    4. Frigate Adapter für ioBroker
      crunchip Forum Testing Most Active @tombox last edited by
      @tombox sagte in Frigate Adapter für ioBroker:
      Es dürfen keine warnings kommen
      nachdem ich nun frigate neu gestartet hab
      frigate.0
      2024-01-24 11:29:52.488	info	frigate.0 (3233) MQTT client frigate subscribed to topics: frigate/# from broker 8f43c1df-0f3d-46e6-b896-daf19f01ffd0
      frigate.0
      2024-01-24 11:29:52.467	warn	AxiosError: Request failed with status code 502
      frigate.0
      2024-01-24 11:29:52.464	warn	Cannot reach server. You can ignore this after restarting the frigate server.
      frigate.0
      2024-01-24 11:29:52.461	warn	fetchEventHistory error from http://10.1.1.219:5000/api/events
      frigate.0
      2024-01-24 11:29:52.299	info	Filter for message from client: frigate
      frigate.0
      2024-01-24 11:29:52.297	info	New client: frigate
      danach in der Instanz nun mal alle Haken bei Benachrichtigung gesetzt
      frigate.0
      2024-01-24 11:38:35.091	info	Notification score 0.8125 is lower than 80 state Event After Snapshot update type person
      frigate.0
      2024-01-24 11:38:34.879	info	Notification score 0.8046875 is lower than 80 state Event After Snapshot update type person
      frigate.0
      2024-01-24 11:38:06.884	info	frigate.0 (6659) MQTT client frigate subscribed to topics: frigate/# from broker 0d1b26b5-3576-4961-ba82-774edab3af97
      frigate.0
      2024-01-24 11:38:06.762	info	Filter for message from client: frigate
      frigate.0
      2024-01-24 11:38:06.760	info	New client: frigate
      frigate.0
      2024-01-24 11:38:06.208	info	If you don't see a new client connected, please restart frigate and adapter.
      frigate.0
      2024-01-24 11:38:06.206	info	Please enter host: 'IoBroker' and port: '1883' in frigate config
      frigate.0
      2024-01-24 11:38:06.198	info	MQTT server started and listening on port 1883
      frigate.0
      2024-01-24 11:38:05.874	info	starting. Version 0.2.9 (non-npm: iobroker-community-adapters/ioBroker.frigate#2f7c0df50042d9f0748c3225c9258cc6d955efb4) in /opt/iobroker/node_modules/iobroker.frigate, node: v18.19.0, js-controller: 5.0.17
      frigate.0
      2024-01-24 11:37:59.641	error	Error: DB closed
      frigate.0
      2024-01-24 11:37:59.640	error	Error extract keys: events.after.box04 399
      frigate.0
      2024-01-24 11:37:59.637	error	Error: DB closed
      frigate.0
      2024-01-24 11:37:59.636	error	Error extract keys: events.history.06 {"box":"","camera":"buero","data":{"attributes":[],"box":[0.21805555555555556,0.20208333333333334,0.2875,0.6395833333333333],"region":[0,0,1.0722222222222222,1.6083333333333334],"score":0.8203125,"top_score":0.82421875,"type":"object"},"end_time":1706092340.802761,"false_positive":null,"has_clip":true,"has_snapshot":true,"id":"1706092198.251338-dax9px","label":"person","plus_id":null,"retain_indefinitely":false,"start_time":1706092188.251338,"sub_label":null,"thumbnail":"data:image/jpeg;base64,/9j/4AAQSkZ...q89fWkM//9k=","top_score":null,"zones":["zone_buero1","zone_buero"],"websnap":"http://10.1.1.219:5000/api/events/1706092198.251338-dax9px/snapshot.jpg","webclip":"http://10.1.1.219:5000/api/events/1706092198.251338-dax9px/clip.mp4"}
      frigate.0
      2024-01-24 11:37:59.635	error	Error: DB closed
      frigate.0
      2024-01-24 11:37:59.633	error	Error extract keys: events.history.04.data.region02 0.07954545454545454
      frigate.0
      2024-01-24 11:37:59.632	error	Error: DB closed
      frigate.0
      2024-01-24 11:37:59.631	error	Error extract keys: events.history.04.data.region03 0.5
      frigate.0
      2024-01-24 11:37:59.630	error	Error: DB closed
      frigate.0
      2024-01-24 11:37:59.629	error	Error extract keys: events.history.04.data.region03 0.5
      frigate.0
      2024-01-24 11:37:59.614	error	Error: DB closed
      frigate.0
      2024-01-24 11:37:59.613	error	Error extract keys: events.history.06 {"box":"","camera":"buero","data":{"attributes":[],"box":[0.21805555555555556,0.20208333333333334,0.2875,0.6395833333333333],"region":[0,0,1.0722222222222222,1.6083333333333334],"score":0.8203125,"top_score":0.82421875,"type":"object"},"end_time":1706092340.802761,"false_positive":null,"has_clip":true,"has_snapshot":true,"id":"1706092198.251338-dax9px","label":"person","plus_id":null,"retain_indefinitely":false,"start_time":1706092188.251338,"sub_label":null,"thumbnail":"data:image/jpeg;base64,/9j/4AAQSkZJRgABAQA...q89fWkM//9k=","top_score":null,"zones":["zone_buero1","zone_buero"],"websnap":"http://10.1.1.219:5000/api/events/1706092198.251338-dax9px/snapshot.jpg","webclip":"http://10.1.1.219:5000/api/events/1706092198.251338-dax9px/clip.mp4"}
      frigate.0
      2024-01-24 11:37:59.611	error	Error: DB closed
      frigate.0
      2024-01-24 11:37:59.609	error	Error extract keys: events.history.10.data.region03 0.9888888888888889
      frigate.0
      2024-01-24 11:37:59.607	error	Error: DB closed
      dann ging mir plötzlich der Ram auf der VM aus😏
      hab der VM nun mehr Ram gegeben und alles nochmal neu gestartet, ich beobachte
        tombox @crunchip last edited by
        @crunchip das sieht soweit gut aus
        eigentlich ist die score zwischen 0 und 1 aber ich werde es umrechnen wenn score höher als 1 ist
        ja RAM verbrauch bei notification habe ich auch gesehen ich schaue mal wie ich da optimieren kann.
          Ja da hatte ich mich erst vertan, hatte 89 anstatt 0.8 eingetragen
          War auch anfangs verwirrend, da mit den Pfeiltasten Ganzzahlen kommen.
          Und 0.x gar nicht geht sonder das Komma verwenden muss, alao 0,x
            hagst @tombox last edited by
            Bitte testen und gerne zusätzliche Features äußern.
            Ich habe kürzlich nach einer Methode gesucht, Snapshots von Frigate bei Bewegungserkennung an Telegram zu senden. Dabei bin ich auf deinen Adapter gestoßen. Er ist genial, bei mir funktioniert alles so, wie du es programmiert hast. Vielen, vielen Dank für dein Engagement, uns einen so genialen Adapter zur Verfügung zu stellen. Wenn man jetzt noch optional den Text bei der Telegram-Nachricht (z. B. "Terrasse Person Event After Snapshot Update" oder "Terrasse Person Event After Snapshot New" usw.) frei gestalten könnte, wäre es super. Es ist jedoch nur eine Spielerei, ohne die der Adapter auch sehr, sehr gut ist.
              tombox @hagst last edited by
              @hagst wie würdest du denn den text anpassen wollen
              H Wal 2 Replies Last reply Reply Quote 0
                Mit einem frei wählbaren Text halt.
                Es wäre auch nicht schlecht, wenn man die Telegram-Benachrichtigungen pro Kamera einstellen könnte. Ich habe hier nämlich verschiedene Kameras in Frigate, brauche jedoch nicht von allen eine Nachricht per Telegram. Aber wie schon geschrieben, alles nur "nette" Spielereien.
                • Wal
                  Wal Developer @tombox last edited by Wal
                  @tombox ,
                  @hagst sagte in Frigate Adapter für ioBroker:
                  ist mir auch schon in den Sinn gekommen, wollte dich am Anfang aber nicht überlasten. 😉
                  Evtl. Datenpunkte für höhe Score für/und Art/Benachrichtigung pro Kamera erzeugen und die Punkte in den Settings löschen.
                  Hätte man dann auch die Möglichkeit die Sachen über Skript an/aus zu schalten. (z.B. Nachts keine Benachrichtigung u.s.w.)
                  auch über Datenpunkt
                    crunchip Forum Testing Most Active @hagst last edited by
                    Dito bzw nicht rund um die Uhr, daher weiterhin per script aktuell
                      tombox @Wal last edited by
                      @wal
                      custom notification text ist jetzt möglich
                      score für jede Kamera
                      exclude liste für Kameras
                      und frigate.0.remote.pauseNotification um via Skript die notification zu pausieren
                      H 2 Replies Last reply Reply Quote 4
                        hagst @tombox last edited by hagst
                        Das klappt super, vielen Dank. Den Ausschluss von Kameras schaue ich mir morgen mal an, ich muss ins Bett.
                        Edit:
                        Das klappt auch, Telegram bleibt stumm:
                          dragst3r last edited by
                          Ich greife meine Frage nochmal auf. Wann wird das Object frigate.0.cameraX.person_snapshot erstellt? Ich hatte es nun wieder, dass ein Bild erzeugt wurde, welches nicht als Event in Frigate exisitiert. Wenn ich das Bild anschauen, sehe ich auch das es eine Motion Erkennung ist, aber außerhalb meiner definierten Zone. Im event History Adapter existiert es auch nicht.
                          VG
                          dragst3r
                            tombox @dragst3r last edited by
                            @dragst3r Hier gibt es die offizielle Erklärung
                            https://docs.frigate.video/integrations/mqtt/#frigatecamera_nameobject_namesnapshot
                              Gerade gemerkt, etwas suboptimal ist:
                              Es wurde eine person auf der Terrasse erkannt
                              Es wurde eine person auf der Einfahrt erkannt
                              Es wurde eine person auf der Wald erkannt
                              Es wurde eine person auf der Eingang erkannt
                              Vielleicht könntest Du "globale" und "kameraspezifische" Einstellmöglichkeiten einbauen?
                              Ich habe jetzt so ziemlich alles getestet, bisher ist mir kein Fehler irgendwo aufgefallen, sehr gute Arbeit!
                              • Wal
                                @tombox ,
                                mir wäre es auch lieber, wenn die Schalter für Nachrichten und Meldetexte im Objektbaum der Kamera wären da man mit Skripten darauf Zugriff hätte.
                                Genau so der Ringpuffer wäre meiner Meinung im Objektbaum jeder Kamera besser aufgehoben.
                                Habe jetzt im Testsystem nur eine Kamera am laufen, aber so wie ich das sehe füllt sich im Moment der Ring mit allen Kameras.
                                Wie gesagt lass dir Zeit, es funktioniert soweit.
                                  @wal
                                  pro Kamera
                                  remote Pause
                                  remote Notification Text
                                  remote Notification Score
                                  event History
                                  H 1 Reply Last reply Reply Quote 2
                                    remote Pause
                                    Sollten die automatisch angelegt werden?
                                    Wal T 2 Replies Last reply Reply Quote 0
                                    • Wal
                                      Wal Developer @hagst last edited by
                                      @hagst ,
                                      ja wurden bei mir automatisch angelegt.
                                      Adapter Version 1.0.0 über NPM installiert.
                                        @hagst Ja das dauert aber ein Moment bis das erste mal die Kamera infos kommen
                                          Die fehlenden Einträge wurden, auch über Nacht, nicht erstellt.
                                          Also alles wieder deinstalliert, alle vorhandenen Einträge gelöscht, ioBroker neu gestartet. Dann wieder alles neu über Git > Benutzerdefierter URL installiert, Einstellungen MQTT vorgenommen.
                                          Alle Kameras wurden erkannt und angelegt, History auch. ioBroker und Frigate neu gestartet, die fehlenden Einträge wurden wieder nicht erstellt. Was mir auch aufgefallen ist, ist folgendes unter den Bildern und Clips bei Telegram:
                                          Die Standard Textvorlage wurde nicht verändert:
                                          {{source}} {{type}} erkannt {{status}} {{score}}
                                          Installierte Adapter Version: 1.0.0
                                          Frigate Version: 0.12.1-367D724
                                          Umgebung: Proxmox 8.1.4
                                            @hagst Steht im log denn Create Device information and fetch Event History
                                            367
                                            98655
