtt"         : 5.2.0    , installed 5.2.0
          Adapter    "net-tools"    : 1.0.4    , installed 0.2.0  [Updatable]
          Adapter    "node-red"     : 5.1.0    , installed 5.1.0
          Adapter    "parcel"       : 0.2.7    , installed 0.2.7
          Adapter    "pushover"     : 3.0.6    , installed 3.0.6
          Adapter    "sainlogic"    : 0.10.5   , installed 0.10.5
          Adapter    "shelly"       : 6.7.0    , installed 6.7.0
          Adapter    "shuttercontrol": 1.6.3   , installed 1.6.3
          Adapter    "smartthings"  : 0.1.1    , installed 0.1.1
          Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
          Adapter    "spotify-premium": 1.3.1  , installed 1.3.1
          Adapter    "tahoma"       : 0.10.2   , installed 0.10.2
          Adapter    "telegram"     : 3.0.1    , installed 3.0.1
          Adapter    "trashschedule": 3.2.0    , installed 3.1.3  [Updatable]
          Adapter    "vis-2"        : 2.9.22   , installed 2.9.18 [Updatable]
          Adapter    "vis-2-widgets-radar-trap": 1.0.7, installed 1.0.7
          Adapter    "vis-2-widgets-sweethome3d": 0.1.6, installed 0.1.6
          Adapter    "vw-connect"   : 0.5.1    , installed 0.5.1
          Adapter    "weatherunderground": 3.6.0, installed 3.6.0
          Adapter    "web"          : 6.2.3    , installed 6.2.3
          Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
          Adapter    "ws"           : 2.5.10   , installed 2.5.10
          Adapter    "yahka"        : 1.0.3    , installed 1.0.3
          Adapter    "zigbee"       : 1.10.1   , installed 1.10.0 [Updatable]
          Objects and States
          Objects: 	6298
          States: 	4420
          Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
          Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 13
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18184      931/iobroker.js-con
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       19481      931/iobroker.js-con
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          153202     9376/cupsd
          tcp        0      0 0.0.0.0:8200            0.0.0.0:*               LISTEN      112        16185      771/minidlnad
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14929      974/sshd: /usr/sbin
          tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       27777      3106/io.jarvis.0
          tcp        0      0 0.0.0.0:33643           0.0.0.0:*               LISTEN      1001       25059      2998/io.yahka.0
          tcp        0      0 127.0.0.1:45211         0.0.0.0:*               LISTEN      1001       139002     2998/io.yahka.0
          tcp        0      0 0.0.0.0:1881            0.0.0.0:*               LISTEN      1001       24510      2849/io.shelly.2
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       22434      2558/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       27715      3054/io.web.0
          tcp6       0      0 :::22                   :::*                    LISTEN      0          14931      974/sshd: /usr/sbin
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          153201     9376/cupsd
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          153226     9379/cups-browsed
          udp        0      0 0.0.0.0:54145           0.0.0.0:*                           104        14804      765/avahi-daemon: r
          udp        0      0 224.0.0.251:5353        0.0.0.0:*                           1000       297615     2029/chromium-brows
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       24929      2725/io.ham.0
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        14802      765/avahi-daemon: r
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       25654      2706/io.shelly.1
          udp        0      0 239.255.255.250:1900    0.0.0.0:*                           112        16184      771/minidlnad
          udp        0      0 192.168.2.167:43545     0.0.0.0:*                           112        178923     771/minidlnad
          udp6       0      0 fe80::fd88:586a:223:546 :::*                                0          18359      894/NetworkManager
          udp6       0      0 :::5353                 :::*                                104        14803      765/avahi-daemon: r
          udp6       0      0 :::46803                :::*                                104        14805      765/avahi-daemon: r
          2024-01-24 13:31:30.132  - info: mqtt.0 (14172) Disconnected from 192.168.2.190
          2024-01-24 13:31:40.133  - info: mqtt.0 (14172) Reconnected to 192.168.2.190
          2024-01-24 13:31:40.137  - error: mqtt.0 (14172) Client error: Error: connect ECONNREFUSED 192.168.2.190:1883
          2024-01-24 13:31:40.138  - info: mqtt.0 (14172) Disconnected from 192.168.2.190
          2024-01-24 13:31:50.139  - info: mqtt.0 (14172) Reconnected to 192.168.2.190
          2024-01-24 13:31:50.143  - error: mqtt.0 (14172) Client error: Error: connect ECONNREFUSED 192.168.2.190:1883
          2024-01-24 13:31:50.143  - info: mqtt.0 (14172) Disconnected from 192.168.2.190
          2024-01-24 13:32:00.144  - info: mqtt.0 (14172) Reconnected to 192.168.2.190
          2024-01-24 13:32:00.213  - error: mqtt.0 (14172) Client error: Error: connect ECONNREFUSED 192.168.2.190:1883
          2024-01-24 13:32:00.214  - info: mqtt.0 (14172) Disconnected from 192.168.2.190
          2024-01-24 13:32:10.215  - info: mqtt.0 (14172) Reconnected to 192.168.2.190
          2024-01-24 13:32:10.240  - error: mqtt.0 (14172) Client error: Error: connect ECONNREFUSED 192.168.2.190:1883
          2024-01-24 13:32:10.241  - info: mqtt.0 (14172) Disconnected from 192.168.2.190
          2024-01-24 13:32:20.242  - info: mqtt.0 (14172) Reconnected to 192.168.2.190
          2024-01-24 13:32:20.277  - error: mqtt.0 (14172) Client error: Error: connect ECONNREFUSED 192.168.2.190:1883
          2024-01-24 13:32:20.277  - info: mqtt.0 (14172) Disconnected from 192.168.2.190
          2024-01-24 13:32:30.278  - info: mqtt.0 (14172) Reconnected to 192.168.2.190
          2024-01-24 13:32:30.284  - error: mqtt.0 (14172) Client error: Error: connect ECONNREFUSED 192.168.2.190:1883
          2024-01-24 13:32:30.285  - info: mqtt.0 (14172) Disconnected from 192.168.2.190
          2024-01-24 13:32:40.286  - info: mqtt.0 (14172) Reconnected to 192.168.2.190
          2024-01-24 13:32:40.290  - error: mqtt.0 (14172) Client error: Error: connect ECONNREFUSED 192.168.2.190:1883
          2024-01-24 13:32:40.291  - info: mqtt.0 (14172) Disconnected from 192.168.2.190
          2024-01-24 13:32:50.292  - info: mqtt.0 (14172) Reconnected to 192.168.2.190
          2024-01-24 13:32:50.299  - error: mqtt.0 (14172) Client error: Error: connect ECONNREFUSED 192.168.2.190:1883
          2024-01-24 13:32:50.300  - info: mqtt.0 (14172) Disconnected from 192.168.2.190
          iob diag has finished.
          Press any key for a summary
          Marc Berg Thomas Braun 2 Replies Last reply Reply Quote 0
          • Marc Berg
            Marc Berg Most Active @Felix18 last edited by
            Wenn ich das richtig sehe, ist der MQTT Adapter als Client konfiguriert und du versuchst dich zu einem Broker mit der IP 192.168.2.190 zu verbinden. Was ist das für ein Broker und heißt das, du hast das Passwort vom Broker vergessen?
              Felix18 @Marc Berg last edited by
              @marc-berg
              Ich möchte ein ESP 8266 mit dem mqtt Adapter verbinden. Ich habe noch keinerlei Instanzen über den mqtt Adapter angelegt. Ich habe den iobroker erst seit 2 Monaten am laufen und habe anfangs eben ein bisschen ausprobiert, aber nie etwas mit dem mqtt Adapter eingebunden. Jetzt wollte ich mal versuchen ein ESP 8266 einzubinden, aber der Adapter speichert wohl "Alte" Passwörter ab auch wenn ich ihn lösche. Auch bei neu angelegten Instanzen. Nach dem speichern ist wieder ein 11 stelliges Passwort mit Sternen markiert, obwohl ich nur 6 Zeichen benutzt habe.
              Marc Berg 2 Replies Last reply Reply Quote 0
              • Marc Berg
                Marc Berg Most Active @Felix18 last edited by Marc Berg
                Wenn du da einen ESP anschließen willst, muss der Adapter als Broker konfiguriert sein.
                EDIT: Unklarheiten mit der angezeigten PW-Länge
                • Marc Berg
                  Habe das gerade ausprobiert, da stehen immer 11 Sternchen, unabhängig von der PW Länge.
                    @marc-berg vielen dank Marc Berg, es lag an dem Broker. Es funktioniert!!!
                    1000 DANK für deine hilfe!!!!!
                      Thomas Braun Most Active @Felix18 last edited by
                      Losgelöst vom Problem:
                      Halt die Kiste auf Stand, sowohl das OS:
                      Pending Updates: 13
                      wie auch den ioBroker.
                      Und schalt den Desktop aus. Hat auf einem Server nix verloren.
                        @marc-berg das hat mich immer irritiert mit dem Passwort.
                          Felix18 @Thomas Braun last edited by
                          @thomas-braun ja werde ich demnächst machen. Muss ich da irgendwas vom raspi speichern? Oder kann ich den komplett löschen und neues Betriebssytem ohne Desktop installieren?
                            Das wäre die radikale Lösung. Du kannst ihn im ersten Step aber auch nur ausschalten:
                            sudo systemctl set-default multi-user.target
                            Updates per
                            sudo apt update
                            sudo apt full-upgrade
                            sudo reboot
                              @thomas-braun bring das denn viel an freien speicher? Oder warum meinst du soll ich den Desktop runter schmeißen?
                              Müsste ich denn was speichern, wenn ich ein neues Betriebssystem auf dem raspberry installiere?
                              Thomas Braun D 2 Replies Last reply Reply Quote 0
                                Weil ein Desktop viel zu viel Overhead anschleppt.
                                Was nicht läuft kann nicht kaputt gehen, muss nicht gepflegt werden, kann
                                keine Sicherheitslücken haben und verbraucht auch keine Systemressourcen.
                                Ein Backup des ioBrokers via Backitup-Adapter reicht eigentlich aus. Andere Dienste, die parallel laufen musst du dann über deren Prozesse backuppen.
                                  darkblu @Felix18 last edited by
                                  @felix18 ,
                                  bevor du neu installierst, mach doch erstmal ein „Probe Backup“,
                                  erstellen und wieder herstellen.
                                  Sicher ist sicher.
                                    @darkblu alles klar, vielen vielen Dank Leute. Ja habe den back it up Adapter auch am laufen, und konnte den schon einmal benutzen und es hat funktioniert als meine Skripte auf einmal alle weg waren.
                                    • mcm1957
                                      mcm1957 last edited by
                                      Wenn ich das diag richtig interpretiere verwendest du ein sd Karte für deinen Raspi.
                                      In dem Fall kannst du jedenfalls die Neuinstalaltion auf anderen Karte machen. Damit kannst du zu 100% sicher sein, dass du jederzeit zurück kannst wenn was bei Backup / Restore nicht funktioniert. Einfach auf neuer Karte installieren.
                                      Und mittelfristig überleg ob nicht eine ssd sinnvoll wäre. (Ich weiß, die ssd HATs sind noch rar ...)
                                      1227
