    4. colormode not modifiable
      Homoran Global Moderator Administrators @WernerS last edited by
      @werners sagte in colormode not modifiable:
      Da kommt leider nix
      iob stop
      iob fix
      iob start
      warten
      iob diag
        WernerS @Homoran last edited by
        anbei die gewünschten Daten einmal vom master und vom slave 1. Beim slave hat es gleich funktioniert.
                                v.2023-10-10
           Static hostname: iobroker
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 10 (buster)
                    Kernel: Linux 5.10.63-v7l+
              Architecture: arm
        Installation:           native
        Kernel:                 armv7l
        Userland:               armhf
        Timezone:               Europe/Berlin (CET, +0100)
        User-ID:                1001
        X-Server:               false
        Boot Target:            graphical.target
        Pending OS-Updates:     194
        Pending iob updates:    4
        Nodejs-Installation:    /usr/bin/nodejs         v16.20.2
                                /usr/bin/node           v16.20.2
                                /usr/bin/npm            8.19.4
                                /usr/bin/npx            8.19.4
                                /usr/bin/corepack       0.17.0
        Recommended versions are nodejs 18.19.0 and npm 10.2.3
        MEMORY:
        Mem:           3.8G        1.2G        766M         24M        1.8G        2.7G
        Swap:          1.0G          0B        1.0G
        Total:         4.9G        1.2G        1.8G
        Active iob-Instances:   32
        Active repo(s): stable
        ioBroker Core:          js-controller           5.0.17
                                admin                   6.12.0
        Objects type: jsonl
        States  type: jsonl
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 192.168.178.51 (SSL), run as: admin
        + system.adapter.admin.1                  : admin                 : iobroker-slave01                         -  enabled, port: 8089, bind: 192.168.178.56, run as: admin
        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 443, bind: 192.168.178.51 (SSL), run as: admin
        + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8083, bind: 192.168.178.51, run as: admin
        Objects:                13007
        States:                 11260
        Size of iob-Database:
        17M     /opt/iobroker/iobroker-data/objects.jsonl
        9.8M    /opt/iobroker/iobroker-data/objects.json.migrated
        9.8M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
        0       /opt/iobroker/iobroker-data/objects.json.broken
        5.3M    /opt/iobroker/iobroker-data/states.jsonl
        2.2M    /opt/iobroker/iobroker-data/states.json.migrated
        2.2M    /opt/iobroker/iobroker-data/states.json.bak.migrated
        0       /opt/iobroker/iobroker-data/states.json.broken
        v.2023-10-10
        Static hostname: iobroker-slave01
        Icon name: computer
        Kernel: Linux 5.10.103-v7l+
        Architecture: arm
        Kernel: armv7l
        Userland: armhf
        User-ID: 1001
        X-Server: false
        Pending OS-Updates: 8
        /usr/bin/npm 8.19.4
        /usr/bin/npx 8.19.4
        MEMORY:
        total used free shared buff/cache available
        Mem: 3.8G 812M 2.6G 8.0M 472M 3.1G
        Swap: 99M 0B 99M
        Total: 3.9G 812M 2.7G
        Active iob-Instances: 31
        admin 6.12.0
        ioBroker Status: iobroker is running on this host.
        At least one iobroker host is running.
        Objects type: jsonl
        States type: jsonl
        • system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 192.168.178.51 (SSL), run as: admin
          system.adapter.admin.1 : admin : iobroker-slave01 - disabled, port: 8089, bind: 192.168.178.56, run as: admin
        • system.adapter.web.0 : web : iobroker - enabled, port: 443, bind: 192.168.178.51 (SSL), run as: admin
        • system.adapter.web.1 : web : iobroker - enabled, port: 8083, bind: 192.168.178.51, run as: admin
        Objects: 13007
        States: 11260
        2.0M /opt/iobroker/iobroker-data/objects.jsonl
        2.0M /opt/iobroker/iobroker-data/objects.json.migrated
        2.0M /opt/iobroker/iobroker-data/objects.json.bak.migrated
        256K /opt/iobroker/iobroker-data/states.jsonl
        252K /opt/iobroker/iobroker-data/states.json.migrated
        252K /opt/iobroker/iobroker-data/states.json.bak.migrated
        Gruß Werner
        • Codierknecht
          Codierknecht Developer Most Active @WernerS last edited by
          @WernerS
          Die Kiste ist hoffnungslos veraltet.
          Installier da was lebendiges und dann sehen wir weiter.
            WernerS @Codierknecht last edited by
            @codierknecht
            was ist veraltet, habe immer alle updates gemacht
            komplett neu? 3 Raspberries?
            Werner
            Thomas Braun Codierknecht 3 Replies Last reply Reply Quote 0
              Thomas Braun Most Active @WernerS last edited by
              Ja, und dann gleich die 64Bit-Variante für die Kisten.
                Kann ja nicht sein, bei 194 Updates die da in der Pipiline hängen ist das Betriebssystem mit Sicherheit nie angepackt worden.
                  WernerS @Thomas Braun last edited by
                  da lerne ich gerade was dazu.
                  habe eigentlich mehrmals mit sudo apt update und apt upgrade gearbeitet + die Adapterupdate die ja angezeigt werden. Was läuft da falsch?
                  Werner
                    Kann ich dir ohne konkrete Ausgabe von
                    sudo apt update
                    sudo apt full-upgrade
                    nicht sagen.
                    • Codierknecht
                      194 Updates sprechen eindeutig dagegen.
                      Und das OS hat auch sein EOL erreicht.
                      • Armilar
                        Armilar Most Active Forum Testing @Asgothian last edited by
                        @asgothian
                        @WernerS
                        ist so...
                        der Mode schaltet automatisch um.
                        Mit "xy" schaltet das Leuchtmittel in den Farb-Modus:
                        und mit "ct" schaltet es automatisch in den Farbtemperatur-Modus
                        Hue hat bei mir keine Wirkung...
                        Colormode wird durch den Adapter umgeschaltet. Das musst du nicht...
                          @armilar sagte in colormode not modifiable:
                          @asgothian
                          @WernerS
                          ist so...
                          Ich galube das ist es. Ich muss nicht den colormode ändern sonder in xy 0,0 und in ct einen wert schreiben. Da muss man erst mal drauf kommen
                          Danke!
                          Werner
                          • Armilar
                            Armilar Most Active Forum Testing @WernerS last edited by Armilar
                            @werners
                            so ist es...
                            Dachte um den Thread nicht in ein "Dein Server ist veraltet" Thema zu bringen, wäre es nicht schlecht das wesentliche auch zu lösen...
                            449
