    4. Shelly 2.5 PM Random AxiosError: timeout of 8000ms exceeded
    • da_Woody
      da_Woody @Fabio last edited by
      @fa-bio gerade gelinst. Wozu braucht man das bei ioB und dem Adapter?
      Fabio 1 Reply Last reply Reply Quote 0
      • Fabio
        Fabio @da_Woody last edited by
        @da_woody ich weiß es nicht. 🤷‍♂️
          SmartGuy1994 @Thomas Braun last edited by
          @thomas-braun sorry für die späte Rückmeldung, hier die Ausgabe von iob diag
          Skript v.2023-10-10
          *** BASE SYSTEM ***
             Static hostname: raspberrypi
                   Icon name: computer
            Operating System: Raspbian GNU/Linux 10 (buster)
                      Kernel: Linux 5.10.103-v7l+
                Architecture: arm
          Model		: Raspberry Pi 4 Model B Rev 1.1
          Docker          : false
          Virtualization  : none
          Kernel          : armv7l
          Userland        : armhf
          Systemuptime and Load:
           12:05:53 up 1 day, 23:20,  1 user,  load average: 0.74, 0.67, 0.52
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Sat 2024-01-27 12:05:53 CET
                     Universal time: Sat 2024-01-27 11:05:53 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          pi
          /home/pi
          pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server: 	true
          Desktop: 	LXDE-pi
          Terminal: 	x11
          Boot Target: 	graphical.target
          *** MEMORY ***
          Mem:           1.9G        1.0G        222M         13M        616M        730M
          Swap:           99M        5.0M         94M
          Total:         2.0G        1.0G        317M
                   1872 M total memory
                   1033 M used memory
                    281 M active memory
                   1245 M inactive memory
                    222 M free memory
                     76 M buffer memory
                    539 M swap cache
                     99 M total swap
                      5 M used swap
                     94 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
            UNIT           LOAD   ACTIVE SUB    DESCRIPTION
          * webmin.service loaded failed failed LSB: web-based administration interface for Unix systems
          LOAD   = Reflects whether the unit definition was properly loaded.
          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
          SUB    = The low-level unit activation state, values depend on unit type.
          1 loaded units listed. Pass --all to see loaded but inactive units, too.
          To show all installed unit files use 'systemctl list-unit-files'.
          *** FILESYSTEM ***
          /dev/root      ext4       59G  6.7G   50G  12% /
          devtmpfs       devtmpfs  776M     0  776M   0% /dev
          tmpfs          tmpfs     937M     0  937M   0% /dev/shm
          tmpfs          tmpfs     937M  9.6M  927M   2% /run
          tmpfs          tmpfs     937M     0  937M   0% /sys/fs/cgroup
          /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
          tmpfs          tmpfs     188M   12K  188M   1% /run/user/1000
          /dev/sda2      fuseblk   5.5T  1.1T  4.4T  21% /media/pi/External Drive
          [Thu Jan 25 12:45:31 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60D smsc95xx.macaddr=DC:A6:32:33:13:2B vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=db8ba147-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
          [Thu Jan 25 12:45:32 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
          [Thu Jan 25 12:45:32 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Thu Jan 25 12:45:34 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
          TARGET                     SOURCE         FSTYPE          OPTIONS
          /                          /dev/mmcblk0p2 ext4            rw,noatime
          |-/sys/fs/bpf              none           bpf             rw,nosuid,nodev,noexec,relatime,mode=700
          |-/run/user/1000/gvfs      gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
          |-/boot                    /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          `-/media/pi/External Drive /dev/sda2      fuseblk         rw,nosuid,nodev,relatime,user_id=0,group_id=0,default_permissions,allow_other,blksize=4096
          /var:
          519M	/var/
          245M	/var/lib
          123M	/var/lib/mysql
          122M	/var/cache
          107M	/var/cache/apt
          Archived and active journals take up 8.0M in the file system.
          /opt/iobroker/backups:
          861M	/opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          293M	/opt/iobroker/iobroker-data/
          163M	/opt/iobroker/iobroker-data/files
          97M	/opt/iobroker/iobroker-data/backup-objects
          77M	/opt/iobroker/iobroker-data/files/javascript.admin
          56M	/opt/iobroker/iobroker-data/files/javascript.admin/static
          21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
          9.1M	/opt/iobroker/iobroker-data/objects.jsonl
          8.3M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js
          7.5M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/691.26ff76ce.chunk.js.map
          7.2M	/opt/iobroker/iobroker-data/objects.json.migrated
          USB-Devices by-id:
          /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
          *** NodeJS-Installation ***
          /usr/bin/nodejs 	v18.19.0
          /usr/bin/node 		v18.19.0
          /usr/local/bin/npm 		9.6.7
          /usr/local/bin/npx 		9.6.7
          /usr/local/bin/corepack 	0.18.0
          *** nodejs is NOT correctly installed ***
          nodejs:
            Installed: 18.19.0-1nodesource1
            Candidate: 18.19.0-1nodesource1
            Version table:
           *** 18.19.0-1nodesource1 500
                  500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                  100 /var/lib/dpkg/status
               18.18.2-1nodesource1 500
               18.18.1-1nodesource1 500
               18.18.0-1nodesource1 500
               18.17.1-1nodesource1 500
               18.17.0-1nodesource1 500
               18.16.1-1nodesource1 500
               18.16.0-1nodesource1 500
               18.15.0-1nodesource1 500
               18.14.2-1nodesource1 500
               18.14.1-1nodesource1 500
               18.14.0-1nodesource1 500
               18.13.0-1nodesource1 500
               18.12.0-1nodesource1 500
               18.11.0-1nodesource1 500
               18.10.0-1nodesource1 500
               18.9.1-1nodesource1 500
               18.9.0-1nodesource1 500
               18.8.0-1nodesource1 500
               18.7.0-1nodesource1 500
               18.6.0-1nodesource1 500
               18.5.0-1nodesource1 500
               18.4.0-1nodesource1 500
               18.3.0-1nodesource1 500
               18.2.0-1nodesource1 500
               18.1.0-1nodesource1 500
               18.0.0-1nodesource1 500
               10.24.0~dfsg-1~deb10u3 500
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Core adapters versions
          js-controller: 	5.0.17
          admin: 		6.12.0
          javascript: 	7.1.6
          Adapters from github: 	0
          Adapter State
          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
          + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
            system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
            system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
            system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
          + system.adapter.denon.0                  : denon                 : raspberrypi                              -  enabled
          + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
            system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              - disabled, port: 0
          + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
            system.adapter.iot.0                    : iot                   : raspberrypi                              - disabled
          + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
            system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              - disabled, port: 54321
            system.adapter.mihome-vacuum.1          : mihome-vacuum         : raspberrypi                              - disabled, port: 54321
          + system.adapter.nibeuplink.0             : nibeuplink            : raspberrypi                              -  enabled
            system.adapter.onvif.0                  : onvif                 : raspberrypi                              - disabled
            system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              - disabled
            system.adapter.pushbullet.0             : pushbullet            : raspberrypi                              - disabled
          + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
            system.adapter.roborock.0               : roborock              : raspberrypi                              - disabled
          + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 192.168.3.24
            system.adapter.shelly.1                 : shelly                : raspberrypi                              - disabled, port: 1882, bind: 0.0.0.0
          + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            system.adapter.sonoff.0                 : sonoff                : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
          + system.adapter.tapo.0                   : tapo                  : raspberrypi                              -  enabled
          + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
            system.adapter.web.1                    : web                   : raspberrypi                              - disabled, port: 8092, bind: 0.0.0.0, run as: admin
          + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/ttyUSB0
            system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : raspberrypi                              - disabled
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 6.12.0   , installed 6.12.0
          Adapter    "alexa2"       : 3.26.3   , installed 3.24.1 [Updatable]
          Adapter    "backitup"     : 2.9.8    , installed 2.1.13 [Updatable]
          Adapter    "chromecast"   : 3.0.3    , installed 2.3.1  [Updatable]
          Adapter    "cloud"        : 4.4.1    , installed 4.1.0  [Updatable]
          Adapter    "daswetter"    : 3.1.12   , installed 3.1.10 [Updatable]
          Adapter    "denon"        : 1.15.4   , installed 1.7.4  [Updatable]
          Adapter    "discovery"    : 4.2.0    , installed 2.3.5  [Updatable]
          Adapter    "followthesun" : 0.5.0    , installed 0.3.5  [Updatable]
          Adapter    "hm-rpc"       : 1.15.19  , installed 1.14.2 [Updatable]
          Adapter    "info"         : 2.0.0    , installed 1.7.2  [Updatable]
          Adapter    "iot"          : 2.0.11   , installed 1.8.22 [Updatable]
          Adapter    "javascript"   : 7.1.6    , installed 7.1.6
          Controller "js-controller": 5.0.17   , installed 5.0.17
          Adapter    "mihome-vacuum": 4.1.1    , installed 4.1.1
          Adapter    "nibeuplink"   : 1.3.1    , installed 1.3.0  [Updatable]
          Adapter    "onvif"        : 1.1.1    , installed 1.0.5  [Updatable]
          Adapter    "openweathermap": 1.0.4   , installed 0.4.5  [Updatable]
          Adapter    "pushbullet"   : 2.0.1    , installed 0.0.11 [Updatable]
          Adapter    "pushover"     : 3.0.6    , installed 3.0.6
          Adapter    "ring"         : 5.0.10   , installed 1.1.3  [Updatable]
          Adapter    "roborock"     : 0.4.4    , installed 0.2.1  [Updatable]
          Adapter    "shelly"       : 6.6.1    , installed 6.6.1
          Adapter    "socketio"     : 6.6.0    , installed 3.0.7  [Updatable]
          Adapter    "sonoff"       : 3.0.3    , installed 2.5.3  [Updatable]
          Adapter    "tapo"         : 0.0.8    , installed 0.0.8
          Adapter    "vis"          : 1.5.4    , installed 1.3.4  [Updatable]
          Adapter    "web"          : 6.1.10   , installed 6.1.10
          Adapter    "ws"           : 2.5.8    , installed 2.5.8
          Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
          Adapter    "zigbee2mqtt"  : 2.13.4   , installed 2.9.0  [Updatable]
          Objects and States
          Objects: 	5455
          States: 	4432
          Hit:1 http://phoscon.de/apt/deconz buster InRelease
          Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
          Hit:3 http://archive.raspberrypi.org/debian buster InRelease
          Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17236      641/sshd
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          3648546    18053/cupsd
          tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          19186      745/smbd
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       31116      2196/iobroker.js-co
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       31109      2196/iobroker.js-co
          tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      114        21509      720/mysqld
          tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          19187      745/smbd
          tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          19095      617/vncserver-x11-c
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       31162      2214/io.admin.0
          tcp6       0      0 :::10001                :::*                    LISTEN      0          19154      751/apache2
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       30650      2357/io.web.0
          tcp6       0      0 :::10002                :::*                    LISTEN      0          19158      751/apache2
          tcp6       0      0 :::22                   :::*                    LISTEN      0          17238      641/sshd
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          3648545    18053/cupsd
          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       33099      2753/io.simple-api.
          tcp6       0      0 :::445                  :::*                    LISTEN      0          19184      745/smbd
          tcp6       0      0 :::139                  :::*                    LISTEN      0          19185      745/smbd
          tcp6       0      0 :::5900                 :::*                    LISTEN      0          19094      617/vncserver-x11-c
          udp        0      0 0.0.0.0:54188           0.0.0.0:*                           1001       4743979    22913/io.shelly.0
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       4737900    22913/io.shelly.0
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16631      593/dhcpcd
          udp        0      0 0.0.0.0:51820           0.0.0.0:*                           0          19842      -
          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          3648552    18055/cups-browsed
          udp        0      0 192.168.3.255:137       0.0.0.0:*                           0          20706      599/nmbd
          udp        0      0 192.168.3.24:137        0.0.0.0:*                           0          20705      599/nmbd
          udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          20693      599/nmbd
          udp        0      0 192.168.3.255:138       0.0.0.0:*                           0          20708      599/nmbd
          udp        0      0 192.168.3.24:138        0.0.0.0:*                           0          20707      599/nmbd
          udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          20694      599/nmbd
          udp        0      0 0.0.0.0:41133           0.0.0.0:*                           108        13269      348/avahi-daemon: r
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13267      348/avahi-daemon: r
          udp6       0      0 :::58973                :::*                                108        13270      348/avahi-daemon: r
          udp6       0      0 :::51820                :::*                                0          19843      -
          udp6       0      0 :::5353                 :::*                                108        13268      348/avahi-daemon: r
          2024-01-27 12:03:00.949  - info: simple-api.0 (2753) State value to set for "javascript.0.scriptEnabled.Rolllaeden_hoch" has to be type "boolean" but received type "number"
          2024-01-27 12:03:01.032  - info: javascript.0 (2236) Stop script script.js.Rolllaeden_hoch
          2024-01-27 12:03:01.199  - info: simple-api.0 (2753) State value to set for "javascript.0.scriptEnabled.Rolllaeden_runter" has to be type "boolean" but received type "number"
          2024-01-27 12:03:01.395  - info: javascript.0 (2236) Start javascript script.js.Rolllaeden_runter
          2024-01-27 12:03:01.504  - info: javascript.0 (2236) script.js.Rolllaeden_runter: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          2024-01-27 12:03:06.217  - info: simple-api.0 (2753) State value to set for "javascript.0.scriptEnabled.Rolllaeden_runter" has to be type "boolean" but received type "number"
          2024-01-27 12:03:06.289  - info: javascript.0 (2236) Stop script script.js.Rolllaeden_runter
          2024-01-27 12:03:06.421  - info: simple-api.0 (2753) State value to set for "javascript.0.scriptEnabled.Rolllaeden_hoch" has to be type "boolean" but received type "number"
          2024-01-27 12:03:06.436  - info: javascript.0 (2236) Start javascript script.js.Rolllaeden_hoch
          2024-01-27 12:03:06.490  - info: javascript.0 (2236) script.js.Rolllaeden_hoch: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
          2024-01-27 12:03:09.910  - error: shelly.0 (22913) [http controlFunction] Error in function state.coap.http_cmd of state SHSW-25#E8DB84AA6A80#1.Shutter.Position for 192.168.3.132 (shellyswitch25 / shellyswitch25-E8DB84AA6A80 / SHSW-25#E8DB84AA6A80#1): AxiosError: timeout of 8000ms exceeded
          2024-01-27 12:03:09.925  - error: shelly.0 (22913) [http controlFunction] Error in function state.coap.http_cmd of state SHSW-25#E8DB84ACC809#1.Shutter.Position for 192.168.3.114 (shellyswitch25 / shellyswitch25-E8DB84ACC809 / SHSW-25#E8DB84ACC809#1): AxiosError: timeout of 8000ms exceeded
          2024-01-27 12:03:10.637  - info: shelly.0 (22913) [CoAP] Device 192.168.3.109 (shellyswitch25 / shellyswitch25-E8DB84AA1F6E / SHSW-25#E8DB84AA1F6E#1) connected! Polltime set to 15 sec.
          2024-01-27 12:03:14.534  - error: shelly.0 (22913) [http controlFunction] Error in function state.coap.http_cmd of state SHSW-25#E8DB84ACC809#1.Shutter.Position for 192.168.3.114 (shellyswitch25 / shellyswitch25-E8DB84ACC809 / SHSW-25#E8DB84ACC809#1): AxiosError: timeout of 8000ms exceeded
          2024-01-27 12:04:13.640  - info: shelly.0 (22913) [CoAP] Device 192.168.3.131 (shellyswitch25 / shellyswitch25-E8DB84ACB936 / SHSW-25#E8DB84ACB936#1) connected! Polltime set to 15 sec.
          iob diag has finished.
            Thomas Braun Most Active @SmartGuy1994 last edited by Thomas Braun
            @smartguy1994 sagte in Shelly 2.5 PM Random AxiosError: timeout of 8000ms exceeded:
            Kannst du direkt auf 12 Bookworm bringen.
            Neuinstallation in der 64Bit-Variante, natürlich ohne Desktop-Quark.
            Dann wäre auch dein nodejs-Krempel senkrecht und der Update-Stau ist auch zu beseitigen.
              @thomas-braun das wollte ich eigentlich vermeiden, da ich im Sommer auf Home Assistent umsteige und Debian 10 zumindest bis zum Sommer ja noch supportet wird.
                @smartguy1994
                Nein. Raspberry OS 10 wird nicht mehr unterstützt, weil Raspberry nur das aktuelle und vorherige Release supporten.
                Und dein nodejs ist trotzdem krumm. Und die Adapter sind trotzdem nicht auf aktuellem Stand.
                iob nodejs-update
                ausführen und die Adapter updaten.
                  @thomas-braun ich verstehe, das hatte ich nicht auf dem Schirm.
                  Ich habe nodejs bei mir gerade gezogen und noch alle ausstehenden Updates nachgeholt.
                  Problem besteht leider trotzdem unverändert.
                  Danke für eure Hilfe
                  Thomas Braun Fabio 2 Replies Last reply Reply Quote 0
                    @smartguy1994
                    iob diag
                    sagt nun?
                    • Fabio
                      Fabio @SmartGuy1994 last edited by Fabio
                      @smartguy1994 hast du die shelly mal rebootet und sind die shelly auch ereichbar über die weboberfläche wenn du den Error im ioBroker hast?
                        @thomas-braun ```
                        *** BASE SYSTEM ***        Static hostname: raspberrypi
                                 Icon name: computer
                              Architecture: arm
                        Docker          : false
                        Kernel          : armv7l
                        Userland        : armhf
                         13:13:06 up 38 min,  2 users,  load average: 0.40, 1.11, 1.49
                        CPU threads: 4
                        Current issues:
                                       Local time: Sat 2024-01-27 13:13:07 CET
                                   Universal time: Sat 2024-01-27 12:13:07 UTC
                                         RTC time: n/a
                                      NTP service: active
                                  RTC in local TZ: no
                        pi
                        /home/pi
                        pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                        /home/iobroker/.diag.sh: line 200: [[: 675
                        4331: syntax error in expression (error token is "4331")
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Mem:           1.9G        996M        228M         14M        647M        763M
                        Swap:           99M         10M         89M
                        Total:         2.0G        1.0G        318M
                                 1872 M total memory
                                  996 M used memory
                                  330 M active memory
                                 1183 M inactive memory
                                  228 M free memory
                                  102 M buffer memory
                                  545 M swap cache
                                   99 M total swap
                                   10 M used swap
                                   89 M free swap
                        Raspberry only:
                        oom events: 0
                        *** FILESYSTEM ***
                        /dev/root      ext4       59G  6.9G   50G  13% /
                        tmpfs          tmpfs     188M     0  188M   0% /run/user/112
                        [Sat Jan 27 12:34:50 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60D smsc95xx.macaddr=DC:A6:32:33:13:2B vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=db8ba147-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
                        [Sat Jan 27 12:34:51 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                        [Sat Jan 27 12:34:51 2024] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                        [Sat Jan 27 12:34:53 2024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                        |-/run/user/112/gvfs       gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=112,group_id=118
                        /var:
                        520M    /var/
                        245M    /var/lib
                        123M    /var/lib/mysql
                        122M    /var/cache
                        107M    /var/cache/apt
                        331M    /opt/iobroker/iobroker-data/
                        201M    /opt/iobroker/iobroker-data/files
                        33M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
                        13M     /opt/iobroker/iobroker-data/objects.jsonl
                        8.5M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js
                        USB-Devices by-id:
                        /usr/bin/npm            10.2.3
                        /usr/bin/npx            10.2.3
                        /usr/bin/corepack       0.22.0
                        nodejs:
                          Version table:
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin:          6.12.0
                        javascript:     7.1.6
                        Adapter State
                        + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                        + instance is alive
                        Adapter    "alexa2"       : 3.26.3   , installed 3.26.3
                        Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                        Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
                        Adapter    "daswetter"    : 3.1.12   , installed 3.1.12
                        Adapter    "denon"        : 1.15.4   , installed 1.15.4
                        Adapter    "followthesun" : 0.5.0    , installed 0.5.0
                        Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                        Adapter    "iot"          : 2.0.11   , installed 2.0.11
                        Adapter    "nibeuplink"   : 1.3.1    , installed 1.3.1
                        Adapter    "onvif"        : 1.1.1    , installed 1.1.1
                        Adapter    "openweathermap": 1.0.4   , installed 1.0.4
                        Adapter    "pushbullet"   : 2.0.1    , installed 2.0.1
                        Adapter    "ring"         : 5.0.10   , installed 5.0.10
                        Adapter    "roborock"     : 0.4.4    , installed 0.4.4
                        Adapter    "sonoff"       : 3.0.3    , installed 3.0.3
                        Adapter    "zigbee2mqtt"  : 2.13.4   , installed 2.13.4
                        Objects and States
                        Objects:        6382
                        States:         5153
                        Pending Updates: 0
                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          20773      644/sshd
                        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15806      344/cupsd
                        tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          19098      740/smbd
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       31882      2753/iobroker.js-co
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       31530      2753/iobroker.js-co
                        tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      114        18996      719/mysqld
                        tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          19099      740/smbd
                        tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          19831      638/vncserver-x11-c
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       30615      2771/io.admin.0
                        tcp6       0      0 :::10001                :::*                    LISTEN      0          18297      741/apache2
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       56535      5932/io.web.0
                        tcp6       0      0 :::10002                :::*                    LISTEN      0          18301      741/apache2
                        tcp6       0      0 :::22                   :::*                    LISTEN      0          20775      644/sshd
                        tcp6       0      0 :::8087                 :::*                    LISTEN      1001       33303      3079/io.simple-api.
                        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15805      344/cupsd
                        tcp6       0      0 :::445                  :::*                    LISTEN      0          19096      740/smbd
                        tcp6       0      0 :::139                  :::*                    LISTEN      0          19097      740/smbd
                        tcp6       0      0 :::5900                 :::*                    LISTEN      0          19830      638/vncserver-x11-c
                        udp        0      0 0.0.0.0:42468           0.0.0.0:*                           108        15026      334/avahi-daemon: r
                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       60492      6095/io.shelly.0
                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16062      591/dhcpcd
                        udp        0      0 0.0.0.0:51820           0.0.0.0:*                           0          20812      -
                        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          17270      496/cups-browsed
                        udp        0      0 192.168.3.255:137       0.0.0.0:*                           0          18868      603/nmbd
                        udp        0      0 192.168.3.24:137        0.0.0.0:*                           0          18867      603/nmbd
                        udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          18855      603/nmbd
                        udp        0      0 192.168.3.255:138       0.0.0.0:*                           0          18870      603/nmbd
                        udp        0      0 192.168.3.24:138        0.0.0.0:*                           0          18869      603/nmbd
                        udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          18856      603/nmbd
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15024      334/avahi-daemon: r
                        udp6       0      0 :::51820                :::*                                0          20813      -
                        udp6       0      0 :::5353                 :::*                                108        15025      334/avahi-daemon: r
                        udp6       0      0 :::56057                :::*                                108        15027      334/avahi-daemon: r
                        2024-01-27 13:06:08.979  - info: javascript.0 (2788) Start javascript script.js.Rolllaeden_hoch
                        2024-01-27 13:06:09.043  - info: javascript.0 (2788) script.js.Rolllaeden_hoch: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                        2024-01-27 13:06:46.518  - info: simple-api.0 (3079) State value to set for "javascript.0.scriptEnabled.Rolllaeden_hoch" has to be type "boolean" but received type "number"
                        2024-01-27 13:06:46.529  - info: javascript.0 (2788) Stop script script.js.Rolllaeden_hoch
                        2024-01-27 13:06:46.732  - info: simple-api.0 (3079) State value to set for "javascript.0.scriptEnabled.Rolllaeden_runter" has to be type "boolean" but received type "number"
                        2024-01-27 13:06:46.749  - info: javascript.0 (2788) Start javascript script.js.Rolllaeden_runter
                        2024-01-27 13:06:46.827  - info: javascript.0 (2788) script.js.Rolllaeden_runter: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions2024-01-27 13:06:46.856  - warn: shelly.0 (6095) [http controlFunction] Unable to perform request - device 192.168.3.132 (shellyswitch25 / shellyswitch25-E8DB84AA6A80 / SHSW-25#E8DB84AA6A80#1) is offline
                        2024-01-27 13:06:46.865  - warn: shelly.0 (6095) [http controlFunction] Unable to perform request - device 192.168.3.131 (shellyswitch25 / shellyswitch25-E8DB84ACB936 / SHSW-25#E8DB84ACB936#1) is offline
                        2024-01-27 13:06:53.945  - info: simple-api.0 (3079) State value to set for "javascript.0.scriptEnabled.Rolllaeden_runter" has to be type "boolean" but received type "number"
                        2024-01-27 13:06:53.957  - info: javascript.0 (2788) Stop script script.js.Rolllaeden_runter
                        2024-01-27 13:06:54.159  - info: simple-api.0 (3079) State value to set for "javascript.0.scriptEnabled.Rolllaeden_hoch" has to be type "boolean" but received type "number"
                        2024-01-27 13:06:54.172  - info: javascript.0 (2788) Start javascript script.js.Rolllaeden_hoch
                        2024-01-27 13:06:54.238  - info: javascript.0 (2788) script.js.Rolllaeden_hoch: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                        2024-01-27 13:06:54.296  - warn: shelly.0 (6095) [http controlFunction] Unable to perform request - device 192.168.3.132 (shellyswitch25 / shellyswitch25-E8DB84AA6A80 / SHSW-25#E8DB84AA6A80#1) is offline
                        2024-01-27 13:06:54.303  - warn: shelly.0 (6095) [http controlFunction] Unable to perform request - device 192.168.3.131 (shellyswitch25 / shellyswitch25-E8DB84ACB936 / SHSW-25#E8DB84ACB936#1) is offline
                        2024-01-27 13:08:33.923  - info: shelly.0 (6095) [CoAP] Device 192.168.3.114 (shellyswitch25 / shellyswitch25-E8DB84ACC809 / SHSW-25#E8DB84ACC809#1) connected! Polltime set to 30 sec.
                        2024-01-27 13:08:46.350  - info: javascript.0 (2788) script.js.Pool_Temperatur_Steuerung_Pumpe_Winter: Außentemperatur: 2.7
                        2024-01-27 13:08:46.421  - info: javascript.0 (2788) script.js.Pool_Temperatur_Steuerung_Pumpe_Winter: Ende des Laufs
                        2024-01-27 13:08:46.437  - info: javascript.0 (2788) script.js.Pool_Temperatur_Steuerung_Pumpe_Winter: ['wui.init('syrFLLjsQaPD2MyaDfAS8xOaevpyskOM',false);','syrFLLjsQaPD2MyaDfAS8xOaevpyskOM']
                        2024-01-27 13:08:46.499  - info: javascript.0 (2788) script.js.Pool_Temperatur_Steuerung_Pumpe_Winter: Aktuelle Wassertemperatur: 3.1
                        2024-01-27 13:08:46.499  - info: javascript.0 (2788) script.js.Pool_Temperatur_Steuerung_Pumpe_Winter: Aktueller Wert: 2 , Gewünschter Wert: 2
                        2024-01-27 13:10:41.265  - warn: zigbee.0 (2854) DeviceAvailability:Stopping to ping 0xec1bbdfffea3e7cc TS011F after 4 ping attempts
                        2024-01-27 13:12:22.613  - info: admin.0 (2771) <== Disconnect system.user.admin from ::ffff:192.168.3.154 admin
                        2024-01-27 13:13:15.478  - info: admin.0 (2771) ==> Connected system.user.admin from ::ffff:192.168.3.154
                        Press any key for a summary
                          SmartGuy1994 @Fabio last edited by
                          @fa-bio ja sind über die Weboberfläche erreichbar und steuerbar. Neugestartet habe ich sie auch schon.
                          • Fabio
                            @smartguy1994 hm das ist komisch was sind denn die Schutter Daten die du überträgts kannst du das mal zeigen.
                              • Fabio
                                @smartguy1994 hast du schon mal probiert andere Prozentwerte zu nehmen also zum Beispiel 50% ist das Verhalten dann immer noch so?
                                Sind die alle über den Shelly Adapter eingebunden, wenn ja, kannst du in den Datenpunkten selber die Prozentzahl ändern und was passiert dann?
                                  @fa-bio ja das Verhalten ist dabei leider das selbe
                                  • Fabio
                                    @smartguy1994 also halten wir fest über die Webseite oder App geht der Shelly einwandfrei über ioBroker Adapter nicht oder nicht richtig. Also dann weiß ich auch nicht weiter. Evtl mal die Einstellungen vom Shelly Adapter bitte zeigen.
                                    Ich empfehle dir auch alles auf den neusten Stand zu bringen.
                                    Ansonten auf Github ein Issues öffnen.
                                    Fabio
                                      @fa-bio Screenshot_20240127_141453_Chrome.png Screenshot_20240127_141448_Chrome.png
                                      Aber wenn ihr auch keine Idee habt stelle ich das als Issue bei GitHub ein.
                                      Vielen lieben Dank euch für euren Einsatz.
                                      Fabio da_Woody 2 Replies Last reply Reply Quote 0
                                      • Fabio
                                        @smartguy1994 mach mal bitte den Haken weg bei "aktualiseren auch wenn keine werte" starte dann neu und probiere noch mal.
                                        • da_Woody
                                          da_Woody @SmartGuy1994 last edited by
                                          @smartguy1994 sorry wenn ich mich da nochmal einklinke...
                                          warum steuerst du die dinger nicht automatisch über die app, oder verwendest den adapter shuttercontrol für automatisierung?
                                          lieber mit js rumfummeln?
                                          die dinger funktionieren einwandfrei, da wird IMHO ein issue auf github auch nicht helfen.
                                            SmartGuy1994 @da_Woody last edited by
                                            @da_woody als ich es vor einigen Jahren gebastelt hatte war das die einfachste Lösung für meine Anforderung. Jetzt werde ich dann wahrscheinlich sowieso auf Home Assistent umsteigen, auch um meine Custom Web UI abzulösen die ich vor einigen Jahren für den ioBroker Rest Api Adapter gebaut hatte.
                                            Da ist die GUI schon out-of-the-box für mich stimmig.
                                            Ich danke euch für eure Unterstützung.
                                            1800
