    4. Frigate Adapter für ioBroker
      tombox @dragst3r last edited by
      @dragst3r Es werden nur die mqtt Sachen verarbeitet die frigate schickt
      unter events.after das letzte event
      events.history die letzen 10 events wenn ein neues event passiert ist
      camera.person_snapshot wenn frigate ein neuen person snapshot liefert wird er dort abgespeichert.
      motion wird nicht verarbeitet sondern nur unter
      camera.motion angezeigt
        crunchip Forum Testing Most Active @tombox last edited by
        @tombox sagte in Frigate Adapter für ioBroker:
        Es dürfen keine warnings kommen
        nachdem ich nun frigate neu gestartet hab
        frigate.0
        2024-01-24 11:29:52.488	info	frigate.0 (3233) MQTT client frigate subscribed to topics: frigate/# from broker 8f43c1df-0f3d-46e6-b896-daf19f01ffd0
        frigate.0
        2024-01-24 11:29:52.467	warn	AxiosError: Request failed with status code 502
        frigate.0
        2024-01-24 11:29:52.464	warn	Cannot reach server. You can ignore this after restarting the frigate server.
        frigate.0
        2024-01-24 11:29:52.461	warn	fetchEventHistory error from http://10.1.1.219:5000/api/events
        frigate.0
        2024-01-24 11:29:52.299	info	Filter for message from client: frigate
        frigate.0
        2024-01-24 11:29:52.297	info	New client: frigate
        danach in der Instanz nun mal alle Haken bei Benachrichtigung gesetzt
        frigate.0
        2024-01-24 11:38:35.091	info	Notification score 0.8125 is lower than 80 state Event After Snapshot update type person
        frigate.0
        2024-01-24 11:38:34.879	info	Notification score 0.8046875 is lower than 80 state Event After Snapshot update type person
        frigate.0
        2024-01-24 11:38:06.884	info	frigate.0 (6659) MQTT client frigate subscribed to topics: frigate/# from broker 0d1b26b5-3576-4961-ba82-774edab3af97
        frigate.0
        2024-01-24 11:38:06.762	info	Filter for message from client: frigate
        frigate.0
        2024-01-24 11:38:06.760	info	New client: frigate
        frigate.0
        2024-01-24 11:38:06.208	info	If you don't see a new client connected, please restart frigate and adapter.
        frigate.0
        2024-01-24 11:38:06.206	info	Please enter host: 'IoBroker' and port: '1883' in frigate config
        frigate.0
        2024-01-24 11:38:06.198	info	MQTT server started and listening on port 1883
        frigate.0
        2024-01-24 11:38:05.874	info	starting. Version 0.2.9 (non-npm: iobroker-community-adapters/ioBroker.frigate#2f7c0df50042d9f0748c3225c9258cc6d955efb4) in /opt/iobroker/node_modules/iobroker.frigate, node: v18.19.0, js-controller: 5.0.17
        frigate.0
        2024-01-24 11:37:59.641	error	Error: DB closed
        frigate.0
        2024-01-24 11:37:59.640	error	Error extract keys: events.after.box04 399
        frigate.0
        2024-01-24 11:37:59.637	error	Error: DB closed
        frigate.0
        2024-01-24 11:37:59.636	error	Error extract keys: events.history.06 {"box":"","camera":"buero","data":{"attributes":[],"box":[0.21805555555555556,0.20208333333333334,0.2875,0.6395833333333333],"region":[0,0,1.0722222222222222,1.6083333333333334],"score":0.8203125,"top_score":0.82421875,"type":"object"},"end_time":1706092340.802761,"false_positive":null,"has_clip":true,"has_snapshot":true,"id":"1706092198.251338-dax9px","label":"person","plus_id":null,"retain_indefinitely":false,"start_time":1706092188.251338,"sub_label":null,"thumbnail":"data:image/jpeg;base64,/9j/4AAQSkZ...q89fWkM//9k=","top_score":null,"zones":["zone_buero1","zone_buero"],"websnap":"http://10.1.1.219:5000/api/events/1706092198.251338-dax9px/snapshot.jpg","webclip":"http://10.1.1.219:5000/api/events/1706092198.251338-dax9px/clip.mp4"}
        frigate.0
        2024-01-24 11:37:59.635	error	Error: DB closed
        frigate.0
        2024-01-24 11:37:59.633	error	Error extract keys: events.history.04.data.region02 0.07954545454545454
        frigate.0
        2024-01-24 11:37:59.632	error	Error: DB closed
        frigate.0
        2024-01-24 11:37:59.631	error	Error extract keys: events.history.04.data.region03 0.5
        frigate.0
        2024-01-24 11:37:59.630	error	Error: DB closed
        frigate.0
        2024-01-24 11:37:59.629	error	Error extract keys: events.history.04.data.region03 0.5
        frigate.0
        2024-01-24 11:37:59.614	error	Error: DB closed
        frigate.0
        2024-01-24 11:37:59.613	error	Error extract keys: events.history.06 {"box":"","camera":"buero","data":{"attributes":[],"box":[0.21805555555555556,0.20208333333333334,0.2875,0.6395833333333333],"region":[0,0,1.0722222222222222,1.6083333333333334],"score":0.8203125,"top_score":0.82421875,"type":"object"},"end_time":1706092340.802761,"false_positive":null,"has_clip":true,"has_snapshot":true,"id":"1706092198.251338-dax9px","label":"person","plus_id":null,"retain_indefinitely":false,"start_time":1706092188.251338,"sub_label":null,"thumbnail":"data:image/jpeg;base64,/9j/4AAQSkZJRgABAQA...q89fWkM//9k=","top_score":null,"zones":["zone_buero1","zone_buero"],"websnap":"http://10.1.1.219:5000/api/events/1706092198.251338-dax9px/snapshot.jpg","webclip":"http://10.1.1.219:5000/api/events/1706092198.251338-dax9px/clip.mp4"}
        frigate.0
        2024-01-24 11:37:59.611	error	Error: DB closed
        frigate.0
        2024-01-24 11:37:59.609	error	Error extract keys: events.history.10.data.region03 0.9888888888888889
        frigate.0
        2024-01-24 11:37:59.607	error	Error: DB closed
        dann ging mir plötzlich der Ram auf der VM aus😏
        hab der VM nun mehr Ram gegeben und alles nochmal neu gestartet, ich beobachte
          tombox @crunchip last edited by
          @crunchip das sieht soweit gut aus
          eigentlich ist die score zwischen 0 und 1 aber ich werde es umrechnen wenn score höher als 1 ist
          ja RAM verbrauch bei notification habe ich auch gesehen ich schaue mal wie ich da optimieren kann.
            Ja da hatte ich mich erst vertan, hatte 89 anstatt 0.8 eingetragen
            War auch anfangs verwirrend, da mit den Pfeiltasten Ganzzahlen kommen.
            Und 0.x gar nicht geht sonder das Komma verwenden muss, alao 0,x
              hagst @tombox last edited by
              Bitte testen und gerne zusätzliche Features äußern.
              Ich habe kürzlich nach einer Methode gesucht, Snapshots von Frigate bei Bewegungserkennung an Telegram zu senden. Dabei bin ich auf deinen Adapter gestoßen. Er ist genial, bei mir funktioniert alles so, wie du es programmiert hast. Vielen, vielen Dank für dein Engagement, uns einen so genialen Adapter zur Verfügung zu stellen. Wenn man jetzt noch optional den Text bei der Telegram-Nachricht (z. B. "Terrasse Person Event After Snapshot Update" oder "Terrasse Person Event After Snapshot New" usw.) frei gestalten könnte, wäre es super. Es ist jedoch nur eine Spielerei, ohne die der Adapter auch sehr, sehr gut ist.
                tombox @hagst last edited by
                @hagst wie würdest du denn den text anpassen wollen
                H Wal 2 Replies Last reply Reply Quote 0
                  Mit einem frei wählbaren Text halt.
                  Es wäre auch nicht schlecht, wenn man die Telegram-Benachrichtigungen pro Kamera einstellen könnte. Ich habe hier nämlich verschiedene Kameras in Frigate, brauche jedoch nicht von allen eine Nachricht per Telegram. Aber wie schon geschrieben, alles nur "nette" Spielereien.
                  • Wal
                    Wal Developer @tombox last edited by Wal
                    @tombox ,
                    @hagst sagte in Frigate Adapter für ioBroker:
                    ist mir auch schon in den Sinn gekommen, wollte dich am Anfang aber nicht überlasten. 😉
                    Evtl. Datenpunkte für höhe Score für/und Art/Benachrichtigung pro Kamera erzeugen und die Punkte in den Settings löschen.
                    Hätte man dann auch die Möglichkeit die Sachen über Skript an/aus zu schalten. (z.B. Nachts keine Benachrichtigung u.s.w.)
                    auch über Datenpunkt
                      crunchip Forum Testing Most Active @hagst last edited by
                      Dito bzw nicht rund um die Uhr, daher weiterhin per script aktuell
                        tombox @Wal last edited by
                        @wal
                        custom notification text ist jetzt möglich
                        score für jede Kamera
                        exclude liste für Kameras
                        und frigate.0.remote.pauseNotification um via Skript die notification zu pausieren
                        H 2 Replies Last reply Reply Quote 4
                          hagst @tombox last edited by hagst
                          Das klappt super, vielen Dank. Den Ausschluss von Kameras schaue ich mir morgen mal an, ich muss ins Bett.
                          Edit:
                          Das klappt auch, Telegram bleibt stumm:
                            Ich greife meine Frage nochmal auf. Wann wird das Object frigate.0.cameraX.person_snapshot erstellt? Ich hatte es nun wieder, dass ein Bild erzeugt wurde, welches nicht als Event in Frigate exisitiert. Wenn ich das Bild anschauen, sehe ich auch das es eine Motion Erkennung ist, aber außerhalb meiner definierten Zone. Im event History Adapter existiert es auch nicht.
                            VG
                            dragst3r
                              @dragst3r Hier gibt es die offizielle Erklärung
                              https://docs.frigate.video/integrations/mqtt/#frigatecamera_nameobject_namesnapshot
                                Gerade gemerkt, etwas suboptimal ist:
                                Es wurde eine person auf der Terrasse erkannt
                                Es wurde eine person auf der Einfahrt erkannt
                                Es wurde eine person auf der Wald erkannt
                                Es wurde eine person auf der Eingang erkannt
                                Vielleicht könntest Du "globale" und "kameraspezifische" Einstellmöglichkeiten einbauen?
                                Ich habe jetzt so ziemlich alles getestet, bisher ist mir kein Fehler irgendwo aufgefallen, sehr gute Arbeit!
                                • Wal
                                  @tombox ,
                                  mir wäre es auch lieber, wenn die Schalter für Nachrichten und Meldetexte im Objektbaum der Kamera wären da man mit Skripten darauf Zugriff hätte.
                                  Genau so der Ringpuffer wäre meiner Meinung im Objektbaum jeder Kamera besser aufgehoben.
                                  Habe jetzt im Testsystem nur eine Kamera am laufen, aber so wie ich das sehe füllt sich im Moment der Ring mit allen Kameras.
                                  Wie gesagt lass dir Zeit, es funktioniert soweit.
                                    @wal
                                    pro Kamera
                                    remote Pause
                                    remote Notification Text
                                    remote Notification Score
                                    event History
                                    H 1 Reply Last reply Reply Quote 2
                                      remote Pause
                                      Sollten die automatisch angelegt werden?
                                      Wal T 2 Replies Last reply Reply Quote 0
                                      • Wal
                                        Wal Developer @hagst last edited by
                                        @hagst ,
                                        ja wurden bei mir automatisch angelegt.
                                        Adapter Version 1.0.0 über NPM installiert.
                                          @hagst Ja das dauert aber ein Moment bis das erste mal die Kamera infos kommen
                                            Die fehlenden Einträge wurden, auch über Nacht, nicht erstellt.
                                            Also alles wieder deinstalliert, alle vorhandenen Einträge gelöscht, ioBroker neu gestartet. Dann wieder alles neu über Git > Benutzerdefierter URL installiert, Einstellungen MQTT vorgenommen.
                                            Alle Kameras wurden erkannt und angelegt, History auch. ioBroker und Frigate neu gestartet, die fehlenden Einträge wurden wieder nicht erstellt. Was mir auch aufgefallen ist, ist folgendes unter den Bildern und Clips bei Telegram:
                                            Die Standard Textvorlage wurde nicht verändert:
                                            {{source}} {{type}} erkannt {{status}} {{score}}
                                            Installierte Adapter Version: 1.0.0
                                            Frigate Version: 0.12.1-367D724
                                            Umgebung: Proxmox 8.1.4
                                            367
                                            98670
