    4. Jarvis Adapter lässt sich nicht Installieren
    • Glasfaser
      Glasfaser @Schweiz last edited by Glasfaser
      @schweiz sagte in Jarvis Adapter lässt sich nicht Installieren:
      notarget No matching version found for
      Zeige mal die Ausgabe von :
      curl -L -o diag.sh https://iobroker.net/diag.sh
        complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-27T20_06_49_104Z-debug-0.log
        zeigen
          Schweiz @Homoran last edited by
          john@raspberrypi:~ $ curl -L -o diag.sh https://iobroker.net/diag.sh
            % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                           Dload  Upload   Total   Spent    Left  Speed
          100   185  100   185    0     0    693      0 --:--:-- --:--:-- --:--:--   692
          100 18519  100 18519    0     0  25049      0 --:--:-- --:--:-- --:--:-- 25049
          john@raspberrypi:~ $ nano /home/iobroker/.npm/_logs/2024-01-27T20_06_49_104Z-deb        ug-0.log
            GNU nano 7.2                                                        /home/iobroker/.npm/_logs/2024-01-27T20_06_49_104Z-debug-0.log
          0 verbose cli /usr/bin/node /usr/bin/npm
          1 info using npm@10.2.3
          2 info using node@v18.19.0
          3 timing npm:load:whichnode Completed in 4ms
          4 timing config:load:defaults Completed in 6ms
          5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 3ms
          6 timing config:load:builtin Completed in 4ms
          7 timing config:load:cli Completed in 12ms
          8 timing config:load:env Completed in 1ms
          9 timing config:load:file:/opt/iobroker/.npmrc Completed in 5ms
          10 timing config:load:project Completed in 18ms
          11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
          12 timing config:load:user Completed in 1ms
          13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
          14 timing config:load:global Completed in 1ms
          15 timing config:load:setEnvs Completed in 3ms
          16 timing config:load Completed in 49ms
          17 timing npm:load:configload Completed in 50ms
          18 timing config:load:flatten Completed in 9ms
          19 timing npm:load:mkdirpcache Completed in 1ms
          20 timing npm:load:mkdirplogs Completed in 0ms
          21 verbose title npm install iobroker.alexa2@3.26.4
          22 verbose argv "install" "--save-exact" "iobroker.alexa2@3.26.4"
          23 timing npm:load:setTitle Completed in 4ms
          24 timing npm:load:display Completed in 2ms
          25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2024-01-27T20_06_49_104Z-
          26 verbose logfile /home/iobroker/.npm/_logs/2024-01-27T20_06_49_104Z-debug-0.log
          27 timing npm:load:logFile Completed in 29ms
          28 timing npm:load:timers Completed in 0ms
          29 timing npm:load:configScope Completed in 1ms
          30 timing npm:load Completed in 146ms
          31 timing arborist:ctor Completed in 3ms
          32 silly logfile start cleaning logs, removing 2 files
          33 silly logfile done cleaning log files
          34 timing idealTree:init Completed in 2412ms
          35 timing idealTree:userRequests Completed in 5ms
          36 silly idealTree buildDeps
          37 silly fetch manifest iobroker.alexa2@3.26.4
          38 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules/iobroker.alexa2
          39 http fetch GET 200 https://registry.npmjs.org/iobroker.alexa2 460149ms (cache stale)
          40 silly placeDep ROOT iobroker.alexa2@ REPLACE for: iobroker.inst@3.0.0 want: 3.26.4
          41 timing idealTree:#root Completed in 460211ms
          42 timing idealTree:node_modules/iobroker.alexa2 Completed in 1ms
          43 timing idealTree:buildDeps Completed in 460215ms
          44 timing idealTree:fixDepFlags Completed in 85ms
          45 timing idealTree Completed in 462721ms
          46 timing command:install Completed in 462749ms
          47 verbose type version
          MFG Schweizer
          • Glasfaser
            iob stop
            rm /opt/iobroker/package*
            sudo reboot
              Schweiz @Glasfaser last edited by
              @glasfaser
              john@raspberrypi:~ $ iob upgrade alexa2@3.26.4 --debug
              This upgrade of "alexa2" will introduce the following changes:
              -> 3.26.4:
              Removed Weblink
              Adjust History query to recent Amazon changes
              Would you like to upgrade alexa2 from @3.26.3 to @3.26.4 now? [(y)es, (n)o]: y
              Update alexa2 from @3.26.3 to @3.26.4
              NPM version: 10.2.3
              Installing iobroker.alexa2@3.26.4... (System call)
              npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
              removed 746 packages, and changed 20 packages in 29s
              15 packages are looking for funding
                run `npm fund` for details
              Could not install iobroker.alexa2@3.26.4: Could not determine controller directory
              Cannot upgrade: Could not determine controller directory
              MFG Schweizer
              Glasfaser S 2 Replies Last reply Reply Quote 0
              • Glasfaser
                @schweiz
                Zeige mal
                iob diag
                aber die Full Ausgabe
                  Schweiz @Schweiz last edited by
                  und es lässt sich weder iobroker noch homematic starten ;(
                  MFG Schweizer
                  • Glasfaser
                    MFG Schweizer
                    Hat aber nichts mit den Befehlen von mir zu tun !
                    Da klemmt eher was bei dir !
                    Starte nochmal durch , dann
                    iob diag
                      @glasfaser sagte in Jarvis Adapter lässt sich nicht Installieren:
                      iob diag
                      Skript v.2023-10-10
                      *** BASE SYSTEM ***
                       Static hostname: raspberrypi
                             Icon name: computer
                                Kernel: Linux 6.1.0-rpi7-rpi-v8
                          Architecture: arm64
                      Model           : Raspberry Pi 4 Model B Rev 1.1
                      Docker          : false
                      Virtualization  : none
                      Kernel          : aarch64
                      Userland        : arm64
                      Systemuptime and Load:
                       21:28:36 up 5 min,  2 users,  load average: 0.13, 0.65, 0.40
                      CPU threads: 4
                      *** RASPBERRY THROTTLING ***
                      Current issues:
                      Previously detected issues:
                      *** Time and Time Zones ***
                                     Local time: Sat 2024-01-27 21:28:36 CET
                                 Universal time: Sat 2024-01-27 20:28:36 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      *** User and Groups ***
                      john
                      /home/john
                      john adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                      *** X-Server-Setup ***
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      Boot Target:    multi-user.target
                      *** MEMORY ***
                      Mem:            4.0G        439M        3.2G        1.3M        405M        3.5G
                      Swap:           104M          0B        104M
                      Total:          4.1G        439M        3.3G
                               3793 M total memory
                                419 M used memory
                                446 M active memory
                                180 M inactive memory
                               3061 M free memory
                                 39 M buffer memory
                                346 M swap cache
                                 99 M total swap
                                  0 M used swap
                                 99 M free swap
                      Raspberry only:
                      oom events: 0
                      *** FAILED SERVICES ***
                      0 loaded units listed.
                      *** FILESYSTEM ***
                      udev           devtmpfs  1.6G     0  1.6G   0% /dev
                      tmpfs          tmpfs     380M  1.2M  379M   1% /run
                      /dev/mmcblk0p2 ext4       59G  3.8G   52G   7% /
                      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                      /dev/mmcblk0p1 vfat      510M   62M  449M  13% /boot/firmware
                      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                      [Sat Jan 27 21:22:48 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:29:88:49 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=620a9d97-02 rootfstype=ext4 fsck.repair=yes rootwait
                      [Sat Jan 27 21:22:50 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                      [Sat Jan 27 21:22:52 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                      TARGET           SOURCE         FSTYPE OPTIONS
                      /                /dev/mmcblk0p2 ext4   rw,noatime
                      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                      /var:
                      1.2G    /var/
                      837M    /var/lib
                      662M    /var/lib/piVCCU3
                      604M    /var/lib/piVCCU3/rootfs
                      279M    /var/lib/piVCCU3/rootfs/opt
                      Archived and active journals take up 85.1M in the file system.
                      /opt/iobroker/backups:
                      34M     /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      319M    /opt/iobroker/iobroker-data/
                      185M    /opt/iobroker/iobroker-data/files
                      86M     /opt/iobroker/iobroker-data/backup-objects
                      67M     /opt/iobroker/iobroker-data/files/javascript.admin
                      49M     /opt/iobroker/iobroker-data/files/telegram-menu.admin
                      38M     /opt/iobroker/iobroker-data/objects.jsonl
                      36M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
                      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
                      13M     /opt/iobroker/iobroker-data/states.jsonl
                      13M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js
                      USB-Devices by-id:
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs         v18.19.0
                      /usr/bin/node           v18.19.0
                      /usr/bin/npm            10.2.3
                      /usr/bin/npx            10.2.3
                      /usr/bin/corepack       0.22.0
                      nodejs:
                        Installed: 18.19.0-1nodesource1
                        Candidate: 18.19.0-1nodesource1
                        Version table:
                           18.19.0+dfsg-6~deb12u1 500
                       *** 18.19.0-1nodesource1 1001
                              100 /var/lib/dpkg/status
                           18.18.2-1nodesource1 1001
                           18.18.1-1nodesource1 1001
                           18.18.0-1nodesource1 1001
                           18.17.1-1nodesource1 1001
                           18.17.0-1nodesource1 1001
                           18.16.1-1nodesource1 1001
                           18.16.0-1nodesource1 1001
                           18.15.0-1nodesource1 1001
                           18.14.2-1nodesource1 1001
                           18.14.1-1nodesource1 1001
                           18.14.0-1nodesource1 1001
                           18.13.0+dfsg1-1 500
                           18.13.0-1nodesource1 1001
                           18.12.0-1nodesource1 1001
                           18.11.0-1nodesource1 1001
                           18.10.0-1nodesource1 1001
                           18.9.1-1nodesource1 1001
                           18.9.0-1nodesource1 1001
                           18.8.0-1nodesource1 1001
                           18.7.0-1nodesource1 1001
                           18.6.0-1nodesource1 1001
                           18.5.0-1nodesource1 1001
                           18.4.0-1nodesource1 1001
                           18.3.0-1nodesource1 1001
                           18.2.0-1nodesource1 1001
                           18.1.0-1nodesource1 1001
                           18.0.0-1nodesource1 1001
                      No problems detected
                      Errors in npm tree:
                      *** ioBroker-Installation ***
                      ioBroker Status
                      node:internal/modules/cjs/loader:1137
                        throw err;
                      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                          at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
                          at Module._load (node:internal/modules/cjs/loader:975:27)
                          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
                          at node:internal/main/run_main_module:28:49 {
                        code: 'MODULE_NOT_FOUND',
                        requireStack: []
                      Node.js v18.19.0
                      Core adapters versions
                        throw err;
                        requireStack: []
                      Node.js v18.19.0
                      js-controller:
                        throw err;
                        requireStack: []
                      Node.js v18.19.0
                      admin:
                        throw err;
                        requireStack: []
                      Node.js v18.19.0
                      javascript:
                      Adapters from github:   0
                      Adapter State
                        throw err;
                        requireStack: []
                      Node.js v18.19.0
                        throw err;
                        requireStack: []
                      Node.js v18.19.0
                      ioBroker-Repositories
                        throw err;
                        requireStack: []
                      Node.js v18.19.0
                      Installed ioBroker-Instances
                        throw err;
                        requireStack: []
                      Node.js v18.19.0
                      Objects and States
                      Objects:        0
                      States:         0
                      Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
                      Hit:2 http://deb.debian.org/debian bookworm InRelease
                      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                      Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
                      Reading package lists...
                      Pending Updates: 10
                      *** Listening Ports ***
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16812      1009/sshd: /usr/sbi
                      tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          16839      1053/dnsmasq
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          16814      1009/sshd: /usr/sbi
                      udp        0      0 0.0.0.0:56245           0.0.0.0:*                           104        15562      507/avahi-daemon: r
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        15560      507/avahi-daemon: r
                      udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          16838      1053/dnsmasq
                      udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          16835      1053/dnsmasq
                      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12872      906/dhclient
                      udp6       0      0 :::46068                :::*                                104        15563      507/avahi-daemon: r
                      udp6       0      0 :::5353                 :::*                                104        15561      507/avahi-daemon: r
                      - /opt/iobroker/node_modules/@iobroker/adapter-core/build/controllerTools.js
                      - /opt/iobroker/node_modules/@iobroker/adapter-core/build/index.js
                      - /opt/iobroker/node_modules/iobroker.alexa2/main.js
                          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
                          at Function.Module._load (node:internal/modules/cjs/loader:975:27)
                          at Module.require (node:internal/modules/cjs/loader:1225:19)
                          at require (node:internal/modules/helpers:177:18)
                          at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1800:82
                          at AdapterClass._setObject (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1800:34)
                      2024-01-27 21:24:08.726  - error: alexa2.0 (1919) Exception-Code: MODULE_NOT_FOUND: Cannot find module './defaultObjs.js'
                      Require stack:
                      - /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js
                      - /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/index.js
                      - /opt/iobroker/node_modules/@iobroker/adapter-core/build/utils.js
                      2024-01-27 21:24:09.032  - info: hm-rpc.1 (2113) terminating
                      2024-01-27 21:24:09.035  - info: hm-rpc.1 (2113) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2024-01-27 21:24:09.065  - info: hm-rpc.0 (1981) terminating
                      2024-01-27 21:24:09.069  - info: hm-rpc.0 (1981) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2024-01-27 21:24:09.083  - error: iceroad.0 (2213) Objects database error: read ECONNRESET
                      2024-01-27 21:24:10.692  - info: iceroad.0 (2213) terminating with timeout
                      2024-01-27 21:24:10.694  - info: iceroad.0 (2213) Terminated (NO_ERROR): Without reason
                      2024-01-27 21:24:14.100  - warn: iceroad.0 (2213) get state error: Connection is closed.
                      MFG Schweizer
                      • Glasfaser
                        Glasfaser last edited by Glasfaser
                        @schweiz
                        cd /opt/iobroker
                        npm cache clean --force
                        sudo -H -u iobroker npm install iobroker.js-controller
                        S Glasfaser 2 Replies Last reply Reply Quote 0
                          john@raspberrypi:~ $ cd /opt/iobroker
                          john@raspberrypi:/opt/iobroker $ npm cache clean --force
                          npm WARN using --force Recommended protections disabled.
                          john@raspberrypi:/opt/iobroker $ iob stop
                          john@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-con        troller
                          npm WARN deprecated har-validator@5.1.5: this library is no longer supported
                          npm WARN deprecated request@2.88.2: request has been deprecated, see https://git        hub.com/request/request/issues/3142
                          npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older v        ersions may use Math.random() in certain circumstances, which is known to be pro        blematic.  See https://v8.dev/blog/math-random for details.
                          added 275 packages, and removed 2 packages in 1m
                          25 packages are looking for funding
                          sudo reboot
                          iob start
                          das komplette system ist tot, es startet nicht mehr seid
                          iob stop
                          sudo reboot
                          nun schaut es anders aus...
                          Would you like to reinstall version 3.26.4 of alexa2 now? [(y)es, (n)o]: y
                          Update alexa2 from @3.26.4 to @3.26.4
                          NPM version: 10.2.3
                          removed 58 packages, and changed 1 package in 6s
                          Update "system.adapter.alexa2.0"
                          upload [28] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.        png alexa.png image/png
                          upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_dot3.png icons/echo_dot3.png image/png
                          upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_dot4.png icons/echo_dot4.png image/png
                          upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_flex.png icons/echo_flex.png image/png
                          upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_plus2.png icons/echo_plus2.png image/png
                          upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_show.png icons/echo_show.png image/png
                          upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_show2.png icons/echo_show2.png image/png
                          upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_show5.png icons/echo_show5.png image/png
                          upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_studio.png icons/echo_studio.png image/png
                          upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_sub.png icons/echo_sub.png image/png
                          upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        firetab.png icons/firetab.png image/png
                          upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        firetv.png icons/firetv.png image/png
                          upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/m        icrophone.png icons/microphone.png image/png
                          upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/m        ultiroom.png icons/multiroom.png image/png
                          upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/r        aspi.png icons/raspi.png image/png
                          upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/r        everb.png icons/reverb.png image/png
                          upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/s        onos.png icons/sonos.png image/png
                          upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/s        pot.png icons/spot.png image/png
                          upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m        .html index_m.html text/html
                          upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/info.pn        g info.png image/png
                          upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/warning        .png warning.png image/png
                          upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/words.j        s words.js application/javascript
                          aber wie starte ich das ganze jetzt wider....????
                          MFG Schweizer
                          Glasfaser Homoran 2 Replies Last reply Reply Quote 0
                          • Glasfaser
                            dann zeige jetzt nochmal
                            iob diag
                              Homoran Global Moderator Administrators @Schweiz last edited by
                              zeig noch mal ein aktuelles iob diag
                                @homoran sagte in Jarvis Adapter lässt sich nicht Installieren:
                                iob diag
                                Skript v.2023-10-10
                                *** BASE SYSTEM ***
                                       Icon name: computer
                                    Architecture: arm64
                                Docker          : false
                                Kernel          : aarch64
                                Userland        : arm64
                                 21:45:09 up 9 min,  2 users,  load average: 2.33, 1.94, 1.07
                                CPU threads: 4
                                Current issues:
                                               Local time: Sat 2024-01-27 21:45:10 CET
                                           Universal time: Sat 2024-01-27 20:45:10 UTC
                                                 RTC time: n/a
                                              NTP service: active
                                          RTC in local TZ: no
                                john
                                /home/john
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:            4.0G        1.5G        1.0G        1.3M        1.5G        2.4G
                                Swap:           104M          0B        104M
                                Total:          4.1G        1.5G        1.2G
                                         3793 M total memory
                                         1476 M used memory
                                         1483 M active memory
                                         1141 M inactive memory
                                          996 M free memory
                                           41 M buffer memory
                                         1363 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                Raspberry only:
                                oom events: 0
                                *** FILESYSTEM ***
                                /dev/mmcblk0p2 ext4       59G  4.5G   51G   9% /
                                [Sat Jan 27 21:35:23 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:29:88:49 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=620a9d97-02 rootfstype=ext4 fsck.repair=yes rootwait
                                [Sat Jan 27 21:35:25 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                                [Sat Jan 27 21:35:27 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                /var:
                                1.3G    /var/
                                837M    /var/lib
                                Archived and active journals take up 101.1M in the file system.
                                323M    /opt/iobroker/iobroker-data/
                                40M     /opt/iobroker/iobroker-data/objects.jsonl
                                14M     /opt/iobroker/iobroker-data/states.jsonl
                                USB-Devices by-id:
                                /usr/bin/npm            10.2.3
                                /usr/bin/npx            10.2.3
                                nodejs:
                                  Version table:
                                     18.13.0+dfsg1-1 500
                                Errors in npm tree:
                                npm ERR! code ELSPROBLEMS
                                npm ERR! extraneous: iobroker.viessmannapi@2.4.0 /opt/iobroker/node_modules/iobroker.viessmannapi
                                npm ERR! extraneous: retry-axios@2.6.0 /opt/iobroker/node_modules/retry-axios
                                npm ERR! extraneous: qs@6.11.2 /opt/iobroker/node_modules/iobroker.viessmannapi/node_modules/qs
                                npm ERR! invalid: fsevents@ /opt/iobroker/node_modules/fsevents
                                npm ERR! A complete log of this run can be found in: /home/john/.npm/_logs/2024-01-27T20_45_21_968Z-debug-0.log
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                js-controller:  5.0.17
                                admin:          6.12.0
                                javascript:     7.1.6
                                Adapters from github:   1
                                Adapter State
                                + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                                + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                                  system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
                                + system.adapter.enigma2.0                : enigma2               : raspberrypi                              -  enabled
                                  system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
                                  system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
                                + system.adapter.heizoel.0                : heizoel               : raspberrypi                              -  enabled
                                + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
                                + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                                  system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                                  system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                                  system.adapter.iceroad.0                : iceroad               : raspberrypi                              -  enabled
                                + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                                  system.adapter.smartthings.0            : smartthings           : raspberrypi                              - disabled
                                + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                                  system.adapter.telegram-menu.0          : telegram-menu         : raspberrypi                              - disabled
                                + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
                                + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                                + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                                + system.adapter.viessmannapi.0           : viessmannapi          : raspberrypi                              -  enabled
                                + system.adapter.weather-warnings.0       : weather-warnings      : raspberrypi                              -  enabled
                                + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                + system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
                                  system.adapter.youtube.0                : youtube               : raspberrypi                              - disabled
                                + instance is alive
                                Active repo(s): stable
                                Used repository: stable
                                Adapter    "admin"        : 6.12.0   , installed 6.12.0
                                Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
                                Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                                Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
                                Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
                                Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                                Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
                                Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                                Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                                Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
                                Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                                Controller "js-controller": 5.0.17   , installed 5.0.17
                                Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
                                Adapter    "telegram"     : 3.0.1    , installed 3.0.1
                                Adapter    "telegram-menu": 1.5.1    , installed 1.5.1
                                Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                                Adapter    "viessmannapi" : 2.3.0    , installed 2.4.0
                                Adapter    "weather-warnings": 0.6.6 , installed 0.6.4  [Updatable]
                                Adapter    "web"          : 6.1.10   , installed 6.1.10
                                Adapter    "worx"         : 2.3.4    , installed 2.3.4
                                Adapter    "ws"           : 2.5.8    , installed 2.5.8
                                Adapter    "youtube"      : 4.4.0    , installed 4.4.0
                                Objects and States
                                Objects:        11787
                                States:         9567
                                Pending Updates: 10
                                tcp        0      0 192.168.2.113:2010      0.0.0.0:*               LISTEN      1001       28770      4393/io.hm-rpc.1
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16496      966/iobroker.js-con
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16017      966/iobroker.js-con
                                tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          14299      1058/dnsmasq
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15842      1012/sshd: /usr/sbi
                                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       25725      3881/io.web.0
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       26787      4256/io.admin.0
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          15853      1012/sshd: /usr/sbi
                                udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          14298      1058/dnsmasq
                                udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14295      1058/dnsmasq
                                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13253      909/dhclient
                                udp        0      0 0.0.0.0:55548           0.0.0.0:*                           104        15391      437/avahi-daemon: r
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        15389      437/avahi-daemon: r
                                udp6       0      0 :::53648                :::*                                104        15392      437/avahi-daemon: r
                                udp6       0      0 :::5353                 :::*                                104        15390      437/avahi-daemon: r
                                2024-01-27 21:45:39.402  - info: hm-rpc.1 (3986) Terminated (NO_ERROR): Without reason
                                2024-01-27 21:45:39.430  - info: hm-rpc.1 (3986) terminating
                                2024-01-27 21:45:39.471  - info: hm-rpc.1 (3986) terminating
                                2024-01-27 21:45:39.920  - info: admin.0 (4256) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                2024-01-27 21:45:40.017  - info: host.raspberrypi instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
                                2024-01-27 21:45:40.017  - info: host.raspberrypi Restart adapter system.adapter.hm-rpc.1 because enabled
                                2024-01-27 21:45:40.257  - info: admin.0 (4256) starting. Version 6.12.0 in /opt/iobroker/node_modules/iobroker.admin, node: v18.19.0, js-controller: 5.0.17
                                2024-01-27 21:45:40.316  - info: admin.0 (4256) requesting all objects
                                2024-01-27 21:45:43.816  - info: admin.0 (4256) received all objects
                                2024-01-27 21:45:44.637  - info: admin.0 (4256) socket.io server listening on port 8081
                                2024-01-27 21:45:44.644  - info: admin.0 (4256) http server listening on port 8081
                                2024-01-27 21:45:44.645  - info: admin.0 (4256) Use link "http://127.0.0.1:8081" to configure.
                                2024-01-27 21:46:02.392  - error: hm-rpc.0 (4197) Init not possible, going to stop: connect EHOSTUNREACH 192.168.2.122:2001
                                2024-01-27 21:46:02.414  - info: hm-rpc.0 (4197) xmlrpc -> 192.168.2.122:2001/ init ["http://192.168.2.113:2001",""]
                                2024-01-27 21:46:03.422  - info: hm-rpc.0 (4197) terminating
                                2024-01-27 21:46:03.425  - info: hm-rpc.0 (4197) Terminated (NO_ERROR): Without reason
                                2024-01-27 21:46:04.037  - info: host.raspberrypi instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
                                2024-01-27 21:46:04.038  - info: host.raspberrypi Restart adapter system.adapter.hm-rpc.0 because enabled
                                2024-01-27 21:46:08.568  - error: hm-rega.0 (2608) CCU 192.168.2.122 unreachable
                                2024-01-27 21:46:10.169  - info: host.raspberrypi instance system.adapter.hm-rpc.1 started with pid 4393
                                2024-01-27 21:46:12.464  - info: hm-rpc.1 (4393) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                                2024-01-27 21:46:12.735  - info: hm-rpc.1 (4393) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.17
                                2024-01-27 21:46:13.081  - info: hm-rpc.1 (4393) xmlrpc server is trying to listen on 192.168.2.113:2010
                                2024-01-27 21:46:13.082  - info: hm-rpc.1 (4393) xmlrpc client is trying to connect to 192.168.2.122:2010/ with ["http://192.168.2.113:2010","raspberrypi:hm-rpc.1:ff6dfd3a7f0f6cc5fcbfb9b363ac5e5a"]
                                2024-01-27 21:46:16.186  - error: hm-rpc.1 (4393) Init not possible, going to stop: connect EHOSTUNREACH 192.168.2.122:2010
                                wenn ich iob fix mache kommt
                                john@raspberrypi:/opt/iobroker $ iob fix
                                library: loaded
                                Library version=2024-01-04
                                ioBroker or some processes are still running:
                                 io.alexa2.0
                                 io.telegram.0
                                 io.javascript.0
                                 io.discovery.0
                                 io.backitup.0
                                 io.enigma2.0
                                 io.heizoel.0
                                 io.tankerkoenig.0
                                 io.worx.0
                                Please stop them first and try again!
                                klar, irgendwas läuft, nur nicht ccu und nicht iob
                                MFG Schweizer
                                Homoran Glasfaser 4 Replies Last reply Reply Quote 0
                                  Homoran Global Moderator Administrators @Schweiz last edited by Homoran
                                  iob läuft, auch der admin.
                                  zumindest war das als diag lief
                                    nur nicht ccu
                                    sudo pivccu-info
                                    • Glasfaser
                                      Logo ... steht doch da
                                      iob stop
                                      zuvor
                                        ich hatte iob fix nur ausgeführt um zu sehen ob es mit iob start gestartet ist, aber ich habe keinen zugriff auf die oberfläche bekommen.
                                        Nun nochmal sudo reboot gemacht und nun geht es...
                                        CCU läuft auch, aber...
                                        das ist echt strange...
                                        über die console ging es mit dem alexa Adapter... zu aktuallsieren
                                        über IOB geht es nicht mit dem wetter Adapter...
                                        und über die console auch nicht ;(
                                        john@raspberrypi:/opt/iobroker $ john@raspberrypi:/opt/iobroker $ iob upgrade weather-warnings@0.6.6 --debug
                                        This upgrade of "weather-warnings" will introduce the following changes:
                                        -> 0.6.6:
                                        fullday(ZAMG only): If time span is 24h +/- 5 minutes and the start hour is between 0-3, day of the week from start time, otherwise blank.
                                        -> 0.6.5:
                                        Added: ZAMG full day token
                                        fixed: Send emails asynchron
                                        fixed: dont ignore uwz activate setting
                                        update dp-objects on every start.
                                        Would you like to upgrade weather-warnings from @0.6.4 to @0.6.6 now? [(y)es, (n)o]: y
                                        Update weather-warnings from @0.6.4 to @0.6.6
                                        NPM version: 10.2.3
                                        Installing iobroker.weather-warnings@0.6.6... (System call)
                                        npm ERR! code ETIMEDOUT
                                        npm ERR! syscall connect
                                        npm ERR! errno ETIMEDOUT
                                        npm ERR! network request to https://registry.npmjs.org/iobroker.weather-warnings/-/iobroker.weather-warnings-0.6.6.tgz failed, reason: connect ETIMEDOUT 2606:4700::6810:223:443
                                        npm ERR! network This is a problem related to network connectivity.
                                        npm ERR! network In most cases you are behind a proxy or have bad network settings.
                                        npm ERR! network
                                        npm ERR! network If you are behind a proxy, please make sure that the
                                        npm ERR! network 'proxy' config is set properly.  See: 'npm help config'
                                        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-27T21_09_40_353Z-debug-0.log
                                        npm ERR! network
                                        host.raspberrypi Cannot install iobroker.weather-warnings@0.6.6: 1
                                        und nach wie vor kein anderer Adapter...
                                        ich verzweifle bald...
                                        MFG Schweizer
                                          da hatten wir ja auch das Problem vorher behoben.
                                          dann musst du da auch nochmal mit --debug arbeiten
                                            doch wieder ipv6 Probleme?
                                            4120
