    4. Jarvis Adapter lässt sich nicht Installieren
    • Glasfaser
      Glasfaser @Glasfaser last edited by
      @schweiz
      Ich habe keinen blassen Schimmer , warum der immer sich bei Dir zerschießt !
      cd /opt/iobroker
      npm cache clean --force
      sudo -H -u iobroker npm install iobroker.js-controller
        Schweiz @Glasfaser last edited by
        @glasfaser sagte in Jarvis Adapter lässt sich nicht Installieren:
        iob diag
        hab nur neustart gemacht und iob start... der admin war kurz da und dann kam nur noch das dreh rad...
                                v.2023-10-10
         Static hostname: raspberrypi
               Icon name: computer
                  Kernel: Linux 6.1.0-rpi7-rpi-v8
            Architecture: arm64
        Installation:           native
        Kernel:                 aarch64
        Userland:               arm64
        Timezone:               Europe/Berlin (CET, +0100)
        User-ID:                1000
        X-Server:               false
        Boot Target:            multi-user.target
        Pending OS-Updates:     10
        node:internal/modules/cjs/loader:1137
          throw err;
        Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
            at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
            at Module._load (node:internal/modules/cjs/loader:975:27)
            at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
            at node:internal/main/run_main_module:28:49 {
          code: 'MODULE_NOT_FOUND',
          requireStack: []
        Node.js v18.19.0
        Pending iob updates:    0
        Nodejs-Installation:    /usr/bin/nodejs         v18.19.0
                                /usr/bin/node           v18.19.0
                                /usr/bin/npm            10.2.3
                                /usr/bin/npx            10.2.3
                                /usr/bin/corepack       0.22.0
        Recommended versions are nodejs  and npm
        MEMORY:
        Mem:            4.0G        460M        2.9G        1.3M        704M        3.5G
        Swap:           104M          0B        104M
        Total:          4.1G        460M        3.0G
          throw err;
          requireStack: []
        Node.js v18.19.0
        Active iob-Instances:   0
          throw err;
          requireStack: []
        Node.js v18.19.0
          throw err;
          requireStack: []
        Node.js v18.19.0
        ioBroker Core:          js-controller
          throw err;
          requireStack: []
        Node.js v18.19.0
                                admin
          throw err;
          requireStack: []
        Node.js v18.19.0
        ioBroker Status:
          throw err;
          requireStack: []
        Node.js v18.19.0
        Objects:                0
        States:                 0
        Size of iob-Database:
        18M     /opt/iobroker/iobroker-data/objects.jsonl
        8.8M    /opt/iobroker/iobroker-data/states.jsonl
        MFG Schweizer
          Schweiz @Schweiz last edited by Schweiz
          Skript v.2023-10-10
          *** BASE SYSTEM ***
                 Icon name: computer
              Architecture: arm64
          Model           : Raspberry Pi 4 Model B Rev 1.1
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : arm64
          Systemuptime and Load:
           23:27:01 up 13 min,  3 users,  load average: 0.13, 0.29, 0.33
          CPU threads: 4
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** Time and Time Zones ***
                         Local time: Sat 2024-01-27 23:27:01 CET
                     Universal time: Sat 2024-01-27 22:27:01 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** User and Groups ***
          john
          /home/john
          john adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
          *** X-Server-Setup ***
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            4.0G        461M        2.9G        1.3M        704M        3.5G
          Swap:           104M          0B        104M
          Total:          4.1G        461M        3.0G
                   3793 M total memory
                    440 M used memory
                    470 M active memory
                    420 M inactive memory
                   2757 M free memory
                     62 M buffer memory
                    609 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          Raspberry only:
          oom events: 0
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** FILESYSTEM ***
          udev           devtmpfs  1.6G     0  1.6G   0% /dev
          tmpfs          tmpfs     380M  1.2M  379M   1% /run
          /dev/mmcblk0p2 ext4       59G  3.8G   52G   7% /
          tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
          /dev/mmcblk0p1 vfat      510M   62M  449M  13% /boot/firmware
          tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
          [Sat Jan 27 23:13:01 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:29:88:49 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=620a9d97-02 rootfstype=ext4 fsck.repair=yes rootwait
          [Sat Jan 27 23:13:03 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
          [Sat Jan 27 23:13:05 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          TARGET           SOURCE         FSTYPE OPTIONS
          /                /dev/mmcblk0p2 ext4   rw,noatime
          `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          1.3G    /var/
          837M    /var/lib
          662M    /var/lib/piVCCU3
          604M    /var/lib/piVCCU3/rootfs
          279M    /var/lib/piVCCU3/rootfs/opt
          Archived and active journals take up 109.1M in the file system.
          /opt/iobroker/backups:
          34M     /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          297M    /opt/iobroker/iobroker-data/
          185M    /opt/iobroker/iobroker-data/files
          86M     /opt/iobroker/iobroker-data/backup-objects
          67M     /opt/iobroker/iobroker-data/files/javascript.admin
          49M     /opt/iobroker/iobroker-data/files/telegram-menu.admin
          36M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
          21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
          13M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js
          USB-Devices by-id:
          *** NodeJS-Installation ***
          /usr/bin/npm            10.2.3
          /usr/bin/npx            10.2.3
          nodejs:
            Installed: 18.19.0-1nodesource1
            Candidate: 18.19.0-1nodesource1
            Version table:
               18.19.0+dfsg-6~deb12u1 500
           *** 18.19.0-1nodesource1 1001
                  100 /var/lib/dpkg/status
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0+dfsg1-1 500
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
          No problems detected
          Errors in npm tree:
          *** ioBroker-Installation ***
          ioBroker Status
            throw err;
            requireStack: []
          Node.js v18.19.0
          Core adapters versions
            throw err;
            requireStack: []
          Node.js v18.19.0
          js-controller:
            throw err;
            requireStack: []
          Node.js v18.19.0
          admin:
            throw err;
            requireStack: []
          Node.js v18.19.0
          javascript:
          Adapters from github:   0
          Adapter State
            throw err;
            requireStack: []
          Node.js v18.19.0
            throw err;
            requireStack: []
          Node.js v18.19.0
          ioBroker-Repositories
            throw err;
            requireStack: []
          Node.js v18.19.0
          Installed ioBroker-Instances
            throw err;
            requireStack: []
          Node.js v18.19.0
          Objects and States
          Objects:        0
          States:         0
          Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:2 http://deb.debian.org/debian bookworm InRelease
          Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
          Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 10
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15874      1007/sshd: /usr/sbi
          tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          14834      1045/dnsmasq
          tcp6       0      0 :::22                   :::*                    LISTEN      0          15876      1007/sshd: /usr/sbi
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        12824      510/avahi-daemon: r
          udp        0      0 0.0.0.0:50638           0.0.0.0:*                           104        12826      510/avahi-daemon: r
          udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          14833      1045/dnsmasq
          udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14830      1045/dnsmasq
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12972      900/dhclient
          udp6       0      0 :::5353                 :::*                                104        12825      510/avahi-daemon: r
          udp6       0      0 :::40707                :::*                                104        12827      510/avahi-daemon: r
          2024-01-27 23:15:10.525  - info: host.raspberrypi stopInstance system.adapter.viessmannapi.0 send kill signal
          2024-01-27 23:15:10.631  - info: hm-rega.0 (2002) terminating
          2024-01-27 23:15:10.635  - info: hm-rega.0 (2002) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-01-27 23:15:10.655  - info: web.0 (2499) terminated http server on port 8082
          2024-01-27 23:15:10.656  - info: web.0 (2499) terminating
          2024-01-27 23:15:10.659  - info: web.0 (2499) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-01-27 23:15:10.731  - info: javascript.0 (1832) terminating
          2024-01-27 23:15:10.724  - info: telegram.0 (1703) terminating
          2024-01-27 23:15:10.729  - info: telegram.0 (1703) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-01-27 23:15:10.741  - info: hm-rega.0 (2002) terminating
          2024-01-27 23:15:10.745  - info: tr-064.0 (2027) terminating
          2024-01-27 23:15:10.765  - info: backitup.0 (2186) terminating
          2024-01-27 23:15:10.793  - info: discovery.0 (2134) terminating
          2024-01-27 23:15:10.795  - info: enigma2.0 (2264) terminating
          2024-01-27 23:15:10.797  - info: enigma2.0 (2264) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2024-01-27 23:15:10.806  - info: heizoel.0 (2424) terminating
          2024-01-27 23:15:10.810  - info: admin.0 (1612) terminating
          2024-01-27 23:15:10.813  - info: tankerkoenig.0 (2441) terminating
          2024-01-27 23:15:10.830  - info: worx.0 (2457) terminating
          2024-01-27 23:15:10.835  - info: weather-warnings.0 (2482) terminating
          2024-01-27 23:15:10.842  - info: web.0 (2499) terminating
          2024-01-27 23:15:10.860  - info: viessmannapi.0 (2559) terminating
          2024-01-27 23:15:10.870  - info: trashschedule.0 (2528) terminating
          2024-01-27 23:15:11.119  - info: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2024-01-27 23:15:11.120  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          • Glasfaser
            @Schweiz
            Hast du das gemacht !?
            @schweiz
            cd /opt/iobroker
            S Glasfaser 2 Replies Last reply Reply Quote 0
              @glasfaser
              ja, hast du ja geschrieben, beim ersten mal ging ja Alexa2 über console mit debug, da hatte ich ja hoffnung...
              soll ich nochmal machen?
              MFG Schweizer
              Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
              • Glasfaser
                Glasfaser @Schweiz last edited by
                @schweiz sagte in Jarvis Adapter lässt sich nicht Installieren:
                ja
                und danach
                sudo reboot
                  Thomas Braun Most Active @Schweiz last edited by Thomas Braun
                  @schweiz
                  Pending Updates: 10
                  sudo apt update
                  sudo apt full-upgrade
                  sudo reboot
                  Dann weiter forschen.
                    @glasfaser
                    der bleibt jetzt hängen
                    john@raspberrypi:~ $ cd /opt/iobroker
                    john@raspberrypi:/opt/iobroker $ iob stop
                    john@raspberrypi:/opt/iobroker $ npm cache clean --force
                    npm WARN using --force Recommended protections disabled.
                    john@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                    (⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂) ⠏ idealTree:iobroker: sill idealTree buildDeps
                    sudo apt update
                    Paketlisten werden gelesen… Fertig
                    Abhängigkeitsbaum wird aufgebaut… Fertig
                    Statusinformationen werden eingelesen… Fertig
                    Paketaktualisierung (Upgrade) wird berechnet… Fertig
                    Die folgenden Pakete werden aktualisiert (Upgrade):
                      firmware-atheros firmware-brcm80211 firmware-libertas firmware-misc-nonfree
                      firmware-realtek kms++-utils libkms++0 raspberrypi-net-mods raspi-config
                      rpi-eeprom
                    10 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                    Es müssen 73,3 MB an Archiven heruntergeladen werden.
                    Nach dieser Operation werden 9.447 kB Plattenplatz zusätzlich benutzt.
                    Möchten Sie fortfahren? [J/n] j
                    Holen:1 http://archive.raspberrypi.com/debian bookworm/main arm64 firmware-ather        os all 1:20230210-5+rpt3 [16,8 MB]
                    Holen:2 http://archive.raspberrypi.com/debian bookworm/main arm64 firmware-brcm8        0211 all 1:20230210-5+rpt3 [5.852 kB]
                    Holen:3 http://archive.raspberrypi.com/debian bookworm/main arm64 firmware-liber        tas all 1:20230210-5+rpt3 [31,2 MB]
                    Holen:4 http://archive.raspberrypi.com/debian bookworm/main arm64 firmware-misc-        nonfree all 1:20230210-5+rpt3 [13,0 MB]
                    Holen:5 http://archive.raspberrypi.com/debian bookworm/main arm64 firmware-realt        ek all 1:20230210-5+rpt3 [1.492 kB]
                    Holen:6 http://archive.raspberrypi.com/debian bookworm/main arm64 libkms++0 arm6        4 0~git20231115~065257+9ae90ce-1 [75,2 kB]
                    Holen:7 http://archive.raspberrypi.com/debian bookworm/main arm64 kms++-utils ar        m64 0~git20231115~065257+9ae90ce-1 [81,9 kB]
                    Holen:8 http://archive.raspberrypi.com/debian bookworm/main arm64 raspi-config a        ll 20240108 [29,7 kB]
                    Holen:9 http://archive.raspberrypi.com/debian bookworm/main arm64 raspberrypi-ne        t-mods all 1.4.1 [2.180 B]
                    Holen:10 http://archive.raspberrypi.com/debian bookworm/main arm64 rpi-eeprom al        l 21.1-1 [4.651 kB]
                    Es wurden 73,3 MB in 28 s geholt (2.627 kB/s).
                    Changelogs werden gelesen... Fertig
                    (Lese Datenbank ... 109167 Dateien und Verzeichnisse sind derzeit installiert.)
                    Vorbereitung zum Entpacken von .../0-firmware-atheros_1%3a20230210-5+rpt3_all.de        b ...
                    Entpacken von firmware-atheros (1:20230210-5+rpt3) über (1:20230210-5+rpt2) ...
                    Vorbereitung zum Entpacken von .../1-firmware-brcm80211_1%3a20230210-5+rpt3_all.        deb ...
                    Entpacken von firmware-brcm80211 (1:20230210-5+rpt3) über (1:20230210-5+rpt2) ..        .
                    Vorbereitung zum Entpacken von .../2-firmware-libertas_1%3a20230210-5+rpt3_all.d        eb ...
                    Entpacken von firmware-libertas (1:20230210-5+rpt3) über (1:20230210-5+rpt2) ...
                    Vorbereitung zum Entpacken von .../3-firmware-misc-nonfree_1%3a20230210-5+rpt3_a        ll.deb ...
                    Entpacken von firmware-misc-nonfree (1:20230210-5+rpt3) über (1:20230210-5+rpt2)        ...
                    Vorbereitung zum Entpacken von .../4-firmware-realtek_1%3a20230210-5+rpt3_all.de        b ...
                    Entpacken von firmware-realtek (1:20230210-5+rpt3) über (1:20230210-5+rpt2) ...
                    Vorbereitung zum Entpacken von .../5-libkms++0_0~git20231115~065257+9ae90ce-1_ar        m64.deb ...
                    Entpacken von libkms++0:arm64 (0~git20231115~065257+9ae90ce-1) über (0~git202309        30~162059+b91affd-1) ...
                    Vorbereitung zum Entpacken von .../6-kms++-utils_0~git20231115~065257+9ae90ce-1_        arm64.deb ...
                    Entpacken von kms++-utils (0~git20231115~065257+9ae90ce-1) über (0~git20230930~1        62059+b91affd-1) ...
                    Vorbereitung zum Entpacken von .../7-raspi-config_20240108_all.deb ...
                    Entpacken von raspi-config (20240108) über (20231216) ...
                    Vorbereitung zum Entpacken von .../8-raspberrypi-net-mods_1.4.1_all.deb ...
                    Entpacken von raspberrypi-net-mods (1.4.1) über (1.4.0) ...
                    Vorbereitung zum Entpacken von .../9-rpi-eeprom_21.1-1_all.deb ...
                    Entpacken von rpi-eeprom (21.1-1) über (20.5-1) ...
                    firmware-atheros (1:20230210-5+rpt3) wird eingerichtet ...
                    firmware-misc-nonfree (1:20230210-5+rpt3) wird eingerichtet ...
                    libkms++0:arm64 (0~git20231115~065257+9ae90ce-1) wird eingerichtet ...
                    firmware-brcm80211 (1:20230210-5+rpt3) wird eingerichtet ...
                    firmware-realtek (1:20230210-5+rpt3) wird eingerichtet ...
                    firmware-libertas (1:20230210-5+rpt3) wird eingerichtet ...
                    rpi-eeprom (21.1-1) wird eingerichtet ...
                    raspi-config (20240108) wird eingerichtet ...
                    kms++-utils (0~git20231115~065257+9ae90ce-1) wird eingerichtet ...
                    raspberrypi-net-mods (1.4.1) wird eingerichtet ...
                    Neue Version der Konfigurationsdatei /etc/profile.d/wifi-check.sh wird installie        rt ...
                    Trigger für man-db (2.11.2-2) werden verarbeitet ...
                    Trigger für libc-bin (2.36-9+rpt2+deb12u3) werden verarbeitet ...
                    Trigger für initramfs-tools (0.142) werden verarbeitet ...
                    update-initramfs: Generating /boot/initrd.img-6.1.0-rpi7-rpi-v8
                    update-initramfs: Generating /boot/initrd.img-6.1.0-rpi7-rpi-2712
                    sudo reboot
                    iob start
                    iob diag
                    Skript v.2023-10-10
                    *** BASE SYSTEM ***
                           Icon name: computer
                        Architecture: arm64
                    Docker          : false
                    Kernel          : aarch64
                    Userland        : arm64
                     23:42:03 up 3 min,  2 users,  load average: 0.46, 0.30, 0.12
                    CPU threads: 4
                    Current issues:
                                   Local time: Sat 2024-01-27 23:42:03 CET
                               Universal time: Sat 2024-01-27 22:42:03 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    john
                    /home/john
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            4.0G        417M        3.4G        1.3M        271M        3.6G
                    Swap:           104M          0B        104M
                    Total:          4.1G        417M        3.5G
                             3793 M total memory
                              398 M used memory
                              418 M active memory
                               79 M inactive memory
                             3203 M free memory
                               16 M buffer memory
                              242 M swap cache
                               99 M total swap
                                0 M used swap
                               99 M free swap
                    Raspberry only:
                    oom events: 0
                    *** FILESYSTEM ***
                    [Sat Jan 27 23:38:57 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:29:88:49 vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty        1 root=PARTUUID=620a9d97-02 rootfstype=ext4 fsck.repair=yes rootwait
                    [Sat Jan 27 23:39:00 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
                    [Sat Jan 27 23:39:02 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepag        e=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                    /var:
                    1.3G    /var/
                    837M    /var/lib
                    Archived and active journals take up 117.1M in the file system.
                    USB-Devices by-id:
                    /usr/bin/npm            10.2.3
                    /usr/bin/npx            10.2.3
                    nodejs:
                      Version table:
                         18.13.0+dfsg1-1 500
                    Errors in npm tree:
                    ioBroker Status
                      throw err;
                      requireStack: []
                    Node.js v18.19.0
                      throw err;
                      requireStack: []
                    Node.js v18.19.0
                    js-controller:
                      throw err;
                      requireStack: []
                    Node.js v18.19.0
                    admin:
                      throw err;
                      requireStack: []
                    Node.js v18.19.0
                    javascript:
                    Adapter State
                      throw err;
                      requireStack: []
                    Node.js v18.19.0
                      throw err;
                      requireStack: []
                    Node.js v18.19.0
                      throw err;
                      requireStack: []
                    Node.js v18.19.0
                      throw err;
                      requireStack: []
                    Node.js v18.19.0
                    Objects and States
                    Objects:        0
                    States:         0
                    Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                    Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                    Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
                    Pending Updates: 0
                    tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          16548      1039/dnsmasq
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15964      994/sshd: /usr/sbin
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          15966      994/sshd: /usr/sbin
                    udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          16547      1039/dnsmasq
                    udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          16544      1039/dnsmasq
                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          647        890/dhclient
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        13219      512/avahi-daemon: r
                    udp        0      0 0.0.0.0:38913           0.0.0.0:*                           104        13221      512/avahi-daemon: r
                    udp6       0      0 :::41539                :::*                                104        13222      512/avahi-daemon: r
                    udp6       0      0 :::5353                 :::*                                104        13220      512/avahi-daemon: r
                    CCU geht IOB nicht...
                    • Glasfaser
                      @Schweiz
                      Gehe mal eine Version runter
                      sudo -H -u iobroker npm install iobroker.js-controller@5.0.16
                        geht nicht, klemmt auch am anfang...
                        MFG Schweizer
                        • Glasfaser
                          Habe ich mir gedacht ... da klemmt eher dein Netzwerk
                            @glasfaser
                            ich habe ja die ganze zeit installiert, und es hat alles funktioniert... bis dann plötzlich die Adapter sich nicht Installieren lassen haben...
                            IOB und CCU haben tadelos funktioniert und mir auch per Telegram und Enigma nachrichten gesendet...
                            MFG Schweizer
                              CCU läuft weiter hin, nur IOB nicht
                              MFG Schweizer
                                wo speichert der BackupAdapter auf der Karte das Backup?
                                Dann zieht ich das morgen runter und Insatlliere nochmal...
                                vorher Teste ich ob ich Adapter installieren kann...
                                geht ja nicht weiter... sonst besauf mich...
                                MFG Schweizer
                                • Glasfaser
                                    @glasfaser
                                    ok, danke... erst mal... eine gute n8
                                    MFG Schweizer
                                      Also gut...
                                      ich denke ich kann es nun eingrenzen...
                                      Also das erste mal habe ich die Adapter alphabetisch installiert von A-Z dabei war Trashschedule mehr oder weiger einer der letzten Adapter war welche ich Installiert hatte. Der Jarvis war dann der letzte welchen ich Installieren wollte aber nicht ging... Der fehler liegt hier ganz offensichtlich im Trashschedule, da ich nun von Z-A installiert habe. Jetzt habe ich ich den Trashschedule installiert und es geht wider nix, auch nicht nach entfernen des Adapters...
                                      Skript v.2023-10-10
                                      *** BASE SYSTEM ***
                                             Icon name: computer
                                          Architecture: arm64
                                      Docker          : false
                                      Kernel          : aarch64
                                      Userland        : arm64
                                       18:40:41 up  2:09,  2 users,  load average: 0.29, 0.30, 0.34
                                      CPU threads: 4
                                      Current issues:
                                                     Local time: Sun 2024-01-28 18:40:41 CET
                                                 Universal time: Sun 2024-01-28 17:40:41 UTC
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      john
                                      /home/john
                                      X-Server:       false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Mem:            4.0G        1.1G        1.2G        1.2M        1.8G        2.9G
                                      Swap:           104M          0B        104M
                                      Total:          4.1G        1.1G        1.3G
                                               3793 M total memory
                                               1006 M used memory
                                               1081 M active memory
                                               1295 M inactive memory
                                               1167 M free memory
                                                 82 M buffer memory
                                               1613 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      Raspberry only:
                                      oom events: 0
                                      *** FILESYSTEM ***
                                      /dev/mmcblk0p2 ext4       59G  3.5G   52G   7% /
                                      /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
                                      [Sun Jan 28 16:30:54 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:29:88:49 vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty        1 root=PARTUUID=96a04be6-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ie        ee80211_regdom=DE
                                      [Sun Jan 28 16:30:57 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
                                      [Sun Jan 28 16:30:59 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                      /var:
                                      500M    /var/
                                      203M    /var/cache
                                      198M    /var/cache/apt
                                      160M    /var/lib
                                      132M    /var/lib/apt/lists
                                      Archived and active journals take up 36.0M in the file system.
                                      4.0K    /opt/iobroker/backups/
                                      318M    /opt/iobroker/iobroker-data/
                                      310M    /opt/iobroker/iobroker-data/files
                                      155M    /opt/iobroker/iobroker-data/files/vis-2
                                      78M     /opt/iobroker/iobroker-data/files/vis-2/static
                                      77M     /opt/iobroker/iobroker-data/files/vis-2/static/js
                                      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.m        ap
                                      18M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e642d05b.js.map
                                      18M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.2b7aff38.js.map
                                      18M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
                                      USB-Devices by-id:
                                      USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always        prefer the links 'by-id':
                                      /usr/bin/npm            10.2.3
                                      /usr/bin/npx            10.2.3
                                      nodejs:
                                        Version table:
                                           18.13.0+dfsg1-1 500
                                      Errors in npm tree:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      js-controller:  5.0.17
                                      admin:          6.12.0
                                      javascript:     "javascript" not found
                                      Adapter State
                                      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                        system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : raspberrypi                              - disabled
                                        system.adapter.alexa2.0                 : alexa2                : raspberrypi                              - disabled
                                      + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                        system.adapter.daswetter.0              : daswetter             : raspberrypi                              - disabled
                                      + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                                        system.adapter.exchangerates.0          : exchangerates         : raspberrypi                              - disabled
                                        system.adapter.ical.0                   : ical                  : raspberrypi                              - disabled
                                      + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                        system.adapter.parcel.0                 : parcel                : raspberrypi                              - disabled
                                        system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              - disabled
                                        system.adapter.telegram-menu.0          : telegram-menu         : raspberrypi                              - disabled
                                        system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
                                        system.adapter.telegram.1               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
                                        system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
                                        system.adapter.viessmannapi.0           : viessmannapi          : raspberrypi                              - disabled
                                        system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : raspberrypi                              -  enabled
                                        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi                              -  enabled
                                      + system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              -  enabled
                                        system.adapter.vis-map.0                : vis-map               : raspberrypi                              -  enabled
                                        system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
                                        system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                                        system.adapter.weather-warnings.0       : weather-warnings      : raspberrypi                              - disabled
                                      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                      + system.adapter.welcome.0                : welcome               : raspberrypi                              -  enabled, port: 80, bind: 0.0.0.0, run as: admin
                                        system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
                                      + instance is alive
                                      Active repo(s): stable
                                      Used repository: stable
                                      Adapter    "admin"        : 6.12.0   , installed 6.12.0
                                      Adapter    "alexa-timer-vis": 0.3.0  , installed 0.3.0
                                      Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
                                      Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                                      Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
                                      Adapter    "exchangerates": 0.0.14   , installed 0.0.14
                                      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                                      Controller "js-controller": 5.0.17   , installed 5.0.17
                                      Adapter    "parcel"       : 0.0.27   , installed 0.0.27
                                      Adapter    "telegram"     : 3.0.1    , installed 3.0.1
                                      Adapter    "telegram-menu": 1.5.1    , installed 1.5.1
                                      Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                                      Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
                                      Adapter    "vis-2"        : 2.9.11   , installed 2.9.11
                                      Adapter    "vis-2-widgets-gauges": 1.0.2, installed 1.0.2
                                      Adapter    "vis-2-widgets-material": 1.3.17, installed 1.3.17
                                      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                                      Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                                      Adapter    "weather-warnings": 0.6.6 , installed 0.6.6
                                      Adapter    "web"          : 6.1.10   , installed 6.1.10
                                      Adapter    "welcome"      : 0.1.0    , installed 0.1.0
                                      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                                      Adapter    "ws"           : 2.5.8    , installed 2.5.8
                                      Objects and States
                                      Objects:        668
                                      States:         351
                                      Pending Updates: 16
                                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       42700      9269/iobroker.js-co
                                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       42715      9269/iobroker.js-co
                                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13698      709/sshd: /usr/sbin
                                      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       51994      10190/io.jarvis.0
                                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       46305      9445/io.admin.0
                                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       50780      10124/io.web.0
                                      tcp6       0      0 :::22                   :::*                    LISTEN      0          13700      709/sshd: /usr/sbin
                                      tcp6       0      0 :::80                   :::*                    LISTEN      1001       50995      10429/io.welcome.0
                                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        13548      495/avahi-daemon: r
                                      udp        0      0 0.0.0.0:5678            0.0.0.0:*                           1001       50670      9396/io.discovery.0
                                      udp        0      0 0.0.0.0:32949           0.0.0.0:*                           104        13550      495/avahi-daemon: r
                                      udp6       0      0 fe80::e0bd:e062:255:546 :::*                                0          14849      598/NetworkManager
                                      udp6       0      0 fe80::59d9:79d7:153:546 :::*                                0          13730      598/NetworkManager
                                      udp6       0      0 :::5353                 :::*                                104        13549      495/avahi-daemon: r
                                      udp6       0      0 :::51658                :::*                                104        13551      495/avahi-daemon: r
                                      2024-01-28 18:31:43.989  - error: host.raspberrypi iobroker host.raspberrypi Cannot install iobroker.opi@0.1.2: 1
                                      2024-01-28 18:31:45.025  - info: host.raspberrypi iobroker exit 25
                                      2024-01-28 18:36:52.680  - info: admin.0 (9445) <== Disconnect system.user.admin from ::ffff:192.168.2.116 admin
                                      2024-01-28 18:36:54.372  - info: admin.0 (9445) ==> Connected system.user.admin from ::ffff:192.168.2.116
                                      2024-01-28 18:37:14.246  - info: host.raspberrypi iobroker del trashschedule.0
                                      2024-01-28 18:37:16.428  - info: host.raspberrypi iobroker Delete instance "trashschedule.0"
                                      2024-01-28 18:37:16.478  - info: host.raspberrypi iobroker host.raspberrypi Counted 1 instances of trashschedule.0
                                      2024-01-28 18:37:16.498  - info: host.raspberrypi iobroker host.raspberrypi Counted 9 channels of trashschedule.0
                                      2024-01-28 18:37:16.512  - info: host.raspberrypi iobroker host.raspberrypi Counted 59 states of trashschedule.0
                                      2024-01-28 18:37:16.523  - info: host.raspberrypi iobroker host.raspberrypi Counted 15 states of system.adapter.trashschedule.0
                                      2024-01-28 18:37:16.530  - info: host.raspberrypi iobroker host.raspberrypi Counted 11 states (io.trashschedule.0.*) from states
                                      2024-01-28 18:37:16.544  - info: host.raspberrypi iobroker host.raspberrypi Counted 6 states (system.adapter.trashschedule.0.*) from states
                                      2024-01-28 18:37:17.092  - info: host.raspberrypi iobroker host.raspberrypi Counted 1 objects of trashschedule.0
                                      2024-01-28 18:37:17.094  - info: host.raspberrypi iobroker host.raspberrypi Deleting 85 object(s).
                                      2024-01-28 18:37:17.429  - info: host.raspberrypi iobroker host.raspberrypi Deleting 17 state(s).
                                      2024-01-28 18:37:17.475  - info: vis-2.0 (11069) config.js changed. Upload.
                                      2024-01-28 18:37:17.489  - info: host.raspberrypi object deleted system.adapter.trashschedule.0
                                      2024-01-28 18:37:18.601  - info: host.raspberrypi iobroker exit 0
                                      2024-01-28 18:37:53.039  - error: host.raspberrypi iobroker npm ERR! code ETIMEDOUTnpm ERR! syscall connectnpm ERR! errno ETIMEDOUTnpm ERR! network request to https://registry.npmjs.org/iobroker.javascript failed, reason: connect ETIMEDOUT 2606:4700::6810:1f22:443npm ERR! network This is a problem related to network connectivity.npm ERR! network In most cases you are behind a proxy or have bad network settings.npm ERR! network npm ERR! network If you are behind a proxy, please make sure that thenpm ERR! network 'proxy' config is set properly.  See: 'npm help config'npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-28T17_30_09_040Z-debug-0.loghost.raspberrypi Cannot install iobroker.javascript@7.1.6: 1
                                      2024-01-28 18:37:54.704  - info: host.raspberrypi iobroker exit 25
                                      2024-01-28 18:38:37.503  - info: host.raspberrypi iobroker add javascript --host raspberrypi
                                      2024-01-28 18:38:41.121  - info: host.raspberrypi iobroker NPM version: 10.2.3
                                      2024-01-28 18:38:41.124  - info: host.raspberrypi iobroker Installing iobroker.javascript@7.1.6... (System call)
                                      2024-01-28 18:41:26.419  - error: host.raspberrypi cannot call visUtils: Not exists
                                      2024-01-28 18:41:26.426  - error: host.raspberrypi cannot call visUtils: Not exists
                                      also mache ich jetzt nun die 5. neu installation und überspringe diesen Adapter in der hoffnung dass das System dann mal endlich läuft...
                                      MFG Schweizer
                                      Homoran Glasfaser 2 Replies Last reply Reply Quote 0
                                        Homoran Global Moderator Administrators @Schweiz last edited by
                                        Ist der wirklich entfernt?
                                        oder nur die Instanz davon?
                                          Schweiz @Homoran last edited by Schweiz
                                          na gott sei dank, ich habe die Instanz sowie den Adapter entfernt...
                                          Neustart geamacht und es läuft wider...
                                          MFG Schweizer
                                            MFG Schweizer
                                            aber ich verstehe es nicht warum der trashschedule das schuld sein soll.
                                            nichtdass es der fehlende Neustart nach irgendeiner Aktion war.
                                            Ansonsten müssest du ein Issue beim Adapter anlegen, damit @haus-automatisierung sich das mal ansehen kann.
                                            4093
