    4. IObroker startet jeden Abend neu!
    • N
      norman @Thomas Braun last edited by
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: raspi
             Icon name: computer
                Kernel: Linux 6.1.0-rpi7-rpi-v8
          Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       09:29:50 up 14:23,  2 users,  load average: 0.13, 0.10, 0.09
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Thu 2024-01-25 09:29:50 CET
                 Universal time: Thu 2024-01-25 08:29:50 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            1.9G        1.7G        108M        229K        225M        262M
      Swap:           104M        7.6M         97M
      Total:          2.0G        1.7G        205M
               1848 M total memory
               1597 M used memory
                976 M active memory
                624 M inactive memory
                103 M free memory
                  1 M buffer memory
                213 M swap cache
                 99 M total swap
                  7 M used swap
                 92 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  661M     0  661M   0% /dev
      tmpfs          tmpfs     185M  1.2M  184M   1% /run
      /dev/mmcblk0p2 ext4       59G  4.8G   51G   9% /
      tmpfs          tmpfs     925M     0  925M   0% /dev/shm
      /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
      tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
      [Wed Jan 24 19:06:02 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:2A:EE:F4 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c7af47fd-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Wed Jan 24 19:06:05 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Wed Jan 24 19:06:07 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET           SOURCE         FSTYPE OPTIONS
      /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.1G    /var/
      627M    /var/log
      625M    /var/log/journal/646f283dbad041b98afadc09481d9d55
      203M    /var/cache
      Archived and active journals take up 624.8M in the file system.
      /opt/iobroker/backups:
      28M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      345M    /opt/iobroker/iobroker-data/
      224M    /opt/iobroker/iobroker-data/files
      76M     /opt/iobroker/iobroker-data/backup-objects
      67M     /opt/iobroker/iobroker-data/files/javascript.admin
      48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
      43M     /opt/iobroker/iobroker-data/objects.jsonl
      33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
      8.3M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
      USB-Devices by-id:
      /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B00193675CD-if00
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
           18.19.0+dfsg-6~deb12u1 500
       *** 18.19.0-1nodesource1 1001
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1 500
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: redis
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.12.0
      javascript:     7.1.6
      Adapters from github:   2
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspi                                    -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : raspi                                    -  enabled
        system.adapter.backitup.0               : backitup              : raspi                                    - disabled
      + system.adapter.evohome.0                : evohome               : raspi                                    -  enabled
        system.adapter.flot.0                   : flot                  : raspi                                    - disabled
      + system.adapter.growatt.0                : growatt               : raspi                                    -  enabled
      + system.adapter.history.0                : history               : raspi                                    -  enabled
      + system.adapter.hs100.0                  : hs100                 : raspi                                    -  enabled
        system.adapter.ical.0                   : ical                  : raspi                                    -  enabled
        system.adapter.ical.1                   : ical                  : raspi                                    -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspi                                    - disabled
      + system.adapter.info.0                   : info                  : raspi                                    -  enabled
      + system.adapter.iot.0                    : iot                   : raspi                                    -  enabled
      + system.adapter.javascript.0             : javascript            : raspi                                    -  enabled
      + system.adapter.lgtv.0                   : lgtv                  : raspi                                    -  enabled
        system.adapter.mobile.0                 : mobile                : raspi                                    - disabled
      + system.adapter.mqtt.0                   : mqtt                  : raspi                                    -  enabled, port: 1884, bind: 192.168.178.60
        system.adapter.openweathermap.0         : openweathermap        : raspi                                    -  enabled
      + system.adapter.ring.0                   : ring                  : raspi                                    -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : raspi                                    -  enabled
        system.adapter.socketio.0               : socketio              : raspi                                    - disabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.0                 : sonoff                : raspi                                    -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.tr-064.1                 : tr-064                : raspi                                    -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspi                                    - disabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspi                                    - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : raspi                                    - disabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : raspi                                    - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : raspi                                    - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspi                                    - disabled
        system.adapter.vis.0                    : vis                   : raspi                                    -  enabled
        system.adapter.wallpanel.0              : wallpanel             : raspi                                    - disabled
      + system.adapter.web.0                    : web                   : raspi                                    -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.web.1                    : web                   : raspi                                    - disabled, port: 20002, bind: 0.0.0.0, run as: admin
      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspi                                    -  enabled
        system.adapter.ws.0                     : ws                    : raspi                                    - disabled, port: 8084, bind: 0.0.0.0, run as: admin
      + system.adapter.zigbee.0                 : zigbee                : raspi                                    -  enabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B00193675CD-if00
      + instance is alive
      ioBroker-Repositories
      stabil        : http://download.iobroker.net/sources-dist.json
      Active repo(s): stabil
      Installed ioBroker-Instances
      Used repository: stabil
       Objects database error: read ECONNRESET
       Objects database error: connect ECONNREFUSED 127.0.0.1:9001
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
      Adapter    "growatt"      : 3.2.1    , installed 3.2.1
      Adapter    "hs100"        : 2.2.0    , installed 2.2.0
      Adapter    "iot"          : 2.0.11   , installed 2.0.11
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "lgtv"         : 2.1.2    , installed 2.1.2
      Adapter    "mobile"       : 1.0.1    , installed 1.0.1
      Adapter    "mqtt"         : 5.1.0    , installed 5.1.0
      Adapter    "openweathermap": 1.0.4   , installed 1.0.4
      Adapter    "ring"         : 5.0.10   , installed 5.0.10
      Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
      Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
      Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
      Adapter    "wallpanel"    : 0.3.11   , installed 0.3.11
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
      Objects and States
      Objects:        6085
      States:         16776
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 7
      *** Listening Ports ***
      tcp        0      0 192.168.178.60:1884     0.0.0.0:*               LISTEN      1001       542361     26603/io.mqtt.0
      tcp        0      0 192.168.178.60:1885     0.0.0.0:*               LISTEN      1001       542362     26603/io.mqtt.0
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       539776     26064/iobroker.js-c
      tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      106        13880      613/redis-server 12
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13837      652/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       539836     26082/io.admin.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          13839      652/sshd: /usr/sbin
      tcp6       0      0 ::1:6379                :::*                    LISTEN      106        13881      613/redis-server 12
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        13770      453/avahi-daemon: r
      udp        0      0 0.0.0.0:36397           0.0.0.0:*                           104        13772      453/avahi-daemon: r
      udp6       0      0 :::60534                :::*                                104        13773      453/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        13771      453/avahi-daemon: r
      udp6       0      0 fe80::c189:98ca:96e:546 :::*                                0          13959      539/NetworkManager
      2024-01-25 09:33:05.695  - info: javascript.0 (26128) Start javascript script.js.common.Waschmaschine_fertig_Ansage
      2024-01-25 09:33:05.703  - info: javascript.0 (26128) script.js.common.Waschmaschine_fertig_Ansage: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      2024-01-25 09:33:05.778  - info: whatsapp-cmb.0 (26147) starting. Version 0.2.3 in /opt/iobroker/node_modules/iobroker.whatsapp-cmb, node: v18.19.0, js-controller: 5.0.17
      2024-01-25 09:33:06.702  - info: host.raspi instance scheduled system.adapter.ical.1 0 3 * * *
      2024-01-25 09:33:06.718  - info: host.raspi instance system.adapter.ical.1 started with pid 26215
      2024-01-25 09:33:08.050  - info: ical.0 (26185) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
      2024-01-25 09:33:08.502  - info: ical.0 (26185) processing URL: Abfall /opt/iobroker/Abfall2024.ics
      2024-01-25 09:33:10.149  - info: ical.1 (26215) starting. Version 1.13.3 in /opt/iobroker/node_modules/iobroker.ical, node: v18.19.0, js-controller: 5.0.17
      2024-01-25 09:33:10.250  - info: alexa2.0 (26157) Initialize all Device states ...
      2024-01-25 09:33:10.688  - info: host.raspi instance system.adapter.mqtt.0 started with pid 26603
      2024-01-25 09:33:10.898  - info: ical.1 (26215) processing URL: Frei https://calendar.google.com/calendar/ical/l8asmcgpumc56d3n6opmji52to%40group.calendar.google.com/public/basic.ics
      2024-01-25 09:33:12.112  - warn: ical.0 (26185) Error reading from URL "http://www.eventfabrik24.de/Abfall2023.ics": 404
      2024-01-25 09:33:12.119  - warn: ical.0 (26185) Error reading "http://www.eventfabrik24.de/Abfall2023.ics": Cannot read URL: "http://www.eventfabrik24.de/Abfall2023.ics"
      2024-01-25 09:33:14.677  - info: host.raspi instance scheduled system.adapter.openweathermap.0 0 23 * * *
      2024-01-25 09:33:14.692  - info: host.raspi instance system.adapter.openweathermap.0 started with pid 26625
      2024-01-25 09:33:16.006  - info: ical.1 (26215) Terminated (NO_ERROR): Without reason
      2024-01-25 09:33:16.687  - info: host.raspi instance system.adapter.ical.1 terminated with code 0 (NO_ERROR)
      2024-01-25 09:33:17.233  - info: ical.0 (26185) Terminated (NO_ERROR): Without reason
      2024-01-25 09:33:18.010  - info: host.raspi instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
      2024-01-25 09:33:18.790  - info: host.raspi instance system.adapter.rpi2.0 started with pid 27004
      2024-01-25 09:33:20.344  - info: openweathermap.0 (26625) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v18.19.0, js-controller: 5.0.17
      2024-01-25 09:33:22.289  - info: rpi2.0 (27004) starting. Version 1.3.2 in /opt/iobroker/node_modules/iobroker.rpi2, node: v18.19.0, js-controller: 5.0.17
      2024-01-25 09:33:22.678  - error: rpi2.0 (27004) No Value found for cpu_frequency
      2024-01-25 09:33:22.690  - info: host.raspi instance system.adapter.sonoff.0 started with pid 27052
      2024-01-25 09:33:26.745  - info: host.raspi instance system.adapter.tr-064.1 started with pid 27060
      iob diag has finished.
      Press any key for a summary
        Thomas Braun Most Active @norman last edited by
        @norman sagte in IObroker startet jeden Abend neu!:
        *** MEMORY ***
        Das wird zu wenig sein. Bei Lastspitzen knickt dir das weg.
        • N
          norman @JohnnyBahama last edited by
          @johnnybahama
          nicht, dass ich dir nicht glauben will, will das nur etwas genauer verstehen. er kommt bei mir ja gar nicht über die 1500MB Speicherbedarf drüber bevor er abschmiert, da is ja eigentlich noch etwas Luft.....
          Thomas Braun J 2 Replies Last reply Reply Quote 0
            @norman
            Da sind noch 262MB verfügbar. So viel Luft ist da also nicht mehr.
            Wenn jetzt ein Adapter sich mehr genehmigen muss (z. B. weil ein Backup läuft) hast du ein Problem.
            • N
              @thomas-braun said in IObroker startet jeden Abend neu!:
              @norman
              ja, knapp is es schon....aber es gibt doch noch mehr Leute hier, die IOb auf nem 2GBPi4 rennen haben.....
              Oder ich hab zuviel Instanzen am laufen 😞
              Also auf n Pi5 gehen??
              Thomas Braun Homoran MartinP Marc Berg 4 Replies Last reply Reply Quote 0
                Die haben dann aber nicht wie du da 18 Instanzen laufen.
                Man kann mit einem durchschnittlichen Bedarf von 80-100MB pro Instanz rechnen. Da bist du also alleine mit dem iobroker schon fast dicht. Und das Betriebssystem braucht ja auch noch was Luft zum atmen.
                  Homoran Global Moderator Administrators @norman last edited by
                  muss kein pi5 sein, gibt auch pi4 mit 4 und 8 GB.
                  woher weisst du das?
                  Da wird wahrscheinlich intern schon Speicher freigeräumt indem Prozesse gestoppt werden.
                  ...bis dann lebenswichtige Prozesse dran glauben müssen.
                  N 1 Reply Last reply Reply Quote 1
                  • MartinP
                    MartinP @norman last edited by
                    @norman said in IObroker startet jeden Abend neu!:
                    @norman
                    Ein Pi4 mit mehr Arbeitsspeicher, oder ein Mini-PC (NUC o.Ä.) wäre auch eine Option, wenn die IO-Pins des Pi nicht gebraucht werden....
                    Eine weitere Option wäre, ggfs die ioBroker Installation zu verschlanken. Adapter, die man probeweise installiert hat anhalten oder deinstallieren, Aufgaben an Slave-ioBroker auslagern usw... In aller Regel ist das aber keine Lösung, die dauerhaft funktioniert ...
                    Mein in der Signatur genanntes System kommt mit unter 10 Watt aus ... Tagesverbrauch ca 0,2 kWh ...
                    Mein Celeron 3000 ist aber ziemlich lahm (irgendwo zwischen Pi3 und Pi4), das System hat aber auch ohne RAM und SSD nur 69€ incl Gehäuse und Netzteil als "Refurbished" gekostet...
                    • Marc Berg
                      Marc Berg Most Active @norman last edited by
                      Ich finde, du hättest schon noch ein wenig Optimierungspotential, um die Zeit bis zur neuen Hardware zu überbrücken. Den Info-Adapter würde ich wegwerfen und ob man bei DER Anzahl von States eine redis-DB betreiben muss? Ich weiß nicht ...
                      Wenn das Geld ein Thema ist und du mit der CPU Leistung zufrieden bist, warum nicht einen gebrauchten Pi4 mit 4 oder 8 GB RAM?
                      • N
                        norman @Homoran last edited by
                        @homoran said in IObroker startet jeden Abend neu!:
                        Joa, stimmt schon, macht aber preislich ja schon kaum noch einen Unterschied, da kann man das gleich auf den 5er gehen.
                        Oder hat der HW-technisch irgendwelche Nachteile beim IOB-Betrieb?
                        Homoran MartinP 2 Replies Last reply Reply Quote 0
                          mal schnell bei einem Händler verglichen: bei 8GB 95 vs 79 Euro (Ohne Gewähr auf Vollständigkeit)
                          außer dem höheren Stromverbrauch eher nicht.
                          • MartinP
                            @norman Es wurde ja vorgeschlagen einen gebrauchten Pi4 zu versuchen, aber da habe ich schon gewisse Vorbehalte. Ein geschrotteter IO-Pin ist nicht schnell erkennbar, und ansonsten könnte der Pi dann bei ersten Tests unauffällig sein ....
                            • N
                              ja, bei Berrybase 93,90€ zu 79,90, bei 4GB Ram sind sogar knapp unter 10€ Preisunterschied
                              • N
                                norman @MartinP last edited by
                                @martinp said in IObroker startet jeden Abend neu!:
                                Joa, hab eben auch mal kurz auf Kleinanzeigen geschaut, die sind ja z.T. teuerer als neue im Netz, die haben zum Teil echt seltsame Preisvorstellungen.
                                okay, DANKE nochmals @all !
                                Ich habe jetzt mal ein paar nicht so wichtige Instanzen bzw. Spielerein deaktiviert und schaue mal, ob er jetzt so stabiler läuft.
                                Wenns so klappt, stell ich um 😉
                                Ich geb auf jeden Fall Rückmeldung!
                                • MartinP
                                  MartinP @norman last edited by MartinP
                                  Oder ein Futro S740 ...
                                  https://www.heise.de/select/ct/2023/6/2301013201757655367
                                  https://browser.geekbench.com/v5/cpu/20833684
                                  Geekbench 5.5.1 Multi Core 1449
                                  Pi5 1608
                                  Pi4 789
                                  Mein Celeron3000 426 ;-(
                                  https://browser.geekbench.com/v5/cpu/19722005
                                  Bei den Futros muss man aber aufpassen, die S720 und S920 werden DEUTLICH günstiger angeboten, sind aber mit alten AMD G-Prozessoren ausgestattet, sind auch eher bei 300 .. 500 im Geekbench... Stromverbrauch liegt auch bei um die 10 Watt
                                    JohnnyBahama @norman last edited by JohnnyBahama
                                    @norman Das wird sich auch nicht ändern. Nachdem du umgezogen bist, siehst du das du über die 2GB kommst. Fakt ist, du kannst dich jetzt weiter ärgern das er absgürzt oder Adapter deinstallieren damit es wieder geht oder ne größere Kiste besorgen und sorgenfrei sein.
                                    Nimm am besten nen Futro und nicht nen Pi. Die sind etwas grßer ja, aber da kannste die Ramriegel wenigstens tauschen. Zudem sind die günstiger.
                                    • N
                                      @johnnybahama said in IObroker startet jeden Abend neu!:
                                      Ja, wie gesagt, die Adapter deinstallieren war je jetzt nur mal zur Fehlersuche, soll natürlich nicht für immer so bleiben.
                                      Wollte ja nur sichergehen, dass der RAM die einzige ursache ist.
                                      @all, es scheint aber tatsächlich zu funktionieren, seitdem ich ein paar Adapter deaktiviert habe läufts nun schon über 2 Tage durch, scheint wirklich wohl nur am RAM zu liegen, danke für die Hilfe.
                                      Eine Frage hätte ich aber noch, mir ist aufgefallen dass jeden morgen die RAM-Auslastung ein klein wenig einknickt, genau zu der Zeit, und das täglich, hab ich das hier im LOG stehen, weiß jemand, was es damit auf sich hat? Oder ist das normal:
                                      pi@raspi:~ $ iob logs admin
                                      2024-01-27 09:32:56.739  - info: admin.0 (26082) Adapter rating updated
                                      2024-01-27 09:33:11.746  - info: admin.0 (26082) Request actual repository...
                                      2024-01-27 09:33:18.404  - info: admin.0 (26082) Repository received successfull                                                       y.
                                      2024-01-27 11:20:05.313  - info: admin.0 (26082) ==> Connected system.user.admin                                                        from ::ffff:192.168.178.94
                                      pi@raspi:~ $
                                        @norman
                                        Normal.
                                        Da schaut der ioBroker ob es Updates gibt und schickt statische Daten.
                                        1599
