    4. iobroker + docker + MACVLAN - fixe IP für bridge möglich ?
    • stephan1827
      stephan1827 last edited by
      So ich habe jetzt mal parallel einen docker mit macvlan neu aufgesetzt und der läuft einwandfrei bis ich die Backup wieder herstelle. Danach habe ich wieder das gleiche Problem wie vorher. Ich habe darauf geachtet das npm, node und js controller die gleiche Version haben wie vorher.
      strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/certificatesProps" (strictTypes)
      strict mode: missing type "object" for keyword "properties" at "#/definitions/certificatesProps" (strictTypes)
      strict mode: missing type "object" for keyword "required" at "#/definitions/instanceProps" (strictTypes)
      strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/instanceProps" (strictTypes)
      strict mode: missing type "object" for keyword "properties" at "#/definitions/instanceProps" (strictTypes)
      strict mode: missing type "object" for keyword "required" at "#/definitions/objectIdProps" (strictTypes)
      strict mode: missing type "object" for keyword "additionalProperties" at "#/definitions/objectIdProps" (strictTypes)
      strict mode: missing type "object" for keyword "properties" at "#/definitions/objectIdProps" (strictTypes)
      ================================== > LOG REDIRECT system.adapter.admin.0 => false [Process stopped]
      ================================== > LOG REDIRECT system.adapter.admin.0 => false [system.adapter.admin.0.logging]
      Terminated
      -------------------------     2024-01-20 12:33:53      -------------------------
      -----              Welcome to your ioBroker Docker container!              -----
      -----                    Startupscript is now running!                     -----
      -----                          Please be patient!                          -----
      -----                          System Information                          -----
      -----                    arch:                x86_64                       -----
      -----                    hostname:            iobroker                     -----
      -----                          Version Information                         -----
      -----                    image:               v9.1.0                       -----
      -----                    build:               2024-01-19T13:46:03+00:00    -----
      -----                    node:                v18.19.0                     -----
      -----                    npm:                 9.2.0                        -----
      -----                        Environment Variables                         -----
      -----                    DEBUG:               true                         -----
      -----                    SETGID:              1000                         -----
      -----                    SETUID:              1000                         -----
      !!!!                            DEBUG LOG ACTIVE                            !!!!
      !!!!               Environment variable DEBUG is set to true.               !!!!
      !!!! This will extend the logging output and may slow down container start. !!!!
      !!!!          Please make sure to deactivate if no longer needed.           !!!!
      !!!!     For more information see ioBroker Docker image documentation:      !!!!
      !!!!           https://docs.buanet.de/iobroker-docker-image/docs/           !!!!
      -----                   Step 1 of 5: Preparing Container                   -----
      This is not the first run of this container. Skipping first run preparation.
      -----             Step 2 of 5: Detecting ioBroker Installation             -----
      Existing installation of ioBroker detected in "/opt/iobroker".
      -----             Step 3 of 5: Checking ioBroker Installation              -----
      (Re)setting permissions (This might take a while! Please be patient!)... Done.
      [DEBUG] Checking multihost settings...
      [DEBUG] No multihost settings detected.
      [DEBUG] Done.
      [DEBUG] Checking custom objects db settings...
      [DEBUG] No custom objects db settings detected.
      [DEBUG] Done.
      [DEBUG] Checking custom states db settings...
      [DEBUG] No custom states db settings detected.
      [DEBUG] Done.
      Checking database connection... Failed.
      [DEBUG] Error message:
      [DEBUG] No connection to databases possible ...
      Please check your configuration and try again.
      For more information see ioBroker Docker image docs (https://docs.buanet.de/iobroker-docker-image/docs).
      [DEBUG] Debug mode prevents the container from exiting on errors.
      [DEBUG] This enables you to investigate or fix your issue on the command line.
      [DEBUG] If you want to stop or restart your container you have to do it manually.
      [DEBUG] IoBroker is not running!
      • Glasfaser
        Glasfaser @stephan1827 last edited by Glasfaser
        @stephan1827 sagte in iobroker + docker + MACVLAN - fixe IP für bridge möglich ?:
        @marc-berg anscheinend kann der container sich nicht mehr mit der Datenbank verbinden,
        Neuer Container !
        image: v9.1.0
        da passt was nicht zusammen ...
        ich wette du hast diesen Fehler vorhanden :
        https://forum.iobroker.net/topic/71461/dfsg-nodejs-eingehandelt-hier-die-korrektur
        Schau nach mit
        iob diag
        da kommt bestimmt das raus :
        NodeJS-Installation
        usrbinnodejs v18.19.0
        usrbinnode v18.19.0
        usrbinnpm 9.2.0
        usrbinnpx 9.2.0
        homeiobroker.diag.sh line 281 corepack command not found
        nodejs is NOT correctly installed
        nodejs
        Installed 18.19.0+dfsg-6~deb12u1
        Candidate 18.19.0+dfsg-6~deb12u1
        Version table
        18.19.0+dfsg-6~deb12u1 500
        500 httpdeb.debian.orgdebian-security bookworm-securitymain amd64 Packages
        100 varlibdpkgstatus
        18.19.0-1nodesource1 500
        500 httpsdeb.nodesource.comnode_18.x nodistromain amd64 Packages
        stephan1827 1 Reply Last reply Reply Quote 0
        • stephan1827
          stephan1827 @Glasfaser last edited by
          @glasfaser Ich habe das mal probiert aber das Ergebnis ist das gleiche. Der Container funktioniert ja auch soweit bis versuche die Backup wieder herzustellen.
          • Glasfaser
            Zeige bitte die aktuelle Full Ausgabe von
            iob diag
            wo du dein Backup her hast . ( Container )
            • stephan1827
              @glasfaser hier ist die Ausgabe von Diag. Wie gesagt, das Ganze läuft, bis ich das Backup zurückspiele. Ist es eigentlich möglich nur einzelne Adapter das Backup zurückzuspielen? Dann könnte ich versuchen das Ganze Stück für Stück zurückzuspielen um zu sehen das die Instanz kaputt macht.
              Skript v.2023-10-10
              *** BASE SYSTEM ***
              Hardware Vendor : Synology
              Kernel          : x86_64
              Userland        : amd64
              Docker          : v9.1.0
              Virtualization  : Docker
              Kernel          : x86_64
              Userland        : amd64
              Systemuptime and Load:
               06:52:15 up 6 days, 15:46,  0 user,  load average: 0.43, 0.62, 0.79
              CPU threads: 4
              *** Time and Time Zones ***
              Wed Jan 24 05:52:15 UTC 2024
              Wed Jan 24 06:52:15 CET 2024
              CET +0100
              Etc/UTC
              *** User and Groups ***
              root
              /root
              root
              *** X-Server-Setup ***
              X-Server:       false
              Desktop:
              Terminal:
              *** MEMORY ***
              Mem:             12G        5.1G        672M        605M        7.6G        7.3G
              Swap:           2.1G        1.9G        230M
              Total:           14G        7.0G        902M
                      11812 M total memory
                       4854 M used memory
                       5216 M active memory
                       4144 M inactive memory
                        641 M free memory
                         21 M buffer memory
                       7263 M swap cache
                       2047 M total swap
                       1828 M used swap
                        219 M free swap
              *** FILESYSTEM ***
              Filesystem             Type   Size  Used Avail Use% Mounted on
              /dev/mapper/cachedev_0 btrfs  5.3T  3.4T  1.9T  65% /
              tmpfs                  tmpfs   64M     0   64M   0% /dev
              tmpfs                  tmpfs  5.8G     0  5.8G   0% /sys/fs/cgroup
              shm                    tmpfs   64M     0   64M   0% /dev/shm
              /dev/mapper/cachedev_0 btrfs  5.3T  3.4T  1.9T  65% /opt/iobroker
              /dev/mapper/cachedev_0 btrfs  5.3T  3.4T  1.9T  65% /etc/hosts
              tmpfs                  tmpfs  5.8G     0  5.8G   0% /proc/acpi
              tmpfs                  tmpfs  5.8G     0  5.8G   0% /proc/scsi
              tmpfs                  tmpfs  5.8G     0  5.8G   0% /sys/firmware
              TARGET             SOURCE        FSTYPE OPTIONS
              /                  /dev/mapper/cachedev_0[/@syno/@docker/btrfs/subvolumes/8f61f99191ae24afec750236d3556bdb71cf468d8ad1a1f67b4ce1d5aaaf95ad]       btrfs  rw,nodev,relatime,ssd,synoacl,nospace_cache,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=11933,subvol=/@syno/@docker/btrfs/subvolumes/8f61f99191ae24afec750236d3556bdb71cf468d8ad1a1f67b4ce1d5aaaf95ad
              |-/opt/iobroker    /dev/mapper/cachedev_0[/@syno/docker/iobroker]        btrfs  rw,nodev,relatime,ssd,synoacl,nospace_cache,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=259,subvol=/@syno/docker
              |-/etc/resolv.conf /dev/mapper/cachedev_0[/@syno/@docker/containers/6fb14c1d0acc003618c8dd804f894f67ff863ff6c8226945827e6173e507bc0b/resolv.conf] btrfs  rw,nodev,relatime,ssd,synoacl,nospace_cache,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno
              |-/etc/hostname    /dev/mapper/cachedev_0[/@syno/@docker/containers/6fb14c1d0acc003618c8dd804f894f67ff863ff6c8226945827e6173e507bc0b/hostname]    btrfs  rw,nodev,relatime,ssd,synoacl,nospace_cache,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno
              `-/etc/hosts       /dev/mapper/cachedev_0[/@syno/@docker/containers/6fb14c1d0acc003618c8dd804f894f67ff863ff6c8226945827e6173e507bc0b/hosts]       btrfs  rw,nodev,relatime,ssd,synoacl,nospace_cache,auto_reclaim_space,metadata_ratio=50,syno_allocator,subvolid=257,subvol=/@syno
              /var:
              38M     /var/
              35M     /var/lib
              19M     /var/lib/apt/lists
              19M     /var/lib/apt
              17M     /var/lib/dpkg
              /opt/iobroker/backups:
              4.0G    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              50M     /opt/iobroker/iobroker-data/
              16M     /opt/iobroker/iobroker-data/files
              13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
              28M     /opt/iobroker/iobroker-data/objects.jsonl
              6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
              5.2M    /opt/iobroker/iobroker-data/states.jsonl
              2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
              1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
              USB-Devices by-id:
              *** NodeJS-Installation ***
              /usr/bin/nodejs         v18.19.0
              /usr/bin/node           v18.19.0
              /usr/bin/npm            10.2.3
              /usr/bin/npx            10.2.3
              /usr/bin/corepack       0.22.0
              nodejs:
                Installed: 18.19.0-1nodesource1
                Candidate: 18.19.0-1nodesource1
                Version table:
                      500 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages
               *** 18.19.0-1nodesource1 1001
                      500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                      100 /var/lib/dpkg/status
                   18.18.2-1nodesource1 1001
                   18.18.1-1nodesource1 1001
                   18.18.0-1nodesource1 1001
                   18.17.1-1nodesource1 1001
                   18.17.0-1nodesource1 1001
                   18.16.1-1nodesource1 1001
                   18.16.0-1nodesource1 1001
                   18.15.0-1nodesource1 1001
                   18.14.2-1nodesource1 1001
                   18.14.1-1nodesource1 1001
                   18.14.0-1nodesource1 1001
                   18.13.0+dfsg1-1 500
                      500 http://deb.debian.org/debian bookworm/main amd64 Packages
                   18.13.0-1nodesource1 1001
                   18.12.0-1nodesource1 1001
                   18.11.0-1nodesource1 1001
                   18.10.0-1nodesource1 1001
                   18.9.1-1nodesource1 1001
                   18.9.0-1nodesource1 1001
                   18.8.0-1nodesource1 1001
                   18.7.0-1nodesource1 1001
                   18.6.0-1nodesource1 1001
                   18.5.0-1nodesource1 1001
                   18.4.0-1nodesource1 1001
                   18.3.0-1nodesource1 1001
                   18.2.0-1nodesource1 1001
                   18.1.0-1nodesource1 1001
                   18.0.0-1nodesource1 1001
              No problems detected
              Errors in npm tree:
              *** ioBroker-Installation ***
              ioBroker Status
              Core adapters versions
              js-controller:  4.0.24
              admin:          6.12.0
              javascript:     "javascript" not found
              Adapters from github:   0
              Adapter State
              ioBroker-Repositories
              Installed ioBroker-Instances
              Objects and States
              Objects:        1
              States:         1
              Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
              Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
              Reading package lists...
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 127.0.0.11:44047        0.0.0.0:*               LISTEN      0          99628225   -
              udp        0      0 127.0.0.11:60690        0.0.0.0:*                           0          99628224   -
              2024-01-21 17:35:41.819  - info: admin.0 (234) ==> Connected system.user.admin from ::ffff:192.168.86.90
              2024-01-21 17:35:47.365  - info: admin.0 (234) ==> Connected system.user.admin from ::ffff:192.168.86.90
              2024-01-21 17:36:06.719  - info: host.iobroker received SIGTERM
              2024-01-21 17:36:06.722  - info: host.iobroker stopInstance system.adapter.admin.0 (force=false, process=true)
              2024-01-21 17:36:06.722  - info: host.iobroker stopInstance system.adapter.discovery.0 (force=false, process=true)
              2024-01-21 17:36:06.723  - info: host.iobroker stopInstance system.adapter.backitup.0 (force=false, process=true)
              2024-01-21 17:36:06.730  - info: discovery.0 (261) Got terminate signal TERMINATE_YOURSELF
              2024-01-21 17:36:06.732  - info: discovery.0 (261) terminating
              2024-01-21 17:36:06.733  - info: discovery.0 (261) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2024-01-21 17:36:06.734  - info: admin.0 (234) Got terminate signal TERMINATE_YOURSELF
              2024-01-21 17:36:06.738  - info: backitup.0 (276) Got terminate signal TERMINATE_YOURSELF
              2024-01-21 17:36:06.739  - info: host.iobroker stopInstance system.adapter.admin.0 send kill signal
              2024-01-21 17:36:06.740  - info: host.iobroker stopInstance system.adapter.discovery.0 send kill signal
              2024-01-21 17:36:06.741  - info: host.iobroker stopInstance system.adapter.backitup.0 send kill signal
              2024-01-21 17:36:06.738  - info: admin.0 (234) terminating http server on port 8081
              2024-01-21 17:36:06.743  - info: admin.0 (234) terminating
              2024-01-21 17:36:06.744  - info: admin.0 (234) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2024-01-21 17:36:06.739  - info: backitup.0 (276) cleaned everything up...
              2024-01-21 17:36:06.739  - info: backitup.0 (276) terminating
              2024-01-21 17:36:06.740  - info: backitup.0 (276) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2024-01-21 17:36:07.278  - info: host.iobroker instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2024-01-21 17:36:07.287  - info: host.iobroker instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2024-01-21 17:36:07.305  - info: host.iobroker instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2024-01-21 17:36:07.307  - info: host.iobroker All instances are stopped.
              2024-01-21 17:36:07.358  - info: host.iobroker terminated
              iob diag has finished.
                                      v.2023-10-10
              model name      : Intel(R) Celeron(R) J4125 CPU @ 2.00GHz
              Kernel          : x86_64
              Userland        : amd64
              Docker          : v9.1.0
              Installation:           Docker
              Kernel:                 x86_64
              Userland:               amd64
              Timezone:               Etc/UTC
              User-ID:                0
              X-Server:               false
              Pending OS-Updates:     0
              Pending iob updates:    0
              Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                      /usr/bin/npm            10.2.3
                                      /usr/bin/npx            10.2.3
              Recommended versions are nodejs No connection to databases possible ... and npm No connection to databases possible ...
              MEMORY:
              Mem:             12G        5.1G        696M        605M        7.6G        7.3G
              Swap:           2.1G        1.9G        228M
              Total:           14G        7.0G        924M
              Active iob-Instances:   0
              ioBroker Core:          js-controller           4.0.24
                                      admin                   6.12.0
              ioBroker Status:        No connection to databases possible ...
              Objects:                1
              States:                 1
              Size of iob-Database:
              === Mark text until here for copying ===
              • Marc Berg
                Marc Berg Most Active @stephan1827 last edited by
                @stephan1827
                Das frische Image kommt mit js-Controller Version 5.x. In dem diag Auszug sehe ich aber 4.0.24. Von welcher Version wurde das Backup erzeugt?
                • stephan1827
                  stephan1827 @Marc Berg last edited by
                  @marc-berg Ich installiere den neuen Docker mit der Version 7.2.0 die den js controller 4.0.024 enthält.
                  • Glasfaser
                    So ganz passt das alles nicht !
                    in den Log´s ist das ioBroker Docker Image 9.1.0 , angezeigt und also das aktuellste .
                    du schreibts von "neuen Docker ... Version 7.2.0" , das wäre ab die Synology DSM Version 7.2.0 ( auch nicht aktuell ) das hat aber nichts mit dem Container Image zu tun .
                    dann zu 4.0.24 , dann würdest du es selbstständig auf diese Version bringen , denn :
                    @marc-berg sagte in iobroker + docker + MACVLAN - fixe IP für bridge möglich ?:
                    und ein Backup würde gar nicht von 5.x. auf 4.x funktionieren , da mußt du selber Hand anlegen.
                    Hier liegt ein ganz Großes ? vor .
                    Hier wird nur vom neuen Container ... von dir gezeigt ,
                    aber wie ist der Stand vom alten vorhandenen Container .
                    stephan1827 1 Reply Last reply Reply Quote 1
                    • stephan1827
                      @glasfaser Der Grund für diesen Unterschied ist vermutlich, das der alte Docker zwar auf dem neusten Image beruht (weil er zwischendurch immer wieder geupdated wurde), aber noch den alten js-controller verwendet. Ich habe den früher schon mal versucht js abzudaten, aber das produziert bei mir ohne Ende Fehler. Deswegen ist der noch auf dem alten Stand.
                      • OliverIO
                        OliverIO @stephan1827 last edited by OliverIO
                        @stephan1827
                        irgendwie bekomme ich deine terminologie nicht mit der realen welt in überdeckung. um es evtl etwas abzugrenzen, hier mal die verschiedenen ebenen über die man sprechen kann
                        1. host-betriebssystem
                        2. container management software
                        3. docker-virtualisierung
                        4. container/image
                        5. container betriebssystem
                        6. software im container
                        jedes dieser ebenen kann mindestens eine versionsnummer haben
                        bei dir vermute ich folgendes
                        1. synology dsm 7.2.0
                        2. sonology dsm 7.2.0
                        3. docker ?, aber egal, das was mit dsm 7.2.0 mitkommt
                        4. hier wäre es interessant welches image und welche version. nie neueste wäre buanet 9.1.1
                        5. egal, wenn du buanet verwendets
                        6. version deines iobrokers
                        und nun nochmal zu deinem satz
                        wenn du schreibst, ich habe immer wieder geupdatet, meinst du dann
                        4 oder 6? oder noch schlimmer 5?
                        von welcher version auf welche version?
                        was sind die fehlermeldungen?
                        irgendwie ist ja was verkorxt und dann sollte man das grundübel erstmal reparieren, bevor man irgendwie rumdoktert
                        IM container wird nie durch irgendwelche befehle das betriebssystem oder node aktualisiert. das bringt chaos. diese dinge werden nur aktualisiert, in dem man das komplette image aktualisiert. welches betriebssystem und node da dann drin steckt bestimmt buanet.
                        alle diese änderungen überleben eine container aktualisierung nicht
                        iobroker IM container kann aktualisiert werden, aber auch nur weil alles in einer definierten volume steckt und die dann auch eine containeraktualisierung überlebt.
                        Glasfaser 1 Reply Last reply Reply Quote 1
                        • Glasfaser
                          Glasfaser @OliverIO last edited by
                          @oliverio sagte in iobroker + docker + MACVLAN - fixe IP für bridge möglich ?:
                          Richtig ...
                          und alles was hier @stephan1827 schreibt , versteht keiner bzw. versuchen WIR hier ins Klare zu rücken .
                          @stephan1827
                          Ich finde es sehr schade ...
                          wir hier im Forum opfern unsere Freizeit und bekommen erst nach und nach Infos die überhaupt nicht im zusammenhand zu diesem eigentlichen Thread sind ,
                          bzw. stellt sich herraus , das dein System verkorxt ist .
                          2423
