    4. IObroker startet jeden Abend neu!
    • wendy2702
      wendy2702 @Thomas Braun last edited by
      @thomas-braun Sorry, hatte es so verstanden das die Maschine neu startet.
      • N
        norman @Thomas Braun last edited by
        meinst du so:
        Skript v.2023-10-10
        *** BASE SYSTEM ***
         Static hostname: raspi
               Icon name: computer
                  Kernel: Linux 6.1.0-rpi7-rpi-v8
            Architecture: arm64
        Model           : Raspberry Pi 4 Model B Rev 1.1
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : arm64
        Systemuptime and Load:
         19:56:24 up 14 days,  1:24,  2 users,  load average: 0.39, 0.52, 0.52
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Sun 2024-01-21 19:56:24 CET
                   Universal time: Sun 2024-01-21 18:56:24 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        Boot Target:    multi-user.target
        *** MEMORY ***
        Mem:            1.9G        1.4G        292M        225K        349M        569M
        Swap:           104M         21M         83M
        Total:          2.0G        1.4G        375M
                 1848 M total memory
                 1304 M used memory
                  377 M active memory
                 1060 M inactive memory
                  278 M free memory
                   21 M buffer memory
                  311 M swap cache
                   99 M total swap
                   20 M used swap
                   79 M free swap
        Raspberry only:
        oom events: 0
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        udev           devtmpfs  661M     0  661M   0% /dev
        tmpfs          tmpfs     185M  1.2M  184M   1% /run
        /dev/mmcblk0p2 ext4       59G  4.5G   51G   9% /
        tmpfs          tmpfs     925M     0  925M   0% /dev/shm
        /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
        tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
        TARGET           SOURCE         FSTYPE OPTIONS
        /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
        `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        956M    /var/
        490M    /var/log
        489M    /var/log/journal/646f283dbad041b98afadc09481d9d55
        202M    /var/cache
        Archived and active journals take up 488.8M in the file system.
        /opt/iobroker/backups:
        28M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        342M    /opt/iobroker/iobroker-data/
        223M    /opt/iobroker/iobroker-data/files
        76M     /opt/iobroker/iobroker-data/backup-objects
        67M     /opt/iobroker/iobroker-data/files/javascript.admin
        48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
        41M     /opt/iobroker/iobroker-data/objects.jsonl
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
        8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
        8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
        USB-Devices by-id:
        /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B00193675CD-if00
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.0
        /usr/bin/node           v18.19.0
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.0-1nodesource1
          Candidate: 18.19.0-1nodesource1
          Version table:
             18.19.0+dfsg-6~deb12u1 500
         *** 18.19.0-1nodesource1 1001
                100 /var/lib/dpkg/status
             18.18.2-1nodesource1 1001
             18.18.1-1nodesource1 1001
             18.18.0-1nodesource1 1001
             18.17.1-1nodesource1 1001
             18.17.0-1nodesource1 1001
             18.16.1-1nodesource1 1001
             18.16.0-1nodesource1 1001
             18.15.0-1nodesource1 1001
             18.14.2-1nodesource1 1001
             18.14.1-1nodesource1 1001
             18.14.0-1nodesource1 1001
             18.13.0+dfsg1-1 500
             18.13.0-1nodesource1 1001
             18.12.0-1nodesource1 1001
             18.11.0-1nodesource1 1001
             18.10.0-1nodesource1 1001
             18.9.1-1nodesource1 1001
             18.9.0-1nodesource1 1001
             18.8.0-1nodesource1 1001
             18.7.0-1nodesource1 1001
             18.6.0-1nodesource1 1001
             18.5.0-1nodesource1 1001
             18.4.0-1nodesource1 1001
             18.3.0-1nodesource1 1001
             18.2.0-1nodesource1 1001
             18.1.0-1nodesource1 1001
             18.0.0-1nodesource1 1001
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: redis
        Core adapters versions
        js-controller:  5.0.17
        admin:          6.12.0
        javascript:     7.1.6
        Adapters from github:   2
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspi                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : raspi                                    -  enabled
          system.adapter.backitup.0               : backitup              : raspi                                    - disabled
        + system.adapter.evohome.0                : evohome               : raspi                                    -  enabled
          system.adapter.flot.0                   : flot                  : raspi                                    - disabled
        + system.adapter.growatt.0                : growatt               : raspi                                    -  enabled
        + system.adapter.history.0                : history               : raspi                                    -  enabled
        + system.adapter.hs100.0                  : hs100                 : raspi                                    -  enabled
          system.adapter.ical.0                   : ical                  : raspi                                    -  enabled
          system.adapter.ical.1                   : ical                  : raspi                                    -  enabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspi                                    - disabled
        + system.adapter.info.0                   : info                  : raspi                                    -  enabled
        + system.adapter.iot.0                    : iot                   : raspi                                    -  enabled
        + system.adapter.javascript.0             : javascript            : raspi                                    -  enabled
        + system.adapter.lgtv.0                   : lgtv                  : raspi                                    -  enabled
          system.adapter.mobile.0                 : mobile                : raspi                                    - disabled
        + system.adapter.mqtt.0                   : mqtt                  : raspi                                    -  enabled, port: 1884, bind: 192.168.178.60
          system.adapter.openweathermap.0         : openweathermap        : raspi                                    -  enabled
        + system.adapter.ring.0                   : ring                  : raspi                                    -  enabled
        + system.adapter.rpi2.0                   : rpi2                  : raspi                                    -  enabled
          system.adapter.socketio.0               : socketio              : raspi                                    - disabled, port: 8084, bind: 0.0.0.0, run as: admin
        + system.adapter.sonoff.0                 : sonoff                : raspi                                    -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.tr-064.1                 : tr-064                : raspi                                    -  enabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspi                                    - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspi                                    - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : raspi                                    - disabled
          system.adapter.vis-inventwo.0           : vis-inventwo          : raspi                                    - disabled
          system.adapter.vis-justgage.0           : vis-justgage          : raspi                                    - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspi                                    - disabled
          system.adapter.vis.0                    : vis                   : raspi                                    -  enabled
          system.adapter.wallpanel.0              : wallpanel             : raspi                                    - disabled
        + system.adapter.web.0                    : web                   : raspi                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.web.1                    : web                   : raspi                                    - disabled, port: 20002, bind: 0.0.0.0, run as: admin
        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspi                                    -  enabled
          system.adapter.ws.0                     : ws                    : raspi                                    - disabled, port: 8084, bind: 0.0.0.0, run as: admin
        + system.adapter.zigbee.0                 : zigbee                : raspi                                    -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B00193675CD-if00
        + instance is alive
        ioBroker-Repositories
        stabil        : http://download.iobroker.net/sources-dist.json
        Active repo(s): stabil
        Installed ioBroker-Instances
        Used repository: stabil
        Adapter    "admin"        : 6.12.0   , installed 6.12.0
        Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
        Adapter    "backitup"     : 2.9.8    , installed 2.9.8
        Adapter    "growatt"      : 3.2.1    , installed 3.2.1
        Adapter    "hs100"        : 2.2.0    , installed 2.2.0
        Adapter    "icons-mfd-png": 1.2.1    , installed 1.1.0  [Updatable]
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
        Controller "js-controller": 5.0.17   , installed 5.0.17
        Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
        Adapter    "mobile"       : 1.0.1    , installed 1.0.1
        Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
        Adapter    "openweathermap": 1.0.4   , installed 0.4.5  [Updatable]
        Adapter    "ring"         : 5.0.10   , installed 5.0.10
        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
        Adapter    "vis-hqwidgets": 1.4.0    , installed 1.1.9  [Updatable]
        Adapter    "vis-icontwo"  : 1.3.0    , installed 0.89.0 [Updatable]
        Adapter    "vis-inventwo" : 3.3.3    , installed 3.3.1  [Updatable]
        Adapter    "vis-justgage" : 2.1.0    , installed 1.0.2  [Updatable]
        Adapter    "vis-timeandweather": 1.2.2, installed 1.1.7 [Updatable]
        Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
        Adapter    "web"          : 6.1.10   , installed 6.1.10
        Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
        Adapter    "ws"           : 2.5.8    , installed 2.5.8
        Adapter    "zigbee"       : 1.10.1   , installed 1.9.5  [Updatable]
        Objects and States
        Objects:        6083
        States:         16948
        Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
        Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 5
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15801      653/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      106        16411      627/redis-server 12
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       12224465   533020/iobroker.js-
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       12228465   534012/io.sonoff.0
        tcp        0      0 192.168.178.60:1884     0.0.0.0:*               LISTEN      1001       12228375   533933/io.mqtt.0
        tcp        0      0 192.168.178.60:1885     0.0.0.0:*               LISTEN      1001       12228376   533933/io.mqtt.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          15803      653/sshd: /usr/sbin
        tcp6       0      0 ::1:6379                :::*                    LISTEN      106        16412      627/redis-server 12
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       12232145   534743/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       12226506   533038/io.admin.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        13647      412/avahi-daemon: r
        udp        0      0 0.0.0.0:37662           0.0.0.0:*                           104        13649      412/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                104        13648      412/avahi-daemon: r
        udp6       0      0 :::46445                :::*                                104        13650      412/avahi-daemon: r
        udp6       0      0 fe80::c189:98ca:96e:546 :::*                                0          16472      477/NetworkManager
        2024-01-21 19:44:49.088  - info: info.0 (534111) cpu Temp res = {"main":47.712,"cores":[],"max":47.712,"socket":[],"chipset":null}
        2024-01-21 19:44:49.312  - info: iot.0 (534161) Connection changed: connect "info_mediaevent24_de"
        2024-01-21 19:44:49.682  - info: info.0 (534111) State value to set for "info.0.sysinfo.memory.memLayout.ram0.clockSpeed" has to be type "string" but received type "number"
        2024-01-21 19:44:50.424  - info: host.raspi instance system.adapter.ring.0 started with pid 534301
        2024-01-21 19:44:50.731  - info: lgtv.0 (534172) starting. Version 2.1.2 in /opt/iobroker/node_modules/iobroker.lgtv, node: v18.19.0, js-controller: 5.0.17
        2024-01-21 19:44:51.001  - info: lgtv.0 (534172) Ready. Configured WebOS TV IP: 192.168.178.56
        2024-01-21 19:44:55.048  - info: info.0 (534111) State value to set for "info.0.sysinfo.disks.diskLayout.dev0.size" has to be type "string" but received type "number"
        2024-01-21 19:44:58.472  - info: host.raspi instance system.adapter.web.0 started with pid 534743
        2024-01-21 19:44:58.854  - info: vis.0 (534583) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
        2024-01-21 19:45:01.370  - info: vis.0 (534583) Terminated (NO_ERROR): Without reason
        2024-01-21 19:45:02.095  - info: host.raspi instance system.adapter.vis.0 terminated while should be started once
        2024-01-21 19:45:04.551  - info: ring.0 (534301) starting. Version 5.0.10 (non-npm: iobroker-community-adapters/ioBroker.ring) in /opt/iobroker/node_modules/iobroker.ring, node: v18.19.0, js-controller: 5.0.17
        2024-01-21 19:45:04.603  - info: ring.0 (534301) Initializing Api Client
        2024-01-21 19:45:05.483  - info: ring.0 (534301) Received new Refresh Token. Will use the new one until the token in config gets changed
        2024-01-21 19:45:06.926  - info: ring.0 (534301) Get sunset and sunrise
        2024-01-21 19:45:07.011  - info: ring.0 (534301) Daily sun parameter calculation scheduled for 00:00:25
        2024-01-21 19:45:16.762  - info: alexa2.0 (533309) Subscribing to states...
        2024-01-21 19:45:16.772  - info: alexa2.0 (533309) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
        2024-01-21 19:45:18.526  - info: alexa2.0 (533309) Alexa-Push-Connection (macDms = true) established. Disable Polling
        2024-01-21 19:45:31.828  - info: alexa2.0 (533309) Initialization Done ...
        2024-01-21 19:46:31.428  - warn: sonoff.0 (534012) Client "" not connected
        2024-01-21 19:46:38.946  - warn: sonoff.0 (534012) Client "" not connected
        2024-01-21 19:47:24.048  - warn: sonoff.0 (534012) Client "" not connected
        2024-01-21 19:50:54.596  - warn: sonoff.0 (534012) Client "" not connected
        2024-01-21 19:54:14.031  - warn: sonoff.0 (534012) Client "" not connected
          Homoran Global Moderator Administrators @norman last edited by
          @norman sagte in IObroker startet jeden Abend neu!:
          Das System hab ich ganz regulär nach Anleitung gemacht,
          nach welcher?
          weil die SD-Karte gecrasht war
          hoffentlich jetzt auf einer neuen Karte
          Was läuft da noch drauf?
            Thomas Braun Most Active @norman last edited by
            @norman
            Hau die Updates rein.
            sudo apt update
            sudo apt full-upgrade
            sudo reboot
            iob update
            iob upgrade all
            • N
              Update nach deinen Kommandos durchgeschossen, bin mal gespannt wie er sich heute verhält.
              ich geb mal Rückmeldung.
              Soll ich zusätzlich nochmal den Fixer drüber schicken?
              • N
                norman @norman last edited by
                So, nach anderthalb Tagen Testlauf kann ich nun sagen, is noch schlimmer wie vorher.
                Vorher startete nur IO neu, jetzt bleibt der ganze Raspi hängen und muss über Hard-Reset neu gestartet werden. 😞
                Und das sogar gestern 2x am Tag.
                Man muss doch irgendwie herausfinden können, woran das liegt 😞 kann man nicht irgendwo gespeicherte Logs ziehen oder so??
                In der iob diag schreibt er auch irgendwas von "Error in NPM tree"
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : arm64
                 19:11:38 up 5 min,  2 users,  load average: 0.35, 0.68, 0.39
                CPU threads: 4
                Current issues:
                               Local time: Wed 2024-01-24 19:11:38 CET
                           Universal time: Wed 2024-01-24 18:11:38 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                /home/pi
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            1.9G        1.3G        347M        1.2M        334M        607M
                Swap:           104M          0B        104M
                Total:          2.0G        1.3G        452M
                         1848 M total memory
                         1268 M used memory
                         1282 M active memory
                          123 M inactive memory
                          330 M free memory
                           24 M buffer memory
                          294 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /dev/mmcblk0p2 ext4       59G  4.8G   51G   9% /
                [Wed Jan 24 19:06:02 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:2A:EE:F4 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c7af47fd-02 rootfstype=ext4 fsck.repair=yes rootwait
                [Wed Jan 24 19:06:05 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                [Wed Jan 24 19:06:07 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                /var:
                1.1G    /var/
                611M    /var/log
                609M    /var/log/journal/646f283dbad041b98afadc09481d9d55
                203M    /var/cache
                Archived and active journals take up 608.8M in the file system.
                343M    /opt/iobroker/iobroker-data/
                224M    /opt/iobroker/iobroker-data/files
                42M     /opt/iobroker/iobroker-data/objects.jsonl
                USB-Devices by-id:
                /usr/bin/npm            10.2.3
                /usr/bin/npx            10.2.3
                nodejs:
                  Version table:
                     18.13.0+dfsg1-1 500
                Errors in npm tree:
                ioBroker Status
                Objects type: jsonl
                States  type: redis
                admin:          6.12.0
                javascript:     7.1.6
                Adapter State
                + instance is alive
                Adapter    "openweathermap": 1.0.4   , installed 1.0.4
                Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
                Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
                Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
                Objects and States
                Objects:        6085
                States:         16953
                Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
                Hit:5 http://archive.raspberrypi.com/debian bookworm InRelease
                Pending Updates: 7
                tcp        0      0 192.168.178.60:1884     0.0.0.0:*               LISTEN      1001       16654      906/io.mqtt.0
                tcp        0      0 192.168.178.60:1885     0.0.0.0:*               LISTEN      1001       16655      906/io.mqtt.0
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       12210      996/io.sonoff.0
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16465      696/iobroker.js-con
                tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      106        13880      613/redis-server 12
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13837      652/sshd: /usr/sbin
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       21580      1701/io.web.0
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       12017      785/io.admin.0
                tcp6       0      0 :::22                   :::*                    LISTEN      0          13839      652/sshd: /usr/sbin
                tcp6       0      0 ::1:6379                :::*                    LISTEN      106        13881      613/redis-server 12
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        13770      453/avahi-daemon: r
                udp        0      0 0.0.0.0:36397           0.0.0.0:*                           104        13772      453/avahi-daemon: r
                udp6       0      0 :::60534                :::*                                104        13773      453/avahi-daemon: r
                udp6       0      0 :::5353                 :::*                                104        13771      453/avahi-daemon: r
                udp6       0      0 fe80::c189:98ca:96e:546 :::*                                0          13959      539/NetworkManager
                2024-01-24 19:07:31.532  - info: info.0 (1087) cpu Temp res = {"main":53.069,"cores":[],"max":53.069,"socket":[],"chipset":null}
                2024-01-24 19:07:31.933  - info: info.0 (1087) State value to set for "info.0.sysinfo.memory.memLayout.ram0.clockSpeed" has to be type "string" but received type "number"
                2024-01-24 19:07:32.682  - info: host.raspi instance system.adapter.lgtv.0 started with pid 1233
                2024-01-24 19:07:32.998  - info: iot.0 (1110) starting. Version 2.0.11 in /opt/iobroker/node_modules/iobroker.iot, node: v18.19.0, js-controller: 5.0.17
                2024-01-24 19:07:33.292  - info: iot.0 (1110) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
                2024-01-24 19:07:34.478  - info: iot.0 (1110) Connection changed: connect "info_mediaevent24_de"
                2024-01-24 19:07:36.233  - info: info.0 (1087) State value to set for "info.0.sysinfo.disks.diskLayout.dev0.size" has to be type "string" but received type "number"
                2024-01-24 19:07:36.507  - info: lgtv.0 (1233) starting. Version 2.1.2 in /opt/iobroker/node_modules/iobroker.lgtv, node: v18.19.0, js-controller: 5.0.17
                2024-01-24 19:07:36.685  - info: host.raspi instance system.adapter.ring.0 started with pid 1508
                2024-01-24 19:07:36.746  - info: lgtv.0 (1233) Ready. Configured WebOS TV IP: 192.168.178.56
                2024-01-24 19:07:43.082  - info: vis.0 (1686) starting. Version 1.5.4 in /opt/iobroker/node_modules/iobroker.vis, node: v18.19.0, js-controller: 5.0.17
                2024-01-24 19:07:44.691  - info: host.raspi instance system.adapter.web.0 started with pid 1701
                2024-01-24 19:07:44.805  - info: vis.0 (1686) Terminated (NO_ERROR): Without reason
                2024-01-24 19:07:45.471  - info: host.raspi instance system.adapter.vis.0 terminated while should be started once
                2024-01-24 19:07:45.698  - info: ring.0 (1508) starting. Version 5.0.10 (non-npm: iobroker-community-adapters/ioBroker.ring) in /opt/iobroker/node_modules/iobroker.ring, node: v18.19.0, js-controller: 5.0.17
                2024-01-24 19:07:45.763  - info: ring.0 (1508) Initializing Api Client
                2024-01-24 19:07:46.476  - info: ring.0 (1508) Received new Refresh Token. Will use the new one until the token in config gets changed
                2024-01-24 19:07:48.002  - info: ring.0 (1508) Get sunset and sunrise
                2024-01-24 19:07:48.070  - info: ring.0 (1508) Daily sun parameter calculation scheduled for 00:00:37
                2024-01-24 19:07:54.417  - warn: sonoff.0 (996) Client "" not connected
                2024-01-24 19:07:54.517  - warn: sonoff.0 (996) Client "" not connected
                2024-01-24 19:08:10.184  - info: alexa2.0 (932) Subscribing to states...
                2024-01-24 19:08:10.191  - info: alexa2.0 (932) Deleting the following states: ["Smart-Home-Devices.deleteAll","Smart-Home-Devices.discoverDevices"]
                2024-01-24 19:08:12.068  - info: alexa2.0 (932) Alexa-Push-Connection (macDms = true) established. Disable Polling
                2024-01-24 19:08:25.834  - info: alexa2.0 (932) Initialization Done ...
                Im Summary, das danach automatisch erstellt wird sind auch rote Errors bei NPM:
                                        v.2023-10-10
                Kernel          : aarch64
                Userland        : arm64
                CPU threads: 4
                Current issues:
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                pi
                /home/pi
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Swap:           104M          0B        104M
                         1848 M total memory
                         1268 M used memory
                          330 M free memory
                           24 M buffer memory
                          294 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /var:
                1.1G    /var/
                611M    /var/log
                203M    /var/cache
                33M     /opt/iobroker/iobroker-data/files/iot.admin/stat Static hostname: raspi
                       Icon name: computer
                    Architecture: arm64
                Installation:           native
                Kernel:                 aarch64
                Userland:               arm64
                Timezone:               Europe/Berlin (CET, +0100)
                User-ID:                1000
                X-Server:               false
                Pending OS-Updates:     7
                Pending iob updates:    0
                Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                        /usr/bin/npm            10.2.3
                                        /usr/bin/npx            10.2.3
                Recommended versions are nodejs 18.19.0 and npm 10.2.3
                MEMORY:
                Mem:            1.9G        1.4G        165M        1.2M        436M        529M
                Swap:           104M          0B        104M
                Total:          2.0G        1.4G        270M
                Active iob-Instances:   19
                ioBroker Core:          js-controller           5.0.17
                                        admin                   6.12.0
                Objects type: jsonl
                States  type: redis
                Objects:                6085
                States:                 16953
                Size of iob-Database:
                68K     /opt/iobroker/iobroker-data/states.jsonl
                === Mark text until here for copying ===
                pi@raspi:~ $ ======== Start marking the full check here =========
                -bash: ========: command not found
                pi@raspi:~ $
                pi@raspi:~ $ ```
                > Skript v.2023-10-10
                > *** BASE SYSTEM ***
                >        Icon name: computer
                > Operating System: Debian GNU/Linux 12 (bookworm)
                >     Architecture: arm64
                > Docker          : false
                > Kernel          : aarch64
                > Userland        : arm64
                > CPU threads: 4
                > Current issues:
                > No throttling issues detected.
                >                  RTC time: n/a
                >                 Time zone: Europe/Berlin (CET, +0100)
                > System clock synchronized: yes
                >               NTP service: active
                >           RTC in local TZ: no
                > pi
                > /home/pi
                > X-Server:       false
                > Desktop:
                > Terminal:       tty
                > *** MEMORY ***
                >                total        used        free      shared  buff/cache   available
                > Swap:           104M          0B        104M
                >          1848 M total memory
                >          1268 M used memory
                >           330 M free memory
                >            24 M buffer memory
                >           294 M swap cache
                >            99 M total swap
                >             0 M used swap
                >            99 M free swap
                > Raspberry only:
                > oom events: 0
                > lifetime oom required: 0 Mbytes
                > total time in oom handler: 0 ms
                > max time spent in oom handler: 0 ms
                >   UNIT LOAD ACTIVE SUB DESCRIPTION
                > *** FILESYSTEM ***
                > Filesystem     Type      Size  Used Avail Use% Mounted on
                > tmpfs          tmpfs     5.0M   16K  5.0M   1% /run/lock
                > Messages concerning ext4 filesystem in dmesg:
                > Show mounted filesystems \(real ones only\):
                -bash: Skript: command not found
                -bash: Abfall2024.ics: command not found
                -bash: Static: command not found
                -bash: Icon: command not found
                -bash: command substitution: line 7: syntax error near unexpected token `('
                -bash: command substitution: line 7: `Operating System: Debian GNU/Linux 12 (bookworm)'
                -bash: -/boot/firmware: No such file or directory
                pi@raspi:~ $
                pi@raspi:~ $ Files in neuralgic directories:
                -bash: Files: command not found
                pi@raspi:~ $
                pi@raspi:~ $ /var:
                -bash: /var:: No such file or directory
                pi@raspi:~ $ 1.1G    /var/
                -bash: 1.1G: command not found
                pi@raspi:~ $ 611M    /var/log
                -bash: 611M: command not found
                pi@raspi:~ $ 609M    /var/log/journal/646f283dbad041b98afadc09481d9d55
                -bash: 609M: command not found
                pi@raspi:~ $ 203M    /var/cache
                -bash: 203M: command not found
                pi@raspi:~ $
                pi@raspi:~ $ Archived and active journals take up 608.8M in the file system.
                -bash: Archived: command not found
                pi@raspi:~ $
                pi@raspi:~ $ /opt/iobroker/backups:
                -bash: /opt/iobroker/backups:: No such file or directory
                pi@raspi:~ $ 28M     /opt/iobroker/backups/
                -bash: 28M: command not found
                pi@raspi:~ $
                pi@raspi:~ $ /opt/iobroker/iobroker-data:
                -bash: /opt/iobroker/iobroker-data:: No such file or directory
                pi@raspi:~ $ 343M    /opt/iobroker/iobroker-data/
                -bash: 343M: command not found
                pi@raspi:~ $ 224M    /opt/iobroker/iobroker-data/files
                -bash: 224M: command not found
                pi@raspi:~ $ 76M     /opt/iobroker/iobroker-data/backup-objects
                -bash: 76M: command not found
                pi@raspi:~ $ 67M     /opt/iobroker/iobroker-data/files/javascript.admin
                -bash: 67M: command not found
                pi@raspi:~ $ 48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                -bash: 48M: command not found
                pi@raspi:~ $
                pi@raspi:~ $ The five largest files in iobroker-data are:
                -bash: The: command not found
                pi@raspi:~ $ 42M     /opt/iobroker/iobroker-data/objects.jsonl
                -bash: 42M: command not found
                pi@raspi:~ $ 33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                -bash: 33M: command not found
                pi@raspi:~ $ 21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                -bash: 21M: command not found
                pi@raspi:~ $ 8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
                -bash: 8.5M: command not found
                pi@raspi:~ $ 8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
                -bash: 8.3M: command not found
                pi@raspi:~ $
                pi@raspi:~ $ USB-Devices by-id:
                -bash: USB-Devices: command not found
                pi@raspi:~ $ USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always prefer the links 'by-id':
                -bash: USB-Sticks: command not found
                pi@raspi:~ $
                pi@raspi:~ $ /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B00193675CD-if00
                -bash: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B00193675CD-if00: Permission denied
                pi@raspi:~ $
                pi@raspi:~ $ *** NodeJS-Installation ***
                pi@raspi:~ $
                pi@raspi:~ $ /usr/bin/nodejs         v18.19.0
                node:internal/modules/cjs/loader:1137
                  throw err;
                Error: Cannot find module '/home/pi/v18.19.0'
                    at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
                    at Module._load (node:internal/modules/cjs/loader:975:27)
                    at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                    at node:internal/main/run_main_module:28:49 {
                  code: 'MODULE_NOT_FOUND',
                  requireStack: []
                Node.js v18.19.0
                pi@raspi:~ $ /usr/bin/node           v18.19.0
                  throw err;
                  requireStack: []
                Node.js v18.19.0
                pi@raspi:~ $ /usr/bin/npm            10.2.3
                Unknown command: "10.2.3"
                To see a list of supported npm commands, run:
                  npm help
                pi@raspi:~ $ /usr/bin/npx            10.2.3
                npm ERR! code E404
                npm ERR! 404 Not Found - GET https://registry.npmjs.org/10.2.3 - Not found
                npm ERR! 404
                npm ERR! 404  '10.2.3@*' is not in this registry.
                npm ERR! 404
                npm ERR! 404 Note that you can also install from a
                npm ERR! 404 tarball, folder, http url, or git url.
                npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-01-24T18_14_59_263Z-debug-0.log
                pi@raspi:~ $ /usr/bin/corepack       0.22.0
                Unknown Syntax Error: Command not found; did you mean one of:
                  0. corepack -h
                  1. corepack -v
                  2. corepack disable [--install-directory #0] ...
                  3. corepack enable [--install-directory #0] ...
                  4. corepack install <-g,--global> [--all] [--cache-only] ...
                  5. corepack install
                  6. corepack pack [--all] [--json] [-o,--output #0] ...
                  7. corepack up
                  8. corepack use <pattern>
                  9. corepack hydrate [--activate] <fileName>
                 10. corepack prepare [--activate] [--all] [--json] [-o,--output] ...
                While running 0.22.0
                pi@raspi:~ $
                pi@raspi:~ $
                pi@raspi:~ $ nodejs:
                -bash: nodejs:: command not found
                pi@raspi:~ $   Installed: 18.19.0-1nodesource1
                -bash: Installed:: command not found
                pi@raspi:~ $   Candidate: 18.19.0-1nodesource1
                -bash: Candidate:: command not found
                pi@raspi:~ $   Version table:
                -bash: Version: command not found
                pi@raspi:~ $      18.19.0+dfsg-6~deb12u1 500
                -bash: 18.19.0+dfsg-6~deb12u1: command not found
                pi@raspi:~ $         500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages
                -bash: 500: command not found
                pi@raspi:~ $  *** 18.19.0-1nodesource1 1001
                pi@raspi:~ $         500 https://deb.nodesource.com/node_18.x nodistro/main arm64 Packages
                pi@raspi:~ $         100 /var/lib/dpkg/status
                -bash: 100: command not found
                pi@raspi:~ $      18.18.2-1nodesource1 1001
                -bash: 18.18.2-1nodesource1: command not found
                pi@raspi:~ $      18.18.1-1nodesource1 1001
                -bash: 18.18.1-1nodesource1: command not found
                pi@raspi:~ $      18.18.0-1nodesource1 1001
                -bash: 18.18.0-1nodesource1: command not found
                pi@raspi:~ $      18.17.1-1nodesource1 1001
                -bash: 18.17.1-1nodesource1: command not found
                pi@raspi:~ $      18.17.0-1nodesource1 1001
                -bash: 18.17.0-1nodesource1: command not found
                      : raspi                                    - disabled
                + system.adapter.i-bash: 500: command not found
                pi@raspi:~ $      18.16.1-1nodesource1 1001
                -bash: 18.16.1-1nodesource1: command not found
                pi@raspi:~ $      18.16.0-1nodesource1 1001
                -bash: 18.16.0-1nodesource1: command not found
                pi@raspi:~ $      18.15.0-1nodesource1 1001
                -bash: 18.15.0-1nodesource1: command not found
                pi@raspi:~ $      18.14.2-1nodesource1 1001
                -bash: 18.14.2-1nodesource1: command not found
                pi@raspi:~ $      18.14.1-1nodesource1 1001
                -bash: 18.14.1-1nodesource1: command not found
                pi@raspi:~ $      18.14.0-1nodesource1 1001
                -bash: 18.14.0-1nodesource1: command not found
                pi@raspi:~ $      18.13.0+dfsg1-1 500
                -bash: 18.13.0+dfsg1-1: command not found
                pi@raspi:~ $         500 http://deb.debian.org/debian bookworm/main arm64 Packages
                pi@raspi:~ $      18.13.0-1nodesource1 1001
                -bash: 18.13.0-1nodesource1: command not found
                pi@raspi:~ $      18.12.0-1nodesource1 1001
                -bash: 18.12.0-1nodesource1: command not found
                pi@raspi:~ $      18.11.0-1nodesource1 1001
                -bash: 18.11.0-1nodesource1: command not found
                pi@raspi:~ $      18.10.0-1nodesource1 1001
                -bash: 18.10.0-1nodesource1: command not found
                pi@raspi:~ $      18.9.1-1nodesource1 1001
                -bash: 18.9.1-1nodesource1: command not found
                pi@raspi:~ $      18.9.0-1nodesource1 1001
                -bash: 18.9.0-1nodesource1: command not found
                pi@raspi:~ $      18.8.0-1nodesource1 1001
                -bash: 18.8.0-1nodesource1: command not found
                pi@raspi:~ $      18.7.0-1nodesource1 1001
                -bash: 18.7.0-1nodesource1: command not found
                pi@raspi:~ $      18.6.0-1nodesource1 1001
                -bash: 18.6.0-1nodesource1: command not found
                pi@raspi:~ $      18.5.0-1nodesource1 1001
                -bash: 18.5.0-1nodesource1: command not found
                pi@raspi:~ $      18.4.0-1nodesource1 1001
                -bash: 18.4.0-1nodesource1: command not found
                pi@raspi:~ $      18.3.0-1nodesource1 1001
                -bash: 18.3.0-1nodesource1: command not found
                pi@raspi:~ $      18.2.0-1nodesource1 1001
                -bash: 18.2.0-1nodesource1: command not found
                pi@raspi:~ $      18.1.0-1nodesource1 1001
                -bash: 18.1.0-1nodesource1: command not found
                pi@raspi:~ $      18.0.0-1nodesource1 1001
                -bash: 18.0.0-1nodesource1: command not found
                pi@raspi:~ $
                pi@raspi:~ $ Temp directories causing npm8 problem: 0
                -bash: Temp: command not found
                pi@raspi:~ $ No problems detected
                -bash: No: command not found
                pi@raspi:~ $
                pi@raspi:~ $ Errors in npm tree:
                -bash: Errors: command not found
                pi@raspi:~ $
                pi@raspi:~ $ *** ioBroker-Installation ***
                pi@raspi:~ $
                pi@raspi:~ $ ioBroker Status
                -bash: ioBroker: command not found
                pi@raspi:~ $ iobroker is running on this host.
                Objects type: jsonl
                States  type: redis
                admin:          6.12.0
                javascript:     7.1.6
                Adapter State
                + system.adapter.web.0                    : web       iobroker [command]
                Commands:
                  iobroker setup                                               Setup ioBroker
                  iobroker start [all|<adapter>.<instance>|<adapter>]          Starts the js-controller or a specified adapter instance or all instances of an adapter
                  iobroker stop [<adapter>.<instance>|<adapter>]               stops the js-controller or a specified adapter instance or all instances of an adapter
                  iobroker restart [<adapter>.<instance>|<adapter>]            Restarts js-controller or a specified adapter instance or all instances of an adapter  [aliases: r]
                  iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
                  iobroker info                                                Shows the host info
                  iobroker logs [<adapter>]                                    Monitor log
                  iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
                  iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
                  iobroker rebuild [<module>]                                  Rebuild all native modules or path
                  iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
                  iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
                  iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
                  iobroker update [<repositoryUrl>]                            Update repository and list adapters
                  iobroker upgrade                                             Upgrade management
                  iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
                  iobroker object                                              Object management  [aliases: o]
                  iobroker state                                               State management  [aliases: s]
                  iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
                  iobroker list <type> [<filter>]                              List all entries, like objects
                  iobroker chmod <mode> <file>                                 Change file rights
                  iobroker chown <user> <group> <file>                         Change file ownership
                  iobroker touch <file>                                        Touch file
                  iobroker rm <file>                                           Remove file
                  iobroker file                                                File management
                  iobroker user                                                User commands
                  iobroker group                                               group management
                  iobroker host <hostname>                                     Set host to given hostname
                  iobroker set <adapter>.<instance>                            Change settings of adapter config
                  iobroker license <license.file or license.text>              Update license by given file
                  iobroker cert                                                Certificate management
                  iobroker clean <yes>                                         Clears all objects and states
                  iobroker backup                                              Create backup
                  iobroker restore <backup name or path>                       Restore a specified backup
                  iobroker validate <backup name or path>                      Validate a specified backup
                  iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
                  iobroker repo [<name>]                                       Show repo information
                  iobroker uuid                                                Show uuid of the installation  [aliases: id]
                  iobroker unsetup                                             Reset license, installation secret and language
                  iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
                  iobroker nodejs-update [<major-version>]                     Upgrade the Node.JS installation to the current LTS
                  iobroker multihost                                           Multihost management
                  iobroker compact                                             compact group management
                  iobroker plugin                                              Plugin management
                  iobroker vendor <passphrase> [<vendor.json>]                 Update the vendor information using given passphrase
                  iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
                Options:
                  --help  Show help  [boolean]
                pi@raspi:~ $
                Blickt da einer genau durch??
                  Nein. Aber du hast auch irgendwas wirres in die Konsole geklatscht und das führt dann zu dem chaotischen Output.
                  Also nochmal sauber die Ausgabe von iob diag bitte.
                  N 1 Reply Last reply Reply Quote -1
                    JohnnyBahama last edited by JohnnyBahama
                    Bevor weiter rumprobiert wird, es ist derArbeitsspeicher. Der reicht nicht mehr. Mein System lief vorher auch Jahre, aber seit dem letztem Admin Update stürzte der immer wieder ab, auch wenn andere sagen das kann damit nichts zu tun haben.
                    Neue Kiste mit mehr Arbeitsspeicher und läuft jetzt wieder seit 50 Tagen ohne Ausfälle.
                    Kannst dir meinen Thread dazu anschauen, hat die gleichen Werte ausgeworfen
                    https://forum.iobroker.net/topic/68713/gelöst-admin-adapter-restart-loop/3
                    wendy2702 N 2 Replies Last reply Reply Quote 1
                    • wendy2702
                      wendy2702 @JohnnyBahama last edited by
                      @johnnybahama das hat @Homoran schon im dritten Post geschrieben
                      https://forum.iobroker.net/topic/72131/iobroker-startet-jeden-abend-neu/3#
                      • N
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : arm64
                         09:29:50 up 14:23,  2 users,  load average: 0.13, 0.10, 0.09
                        CPU threads: 4
                        Current issues:
                                       Local time: Thu 2024-01-25 09:29:50 CET
                                   Universal time: Thu 2024-01-25 08:29:50 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        /home/pi
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:            1.9G        1.7G        108M        229K        225M        262M
                        Swap:           104M        7.6M         97M
                        Total:          2.0G        1.7G        205M
                                 1848 M total memory
                                 1597 M used memory
                                  976 M active memory
                                  624 M inactive memory
                                  103 M free memory
                                    1 M buffer memory
                                  213 M swap cache
                                   99 M total swap
                                    7 M used swap
                                   92 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /var:
                        1.1G    /var/
                        627M    /var/log
                        625M    /var/log/journal/646f283dbad041b98afadc09481d9d55
                        203M    /var/cache
                        Archived and active journals take up 624.8M in the file system.
                        345M    /opt/iobroker/iobroker-data/
                        43M     /opt/iobroker/iobroker-data/objects.jsonl
                        USB-Devices by-id:
                        /usr/bin/npm            10.2.3
                        /usr/bin/npx            10.2.3
                        nodejs:
                          Version table:
                             18.13.0+dfsg1-1 500
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: redis
                        admin:          6.12.0
                        javascript:     7.1.6
                        Adapter State
                        + instance is alive
                         Objects database error: read ECONNRESET
                         Objects database error: connect ECONNREFUSED 127.0.0.1:9001
                        Objects and States
                        Objects:        6085
                        States:         16776
                        Pending Updates: 7
                        tcp        0      0 192.168.178.60:1884     0.0.0.0:*               LISTEN      1001       542361     26603/io.mqtt.0
                        tcp        0      0 192.168.178.60:1885     0.0.0.0:*               LISTEN      1001       542362     26603/io.mqtt.0
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       539776     26064/iobroker.js-c
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       539836     26082/io.admin.0
                        2024-01-25 09:33:05.695  - info: javascript.0 (26128) Start javascript script.js.common.Waschmaschine_fertig_Ansage
                        2024-01-25 09:33:05.703  - info: javascript.0 (26128) script.js.common.Waschmaschine_fertig_Ansage: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                        2024-01-25 09:33:05.778  - info: whatsapp-cmb.0 (26147) starting. Version 0.2.3 in /opt/iobroker/node_modules/iobroker.whatsapp-cmb, node: v18.19.0, js-controller: 5.0.17
                        2024-01-25 09:33:06.702  - info: host.raspi instance scheduled system.adapter.ical.1 0 3 * * *
                        2024-01-25 09:33:06.718  - info: host.raspi instance system.adapter.ical.1 started with pid 26215
                        2024-01-25 09:33:08.050  - info: ical.0 (26185) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
                        2024-01-25 09:33:08.502  - info: ical.0 (26185) processing URL: Abfall /opt/iobroker/Abfall2024.ics
                        2024-01-25 09:33:10.149  - info: ical.1 (26215) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
                        2024-01-25 09:33:10.250  - info: alexa2.0 (26157) Initialize all Device states ...
                        2024-01-25 09:33:10.688  - info: host.raspi instance system.adapter.mqtt.0 started with pid 26603
                        2024-01-25 09:33:10.898  - info: ical.1 (26215) processing URL: Frei https://calendar.google.com/calendar/ical/l8asmcgpumc56d3n6opmji52to%40group.calendar.google.com/public/basic.ics
                        2024-01-25 09:33:12.112  - warn: ical.0 (26185) Error reading from URL "http://www.eventfabrik24.de/Abfall2023.ics": 404
                        2024-01-25 09:33:12.119  - warn: ical.0 (26185) Error reading "http://www.eventfabrik24.de/Abfall2023.ics": Cannot read URL: "http://www.eventfabrik24.de/Abfall2023.ics"
                        2024-01-25 09:33:14.677  - info: host.raspi instance scheduled system.adapter.openweathermap.0 0 23 * * *
                        2024-01-25 09:33:14.692  - info: host.raspi instance system.adapter.openweathermap.0 started with pid 26625
                        2024-01-25 09:33:16.006  - info: ical.1 (26215) Terminated (NO_ERROR): Without reason
                        2024-01-25 09:33:16.687  - info: host.raspi instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
                        2024-01-25 09:33:17.233  - info: ical.0 (26185) Terminated (NO_ERROR): Without reason
                        2024-01-25 09:33:18.010  - info: host.raspi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                        2024-01-25 09:33:18.790  - info: host.raspi instance system.adapter.rpi2.0 started with pid 27004
                        2024-01-25 09:33:20.344  - info: openweathermap.0 (26625) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v18.19.0, js-controller: 5.0.17
                        2024-01-25 09:33:22.289  - info: rpi2.0 (27004) starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.rpi2, node: v18.19.0, js-controller: 5.0.17
                        2024-01-25 09:33:22.678  - error: rpi2.0 (27004) No Value found for cpu_frequency
                        2024-01-25 09:33:22.690  - info: host.raspi instance system.adapter.sonoff.0 started with pid 27052
                        2024-01-25 09:33:26.745  - info: host.raspi instance system.adapter.tr-064.1 started with pid 27060
                        iob diag has finished.
                        Press any key for a summary
                          *** MEMORY ***
                          Das wird zu wenig sein. Bei Lastspitzen knickt dir das weg.
                          • N
                            norman @JohnnyBahama last edited by
                            @johnnybahama
                            nicht, dass ich dir nicht glauben will, will das nur etwas genauer verstehen. er kommt bei mir ja gar nicht über die 1500MB Speicherbedarf drüber bevor er abschmiert, da is ja eigentlich noch etwas Luft.....
                            Thomas Braun J 2 Replies Last reply Reply Quote 0
                              @norman
                              Da sind noch 262MB verfügbar. So viel Luft ist da also nicht mehr.
                              Wenn jetzt ein Adapter sich mehr genehmigen muss (z. B. weil ein Backup läuft) hast du ein Problem.
                              • N
                                @thomas-braun said in IObroker startet jeden Abend neu!:
                                @norman
                                ja, knapp is es schon....aber es gibt doch noch mehr Leute hier, die IOb auf nem 2GBPi4 rennen haben.....
                                Oder ich hab zuviel Instanzen am laufen 😞
                                Also auf n Pi5 gehen??
                                Thomas Braun Homoran MartinP Marc Berg 4 Replies Last reply Reply Quote 0
                                  Die haben dann aber nicht wie du da 18 Instanzen laufen.
                                  Man kann mit einem durchschnittlichen Bedarf von 80-100MB pro Instanz rechnen. Da bist du also alleine mit dem iobroker schon fast dicht. Und das Betriebssystem braucht ja auch noch was Luft zum atmen.
                                    muss kein pi5 sein, gibt auch pi4 mit 4 und 8 GB.
                                    woher weisst du das?
                                    Da wird wahrscheinlich intern schon Speicher freigeräumt indem Prozesse gestoppt werden.
                                    ...bis dann lebenswichtige Prozesse dran glauben müssen.
                                    N 1 Reply Last reply Reply Quote 1
                                    • MartinP
                                      MartinP @norman last edited by
                                      @norman said in IObroker startet jeden Abend neu!:
                                      @norman
                                      Ein Pi4 mit mehr Arbeitsspeicher, oder ein Mini-PC (NUC o.Ä.) wäre auch eine Option, wenn die IO-Pins des Pi nicht gebraucht werden....
                                      Eine weitere Option wäre, ggfs die ioBroker Installation zu verschlanken. Adapter, die man probeweise installiert hat anhalten oder deinstallieren, Aufgaben an Slave-ioBroker auslagern usw... In aller Regel ist das aber keine Lösung, die dauerhaft funktioniert ...
                                      Mein in der Signatur genanntes System kommt mit unter 10 Watt aus ... Tagesverbrauch ca 0,2 kWh ...
                                      Mein Celeron 3000 ist aber ziemlich lahm (irgendwo zwischen Pi3 und Pi4), das System hat aber auch ohne RAM und SSD nur 69€ incl Gehäuse und Netzteil als "Refurbished" gekostet...
                                      • Marc Berg
                                        Marc Berg Most Active @norman last edited by
                                        Ich finde, du hättest schon noch ein wenig Optimierungspotential, um die Zeit bis zur neuen Hardware zu überbrücken. Den Info-Adapter würde ich wegwerfen und ob man bei DER Anzahl von States eine redis-DB betreiben muss? Ich weiß nicht ...
                                        Wenn das Geld ein Thema ist und du mit der CPU Leistung zufrieden bist, warum nicht einen gebrauchten Pi4 mit 4 oder 8 GB RAM?
                                        • N
                                          norman @Homoran last edited by
                                          @homoran said in IObroker startet jeden Abend neu!:
                                          Joa, stimmt schon, macht aber preislich ja schon kaum noch einen Unterschied, da kann man das gleich auf den 5er gehen.
                                          Oder hat der HW-technisch irgendwelche Nachteile beim IOB-Betrieb?
                                          Homoran MartinP 2 Replies Last reply Reply Quote 0
                                            mal schnell bei einem Händler verglichen: bei 8GB 95 vs 79 Euro (Ohne Gewähr auf Vollständigkeit)
                                            außer dem höheren Stromverbrauch eher nicht.
                                            1598
