    4. [Cloud eingestellt] Gigaset Elements
      HomeControl @matthsc last edited by
      @matthsc
      Anbei die Daten. Zur Info, ich habe heute einen Testalarm durchgeführt.
      "bs": [
      "id": "baseId000-c3PZt",
      "friendly_name": "baseName000-H9lRZ",
      "status": "online",
      "firmware_status": "up_to_date",
      "updates_available": false,
      "version": "bas-002.009.001",
      "latest_version": "bas-002.009.001",
      "fw_outdated": false,
      "intrusion_settings": {
      "active_mode": "home",
      "requestedMode": "home",
      "modeTransitionInProgress": false,
      "modes": [
      "away": {
      "sirens_on": true,
      "trigger_delay": 0,
      "privacy_mode": false
      "home": {
      "sirens_on": false,
      "trigger_delay": 0,
      "night": {
      "sirens_on": false,
      "trigger_delay": 0,
      "custom": {
      "sirens_on": false,
      "trigger_delay": 0,
      "endnodes": [
      "id": "elementId000-1Dhhr",
      "type": "sd01",
      "friendly_name": "elementName000-GetDw",
      "status": "online",
      "fw_version": "0013000010250000",
      "latest_version": "0013000010250000",
      "battery": {
      "state": "ok"
      "ts_button": 1656661747223
      "id": "elementId001-xyK4u",
      "type": "wd01",
      "friendly_name": "elementName001-uG6Wo",
      "status": "online",
      "fw_version": "0006000010250000",
      "latest_version": "0006000010250000",
      "battery": {
      "state": "ok"
      "ts_button": 1613757851275
      "sensors": [
      "type": "sd01",
      "status": "online",
      "battery": {
      "state": "ok"
      "type": "wd01",
      "status": "online",
      "battery": {
      "state": "ok"
      "elements": {
      "gp01": [],
      "gp02": [],
      "yc01": [],
      "bs01": [
      "type": "bs01",
      "friendlyName": "baseName000-H9lRZ",
      "firmwareStatus": "up_to_date",
      "firmwareVersion": "bas-002.009.001",
      "latestFirmwareVersion": "bas-002.009.001",
      "connectionStatus": "online",
      "timezone": "Europe/Vienna",
      "mac": "589EC6135618",
      "disabled": false,
      "pairingMode": false,
      "subelements": [
      "id": "baseId000-c3PZt.elementId001-xyK4u",
      "type": "bs01.wd01",
      "friendlyName": "elementName001-uG6Wo",
      "firmwareVersion": "0006000010250000",
      "latestFirmwareVersion": "0006000010250000",
      "batteryStatus": "ok",
      "states": {
      "temperature": 27.7,
      "humidity": 55.2,
      "waterAlarm": "water_no_longer_detected",
      "testRequired": true,
      "lastAlarmTestTimestamp": 1613256919306
      "frontendTags": {
      "room": {
      "roomName": "Room 000-pBh0M"
      "room": {
      "id": 79283,
      "friendlyName": "Room 000-pBh0M"
      "buttonPressedTs": 1613757851275,
      "capabilities": [],
      "debug": {
      "simple": "batteryLifetimePrediction: green",
      "extended": {
      "batteryLifetimePredictionColor": "green"
      "id": "baseId000-c3PZt.elementId000-1Dhhr",
      "type": "bs01.sd01",
      "friendlyName": "elementName000-GetDw",
      "firmwareVersion": "0013000010250000",
      "latestFirmwareVersion": "0013000010250000",
      "frontendTags": {
      "room": {
      "room": {
      "id": 79283,
      "buttonPressedTs": 1656661747223,
      "capabilities": [],
      "debug": {
      "extended": {
      "testRequired": false,
      "unmounted": false,
      "smokeDetected": false,
      "permanentBatteryLow": false,
      "permanentBatteryChangeRequest": false,
      "smokeChamberFail": false,
      "smokeDetectorOff": false,
      "lastAlarmTestTimestamp": 1656661749339,
      "lastPairingTimestamp": 1613251172762
      "frontendTags": {
      "room": {
      "capabilities": [
      "firmware.update.procedure.managed",
      "presentation.deviceType.elementsBasestation",
      "hardware.radio.dect.ule"
      "states": {
      "dect.remaining_devices_to_be_paired": 62,
      "dect.remaining_devices_to_be_paired._meta": {
      "modificationTimestamp": 1656661749345
      "room": {
      "id": 79283,
      "bs02": []
      "events": {
      "events": [
      "id": "035e569c4502721828a47594c9b28db2e7498aef",
      "state": "ok",
      "ts": "1656661763179",
      "type": "end_sd01_test",
      "o": {
      "reason": "acknowledged_by_user"
      "source_id": "app-mids-user-management@dkrh4.reef",
      "source_type": "iml01",
      "state_pre": "ok"
      "id": "29f97a3d45855e6593001dffe2c2ed00374958c5",
      "state": "ok",
      "ts": "1656661749349",
      "type": "test",
      "o": {
      "frontendTags": {
      "room": {
      "roomName": "Room 001-AXVvW"
      "type": "sd01",
      "room": {
      "id": 79283,
      "friendlyName": "Room 001-AXVvW"
      "source_id": "baseId000-c3PZt",
      "source_name": "baseName000-H9lRZ",
      "source_type": "basestation",
      "state_pre": "ok"
      "id": "ad44eed33f11325b38b3133b81c246489101e989",
      "state": "ok",
      "ts": "1655477524169",
      "type": "isl01.bs01.intrusion_mode_loaded",
      "o": {
      "configurationLoadedId": "0123",
      "modeBefore": "away",
      "modeAfter": "home",
      "userId": "https://im.gigaset-elements.de/identity/api/v1/openid/identifier/id/xxx"
      "source_id": "app-services-intrusion-detector@dkrd4.reef",
      "source_type": "isl01",
      "state_pre": "ok"
      "id": "f05ae7289a0df9039c807c8ac70090fc0ac7b6fa",
      "state": "ok",
      "ts": "1655477524159",
      "type": "isl01.configuration_changed.user.intrusion_mode",
      "o": {
      "modeAfter": "home"
      "state_pre": "ok"
      "home_state": "ok"
      H matthsc 2 Replies Last reply Reply Quote 0
        HomeControl @HomeControl last edited by
        Anbei auch die Ereignisse:
        "events": [
        "state": "ok",
        "o": {
        "state_pre": "ok"
        "state": "ok",
        "type": "test",
        "o": {
        "frontendTags": {
        "room": {
        "roomName": "Technikraum"
        "friendly_name": "Brandmelder",
        "id": "033e3d32b7",
        "type": "sd01",
        "room": {
        "id": 79283,
        "friendlyName": "Technikraum"
        "source_id": "AFF135FD706A21DB007B94E87A4BCA09",
        "source_name": "Basisstation",
        "state_pre": "ok"
        • matthsc
          matthsc Developer @HomeControl last edited by
          @homecontrol Super, danke.
          Es sollte bald Version 0.2.1 im Latest/Beta auftauchen. Die beinhaltet diverse neue States für den Rauchmelder. Unter anderem "smokeDetected".
          Den "alarm" State verwende ich jetzt nicht. Für richtige Alarme fehlen dazu die Events, und für den Testalarm fehlt dem End-Event die Referenz auf den Rauchmelder. Könnte ich zwar versuchen zu erraten, aber nur für den Test lohnt sich das noch nicht. Kann ich mir aber gerne anschauen falls es mal einen richtigen Alarm gibt 🙂
          H draexler 2 Replies Last reply Reply Quote 0
            @matthsc
            Vielen Dank für die rasche Antwort.
            Ich hoffe nicht, dass es mal einen richtigen Alarm gibt - falls doch lasse ich dir die Daten zukommen. 😉
            Ich habe heute geschaut jedoch noch keine neue Version gefunden. Werde es am Wochenende nochmals versuchen.
            • draexler
              draexler @matthsc last edited by
              @matthsc Wann kommt die 0.2.1 ins Latest/Beta? Ich bräuchte eigentlich nur die Telefoniefunktion.
              Aber irgendwie schaffe ich es über NPM obwohl die Beta Repo eingestellt ist nur die 0.1.3 zu installieren....
              matthsc 1 Reply Last reply Reply Quote 0
              • matthsc
                matthsc Developer @draexler last edited by matthsc
                @draexler die 0.2.1 war seit dem 02. oder 03. Juli im Latest/Beta. Seit diesem Wochenende ist die 0.2.2 drin. Mir wurde sie von dort als Update für die 0.2.1 angeboten.
                Ich plane demnächst noch ein paar kleinere Hintergrund-Anpassungen/Aktualisierungen fertig zu stellen und mit neuen Mindestanforderungen (Node.js 14, js-controller 4) als 0.3.0 rauszubringen. Bei der würde ich dann auch schauen dass ich sie ins stable reinbekomme.
                draexler 1 Reply Last reply Reply Quote 1
                • draexler
                  @matthsc Jetzt hast funktioniert.... Komisch....
                  Aber trotzdem Danke 🙂
                  • matthsc
                    matthsc Developer @matthsc last edited by matthsc
                    Ab morgen ist Version 0.4.3 zum testen im Latest Repository.
                    Highlights:
                    • (matthsc) add states for batterySaverMode, momentaryPowerMeasurement (plug), setPoint (thermostat)
                    • (matthsc) allow to change setPoint for thermostat (experimental/untested)
                    • (matthsc) allow to change intrusion mode
                    • (matthsc) allow to trigger user alarm
                    • (matthsc) add info.systemHealth state
                    • (matthsc) add support for plugs
                    • (matthsc) drop support for Node 14 and 16
                    Vor allem der Thermostat ist bis jetzt komplett ungetestet, da wäre ich über Feedback froh.
                      cyfm @matthsc last edited by
                      @matthsc
                      Gibt es eigentlich irgendeine Möglichkeit, die kwH Verbrauchswerte aus dem Plug2.0 elements auszulesen außer mit der offiziellen App ?
                      Ein "dump" mit dem dynasticorpheus gigasetelements-cli liefert nur einen statischen Wert wie z.B.
                      Steckdose 5 Heat Living | ONLINE | firmware UP_TO_DATE | relay ON | momentaryPower 1648.0
                      Da muss irgendwie ein neues API hinzugefügt worden sein, ist nur die Frage 'was ...
                      Die App bietet die Möglichkeit, den Verbrauch der letzten 30 Tage anzuzeigen für jeden Plug.
                      Ich hoffe auch 'mal, dass die gigaset cloud auch noch weiter aktiv bleibt, nachdem nach der letzten gigaset Insolvenz in 2023 jetzt neue asiatischen Investoren eingesprungen sind ...
                      Wollte meine ganzen elements eigentlich nicht einmotten ...
                      • matthsc
                        matthsc Developer @cyfm last edited by
                        @cyfm Die momentaryPower sollte im Adapter angezeigt werden. Konnte ich mangels entsprechender Hardware allerdings nicht testen.
                        Was genau würdest du denn auslesen wollen - die genannten letzten 30 Tage?
                        Du kannst sonst auch mal den Export-Modus aktivieren und dann in den Einstellungen der Adapter-Instanz im Debug-Tab die "Debug" bereiche laden und anschauen, ob da noch was drin ist, was angezeigt werden könnte.
                        Werden die Verbrauchsdaten nur in der Mobile-App, oder auch in der WebApp (https://app.gigaset-elements.com/) angezeigt? Dort käme man über die Entwicklertools noch einfach an die verwendeten Endpunkte heran. Bei den Apps war ich selbst bisher noch nicht erfolgreich...
                          cyfm @matthsc last edited by cyfm
                          @matthsc said in [Neuer Adapter] Gigaset Elements:
                          vermutlich wird das irgendwie drin sein. Ich hab' das selbst 'mal in dem anderen Tool eingebaut, über das ioBroker Zeug bin ich nur aktuell "gestolpert", weil das ja offenbar noch "aktiv" weiterentwickelt wird.
                          Ja, das wäre Idee. Aktuell etwas müßig bzw. gar nicht möglich, dass aus der App herauszubekommen für statistische Zwecke ...
                          Ja, muss mir erst noch 'mal anschauen, wie das alles funktioniert.
                          Leider sind diese Sachen nicht über die WebApp abrufbar und ich verstehe, dass das kompliziert ist über die mobile App. Diese "MomentaryPower" in der "klassischen" JSON Rückgabe scheint auch nicht wirklich ständig aktualisiert zu werden, daher kaum brauchbar, selbst wenn man das jetzt zyklisch abfragen würde ....
                          • MartinP
                            MartinP @cyfm last edited by
                            Hmm, war es das nun, mit diesem Adapter?
                            https://www.golem.de/news/insolvenz-gigasets-smart-home-system-wird-zu-elektroschrott-2403-183590.html
                            • matthsc
                              matthsc Developer @MartinP last edited by
                              @martinp ich fürchte schon. Ohne den Cloud Dienst geht nichts, und ich halte es für unwahrscheinlich, dass Gigaset daran noch etwas ändern wird oder eine Version zum selbst Hosten herausgibt.
                              Zeigt leider mal wieder, dass man sich nicht auf Systeme mit Cloud Zwang einlassen sollte 😑
                              • mcm1957
                                mcm1957 @matthsc last edited by mcm1957
                                Hi, @matthsc
                                Da das dein Adapter ist und du hier schon aktiv bist.
                                Spricht aus deiner Sicht etwas dagegen, die Info über den Komazustand des Adapters via Admin News auszurollen?
                                So wie ich das sehe sind die Überlebenschancen oder die Chance einer Reanimation ja sehr gering.
                                ICh war mir bisher nicht 200% sicher dass gigaset-elements und gigaset-smart-home-care dasselbe sind.
                                MartinP matthsc 2 Replies Last reply Reply Quote 0
                                • MartinP
                                  MartinP @mcm1957 last edited by MartinP
                                  @mcm57 Ich denke, ein Alarm an die Nutzer wäre schon angebracht, vielleicht steuert jemand etwas, was nicht so einfach "de-automatisiert" werden kann und dann Unannehmlichkeiten (Temperatursensoren, die die Heizung steuern z .B.) verursacht. Da ist es sicherlich gut, frühzeitig zu wissen, dass man sich um Ersatz kümmern muss.
                                  Es ist ja nur noch bis Ende März Zeit - also knapp eine Woche. Das ist schon sportlich, bis da hin Ersatz zu bekommen, und zumindest die wichtigsten Dinge dann wieder in ioBroker zum Laufen zu bringen ...
                                  In der Meldung auf der Gigaset-Seite steht, dass die Cloud-Dienste eingestellt werden. Da würde ich schon denken, dass da ALLES abgeschaltet wird...
                                  • matthsc
                                    matthsc Developer @mcm1957 last edited by
                                    @mcm57 nein, spricht nichts dagegen.
                                    Ich weiss auch nicht genau, was jetzt zu Gigaset Smart Home oder Gigaset Care gehört. Aber da sie den Cloud Dienst einstellen fällt Elements da garantiert auch darunter. Einzig die Telefonie haben sie ja verkauft. Das kann der Adapter zwar auch ansprechen, aber da habe ich auch keine Geräte, und vermute mal dass das auch auf Aus des Cloud Dienstes betroffen ist.
                                    • mcm1957
                                      mcm1957 @MartinP last edited by mcm1957
                                      @martinp said in [Neuer Adapter] Gigaset Elements:
                                      Kanpp eine Woche 🙂 == 3 Tage
                                      Ok, news geht raus.
                                      Heizung mag Problem sein, da kann man aber zur Not mal manuell fahren.
                                      Aber Alarmanlagen, Brandmelder und vor allem der soweit ich weiß auch angeboten Seriennotruf ist wohl nicht mehr eine so "na dann halt nicht" Sache.
                                      Ok - veranlass eine News.
                                      Und wenn dann überraschend doch noch was geht freuen wir uns und bewerben das dann. News heißt ja nicht Löschen des Codes von Github.
                                      Sollte keine sinnvolle Funktion nach dem 29.3. mehr gegeben sein, dann schreib dass bitte ins Readme im Repo und setz das Github Repo auf archived. Dann fliegt der Adapter mehr oder weniger automatisch aus den Repositories.
                                      DANKE fürs Schreiben und Warten des Adapters !
                                      • MartinP
                                        MartinP @matthsc last edited by
                                        @matthsc
                                        Die Cloud-Dienste werden zum 29. März 2024 eingestellt.
                                        Apps und verbundene Sensoren/Geräte werden nicht mehr nutzbar sein.
                                        Kamera Service Pakete enden zum 29. März 2024.
                                        Eine Rücksendung Ihrer Geräte ist leider nicht möglich.
                                        Der lokale Alarm des Rauchmelders Gigaset Smoke funktioniert uneingeschränkt weiter.
                                        Das scheint wirklich Tabula Rasa zu sein ...
                                        • MartinP
                                          @mcm57 said in [Neuer Adapter] Gigaset Elements:
                                          Kanpp eine Woche == 3 Tage
                                          Meine Glaskugel sagt mir, dass die Admins womöglich schon am Donnerstag gegen Feierabend den Stecker ziehen, weil sie bei der Meldung nicht bedacht haben, dass Freitag ein Feiertag ist ...
                                          matthsc 1 Reply Last reply Reply Quote 1
                                          • matthsc
                                            @martinp Es wurde tatsächlich erst irgendwann zwischen Freitagabend und Samstagmorgen deaktiviert.
                                            Ich habe das Adapter-Repo archiviert.
                                            79
                                            7251
