    4. IObroker startet jeden Abend neu!
    • wendy2702
      Restart passt nicht:
      > Systemuptime and Load:
      >  19:42:08 up 14 days,
      Läuft laut log seit 14 Tagen.
        Thomas Braun Most Active @wendy2702 last edited by
        @wendy2702 sagte in IObroker startet jeden Abend neu!:
        Das System vielleicht. Ich vermute, der ioBroker wird als 'nicht lebenswichtig' aufgrund von zu wenig RAM vom Kernel abgeschossen.
        wendy2702 N 2 Replies Last reply Reply Quote 0
        • wendy2702
          wendy2702 @Thomas Braun last edited by
          @thomas-braun Sorry, hatte es so verstanden das die Maschine neu startet.
          • N
            norman @Thomas Braun last edited by
            meinst du so:
            Skript v.2023-10-10
            *** BASE SYSTEM ***
             Static hostname: raspi
                   Icon name: computer
                      Kernel: Linux 6.1.0-rpi7-rpi-v8
                Architecture: arm64
            Model           : Raspberry Pi 4 Model B Rev 1.1
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : arm64
             19:56:24 up 14 days,  1:24,  2 users,  load average: 0.39, 0.52, 0.52
            CPU threads: 4
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            *** Time and Time Zones ***
                           Local time: Sun 2024-01-21 19:56:24 CET
                       Universal time: Sun 2024-01-21 18:56:24 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** User and Groups ***
            pi
            /home/pi
            pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:       tty
            Boot Target:    multi-user.target
            *** MEMORY ***
            Mem:            1.9G        1.4G        292M        225K        349M        569M
            Swap:           104M         21M         83M
            Total:          2.0G        1.4G        375M
                     1848 M total memory
                     1304 M used memory
                      377 M active memory
                     1060 M inactive memory
                      278 M free memory
                       21 M buffer memory
                      311 M swap cache
                       99 M total swap
                       20 M used swap
                       79 M free swap
            Raspberry only:
            oom events: 0
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** FILESYSTEM ***
            udev           devtmpfs  661M     0  661M   0% /dev
            tmpfs          tmpfs     185M  1.2M  184M   1% /run
            /dev/mmcblk0p2 ext4       59G  4.5G   51G   9% /
            tmpfs          tmpfs     925M     0  925M   0% /dev/shm
            /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
            tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
            TARGET           SOURCE         FSTYPE OPTIONS
            /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
            `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            956M    /var/
            490M    /var/log
            489M    /var/log/journal/646f283dbad041b98afadc09481d9d55
            202M    /var/cache
            Archived and active journals take up 488.8M in the file system.
            /opt/iobroker/backups:
            28M     /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            342M    /opt/iobroker/iobroker-data/
            223M    /opt/iobroker/iobroker-data/files
            76M     /opt/iobroker/iobroker-data/backup-objects
            67M     /opt/iobroker/iobroker-data/files/javascript.admin
            48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
            41M     /opt/iobroker/iobroker-data/objects.jsonl
            33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
            21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
            8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
            8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
            USB-Devices by-id:
            /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B00193675CD-if00
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v18.19.0
            /usr/bin/node           v18.19.0
            /usr/bin/npm            10.2.3
            /usr/bin/npx            10.2.3
            /usr/bin/corepack       0.22.0
            nodejs:
              Installed: 18.19.0-1nodesource1
              Candidate: 18.19.0-1nodesource1
              Version table:
                 18.19.0+dfsg-6~deb12u1 500
             *** 18.19.0-1nodesource1 1001
                    100 /var/lib/dpkg/status
                 18.18.2-1nodesource1 1001
                 18.18.1-1nodesource1 1001
                 18.18.0-1nodesource1 1001
                 18.17.1-1nodesource1 1001
                 18.17.0-1nodesource1 1001
                 18.16.1-1nodesource1 1001
                 18.16.0-1nodesource1 1001
                 18.15.0-1nodesource1 1001
                 18.14.2-1nodesource1 1001
                 18.14.1-1nodesource1 1001
                 18.14.0-1nodesource1 1001
                 18.13.0+dfsg1-1 500
                 18.13.0-1nodesource1 1001
                 18.12.0-1nodesource1 1001
                 18.11.0-1nodesource1 1001
                 18.10.0-1nodesource1 1001
                 18.9.1-1nodesource1 1001
                 18.9.0-1nodesource1 1001
                 18.8.0-1nodesource1 1001
                 18.7.0-1nodesource1 1001
                 18.6.0-1nodesource1 1001
                 18.5.0-1nodesource1 1001
                 18.4.0-1nodesource1 1001
                 18.3.0-1nodesource1 1001
                 18.2.0-1nodesource1 1001
                 18.1.0-1nodesource1 1001
                 18.0.0-1nodesource1 1001
            No problems detected
            Errors in npm tree:
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: redis
            Core adapters versions
            js-controller:  5.0.17
            admin:          6.12.0
            javascript:     7.1.6
            Adapters from github:   2
            Adapter State
            + system.adapter.admin.0                  : admin                 : raspi                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.alexa2.0                 : alexa2                : raspi                                    -  enabled
              system.adapter.backitup.0               : backitup              : raspi                                    - disabled
            + system.adapter.evohome.0                : evohome               : raspi                                    -  enabled
              system.adapter.flot.0                   : flot                  : raspi                                    - disabled
            + system.adapter.growatt.0                : growatt               : raspi                                    -  enabled
            + system.adapter.history.0                : history               : raspi                                    -  enabled
            + system.adapter.hs100.0                  : hs100                 : raspi                                    -  enabled
              system.adapter.ical.0                   : ical                  : raspi                                    -  enabled
              system.adapter.ical.1                   : ical                  : raspi                                    -  enabled
              system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspi                                    - disabled
            + system.adapter.info.0                   : info                  : raspi                                    -  enabled
            + system.adapter.iot.0                    : iot                   : raspi                                    -  enabled
            + system.adapter.javascript.0             : javascript            : raspi                                    -  enabled
            + system.adapter.lgtv.0                   : lgtv                  : raspi                                    -  enabled
              system.adapter.mobile.0                 : mobile                : raspi                                    - disabled
            + system.adapter.mqtt.0                   : mqtt                  : raspi                                    -  enabled, port: 1884, bind: 192.168.178.60
              system.adapter.openweathermap.0         : openweathermap        : raspi                                    -  enabled
            + system.adapter.ring.0                   : ring                  : raspi                                    -  enabled
            + system.adapter.rpi2.0                   : rpi2                  : raspi                                    -  enabled
              system.adapter.socketio.0               : socketio              : raspi                                    - disabled, port: 8084, bind: 0.0.0.0, run as: admin
            + system.adapter.sonoff.0                 : sonoff                : raspi                                    -  enabled, port: 1883, bind: 0.0.0.0
            + system.adapter.tr-064.1                 : tr-064                : raspi                                    -  enabled
              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspi                                    - disabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspi                                    - disabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : raspi                                    - disabled
              system.adapter.vis-inventwo.0           : vis-inventwo          : raspi                                    - disabled
              system.adapter.vis-justgage.0           : vis-justgage          : raspi                                    - disabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspi                                    - disabled
              system.adapter.vis.0                    : vis                   : raspi                                    -  enabled
              system.adapter.wallpanel.0              : wallpanel             : raspi                                    - disabled
            + system.adapter.web.0                    : web                   : raspi                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              system.adapter.web.1                    : web                   : raspi                                    - disabled, port: 20002, bind: 0.0.0.0, run as: admin
            + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspi                                    -  enabled
              system.adapter.ws.0                     : ws                    : raspi                                    - disabled, port: 8084, bind: 0.0.0.0, run as: admin
            + system.adapter.zigbee.0                 : zigbee                : raspi                                    -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B00193675CD-if00
            + instance is alive
            ioBroker-Repositories
            stabil        : http://download.iobroker.net/sources-dist.json
            Active repo(s): stabil
            Installed ioBroker-Instances
            Used repository: stabil
            Adapter    "admin"        : 6.12.0   , installed 6.12.0
            Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
            Adapter    "backitup"     : 2.9.8    , installed 2.9.8
            Adapter    "growatt"      : 3.2.1    , installed 3.2.1
            Adapter    "hs100"        : 2.2.0    , installed 2.2.0
            Adapter    "icons-mfd-png": 1.2.1    , installed 1.1.0  [Updatable]
            Adapter    "iot"          : 2.0.11   , installed 2.0.11
            Adapter    "javascript"   : 7.1.6    , installed 7.1.6
            Controller "js-controller": 5.0.17   , installed 5.0.17
            Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
            Adapter    "mobile"       : 1.0.1    , installed 1.0.1
            Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
            Adapter    "openweathermap": 1.0.4   , installed 0.4.5  [Updatable]
            Adapter    "ring"         : 5.0.10   , installed 5.0.10
            Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
            Adapter    "vis-hqwidgets": 1.4.0    , installed 1.1.9  [Updatable]
            Adapter    "vis-icontwo"  : 1.3.0    , installed 0.89.0 [Updatable]
            Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.1  [Updatable]
            Adapter    "vis-justgage" : 2.1.0    , installed 1.0.2  [Updatable]
            Adapter    "vis-timeandweather": 1.2.2, installed 1.1.7 [Updatable]
            Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
            Adapter    "web"          : 6.1.10   , installed 6.1.10
            Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
            Adapter    "ws"           : 2.5.8    , installed 2.5.8
            Adapter    "zigbee"       : 1.10.1   , installed 1.9.5  [Updatable]
            Objects and States
            Objects:        6083
            States:         16948
            Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
            Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
            Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
            Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
            Reading package lists...
            Pending Updates: 5
            *** Listening Ports ***
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15801      653/sshd: /usr/sbin
            tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      106        16411      627/redis-server 12
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       12224465   533020/iobroker.js-
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       12228465   534012/io.sonoff.0
            tcp        0      0 192.168.178.60:1884     0.0.0.0:*               LISTEN      1001       12228375   533933/io.mqtt.0
            tcp        0      0 192.168.178.60:1885     0.0.0.0:*               LISTEN      1001       12228376   533933/io.mqtt.0
            tcp6       0      0 :::22                   :::*                    LISTEN      0          15803      653/sshd: /usr/sbin
            tcp6       0      0 ::1:6379                :::*                    LISTEN      106        16412      627/redis-server 12
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       12232145   534743/io.web.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       12226506   533038/io.admin.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        13647      412/avahi-daemon: r
            udp        0      0 0.0.0.0:37662           0.0.0.0:*                           104        13649      412/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                104        13648      412/avahi-daemon: r
            udp6       0      0 :::46445                :::*                                104        13650      412/avahi-daemon: r
            udp6       0      0 fe80::c189:98ca:96e:546 :::*                                0          16472      477/NetworkManager
            2024-01-21 19:44:49.088  - info: info.0 (534111) cpu Temp res = {"main":47.712,"cores":[],"max":47.712,"socket":[],"chipset":null}
            2024-01-21 19:44:49.312  - info: iot.0 (534161) Connection changed: connect "info_mediaevent24_de"
            2024-01-21 19:44:49.682  - info: info.0 (534111) State value to set for "info.0.sysinfo.memory.memLayout.ram0.clockSpeed" has to be type "string" but received type "number"
            2024-01-21 19:44:50.424  - info: host.raspi instance system.adapter.ring.0 started with pid 534301
            2024-01-21 19:44:50.731  - info: lgtv.0 (534172) starting. Version 2.1.2 in /opt/iobroker/node_modules/iobroker.lgtv, node: v18.19.0, js-controller: 5.0.17
            2024-01-21 19:44:51.001  - info: lgtv.0 (534172) Ready. Configured WebOS TV IP: 192.168.178.56
            2024-01-21 19:44:55.048  - info: info.0 (534111) State value to set for "info.0.sysinfo.disks.diskLayout.dev0.size" has to be type "string" but received type "number"
            2024-01-21 19:44:58.472  - info: host.raspi instance system.adapter.web.0 started with pid 534743
            2024-01-21 19:44:58.854  - info: vis.0 (534583) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
            2024-01-21 19:45:01.370  - info: vis.0 (534583) Terminated (NO_ERROR): Without reason
            2024-01-21 19:45:02.095  - info: host.raspi instance system.adapter.vis.0 terminated while should be started once
            2024-01-21 19:45:04.551  - info: ring.0 (534301) starting. Version 5.0.10 (non-npm: iobroker-community-adapters/ioBroker.ring) in /opt/iobroker/node_modules/iobroker.ring, node: v18.19.0, js-controller: 5.0.17
            2024-01-21 19:45:04.603  - info: ring.0 (534301) Initializing Api Client
            2024-01-21 19:45:05.483  - info: ring.0 (534301) Received new Refresh Token. Will use the new one until the token in config gets changed
            2024-01-21 19:45:06.926  - info: ring.0 (534301) Get sunset and sunrise
            2024-01-21 19:45:07.011  - info: ring.0 (534301) Daily sun parameter calculation scheduled for 00:00:25
            2024-01-21 19:45:16.762  - info: alexa2.0 (533309) Subscribing to states...
            2024-01-21 19:45:16.772  - info: alexa2.0 (533309) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
            2024-01-21 19:45:18.526  - info: alexa2.0 (533309) Alexa-Push-Connection (macDms = true) established. Disable Polling
            2024-01-21 19:45:31.828  - info: alexa2.0 (533309) Initialization Done ...
            2024-01-21 19:46:31.428  - warn: sonoff.0 (534012) Client "" not connected
            2024-01-21 19:46:38.946  - warn: sonoff.0 (534012) Client "" not connected
            2024-01-21 19:47:24.048  - warn: sonoff.0 (534012) Client "" not connected
            2024-01-21 19:50:54.596  - warn: sonoff.0 (534012) Client "" not connected
            2024-01-21 19:54:14.031  - warn: sonoff.0 (534012) Client "" not connected
              Homoran Global Moderator Administrators @norman last edited by
              @norman sagte in IObroker startet jeden Abend neu!:
              Das System hab ich ganz regulär nach Anleitung gemacht,
              nach welcher?
              weil die SD-Karte gecrasht war
              hoffentlich jetzt auf einer neuen Karte
              Was läuft da noch drauf?
                Thomas Braun Most Active @norman last edited by
                @norman
                Hau die Updates rein.
                sudo apt update
                sudo apt full-upgrade
                sudo reboot
                iob update
                iob upgrade all
                • N
                  Update nach deinen Kommandos durchgeschossen, bin mal gespannt wie er sich heute verhält.
                  ich geb mal Rückmeldung.
                  Soll ich zusätzlich nochmal den Fixer drüber schicken?
                  • N
                    norman @norman last edited by
                    So, nach anderthalb Tagen Testlauf kann ich nun sagen, is noch schlimmer wie vorher.
                    Vorher startete nur IO neu, jetzt bleibt der ganze Raspi hängen und muss über Hard-Reset neu gestartet werden. 😞
                    Und das sogar gestern 2x am Tag.
                    Man muss doch irgendwie herausfinden können, woran das liegt 😞 kann man nicht irgendwo gespeicherte Logs ziehen oder so??
                    In der iob diag schreibt er auch irgendwas von "Error in NPM tree"
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : arm64
                     19:11:38 up 5 min,  2 users,  load average: 0.35, 0.68, 0.39
                    CPU threads: 4
                    Current issues:
                                   Local time: Wed 2024-01-24 19:11:38 CET
                               Universal time: Wed 2024-01-24 18:11:38 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            1.9G        1.3G        347M        1.2M        334M        607M
                    Swap:           104M          0B        104M
                    Total:          2.0G        1.3G        452M
                             1848 M total memory
                             1268 M used memory
                             1282 M active memory
                              123 M inactive memory
                              330 M free memory
                               24 M buffer memory
                              294 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /dev/mmcblk0p2 ext4       59G  4.8G   51G   9% /
                    [Wed Jan 24 19:06:02 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:2A:EE:F4 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c7af47fd-02 rootfstype=ext4 fsck.repair=yes rootwait
                    [Wed Jan 24 19:06:05 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                    [Wed Jan 24 19:06:07 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                    /var:
                    1.1G    /var/
                    611M    /var/log
                    609M    /var/log/journal/646f283dbad041b98afadc09481d9d55
                    203M    /var/cache
                    Archived and active journals take up 608.8M in the file system.
                    343M    /opt/iobroker/iobroker-data/
                    224M    /opt/iobroker/iobroker-data/files
                    42M     /opt/iobroker/iobroker-data/objects.jsonl
                    USB-Devices by-id:
                    /usr/bin/npm            10.2.3
                    /usr/bin/npx            10.2.3
                    nodejs:
                      Version table:
                         18.13.0+dfsg1-1 500
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: redis
                    admin:          6.12.0
                    javascript:     7.1.6
                    Adapter State
                    + instance is alive
                    Adapter    "openweathermap": 1.0.4   , installed 1.0.4
                    Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
                    Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
                    Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
                    Objects and States
                    Objects:        6085
                    States:         16953
                    Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Hit:5 http://archive.raspberrypi.com/debian bookworm InRelease
                    Pending Updates: 7
                    tcp        0      0 192.168.178.60:1884     0.0.0.0:*               LISTEN      1001       16654      906/io.mqtt.0
                    tcp        0      0 192.168.178.60:1885     0.0.0.0:*               LISTEN      1001       16655      906/io.mqtt.0
                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       12210      996/io.sonoff.0
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16465      696/iobroker.js-con
                    tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      106        13880      613/redis-server 12
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13837      652/sshd: /usr/sbin
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21580      1701/io.web.0
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       12017      785/io.admin.0
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          13839      652/sshd: /usr/sbin
                    tcp6       0      0 ::1:6379                :::*                    LISTEN      106        13881      613/redis-server 12
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        13770      453/avahi-daemon: r
                    udp        0      0 0.0.0.0:36397           0.0.0.0:*                           104        13772      453/avahi-daemon: r
                    udp6       0      0 :::60534                :::*                                104        13773      453/avahi-daemon: r
                    udp6       0      0 :::5353                 :::*                                104        13771      453/avahi-daemon: r
                    udp6       0      0 fe80::c189:98ca:96e:546 :::*                                0          13959      539/NetworkManager
                    2024-01-24 19:07:31.532  - info: info.0 (1087) cpu Temp res = {"main":53.069,"cores":[],"max":53.069,"socket":[],"chipset":null}
                    2024-01-24 19:07:31.933  - info: info.0 (1087) State value to set for "info.0.sysinfo.memory.memLayout.ram0.clockSpeed" has to be type "string" but received type "number"
                    2024-01-24 19:07:32.682  - info: host.raspi instance system.adapter.lgtv.0 started with pid 1233
                    2024-01-24 19:07:32.998  - info: iot.0 (1110) starting. Version 2.0.11 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.17
                    2024-01-24 19:07:33.292  - info: iot.0 (1110) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                    2024-01-24 19:07:34.478  - info: iot.0 (1110) Connection changed: connect "info_mediaevent24_de"
                    2024-01-24 19:07:36.233  - info: info.0 (1087) State value to set for "info.0.sysinfo.disks.diskLayout.dev0.size" has to be type "string" but received type "number"
                    2024-01-24 19:07:36.507  - info: lgtv.0 (1233) starting. Version 2.1.2 in /opt/iobroker/node_modules/iobroker.lgtv, node: v18.19.0, js-controller: 5.0.17
                    2024-01-24 19:07:36.685  - info: host.raspi instance system.adapter.ring.0 started with pid 1508
                    2024-01-24 19:07:36.746  - info: lgtv.0 (1233) Ready. Configured WebOS TV IP: 192.168.178.56
                    2024-01-24 19:07:43.082  - info: vis.0 (1686) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
                    2024-01-24 19:07:44.691  - info: host.raspi instance system.adapter.web.0 started with pid 1701
                    2024-01-24 19:07:44.805  - info: vis.0 (1686) Terminated (NO_ERROR): Without reason
                    2024-01-24 19:07:45.471  - info: host.raspi instance system.adapter.vis.0 terminated while should be started once
                    2024-01-24 19:07:45.698  - info: ring.0 (1508) starting. Version 5.0.10 (non-npm: iobroker-community-adapters/ioBroker.ring) in /opt/iobroker/node_modules/iobroker.ring, node: v18.19.0, js-controller: 5.0.17
                    2024-01-24 19:07:45.763  - info: ring.0 (1508) Initializing Api Client
                    2024-01-24 19:07:46.476  - info: ring.0 (1508) Received new Refresh Token. Will use the new one until the token in config gets changed
                    2024-01-24 19:07:48.002  - info: ring.0 (1508) Get sunset and sunrise
                    2024-01-24 19:07:48.070  - info: ring.0 (1508) Daily sun parameter calculation scheduled for 00:00:37
                    2024-01-24 19:07:54.417  - warn: sonoff.0 (996) Client "" not connected
                    2024-01-24 19:07:54.517  - warn: sonoff.0 (996) Client "" not connected
                    2024-01-24 19:08:10.184  - info: alexa2.0 (932) Subscribing to states...
                    2024-01-24 19:08:10.191  - info: alexa2.0 (932) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
                    2024-01-24 19:08:12.068  - info: alexa2.0 (932) Alexa-Push-Connection (macDms = true) established. Disable Polling
                    2024-01-24 19:08:25.834  - info: alexa2.0 (932) Initialization Done ...
                    Im Summary, das danach automatisch erstellt wird sind auch rote Errors bei NPM:
                                            v.2023-10-10
                    Kernel          : aarch64
                    Userland        : arm64
                    CPU threads: 4
                    Current issues:
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    pi
                    /home/pi
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Swap:           104M          0B        104M
                             1848 M total memory
                             1268 M used memory
                              330 M free memory
                               24 M buffer memory
                              294 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    /var:
                    1.1G    /var/
                    611M    /var/log
                    203M    /var/cache
                    33M     /opt/iobroker/iobroker-data/files/iot.admin/stat Static hostname: raspi
                           Icon name: computer
                        Architecture: arm64
                    Installation:           native
                    Kernel:                 aarch64
                    Userland:               arm64
                    Timezone:               Europe/Berlin (CET, +0100)
                    User-ID:                1000
                    X-Server:               false
                    Pending OS-Updates:     7
                    Pending iob updates:    0
                    Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                            /usr/bin/npm            10.2.3
                                            /usr/bin/npx            10.2.3
                    Recommended versions are nodejs 18.19.0 and npm 10.2.3
                    MEMORY:
                    Mem:            1.9G        1.4G        165M        1.2M        436M        529M
                    Swap:           104M          0B        104M
                    Total:          2.0G        1.4G        270M
                    Active iob-Instances:   19
                    ioBroker Core:          js-controller           5.0.17
                                            admin                   6.12.0
                    Objects type: jsonl
                    States  type: redis
                    Objects:                6085
                    States:                 16953
                    Size of iob-Database:
                    68K     /opt/iobroker/iobroker-data/states.jsonl
                    === Mark text until here for copying ===
                    pi@raspi:~ $ ======== Start marking the full check here =========
                    -bash: ========: command not found
                    pi@raspi:~ $
                    pi@raspi:~ $ ```
                    > Skript v.2023-10-10
                    > *** BASE SYSTEM ***
                    >        Icon name: computer
                    > Operating System: Debian GNU/Linux 12 (bookworm)
                    >     Architecture: arm64
                    > Docker          : false
                    > Kernel          : aarch64
                    > Userland        : arm64
                    > CPU threads: 4
                    > Current issues:
                    > No throttling issues detected.
                    >                  RTC time: n/a
                    >                 Time zone: Europe/Berlin (CET, +0100)
                    > System clock synchronized: yes
                    >               NTP service: active
                    >           RTC in local TZ: no
                    > pi
                    > /home/pi
                    > X-Server:       false
                    > Desktop:
                    > Terminal:       tty
                    > *** MEMORY ***
                    >                total        used        free      shared  buff/cache   available
                    > Swap:           104M          0B        104M
                    >          1848 M total memory
                    >          1268 M used memory
                    >           330 M free memory
                    >            24 M buffer memory
                    >           294 M swap cache
                    >            99 M total swap
                    >             0 M used swap
                    >            99 M free swap
                    > Raspberry only:
                    > oom events: 0
                    > lifetime oom required: 0 Mbytes
                    > total time in oom handler: 0 ms
                    > max time spent in oom handler: 0 ms
                    >   UNIT LOAD ACTIVE SUB DESCRIPTION
                    > *** FILESYSTEM ***
                    > Filesystem     Type      Size  Used Avail Use% Mounted on
                    > tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                    > Messages concerning ext4 filesystem in dmesg:
                    > Show mounted filesystems \(real ones only\):
                    -bash: Skript: command not found
                    -bash: Abfall2024.ics: command not found
                    -bash: Static: command not found
                    -bash: Icon: command not found
                    -bash: command substitution: line 7: syntax error near unexpected token `('
                    -bash: command substitution: line 7: `Operating System: Debian GNU/Linux 12 (bookworm)'
                    -bash: -/boot/firmware: No such file or directory
                    pi@raspi:~ $
                    pi@raspi:~ $ Files in neuralgic directories:
                    -bash: Files: command not found
                    pi@raspi:~ $
                    pi@raspi:~ $ /var:
                    -bash: /var:: No such file or directory
                    pi@raspi:~ $ 1.1G    /var/
                    -bash: 1.1G: command not found
                    pi@raspi:~ $ 611M    /var/log
                    -bash: 611M: command not found
                    pi@raspi:~ $ 609M    /var/log/journal/646f283dbad041b98afadc09481d9d55
                    -bash: 609M: command not found
                    pi@raspi:~ $ 203M    /var/cache
                    -bash: 203M: command not found
                    pi@raspi:~ $
                    pi@raspi:~ $ Archived and active journals take up 608.8M in the file system.
                    -bash: Archived: command not found
                    pi@raspi:~ $
                    pi@raspi:~ $ /opt/iobroker/backups:
                    -bash: /opt/iobroker/backups:: No such file or directory
                    pi@raspi:~ $ 28M     /opt/iobroker/backups/
                    -bash: 28M: command not found
                    pi@raspi:~ $
                    pi@raspi:~ $ /opt/iobroker/iobroker-data:
                    -bash: /opt/iobroker/iobroker-data:: No such file or directory
                    pi@raspi:~ $ 343M    /opt/iobroker/iobroker-data/
                    -bash: 343M: command not found
                    pi@raspi:~ $ 224M    /opt/iobroker/iobroker-data/files
                    -bash: 224M: command not found
                    pi@raspi:~ $ 76M     /opt/iobroker/iobroker-data/backup-objects
                    -bash: 76M: command not found
                    pi@raspi:~ $ 67M     /opt/iobroker/iobroker-data/files/javascript.admin
                    -bash: 67M: command not found
                    pi@raspi:~ $ 48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                    -bash: 48M: command not found
                    pi@raspi:~ $
                    pi@raspi:~ $ The five largest files in iobroker-data are:
                    -bash: The: command not found
                    pi@raspi:~ $ 42M     /opt/iobroker/iobroker-data/objects.jsonl
                    -bash: 42M: command not found
                    pi@raspi:~ $ 33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                    -bash: 33M: command not found
                    pi@raspi:~ $ 21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                    -bash: 21M: command not found
                    pi@raspi:~ $ 8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
                    -bash: 8.5M: command not found
                    pi@raspi:~ $ 8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
                    -bash: 8.3M: command not found
                    pi@raspi:~ $
                    pi@raspi:~ $ USB-Devices by-id:
                    -bash: USB-Devices: command not found
                    pi@raspi:~ $ USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
                    -bash: USB-Sticks: command not found
                    pi@raspi:~ $
                    pi@raspi:~ $ /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B00193675CD-if00
                    -bash: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B00193675CD-if00: Permission denied
                    pi@raspi:~ $
                    pi@raspi:~ $ *** NodeJS-Installation ***
                    pi@raspi:~ $
                    pi@raspi:~ $ /usr/bin/nodejs         v18.19.0
                    node:internal/modules/cjs/loader:1137
                      throw err;
                    Error: Cannot find module '/home/pi/v18.19.0'
                        at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
                        at Module._load (node:internal/modules/cjs/loader:975:27)
                        at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                        at node:internal/main/run_main_module:28:49 {
                      code: 'MODULE_NOT_FOUND',
                      requireStack: []
                    Node.js v18.19.0
                    pi@raspi:~ $ /usr/bin/node           v18.19.0
                      throw err;
                      requireStack: []
                    Node.js v18.19.0
                    pi@raspi:~ $ /usr/bin/npm            10.2.3
                    Unknown command: "10.2.3"
                    To see a list of supported npm commands, run:
                      npm help
                    pi@raspi:~ $ /usr/bin/npx            10.2.3
                    npm ERR! code E404
                    npm ERR! 404 Not Found - GET https://registry.npmjs.org/10.2.3 - Not found
                    npm ERR! 404
                    npm ERR! 404  '10.2.3@*' is not in this registry.
                    npm ERR! 404
                    npm ERR! 404 Note that you can also install from a
                    npm ERR! 404 tarball, folder, http url, or git url.
                    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-01-24T18_14_59_263Z-debug-0.log
                    pi@raspi:~ $ /usr/bin/corepack       0.22.0
                    Unknown Syntax Error: Command not found; did you mean one of:
                      0. corepack -h
                      1. corepack -v
                      2. corepack disable [--install-directory #0] ...
                      3. corepack enable [--install-directory #0] ...
                      4. corepack install <-g,--global> [--all] [--cache-only] ...
                      5. corepack install
                      6. corepack pack [--all] [--json] [-o,--output #0] ...
                      7. corepack up
                      8. corepack use <pattern>
                      9. corepack hydrate [--activate] <fileName>
                     10. corepack prepare [--activate] [--all] [--json] [-o,--output] ...
                    While running 0.22.0
                    pi@raspi:~ $
                    pi@raspi:~ $
                    pi@raspi:~ $ nodejs:
                    -bash: nodejs:: command not found
                    pi@raspi:~ $   Installed: 18.19.0-1nodesource1
                    -bash: Installed:: command not found
                    pi@raspi:~ $   Candidate: 18.19.0-1nodesource1
                    -bash: Candidate:: command not found
                    pi@raspi:~ $   Version table:
                    -bash: Version: command not found
                    pi@raspi:~ $      18.19.0+dfsg-6~deb12u1 500
                    -bash: 18.19.0+dfsg-6~deb12u1: command not found
                    pi@raspi:~ $         500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                    -bash: 500: command not found
                    pi@raspi:~ $  *** 18.19.0-1nodesource1 1001
                    pi@raspi:~ $         500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                    pi@raspi:~ $         100 /var/lib/dpkg/status
                    -bash: 100: command not found
                    pi@raspi:~ $      18.18.2-1nodesource1 1001
                    -bash: 18.18.2-1nodesource1: command not found
                    pi@raspi:~ $      18.18.1-1nodesource1 1001
                    -bash: 18.18.1-1nodesource1: command not found
                    pi@raspi:~ $      18.18.0-1nodesource1 1001
                    -bash: 18.18.0-1nodesource1: command not found
                    pi@raspi:~ $      18.17.1-1nodesource1 1001
                    -bash: 18.17.1-1nodesource1: command not found
                    pi@raspi:~ $      18.17.0-1nodesource1 1001
                    -bash: 18.17.0-1nodesource1: command not found
                          : raspi                                    - disabled
                    + system.adapter.i-bash: 500: command not found
                    pi@raspi:~ $      18.16.1-1nodesource1 1001
                    -bash: 18.16.1-1nodesource1: command not found
                    pi@raspi:~ $      18.16.0-1nodesource1 1001
                    -bash: 18.16.0-1nodesource1: command not found
                    pi@raspi:~ $      18.15.0-1nodesource1 1001
                    -bash: 18.15.0-1nodesource1: command not found
                    pi@raspi:~ $      18.14.2-1nodesource1 1001
                    -bash: 18.14.2-1nodesource1: command not found
                    pi@raspi:~ $      18.14.1-1nodesource1 1001
                    -bash: 18.14.1-1nodesource1: command not found
                    pi@raspi:~ $      18.14.0-1nodesource1 1001
                    -bash: 18.14.0-1nodesource1: command not found
                    pi@raspi:~ $      18.13.0+dfsg1-1 500
                    -bash: 18.13.0+dfsg1-1: command not found
                    pi@raspi:~ $         500 http://deb.debian.org/debian bookworm/main arm64 Packages
                    pi@raspi:~ $      18.13.0-1nodesource1 1001
                    -bash: 18.13.0-1nodesource1: command not found
                    pi@raspi:~ $      18.12.0-1nodesource1 1001
                    -bash: 18.12.0-1nodesource1: command not found
                    pi@raspi:~ $      18.11.0-1nodesource1 1001
                    -bash: 18.11.0-1nodesource1: command not found
                    pi@raspi:~ $      18.10.0-1nodesource1 1001
                    -bash: 18.10.0-1nodesource1: command not found
                    pi@raspi:~ $      18.9.1-1nodesource1 1001
                    -bash: 18.9.1-1nodesource1: command not found
                    pi@raspi:~ $      18.9.0-1nodesource1 1001
                    -bash: 18.9.0-1nodesource1: command not found
                    pi@raspi:~ $      18.8.0-1nodesource1 1001
                    -bash: 18.8.0-1nodesource1: command not found
                    pi@raspi:~ $      18.7.0-1nodesource1 1001
                    -bash: 18.7.0-1nodesource1: command not found
                    pi@raspi:~ $      18.6.0-1nodesource1 1001
                    -bash: 18.6.0-1nodesource1: command not found
                    pi@raspi:~ $      18.5.0-1nodesource1 1001
                    -bash: 18.5.0-1nodesource1: command not found
                    pi@raspi:~ $      18.4.0-1nodesource1 1001
                    -bash: 18.4.0-1nodesource1: command not found
                    pi@raspi:~ $      18.3.0-1nodesource1 1001
                    -bash: 18.3.0-1nodesource1: command not found
                    pi@raspi:~ $      18.2.0-1nodesource1 1001
                    -bash: 18.2.0-1nodesource1: command not found
                    pi@raspi:~ $      18.1.0-1nodesource1 1001
                    -bash: 18.1.0-1nodesource1: command not found
                    pi@raspi:~ $      18.0.0-1nodesource1 1001
                    -bash: 18.0.0-1nodesource1: command not found
                    pi@raspi:~ $
                    pi@raspi:~ $ Temp directories causing npm8 problem: 0
                    -bash: Temp: command not found
                    pi@raspi:~ $ No problems detected
                    -bash: No: command not found
                    pi@raspi:~ $
                    pi@raspi:~ $ Errors in npm tree:
                    -bash: Errors: command not found
                    pi@raspi:~ $
                    pi@raspi:~ $ *** ioBroker-Installation ***
                    pi@raspi:~ $
                    pi@raspi:~ $ ioBroker Status
                    -bash: ioBroker: command not found
                    pi@raspi:~ $ iobroker is running on this host.
                    Objects type: jsonl
                    States  type: redis
                    admin:          6.12.0
                    javascript:     7.1.6
                    Adapter State
                    + system.adapter.web.0                    : web       iobroker [command]
                    Commands:
                      iobroker setup                                               Setup ioBroker
                      iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
                      iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
                      iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
                      iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
                      iobroker info                                                Shows the host info
                      iobroker logs [<adapter>]                                    Monitor log
                      iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
                      iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
                      iobroker rebuild [<module>]                                  Rebuild all native modules or path
                      iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
                      iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
                      iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
                      iobroker update [<repositoryUrl>]                            Update repository and list adapters
                      iobroker upgrade                                             Upgrade management
                      iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
                      iobroker object                                              Object management  [aliases: o]
                      iobroker state                                               State management  [aliases: s]
                      iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
                      iobroker list <type> [<filter>]                              List all entries, like objects
                      iobroker chmod <mode> <file>                                 Change file rights
                      iobroker chown <user> <group> <file>                         Change file ownership
                      iobroker touch <file>                                        Touch file
                      iobroker rm <file>                                           Remove file
                      iobroker file                                                File management
                      iobroker user                                                User commands
                      iobroker group                                               group management
                      iobroker host <hostname>                                     Set host to given hostname
                      iobroker set <adapter>.<instance>                            Change settings of adapter config
                      iobroker license <license.file or license.text>              Update license by given file
                      iobroker cert                                                Certificate management
                      iobroker clean <yes>                                         Clears all objects and states
                      iobroker backup                                              Create backup
                      iobroker restore <backup name or path>                       Restore a specified backup
                      iobroker validate <backup name or path>                      Validate a specified backup
                      iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
                      iobroker repo [<name>]                                       Show repo information
                      iobroker uuid                                                Show uuid of the installation  [aliases: id]
                      iobroker unsetup                                             Reset license, installation secret and language
                      iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
                      iobroker nodejs-update [<major-version>]                     Upgrade the Node.JS installation to the current LTS
                      iobroker multihost                                           Multihost management
                      iobroker compact                                             compact group management
                      iobroker plugin                                              Plugin management
                      iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
                      iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
                    Options:
                      --help  Show help  [boolean]
                    pi@raspi:~ $
                    Blickt da einer genau durch??
                      Nein. Aber du hast auch irgendwas wirres in die Konsole geklatscht und das führt dann zu dem chaotischen Output.
                      Also nochmal sauber die Ausgabe von iob diag bitte.
                      N 1 Reply Last reply Reply Quote -1
                        JohnnyBahama last edited by JohnnyBahama
                        Bevor weiter rumprobiert wird, es ist derArbeitsspeicher. Der reicht nicht mehr. Mein System lief vorher auch Jahre, aber seit dem letztem Admin Update stürzte der immer wieder ab, auch wenn andere sagen das kann damit nichts zu tun haben.
                        Neue Kiste mit mehr Arbeitsspeicher und läuft jetzt wieder seit 50 Tagen ohne Ausfälle.
                        Kannst dir meinen Thread dazu anschauen, hat die gleichen Werte ausgeworfen
                        https://forum.iobroker.net/topic/68713/gelöst-admin-adapter-restart-loop/3
                        wendy2702 N 2 Replies Last reply Reply Quote 1
                        • wendy2702
                          wendy2702 @JohnnyBahama last edited by
                          @johnnybahama das hat @Homoran schon im dritten Post geschrieben
                          https://forum.iobroker.net/topic/72131/iobroker-startet-jeden-abend-neu/3#
                          • N
                            Skript v.2023-10-10
                            *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : arm64
                             09:29:50 up 14:23,  2 users,  load average: 0.13, 0.10, 0.09
                            CPU threads: 4
                            Current issues:
                                           Local time: Thu 2024-01-25 09:29:50 CET
                                       Universal time: Thu 2024-01-25 08:29:50 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            pi
                            /home/pi
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            1.9G        1.7G        108M        229K        225M        262M
                            Swap:           104M        7.6M         97M
                            Total:          2.0G        1.7G        205M
                                     1848 M total memory
                                     1597 M used memory
                                      976 M active memory
                                      624 M inactive memory
                                      103 M free memory
                                        1 M buffer memory
                                      213 M swap cache
                                       99 M total swap
                                        7 M used swap
                                       92 M free swap
                            Raspberry only:
                            oom events: 0
                            *** FILESYSTEM ***
                            /var:
                            1.1G    /var/
                            627M    /var/log
                            625M    /var/log/journal/646f283dbad041b98afadc09481d9d55
                            203M    /var/cache
                            Archived and active journals take up 624.8M in the file system.
                            345M    /opt/iobroker/iobroker-data/
                            43M     /opt/iobroker/iobroker-data/objects.jsonl
                            USB-Devices by-id:
                            /usr/bin/npm            10.2.3
                            /usr/bin/npx            10.2.3
                            nodejs:
                              Version table:
                                 18.13.0+dfsg1-1 500
                            Errors in npm tree:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: redis
                            admin:          6.12.0
                            javascript:     7.1.6
                            Adapter State
                            + instance is alive
                             Objects database error: read ECONNRESET
                             Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                            Objects and States
                            Objects:        6085
                            States:         16776
                            Pending Updates: 7
                            tcp        0      0 192.168.178.60:1884     0.0.0.0:*               LISTEN      1001       542361     26603/io.mqtt.0
                            tcp        0      0 192.168.178.60:1885     0.0.0.0:*               LISTEN      1001       542362     26603/io.mqtt.0
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       539776     26064/iobroker.js-c
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       539836     26082/io.admin.0
                            2024-01-25 09:33:05.695  - info: javascript.0 (26128) Start javascript script.js.common.Waschmaschine_fertig_Ansage
                            2024-01-25 09:33:05.703  - info: javascript.0 (26128) script.js.common.Waschmaschine_fertig_Ansage: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                            2024-01-25 09:33:05.778  - info: whatsapp-cmb.0 (26147) starting. Version 0.2.3 in /opt/iobroker/node_modules/iobroker.whatsapp-cmb, node: v18.19.0, js-controller: 5.0.17
                            2024-01-25 09:33:06.702  - info: host.raspi instance scheduled system.adapter.ical.1 0 3 * * *
                            2024-01-25 09:33:06.718  - info: host.raspi instance system.adapter.ical.1 started with pid 26215
                            2024-01-25 09:33:08.050  - info: ical.0 (26185) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
                            2024-01-25 09:33:08.502  - info: ical.0 (26185) processing URL: Abfall /opt/iobroker/Abfall2024.ics
                            2024-01-25 09:33:10.149  - info: ical.1 (26215) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
                            2024-01-25 09:33:10.250  - info: alexa2.0 (26157) Initialize all Device states ...
                            2024-01-25 09:33:10.688  - info: host.raspi instance system.adapter.mqtt.0 started with pid 26603
                            2024-01-25 09:33:10.898  - info: ical.1 (26215) processing URL: Frei https://calendar.google.com/calendar/ical/l8asmcgpumc56d3n6opmji52to%40group.calendar.google.com/public/basic.ics
                            2024-01-25 09:33:12.112  - warn: ical.0 (26185) Error reading from URL "http://www.eventfabrik24.de/Abfall2023.ics": 404
                            2024-01-25 09:33:12.119  - warn: ical.0 (26185) Error reading "http://www.eventfabrik24.de/Abfall2023.ics": Cannot read URL: "http://www.eventfabrik24.de/Abfall2023.ics"
                            2024-01-25 09:33:14.677  - info: host.raspi instance scheduled system.adapter.openweathermap.0 0 23 * * *
                            2024-01-25 09:33:14.692  - info: host.raspi instance system.adapter.openweathermap.0 started with pid 26625
                            2024-01-25 09:33:16.006  - info: ical.1 (26215) Terminated (NO_ERROR): Without reason
                            2024-01-25 09:33:16.687  - info: host.raspi instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
                            2024-01-25 09:33:17.233  - info: ical.0 (26185) Terminated (NO_ERROR): Without reason
                            2024-01-25 09:33:18.010  - info: host.raspi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                            2024-01-25 09:33:18.790  - info: host.raspi instance system.adapter.rpi2.0 started with pid 27004
                            2024-01-25 09:33:20.344  - info: openweathermap.0 (26625) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v18.19.0, js-controller: 5.0.17
                            2024-01-25 09:33:22.289  - info: rpi2.0 (27004) starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.rpi2, node: v18.19.0, js-controller: 5.0.17
                            2024-01-25 09:33:22.678  - error: rpi2.0 (27004) No Value found for cpu_frequency
                            2024-01-25 09:33:22.690  - info: host.raspi instance system.adapter.sonoff.0 started with pid 27052
                            2024-01-25 09:33:26.745  - info: host.raspi instance system.adapter.tr-064.1 started with pid 27060
                            iob diag has finished.
                            Press any key for a summary
                              *** MEMORY ***
                              Das wird zu wenig sein. Bei Lastspitzen knickt dir das weg.
                              • N
                                norman @JohnnyBahama last edited by
                                @johnnybahama
                                nicht, dass ich dir nicht glauben will, will das nur etwas genauer verstehen. er kommt bei mir ja gar nicht über die 1500MB Speicherbedarf drüber bevor er abschmiert, da is ja eigentlich noch etwas Luft.....
                                Thomas Braun J 2 Replies Last reply Reply Quote 0
                                  @norman
                                  Da sind noch 262MB verfügbar. So viel Luft ist da also nicht mehr.
                                  Wenn jetzt ein Adapter sich mehr genehmigen muss (z. B. weil ein Backup läuft) hast du ein Problem.
                                  • N
                                    @thomas-braun said in IObroker startet jeden Abend neu!:
                                    @norman
                                    ja, knapp is es schon....aber es gibt doch noch mehr Leute hier, die IOb auf nem 2GBPi4 rennen haben.....
                                    Oder ich hab zuviel Instanzen am laufen 😞
                                    Also auf n Pi5 gehen??
                                    Thomas Braun Homoran MartinP Marc Berg 4 Replies Last reply Reply Quote 0
                                      Die haben dann aber nicht wie du da 18 Instanzen laufen.
                                      Man kann mit einem durchschnittlichen Bedarf von 80-100MB pro Instanz rechnen. Da bist du also alleine mit dem iobroker schon fast dicht. Und das Betriebssystem braucht ja auch noch was Luft zum atmen.
                                        muss kein pi5 sein, gibt auch pi4 mit 4 und 8 GB.
                                        woher weisst du das?
                                        Da wird wahrscheinlich intern schon Speicher freigeräumt indem Prozesse gestoppt werden.
                                        ...bis dann lebenswichtige Prozesse dran glauben müssen.
                                        N 1 Reply Last reply Reply Quote 1
                                        • MartinP
                                          MartinP @norman last edited by
                                          @norman said in IObroker startet jeden Abend neu!:
                                          @norman
                                          Ein Pi4 mit mehr Arbeitsspeicher, oder ein Mini-PC (NUC o.Ä.) wäre auch eine Option, wenn die IO-Pins des Pi nicht gebraucht werden....
                                          Eine weitere Option wäre, ggfs die ioBroker Installation zu verschlanken. Adapter, die man probeweise installiert hat anhalten oder deinstallieren, Aufgaben an Slave-ioBroker auslagern usw... In aller Regel ist das aber keine Lösung, die dauerhaft funktioniert ...
                                          Mein in der Signatur genanntes System kommt mit unter 10 Watt aus ... Tagesverbrauch ca 0,2 kWh ...
                                          Mein Celeron 3000 ist aber ziemlich lahm (irgendwo zwischen Pi3 und Pi4), das System hat aber auch ohne RAM und SSD nur 69€ incl Gehäuse und Netzteil als "Refurbished" gekostet...
                                          • Marc Berg
                                            Marc Berg Most Active @norman last edited by
                                            Ich finde, du hättest schon noch ein wenig Optimierungspotential, um die Zeit bis zur neuen Hardware zu überbrücken. Den Info-Adapter würde ich wegwerfen und ob man bei DER Anzahl von States eine redis-DB betreiben muss? Ich weiß nicht ...
                                            Wenn das Geld ein Thema ist und du mit der CPU Leistung zufrieden bist, warum nicht einen gebrauchten Pi4 mit 4 oder 8 GB RAM?
                                            1597
