    4. Jarvis Adapter lässt sich nicht Installieren
      Schweiz @Schweiz last edited by Schweiz
      Skript v.2023-10-10
      *** BASE SYSTEM ***
       Static hostname: raspberrypi
             Icon name: computer
                Kernel: Linux 6.1.0-rpi7-rpi-v8
          Architecture: arm64
      Model           : Raspberry Pi 4 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : arm64
      Systemuptime and Load:
       23:27:01 up 13 min,  3 users,  load average: 0.13, 0.29, 0.33
      CPU threads: 4
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** Time and Time Zones ***
                     Local time: Sat 2024-01-27 23:27:01 CET
                 Universal time: Sat 2024-01-27 22:27:01 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** User and Groups ***
      john
      /home/john
      john adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      Boot Target:    multi-user.target
      *** MEMORY ***
      Mem:            4.0G        461M        2.9G        1.3M        704M        3.5G
      Swap:           104M          0B        104M
      Total:          4.1G        461M        3.0G
               3793 M total memory
                440 M used memory
                470 M active memory
                420 M inactive memory
               2757 M free memory
                 62 M buffer memory
                609 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      Raspberry only:
      oom events: 0
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** FILESYSTEM ***
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     380M  1.2M  379M   1% /run
      /dev/mmcblk0p2 ext4       59G  3.8G   52G   7% /
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      /dev/mmcblk0p1 vfat      510M   62M  449M  13% /boot/firmware
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Sat Jan 27 23:13:01 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:29:88:49 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=620a9d97-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Sat Jan 27 23:13:03 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Sat Jan 27 23:13:05 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      TARGET           SOURCE         FSTYPE OPTIONS
      /                /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.3G    /var/
      837M    /var/lib
      662M    /var/lib/piVCCU3
      604M    /var/lib/piVCCU3/rootfs
      279M    /var/lib/piVCCU3/rootfs/opt
      Archived and active journals take up 109.1M in the file system.
      /opt/iobroker/backups:
      34M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      297M    /opt/iobroker/iobroker-data/
      185M    /opt/iobroker/iobroker-data/files
      86M     /opt/iobroker/iobroker-data/backup-objects
      67M     /opt/iobroker/iobroker-data/files/javascript.admin
      49M     /opt/iobroker/iobroker-data/files/telegram-menu.admin
      36M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js.map
      21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
      18M     /opt/iobroker/iobroker-data/objects.jsonl
      13M     /opt/iobroker/iobroker-data/files/telegram-menu.admin/build/index.js
      8.8M    /opt/iobroker/iobroker-data/states.jsonl
      USB-Devices by-id:
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.19.0
      /usr/bin/node           v18.19.0
      /usr/bin/npm            10.2.3
      /usr/bin/npx            10.2.3
      /usr/bin/corepack       0.22.0
      nodejs:
        Installed: 18.19.0-1nodesource1
        Candidate: 18.19.0-1nodesource1
        Version table:
           18.19.0+dfsg-6~deb12u1 500
       *** 18.19.0-1nodesource1 1001
              100 /var/lib/dpkg/status
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0+dfsg1-1 500
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree:
      *** ioBroker-Installation ***
      ioBroker Status
      node:internal/modules/cjs/loader:1137
        throw err;
      Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
          at Module._resolveFilename (node:internal/modules/cjs/loader:1134:15)
          at Module._load (node:internal/modules/cjs/loader:975:27)
          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:128:12)
          at node:internal/main/run_main_module:28:49 {
        code: 'MODULE_NOT_FOUND',
        requireStack: []
      Node.js v18.19.0
      Core adapters versions
        throw err;
        requireStack: []
      Node.js v18.19.0
      js-controller:
        throw err;
        requireStack: []
      Node.js v18.19.0
      admin:
        throw err;
        requireStack: []
      Node.js v18.19.0
      javascript:
      Adapters from github:   0
      Adapter State
        throw err;
        requireStack: []
      Node.js v18.19.0
        throw err;
        requireStack: []
      Node.js v18.19.0
      ioBroker-Repositories
        throw err;
        requireStack: []
      Node.js v18.19.0
      Installed ioBroker-Instances
        throw err;
        requireStack: []
      Node.js v18.19.0
      Objects and States
      Objects:        0
      States:         0
      Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:5 https://apt.pivccu.de/piVCCU stable InRelease
      Hit:6 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 10
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15874      1007/sshd: /usr/sbi
      tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          14834      1045/dnsmasq
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15876      1007/sshd: /usr/sbi
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        12824      510/avahi-daemon: r
      udp        0      0 0.0.0.0:50638           0.0.0.0:*                           104        12826      510/avahi-daemon: r
      udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          14833      1045/dnsmasq
      udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          14830      1045/dnsmasq
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12972      900/dhclient
      udp6       0      0 :::5353                 :::*                                104        12825      510/avahi-daemon: r
      udp6       0      0 :::40707                :::*                                104        12827      510/avahi-daemon: r
      2024-01-27 23:15:10.525  - info: host.raspberrypi stopInstance system.adapter.viessmannapi.0 send kill signal
      2024-01-27 23:15:10.631  - info: hm-rega.0 (2002) terminating
      2024-01-27 23:15:10.635  - info: hm-rega.0 (2002) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-01-27 23:15:10.655  - info: web.0 (2499) terminated http server on port 8082
      2024-01-27 23:15:10.656  - info: web.0 (2499) terminating
      2024-01-27 23:15:10.659  - info: web.0 (2499) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-01-27 23:15:10.731  - info: javascript.0 (1832) terminating
      2024-01-27 23:15:10.724  - info: telegram.0 (1703) terminating
      2024-01-27 23:15:10.729  - info: telegram.0 (1703) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-01-27 23:15:10.741  - info: hm-rega.0 (2002) terminating
      2024-01-27 23:15:10.745  - info: tr-064.0 (2027) terminating
      2024-01-27 23:15:10.765  - info: backitup.0 (2186) terminating
      2024-01-27 23:15:10.793  - info: discovery.0 (2134) terminating
      2024-01-27 23:15:10.795  - info: enigma2.0 (2264) terminating
      2024-01-27 23:15:10.797  - info: enigma2.0 (2264) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-01-27 23:15:10.806  - info: heizoel.0 (2424) terminating
      2024-01-27 23:15:10.810  - info: admin.0 (1612) terminating
      2024-01-27 23:15:10.813  - info: tankerkoenig.0 (2441) terminating
      2024-01-27 23:15:10.830  - info: worx.0 (2457) terminating
      2024-01-27 23:15:10.835  - info: weather-warnings.0 (2482) terminating
      2024-01-27 23:15:10.842  - info: web.0 (2499) terminating
      2024-01-27 23:15:10.860  - info: viessmannapi.0 (2559) terminating
      2024-01-27 23:15:10.870  - info: trashschedule.0 (2528) terminating
      2024-01-27 23:15:11.119  - info: host.raspberrypi instance system.adapter.tr-064.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-01-27 23:15:11.120  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      • Glasfaser
        Glasfaser @Glasfaser last edited by
        @Schweiz
        Hast du das gemacht !?
        @glasfaser sagte in Jarvis Adapter lässt sich nicht Installieren:
        @schweiz
        Ich habe keinen blassen Schimmer , warum der immer sich bei Dir zerschießt !
        cd /opt/iobroker
        npm cache clean --force
        sudo -H -u iobroker npm install iobroker.js-controller
        S Glasfaser 2 Replies Last reply Reply Quote 0
          Schweiz @Glasfaser last edited by
          @glasfaser
          ja, hast du ja geschrieben, beim ersten mal ging ja Alexa2 über console mit debug, da hatte ich ja hoffnung...
          soll ich nochmal machen?
          MFG Schweizer
          Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
          • Glasfaser
            Glasfaser @Schweiz last edited by
            @schweiz sagte in Jarvis Adapter lässt sich nicht Installieren:
            ja
            und danach
            sudo reboot
              Thomas Braun Most Active @Schweiz last edited by Thomas Braun
              @schweiz
              Pending Updates: 10
              sudo apt update
              sudo apt full-upgrade
              sudo reboot
              Dann weiter forschen.
                @glasfaser
                der bleibt jetzt hängen
                john@raspberrypi:~ $ cd /opt/iobroker
                john@raspberrypi:/opt/iobroker $ iob stop
                john@raspberrypi:/opt/iobroker $ npm cache clean --force
                npm WARN using --force Recommended protections disabled.
                john@raspberrypi:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
                (⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂⠂) ⠏ idealTree:iobroker: sill idealTree buildDeps
                sudo apt update
                Paketlisten werden gelesen… Fertig
                Abhängigkeitsbaum wird aufgebaut… Fertig
                Statusinformationen werden eingelesen… Fertig
                Paketaktualisierung (Upgrade) wird berechnet… Fertig
                Die folgenden Pakete werden aktualisiert (Upgrade):
                  firmware-atheros firmware-brcm80211 firmware-libertas firmware-misc-nonfree
                  firmware-realtek kms++-utils libkms++0 raspberrypi-net-mods raspi-config
                  rpi-eeprom
                10 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                Es müssen 73,3 MB an Archiven heruntergeladen werden.
                Nach dieser Operation werden 9.447 kB Plattenplatz zusätzlich benutzt.
                Möchten Sie fortfahren? [J/n] j
                Holen:1 http://archive.raspberrypi.com/debian bookworm/main arm64 firmware-ather        os all 1:20230210-5+rpt3 [16,8 MB]
                Holen:2 http://archive.raspberrypi.com/debian bookworm/main arm64 firmware-brcm8        0211 all 1:20230210-5+rpt3 [5.852 kB]
                Holen:3 http://archive.raspberrypi.com/debian bookworm/main arm64 firmware-liber        tas all 1:20230210-5+rpt3 [31,2 MB]
                Holen:4 http://archive.raspberrypi.com/debian bookworm/main arm64 firmware-misc-        nonfree all 1:20230210-5+rpt3 [13,0 MB]
                Holen:5 http://archive.raspberrypi.com/debian bookworm/main arm64 firmware-realt        ek all 1:20230210-5+rpt3 [1.492 kB]
                Holen:6 http://archive.raspberrypi.com/debian bookworm/main arm64 libkms++0 arm6        4 0~git20231115~065257+9ae90ce-1 [75,2 kB]
                Holen:7 http://archive.raspberrypi.com/debian bookworm/main arm64 kms++-utils ar        m64 0~git20231115~065257+9ae90ce-1 [81,9 kB]
                Holen:8 http://archive.raspberrypi.com/debian bookworm/main arm64 raspi-config a        ll 20240108 [29,7 kB]
                Holen:9 http://archive.raspberrypi.com/debian bookworm/main arm64 raspberrypi-ne        t-mods all 1.4.1 [2.180 B]
                Holen:10 http://archive.raspberrypi.com/debian bookworm/main arm64 rpi-eeprom al        l 21.1-1 [4.651 kB]
                Es wurden 73,3 MB in 28 s geholt (2.627 kB/s).
                Changelogs werden gelesen... Fertig
                (Lese Datenbank ... 109167 Dateien und Verzeichnisse sind derzeit installiert.)
                Vorbereitung zum Entpacken von .../0-firmware-atheros_1%3a20230210-5+rpt3_all.de        b ...
                Entpacken von firmware-atheros (1:20230210-5+rpt3) über (1:20230210-5+rpt2) ...
                Vorbereitung zum Entpacken von .../1-firmware-brcm80211_1%3a20230210-5+rpt3_all.        deb ...
                Entpacken von firmware-brcm80211 (1:20230210-5+rpt3) über (1:20230210-5+rpt2) ..        .
                Vorbereitung zum Entpacken von .../2-firmware-libertas_1%3a20230210-5+rpt3_all.d        eb ...
                Entpacken von firmware-libertas (1:20230210-5+rpt3) über (1:20230210-5+rpt2) ...
                Vorbereitung zum Entpacken von .../3-firmware-misc-nonfree_1%3a20230210-5+rpt3_a        ll.deb ...
                Entpacken von firmware-misc-nonfree (1:20230210-5+rpt3) über (1:20230210-5+rpt2)        ...
                Vorbereitung zum Entpacken von .../4-firmware-realtek_1%3a20230210-5+rpt3_all.de        b ...
                Entpacken von firmware-realtek (1:20230210-5+rpt3) über (1:20230210-5+rpt2) ...
                Vorbereitung zum Entpacken von .../5-libkms++0_0~git20231115~065257+9ae90ce-1_ar        m64.deb ...
                Entpacken von libkms++0:arm64 (0~git20231115~065257+9ae90ce-1) über (0~git202309        30~162059+b91affd-1) ...
                Vorbereitung zum Entpacken von .../6-kms++-utils_0~git20231115~065257+9ae90ce-1_        arm64.deb ...
                Entpacken von kms++-utils (0~git20231115~065257+9ae90ce-1) über (0~git20230930~1        62059+b91affd-1) ...
                Vorbereitung zum Entpacken von .../7-raspi-config_20240108_all.deb ...
                Entpacken von raspi-config (20240108) über (20231216) ...
                Vorbereitung zum Entpacken von .../8-raspberrypi-net-mods_1.4.1_all.deb ...
                Entpacken von raspberrypi-net-mods (1.4.1) über (1.4.0) ...
                Vorbereitung zum Entpacken von .../9-rpi-eeprom_21.1-1_all.deb ...
                Entpacken von rpi-eeprom (21.1-1) über (20.5-1) ...
                firmware-atheros (1:20230210-5+rpt3) wird eingerichtet ...
                firmware-misc-nonfree (1:20230210-5+rpt3) wird eingerichtet ...
                libkms++0:arm64 (0~git20231115~065257+9ae90ce-1) wird eingerichtet ...
                firmware-brcm80211 (1:20230210-5+rpt3) wird eingerichtet ...
                firmware-realtek (1:20230210-5+rpt3) wird eingerichtet ...
                firmware-libertas (1:20230210-5+rpt3) wird eingerichtet ...
                rpi-eeprom (21.1-1) wird eingerichtet ...
                raspi-config (20240108) wird eingerichtet ...
                kms++-utils (0~git20231115~065257+9ae90ce-1) wird eingerichtet ...
                raspberrypi-net-mods (1.4.1) wird eingerichtet ...
                Neue Version der Konfigurationsdatei /etc/profile.d/wifi-check.sh wird installie        rt ...
                Trigger für man-db (2.11.2-2) werden verarbeitet ...
                Trigger für libc-bin (2.36-9+rpt2+deb12u3) werden verarbeitet ...
                Trigger für initramfs-tools (0.142) werden verarbeitet ...
                update-initramfs: Generating /boot/initrd.img-6.1.0-rpi7-rpi-v8
                update-initramfs: Generating /boot/initrd.img-6.1.0-rpi7-rpi-2712
                sudo reboot
                iob start
                iob diag
                Skript v.2023-10-10
                *** BASE SYSTEM ***
                       Icon name: computer
                    Architecture: arm64
                Docker          : false
                Kernel          : aarch64
                Userland        : arm64
                 23:42:03 up 3 min,  2 users,  load average: 0.46, 0.30, 0.12
                CPU threads: 4
                Current issues:
                               Local time: Sat 2024-01-27 23:42:03 CET
                           Universal time: Sat 2024-01-27 22:42:03 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                john
                /home/john
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            4.0G        417M        3.4G        1.3M        271M        3.6G
                Swap:           104M          0B        104M
                Total:          4.1G        417M        3.5G
                         3793 M total memory
                          398 M used memory
                          418 M active memory
                           79 M inactive memory
                         3203 M free memory
                           16 M buffer memory
                          242 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                Raspberry only:
                oom events: 0
                *** FILESYSTEM ***
                [Sat Jan 27 23:38:57 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:29:88:49 vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty        1 root=PARTUUID=620a9d97-02 rootfstype=ext4 fsck.repair=yes rootwait
                [Sat Jan 27 23:39:00 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
                [Sat Jan 27 23:39:02 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepag        e=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                /var:
                1.3G    /var/
                837M    /var/lib
                Archived and active journals take up 117.1M in the file system.
                USB-Devices by-id:
                /usr/bin/npm            10.2.3
                /usr/bin/npx            10.2.3
                nodejs:
                  Version table:
                     18.13.0+dfsg1-1 500
                Errors in npm tree:
                ioBroker Status
                  throw err;
                  requireStack: []
                Node.js v18.19.0
                  throw err;
                  requireStack: []
                Node.js v18.19.0
                js-controller:
                  throw err;
                  requireStack: []
                Node.js v18.19.0
                admin:
                  throw err;
                  requireStack: []
                Node.js v18.19.0
                javascript:
                Adapter State
                  throw err;
                  requireStack: []
                Node.js v18.19.0
                  throw err;
                  requireStack: []
                Node.js v18.19.0
                  throw err;
                  requireStack: []
                Node.js v18.19.0
                  throw err;
                  requireStack: []
                Node.js v18.19.0
                Objects and States
                Objects:        0
                States:         0
                Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
                Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
                Pending Updates: 0
                tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          16548      1039/dnsmasq
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15964      994/sshd: /usr/sbin
                tcp6       0      0 :::22                   :::*                    LISTEN      0          15966      994/sshd: /usr/sbin
                udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          16547      1039/dnsmasq
                udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          16544      1039/dnsmasq
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          647        890/dhclient
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        13219      512/avahi-daemon: r
                udp        0      0 0.0.0.0:38913           0.0.0.0:*                           104        13221      512/avahi-daemon: r
                udp6       0      0 :::41539                :::*                                104        13222      512/avahi-daemon: r
                udp6       0      0 :::5353                 :::*                                104        13220      512/avahi-daemon: r
                CCU geht IOB nicht...
                • Glasfaser
                  @Schweiz
                  Gehe mal eine Version runter
                  sudo -H -u iobroker npm install iobroker.js-controller@5.0.16
                    geht nicht, klemmt auch am anfang...
                    MFG Schweizer
                    • Glasfaser
                      Habe ich mir gedacht ... da klemmt eher dein Netzwerk
                        @glasfaser
                        ich habe ja die ganze zeit installiert, und es hat alles funktioniert... bis dann plötzlich die Adapter sich nicht Installieren lassen haben...
                        IOB und CCU haben tadelos funktioniert und mir auch per Telegram und Enigma nachrichten gesendet...
                        MFG Schweizer
                          CCU läuft weiter hin, nur IOB nicht
                          MFG Schweizer
                            wo speichert der BackupAdapter auf der Karte das Backup?
                            Dann zieht ich das morgen runter und Insatlliere nochmal...
                            vorher Teste ich ob ich Adapter installieren kann...
                            geht ja nicht weiter... sonst besauf mich...
                            MFG Schweizer
                            • Glasfaser
                                @glasfaser
                                ok, danke... erst mal... eine gute n8
                                MFG Schweizer
                                  Also gut...
                                  ich denke ich kann es nun eingrenzen...
                                  Also das erste mal habe ich die Adapter alphabetisch installiert von A-Z dabei war Trashschedule mehr oder weiger einer der letzten Adapter war welche ich Installiert hatte. Der Jarvis war dann der letzte welchen ich Installieren wollte aber nicht ging... Der fehler liegt hier ganz offensichtlich im Trashschedule, da ich nun von Z-A installiert habe. Jetzt habe ich ich den Trashschedule installiert und es geht wider nix, auch nicht nach entfernen des Adapters...
                                  Skript v.2023-10-10
                                  *** BASE SYSTEM ***
                                         Icon name: computer
                                      Architecture: arm64
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : arm64
                                   18:40:41 up  2:09,  2 users,  load average: 0.29, 0.30, 0.34
                                  CPU threads: 4
                                  Current issues:
                                                 Local time: Sun 2024-01-28 18:40:41 CET
                                             Universal time: Sun 2024-01-28 17:40:41 UTC
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  john
                                  /home/john
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Mem:            4.0G        1.1G        1.2G        1.2M        1.8G        2.9G
                                  Swap:           104M          0B        104M
                                  Total:          4.1G        1.1G        1.3G
                                           3793 M total memory
                                           1006 M used memory
                                           1081 M active memory
                                           1295 M inactive memory
                                           1167 M free memory
                                             82 M buffer memory
                                           1613 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  Raspberry only:
                                  oom events: 0
                                  *** FILESYSTEM ***
                                  /dev/mmcblk0p2 ext4       59G  3.5G   52G   7% /
                                  /dev/mmcblk0p1 vfat      510M   61M  450M  12% /boot/firmware
                                  [Sun Jan 28 16:30:54 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:29:88:49 vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty        1 root=PARTUUID=96a04be6-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ie        ee80211_regdom=DE
                                  [Sun Jan 28 16:30:57 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
                                  [Sun Jan 28 16:30:59 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                                  /var:
                                  500M    /var/
                                  203M    /var/cache
                                  198M    /var/cache/apt
                                  160M    /var/lib
                                  132M    /var/lib/apt/lists
                                  Archived and active journals take up 36.0M in the file system.
                                  4.0K    /opt/iobroker/backups/
                                  318M    /opt/iobroker/iobroker-data/
                                  310M    /opt/iobroker/iobroker-data/files
                                  155M    /opt/iobroker/iobroker-data/files/vis-2
                                  78M     /opt/iobroker/iobroker-data/files/vis-2/static
                                  77M     /opt/iobroker/iobroker-data/files/vis-2/static/js
                                  21M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.m        ap
                                  18M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e642d05b.js.map
                                  18M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.2b7aff38.js.map
                                  18M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
                                  USB-Devices by-id:
                                  USB-Sticks -  Avoid direct links to /dev/* in your adapter setups, please always        prefer the links 'by-id':
                                  /usr/bin/npm            10.2.3
                                  /usr/bin/npx            10.2.3
                                  nodejs:
                                    Version table:
                                       18.13.0+dfsg1-1 500
                                  Errors in npm tree:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  js-controller:  5.0.17
                                  admin:          6.12.0
                                  javascript:     "javascript" not found
                                  Adapter State
                                  + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : raspberrypi                              - disabled
                                    system.adapter.alexa2.0                 : alexa2                : raspberrypi                              - disabled
                                  + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                    system.adapter.daswetter.0              : daswetter             : raspberrypi                              - disabled
                                  + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
                                    system.adapter.exchangerates.0          : exchangerates         : raspberrypi                              - disabled
                                    system.adapter.ical.0                   : ical                  : raspberrypi                              - disabled
                                  + system.adapter.jarvis.0                 : jarvis                : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                    system.adapter.parcel.0                 : parcel                : raspberrypi                              - disabled
                                    system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              - disabled
                                    system.adapter.telegram-menu.0          : telegram-menu         : raspberrypi                              - disabled
                                    system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
                                    system.adapter.telegram.1               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
                                    system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
                                    system.adapter.viessmannapi.0           : viessmannapi          : raspberrypi                              - disabled
                                    system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : raspberrypi                              -  enabled
                                    system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: raspberrypi                              -  enabled
                                  + system.adapter.vis-2.0                  : vis-2                 : raspberrypi                              -  enabled
                                    system.adapter.vis-map.0                : vis-map               : raspberrypi                              -  enabled
                                    system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
                                    system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                                    system.adapter.weather-warnings.0       : weather-warnings      : raspberrypi                              - disabled
                                  + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                  + system.adapter.welcome.0                : welcome               : raspberrypi                              -  enabled, port: 80, bind: 0.0.0.0, run as: admin
                                    system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              - disabled
                                  + instance is alive
                                  Active repo(s): stable
                                  Used repository: stable
                                  Adapter    "admin"        : 6.12.0   , installed 6.12.0
                                  Adapter    "alexa-timer-vis": 0.3.0  , installed 0.3.0
                                  Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
                                  Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                                  Adapter    "daswetter"    : 3.1.13   , installed 3.1.13
                                  Adapter    "exchangerates": 0.0.14   , installed 0.0.14
                                  Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                                  Controller "js-controller": 5.0.17   , installed 5.0.17
                                  Adapter    "parcel"       : 0.0.27   , installed 0.0.27
                                  Adapter    "telegram"     : 3.0.1    , installed 3.0.1
                                  Adapter    "telegram-menu": 1.5.1    , installed 1.5.1
                                  Adapter    "trashschedule": 2.3.0    , installed 2.3.0
                                  Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
                                  Adapter    "vis-2"        : 2.9.11   , installed 2.9.11
                                  Adapter    "vis-2-widgets-gauges": 1.0.2, installed 1.0.2
                                  Adapter    "vis-2-widgets-material": 1.3.17, installed 1.3.17
                                  Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                                  Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                                  Adapter    "weather-warnings": 0.6.6 , installed 0.6.6
                                  Adapter    "web"          : 6.1.10   , installed 6.1.10
                                  Adapter    "welcome"      : 0.1.0    , installed 0.1.0
                                  Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                                  Adapter    "ws"           : 2.5.8    , installed 2.5.8
                                  Objects and States
                                  Objects:        668
                                  States:         351
                                  Pending Updates: 16
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       42700      9269/iobroker.js-co
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       42715      9269/iobroker.js-co
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13698      709/sshd: /usr/sbin
                                  tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       51994      10190/io.jarvis.0
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       46305      9445/io.admin.0
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       50780      10124/io.web.0
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          13700      709/sshd: /usr/sbin
                                  tcp6       0      0 :::80                   :::*                    LISTEN      1001       50995      10429/io.welcome.0
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        13548      495/avahi-daemon: r
                                  udp        0      0 0.0.0.0:5678            0.0.0.0:*                           1001       50670      9396/io.discovery.0
                                  udp        0      0 0.0.0.0:32949           0.0.0.0:*                           104        13550      495/avahi-daemon: r
                                  udp6       0      0 fe80::e0bd:e062:255:546 :::*                                0          14849      598/NetworkManager
                                  udp6       0      0 fe80::59d9:79d7:153:546 :::*                                0          13730      598/NetworkManager
                                  udp6       0      0 :::5353                 :::*                                104        13549      495/avahi-daemon: r
                                  udp6       0      0 :::51658                :::*                                104        13551      495/avahi-daemon: r
                                  2024-01-28 18:31:43.989  - error: host.raspberrypi iobroker host.raspberrypi Cannot install iobroker.opi@0.1.2: 1
                                  2024-01-28 18:31:45.025  - info: host.raspberrypi iobroker exit 25
                                  2024-01-28 18:36:52.680  - info: admin.0 (9445) <== Disconnect system.user.admin from ::ffff:192.168.2.116 admin
                                  2024-01-28 18:36:54.372  - info: admin.0 (9445) ==> Connected system.user.admin from ::ffff:192.168.2.116
                                  2024-01-28 18:37:14.246  - info: host.raspberrypi iobroker del trashschedule.0
                                  2024-01-28 18:37:16.428  - info: host.raspberrypi iobroker Delete instance "trashschedule.0"
                                  2024-01-28 18:37:16.478  - info: host.raspberrypi iobroker host.raspberrypi Counted 1 instances of trashschedule.0
                                  2024-01-28 18:37:16.498  - info: host.raspberrypi iobroker host.raspberrypi Counted 9 channels of trashschedule.0
                                  2024-01-28 18:37:16.512  - info: host.raspberrypi iobroker host.raspberrypi Counted 59 states of trashschedule.0
                                  2024-01-28 18:37:16.523  - info: host.raspberrypi iobroker host.raspberrypi Counted 15 states of system.adapter.trashschedule.0
                                  2024-01-28 18:37:16.530  - info: host.raspberrypi iobroker host.raspberrypi Counted 11 states (io.trashschedule.0.*) from states
                                  2024-01-28 18:37:16.544  - info: host.raspberrypi iobroker host.raspberrypi Counted 6 states (system.adapter.trashschedule.0.*) from states
                                  2024-01-28 18:37:17.092  - info: host.raspberrypi iobroker host.raspberrypi Counted 1 objects of trashschedule.0
                                  2024-01-28 18:37:17.094  - info: host.raspberrypi iobroker host.raspberrypi Deleting 85 object(s).
                                  2024-01-28 18:37:17.429  - info: host.raspberrypi iobroker host.raspberrypi Deleting 17 state(s).
                                  2024-01-28 18:37:17.475  - info: vis-2.0 (11069) config.js changed. Upload.
                                  2024-01-28 18:37:17.489  - info: host.raspberrypi object deleted system.adapter.trashschedule.0
                                  2024-01-28 18:37:18.601  - info: host.raspberrypi iobroker exit 0
                                  2024-01-28 18:37:53.039  - error: host.raspberrypi iobroker npm ERR! code ETIMEDOUTnpm ERR! syscall connectnpm ERR! errno ETIMEDOUTnpm ERR! network request to https://registry.npmjs.org/iobroker.javascript failed, reason: connect ETIMEDOUT 2606:4700::6810:1f22:443npm ERR! network This is a problem related to network connectivity.npm ERR! network In most cases you are behind a proxy or have bad network settings.npm ERR! network npm ERR! network If you are behind a proxy, please make sure that thenpm ERR! network 'proxy' config is set properly.  See: 'npm help config'npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2024-01-28T17_30_09_040Z-debug-0.loghost.raspberrypi Cannot install iobroker.javascript@7.1.6: 1
                                  2024-01-28 18:37:54.704  - info: host.raspberrypi iobroker exit 25
                                  2024-01-28 18:38:37.503  - info: host.raspberrypi iobroker add javascript --host raspberrypi
                                  2024-01-28 18:38:41.121  - info: host.raspberrypi iobroker NPM version: 10.2.3
                                  2024-01-28 18:38:41.124  - info: host.raspberrypi iobroker Installing iobroker.javascript@7.1.6... (System call)
                                  2024-01-28 18:41:26.419  - error: host.raspberrypi cannot call visUtils: Not exists
                                  2024-01-28 18:41:26.426  - error: host.raspberrypi cannot call visUtils: Not exists
                                  also mache ich jetzt nun die 5. neu installation und überspringe diesen Adapter in der hoffnung dass das System dann mal endlich läuft...
                                  MFG Schweizer
                                  Homoran Glasfaser 2 Replies Last reply Reply Quote 0
                                    Homoran Global Moderator Administrators @Schweiz last edited by
                                    Ist der wirklich entfernt?
                                    oder nur die Instanz davon?
                                      Schweiz @Homoran last edited by Schweiz
                                      na gott sei dank, ich habe die Instanz sowie den Adapter entfernt...
                                      Neustart geamacht und es läuft wider...
                                      MFG Schweizer
                                        MFG Schweizer
                                        aber ich verstehe es nicht warum der trashschedule das schuld sein soll.
                                        nichtdass es der fehlende Neustart nach irgendeiner Aktion war.
                                        Ansonsten müssest du ein Issue beim Adapter anlegen, damit @haus-automatisierung sich das mal ansehen kann.
                                          ich will ja keinen Adapter etwas in die schuhe schieben...
                                          Nur ich habe eine ganze reihe Adapter installiert und konfiguriert, und dann möchte ich noch eine Visuallisierung und ees geht nicht... TS was der letzte, nun anders herum und schon klemmt es nach dem gleichen Adapter... ist sicherlich nur zufall...
                                          habe gesucht und aktuell kann ich keinen finden der soooo viele probleme mit Adapter installation hat wie ich, auch keins wo ich schlussfolgern kann das TS schuld sein könnte...
                                          MFG Schweizer
                                          Glasfaser 1 Reply Last reply Reply Quote 1
                                          • Glasfaser
                                            Glasfaser @Schweiz last edited by Glasfaser
                                            Das heißt nach der Installation von Trashschedule soll wieder der Network Error kommen !?
                                            ( Ich finde dazu keinen Zusammenhang , das es an diesem Adapter liegt )
                                            oder auch das der JS-Controller sich zerschießt !?
                                            Und das wundert mich in deinem Log :
                                            ich finde diesen Adapter in keinem Log / Ausgaben von dir !
                                            4111
