    3. Einsteigerfragen
    4. HILFE: IOB läuft aber ich kann ihn nicht erreichen!
      Thomas Braun Most Active @Fibricus last edited by
      @fibricus
      Dann scrollst du einfach nach oben und kopierst die Langfassung.
        Fibricus @Homoran last edited by Fibricus
        @homoran hier die Langfassung (ich hoffe das ist jetzt das Richtige):
        Skript v.2023-10-10
        *** BASE SYSTEM ***
           Static hostname: U55
                 Icon name: computer-laptop
                   Chassis: laptop
          Operating System: Ubuntu 20.04.6 LTS
                    Kernel: Linux 5.15.0-91-generic
              Architecture: x86-64
        model name      : Intel(R) Core(TM) i3-5005U CPU @ 2.00GHz
        Docker          : false
        Virtualization  : none
        Kernel          : x86_64
        Userland        : amd64
        Systemuptime and Load:
         07:24:40 up 11:25,  2 users,  load average: 0.05, 0.04, 0.01
        CPU threads: 4
        This system needs to be REBOOTED!
        *** Time and Time Zones ***
                       Local time: Fri 2024-01-26 07:24:40 CET
                   Universal time: Fri 2024-01-26 06:24:40 UTC
                         RTC time: Fri 2024-01-26 06:24:40
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        iob
        /home/iob
        iob adm cdrom sudo dip plugdev lpadmin lxd sambashare iobroker
        *** X-Server-Setup ***
        X-Server:       true
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:           7.9G        2.0G        3.6G         26M        2.3G        5.5G
        Swap:          2.0G          0B        2.0G
        Total:         9.9G        2.0G        5.6G
                 7865 M total memory
                 2032 M used memory
                 1032 M active memory
                 2812 M inactive memory
                 3557 M free memory
                   20 M buffer memory
                 2255 M swap cache
                 2047 M total swap
                    0 M used swap
                 2047 M free swap
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** FILESYSTEM ***
        udev           devtmpfs  3.9G     0  3.9G   0% /dev
        tmpfs          tmpfs     787M  1.8M  785M   1% /run
        /dev/sda2      ext4      117G   12G   99G  11% /
        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
        tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
        /dev/loop0     squashfs  128K  128K     0 100% /snap/bare/5
        /dev/loop2     squashfs   64M   64M     0 100% /snap/core20/2105
        /dev/loop1     squashfs   64M   64M     0 100% /snap/core20/2015
        /dev/loop3     squashfs   75M   75M     0 100% /snap/core22/1033
        /dev/loop5     squashfs  347M  347M     0 100% /snap/gnome-3-38-2004/119
        /dev/loop6     squashfs   92M   92M     0 100% /snap/gtk-common-themes/1535
        /dev/loop9     squashfs   46M   46M     0 100% /snap/snap-store/638
        /dev/loop4     squashfs  350M  350M     0 100% /snap/gnome-3-38-2004/143
        /dev/loop10    squashfs  497M  497M     0 100% /snap/gnome-42-2204/141
        /dev/loop8     squashfs   41M   41M     0 100% /snap/snapd/20671
        /dev/loop7     squashfs   13M   13M     0 100% /snap/snap-store/959
        /dev/loop11    squashfs   41M   41M     0 100% /snap/snapd/20290
        /dev/sda1      vfat      511M   12M  500M   3% /boot/efi
        tmpfs          tmpfs     787M   36K  787M   1% /run/user/1000
        [Thu Jan 25 19:58:48 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
        [Thu Jan 25 19:58:49 2024] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro. Quota mode: none.
        TARGET                         SOURCE      FSTYPE   OPTIONS
        /                              /dev/sda2   ext4     rw,relatime,errors=remount-ro
        |-/sys/kernel/tracing          tracefs     tracefs  rw,nosuid,nodev,noexec,relatime
        |-/snap/bare/5                 /dev/loop0  squashfs ro,nodev,relatime,errors=continue
        |-/snap/core20/2105            /dev/loop2  squashfs ro,nodev,relatime,errors=continue
        |-/snap/core20/2015            /dev/loop1  squashfs ro,nodev,relatime,errors=continue
        |-/snap/core22/1033            /dev/loop3  squashfs ro,nodev,relatime,errors=continue
        |-/snap/gnome-3-38-2004/119    /dev/loop5  squashfs ro,nodev,relatime,errors=continue
        |-/snap/gtk-common-themes/1535 /dev/loop6  squashfs ro,nodev,relatime,errors=continue
        |-/snap/snap-store/638         /dev/loop9  squashfs ro,nodev,relatime,errors=continue
        |-/snap/gnome-3-38-2004/143    /dev/loop4  squashfs ro,nodev,relatime,errors=continue
        |-/snap/gnome-42-2204/141      /dev/loop10 squashfs ro,nodev,relatime,errors=continue
        |-/snap/snapd/20671            /dev/loop8  squashfs ro,nodev,relatime,errors=continue
        |-/snap/snap-store/959         /dev/loop7  squashfs ro,nodev,relatime,errors=continue
        |-/snap/snapd/20290            /dev/loop11 squashfs ro,nodev,relatime,errors=continue
        `-/boot/efi                    /dev/sda1   vfat     rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro
        /var:
        3.4G    /var/
        2.6G    /var/lib
        2.2G    /var/lib/snapd
        1.6G    /var/lib/snapd/snaps
        701M    /var/log
        Archived and active journals take up 696.0M in the file system.
        /opt/iobroker/backups:
        38M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        237M    /opt/iobroker/iobroker-data/
        180M    /opt/iobroker/iobroker-data/files
        67M     /opt/iobroker/iobroker-data/files/javascript.admin
        48M     /opt/iobroker/iobroker-data/files/javascript.admin/static
        47M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
        14M     /opt/iobroker/iobroker-data/objects.jsonl
        8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
        8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
        USB-Devices by-id:
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v18.19.0
        /usr/bin/node           v18.19.0
        /usr/bin/npm            10.2.3
        /usr/bin/npx            10.2.3
        /usr/bin/corepack       0.22.0
        nodejs:
          Installed: 18.19.0-1nodesource1
          Candidate: 18.19.0-1nodesource1
          Version table:
         *** 18.19.0-1nodesource1 500
                500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             18.18.2-1nodesource1 500
             18.18.1-1nodesource1 500
             18.18.0-1nodesource1 500
             18.17.1-1nodesource1 500
             18.17.0-1nodesource1 500
             18.16.1-1nodesource1 500
             18.16.0-1nodesource1 500
             18.15.0-1nodesource1 500
             18.14.2-1nodesource1 500
             18.14.1-1nodesource1 500
             18.14.0-1nodesource1 500
             18.13.0-1nodesource1 500
             18.12.0-1nodesource1 500
             18.11.0-1nodesource1 500
             18.10.0-1nodesource1 500
             18.9.1-1nodesource1 500
             18.9.0-1nodesource1 500
             18.8.0-1nodesource1 500
             18.7.0-1nodesource1 500
             18.6.0-1nodesource1 500
             18.5.0-1nodesource1 500
             18.4.0-1nodesource1 500
             18.3.0-1nodesource1 500
             18.2.0-1nodesource1 500
             18.1.0-1nodesource1 500
             18.0.0-1nodesource1 500
             10.19.0~dfsg-3ubuntu1.3 500
                500 http://de.archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
                500 http://security.ubuntu.com/ubuntu focal-security/universe amd64 Packages
             10.19.0~dfsg-3ubuntu1 500
                500 http://de.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller:  5.0.17
        admin:          6.12.0
        javascript:     7.1.6
        Adapters from github:   0
        Adapter State
        + system.adapter.admin.0                  : admin                 : U55                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : U55                                      -  enabled
        + system.adapter.backitup.0               : backitup              : U55                                      -  enabled
          system.adapter.bshb.0                   : bshb                  : U55                                      - disabled
        + system.adapter.denon.0                  : denon                 : U55                                      -  enabled
        + system.adapter.discovery.0              : discovery             : U55                                      -  enabled
        + system.adapter.email.0                  : email                 : U55                                      -  enabled
        + system.adapter.iot.0                    : iot                   : U55                                      -  enabled
        + system.adapter.javascript.0             : javascript            : U55                                      -  enabled
        + system.adapter.ping.0                   : ping                  : U55                                      -  enabled
        + system.adapter.samsung.0                : samsung               : U55                                      -  enabled
        + system.adapter.scenes.0                 : scenes                : U55                                      -  enabled
        + system.adapter.tuya.0                   : tuya                  : U55                                      -  enabled
          system.adapter.vis.0                    : vis                   : U55                                      -  enabled
        + system.adapter.web.0                    : web                   : U55                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : U55                                      -  enabled
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.12.0   , installed 6.12.0
        Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
        Adapter    "backitup"     : 2.9.8    , installed 2.9.8
        Adapter    "bshb"         : 0.2.6    , installed 0.2.6
        Adapter    "denon"        : 1.15.4   , installed 1.15.4
        Adapter    "email"        : 1.2.2    , installed 1.2.1  [Updatable]
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
        Controller "js-controller": 5.0.17   , installed 5.0.17
        Adapter    "samsung"      : 0.5.11   , installed 0.5.11
        Adapter    "samsung_tizen": 1.0.0    , installed 1.0.0
        Adapter    "tuya"         : 3.15.0   , installed 3.15.0
        Adapter    "web"          : 6.1.10   , installed 6.1.10
        Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
        Adapter    "ws"           : 2.5.8    , installed 2.5.8
        Objects and States
        Objects:        2664
        States:         1972
        Hit:1 http://de.archive.ubuntu.com/ubuntu focal InRelease
        Hit:2 http://de.archive.ubuntu.com/ubuntu focal-updates InRelease
        Hit:3 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease
        Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
        Hit:5 http://security.ubuntu.com/ubuntu focal-security InRelease
        Reading package lists...
        Pending Updates: 19
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          32745      734/sshd: /usr/sbin
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17193      1/init
        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        24363      568/systemd-resolve
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          113685     9535/cupsd
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       34727      699/iobroker.js-con
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       34719      699/iobroker.js-con
        tcp6       0      0 :::22                   :::*                    LISTEN      0          32747      734/sshd: /usr/sbin
        tcp6       0      0 :::111                  :::*                    LISTEN      0          17197      1/init
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          113684     9535/cupsd
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       96827      8301/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       63107      4542/io.web.0
        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       57179      4440/io.tuya.0
        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       57180      4440/io.tuya.0
        udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        24362      568/systemd-resolve
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17194      1/init
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          113064     9536/cups-browsed
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           115        29940      602/avahi-daemon: r
        udp        0      0 0.0.0.0:50517           0.0.0.0:*                           115        29942      602/avahi-daemon: r
        udp6       0      0 :::111                  :::*                                0          17200      1/init
        udp6       0      0 fe80::9bba:6968:c70:546 :::*                                0          39686      611/NetworkManager
        udp6       0      0 fe80::3973:e9fd:a09:546 :::*                                0          38137      611/NetworkManager
        udp6       0      0 :::5353                 :::*                                115        29941      602/avahi-daemon: r
        udp6       0      0 :::58938                :::*                                115        29943      602/avahi-daemon: r
        2024-01-26 07:05:41.838  - info: javascript.0 (2542) script.js.Nachtlicht_Trph_runter: Nachtlicht im Treppenhaus unten ist an: null
        2024-01-26 07:05:41.876  - warn: javascript.0 (2542) getState "true" not found (3)
        2024-01-26 07:05:41.877  - warn: javascript.0 (2542)     at Object.<anonymous> (script.js.Nachtlicht_Trph_runter:54:68)
        2024-01-26 07:05:41.877  - warn: javascript.0 (2542)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
        2024-01-26 07:05:41.877  - warn: javascript.0 (2542)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
        2024-01-26 07:05:41.877  - warn: javascript.0 (2542)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62)
        2024-01-26 07:05:41.877  - warn: javascript.0 (2542)     at processImmediate (node:internal/timers:476:21)
        2024-01-26 07:05:41.877  - info: javascript.0 (2542) script.js.Nachtlicht_Trph_runter: Nachtlicht im Treppenhaus unten ist an: null
        2024-01-26 07:05:51.472  - info: javascript.0 (2542) script.js.Bewegung_im_Trph: Bewegung im Treppenhaus erkannt
        2024-01-26 07:05:51.473  - info: javascript.0 (2542) script.js.Nachtlicht_Trph_runter: Bewegung im Treppenhaus: 1
        2024-01-26 07:05:53.614  - info: javascript.0 (2542) script.js.Bewegung_im_Trph: Keine Bewegung mehr im Treppenhaus
        2024-01-26 07:05:53.614  - info: javascript.0 (2542) script.js.Nachtlicht_Trph1: Bewegung im Treppenhaus: 1
        2024-01-26 07:05:53.618  - info: javascript.0 (2542) script.js.Bewegung_im_Trph: DP Bewegung Treppenhaus ist: false
        2024-01-26 07:06:00.317  - warn: tuya.0 (4440) bfe831aa6e82295bbbojkm.20: A set command is already in progress. Can not issue a second one that also should return a response.. Try to use cloud.
        2024-01-26 07:06:06.477  - warn: javascript.0 (2542) getState "false" not found (3)
        2024-01-26 07:06:06.479  - warn: javascript.0 (2542)     at Object.<anonymous> (script.js.Nachtlicht_Trph_runter:54:68)
        2024-01-26 07:06:06.479  - warn: javascript.0 (2542)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1266:38)
        2024-01-26 07:06:06.479  - warn: javascript.0 (2542)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
        2024-01-26 07:06:06.479  - warn: javascript.0 (2542)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11229:62)
        2024-01-26 07:06:06.479  - warn: javascript.0 (2542)     at processImmediate (node:internal/timers:476:21)
        2024-01-26 07:06:06.480  - info: javascript.0 (2542) script.js.Nachtlicht_Trph_runter: Nachtlicht im Treppenhaus unten ist an: null
        2024-01-26 07:06:08.622  - info: javascript.0 (2542) script.js.Nachtlicht_Trph1: Nachtlicht im Treppenhaus ist an: false
        2024-01-26 07:13:27.066  - warn: tuya.0 (4440) bfe831aa6e82295bbbojkm.20: A set command is already in progress. Can not issue a second one that also should return a response.. Try to use cloud.
        2024-01-26 07:15:02.755  - info: javascript.0 (2542) script.js.Sprachbefehle.Fernsehen: s. w. r. drei radio
        2024-01-26 07:16:35.977  - warn: tuya.0 (4440) bfe831aa6e82295bbbojkm.20: A set command is already in progress. Can not issue a second one that also should return a response.. Try to use cloud.
          Thomas Braun Most Active @Fibricus last edited by Thomas Braun
          @fibricus sagte in HILFE: IOB läuft aber ich kann ihn nicht erreichen!:
          Danach nochmal die Ausgabe von 'iob diag'.
            Fibricus @Thomas Braun last edited by
            @thomas-braun said in HILFE: IOB läuft aber ich kann ihn nicht erreichen!:
            OK, aber nun wieder mal so ne doofe Anfängerfrage:
            Wie geht ein Reboot?
            Einfach den MiniPC am Hauptschalter "hart" runterfahren ist sicher nicht der richtige Weg...
            Sorry, für die vielleicht doofen Fragen!
              @fibricus
              sudo reboot
              Und du könntest den Desktop ausschalten.
              sudo systemctl set-default multi-user
                @thomas-braun reboot läuft, Danke.
                Aber warum den desktop Ausschalten?
                  @fibricus
                  Weil auf einem Server kein Desktop läuft. Wozu auch?
                  Was nicht läuft kann nicht kaputt gehen, braucht keine Updates, frisst keine Ressourcen und hat keine Sicherheitslücken. Also ausschalten!
                    @thomas-braun Verstehe!
                    Hier ist die neue Langfassung vom IOB diag:
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                               Chassis: laptop
                                Kernel: Linux 5.15.0-92-generic
                    Docker          : false
                    Kernel          : x86_64
                    Userland        : amd64
                     07:56:58 up 2 min,  2 users,  load average: 1.37, 0.76, 0.31
                    CPU threads: 4
                                   Local time: Fri 2024-01-26 07:56:58 CET
                               Universal time: Fri 2024-01-26 06:56:58 UTC
                                     RTC time: Fri 2024-01-26 06:56:58
                                  NTP service: active
                              RTC in local TZ: no
                    iob
                    /home/iob
                    X-Server:       true
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:           7.9G        1.5G        5.1G         12M        1.3G        6.1G
                    Swap:          2.0G          0B        2.0G
                    Total:         9.9G        1.5G        7.1G
                             7865 M total memory
                             1496 M used memory
                              579 M active memory
                             1939 M inactive memory
                             5053 M free memory
                               52 M buffer memory
                             1262 M swap cache
                             2047 M total swap
                                0 M used swap
                             2047 M free swap
                    *** FILESYSTEM ***
                    /dev/loop3     squashfs  350M  350M     0 100% /snap/gnome-3-38-2004/143
                    /dev/loop4     squashfs   75M   75M     0 100% /snap/core22/1033
                    /dev/loop5     squashfs   92M   92M     0 100% /snap/gtk-common-themes/1535
                    /dev/loop6     squashfs   46M   46M     0 100% /snap/snap-store/638
                    /dev/loop10    squashfs   41M   41M     0 100% /snap/snapd/20290
                    /dev/loop9     squashfs  497M  497M     0 100% /snap/gnome-42-2204/141
                    /dev/loop11    squashfs  347M  347M     0 100% /snap/gnome-3-38-2004/119
                    tmpfs          tmpfs     787M   28K  787M   1% /run/user/1000
                    [Fri Jan 26 07:54:23 2024] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                    [Fri Jan 26 07:54:23 2024] EXT4-fs (sda2): re-mounted. Opts: errors=remount-ro. Quota mode: none.
                    |-/snap/gnome-3-38-2004/143    /dev/loop3  squashfs ro,nodev,relatime,errors=continue
                    |-/snap/core22/1033            /dev/loop4  squashfs ro,nodev,relatime,errors=continue
                    |-/snap/gtk-common-themes/1535 /dev/loop5  squashfs ro,nodev,relatime,errors=continue
                    |-/snap/snap-store/638         /dev/loop6  squashfs ro,nodev,relatime,errors=continue
                    |-/snap/snapd/20290            /dev/loop10 squashfs ro,nodev,relatime,errors=continue
                    |-/snap/gnome-42-2204/141      /dev/loop9  squashfs ro,nodev,relatime,errors=continue
                    |-/snap/gnome-3-38-2004/119    /dev/loop11 squashfs ro,nodev,relatime,errors=continue
                    /var:
                    3.4G    /var/
                    2.6G    /var/lib
                    2.2G    /var/lib/snapd
                    710M    /var/log
                    Archived and active journals take up 704.0M in the file system.
                    245M    /opt/iobroker/iobroker-data/
                    20M     /opt/iobroker/iobroker-data/objects.jsonl
                    USB-Devices by-id:
                    /usr/bin/npm            10.2.3
                    /usr/bin/npx            10.2.3
                    nodejs:
                      Version table:
                    Errors in npm tree:
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.12.0
                    javascript:     7.1.6
                    Adapter State
                    + instance is alive
                    Adapter    "email"        : 1.2.2    , installed 1.2.2
                    Objects and States
                    Objects:        2664
                    States:         1984
                    Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Hit:4 http://de.archive.ubuntu.com/ubuntu focal-backports InRelease
                    Pending Updates: 19
                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          30700      616/cupsd
                    tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        27232      577/systemd-resolve
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       36157      713/iobroker.js-con
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       37132      713/iobroker.js-con
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          32088      737/sshd: /usr/sbin
                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17666      1/init
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       41247      1139/io.admin.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       45924      2552/io.web.0
                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          30699      616/cupsd
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          32090      737/sshd: /usr/sbin
                    tcp6       0      0 :::111                  :::*                    LISTEN      0          17670      1/init
                    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          33069      690/cups-browsed
                    udp        0      0 0.0.0.0:50014           0.0.0.0:*                           115        27584      611/avahi-daemon: r
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           115        27582      611/avahi-daemon: r
                    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       48358      2465/io.tuya.0
                    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       48359      2465/io.tuya.0
                    udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        27231      577/systemd-resolve
                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17667      1/init
                    udp6       0      0 fe80::9bba:6968:c70:546 :::*                                0          39548      620/NetworkManager
                    udp6       0      0 fe80::3973:e9fd:a09:546 :::*                                0          35628      620/NetworkManager
                    udp6       0      0 :::5353                 :::*                                115        27583      611/avahi-daemon: r
                    udp6       0      0 :::60866                :::*                                115        27585      611/avahi-daemon: r
                    udp6       0      0 :::111                  :::*                                0          17673      1/init
                    2024-01-26 07:55:36.368  - info: alexa2.0 (2482) Initialization Done ...
                    2024-01-26 07:55:39.417  - info: tuya.0 (2465) bfe9da455b46e19c0cuq7w: Error on Reconnect (3): connect EHOSTUNREACH 192.168.178.86:6668
                    2024-01-26 07:55:41.721  - info: tuya.0 (2465) 5657716640f520e8def5: Error on Reconnect (3): connect EHOSTUNREACH 192.168.178.38:6668
                    2024-01-26 07:55:43.257  - info: tuya.0 (2465) bf6ee706266ec98130pnyr: Error on Reconnect (3): connect EHOSTUNREACH 192.168.178.85:6668
                    2024-01-26 07:55:44.988  - info: tuya.0 (2465) bfff12885558eedc4fgvhi: Error on Reconnect (3): connect EHOSTUNREACH 192.168.178.76:6668
                    2024-01-26 07:55:46.041  - info: tuya.0 (2465) bfefcf5b326f3b0441j3bf: Error on Reconnect (3): connect EHOSTUNREACH 192.168.178.88:6668
                    2024-01-26 07:55:47.129  - info: tuya.0 (2465) bf4b75d73e9fcb0325tgur: Error on Reconnect (3): connect EHOSTUNREACH 192.168.178.81:6668
                    2024-01-26 07:55:49.081  - info: tuya.0 (2465) bf73010fbd58befe9fav7o: Error on Reconnect (5): connect EHOSTUNREACH 192.168.178.84:6668
                    2024-01-26 07:56:10.200  - info: tuya.0 (2465) bf3188beeaf49dab6082c1: Error on Reconnect (5): connect EHOSTUNREACH 192.168.178.81:6668
                    2024-01-26 07:56:11.864  - info: tuya.0 (2465) bfec117f5152ff5fcffeej: Error on Reconnect (5): connect EHOSTUNREACH 192.168.178.77:6668
                    2024-01-26 07:56:22.489  - info: tuya.0 (2465) bfe9da455b46e19c0cuq7w: Error on Reconnect (5): connect EHOSTUNREACH 192.168.178.86:6668
                    2024-01-26 07:56:24.793  - info: tuya.0 (2465) 5657716640f520e8def5: Error on Reconnect (5): connect EHOSTUNREACH 192.168.178.38:6668
                    2024-01-26 07:56:26.329  - info: tuya.0 (2465) bf6ee706266ec98130pnyr: Error on Reconnect (5): connect EHOSTUNREACH 192.168.178.85:6668
                    2024-01-26 07:56:28.057  - info: tuya.0 (2465) bfff12885558eedc4fgvhi: Error on Reconnect (5): connect EHOSTUNREACH 192.168.178.76:6668
                    2024-01-26 07:56:29.113  - info: tuya.0 (2465) bfefcf5b326f3b0441j3bf: Error on Reconnect (5): connect EHOSTUNREACH 192.168.178.88:6668
                    2024-01-26 07:56:30.201  - info: tuya.0 (2465) bf4b75d73e9fcb0325tgur: Error on Reconnect (5): connect EHOSTUNREACH 192.168.178.81:6668
                    2024-01-26 07:56:52.152  - info: tuya.0 (2465) bf73010fbd58befe9fav7o: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.84:6668
                    2024-01-26 07:57:13.273  - info: tuya.0 (2465) bf3188beeaf49dab6082c1: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.81:6668
                    2024-01-26 07:57:14.937  - info: tuya.0 (2465) bfec117f5152ff5fcffeej: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.77:6668
                    2024-01-26 07:57:25.561  - info: tuya.0 (2465) bfe9da455b46e19c0cuq7w: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.86:6668
                    2024-01-26 07:57:27.864  - info: tuya.0 (2465) 5657716640f520e8def5: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.38:6668
                    2024-01-26 07:57:29.400  - info: tuya.0 (2465) bf6ee706266ec98130pnyr: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.85:6668
                    2024-01-26 07:57:31.128  - info: tuya.0 (2465) bfff12885558eedc4fgvhi: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.76:6668
                    2024-01-26 07:57:32.188  - info: tuya.0 (2465) bfefcf5b326f3b0441j3bf: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.88:6668
                    2024-01-26 07:57:33.272  - info: tuya.0 (2465) bf4b75d73e9fcb0325tgur: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.81:6668
                      @fibricus
                      sudo apt full-upgrade
                      Dann nochmal reboot.
                      Perspektivisch musst du auch dein Betriebssystem aktualisieren. Da läuft in ca. 12 Monaten der Support aus.
                        @thomas-braun Nun bin ich in der Firma. Das führe ich dann heute Abend aus.
                        Betriebssystem aktualisieren - jetzt bekomme ich schon wieder hohen Blutdruck. Ich hoffe, dass kann ich als Linux-Laie machen?!
                          Gibt Anleitungen dafür. Je zeitnaher das erfolgt, desto einfacher ist es.
                            Homoran Global Moderator Administrators @Fibricus last edited by
                            Da gab ich nichts von gemerkt.
                            du hast doch bis jetzt auch alles geschafft!
                            Wenn du vernünftige Backups hast, kannst du auch das OS, iobrokermund node neu installieren und danach das Backup zurückspielen.
                            korrekt!
                            Das kann dir dein gesamtes Dateisystem zerstören.
                              @homoran said in HILFE: IOB läuft aber ich kann ihn nicht erreichen!:
                              Da hab ich nichts von gemerkt.
                              Ich habe einfach nur Eure guten Anweisungen ausgeführt - das hat nix mit Können zu tun!
                              Und für die Hilfe bin ich echt dankbar!!!
                              1521
