    4. Iobroker lässt sich nicht mehr starten.
      Borkenkäfer @Homoran last edited by
      hier mal der Anfang
      2024-01-23 17:47:08.532  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Cannot install iobroker.net-tools@0.2.0: 155
      2024-01-23 17:47:09.586  - info: host.raspberrypi iobroker npm-install: exit 25
      2024-01-23 17:47:10.587  - warn: host.raspberrypi startInstance cannot find adapter "fritzdect@2.5.9". Try to install it... 1 attempt
      2024-01-23 17:47:10.588  - info: host.raspberrypi iobroker install fritzdect@2.5.9 using installedFrom
      2024-01-23 17:47:14.249  - info: host.raspberrypi iobroker npm-install: NPM version: 10.2.3
      2024-01-23 17:47:14.252  - info: host.raspberrypi iobroker npm-install: Installing iobroker.fritzdect@2.5.9... (System call)
      2024-01-23 17:50:15.627  - info: host.raspberrypi iobroker npm-install:
      2024-01-23 17:50:15.628  - info: host.raspberrypi iobroker npm-install: added 22 packages, and removed 25 packages in 3m
      2024-01-23 17:50:15.630  - info: host.raspberrypi iobroker npm-install: 73 packages are looking for funding  run `npm fund` for details
      2024-01-23 17:50:15.677  - info: host.raspberrypi iobroker npm-install: host.raspberrypi install adapter fritzdect@2.5.9
      2024-01-23 17:50:15.788  - info: host.raspberrypi iobroker npm-install: upload [5] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/admin.d.ts admin.d.ts video/mp2t
      2024-01-23 17:50:15.815  - info: host.raspberrypi iobroker npm-install: upload [4] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/fritzdect_logo.png fritzdect_logo.png image/png
      2024-01-23 17:50:15.825  - info: host.raspberrypi iobroker npm-install: upload [3] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/index_m.html index_m.html text/html
      2024-01-23 17:50:15.836  - info: host.raspberrypi iobroker npm-install: upload [2] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/jsonConfig.json jsonConfig.json application/json
      2024-01-23 17:50:15.851  - info: host.raspberrypi iobroker npm-install: upload [1] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/style.css style.css text/css
      2024-01-23 17:50:15.862  - info: host.raspberrypi iobroker npm-install: upload [0] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/words.js words.js application/javascript
      2024-01-23 17:50:15.902  - info: host.raspberrypi "system.adapter.vis.0" disabled
      2024-01-23 17:50:15.912  - info: host.raspberrypi "system.adapter.vis.0" enabled
      2024-01-23 17:50:15.915  - info: host.raspberrypi iobroker npm-install: Adapter "system.adapter.vis.0" restarted.
      2024-01-23 17:50:15.969  - info: host.raspberrypi iobroker npm-install: host.raspberrypi object system.adapter.fritzdect created/updated
      2024-01-23 17:50:17.029  - info: host.raspberrypi iobroker npm-install: exit 0
      2024-01-23 17:50:17.077  - info: host.raspberrypi instance system.adapter.fritzdect.0 started with pid 210259
      2024-01-23 17:50:18.031  - warn: host.raspberrypi startInstance cannot find adapter "web@6.1.10". Try to install it... 1 attempt
      2024-01-23 17:50:18.032  - info: host.raspberrypi iobroker install web@6.1.10 using installedFrom
      2024-01-23 17:50:19.050  - info: fritzdect.0 (210259) starting. Version 2.5.9 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v18.19.0, js-controller: 5.0.17
      2024-01-23 17:50:19.083  - info: fritzdect.0 (210259) fritzdect entered ready
      2024-01-23 17:50:19.121  - info: fritzdect.0 (210259) fritzdect uses USER: admin
      2024-01-23 17:50:19.240  - error: fritzdect.0 (210259) --------------- error calling the fritzbox -----------
      2024-01-23 17:50:19.241  - error: fritzdect.0 (210259) API msg   => error calling executeCommand
      2024-01-23 17:50:19.242  - error: fritzdect.0 (210259) API funct => login_SID
      2024-01-23 17:50:19.243  - error: fritzdect.0 (210259) no response part in returned error message
      2024-01-23 17:50:19.243  - error: fritzdect.0 (210259) API  err  => {"msg":"failed to get challenge","function":"get_sid","error":{"msg":"error http.request","function":"get_login_state","error":{"errno":-3008,"code":"ENOTFOUND","syscall":"getaddrinfo","hostname":"192.168.x.x"}}}
      2024-01-23 17:50:19.245  - error: fritzdect.0 (210259) login not possible, check user and permissions
      2024-01-23 17:50:20.812  - info: host.raspberrypi iobroker npm-install: host.raspberrypi Adapter "system.adapter.web.0" is stopped.
      2024-01-23 17:50:20.818  - info: host.raspberrypi "system.adapter.web.0" disabled
      2024-01-23 17:50:21.917  - info: host.raspberrypi iobroker npm-install: NPM version: 10.2.3
      2024-01-23 17:50:21.919  - info: host.raspberrypi iobroker npm-install: Installing iobroker.web@6.1.10... (System call)
      2024-01-23 17:50:46.063  - info: host.raspberrypi iobroker npm-install:
      2024-01-23 17:50:46.064  - info: host.raspberrypi iobroker npm-install: added 62 packages in 23s
      2024-01-23 17:50:46.065  - info: host.raspberrypi iobroker npm-install: 74 packages are looking for funding  run `npm fund` for details
      2024-01-23 17:50:46.117  - info: host.raspberrypi iobroker npm-install: host.raspberrypi install adapter web@6.1.10
      2024-01-23 17:50:47.032  - info: host.raspberrypi iobroker npm-install: upload [129] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
      2024-01-23 17:51:02.449  - info: host.raspberrypi iobroker npm-install: upload [100] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Computer.9558f6ee3941dba4e3c5.svg static/media/Computer.9558f6ee3941dba4e3c5.svg image/svg+xml
      2024-01-23 17:51:02.528  - info: host.raspberrypi iobroker npm-install: upload [90] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Dressing Room.5e6f8f64b0e8f91c473e.svg static/media/Dressing Room.5e6f8f64b0e8f91c473e.svg image/svg+xml
      2024-01-23 17:51:02.609  - info: host.raspberrypi iobroker npm-install: upload [80] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Garage.f7fc0a9b326d582afee6.svg static/media/Garage.f7fc0a9b326d582afee6.svg image/svg+xml
      2024-01-23 17:51:02.687  - info: host.raspberrypi iobroker npm-install: upload [70] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Hanging Lamps.0bd452fc843edd645c30.svg static/media/Hanging Lamps.0bd452fc843edd645c30.svg image/svg+xml
      2024-01-23 17:51:02.764  - info: host.raspberrypi iobroker npm-install: upload [60] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Led Strip.5cf2de461e29ffbaa5f0.svg static/media/Led Strip.5cf2de461e29ffbaa5f0.svg image/svg+xml
      2024-01-23 17:51:02.844  - info: host.raspberrypi iobroker npm-install: upload [50] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Nursery.9cecc0544bdb5c28500c.svg static/media/Nursery.9cecc0544bdb5c28500c.svg image/svg+xml
      2024-01-23 17:51:02.923  - info: host.raspberrypi iobroker npm-install: upload [40] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Rear Wall.38843c33f1ea1f575500.svg static/media/Rear Wall.38843c33f1ea1f575500.svg image/svg+xml
      2024-01-23 17:51:03.021  - info: host.raspberrypi iobroker npm-install: upload [30] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Sockets.8320e1a99be9de004629.svg static/media/Sockets.8320e1a99be9de004629.svg image/svg+xml
      2024-01-23 17:51:03.113  - info: host.raspberrypi iobroker npm-install: upload [20] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Terrace.d71d07d9290674f2ca20.svg static/media/Terrace.d71d07d9290674f2ca20.svg image/svg+xml
      2024-01-23 17:51:03.123  - info: host.raspberrypi iobroker npm-install: upload [19] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
      2024-01-23 17:51:03.132  - info: host.raspberrypi iobroker npm-install: upload [18] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Tv.4e9745a548e57bfac0c7.svg static/media/Tv.4e9745a548e57bfac0c7.svg image/svg+xml
      2024-01-23 17:51:03.141  - info: host.raspberrypi iobroker npm-install: upload [17] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Upstairs.441813e54e0daca0882d.svg static/media/Upstairs.441813e54e0daca0882d.svg image/svg+xml
      2024-01-23 17:51:03.150  - info: host.raspberrypi iobroker npm-install: upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg static/media/Vacuum Cleaner.9c8d50e436e6cea06dfa.svg image/svg+xml
      2024-01-23 17:51:03.158  - info: host.raspberrypi iobroker npm-install: upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Ventilation.c31761d86d67e245ac92.svg static/media/Ventilation.c31761d86d67e245ac92.svg image/svg+xml
      2024-01-23 17:51:03.167  - info: host.raspberrypi iobroker npm-install: upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Wardrobe.e8019970a2b51412cfdc.svg static/media/Wardrobe.e8019970a2b51412cfdc.svg image/svg+xml
      2024-01-23 17:51:03.177  - info: host.raspberrypi iobroker npm-install: upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Washing Machines.577f3acdb3cef002b523.svg static/media/Washing Machines.577f3acdb3cef002b523.svg image/svg+xml
      2024-01-23 17:51:03.185  - info: host.raspberrypi iobroker npm-install: upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Washroom.bfb54196f381f36de9d6.svg static/media/Washroom.bfb54196f381f36de9d6.svg image/svg+xml
      2024-01-23 17:51:03.195  - info: host.raspberrypi iobroker npm-install: upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/Water Consumption.68891649591cc2434c5b.svg static/media/Water Consumption.68891649591cc2434c5b.svg image/svg+xml
      2024-01-23 17:51:03.203  - info: host.raspberrypi iobroker npm-
        Homoran Global Moderator Administrators @Borkenkäfer last edited by
        @borkenkäfer sagte in Iobroker lässt sich nicht mehr starten.:
        die nächsten zwei
          einiger läuft schon mal wieder
          Homoran B 2 Replies Last reply Reply Quote 0
            @borkenkäfer so ein Neubau aller Adapter bei einem Restore kann auch mal gerne eine Stunde dauern.
            in der Zeit darf man nicht stören.
              Borkenkäfer @Borkenkäfer last edited by
              @borkenkäfer said in Iobroker lässt sich nicht mehr starten.:
              einiges läuft schon mal wieder
              werde weiter testen
              Melde mich
              Danke für Eure Hilfe und eure unendliche Geduld
              schönen Abend
                hallo
                iobroker scheint zu funktionieren, die Scripte laufen und vis läuft auch
                aber ich komme nicht auf die WEB seite und es ist kein admin installiert
                nach dem Befehl iobroker add admin --port 8081 0der 8089 kommt folgende meldung
                ulli@raspberrypi:/opt/iobroker $ iobroker add admin --port 8081
                NPM version: 10.2.3
                Installing iobroker.admin@6.12.0... (System call)
                Try to solve ENOTEMPTY error automatically
                Could not handle ENOTEMPTY, because no deletable files were found
                npm ERR! code ENOTEMPTY
                npm ERR! syscall rename
                npm ERR! path /opt/iobroker/node_modules/@tootallnate/once
                npm ERR! dest /opt/iobroker/node_modules/@tootallnate/.once-ZoNnWMHe
                npm ERR! errno -39
                npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/@tootallnate/once' -> '/opt/iobroker/node_modules/@tootallnate/.once-ZoNnWMHe'
                npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-24T17_00_04_975Z-debug-0.log
                host.raspberrypi Cannot install iobroker.admin@6.12.0: 217
                ulli@raspberrypi:/opt/iobroker $ iobroker add admin --port 8089
                NPM version: 10.2.3
                npm ERR! errno -39
                npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-24T17_00_32_891Z-debug-0.log
                  Thomas Braun Most Active @Borkenkäfer last edited by Thomas Braun
                  @borkenkäfer
                  iob stop
                  iob fix
                  iob add admin
                    Borkenkäfer @Thomas Braun last edited by
                    funktioniert?
                    was habe ich falsche gemacht das alles abgestürzt ist
                    danke und schönen Abend
                    B Thomas Braun 2 Replies Last reply Reply Quote 0
                      funktioniert!
                        @borkenkäfer
                        Ich kann mit deiner Frage nicht viel anfangen...
                        Funktioniert die Installation jetzt oder nicht?
                        3679
