    3. Einsteigerfragen
    4. Automatisierung
    5. ( Gelöst) Garagenbeleuchtung reagiert nicht
    • Sezer
      Sezer @DJMarc75 last edited by Homoran
      @djmarc75 Hatte gedacht der reagiert schon nicht vielleicht ist der Anfang nur Falsch. Hast aber recht.
        <block type="on_ext" id="GQIs@i(E;alI-2YSpgd@" x="-2687" y="-3412">
          <value name="OID0">
            <shadow type="field_oid" id="vmn]dEH.dtw+nS)CMGAs">
              <field name="oid">knx.0.Beleuchtung.Garage_Antrieb.Garagentor_Status_Tor_fährt</field>
            <block type="control" id=",5Th~j85zjEul[hjL6f]">
              <field name="OID">wled.0.e8db84e16125.bri</field>
                <block type="math_number" id="GaLez8j=$O]s[C2aM3UO">
                  <field name="NUM">255</field>
                <block type="controls_if" id="m^?.SDbC2hIAR|TSjBzD">
                    <block type="logic_operation" id="%t?qGdKFJ,ok/p*!,WwA">
                      <field name="OP">AND</field>
                        <block type="logic_compare" id="Tbg:GyG|U6WplQ!Vgt+K">
                          <field name="OP">EQ</field>
                            <block type="get_value" id="UX%w2t;J{j+0Jg-Ndirh">
                              <field name="OID">knx.0.Beleuchtung.Garage_Antrieb.Garagentor_Status_Tor_fährt</field>
                            <block type="logic_boolean" id="9a2JO(|gnd#[gBd-u6qy">
                        <block type="logic_compare" id="eG-t8w6svdTVx#RP~KQ2">
                            <block type="get_value" id="|n+$~CjEr5}*rb/x%%XZ">
                            <block type="logic_boolean" id="l$J_S0rLhv|=,k!jp$f]">
                    <block type="control" id="0FN@=:9[V:VMV(3q@]V8">
                      <field name="OID">wled.0.e8db84e16125.seg.0.col.0_HEX</field>
                        <block type="colour_picker" id="~QqI`tU=2(JzdsOwJ?e]">
                          <field name="COLOUR">#ff0000</field>
                        <block type="control" id="aNsgLKWr8d3d2pp:U$LX">
                          <field name="OID">wled.0.e8db84e16125.seg.0.sx</field>
                            <block type="math_number" id="-|6`nbA6_~]_e:=S)HCX">
                              <field name="NUM">150</field>
                            <block type="control" id="TonY@DG~?)S+7x30]Dyr">
                              <field name="OID">wled.0.e8db84e16125.seg.0.fx</field>
                                <block type="math_number" id="87RX20#eqAcjTAE_HP^$">
                                  <field name="NUM">60</field>
                                <block type="control" id="tACF}f9#YI%kb)_^~#tK">
                                  <field name="OID">wled.0.e8db84e16125.seg.0.ix</field>
                                    <block type="math_number" id="3)?eMSV_T6rr8vPxLDM`">
                                      <field name="NUM">240</field>
                                    <block type="controls_if" id="N1N[)/BO`pF[czQ93kCV">
                                        <block type="logic_compare" id="[bkQ6s.C~/t:(654{#zS">
                                            <block type="get_value" id="v#2OQsxo+_^wXxh90J#W">
                                              <field name="OID">wled.0.e8db84e16125.on</field>
                                            <block type="logic_boolean" id="M%LNwyQa[pbyTaJ$)-}M">
                                        <block type="control" id="dq7,xCgtU:6,mwQ159$Z">
                                            <block type="logic_boolean" id=",f0aP;aZkZU=OfR-YPNv">
                                        <block type="controls_if" id="+mA^40o}yz6AO:6KZjiD">
                                            <block type="logic_operation" id="TohssJa+VdIz{!m^{]kU">
                                                <block type="logic_compare" id="k|ZhxV9B7c/-C{DAAVS@">
                                                    <block type="get_value" id="kT|*c=akL2eL||OIUG*w">
                                                      <field name="OID">knx.0.Beleuchtung.Garage_Antrieb.Garagentor_Status_Position</field>
                                                    <block type="math_number" id="7?2|eAXN?S3dP01zL}os">
                                                      <field name="NUM">100</field>
                                                <block type="logic_compare" id=".8.^4Y$xbKkH6^~OA`p2">
                                                    <block type="get_value" id="6do)BtbH`ki~U0Zk6Jb3">
                                                      <field name="OID">knx.0.Beleuchtung.Garage_Antrieb.Garagentor_Status_Oben</field>
                                                    <block type="logic_boolean" id="J|dGa#3tPYK$3]XZ)V,d">
                                            <block type="control" id="f_I;.`nF_*Y,keUX-sX2">
                                                <block type="colour_picker" id="7!?#)Qh||Ds,HgKqFs7.">
                                                  <field name="COLOUR">#33ff33</field>
                                                <block type="controls_if" id="cXTc:dK~jiqnXPOW{mXe">
                                                    <block type="logic_compare" id="$8FWvHL`ALzdAf])Sp5R">
                                                        <block type="get_value" id="gKAu^oX|@A^ZLjkb=wf.">
                                                        <block type="logic_boolean" id="oBTm=X1%@]k-wcC(bsQj">
                                                    <block type="control" id="$P~8xhYnUtR{;bD8_w5$">
                                                      <field name="OID">wled.0.e8db84e16125.seg.0.on</field>
                                                        <block type="logic_boolean" id="NE[;nD[Uf^TBp.@s6:sS">
                                                    <block type="timeouts_wait" id="GCb`Y8H!?N^rLk~@KVuo">
                                                      <field name="DELAY">3</field>
                                                        <block type="control" id="viL)Yw+_JR78%{Ei(L6u">
                                                            <block type="colour_picker" id="QZM|eLB0U9tqK7`|{nfX">
                                                              <field name="COLOUR">#ffffff</field>
                                                            <block type="control" id="r=Y#M}%^7:Qd$Uq?(I`=">
        <block type="math_number" id="@lH3HROapgMKw/C]d3nQ">
        <field name="NUM">215</field>
        <block type="control" id="E7G*)C[COUSr?l4YMU14">
        <block type="math_number" id="UWfddRq)6DVMs7a,k.)N">
        <field name="NUM">0</field>
        <block type="controls_if" id="j+go^vPn.];!D?,0t.nN">
        <block type="logic_compare" id="eNp0nwk8dLEJgjVSqY0;">
        <block type="get_value" id="mGs9h@4yCa],U|K/t7o}">
        <block type="logic_boolean" id="Zcf_I}vE~?)O;;E8|/am">
        <block type="control" id="/%bg?bqlRPQf0bsYuvMW">
        <block type="logic_boolean" id="LVDUgEhXX.[Q^/D1FA9G">
        <block type="timeouts_wait" id="R43lb1vG!PcSenMjz)O+">
        <block type="control" id="DYLdpWUdRQ[J%U-4dxx#">
        <block type="logic_boolean" id="lM6Q)sdGdY|DeFXzV_6]">
        <block type="timeouts_wait" id="V_w:J!6QHz~s.Mov.wrw">
        <field name="DELAY">1500</field>
        <field name="UNIT">ms</field>
        <block type="control" id="i[/$u*#{wd/C%bNO,xt6">
        <block type="logic_boolean" id="}g!.2eE4p5q@|6B9{~f_">
        <block type="control" id="C{f1HunIEv3FS^)|U5Vp">
        <block type="math_number" id="(@P--X?MknBg=lGfIxDO">
        <field name="NUM">85</field>
        <block type="control" id="c%,?0B:5N=`7R=2AiTRo">
        <block type="math_number" id="^%dqsT:Z@-$K#Y^va5{2">
        <field name="NUM">45</field>
        <block type="controls_if" id="%0FB5~Ed`A.=M{5q~u-|">
        <block type="logic_compare" id="a9YV9!:f;_$Ba`i/()4P">
        <block type="get_value" id="g60u=H1WwrXni9~A+c8F">
        <block type="logic_boolean" id="BB4OdZOGc_-J:fP@g!A^">
        <block type="control" id="#G?:^DAAcmcO,-FtUC-B">
        <block type="logic_boolean" id=")IL(AVk)[[^_l@?FO|]X">
        <block type="timeouts_wait" id="uK)[sqBUE(+(W!u(xM_x">
        <field name="DELAY">10</field>
        <block type="control" id="c(bzo6lKU9F:AuIJ*}X+">
        <block type="logic_boolean" id="P]ev+]NpA}Bm{E!,OPDt">
      • Sezer
        @djmarc75 ```
        code_text
            <value name="OID0">
        • DJMarc75
          DJMarc75 @Sezer last edited by
          @sezer
          bitte wie erwähnt in CODETAGS
          steht hier genau beschrieben:
          https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge
          Sezer 1 Reply Last reply Reply Quote 0
          • Sezer
            @djmarc75 sorry habe ich falsch verstanden. habe ich gemacht
            • DJMarc75
              DJMarc75 @Sezer last edited by DJMarc75
              @sezer
              Kann niemand importieren weil der Code nicht vollständig ist.
              Bitte 1 anklicken, danach 2 und dann hier nochmals in Codetags einfügen
              Sezer 1 Reply Last reply Reply Quote 1
              • Sezer
                @djmarc75 ```
                code_text
                    <value name="OID0">
                • DJMarc75
                  @sezer leider wieder nicht die erste Zeile vom Blockly kopiert 😉
                  Hab die mir jetzt mal selber eingefügt und schaue mir das morgen mal an 🙂
                  Sezer Homoran 2 Replies Last reply Reply Quote 2
                  • Sezer
                    @djmarc75 super hört sich gut an. Danke dir im vorraus
                    habe auf Blöcke exportieren gedrückt und kopiert.
                    hab ehrlich, paar tage damit verbracht und habs nicht geschaft.
                      Homoran Global Moderator Administrators @DJMarc75 last edited by
                      @djmarc75 könntest du (jetzt noch schnell) einen lesbaren Screenshot produzieren?
                      • DJMarc75
                        DJMarc75 @Homoran last edited by
                        @homoran sagte in Garagenbeleuchtung reagiert nicht:
                        leider nein, da das Skript meine Auflösung sprengt 🤡 (bin grad nur am Laptop)
                        Aber ich teile es mal /2 😉
                        Im ersten Teil ist schon einiges Verbogen - bin am hinbiegen 😉
                        Homoran Sezer 2 Replies Last reply Reply Quote 1
                          @djmarc75 sagte in Garagenbeleuchtung reagiert nicht:
                          ja, direkt im falls 2x das selbe per und verknüpft.
                          Da muss wohl was anderes rein
                          • DJMarc75
                            Die KNX Bausteine sind alle identisch - das kann nicht klappen
                            • Sezer
                              @djmarc75 Hat es mehrere male versucht und die Objekte mal geändert. Aber das problem ist, das er nicht mal auf den Trigger reagiert. Da passiert einfach nichts.
                              Wenn ich den trigger mit zwei normalen leuchten im Haus miteinander verknüpfe funktioniert es. Nur halt mit dem w-led irgendwie nicht. Wie gesagt ,es hatte einmal funktioniert da blinkte es nachdem ich die garage öffnete das er nur rot geblinkt hat. Da habe ich gedacht jetzt hast du es verstanden , paar Sachen geändert und danach passierte Garnichts mehr.
                              DJMarc75 Sezer 2 Replies Last reply Reply Quote 0
                              • DJMarc75
                                @sezer ich schau morgen mal 😉 Frau und Bett ruft 😄
                                • Sezer
                                  Sezer @Sezer last edited by
                                  @sezer Ok wünsche euch eine gute Nacht
                                  • Sezer
                                    @djmarc75 Habe gerade alle Grundvoraussetzungen überprüft.
                                    Habe alles noch einmal 2min Stromlos gemacht. Kann alles über dem Rechner über iObroker steuern. Habe auch zugriff auf die w-led sowohl beim iObroker und bei Eingabe der ip-adresse im Browser. Alles ist im Aktuellen zustand
                                    • DJMarc75
                                      @sezer bin dabei es irgendwie nachzubauen - kann noch bissle dauern - mach um 22 Uhr Feierabend 👨‍🍳
                                      • Sezer
                                        @djmarc75 Ach kein ding und kein stress , bin froh das du ,ihr, euch das überhaupt anguckt und mir helfen wollt. Finde ich mega cool.
                                        Vielen lieben Dank
                                        • DJMarc75
                                          @sezer
                                          probier mal so:
                                          • Sezer
                                            @djmarc75 ok cool teste ich gleich sofort.Hab grad kurz besuch.
                                            Also so wie es ist. Komplett so alles zusammen fügen. Also mit 2 trigger und so laufen lassen. top.
                                            vielen dank für deine mühe
                                            ich gib dir bescheid.
                                            1.3k
                                            2254
