    3. Off Topic
    4. InfluxDB
    5. Keinen zugriff auf Influx DB
      Herrx @Thomas Braun last edited by
      @thomas-braun said in Keinen zugriff auf Influx DB:
        sudo apt update        sudo apt install grafana
      pi@raspberrypi:~ $ sudo apt-get install -y apt-transport-https
      sudo apt-get install -y software-properties-common wget
      sudo wget -q -O /usr/share/keyrings/grafana.key https://apt.grafana.com/gpg.key
      echo "deb [signed-by=/usr/share/keyrings/grafana.key] https://apt.grafana.com stable main" | sudo tee /etc/apt/sources.list.d/grafana.list
      Reading package lists... Done
      Building dependency tree... Done
      apt-transport-https is already the newest version (2.6.1).
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      software-properties-common is already the newest version (0.99.30-4).
      wget is already the newest version (1.21.3-1+b1).
      pi@raspberrypi:~ $ sudo apt update
      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://repos.influxdata.com/debian stable InRelease
      Hit:6 https://apt.grafana.com stable InRelease
      Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
      All packages are up to date.
      grafana is already the newest version (10.2.3).
      Super Danke. Aber Grafana kann ich ebenfalls nicht über die RPI-IP:3000 erreichen.
        Thomas Braun Most Active @Herrx last edited by
        @herrx
        systemctl status grafana
          Herrx @Thomas Braun last edited by Herrx
          pi@raspberrypi:~ $ systemctl status grafana
          Unit grafana.service could not be found.
          pi@raspberrypi:~ $
          ?? Aber die Installation war doch ohne Probleme ?
            @herrx
            systemctl status grafana*
              pi@raspberrypi:~ $ systemctl status grafana*
              pi@raspberrypi:~ $
                @herrx
                sudo apt update
                apt policy grafana*
                  @herrx
                  Bzw:
                  sudo systemctl daemon-reload
                  sudo systemctl start grafana-server
                  sudo systemctl status grafana-server
                    ● grafana-server.service - Grafana instance
                         Loaded: loaded (/lib/systemd/system/grafana-server.service; disabled; preset: enabled)
                         Active: active (running) since Tue 2024-01-23 00:04:49 CET; 34s ago
                           Docs: http://docs.grafana.org
                       Main PID: 19823 (grafana)
                          Tasks: 15 (limit: 457)
                            CPU: 9.853s
                         CGroup: /system.slice/grafana-server.service
                                 └─19823 /usr/share/grafana/bin/grafana server --config=/etc/grafana/grafana.ini --pidfile=/run/grafana/grafana-server.pid --packaging=deb cfg:default.pat>
                    Jan 23 00:05:10 raspberrypi grafana[19823]: logger=provisioning.alerting t=2024-01-23T00:05:10.484274781+01:00 level=info msg="finished to provision alerting"
                    Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ngalert.state.manager t=2024-01-23T00:05:10.487621618+01:00 level=info msg="Warming state cache for startup"
                    Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ngalert.state.manager t=2024-01-23T00:05:10.489519141+01:00 level=info msg="State cache has been initialized" state>
                    Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ngalert.scheduler t=2024-01-23T00:05:10.489682063+01:00 level=info msg="Starting scheduler" tickInterval=10s
                    Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ticker t=2024-01-23T00:05:10.498451052+01:00 level=info msg=starting first_tick=2024-01-23T00:05:20+01:00
                    Jan 23 00:05:10 raspberrypi grafana[19823]: logger=ngalert.multiorg.alertmanager t=2024-01-23T00:05:10.498873707+01:00 level=info msg="Starting MultiOrg Alertmanager"
                    Jan 23 00:05:10 raspberrypi grafana[19823]: logger=grafanaStorageLogger t=2024-01-23T00:05:10.505991925+01:00 level=info msg="Storage starting"
                    Jan 23 00:05:10 raspberrypi grafana[19823]: logger=http.server t=2024-01-23T00:05:10.531073444+01:00 level=info msg="HTTP Server Listen" address=[::]:3000 protocol=ht>
                    Jan 23 00:05:10 raspberrypi grafana[19823]: logger=grafana.update.checker t=2024-01-23T00:05:10.849257594+01:00 level=info msg="Update check succeeded" duration=342.5>
                    Jan 23 00:05:10 raspberrypi grafana[19823]: logger=plugins.update.checker t=2024-01-23T00:05:10.868909627+01:00 level=info msg="Update check succeeded" d
                    Sehr cool danke. Jetzt geht es.
                      Thomas Braun Most Active last edited by
                      @herrx
                      Schau mal ob der auch nach einem Neustart auf die Beine kommt.
                        @thomas-braun ok da kommt mein Grafana nicht wieder auf die Beine
                          @herrx
                          sudo systemctl enable grafana-server.service
                          sudo systemctl start grafana-server.service
                            @thomas-braun Super Danke das hat geholfen. Muss ich das nach jedem reboot wieder eingeben?
                            jetzt habe ich die Grafana anzeige wieder. Allerdings gibt mir mein Solarman nur alle 6min den aktuellen Leistungswert. Kann ich die Punkte dazwischen interpolieren? oder zumindest die Punkte verbinden?
                              @herrx sagte in Keinen zugriff auf Influx DB:
                              Nein, der Service sollte nun beim booten gestartet werden.
                              1413
