    4. Jarvis Adapter lässt sich nicht Installieren
      Schweiz @Glasfaser last edited by
      @glasfaser sagte in Jarvis Adapter lässt sich nicht Installieren:
      iob diag
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.1.0-rpi7-rpi-v8
          Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       21:28:36 up 5 min,  2 users,  load average: 0.13, 0.65, 0.40
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Sat 2024-01-27 21:28:36 CET
                 Universal time: Sat 2024-01-27 20:28:36 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      john
      /home/john
      john adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            4.0G        439M        3.2G        1.3M        405M        3.5G
      Swap:           104M          0B        104M
      Total:          4.1G        439M        3.3G
               3793 M total memory
                419 M used memory
                446 M active memory
                180 M inactive memory
               3061 M free memory
                 39 M buffer memory
                346 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     380M  1.2M  379M   1% /run
      /dev/mmcblk0p2 ext4       59G  3.8G   52G   7% /
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      /dev/mmcblk0p1 vfat      510M   62M  449M  13% /boot/firmware
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Sat Jan 27 21:22:48 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:29:88:49 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=620a9d97-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Sat Jan 27 21:22:50 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sat Jan 27 21:22:52 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET           SOURCE         FSTYPE OPTIONS
      /                /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.2G    /var/
      837M    /var/lib
      662M    /var/lib/piVCCU3
      604M    /var/lib/piVCCU3/rootfs
      279M    /var/lib/piVCCU3/rootfs/opt
      Archived and active journals take up 85.1M in the file system.
      /opt/iobroker/backups:
      34M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      319M    /opt/iobroker/iobroker-data/
      185M    /opt/iobroker/iobroker-data/files
      86M     /opt/iobroker/iobroker-data/backup-objects
      67M     /opt/iobroker/iobroker-data/files/javascript.admin
      49M     /opt/iobroker/iobroker-data/files/telegram-menu.admin
      38M     /opt/iobroker/iobroker-data/objects.jsonl
      36M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      13M     /opt/iobroker/iobroker-data/states.jsonl
      13M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
           18.19.0+dfsg-6~deb12u1 500
       *** 18.19.0-1nodesource1 1001
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1 500
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      node:internal/modules/cjs/loader:1137
        throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
          at Module._load (node:internal/modules/cjs/loader:975:27)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
          at node:internal/main/run_main_module:28:49 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      Node.js v18.19.0
      Core adapters versions
        throw err;
        requireStack: []
      Node.js v18.19.0
      js-controller:
        throw err;
        requireStack: []
      Node.js v18.19.0
      admin:
        throw err;
        requireStack: []
      Node.js v18.19.0
      javascript:
      Adapters from github:   0
      Adapter State
        throw err;
        requireStack: []
      Node.js v18.19.0
        throw err;
        requireStack: []
      Node.js v18.19.0
      ioBroker-Repositories
        throw err;
        requireStack: []
      Node.js v18.19.0
      Installed ioBroker-Instances
        throw err;
        requireStack: []
      Node.js v18.19.0
      Objects and States
      Objects:        0
      States:         0
      Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
      Reading package lists...
      Pending Updates: 10
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          16812      1009/sshd: /usr/sbi
      tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          16839      1053/dnsmasq
      tcp6       0      0 :::22                   :::*                    LISTEN      0          16814      1009/sshd: /usr/sbi
      udp        0      0 0.0.0.0:56245           0.0.0.0:*                           104        15562      507/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        15560      507/avahi-daemon: r
      udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          16838      1053/dnsmasq
      udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          16835      1053/dnsmasq
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12872      906/dhclient
      udp6       0      0 :::46068                :::*                                104        15563      507/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        15561      507/avahi-daemon: r
      - /opt/iobroker/node_modules/@iobroker/adapter-core/build/controllerTools.js
      - /opt/iobroker/node_modules/@iobroker/adapter-core/build/index.js
      - /opt/iobroker/node_modules/iobroker.alexa2/main.js
          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
          at Function.Module._load (node:internal/modules/cjs/loader:975:27)
          at Module.require (node:internal/modules/cjs/loader:1225:19)
          at require (node:internal/modules/helpers:177:18)
          at /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1800:82
          at AdapterClass._setObject (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:1800:34)
      2024-01-27 21:24:08.726  - error: alexa2.0 (1919) Exception-Code: MODULE_NOT_FOUND: Cannot find module './defaultObjs.js'
      Require stack:
      - /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js
      - /opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/index.js
      - /opt/iobroker/node_modules/@iobroker/adapter-core/build/utils.js
      2024-01-27 21:24:09.032  - info: hm-rpc.1 (2113) terminating
      2024-01-27 21:24:09.035  - info: hm-rpc.1 (2113) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-01-27 21:24:09.065  - info: hm-rpc.0 (1981) terminating
      2024-01-27 21:24:09.069  - info: hm-rpc.0 (1981) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-01-27 21:24:09.083  - error: iceroad.0 (2213) Objects database error: read ECONNRESET
      2024-01-27 21:24:10.692  - info: iceroad.0 (2213) terminating with timeout
      2024-01-27 21:24:10.694  - info: iceroad.0 (2213) Terminated (NO_ERROR): Without reason
      2024-01-27 21:24:14.100  - warn: iceroad.0 (2213) get state error: Connection is closed.
      MFG Schweizer
      • Glasfaser
        Glasfaser last edited by Glasfaser
        @schweiz
        cd /opt/iobroker
        npm cache clean --force
        sudo -H -u iobroker npm install iobroker.js-controller
        S Glasfaser 2 Replies Last reply Reply Quote 0
          john@raspberrypi:~ $ cd /opt/iobroker
          john@raspberrypi:/opt/iobroker $ npm cache clean --force
          npm WARN using --force Recommended protections disabled.
          john@raspberrypi:/opt/iobroker $ iob stop
          john@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-con        troller
          npm WARN deprecated har-validator@5.1.5: this library is no longer supported
          npm WARN deprecated request@2.88.2: request has been deprecated, see https://git        hub.com/request/request/issues/3142
          npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older v        ersions may use Math.random() in certain circumstances, which is known to be pro        blematic.  See https://v8.dev/blog/math-random for details.
          added 275 packages, and removed 2 packages in 1m
          25 packages are looking for funding
            run `npm fund` for details
          sudo reboot
          iob start
          das komplette system ist tot, es startet nicht mehr seid
          iob stop
          rm /opt/iobroker/package*
          sudo reboot
          nun schaut es anders aus...
          iob upgrade alexa2@3.26.4 --debug
          Would you like to reinstall version 3.26.4 of alexa2 now? [(y)es, (n)o]: y
          Update alexa2 from @3.26.4 to @3.26.4
          NPM version: 10.2.3
          Installing iobroker.alexa2@3.26.4... (System call)
          removed 58 packages, and changed 1 package in 6s
          Update "system.adapter.alexa2.0"
          upload [28] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.        png alexa.png image/png
          upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_dot3.png icons/echo_dot3.png image/png
          upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_dot4.png icons/echo_dot4.png image/png
          upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_flex.png icons/echo_flex.png image/png
          upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_plus2.png icons/echo_plus2.png image/png
          upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_show.png icons/echo_show.png image/png
          upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_show2.png icons/echo_show2.png image/png
          upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_show5.png icons/echo_show5.png image/png
          upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_studio.png icons/echo_studio.png image/png
          upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        echo_sub.png icons/echo_sub.png image/png
          upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        firetab.png icons/firetab.png image/png
          upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/        firetv.png icons/firetv.png image/png
          upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/m        icrophone.png icons/microphone.png image/png
          upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/m        ultiroom.png icons/multiroom.png image/png
          upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/r        aspi.png icons/raspi.png image/png
          upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/r        everb.png icons/reverb.png image/png
          upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/s        onos.png icons/sonos.png image/png
          upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/s        pot.png icons/spot.png image/png
          upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m        .html index_m.html text/html
          upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/info.pn        g info.png image/png
          upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/warning        .png warning.png image/png
          upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/words.j        s words.js application/javascript
          aber wie starte ich das ganze jetzt wider....????
          MFG Schweizer
          Glasfaser Homoran 2 Replies Last reply Reply Quote 0
          • Glasfaser
            Glasfaser @Schweiz last edited by
            @schweiz sagte in Jarvis Adapter lässt sich nicht Installieren:
            dann zeige jetzt nochmal
            iob diag
              Homoran Global Moderator Administrators @Schweiz last edited by
              zeig noch mal ein aktuelles iob diag
                Schweiz @Homoran last edited by
                @homoran sagte in Jarvis Adapter lässt sich nicht Installieren:
                iob diag
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : arm64
                 21:45:09 up 9 min,  2 users,  load average: 2.33, 1.94, 1.07
                CPU threads: 4
                Current issues:
                               Local time: Sat 2024-01-27 21:45:10 CET
                           Universal time: Sat 2024-01-27 20:45:10 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                john
                /home/john
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            4.0G        1.5G        1.0G        1.3M        1.5G        2.4G
                Swap:           104M          0B        104M
                Total:          4.1G        1.5G        1.2G
                         3793 M total memory
                         1476 M used memory
                         1483 M active memory
                         1141 M inactive memory
                          996 M free memory
                           41 M buffer memory
                         1363 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                /dev/mmcblk0p2 ext4       59G  4.5G   51G   9% /
                [Sat Jan 27 21:35:23 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:29:88:49 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=620a9d97-02 rootfstype=ext4 fsck.repair=yes rootwait
                [Sat Jan 27 21:35:25 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                [Sat Jan 27 21:35:27 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                /var:
                1.3G    /var/
                837M    /var/lib
                Archived and active journals take up 101.1M in the file system.
                323M    /opt/iobroker/iobroker-data/
                40M     /opt/iobroker/iobroker-data/objects.jsonl
                14M     /opt/iobroker/iobroker-data/states.jsonl
                USB-Devices by-id:
                /usr/bin/npm            10.2.3
                /usr/bin/npx            10.2.3
                nodejs:
                  Version table:
                     18.13.0+dfsg1-1 500
                Errors in npm tree:
                npm ERR! code ELSPROBLEMS
                npm ERR! extraneous: iobroker.viessmannapi@2.4.0 /opt/iobroker/node_modules/iobroker.viessmannapi
                npm ERR! extraneous: retry-axios@2.6.0 /opt/iobroker/node_modules/retry-axios
                npm ERR! extraneous: qs@6.11.2 /opt/iobroker/node_modules/iobroker.viessmannapi/node_modules/qs
                npm ERR! invalid: fsevents@ /opt/iobroker/node_modules/fsevents
                npm ERR! A complete log of this run can be found in: /home/john/.npm/_logs/2024-01-27T20_45_21_968Z-debug-0.log
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                js-controller:  5.0.17
                admin:          6.12.0
                javascript:     7.1.6
                Adapters from github:   1
                Adapter State
                + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                  system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
                + system.adapter.enigma2.0                : enigma2               : raspberrypi                              -  enabled
                  system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
                  system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
                + system.adapter.heizoel.0                : heizoel               : raspberrypi                              -  enabled
                + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
                + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                  system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
                  system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                  system.adapter.iceroad.0                : iceroad               : raspberrypi                              -  enabled
                + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                  system.adapter.smartthings.0            : smartthings           : raspberrypi                              - disabled
                + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                  system.adapter.telegram-menu.0          : telegram-menu         : raspberrypi                              - disabled
                + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
                + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                + system.adapter.viessmannapi.0           : viessmannapi          : raspberrypi                              -  enabled
                + system.adapter.weather-warnings.0       : weather-warnings      : raspberrypi                              -  enabled
                + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                + system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
                  system.adapter.youtube.0                : youtube               : raspberrypi                              - disabled
                + instance is alive
                Active repo(s): stable
                Used repository: stable
                Adapter    "admin"        : 6.12.0   , installed 6.12.0
                Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
                Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
                Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
                Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
                Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
                Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
                Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
                Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
                Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                Controller "js-controller": 5.0.17   , installed 5.0.17
                Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
                Adapter    "telegram"     : 3.0.1    , installed 3.0.1
                Adapter    "telegram-menu": 1.5.1    , installed 1.5.1
                Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                Adapter    "viessmannapi" : 2.3.0    , installed 2.4.0
                Adapter    "weather-warnings": 0.6.6 , installed 0.6.4  [Updatable]
                Adapter    "web"          : 6.1.10   , installed 6.1.10
                Adapter    "worx"         : 2.3.4    , installed 2.3.4
                Adapter    "ws"           : 2.5.8    , installed 2.5.8
                Adapter    "youtube"      : 4.4.0    , installed 4.4.0
                Objects and States
                Objects:        11787
                States:         9567
                Pending Updates: 10
                tcp        0      0 192.168.2.113:2010      0.0.0.0:*               LISTEN      1001       28770      4393/io.hm-rpc.1
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16496      966/iobroker.js-con
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16017      966/iobroker.js-con
                tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          14299      1058/dnsmasq
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15842      1012/sshd: /usr/sbi
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       25725      3881/io.web.0
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       26787      4256/io.admin.0
                tcp6       0      0 :::22                   :::*                    LISTEN      0          15853      1012/sshd: /usr/sbi
                udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          14298      1058/dnsmasq
                udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14295      1058/dnsmasq
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13253      909/dhclient
                udp        0      0 0.0.0.0:55548           0.0.0.0:*                           104        15391      437/avahi-daemon: r
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        15389      437/avahi-daemon: r
                udp6       0      0 :::53648                :::*                                104        15392      437/avahi-daemon: r
                udp6       0      0 :::5353                 :::*                                104        15390      437/avahi-daemon: r
                2024-01-27 21:45:39.402  - info: hm-rpc.1 (3986) Terminated (NO_ERROR): Without reason
                2024-01-27 21:45:39.430  - info: hm-rpc.1 (3986) terminating
                2024-01-27 21:45:39.471  - info: hm-rpc.1 (3986) terminating
                2024-01-27 21:45:39.920  - info: admin.0 (4256) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                2024-01-27 21:45:40.017  - info: host.raspberrypi instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
                2024-01-27 21:45:40.017  - info: host.raspberrypi Restart adapter system.adapter.hm-rpc.1 because enabled
                2024-01-27 21:45:40.257  - info: admin.0 (4256) starting. Version 6.12.0 in /opt/iobroker/node_modules/iobroker.admin, node: v18.19.0, js-controller: 5.0.17
                2024-01-27 21:45:40.316  - info: admin.0 (4256) requesting all objects
                2024-01-27 21:45:43.816  - info: admin.0 (4256) received all objects
                2024-01-27 21:45:44.637  - info: admin.0 (4256) socket.io server listening on port 8081
                2024-01-27 21:45:44.644  - info: admin.0 (4256) http server listening on port 8081
                2024-01-27 21:45:44.645  - info: admin.0 (4256) Use link "http://127.0.0.1:8081" to configure.
                2024-01-27 21:46:02.392  - error: hm-rpc.0 (4197) Init not possible, going to stop: connect EHOSTUNREACH 192.168.2.122:2001
                2024-01-27 21:46:02.414  - info: hm-rpc.0 (4197) xmlrpc -> 192.168.2.122:2001/ init ["http://192.168.2.113:2001",""]
                2024-01-27 21:46:03.422  - info: hm-rpc.0 (4197) terminating
                2024-01-27 21:46:03.425  - info: hm-rpc.0 (4197) Terminated (NO_ERROR): Without reason
                2024-01-27 21:46:04.037  - info: host.raspberrypi instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
                2024-01-27 21:46:04.038  - info: host.raspberrypi Restart adapter system.adapter.hm-rpc.0 because enabled
                2024-01-27 21:46:08.568  - error: hm-rega.0 (2608) CCU 192.168.2.122 unreachable
                2024-01-27 21:46:10.169  - info: host.raspberrypi instance system.adapter.hm-rpc.1 started with pid 4393
                2024-01-27 21:46:12.464  - info: hm-rpc.1 (4393) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                2024-01-27 21:46:12.735  - info: hm-rpc.1 (4393) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.17
                2024-01-27 21:46:13.081  - info: hm-rpc.1 (4393) xmlrpc server is trying to listen on 192.168.2.113:2010
                2024-01-27 21:46:13.082  - info: hm-rpc.1 (4393) xmlrpc client is trying to connect to 192.168.2.122:2010/ with ["http://192.168.2.113:2010","raspberrypi:hm-rpc.1:ff6dfd3a7f0f6cc5fcbfb9b363ac5e5a"]
                2024-01-27 21:46:16.186  - error: hm-rpc.1 (4393) Init not possible, going to stop: connect EHOSTUNREACH 192.168.2.122:2010
                wenn ich iob fix mache kommt
                john@raspberrypi:/opt/iobroker $ iob fix
                library: loaded
                Library version=2024-01-04
                ioBroker or some processes are still running:
                 io.alexa2.0
                 io.telegram.0
                 io.javascript.0
                 io.discovery.0
                 io.backitup.0
                 io.enigma2.0
                 io.heizoel.0
                 io.tankerkoenig.0
                 io.worx.0
                Please stop them first and try again!
                klar, irgendwas läuft, nur nicht ccu und nicht iob
                MFG Schweizer
                Homoran Glasfaser 4 Replies Last reply Reply Quote 0
                  Homoran Global Moderator Administrators @Schweiz last edited by Homoran
                  iob läuft, auch der admin.
                  zumindest war das als diag lief
                    nur nicht ccu
                    sudo pivccu-info
                    • Glasfaser
                      Logo ... steht doch da
                      iob stop
                      zuvor
                        ich hatte iob fix nur ausgeführt um zu sehen ob es mit iob start gestartet ist, aber ich habe keinen zugriff auf die oberfläche bekommen.
                        Nun nochmal sudo reboot gemacht und nun geht es...
                        CCU läuft auch, aber...
                        das ist echt strange...
                        über die console ging es mit dem alexa Adapter... zu aktuallsieren
                        über IOB geht es nicht mit dem wetter Adapter...
                        und über die console auch nicht ;(
                        john@raspberrypi:/opt/iobroker $ john@raspberrypi:/opt/iobroker $ iob upgrade weather-warnings@0.6.6 --debug
                        This upgrade of "weather-warnings" will introduce the following changes:
                        -> 0.6.6:
                        fullday(ZAMG only): If time span is 24h +/- 5 minutes and the start hour is between 0-3, day of the week from start time, otherwise blank.
                        -> 0.6.5:
                        Added: ZAMG full day token
                        fixed: Send emails asynchron
                        fixed: dont ignore uwz activate setting
                        update dp-objects on every start.
                        Would you like to upgrade weather-warnings from @0.6.4 to @0.6.6 now? [(y)es, (n)o]: y
                        Update weather-warnings from @0.6.4 to @0.6.6
                        NPM version: 10.2.3
                        Installing iobroker.weather-warnings@0.6.6... (System call)
                        npm ERR! code ETIMEDOUT
                        npm ERR! syscall connect
                        npm ERR! errno ETIMEDOUT
                        npm ERR! network request to https://registry.npmjs.org/iobroker.weather-warnings/-/iobroker.weather-warnings-0.6.6.tgz failed, reason: connect ETIMEDOUT 2606:4700::6810:223:443
                        npm ERR! network This is a problem related to network connectivity.
                        npm ERR! network In most cases you are behind a proxy or have bad network settings.
                        npm ERR! network
                        npm ERR! network If you are behind a proxy, please make sure that the
                        npm ERR! network 'proxy' config is set properly.  See: 'npm help config'
                        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-27T21_09_40_353Z-debug-0.log
                        npm ERR! network
                        host.raspberrypi Cannot install iobroker.weather-warnings@0.6.6: 1
                        und nach wie vor kein anderer Adapter...
                        ich verzweifle bald...
                        MFG Schweizer
                          da hatten wir ja auch das Problem vorher behoben.
                          dann musst du da auch nochmal mit --debug arbeiten
                            doch wieder ipv6 Probleme?
                              nein, am gleichen tag als ich die anderen adapter installiert habe wollte ich auch jarvis installieren, weil das so an sich das letzte war,... das die anderen auch nicht gehen war mir nicht bewusst... auch hat der Internet Test ja gezeigt das IPV6 voll da ist...
                              hab ich doch gemacht mit Debug, siehe gerade eben... 😉
                              MFG Schweizer
                                aber nicht den debug.log der da genannt wird gezeigt
                                • Glasfaser
                                  curl -L -o iobroker.weather-warnings-0.6.6.tgz https://registry.npmjs.org/iobroker.weather-warnings/-/iobroker.weather-warnings-0.6.6.tgz
                                  Ausgabe zeigen
                                    auch vom iob server aus getestet?
                                    kopier dir mal den Link in meinem Quote in einen Browser.
                                    ich kann das tar.gz runterladen, und du?
                                      curl -L -o iobroker.weather-warnings-0.6.6.tgz https://registry.npmjs.org/iobroker.weather-warnings/-/iobroker.weather-warnings-0.6.6.tgzgz
                                        % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
        Dload  Upload   Total   Spent    Left  Speed
                                      100  849k  100  849k    0     0   990k      0 --:--:-- --:--:-- --:--:--  989k
                                      • Glasfaser
                                        Zeige uns den Inhalt davon
                                        • Glasfaser
                                          Was ist das .... hast du ein DNS Server eingerichtet !?
                                            kann ich herunter laden...
                                            ein dns habe ich nicht eingerichtet... wüsste nicht wo ich das finden soll im PI
                                            in der Fritz
                                            FRITZ!Box 7272 (UI)
                                            Schweiz, FRITZ!OS 06.89, FRITZ!OS ist aktuell
                                            FRITZ!Box-Anmeldung
                                            Mit Benutzername und Kennwort gesichert
                                            LAN
                                            LAN 1
                                            LAN 2
                                            LAN 3
                                            LAN 4
                                            LAN 1, LAN 2 im Power Mode, LAN 3, LAN 4 im Green Mode
                                            WLAN
                                            Funknetzname: Schweiz
                                            aktuell 8 WLAN-Geräte verbunden, gesichert
                                            DECT
                                            aus
                                            USB-Geräte
                                            kein Gerät angeschlossen
                                            Internetverbindung
                                            IPv4: Eine bestehende Internetverbindung im Netzwerk wird mitbenutzt. IPv4-Adresse: 192.168.2.105
                                            IPv6: Eine bestehende Internetverbindung im Netzwerk wird mitbenutzt. IPv6-Adresse: 2003:f9:e724:fa91:3631:c4ff:fee4:338b
                                            Rufnummern
                                            Keine Rufnummern aktiv. Die Funktion der Festnetzrufnummer lässt sich nicht ermitteln.
                                            Heimnetz
                                            93 Geräte im Heimnetz, 0 davon online
                                            WLAN-Umgebung
                                            1 WLAN-Netz auf demselben Kanal aktiv
                                            keine WLAN-Netze mit demselben Namen
                                            PI ist auf LAN2
                                            -> 0.6.6:
                                            -> 0.6.5:
                                            NPM version: 10.2.3
                                            npm ERR! network request to https://registry.npmjs.org/iobroker.weather-warnings/-/iobroker.weather-warnings-0.6.6.tgz failed, reason: connect ETIMEDOUT 2606:4700::6810:1a22:443
                                            npm ERR! network
                                            npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-27T21_46_38_282Z-debug-0.log
                                            npm ERR! network
                                            john@raspberrypi:~ $ nano /home/iobroker/.npm/_logs/2024-01-27T21_46_38_282Z-debug-0.log
                                              GNU nano 7.2                                                        /home/iobroker/.npm/_logs/2024-01-27T21_46_38_282Z-debug-0.log
                                            0 verbose cli /usr/bin/node /usr/bin/npm
                                            1 info using npm@10.2.3
                                            2 info using node@v18.19.0
                                            3 timing npm:load:whichnode Completed in 4ms
                                            4 timing config:load:defaults Completed in 6ms
                                            5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 2ms
                                            6 timing config:load:builtin Completed in 4ms
                                            7 timing config:load:cli Completed in 12ms
                                            8 timing config:load:env Completed in 0ms
                                            9 timing config:load:file:/opt/iobroker/.npmrc Completed in 6ms
                                            10 timing config:load:project Completed in 17ms
                                            11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
                                            12 timing config:load:user Completed in 1ms
                                            13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
                                            14 timing config:load:global Completed in 0ms
                                            15 timing config:load:setEnvs Completed in 3ms
                                            16 timing config:load Completed in 48ms
                                            17 timing npm:load:configload Completed in 49ms
                                            18 timing config:load:flatten Completed in 9ms
                                            19 timing npm:load:mkdirpcache Completed in 1ms
                                            20 timing npm:load:mkdirplogs Completed in 1ms
                                            21 verbose title npm install iobroker.weather-warnings@0.6.6
                                            22 verbose argv "install" "--save-exact" "iobroker.weather-warnings@0.6.6"
                                            23 timing npm:load:setTitle Completed in 4ms
                                            24 timing npm:load:display Completed in 2ms
                                            25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2024-01-27T21_46_38_282Z-
                                            26 verbose logfile /home/iobroker/.npm/_logs/2024-01-27T21_46_38_282Z-debug-0.log
                                            27 timing npm:load:logFile Completed in 30ms
                                            28 timing npm:load:timers Completed in 0ms
                                            29 timing npm:load:configScope Completed in 0ms
                                            30 timing npm:load Completed in 146ms
                                            31 timing arborist:ctor Completed in 3ms
                                            32 silly logfile start cleaning logs, removing 2 files
                                            33 silly logfile done cleaning log files
                                            34 timing idealTree:init Completed in 2377ms
                                            35 timing idealTree:userRequests Completed in 5ms
                                            36 silly idealTree buildDeps
                                            37 silly fetch manifest iobroker.weather-warnings@0.6.6
                                            38 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
                                            39 http fetch GET 200 https://registry.npmjs.org/iobroker.weather-warnings 460159ms (cache stale)
                                            40 silly placeDep ROOT iobroker.weather-warnings@0.6.6 REPLACE for: iobroker.core@1.0.0 want: 0.6.6
                                            41 timing idealTree:#root Completed in 460231ms
                                            42 timing idealTree:node_modules/iobroker.weather-warnings Completed in 0ms
                                            43 timing idealTree:buildDeps Completed in 460235ms
                                            44 timing idealTree:fixDepFlags Completed in 62ms
                                            45 timing idealTree Completed in 462726ms
                                            46 timing reify:loadTrees Completed in 462730ms
                                            47 timing reify:diffTrees Completed in 74ms
                                            MFG Schweizer
                                            4117
