    4. Diverse kleine Adapter Fehler
    • haselchen
      haselchen Most Active @Radix75 last edited by
      @radix75
      Was heisst gelöst?
      Du hast zig 1er Instanzen.
      Ich denke da ist schon was schiefgelaufen bzw. läuft schief.
        Radix75 @Thomas Braun last edited by
        @thomas-braun ```
        Skript v.2023-10-10
        *** BASE SYSTEM ***
        ^[[3~ Static hostname: raspberrypi5
               Icon name: computer
                  Kernel: Linux 6.1.0-rpi7-rpi-2712
            Architecture: arm64
        Model		: Raspberry Pi 5 Model B Rev 1.0
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : arm64
        Systemuptime and Load:
         13:51:03 up  2:38,  3 users,  load average: 1.46, 1.34, 1.28
        CPU threads: 4
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** Time and Time Zones ***
                       Local time: Sun 2024-01-28 13:51:03 CET
                   Universal time: Sun 2024-01-28 12:51:03 UTC
                         RTC time: Sat 1970-01-03 19:52:47
                      NTP service: active
                  RTC in local TZ: no
        *** User and Groups ***
        Radix1975
        /home/Radix1975
        Radix1975 adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server: 	false
        Desktop: 	LXDE-pi-wayfire
        Terminal: 	wayland
        Boot Target: 	graphical.target
        *** MEMORY ***
        Mem:            8.4G        3.6G        2.9G         77M        2.2G        4.9G
        Swap:           104M          0B        104M
        Total:          8.5G        3.6G        3.0G
                 8049 M total memory
                 3393 M used memory
                 3505 M active memory
                 1134 M inactive memory
                 2763 M free memory
                  200 M buffer memory
                 1861 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        Raspberry only:
        vc_gencmd_read_response returned -1
        error=1 error_msg="Command not registered"
        *** FAILED SERVICES ***
          UNIT                  LOAD   ACTIVE SUB    DESCRIPTION
        * bthelper@hci0.service loaded failed failed Raspberry Pi bluetooth helper
        * deconz.service        loaded failed failed deCONZ: ZigBee gateway -- REST API
        * networking.service    loaded failed failed Raise network interfaces
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        3 loaded units listed.
        *** FILESYSTEM ***
        udev           devtmpfs  3.8G     0  3.8G   0% /dev
        tmpfs          tmpfs     805M  6.3M  799M   1% /run
        /dev/mmcblk0p2 ext4      234G   19G  203G   9% /
        tmpfs          tmpfs     4.0G  608K  4.0G   1% /dev/shm
        tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
        /dev/mmcblk0p1 vfat      511M   74M  438M  15% /boot/firmware
        tmpfs          tmpfs     805M  176K  805M   1% /run/user/1000
        [Sun Jan 28 11:12:17 2024] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=D8:3A:DD:BC:98:3F vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=749f5341-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
        [Sun Jan 28 11:12:18 2024] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Sun Jan 28 11:12:19 2024] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        TARGET               SOURCE         FSTYPE      OPTIONS
        /                    /dev/mmcblk0p2 ext4        rw,noatime
        |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
        `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        2.8G	/var/
        983M	/var/cache
        966M	/var/cache/apt
        944M	/var/lib
        853M	/var/cache/apt/archives
        Archived and active journals take up 769.5M in the file system.
        /opt/iobroker/backups:
        670M	/opt/iobroker/backups/
        4.0K	/opt/iobroker/backups/redistmp
        /opt/iobroker/iobroker-data:
        743M	/opt/iobroker/iobroker-data/
        683M	/opt/iobroker/iobroker-data/files
        89M	/opt/iobroker/iobroker-data/files/echarts.admin
        78M	/opt/iobroker/iobroker-data/files/icons-open-icon-library-png
        67M	/opt/iobroker/iobroker-data/files/minuvis
        33M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.1797d034.js.map
        24M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.2b7495c2.js.map
        24M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.2b7495c2.js.map
        23M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.245b61c0.js.map
        21M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.aaea95f8.js.map
        USB-Devices by-id:
        /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE1962617-if00
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v18.19.0
        /usr/bin/node 		v18.19.0
        /usr/bin/npm 		9.2.0
        /usr/bin/npx 		9.2.0
        /home/iobroker/.diag.sh: line 281: corepack: command not found
        *** nodejs is NOT correctly installed ***
        nodejs:
          Installed: 18.19.0+dfsg-6~deb12u1
          Candidate: 18.19.0+dfsg-6~deb12u1
          Version table:
         *** 18.19.0+dfsg-6~deb12u1 500
                100 /var/lib/dpkg/status
             18.19.0-1nodesource1 500
             18.18.2-1nodesource1 500
             18.18.1-1nodesource1 500
             18.18.0-1nodesource1 500
             18.17.1-1nodesource1 500
             18.17.0-1nodesource1 500
             18.16.1-1nodesource1 500
             18.16.0-1nodesource1 500
             18.15.0-1nodesource1 500
             18.14.2-1nodesource1 500
             18.14.1-1nodesource1 500
             18.14.0-1nodesource1 500
             18.13.0+dfsg1-1 500
             18.13.0-1nodesource1 500
             18.12.0-1nodesource1 500
             18.11.0-1nodesource1 500
             18.10.0-1nodesource1 500
             18.9.1-1nodesource1 500
             18.9.0-1nodesource1 500
             18.8.0-1nodesource1 500
             18.7.0-1nodesource1 500
             18.6.0-1nodesource1 500
             18.5.0-1nodesource1 500
             18.4.0-1nodesource1 500
             18.3.0-1nodesource1 500
             18.2.0-1nodesource1 500
             18.1.0-1nodesource1 500
             18.0.0-1nodesource1 500
        No problems detected
        Errors in npm tree:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Core adapters versions
        js-controller: 	5.0.17
        admin: 		6.12.0
        javascript: 	7.1.6
        Adapters from github: 	0
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspberrypi5                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.admin.1                  : admin                 : raspberrypi5                             -  enabled, port: 8085, bind: 192.168.1.226, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : raspberrypi5                             -  enabled
        + system.adapter.backitup.0               : backitup              : raspberrypi5                             -  enabled
        + system.adapter.chromecast.0             : chromecast            : raspberrypi5                             -  enabled
        + system.adapter.chromecast.1             : chromecast            : raspberrypi5                             -  enabled
        + system.adapter.cloud.0                  : cloud                 : raspberrypi5                             -  enabled
        + system.adapter.daikin-cloud.0           : daikin-cloud          : raspberrypi5                             -  enabled
          system.adapter.deconz.1                 : deconz                : raspberrypi5                             - disabled, port: 80
        + system.adapter.discovery.0              : discovery             : raspberrypi5                             -  enabled
        + system.adapter.echarts.0                : echarts               : raspberrypi5                             -  enabled
          system.adapter.flot.0                   : flot                  : raspberrypi5                             - disabled
        + system.adapter.fritzdect.0              : fritzdect             : raspberrypi5                             -  enabled
        + system.adapter.history.0                : history               : raspberrypi5                             -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : raspberrypi5                             -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi5                             -  enabled, port: 12010
        + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi5                             -  enabled, port: 12001
        + system.adapter.hue.0                    : hue                   : raspberrypi5                             -  enabled, port: 80
          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi5                             - disabled
          system.adapter.icons-eclipse-smarthome-classic.0: icons-eclipse-smarthome-classic: raspberrypi5                             - disabled
          system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi5                             - disabled
          system.adapter.icons-freepic.0          : icons-freepic         : raspberrypi5                             - disabled
          system.adapter.icons-icons8.0           : icons-icons8          : raspberrypi5                             - disabled
          system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi5                             - disabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi5                             - disabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi5                             - disabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi5                             - disabled
          system.adapter.icons-smarthome.0        : icons-smarthome       : raspberrypi5                             - disabled
          system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi5                             - disabled
        + system.adapter.iot.0                    : iot                   : raspberrypi5                             -  enabled
        + system.adapter.iqontrol.0               : iqontrol              : raspberrypi5                             -  enabled
        + system.adapter.jarvis.0                 : jarvis                : raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.javascript.0             : javascript            : raspberrypi5                             -  enabled
        + system.adapter.lovelace.0               : lovelace              : raspberrypi5                             -  enabled, port: 8091, bind: 0.0.0.0, run as: admin
          system.adapter.minuvis.0                : minuvis               : raspberrypi5                             - disabled
        + system.adapter.net-tools.0              : net-tools             : raspberrypi5                             -  enabled
        + system.adapter.onvif.0                  : onvif                 : raspberrypi5                             -  enabled
        + system.adapter.ping.0                   : ping                  : raspberrypi5                             -  enabled
        + system.adapter.solax.0                  : solax                 : raspberrypi5                             -  enabled
        + system.adapter.tr-064.0                 : tr-064                : raspberrypi5                             -  enabled
        + system.adapter.tr-064.1                 : tr-064                : raspberrypi5                             -  enabled
        + system.adapter.tr-064.2                 : tr-064                : raspberrypi5                             -  enabled
          system.adapter.vis-bars.0               : vis-bars              : raspberrypi5                             - disabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi5                             - disabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi5                             - disabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi5                             - disabled
          system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi5                             -  enabled
          system.adapter.vis-history.0            : vis-history           : raspberrypi5                             - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi5                             - disabled
          system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi5                             - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi5                             -  enabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi5                             - disabled
          system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi5                             - disabled
          system.adapter.vis-keyboard.0           : vis-keyboard          : raspberrypi5                             - disabled
          system.adapter.vis-lcars.0              : vis-lcars             : raspberrypi5                             - disabled
          system.adapter.vis-map.0                : vis-map               : raspberrypi5                             - disabled
          system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi5                             - disabled
          system.adapter.vis-material.0           : vis-material          : raspberrypi5                             - disabled
          system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi5                             - disabled
          system.adapter.vis-metro.0              : vis-metro             : raspberrypi5                             - disabled
          system.adapter.vis-players.0            : vis-players           : raspberrypi5                             - disabled
          system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi5                             - disabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi5                             - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi5                             - disabled
          system.adapter.vis-weather.0            : vis-weather           : raspberrypi5                             - disabled
          system.adapter.vis.0                    : vis                   : raspberrypi5                             -  enabled
        + system.adapter.web.0                    : web                   : raspberrypi5                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.zigbee.0                 : zigbee                : raspberrypi5                             -  enabled, port: /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE1962617-if00
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Installed ioBroker-Instances
        Used repository: stable
        Adapter    "admin"        : 6.12.0   , installed 6.12.0
        Adapter    "alexa2"       : 3.26.4   , installed 3.26.4
        Adapter    "backitup"     : 2.9.8    , installed 2.9.8
        Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
        Adapter    "daikin-cloud" : 0.3.0    , installed 0.3.0
        Adapter    "deconz"       : 1.3.23   , installed 1.3.23
        Adapter    "echarts"      : 1.7.2    , installed 1.7.2
        Adapter    "fritzdect"    : 2.5.9    , installed 2.5.9
        Adapter    "hm-rega"      : 4.0.0    , installed 4.0.0
        Adapter    "hm-rpc"       : 1.15.19  , installed 1.15.19
        Adapter    "hue"          : 3.10.2   , installed 3.10.2
        Adapter    "icons-eclipse-smarthome-classic": 1.0.0, installed 1.0.0
        Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
        Adapter    "icons-smarthome": 1.0.0  , installed 1.0.0
        Adapter    "iot"          : 2.0.11   , installed 2.0.11
        Adapter    "iqontrol"     : 2.3.0    , installed 2.3.0
        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
        Adapter    "javascript"   : 7.1.6    , installed 7.1.6
        Controller "js-controller": 5.0.17   , installed 5.0.17
        Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
        Adapter    "minuvis"      : 2.3.3    , installed 2.3.3
        Adapter    "onvif"        : 1.1.1    , installed 1.1.1
        Adapter    "solax"        : 0.8.0    , installed 0.8.0
        Adapter    "vis-icontwo"  : 1.3.0    , installed 1.3.0
        Adapter    "vis-justgage" : 2.1.0    , installed 2.1.0
        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
        Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
        Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
        Adapter    "vis-material" : 0.1.3    , installed 0.1.3
        Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
        Adapter    "web"          : 6.1.10   , installed 6.1.10
        Adapter    "ws"           : 2.5.8    , installed 2.5.8
        Adapter    "zigbee"       : 1.10.1   , installed 1.10.1
        Objects and States
        Objects: 	9022
        States: 	7052
        ^[[3~Hit:1 http://deb.debian.org/debian bookworm InRelease
        Hit:2 http://phoscon.de/apt/deconz bookworm InRelease
        Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
        Hit:4 http://deb.debian.org/debian-security bookworm-security InRelease
        Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:6 https://apt.pivccu.de/piVCCU stable InRelease
        Hit:7 https://deb.nodesource.com/node_18.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          18204      1625/dnsmasq
        tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       27620      4840/io.jarvis.0
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18630      1227/sshd: /usr/sbi
        tcp        0      0 192.168.1.65:12010      0.0.0.0:*               LISTEN      1001       29266      5027/io.hm-rpc.0
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          18637      1207/cupsd
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       20677      1208/iobroker.js-co
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       19926      1208/iobroker.js-co
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          18636      1207/cupsd
        tcp6       0      0 :::8091                 :::*                    LISTEN      1001       29905      4878/io.lovelace.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       21406      2467/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       31799      5141/io.web.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          18632      1227/sshd: /usr/sbi
        tcp6       0      0 :::5900                 :::*                    LISTEN      992        19535      1216/wayvnc
        udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          18203      1625/dnsmasq
        udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          18200      1625/dnsmasq
        udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          19718      1513/cups-browsed
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       26092      4205/io.chromecast.
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       24279      3643/io.chromecast.
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        18436      706/avahi-daemon: r
        udp        0      0 0.0.0.0:35225           0.0.0.0:*                           104        18438      706/avahi-daemon: r
        udp6       0      0 :::49052                :::*                                104        18439      706/avahi-daemon: r
        udp6       0      0 fe80::83ce:917a:6b2:546 :::*                                0          19764      922/NetworkManager
        udp6       0      0 :::5353                 :::*                                104        18437      706/avahi-daemon: r
        2024-01-28 13:49:17.317  - info: host.raspberrypi5 instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
        2024-01-28 13:49:17.318  - info: host.raspberrypi5 Restart adapter system.adapter.hm-rpc.1 because enabled
        2024-01-28 13:49:47.381  - info: host.raspberrypi5 instance system.adapter.hm-rpc.1 started with pid 51509
        2024-01-28 13:49:48.645  - info: hm-rpc.1 (51509) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.17
        2024-01-28 13:49:48.764  - info: hm-rpc.1 (51509) binrpc server is trying to listen on 192.168.1.65:12001
        2024-01-28 13:49:48.764  - info: hm-rpc.1 (51509) binrpc client is trying to connect to 192.168.1.63:2001/ with ["xmlrpc_bin://192.168.1.65:12001","raspberrypi5:hm-rpc.1:3a6875486a20cf6d1ffc37d6d5a93d7e"]
        2024-01-28 13:49:53.773  - error: hm-rpc.1 (51509) Init not possible, going to stop: response timeout
        2024-01-28 13:49:58.225  - info: solax.0 (4965) State value to set for "solax.0.data.json" has to be type "string" but received type "number"
        2024-01-28 13:50:23.773  - error: hm-rpc.1 (51509) Init not possible, going to stop: response timeout
        2024-01-28 13:50:23.775  - info: hm-rpc.1 (51509) binrpc -> 192.168.1.63:2001/ init ["xmlrpc_bin://192.168.1.65:12001",""]
        2024-01-28 13:50:24.779  - info: hm-rpc.1 (51509) terminating
        2024-01-28 13:50:24.780  - info: hm-rpc.1 (51509) Terminated (NO_ERROR): Without reason
        2024-01-28 13:50:25.334  - info: host.raspberrypi5 instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
        2024-01-28 13:50:25.334  - info: host.raspberrypi5 Restart adapter system.adapter.hm-rpc.1 because enabled
        2024-01-28 13:50:55.373  - info: host.raspberrypi5 instance system.adapter.hm-rpc.1 started with pid 51645
        2024-01-28 13:50:56.559  - info: hm-rpc.1 (51645) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.17
        2024-01-28 13:50:56.684  - info: hm-rpc.1 (51645) binrpc server is trying to listen on 192.168.1.65:12001
        2024-01-28 13:50:56.685  - info: hm-rpc.1 (51645) binrpc client is trying to connect to 192.168.1.63:2001/ with ["xmlrpc_bin://192.168.1.65:12001","raspberrypi5:hm-rpc.1:9b9a06ee17e8730a5936df99e5cdd256"]
        2024-01-28 13:51:01.692  - error: hm-rpc.1 (51645) Init not possible, going to stop: response timeout
        2024-01-28 13:51:31.694  - error: hm-rpc.1 (51645) Init not possible, going to stop: response timeout
        2024-01-28 13:51:31.695  - info: hm-rpc.1 (51645) binrpc -> 192.168.1.63:2001/ init ["xmlrpc_bin://192.168.1.65:12001",""]
        2024-01-28 13:51:32.707  - info: hm-rpc.1 (51645) terminating
        2024-01-28 13:51:32.710  - info: hm-rpc.1 (51645) Terminated (NO_ERROR): Without reason
        2024-01-28 13:51:33.269  - info: host.raspberrypi5 instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
        2024-01-28 13:51:33.269  - info: host.raspberrypi5 Restart adapter system.adapter.hm-rpc.1 because enabled
        iob diag has finished.
        Press any key for a summary
          Homoran Global Moderator Administrators @Radix75 last edited by
          @radix75 sagte in Diverse kleine Adapter Fehler:
          die läuft ja immer noch
          • haselchen
            haselchen Most Active @Homoran last edited by haselchen
            2mal Admin enabled.
            Auf mich hört ja keiner 🙂
            Deine Instanzen sind verwurschtelt....
            Und vieles andere auch 😞
            web und jarvis auf dem gleichen Port 8082....
              Thomas Braun Most Active @Radix75 last edited by
              @radix75
              https://forum.iobroker.net/topic/71461/dfsg-nodejs-eingehandelt-hier-die-korrektur
              Und schalt den Desktop aus:
              sudo systemctl set-default multi-user.target
                Radix75 @Thomas Braun last edited by Radix75
                @thomas-braun said in Diverse kleine Adapter Fehler:
                Radix1975@raspberrypi5:~ $ https://forum.iobroker.net/topic/71461/dfsg-nodejs-eingehandelt-hier-die-korrektur
                bash: https://forum.iobroker.net/topic/71461/dfsg-nodejs-eingehandelt-hier-die-korrektur: Datei oder Verzeichnis nicht gefunden
                Radix1975@raspberrypi5:~ $ echo -e "Package: nodejs\nPin: origin deb.nodesource.com\nPin-Priority: 1001" | sudo tee /etc/apt/preferences.d/nodejs.pref
                sudo apt update
                iob stop
                sudo apt remove npm
                sudo apt install nodejs=18.19.0-1nodesource1
                iob restart
                Package: nodejs
                Pin-Priority: 1001
                OK:1 http://deb.debian.org/debian bookworm InRelease
                OK:2 http://deb.debian.org/debian-security bookworm-security InRelease
                OK:3 http://phoscon.de/apt/deconz bookworm InRelease
                OK:4 http://deb.debian.org/debian bookworm-updates InRelease
                OK:5 http://archive.raspberrypi.com/debian bookworm InRelease
                OK:6 https://apt.pivccu.de/piVCCU stable InRelease
                OK:7 https://deb.nodesource.com/node_18.x nodistro InRelease
                Paketlisten werden gelesen… Fertig
                Abhängigkeitsbaum wird aufgebaut… Fertig
                Statusinformationen werden eingelesen… Fertig
                Alle Pakete sind aktuell.
                Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                  eslint gyp handlebars libjs-async libjs-events libjs-inherits
                  libjs-is-typedarray libjs-prettify libjs-regenerate libjs-source-map
                  libjs-sprintf-js libjs-typedarray-to-buffer libjs-util libnode-dev
                  libuv1-dev node-abbrev node-agent-base node-ajv node-ajv-keywords
                  node-ampproject-remapping node-ansi-escapes node-ansi-regex node-ansi-styles
                  node-anymatch node-aproba node-archy node-are-we-there-yet node-argparse
                  node-arrify node-assert node-async node-async-each
                  node-babel-helper-define-polyfill-provider
                  node-babel-plugin-add-module-exports node-babel-plugin-lodash
                  node-babel-plugin-polyfill-corejs2 node-babel-plugin-polyfill-corejs3
                  node-babel-plugin-polyfill-regenerator node-babel7 node-babel7-runtime
                  node-balanced-match node-base64-js node-binary-extensions
                  node-brace-expansion node-braces node-browserslist node-builtins
                  node-cacache node-camelcase node-caniuse-lite node-chalk node-chokidar
                  node-chownr node-chrome-trace-event node-ci-info node-cli-table node-cliui
                  node-clone node-clone-deep node-color-convert node-color-name node-colors
                  node-columnify node-commander node-commondir node-concat-stream
                  node-console-control-strings node-convert-source-map node-copy-concurrently
                  node-core-js node-core-js-compat node-core-js-pure node-core-util-is
                  node-css-loader node-css-selector-tokenizer node-data-uri-to-buffer
                  node-debbundle-es-to-primitive node-debug node-decamelize
                  node-decompress-response node-deep-equal node-deep-is node-defaults
                  node-define-properties node-defined node-del node-delegates node-depd
                  node-diff node-doctrine node-electron-to-chromium node-encoding
                  node-end-of-stream node-enhanced-resolve node-err-code node-errno
                  node-error-ex node-es-abstract node-es-module-lexer node-es6-error
                  node-escape-string-regexp node-escodegen node-eslint-scope node-eslint-utils
                  node-eslint-visitor-keys node-espree node-esprima node-esquery
                  node-esrecurse node-estraverse node-esutils node-events node-fancy-log
                  node-fast-deep-equal node-fast-levenshtein node-fetch node-file-entry-cache
                  node-fill-range node-find-cache-dir node-find-up node-flat-cache
                  node-flatted node-for-in node-for-own node-foreground-child
                  node-fs-readdir-recursive node-fs-write-stream-atomic node-fs.realpath
                  node-function-bind node-functional-red-black-tree node-gauge
                  node-get-caller-file node-get-stream node-glob node-glob-parent node-globals
                  node-globby node-got node-graceful-fs node-gyp node-has-flag
                  node-has-unicode node-hosted-git-info node-https-proxy-agent node-iconv-lite
                  node-icss-utils node-ieee754 node-iferr node-ignore node-imurmurhash
                  node-indent-string node-inflight node-inherits node-ini node-interpret
                  node-ip node-ip-regex node-is-arrayish node-is-binary-path node-is-buffer
                  node-is-extendable node-is-extglob node-is-glob node-is-number
                  node-is-path-cwd node-is-path-inside node-is-plain-obj node-is-plain-object
                  node-is-stream node-is-typedarray node-is-windows node-isarray node-isexe
                  node-isobject node-istanbul node-jest-debbundle node-jest-worker
                  node-js-tokens node-js-yaml node-jsesc node-json-buffer
                  node-json-parse-better-errors node-json-schema node-json-schema-traverse
                  node-json-stable-stringify node-json5 node-jsonify node-jsonparse
                  node-kind-of node-levn node-loader-runner node-locate-path node-lodash
                  node-lodash-packages node-lowercase-keys node-lru-cache node-make-dir
                  node-memfs node-memory-fs node-merge-stream node-micromatch node-mime
                  node-mime-types node-mimic-response node-minimatch node-minimist
                  node-minipass node-mkdirp node-move-concurrently node-ms node-mute-stream
                  node-n3 node-negotiator node-neo-async node-nopt node-normalize-package-data
                  node-normalize-path node-npm-bundled node-npm-package-arg node-npm-run-path
                  node-npmlog node-object-assign node-object-inspect node-once node-optimist
                  node-optionator node-osenv node-p-cancelable node-p-limit node-p-locate
                  node-p-map node-parse-json node-path-dirname node-path-exists
                  node-path-is-absolute node-path-is-inside node-path-type node-picocolors
                  node-pify node-pkg-dir node-postcss node-postcss-modules-extract-imports
                  node-postcss-modules-values node-postcss-value-parser node-prelude-ls
                  node-process-nextick-args node-progress node-promise-inflight
                  node-promise-retry node-promzard node-prr node-pump node-punycode
                  node-quick-lru node-randombytes node-read node-read-package-json
                  node-read-pkg node-readable-stream node-readdirp node-rechoir
                  node-regenerate node-regenerate-unicode-properties node-regenerator-runtime
                  node-regenerator-transform node-regexpp node-regexpu-core node-regjsgen
                  node-regjsparser node-repeat-string node-require-directory node-resolve
                  node-resolve-cwd node-resolve-from node-resumer node-retry node-rimraf
                  node-run-queue node-safe-buffer node-schema-utils node-semver
                  node-serialize-javascript node-set-blocking node-set-immediate-shim
                  node-shebang-command node-shebang-regex node-signal-exit node-slash
                  node-slice-ansi node-source-list-map node-source-map node-source-map-support
                  node-spdx-correct node-spdx-exceptions node-spdx-expression-parse
                  node-spdx-license-ids node-sprintf-js node-ssri node-string-decoder
                  node-string-width node-strip-ansi node-strip-bom node-strip-json-comments
                  node-supports-color node-tapable node-tape node-tar node-terser
                  node-text-table node-through node-time-stamp node-to-fast-properties
                  node-to-regex-range node-tslib node-type-check node-typedarray
                  node-typedarray-to-buffer node-unicode-canonical-property-names-ecmascript
                  node-unicode-match-property-ecmascript
                  node-unicode-match-property-value-ecmascript
                  node-unicode-property-aliases-ecmascript node-unique-filename node-uri-js
                  node-util node-util-deprecate node-uuid node-v8-compile-cache node-v8flags
                  node-validate-npm-package-license node-validate-npm-package-name
                  node-watchpack node-wcwidth.js node-webassemblyjs node-webpack-sources
                  node-which node-wide-align node-wordwrap node-wrap-ansi node-wrappy
                  node-write node-write-file-atomic node-y18n node-yallist node-yargs
                  node-yargs-parser terser webpack
                Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                Die folgenden Pakete werden ENTFERNT:
                  npm
                0 aktualisiert, 0 neu installiert, 1 zu entfernen und 0 nicht aktualisiert.
                Nach dieser Operation werden 3.012 kB Plattenplatz freigegeben.
                Möchten Sie fortfahren? [J/n] j
                (Lese Datenbank ... 297731 Dateien und Verzeichnisse sind derzeit installiert.)
                Entfernen von npm (9.2.0~ds1-1) ...
                Trigger für man-db (2.11.2-2) werden verarbeitet ...
                  gyp handlebars libc-ares2 libjs-async libjs-events libjs-inherits
                  libjs-sprintf-js libjs-typedarray-to-buffer libuv1-dev node-abbrev
                  node-aproba node-are-we-there-yet node-argparse node-arrify node-async
                  node-async-each node-babel-plugin-add-module-exports node-babel7-runtime
                  node-brace-expansion node-busboy node-camelcase node-caniuse-lite
                  node-chownr node-chrome-trace-event node-ci-info node-cjs-module-lexer
                  node-console-control-strings node-convert-source-map node-core-js
                  node-core-js-pure node-core-util-is node-data-uri-to-buffer
                  node-decompress-response node-deep-is node-defaults node-delegates node-depd
                  node-diff node-electron-to-chromium node-encoding node-end-of-stream
                  node-err-code node-error-ex node-es-module-lexer node-escape-string-regexp
                  node-eslint-utils node-eslint-visitor-keys node-esquery node-estraverse
                  node-esutils node-events node-fancy-log node-fast-deep-equal
                  node-fast-levenshtein node-fetch node-find-up node-flatted node-for-in
                  node-for-own node-foreground-child node-fs-readdir-recursive
                  node-fs-write-stream-atomic node-fs.realpath node-function-bind
                  node-functional-red-black-tree node-get-caller-file node-get-stream
                  node-glob node-globals node-got node-graceful-fs node-has-flag
                  node-has-unicode node-hosted-git-info node-iconv-lite node-ieee754
                  node-iferr node-imurmurhash node-indent-string node-inflight node-inherits
                  node-ini node-interpret node-ip node-ip-regex node-is-arrayish
                  node-is-binary-path node-is-buffer node-is-extendable node-is-extglob
                  node-is-path-cwd node-is-plain-obj node-is-plain-object node-is-stream
                  node-is-typedarray node-is-windows node-isarray node-isexe node-isobject
                  node-js-tokens node-jsesc node-json-buffer node-json-parse-better-errors
                  node-json-schema node-json-schema-traverse node-json-stable-stringify
                  node-jsonify node-jsonparse node-kind-of node-levn node-loader-runner
                  node-locate-path node-lodash-packages node-lowercase-keys node-lru-cache
                  node-memfs node-merge-stream node-mimic-response node-minimatch
                  node-minimist node-minipass node-mute-stream node-n3 node-negotiator
                  node-neo-async node-npm-run-path node-object-inspect node-once node-optimist
                  node-p-map node-path-dirname node-path-exists node-path-is-absolute
                  node-path-is-inside node-path-type node-pify node-pkg-dir
                  node-postcss-value-parser node-prelude-ls node-process-nextick-args
                  node-promise-inflight node-promise-retry node-promzard node-prr node-pump
                  node-quick-lru node-randombytes node-read node-readable-stream node-rechoir
                  node-regenerator-transform node-regexpp node-regjsgen node-repeat-string
                  node-require-directory node-resolve node-resolve-cwd node-resolve-from
                  node-resumer node-retry node-run-queue node-safe-buffer
                  node-strip-bom node-strip-json-comments node-supports-color node-tapable
                  node-terser node-text-table node-through node-time-stamp
                  node-to-fast-properties node-tslib node-type-check node-typedarray
                  node-typedarray-to-buffer node-undici
                  node-util-deprecate node-uuid node-v8flags node-validate-npm-package-license
                  node-wcwidth.js node-webpack-sources node-wordwrap node-wrappy
                  node-write-file-atomic node-xtend node-y18n node-yallist
                  eslint libjs-util libnode-dev libnode108 node-acorn node-agent-base node-ajv
                  node-ajv-keywords node-anymatch node-archy node-assert
                  node-babel-helper-define-polyfill-provider node-babel-plugin-lodash
                  node-babel-plugin-polyfill-regenerator node-babel7 node-braces
                  node-browserslist node-builtins node-cacache node-chalk node-chokidar
                  node-cli-table node-cliui node-columnify node-copy-concurrently
                  node-core-js-compat node-css-loader node-css-selector-tokenizer
                  node-debbundle-es-to-primitive node-debug node-decamelize node-deep-equal
                  node-define-properties node-defined node-del node-doctrine
                  node-enhanced-resolve node-errno node-es-abstract node-es6-error
                  node-escodegen node-eslint-scope node-espree node-esprima node-esrecurse
                  node-file-entry-cache node-fill-range node-find-cache-dir node-flat-cache
                  node-gauge node-glob-parent node-globby node-gyp node-https-proxy-agent
                  node-icss-utils node-ignore node-is-glob node-is-number node-is-path-inside
                  node-istanbul node-jest-debbundle node-jest-worker node-js-yaml node-json5
                  node-lodash node-make-dir node-memory-fs node-micromatch node-mime
                  node-mime-types node-mkdirp node-move-concurrently node-ms node-nopt
                  node-normalize-package-data node-normalize-path node-npm-bundled
                  node-npm-package-arg node-npmlog node-object-assign node-parse-json
                  node-picocolors node-postcss node-postcss-modules-extract-imports
                  node-postcss-modules-values node-progress node-punycode
                  node-read-package-json node-read-pkg node-readdirp node-regexpu-core
                  node-regjsparser node-rimraf node-schema-utils node-semver node-string-width
                  node-strip-ansi node-tape node-tar node-to-regex-range
                  node-unicode-match-property-ecmascript node-uri-js node-util
                  node-v8-compile-cache node-validate-npm-package-name node-watchpack
                  node-webassemblyjs node-which node-wide-align node-wrap-ansi node-write
                  node-yargs node-yargs-parser nodejs-doc terser webpack
                Die folgenden Pakete werden durch eine ÄLTERE VERSION ERSETZT (Downgrade):
                  nodejs
                0 aktualisiert, 0 neu installiert, 1 durch eine ältere Version ersetzt, 118 zu entfernen und 0 nicht aktualisiert.
                Es müssen noch 0 B von 29,0 MB an Archiven heruntergeladen werden.
                Nach dieser Operation werden 82,7 MB Plattenplatz zusätzlich benutzt.
                (Lese Datenbank ... 296772 Dateien und Verzeichnisse sind derzeit installiert.)
                Entfernen von node-css-loader (6.7.2+~cs14.0.11-1) ...
                Entfernen von webpack (5.75.0+dfsg+~cs17.16.14-1+deb12u1) ...
                Entfernen von eslint (6.4.0~dfsg+~6.1.9-7) ...
                Entfernen von node-webassemblyjs (1.11.4+dfsg+~cs10.11.17-2) ...
                Entfernen von node-gyp (9.3.0-2) ...
                Entfernen von libnode-dev (18.19.0+dfsg-6~deb12u1) ...
                Entfernen von nodejs-doc (18.19.0+dfsg-6~deb12u1) ...
                Entfernen von node-espree (9.4.1~dfsg-1) ...
                Entfernen von node-v8-compile-cache (2.3.0-3) ...
                Entfernen von node-jest-debbundle (29.3.1~ds1+~cs70.48.25-2) ...
                Entfernen von node-babel-plugin-lodash (3.3.4+~cs2.0.1-6) ...
                Entfernen von terser (5.16.5-2) ...
                Entfernen von node-npm-package-arg (10.0.0+~3.0.0-2) ...
                Entfernen von node-cacache (17.0.3+~cs10.3.7-1) ...
                Entfernen von node-move-concurrently (1.0.1-5) ...
                Entfernen von node-schema-utils (3.1.1~ds-2) ...
                Entfernen von node-progress (2.0.3-2) ...
                Entfernen von node-postcss-modules-extract-imports (3.0.0-2) ...
                Entfernen von node-eslint-scope (7.1.1+~3.7.4-1) ...
                Entfernen von node-esrecurse (4.3.0-2) ...
                Entfernen von node-jest-worker (29.3.1~ds1+~cs70.48.25-2) ...
                Entfernen von node-https-proxy-agent (5.0.1+~cs8.0.0-3) ...
                Entfernen von node-tar (6.1.13+~cs7.0.5-1) ...
                Entfernen von node-mime-types (2.1.35-1) ...
                Entfernen von node-mime (3.0.0+dfsg+~cs3.97.1-1) ...
                Entfernen von node-watchpack (2.4.0+~cs2.8.1-1) ...
                Entfernen von node-chokidar (3.5.3-2) ...
                Entfernen von node-file-entry-cache (6.0.0+~3.0.4+~2.0.0+~1.0.0+~2.0.1-5) ...
                Entfernen von node-flat-cache (3.0.4~6.0.0+~3.0.4+~2.0.0+~1.0.0+~2.0.1-5) ...
                Entfernen von node-write (2.0.0~6.0.0+~3.0.4+~2.0.0+~1.0.0+~2.0.1-5) ...
                Entfernen von node-enhanced-resolve (5.10.0-1) ...
                Entfernen von node-memory-fs (0.5.0+~0.3.3-2) ...
                Entfernen von node-errno (1.0.0-3) ...
                Entfernen von node-doctrine (3.0.0-4) ...
                Entfernen von node-css-selector-tokenizer (0.8.0+~cs4.8.3-1) ...
                Entfernen von node-deep-equal (2.1.0+~cs31.12.80-1) ...
                Entfernen von node-tape (5.6.1+~cs8.20.19-1) ...
                Entfernen von node-istanbul (0.4.5+repack10+~cs97.25.57-3) ...
                Entfernen von node-read-pkg (5.2.0-2) ...
                Entfernen von node-parse-json (5.2.0+~cs5.1.7-1) ...
                Entfernen von node-assert (2.0.0+~cs3.9.8-2) ...
                Entfernen von node-util (0.12.5+~1.0.10-1) ...
                Entfernen von libjs-util (0.12.5+~1.0.10-1) ...
                Entfernen von node-define-properties (1.1.4+~1.1.3-1) ...
                Entfernen von node-es-abstract (1.20.4+~cs26.27.47-1) ...
                Entfernen von node-debbundle-es-to-primitive (1.2.1+~cs9.7.25-2) ...
                Entfernen von node-which (2.0.2+~cs1.3.2-3) ...
                Entfernen von node-babel7 (7.20.15+ds1+~cs214.269.168-3+deb12u1) ...
                Entfernen von node-regexpu-core (5.2.2-3) ...
                Entfernen von node-unicode-match-property-ecmascript (2.0.0-2) ...
                Entfernen von node-yargs (16.2.0+~16.0.4-7) ...
                Entfernen von node-cliui (7.0.4+repack+~cs3.1.0-4) ...
                Entfernen von node-wrap-ansi (8.0.1+~8.0.1-3) ...
                Entfernen von node-regjsparser (0.9.1+ds-2) ...
                Entfernen von node-babel-plugin-polyfill-corejs3 (0.6.0~0~20220913+ds1-1) ...
                Entfernen von node-core-js-compat (3.26.1-3) ...
                Entfernen von node-browserslist (4.21.4+~cs6.1.17-2) ...
                Entfernen von node-object-assign (4.1.1-7) ...
                Entfernen von node-find-cache-dir (3.3.2+~3.2.1-1) ...
                Entfernen von node-del (7.0.0-5) ...
                Entfernen von node-globby (13.1.3+~cs16.25.40-1) ...
                Entfernen von node-micromatch (4.0.5+~4.0.2-1) ...
                Entfernen von node-nopt (5.0.0-4) ...
                Entfernen von node-lodash (4.17.21+dfsg+~cs8.31.198.20210220-9) ...
                Entfernen von node-json5 (2.2.3+dfsg-1) ...
                Entfernen von node-js-yaml (4.1.0+dfsg+~4.0.5-7) ...
                Entfernen von node-is-path-inside (3.0.3-2) ...
                Entfernen von node-braces (3.0.2+~3.0.1-1) ...
                Entfernen von node-fill-range (7.0.1+~7.0.0-1) ...
                Entfernen von node-to-regex-range (5.0.1-4) ...
                Entfernen von node-is-number (7.0.0-4) ...
                Entfernen von node-glob-parent (6.0.2+~5.1.1-2) ...
                Entfernen von node-is-glob (4.0.3-2) ...
                Entfernen von node-ignore (5.2.1-1) ...
                Entfernen von node-escodegen (2.0.0+dfsg+~0.0.7-2) ...
                Entfernen von node-esprima (4.0.1+ds+~4.0.3-2) ...
                Entfernen von node-es6-error (4.1.1-5) ...
                Entfernen von node-defined (1.0.1+~1.0.0-1) ...
                Entfernen von node-yargs-parser (21.1.1+~21.0.0-4) ...
                Entfernen von node-decamelize (4.0.0-2) ...
                Entfernen von node-chalk (5.2.0-1) ...
                Entfernen von node-archy (1.0.0-6) ...
                Entfernen von node-babel-plugin-polyfill-corejs2 (0.3.3~0~20220913+ds1-1) ...
                dpkg: node-ajv: Abhängigkeitsprobleme, wird aber wie gefordert dennoch entfernt:
                 node-ajv-keywords hängt ab von node-ajv (>= 6.9.1~).
                Entfernen von node-ajv (6.12.6-3) ...
                Entfernen von node-uri-js (4.4.0+dfsg-8) ...
                Entfernen von node-punycode (2.1.1-6) ...
                dpkg: node-postcss: Abhängigkeitsprobleme, wird aber wie gefordert dennoch entfe
                rnt:
                 node-postcss-modules-values hängt ab von node-postcss (>= 8.1~).
                 node-icss-utils hängt ab von node-postcss (>= 8.1~).
                Entfernen von node-postcss (8.4.20+~cs8.0.23-1) ...
                Entfernen von node-picocolors (1.0.0-4) ...
                dpkg: node-anymatch: Abhängigkeitsprobleme, wird aber wie gefordert dennoch entf
                ernt:
                 node-readdirp hängt ab von node-anymatch (>= 3.0.3).
                Entfernen von node-anymatch (3.1.3+~cs4.6.1-2) ...
                Entfernen von node-normalize-path (3.0.0+~3.0.0-1) ...
                dpkg: node-debug: Abhängigkeitsprobleme, wird aber wie gefordert dennoch entfern
                t:
                 node-babel-helper-define-polyfill-provider hängt ab von node-debug.
                 node-agent-base hängt ab von node-debug.
                Entfernen von node-debug (4.3.4+~cs4.1.7-1) ...
                Entfernen von node-ms (2.1.3+~cs0.7.31-3) ...
                dpkg: node-mkdirp: Abhängigkeitsprobleme, wird aber wie gefordert dennoch entfer
                nt:
                 node-copy-concurrently hängt ab von node-mkdirp (>= 1).
                Entfernen von node-mkdirp (1.0.4+~1.0.2-4) ...
                dpkg: libnode108:arm64: Abhängigkeitsprobleme, wird aber wie gefordert dennoch e
                ntfernt:
                 nodejs hängt ab von libnode108 (= 18.19.0+dfsg-6~deb12u1).
                Entfernen von libnode108:arm64 (18.19.0+dfsg-6~deb12u1) ...
                dpkg: node-strip-ansi: Abhängigkeitsprobleme, wird aber wie gefordert dennoch en
                tfernt:
                 node-string-width hängt ab von node-strip-ansi.
                 node-gauge hängt ab von node-strip-ansi.
                 node-columnify hängt ab von node-strip-ansi.
                Entfernen von node-strip-ansi (6.0.1-2) ...
                dpkg: node-semver: Abhängigkeitsprobleme, wird aber wie gefordert dennoch entfer
                nt:
                 node-normalize-package-data hängt ab von node-semver.
                 node-make-dir hängt ab von node-semver.
                 node-builtins hängt ab von node-semver.
                 node-babel-helper-define-polyfill-provider hängt ab von node-semver.
                 node-agent-base hängt ab von node-semver.
                Entfernen von node-semver (7.3.5+~7.3.9-2) ...
                dpkg: node-rimraf: Abhängigkeitsprobleme, wird aber wie gefordert dennoch entfer
                nt:
                 node-copy-concurrently hängt ab von node-rimraf.
                Entfernen von node-rimraf (3.0.2-2) ...
                dpkg: Warnung: Version 18.19.0+dfsg-6~deb12u1 des Paketes nodejs wird durch älte
                re Version 18.19.0-1nodesource1 ersetzt
                (Lese Datenbank ... 283791 Dateien und Verzeichnisse sind derzeit installiert.)
                Vorbereitung zum Entpacken von .../nodejs_18.19.0-1nodesource1_arm64.deb ...
                Entpacken von nodejs (18.19.0-1nodesource1) über (18.19.0+dfsg-6~deb12u1) ...
                (Lese Datenbank ... 289110 Dateien und Verzeichnisse sind derzeit installiert.)
                Entfernen von node-acorn (8.8.1+ds+~cs25.17.7-2) ...
                Entfernen von node-agent-base (6.0.2+~cs5.4.2-2) ...
                Entfernen von node-ajv-keywords (3.5.2-2) ...
                Entfernen von node-babel-plugin-polyfill-regenerator (0.4.1~0~20220913+ds1-1) ..
                Entfernen von node-babel-helper-define-polyfill-provider (0.3.3~0~20220913+ds1-1
                Entfernen von node-validate-npm-package-name (5.0.0+~4.0.0-1) ...
                Entfernen von node-builtins (5.0.1-1) ...
                Entfernen von node-cli-table (0.3.11+~cs0.13.4-3) ...
                Entfernen von node-columnify (1.6.0+~1.5.1-1) ...
                Entfernen von node-copy-concurrently (1.0.5-9) ...
                Entfernen von node-npmlog (7.0.1+~4.1.4-1) ...
                Entfernen von node-gauge (4.0.4-1) ...
                Entfernen von node-postcss-modules-values (4.0.0+~4.0.0-1) ...
                Entfernen von node-icss-utils (5.1.0+~5.1.0-1) ...
                Entfernen von node-make-dir (3.1.0-3) ...
                Entfernen von node-npm-bundled (2.0.1-2) ...
                Entfernen von node-read-package-json (5.0.2+~2.0.0-1) ...
                Entfernen von node-normalize-package-data (4.0.1+~2.4.1-1) ...
                Entfernen von node-readdirp (3.6.0-1) ...
                Entfernen von node-wide-align (1.1.3-4) ...
                Entfernen von node-string-width (4.2.3+~cs13.2.3-1) ...
                nodejs (18.19.0-1nodesource1) wird eingerichtet ...
                Trigger für libc-bin (2.36-9+rpt2+deb12u3) werden verarbeitet ...
                den zweiten Admin Adapter habe ich gelöscht die GUI möchte ich gerne behalten
                noch einer eine Idee warum zu hm-rpc.1 wechselt von gelb nach rot hin und her
                  Warum? Die steht nur im Weg herum. Und macht die Bedienung und den Unterhalt eines Servers komplizierter.
                    Diese Diskussion hatten wir ja schon mal....
                    Ich tue mir einfach leichter damit und die Raspberry 5 mit 8GB solle genug Leistung dafür haben.
                    Ich und mein Vater können so immer vom HW Raum auf das Smart home zugreifen.
                    Es ist alles auf Deutsch .
                    Ich kann meine Netzwerkverbindungen sehen.
                    Ich kann Einstellungen direct über das GUI machen.
                    Und ja ich möchte sie wirklich behalten.
                    So habt ihr noch andere Fehler die ich beheben sollte " zu Deine Instanzen sind verwurschtelt....
                    Und vieles andere auch 😞" was meist Du damit??
                    und warum wechselt nun die hm-rpc.1 von gelb nach rot hin und her warum ist das so?
                    code_text
                    ```hm-rpc.1
                    2024-01-27 09:32:55.726	error	Init not possible, going to stop: response timeout
                    hm-rpc.1
                    2024-01-27 09:32:50.719	info	binrpc client is trying to connect to 192.168.1.63:2001/ with ["xmlrpc_bin://192.168.1.65:12001","raspberrypi5:hm-rpc.1:3acb5d0ff60e8170c1bd75ea731ef0b9"]
                    hm-rpc.1
                    2024-01-27 09:32:50.719	info	binrpc server is trying to listen on 192.168.1.65:12001
                    hm-rpc.1
                    2024-01-27 09:32:50.615	info	starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.17
                    hm-rpc.1
                    2024-01-27 09:32:18.821	info	Terminated (NO_ERROR): Without reason
                    hm-rpc.1
                    2024-01-27 09:32:18.820	info	terminating
                    hm-rpc.1
                    2024-01-27 09:32:17.817	info	binrpc -> 192.168.1.63:2001/ init ["xmlrpc_bin://192.168.1.65:12001",""]
                    hm-rpc.1
                    2024-01-27 09:32:17.815	error	Init not possible, going to stop: response timeout
                    hm-rpc.1
                    2024-01-27 09:31:47.815	error	Init not possible, going to stop: response timeout
                    hm-rpc.1
                    2024-01-27 09:31:42.808	info	binrpc client is trying to connect to 192.168.1.63:2001/ with ["xmlrpc_bin://192.168.1.65:12001","raspberrypi5:hm-rpc.1:a653d724b29195d887ed1f93dd71cb03"]
                    hm-rpc.1
                    2024-01-27 09:31:42.807	info	binrpc server is trying to listen on 192.168.1.65:12001
                    hm-rpc.1
                    2024-01-27 09:31:42.703	info	starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.17
                    hm-rpc.1
                    2024-01-27 09:31:10.902	info	Terminated (NO_ERROR): Without reason
                    hm-rpc.1
                    2024-01-27 09:31:10.901	info	terminating
                    hm-rpc.1
                    2024-01-27 09:31:09.897	info	binrpc -> 192.168.1.63:2001/ init ["xmlrpc_bin://192.168.1.65:12001",""]
                    hm-rpc.1
                    2024-01-27 09:31:09.896	error	Init not possible, going to stop: response timeout
                    hm-rpc.1
                    2024-01-27 09:30:39.894	error	Init not possible, going to stop: response timeout
                    hm-rpc.1
                    2024-01-27 09:30:34.887	info	binrpc client is trying to connect to 192.168.1.63:2001/ with ["xmlrpc_bin://192.168.1.65:12001","raspberrypi5:hm-rpc.1:76df1607047ecef5fc1f2b38e8162df6"]
                    hm-rpc.1
                    2024-01-27 09:30:34.886	info	binrpc server is trying to listen on 192.168.1.65:12001
                    hm-rpc.1
                    2024-01-27 09:30:34.767	info	starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.17
                    hm-rpc.1
                    2024-01-27 09:30:02.961	info	Terminated (NO_ERROR): Without reason
                    hm-rpc.1
                    2024-01-27 09:30:02.960	info	terminating
                    hm-rpc.1
                    2024-01-27 09:30:01.958	error	Init not possible, going to stop: response timeout
                    hm-rpc.1
                    2024-01-27 09:30:01.955	info	binrpc -> 192.168.1.63:2001/ init ["xmlrpc_bin://192.168.1.65:12001",""]
                    hm-rpc.1
                    2024-01-27 09:29:31.953	error	Init not possible, going to stop: response timeout
                    hm-rpc.1
                    2024-01-27 09:29:26.946	info	binrpc client is trying to connect to 192.168.1.63:2001/ with ["xmlrpc_bin://192.168.1.65:12001","raspberrypi5:hm-rpc.1:c2966d8591766baca963b02eec56645e"]
                    hm-rpc.1
                    2024-01-27 09:29:26.945	info	binrpc server is trying to listen on 192.168.1.65:12001
                    hm-rpc.1
                    2024-01-27 09:29:26.826	info	starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.17
                    hm-rpc.1
                    2024-01-27 09:28:55.015	info	Terminated (NO_ERROR): Without reason
                    hm-rpc.1
                    2024-01-27 09:28:55.014	info	terminating
                    hm-rpc.1
                    2024-01-27 09:28:54.008	info	binrpc -> 192.168.1.63:2001/ init ["xmlrpc_bin://192.168.1.65:12001",""]
                    hm-rpc.1
                    2024-01-27 09:28:54.007	error	Init not possible, going to stop: response timeout
                    hm-rpc.1
                    2024-01-27 09:28:24.005	error	Init not possible, going to stop: response timeout
                    hm-rpc.1
                    2024-01-27 09:28:18.997	info	binrpc client is trying to connect to 192.168.1.63:2001/ with ["xmlrpc_bin://192.168.1.65:12001","raspberrypi5:hm-rpc.1:63715ec7769697d2091f2d779f4c15e1"]
                    hm-rpc.1
                    2024-01-27 09:28:18.996	info	binrpc server is trying to listen on 192.168.1.65:12001
                    hm-rpc.1
                    2024-01-27 09:28:18.876	info	starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.17
                    hm-rpc.1
                    2024-01-27 09:27:47.191	info	Terminated (NO_ERROR): Without reason
                    hm-rpc.1
                    2024-01-27 09:27:47.190	info	terminating
                    hm-rpc.1
                    2024-01-27 09:27:46.186	info	binrpc -> 192.168.1.63:2001/ init ["xmlrpc_bin://192.168.1.65:12001",""]
                    hm-rpc.1
                    2024-01-27 09:27:46.184	error	Init not possible, going to stop: response timeout
                    hm-rpc.1
                    2024-01-27 09:27:16.183	error	Init not possible, going to stop: response timeout
                    hm-rpc.1
                    2024-01-27 09:27:11.176	info	binrpc client is trying to connect to 192.168.1.63:2001/ with ["xmlrpc_bin://192.168.1.65:12001","raspberrypi5:hm-rpc.1:0169b282d72839c63695bb1c43a8559d"]
                    hm-rpc.1
                    2024-01-27 09:27:11.176	info	binrpc server is trying to listen on 192.168.1.65:12001
                    hm-rpc.1
                    2024-01-27 09:27:11.073	info	starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.17
                    hm-rpc.1
                    2024-01-27 09:26:39.226	info	Terminated (NO_ERROR): Without reason
                    hm-rpc.1
                    2024-01-27 09:26:39.225	info	terminating
                    hm-rpc.1
                    2024-01-27 09:26:38.221	info	binrpc -> 192.168.1.63:2001/ init ["xmlrpc_bin://192.168.1.65:12001",""]
                    hm-rpc.1
                    2024-01-27 09:26:38.219	error	Init not possible, going to stop: response timeout
                    hm-rpc.1
                    2024-01-27 09:26:08.218	error	Init not possible, going to stop: response timeout
                    hm-rpc.1
                    2024-01-27 09:26:03.210	info	binrpc client is trying to connect to 192.168.1.63:2001/ with ["xmlrpc_bin://192.168.1.65:12001","raspberrypi5:hm-rpc.1:4c8537fb5485d0deccecc3c8345a965d"]
                    hm-rpc.1
                    2024-01-27 09:26:03.209	info	binrpc server is trying to listen on 192.168.1.65:12001
                    hm-rpc.1
                    2024-01-27 09:26:03.088	info	starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.17**bolded text******bolded text****
                      @radix75
                      iob diag
                      in der Langfassung. Und schalt den Desktop aus.
                        hue.0 kann nicht gehen weil Deconz jetzt aus ist
                        `======== Start marking the full check here =========
                        Skript v.2023-10-10
                        *** BASE SYSTEM ***
                               Icon name: computer
                            Architecture: arm64
                        Docker          : false
                        Kernel          : aarch64
                        Userland        : arm64
                         14:45:43 up  3:33,  3 users,  load average: 0.20, 0.14, 0.37
                        CPU threads: 4
                        Current issues:
                                       Local time: Sun 2024-01-28 14:45:43 CET
                                   Universal time: Sun 2024-01-28 13:45:43 UTC
                                         RTC time: Sat 1970-01-03 20:47:27
                                      NTP service: active
                                  RTC in local TZ: no
                        Radix1975
                        /home/Radix1975
                        X-Server: 	false
                        Terminal: 	wayland
                        *** MEMORY ***
                        Mem:            8.4G        3.1G        2.9G         71M        2.6G        5.3G
                        Swap:           104M          0B        104M
                        Total:          8.5G        3.1G        3.0G
                                 8049 M total memory
                                 2971 M used memory
                                 3079 M active memory
                                 1591 M inactive memory
                                 2726 M free memory
                                  301 M buffer memory
                                 2214 M swap cache
                                   99 M total swap
                                    0 M used swap
                                   99 M free swap
                        Raspberry only:
                        *** FILESYSTEM ***
                        /var:
                        2.8G	/var/
                        983M	/var/cache
                        966M	/var/cache/apt
                        942M	/var/lib
                        750M	/opt/iobroker/iobroker-data/
                        USB-Devices by-id:
                        /usr/bin/npm 		10.2.3
                        /usr/bin/npx 		10.2.3
                        /usr/bin/corepack 	0.22.0
                        nodejs:
                          Installed: 18.19.0-1nodesource1
                          Candidate: 18.19.0-1nodesource1
                          Version table:
                         *** 18.19.0-1nodesource1 1001
                             18.18.2-1nodesource1 1001
                             18.18.1-1nodesource1 1001
                             18.18.0-1nodesource1 1001
                             18.17.1-1nodesource1 1001
                             18.17.0-1nodesource1 1001
                             18.16.1-1nodesource1 1001
                             18.16.0-1nodesource1 1001
                             18.15.0-1nodesource1 1001
                             18.14.2-1nodesource1 1001
                             18.14.1-1nodesource1 1001
                             18.14.0-1nodesource1 1001
                             18.13.0+dfsg1-1 500
                             18.13.0-1nodesource1 1001
                             18.12.0-1nodesource1 1001
                             18.11.0-1nodesource1 1001
                             18.10.0-1nodesource1 1001
                             18.9.1-1nodesource1 1001
                             18.9.0-1nodesource1 1001
                             18.8.0-1nodesource1 1001
                             18.7.0-1nodesource1 1001
                             18.6.0-1nodesource1 1001
                             18.5.0-1nodesource1 1001
                             18.4.0-1nodesource1 1001
                             18.3.0-1nodesource1 1001
                             18.2.0-1nodesource1 1001
                             18.1.0-1nodesource1 1001
                             18.0.0-1nodesource1 1001
                        Errors in npm tree:
                        ioBroker Status
                        Objects type: jsonl
                        States  type: jsonl
                        admin: 		6.12.0
                        javascript: 	7.1.6
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects: 	8992
                        States: 	7028
                        Hit:1 http://phoscon.de/apt/deconz bookworm InRelease
                        Hit:2 http://deb.debian.org/debian bookworm InRelease
                        Pending Updates: 0
                        tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       292691     56035/io.jarvis.0
                        tcp        0      0 192.168.1.65:12001      0.0.0.0:*               LISTEN      1001       307537     57841/io.hm-rpc.1
                        tcp        0      0 192.168.1.65:12010      0.0.0.0:*               LISTEN      1001       291020     55769/io.hm-rpc.0
                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       287659     55535/iobroker.js-c
                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       287670     55535/iobroker.js-c
                        tcp6       0      0 :::8091                 :::*                    LISTEN      1001       292733     56052/io.lovelace.0
                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       287730     55554/io.admin.0
                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       293959     56181/io.web.0
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       289388     55809/io.chromecast
                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       289852     55629/io.chromecast
                        2024-01-28 14:45:28.717  - error: hue.0 (55825) connect ECONNREFUSED 192.168.1.65:80
                        2024-01-28 14:45:28.717  - warn: hue.0 (55825) Could not get configuration from HUE bridge (192.168.1.65:80)
                        2024-01-28 14:45:33.719  - error: hue.0 (55825) connect ECONNREFUSED 192.168.1.65:80
                        2024-01-28 14:45:33.720  - warn: hue.0 (55825) Could not get configuration from HUE bridge (192.168.1.65:80)
                        2024-01-28 14:45:38.722  - error: hue.0 (55825) connect ECONNREFUSED 192.168.1.65:80
                        2024-01-28 14:45:38.722  - warn: hue.0 (55825) Could not get configuration from HUE bridge (192.168.1.65:80)
                        2024-01-28 14:45:43.725  - error: hue.0 (55825) connect ECONNREFUSED 192.168.1.65:80
                        2024-01-28 14:45:43.725  - warn: hue.0 (55825) Could not get configuration from HUE bridge (192.168.1.65:80)
                        2024-01-28 14:45:48.727  - error: hue.0 (55825) connect ECONNREFUSED 192.168.1.65:80
                        2024-01-28 14:45:48.728  - warn: hue.0 (55825) Could not get configuration from HUE bridge (192.168.1.65:80)
                        2024-01-28 14:45:52.046  - info: host.raspberrypi5 instance system.adapter.hm-rpc.1 started with pid 57841
                        2024-01-28 14:45:52.870  - info: hm-rpc.1 (57841) starting. Version 1.15.19 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v18.19.0, js-controller: 5.0.17
                        2024-01-28 14:45:52.964  - info: hm-rpc.1 (57841) binrpc server is trying to listen on 192.168.1.65:12001
                        2024-01-28 14:45:52.965  - info: hm-rpc.1 (57841) binrpc client is trying to connect to 192.168.1.63:2001/ with ["xmlrpc_bin://192.168.1.65:12001","raspberrypi5:hm-rpc.1:e3ec02aa81cfcc459d730c6f1f53df95"]
                        2024-01-28 14:45:53.729  - error: hue.0 (55825) connect ECONNREFUSED 192.168.1.65:80
                        2024-01-28 14:45:53.729  - warn: hue.0 (55825) Could not get configuration from HUE bridge (192.168.1.65:80)
                        2024-01-28 14:45:57.969  - error: hm-rpc.1 (57841) Init not possible, going to stop: response timeout
                        2024-01-28 14:45:58.731  - error: hue.0 (55825) connect ECONNREFUSED 192.168.1.65:80
                        2024-01-28 14:45:58.731  - warn: hue.0 (55825) Could not get configuration from HUE bridge (192.168.1.65:80)
                        2024-01-28 14:46:03.734  - error: hue.0 (55825) connect ECONNREFUSED 192.168.1.65:80
                        2024-01-28 14:46:03.734  - warn: hue.0 (55825) Could not get configuration from HUE bridge (192.168.1.65:80)
                        2024-01-28 14:46:08.736  - error: hue.0 (55825) connect ECONNREFUSED 192.168.1.65:80
                        2024-01-28 14:46:08.737  - warn: hue.0 (55825) Could not get configuration from HUE bridge (192.168.1.65:80)
                        2024-01-28 14:46:13.739  - error: hue.0 (55825) connect ECONNREFUSED 192.168.1.65:80
                        2024-01-28 14:46:13.739  - warn: hue.0 (55825) Could not get configuration from HUE bridge (192.168.1.65:80)
                        • haselchen
                          haselchen Most Active @Radix75 last edited by haselchen
                          Das erschliesst sich mir nicht, warum.
                          Und beim Rest, dass ist ne OP an einem Komapatienten.
                          Ich würde Deine Kiste neu aufsetzen.
                          Vorher Skripte , VIS ... sichern.
                          Deine Node ist immer noch falsch, Deine Ports 8082 immer noch doppelt, wozu brauchst du 3 TR-064 Instanzen?
                          HM-RPC1 vermutlich falsch konfiguriert ( aber Schuss ins Blaue , weil keine Infos bekannt)
                          Wozu 2 Chromecast Instanzen?
                            Homoran Global Moderator Administrators @haselchen last edited by
                            @haselchen sagte in Diverse kleine Adapter Fehler:
                            2mal Admin enabled.
                            und einen davon auf eine fixe IP gebunden
                              was denn nu?
                              2001 oder 12001?
                              da scheint auch noch ein Eintrag zu fehlen.
                              ganz hinten steht "". da gehört bestimmt noch was rein
                                Thomas Braun Most Active @haselchen last edited by
                                Nee, das Setup stimmt.
                                • haselchen
                                  haselchen Most Active @Thomas Braun last edited by haselchen
                                  Mit den *** davor ist die installierte Version?
                                  Ja, dann stimmt es.
                                  Hatte nur oben das dfsg gesehen.
                                    Radix75 @haselchen last edited by Radix75
                                    @haselchen said in Diverse kleine Adapter Fehler:
                                    Ja, dann stimmt es.
                                    wie kann ich den javis Port ändern ?
                                    wozu brauchst du 3 TR-064 Instanzen? Weil das einmal die Fritz box und zwei mal Fritz repeater sind.
                                    Wozu 2 Chromecast Instanzen? Ich habe die sinnlose gelöscht da war gar nix eingestellt
                                    Was denn nu?
                                    2001 oder 12001?
                                    Was davon ist richtig?
                                    Das ist die Rot gelbe
                                    Das sind die Grünen
                                      wie du in deinem geposteten log siehst, kommt die Meldung vom hm-rpc.1
                                        Homoran Global Moderator Administrators @Radix75 last edited by Homoran
                                        da sind ja überhaupt keine Instanzen den jeweiligen Diensten zugeordnet.
                                        ich kann auf den 4k ultrawide cinemascope Screenshots fast nichts entziffern.
                                        Hast du in beiden rpc Instanzen den gleichen Port auf der CCU adressiert?
                                        lies mal hier
                                        https://www.iobroker.net/#de/adapters/adapterref/iobroker.hm-rpc/README.md?homematicport
                                        wo sind die jeweils zweiten Seiten?
                                          Radix75 @Homoran last edited by
                                          @homoran said in Diverse kleine Adapter Fehler:
                                          lies mal hier
                                          hab den Fehler im https://www.iobroker.net/#de/adapters/adapterref/iobroker.hm-rpc/README.md?homematicport gefunden habe das falsche Protokoll eingestellt
                                          Ich habe das geändert und jetzt ist der Adapter grün Danke für die Hilfe
                                            dafür ist eine Doku da!
                                            1298
