    4. Jarvis Adapter lässt sich nicht Installieren
      Schweiz @Homoran last edited by
      @homoran sagte in Jarvis Adapter lässt sich nicht Installieren:
      iob diag
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.1.0-rpi7-rpi-v8
          Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       21:45:09 up 9 min,  2 users,  load average: 2.33, 1.94, 1.07
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Sat 2024-01-27 21:45:10 CET
                 Universal time: Sat 2024-01-27 20:45:10 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      john
      /home/john
      john adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            4.0G        1.5G        1.0G        1.3M        1.5G        2.4G
      Swap:           104M          0B        104M
      Total:          4.1G        1.5G        1.2G
               3793 M total memory
               1476 M used memory
               1483 M active memory
               1141 M inactive memory
                996 M free memory
                 41 M buffer memory
               1363 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     380M  1.2M  379M   1% /run
      /dev/mmcblk0p2 ext4       59G  4.5G   51G   9% /
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      /dev/mmcblk0p1 vfat      510M   62M  449M  13% /boot/firmware
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Sat Jan 27 21:35:23 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:29:88:49 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=620a9d97-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Sat Jan 27 21:35:25 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sat Jan 27 21:35:27 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET           SOURCE         FSTYPE OPTIONS
      /                /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.3G    /var/
      837M    /var/lib
      662M    /var/lib/piVCCU3
      604M    /var/lib/piVCCU3/rootfs
      279M    /var/lib/piVCCU3/rootfs/opt
      Archived and active journals take up 101.1M in the file system.
      /opt/iobroker/backups:
      34M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      323M    /opt/iobroker/iobroker-data/
      185M    /opt/iobroker/iobroker-data/files
      86M     /opt/iobroker/iobroker-data/backup-objects
      67M     /opt/iobroker/iobroker-data/files/javascript.admin
      49M     /opt/iobroker/iobroker-data/files/telegram-menu.admin
      40M     /opt/iobroker/iobroker-data/objects.jsonl
      36M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      14M     /opt/iobroker/iobroker-data/states.jsonl
      13M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
           18.19.0+dfsg-6~deb12u1 500
       *** 18.19.0-1nodesource1 1001
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1 500
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree:
      npm ERR! code ELSPROBLEMS
      npm ERR! extraneous: iobroker.viessmannapi@2.4.0 /opt/iobroker/node_modules/iobroker.viessmannapi
      npm ERR! extraneous: retry-axios@2.6.0 /opt/iobroker/node_modules/retry-axios
      npm ERR! extraneous: qs@6.11.2 /opt/iobroker/node_modules/iobroker.viessmannapi/node_modules/qs
      npm ERR! invalid: fsevents@ /opt/iobroker/node_modules/fsevents
      npm ERR! A complete log of this run can be found in: /home/john/.npm/_logs/2024-01-27T20_45_21_968Z-debug-0.log
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller:  5.0.17
      admin:          6.12.0
      javascript:     7.1.6
      Adapters from github:   1
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
      + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
        system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
      + system.adapter.enigma2.0                : enigma2               : raspberrypi                              -  enabled
        system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
        system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
      + system.adapter.heizoel.0                : heizoel               : raspberrypi                              -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
        system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
        system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
        system.adapter.iceroad.0                : iceroad               : raspberrypi                              -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
        system.adapter.smartthings.0            : smartthings           : raspberrypi                              - disabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
        system.adapter.telegram-menu.0          : telegram-menu         : raspberrypi                              - disabled
      + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
      + system.adapter.viessmannapi.0           : viessmannapi          : raspberrypi                              -  enabled
      + system.adapter.weather-warnings.0       : weather-warnings      : raspberrypi                              -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.worx.0                   : worx                  : raspberrypi                              -  enabled
        system.adapter.youtube.0                : youtube               : raspberrypi                              - disabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 6.12.0   , installed 6.12.0
      Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
      Adapter    "enigma2"      : 2.0.5    , installed 2.0.5
      Adapter    "fb-checkpresence": 1.2.2 , installed 1.2.2
      Adapter    "feiertage"    : 1.1.4    , installed 1.1.4
      Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
      Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
      Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
      Adapter    "iceroad"      : 1.2.1    , installed 1.2.1
      Adapter    "javascript"   : 7.1.6    , installed 7.1.6
      Controller "js-controller": 5.0.17   , installed 5.0.17
      Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
      Adapter    "telegram"     : 3.0.1    , installed 3.0.1
      Adapter    "telegram-menu": 1.5.1    , installed 1.5.1
      Adapter    "trashschedule": 2.3.0    , installed 2.3.0
      Adapter    "viessmannapi" : 2.3.0    , installed 2.4.0
      Adapter    "weather-warnings": 0.6.6 , installed 0.6.4  [Updatable]
      Adapter    "web"          : 6.1.10   , installed 6.1.10
      Adapter    "worx"         : 2.3.4    , installed 2.3.4
      Adapter    "ws"           : 2.5.8    , installed 2.5.8
      Adapter    "youtube"      : 4.4.0    , installed 4.4.0
      Objects and States
      Objects:        11787
      States:         9567
      Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
      Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
      Reading package lists...
      Pending Updates: 10
      *** Listening Ports ***
      tcp        0      0 192.168.2.113:2010      0.0.0.0:*               LISTEN      1001       28770      4393/io.hm-rpc.1
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16496      966/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16017      966/iobroker.js-con
      tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          14299      1058/dnsmasq
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15842      1012/sshd: /usr/sbi
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       25725      3881/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       26787      4256/io.admin.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15853      1012/sshd: /usr/sbi
      udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          14298      1058/dnsmasq
      udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14295      1058/dnsmasq
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13253      909/dhclient
      udp        0      0 0.0.0.0:55548           0.0.0.0:*                           104        15391      437/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        15389      437/avahi-daemon: r
      udp6       0      0 :::53648                :::*                                104        15392      437/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        15390      437/avahi-daemon: r
      2024-01-27 21:45:39.402  - info: hm-rpc.1 (3986) Terminated (NO_ERROR): Without reason
      2024-01-27 21:45:39.430  - info: hm-rpc.1 (3986) terminating
      2024-01-27 21:45:39.471  - info: hm-rpc.1 (3986) terminating
      2024-01-27 21:45:39.920  - info: admin.0 (4256) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2024-01-27 21:45:40.017  - info: host.raspberrypi instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
      2024-01-27 21:45:40.017  - info: host.raspberrypi Restart adapter system.adapter.hm-rpc.1 because enabled
      2024-01-27 21:45:40.257  - info: admin.0 (4256) starting. Version 6.12.0 in /opt/iobroker/node_modules/iobroker.admin, node: v18.19.0, js-controller: 5.0.17
      2024-01-27 21:45:40.316  - info: admin.0 (4256) requesting all objects
      2024-01-27 21:45:43.816  - info: admin.0 (4256) received all objects
      2024-01-27 21:45:44.637  - info: admin.0 (4256) socket.io server listening on port 8081
      2024-01-27 21:45:44.644  - info: admin.0 (4256) http server listening on port 8081
      2024-01-27 21:45:44.645  - info: admin.0 (4256) Use link "http://127.0.0.1:8081" to configure.
      2024-01-27 21:46:02.392  - error: hm-rpc.0 (4197) Init not possible, going to stop: connect EHOSTUNREACH 192.168.2.122:2001
      2024-01-27 21:46:02.414  - info: hm-rpc.0 (4197) xmlrpc -> 192.168.2.122:2001/ init ["http://192.168.2.113:2001",""]
      2024-01-27 21:46:03.422  - info: hm-rpc.0 (4197) terminating
      2024-01-27 21:46:03.425  - info: hm-rpc.0 (4197) Terminated (NO_ERROR): Without reason
      2024-01-27 21:46:04.037  - info: host.raspberrypi instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
      2024-01-27 21:46:04.038  - info: host.raspberrypi Restart adapter system.adapter.hm-rpc.0 because enabled
      2024-01-27 21:46:08.568  - error: hm-rega.0 (2608) CCU 192.168.2.122 unreachable
      2024-01-27 21:46:10.169  - info: host.raspberrypi instance system.adapter.hm-rpc.1 started with pid 4393
      2024-01-27 21:46:12.464  - info: hm-rpc.1 (4393) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2024-01-27 21:46:12.735  - info: hm-rpc.1 (4393) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.17
      2024-01-27 21:46:13.081  - info: hm-rpc.1 (4393) xmlrpc server is trying to listen on 192.168.2.113:2010
      2024-01-27 21:46:13.082  - info: hm-rpc.1 (4393) xmlrpc client is trying to connect to 192.168.2.122:2010/ with ["http://192.168.2.113:2010","raspberrypi:hm-rpc.1:ff6dfd3a7f0f6cc5fcbfb9b363ac5e5a"]
      2024-01-27 21:46:16.186  - error: hm-rpc.1 (4393) Init not possible, going to stop: connect EHOSTUNREACH 192.168.2.122:2010
      wenn ich iob fix mache kommt
      john@raspberrypi:/opt/iobroker $ iob fix
      library: loaded
      Library version=2024-01-04
      ioBroker or some processes are still running:
       io.alexa2.0
       io.telegram.0
       io.javascript.0
       io.discovery.0
       io.backitup.0
       io.enigma2.0
       io.heizoel.0
       io.tankerkoenig.0
       io.worx.0
      Please stop them first and try again!
      klar, irgendwas läuft, nur nicht ccu und nicht iob
      MFG Schweizer
      Homoran Glasfaser 4 Replies Last reply Reply Quote 0
        Homoran Global Moderator Administrators @Schweiz last edited by Homoran
        @schweiz sagte in Jarvis Adapter lässt sich nicht Installieren:
        iob läuft, auch der admin.
        zumindest war das als diag lief
          nur nicht ccu
          sudo pivccu-info
          • Glasfaser
            Glasfaser @Schweiz last edited by
            Logo ... steht doch da
            iob stop
            zuvor
              Schweiz @Glasfaser last edited by
              ich hatte iob fix nur ausgeführt um zu sehen ob es mit iob start gestartet ist, aber ich habe keinen zugriff auf die oberfläche bekommen.
              Nun nochmal sudo reboot gemacht und nun geht es...
              CCU läuft auch, aber...
              das ist echt strange...
              über die console ging es mit dem alexa Adapter... zu aktuallsieren
              über IOB geht es nicht mit dem wetter Adapter...
              und über die console auch nicht ;(
              john@raspberrypi:/opt/iobroker $ john@raspberrypi:/opt/iobroker $ iob upgrade weather-warnings@0.6.6 --debug
              This upgrade of "weather-warnings" will introduce the following changes:
              -> 0.6.6:
              fullday(ZAMG only): If time span is 24h +/- 5 minutes and the start hour is between 0-3, day of the week from start time, otherwise blank.
              -> 0.6.5:
              Added: ZAMG full day token
              fixed: Send emails asynchron
              fixed: dont ignore uwz activate setting
              update dp-objects on every start.
              Would you like to upgrade weather-warnings from @0.6.4 to @0.6.6 now? [(y)es, (n)o]: y
              Update weather-warnings from @0.6.4 to @0.6.6
              NPM version: 10.2.3
              Installing iobroker.weather-warnings@0.6.6... (System call)
              npm ERR! code ETIMEDOUT
              npm ERR! syscall connect
              npm ERR! errno ETIMEDOUT
              npm ERR! network request to https://registry.npmjs.org/iobroker.weather-warnings/-/iobroker.weather-warnings-0.6.6.tgz failed, reason: connect ETIMEDOUT 2606:4700::6810:223:443
              npm ERR! network This is a problem related to network connectivity.
              npm ERR! network In most cases you are behind a proxy or have bad network settings.
              npm ERR! network
              npm ERR! network If you are behind a proxy, please make sure that the
              npm ERR! network 'proxy' config is set properly.  See: 'npm help config'
              npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-27T21_09_40_353Z-debug-0.log
              npm ERR! network
              host.raspberrypi Cannot install iobroker.weather-warnings@0.6.6: 1
              und nach wie vor kein anderer Adapter...
              ich verzweifle bald...
              MFG Schweizer
                da hatten wir ja auch das Problem vorher behoben.
                dann musst du da auch nochmal mit --debug arbeiten
                  doch wieder ipv6 Probleme?
                    nein, am gleichen tag als ich die anderen adapter installiert habe wollte ich auch jarvis installieren, weil das so an sich das letzte war,... das die anderen auch nicht gehen war mir nicht bewusst... auch hat der Internet Test ja gezeigt das IPV6 voll da ist...
                    hab ich doch gemacht mit Debug, siehe gerade eben... 😉
                    MFG Schweizer
                      aber nicht den debug.log der da genannt wird gezeigt
                      • Glasfaser
                        curl -L -o iobroker.weather-warnings-0.6.6.tgz https://registry.npmjs.org/iobroker.weather-warnings/-/iobroker.weather-warnings-0.6.6.tgz
                        Ausgabe zeigen
                          auch vom iob server aus getestet?
                          kopier dir mal den Link in meinem Quote in einen Browser.
                          ich kann das tar.gz runterladen, und du?
                            @glasfaser sagte in Jarvis Adapter lässt sich nicht Installieren:
                            curl -L -o iobroker.weather-warnings-0.6.6.tgz https://registry.npmjs.org/iobroker.weather-warnings/-/iobroker.weather-warnings-0.6.6.tgzgz
                              % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                                             Dload  Upload   Total   Spent    Left  Speed
                            100  849k  100  849k    0     0   990k      0 --:--:-- --:--:-- --:--:--  989k
                            • Glasfaser
                              Zeige uns den Inhalt davon
                              • Glasfaser
                                Was ist das .... hast du ein DNS Server eingerichtet !?
                                  kann ich herunter laden...
                                  ein dns habe ich nicht eingerichtet... wüsste nicht wo ich das finden soll im PI
                                  in der Fritz
                                  FRITZ!Box 7272 (UI)
                                  Schweiz, FRITZ!OS 06.89, FRITZ!OS ist aktuell
                                  FRITZ!Box-Anmeldung
                                  Mit Benutzername und Kennwort gesichert
                                  LAN
                                  LAN 1
                                  LAN 2
                                  LAN 3
                                  LAN 4
                                  LAN 1, LAN 2 im Power Mode, LAN 3, LAN 4 im Green Mode
                                  WLAN
                                  Funknetzname: Schweiz
                                  aktuell 8 WLAN-Geräte verbunden, gesichert
                                  DECT
                                  aus
                                  USB-Geräte
                                  kein Gerät angeschlossen
                                  Internetverbindung
                                  IPv4: Eine bestehende Internetverbindung im Netzwerk wird mitbenutzt. IPv4-Adresse: 192.168.2.105
                                  IPv6: Eine bestehende Internetverbindung im Netzwerk wird mitbenutzt. IPv6-Adresse: 2003:f9:e724:fa91:3631:c4ff:fee4:338b
                                  Rufnummern
                                  Keine Rufnummern aktiv. Die Funktion der Festnetzrufnummer lässt sich nicht ermitteln.
                                  Heimnetz
                                  93 Geräte im Heimnetz, 0 davon online
                                  WLAN-Umgebung
                                  1 WLAN-Netz auf demselben Kanal aktiv
                                  keine WLAN-Netze mit demselben Namen
                                  PI ist auf LAN2
                                  -> 0.6.6:
                                  -> 0.6.5:
                                  NPM version: 10.2.3
                                  npm ERR! network request to https://registry.npmjs.org/iobroker.weather-warnings/-/iobroker.weather-warnings-0.6.6.tgz failed, reason: connect ETIMEDOUT 2606:4700::6810:1a22:443
                                  npm ERR! network
                                  npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-27T21_46_38_282Z-debug-0.log
                                  npm ERR! network
                                  john@raspberrypi:~ $ nano /home/iobroker/.npm/_logs/2024-01-27T21_46_38_282Z-debug-0.log
                                    GNU nano 7.2                                                        /home/iobroker/.npm/_logs/2024-01-27T21_46_38_282Z-debug-0.log
                                  0 verbose cli /usr/bin/node /usr/bin/npm
                                  1 info using npm@10.2.3
                                  2 info using node@v18.19.0
                                  3 timing npm:load:whichnode Completed in 4ms
                                  4 timing config:load:defaults Completed in 6ms
                                  5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 2ms
                                  6 timing config:load:builtin Completed in 4ms
                                  7 timing config:load:cli Completed in 12ms
                                  8 timing config:load:env Completed in 0ms
                                  9 timing config:load:file:/opt/iobroker/.npmrc Completed in 6ms
                                  10 timing config:load:project Completed in 17ms
                                  11 timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
                                  12 timing config:load:user Completed in 1ms
                                  13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
                                  14 timing config:load:global Completed in 0ms
                                  15 timing config:load:setEnvs Completed in 3ms
                                  16 timing config:load Completed in 48ms
                                  17 timing npm:load:configload Completed in 49ms
                                  18 timing config:load:flatten Completed in 9ms
                                  19 timing npm:load:mkdirpcache Completed in 1ms
                                  20 timing npm:load:mkdirplogs Completed in 1ms
                                  21 verbose title npm install iobroker.weather-warnings@0.6.6
                                  22 verbose argv "install" "--save-exact" "iobroker.weather-warnings@0.6.6"
                                  23 timing npm:load:setTitle Completed in 4ms
                                  24 timing npm:load:display Completed in 2ms
                                  25 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs/2024-01-27T21_46_38_282Z-
                                  26 verbose logfile /home/iobroker/.npm/_logs/2024-01-27T21_46_38_282Z-debug-0.log
                                  27 timing npm:load:logFile Completed in 30ms
                                  28 timing npm:load:timers Completed in 0ms
                                  29 timing npm:load:configScope Completed in 0ms
                                  30 timing npm:load Completed in 146ms
                                  31 timing arborist:ctor Completed in 3ms
                                  32 silly logfile start cleaning logs, removing 2 files
                                  33 silly logfile done cleaning log files
                                  34 timing idealTree:init Completed in 2377ms
                                  35 timing idealTree:userRequests Completed in 5ms
                                  36 silly idealTree buildDeps
                                  37 silly fetch manifest iobroker.weather-warnings@0.6.6
                                  38 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
                                  39 http fetch GET 200 https://registry.npmjs.org/iobroker.weather-warnings 460159ms (cache stale)
                                  40 silly placeDep ROOT iobroker.weather-warnings@0.6.6 REPLACE for: iobroker.core@1.0.0 want: 0.6.6
                                  41 timing idealTree:#root Completed in 460231ms
                                  42 timing idealTree:node_modules/iobroker.weather-warnings Completed in 0ms
                                  43 timing idealTree:buildDeps Completed in 460235ms
                                  44 timing idealTree:fixDepFlags Completed in 62ms
                                  45 timing idealTree Completed in 462726ms
                                  46 timing reify:loadTrees Completed in 462730ms
                                  47 timing reify:diffTrees Completed in 74ms
                                  MFG Schweizer
                                  • Glasfaser
                                    Nochmal :
                                    iob stop
                                    cd /opt/iobroker
                                    npm cache clean --force
                                    rm /opt/iobroker/package*
                                    sudo reboot
                                    • Glasfaser
                                      Danach diesen über die Admin Konsole updaten ( Instanz )
                                        das ist alles was er macht...
                                        MFG Schweizer
                                          Schweiz @Schweiz last edited by
                                          IOB startet nicht mehr... CCU jedoch ja...
                                          MFG Schweizer
                                          • Glasfaser
                                            @schweiz
                                            dann in der Konsole
                                            iob update
                                            iob upgrade
                                            4116
