    4. Frigate Adapter für ioBroker
      hagst @tombox last edited by
      @tombox sagte in Frigate Adapter für ioBroker:
      bitte mal die GitHub version installieren die hat nochmal mehr log
      Du meinst die Version?
        tombox @hagst last edited by
        @hagst ja genau korrekt
          hagst @tombox last edited by hagst
          Alte Version deinstalliert
          $ iobroker del frigate --debug
          Delete adapter "frigate"
          host.iobroker Counted 1 instances of frigate
          host.iobroker Counted 1 meta of frigate
          host.iobroker Counted 1 adapter for frigate
          host.iobroker Counted 29 channels of frigate
          host.iobroker Counted 325 states of frigate
          host.iobroker Counted 15 states of system.adapter.frigate
          host.iobroker Counted 327 states (io.frigate.*) from states
          host.iobroker Counted 16 states (system.adapter.frigate.*) from states
          host.iobroker Counted 1 objects of frigate
          host.iobroker file frigate.admin deleted
          host.iobroker Deleting 373 object(s).
          host.iobroker: Only 200 objects left to be deleted.
          host.iobroker Deleting 343 state(s).
          host.iobroker: Only 200 states left to be deleted.
          removed 145 packages in 2s
          89 packages are looking for funding run `npm fund` for details
          Process exited with code 0
          Alle alten Einträge sind gelöscht:Alt1.png
          Neue Version von Github installiert
          $ iobroker url iobroker-community-adapters/ioBroker.frigate --host iobroker --debug
          install iobroker-community-adapters/ioBroker.frigate
          NPM version: 10.2.4
          Installing iobroker-community-adapters/ioBroker.frigate... (System call)
          added 31 packages, and changed 1 package in 6s89 packages are looking for funding run `npm fund` for details
          upload [1] frigate.admin /opt/iobroker/node_modules/iobroker.frigate/admin/frigate.png frigate.png image/png
          upload [0] frigate.admin /opt/iobroker/node_modules/iobroker.frigate/admin/jsonConfig.json jsonConfig.json application/json
          Instanz hinzugefügt:
          $ iobroker add frigate auto --host iobroker --debug
          host.iobroker create instance frigate
          host.iobroker object system.adapter.frigate.0.connected created
          host.iobroker object system.adapter.frigate.0.compactMode created
          host.iobroker object system.adapter.frigate.0.cpu created
          host.iobroker object system.adapter.frigate.0.memHeapUsed created
          host.iobroker object system.adapter.frigate.0.memRss created
          host.iobroker object system.adapter.frigate.0.uptime created
          host.iobroker object system.adapter.frigate.0.sigKill created
          host.iobroker object system.adapter.frigate.0.logLevel created
          host.iobroker object frigate.0.info.connection created
          host.iobroker Set default value of frigate.0.info.connection: false
          host.iobroker object system.adapter.frigate.0 created
          Adapter-Einstellungen vorgenommen:
          Logdatei:
          frigate.0
          2024-01-28 13:30:41.958	warn	State "frigate.0.events.history.json" has no existing object, this might lead to an error in future versions
          frigate.0
          2024-01-28 13:30:41.881	info	frigate.0 (2510) MQTT client frigate subscribed to topics: frigate/# from broker cb4f78fc-a529-4ab9-985e-c192fa46b979
          frigate.0
          2024-01-28 13:30:41.828	info	Filter for message from client: frigate
          frigate.0
          2024-01-28 13:30:41.828	info	New client: frigate
          frigate.0
          2024-01-28 13:29:58.798	info	If you don't see a new client connected, please restart frigate and adapter.
          frigate.0
          2024-01-28 13:29:58.798	info	Please enter host: 'iobroker' and port: '1885' in frigate config
          frigate.0
          2024-01-28 13:29:58.798	info	MQTT server started and listening on port 1885
          frigate.0
          2024-01-28 13:29:58.727	info	starting. Version 1.0.0 (non-npm: iobroker-community-adapters/ioBroker.frigate) in /opt/iobroker/node_modules/iobroker.frigate, node: v20.11.0, js-controller: 5.0.17
          frigate.0
          2024-01-28 13:29:55.429	info	terminating
          frigate.0
          2024-01-28 13:29:54.927	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          frigate.0
          2024-01-28 13:29:54.927	info	terminating
          frigate.0
          2024-01-28 13:29:54.926	info	Got terminate signal TERMINATE_YOURSELF
          frigate.0
          2024-01-28 13:27:53.031	error	Please check if port 1883 is already in use. Use a different port in instance and frigate settings or restart ioBroker.
          frigate.0
          2024-01-28 13:27:53.030	error	MQTT server error: Error: listen EADDRINUSE: address already in use :::1883
          frigate.0
          2024-01-28 13:27:52.893	info	starting. Version 1.0.0 (non-npm: iobroker-community-adapters/ioBroker.frigate) in /opt/iobroker/node_modules/iobroker.frigate, node: v20.11.0, js-controller: 5.0.17
          Ergebnis: 😕
          frigate.0
          2024-01-28 13:32:34.876	warn	State "frigate.0.events.history.json" has no existing object, this might lead to an error in future versions
          frigate.0
          2024-01-28 13:32:31.375	warn	State "frigate.0.events.history.json" has no existing object, this might lead to an error in future versions
          frigate.0
          2024-01-28 13:32:26.173	warn	State "frigate.0.events.history.json" has no existing object, this might lead to an error in future versions
          frigate.0
          2024-01-28 13:32:21.392	warn	State "frigate.0.events.history.json" has no existing object, this might lead to an error in future versions
          frigate.0
          2024-01-28 13:31:03.254	warn	State "frigate.0.events.history.json" has no existing object, this might lead to an error in future versions
          frigate.0
          2024-01-28 13:31:03.239	info	Device information created
          frigate.0
          2024-01-28 13:31:03.236	info	Fetch event history for 0 cameras
          frigate.0
          2024-01-28 13:31:03.236	info	{"Einfahrt":{"camera_fps":5,"process_fps":5,"skipped_fps":0,"detection_fps":0,"detection_enabled":1,"pid":295,"capture_pid":299,"ffmpeg_pid":311},"Terrasse":{"camera_fps":5.1,"process_fps":5.1,"skipped_fps":0,"detection_fps":0,"detection_enabled":1,"pid":297,"capture_pid":300,"ffmpeg_pid":306},"Wald":{"camera_fps":5.1,"process_fps":5.1,"skipped_fps":0,"detection_fps":0,"detection_enabled":1,"pid":298,"capture_pid":302,"ffmpeg_pid":1285},"detectors":{"cpu":{"inference_speed":119.08,"detection_start":0,"pid":290}},"detection_fps":0,"service":{"uptime":10186,"version":"0.12.1-367d724","latest_version":"0.12.1","storage":{"/media/frigate/recordings":{"total":10464,"used":4280.4,"free":5630,"mount_type":"ext4"},"/media/frigate/clips":{"total":10464,"used":4280.4,"free":5630,"mount_type":"ext4"},"/tmp/cache":{"total":1000,"used":12.4,"free":987.6,"mount_type":"tmpfs"},"/dev/shm":{"total":67.1,"used":5.7,"free":61.4,"mount_type":"tmpfs"}},"temperatures":{},"last_updated":1706445063}}
          frigate.0
          2024-01-28 13:31:03.236	warn	No cameras found
          frigate.0
          2024-01-28 13:31:03.235	info	Create Device information and fetch Event History
          frigate.0
          frigate.0
          frigate.0
          frigate.0
          frigate.0
          frigate.0
          frigate.0
          frigate.0
          Nachtrag:
          Neustart ioBroker:
          frigate.0
          2024-01-28 13:43:41.697	warn	State "frigate.0.events.history.json" has no existing object, this might lead to an error in future versions
          frigate.0
          2024-01-28 13:43:41.680	info	Device information created
          frigate.0
          2024-01-28 13:43:41.677	info	Fetch event history for 0 cameras
          frigate.0
          2024-01-28 13:43:41.677	info	{"Einfahrt":{"camera_fps":5.1,"process_fps":5.1,"skipped_fps":0,"detection_fps":0,"detection_enabled":1,"pid":295,"capture_pid":299,"ffmpeg_pid":311},"Terrasse":{"camera_fps":5.1,"process_fps":5.1,"skipped_fps":0,"detection_fps":0,"detection_enabled":1,"pid":297,"capture_pid":300,"ffmpeg_pid":306},"Wald":{"camera_fps":5,"process_fps":5,"skipped_fps":0,"detection_fps":0,"detection_enabled":1,"pid":298,"capture_pid":302,"ffmpeg_pid":4836},"detectors":{"cpu":{"inference_speed":92.58,"detection_start":0,"pid":290}},"detection_fps":0,"service":{"uptime":10944,"version":"0.12.1-367d724","latest_version":"0.12.1","storage":{"/media/frigate/recordings":{"total":10464,"used":4287.6,"free":5622.8,"mount_type":"ext4"},"/media/frigate/clips":{"total":10464,"used":4287.6,"free":5622.8,"mount_type":"ext4"},"/tmp/cache":{"total":1000,"used":11.3,"free":988.7,"mount_type":"tmpfs"},"/dev/shm":{"total":67.1,"used":5.7,"free":61.4,"mount_type":"tmpfs"}},"temperatures":{},"last_updated":1706445821}}
          frigate.0
          2024-01-28 13:43:41.677	warn	No cameras found
          frigate.0
          2024-01-28 13:43:41.676	info	Create Device information and fetch Event History
          frigate.0
          2024-01-28 13:42:44.876	warn	State "frigate.0.events.history.json" has no existing object, this might lead to an error in future versions
          frigate.0
          2024-01-28 13:42:44.847	info	frigate.0 (734) MQTT client frigate subscribed to topics: frigate/# from broker cbd3cc19-f5b8-4d68-8252-e2cbe0736d9b
          frigate.0
          2024-01-28 13:42:44.784	info	Filter for message from client: frigate
          frigate.0
          2024-01-28 13:42:44.784	info	New client: frigate
          frigate.0
          2024-01-28 13:42:11.387	info	If you don't see a new client connected, please restart frigate and adapter.
          frigate.0
          2024-01-28 13:42:11.387	info	Please enter host: 'iobroker' and port: '1885' in frigate config
          frigate.0
          2024-01-28 13:42:11.387	info	MQTT server started and listening on port 1885
          frigate.0
          2024-01-28 13:42:11.316	info	starting. Version 1.0.0 (non-npm: iobroker-community-adapters/ioBroker.frigate) in /opt/iobroker/node_modules/iobroker.frigate, node: v20.11.0, js-controller: 5.0.17
            @hagst Kannst die logs wieder löschen und die GitHub version drüber installieren
            • Q
              QuesT last edited by
              habe auch auf die 1.0 umgestellt und gleich versucht die Nachrichten via pushover zu senden. Leider stürtz der IoBroker komplett ab wenn ein Ereigniss getriggert wird. Per Telegram läuft es. Ist hier noch was zubeachten?
                tombox @QuesT last edited by
                @quest brauch ich den Fehler log
                  frigate.0
                  2024-01-28 14:36:00.603	info	Device information created
                  frigate.0
                  2024-01-28 14:36:00.600	info	Fetch event history for 3 cameras
                  frigate.0
                  2024-01-28 14:36:00.586	info	Create device information for: Wald
                  frigate.0
                  2024-01-28 14:36:00.573	info	Create device information for: Terrasse
                  frigate.0
                  2024-01-28 14:36:00.558	info	Create device information for: Einfahrt
                  frigate.0
                  2024-01-28 14:36:00.527	info	Create Device information and fetch Event History
                  frigate.0
                  2024-01-28 14:35:55.551	info	frigate.0 (1789) MQTT client frigate subscribed to topics: frigate/# from broker 00d2ab76-66f6-4aa7-8018-159a69db4997
                  frigate.0
                  2024-01-28 14:35:55.526	info	Filter for message from client: frigate
                  frigate.0
                  2024-01-28 14:35:55.526	info	New client: frigate
                  frigate.0
                  2024-01-28 14:35:51.876	info	If you don't see a new client connected, please restart frigate and adapter.
                  frigate.0
                  2024-01-28 14:35:51.876	info	Please enter host: 'iobroker' and port: '1885' in frigate config
                  frigate.0
                  2024-01-28 14:35:51.876	info	MQTT server started and listening on port 1885
                  frigate.0
                  2024-01-28 14:35:51.793	info	starting. Version 1.0.0 (non-npm: iobroker-community-adapters/ioBroker.frigate) in /opt/iobroker/node_modules/iobroker.frigate, node: v20.11.0, js-controller: 5.0.17
                  frigate.0
                  2024-01-28 14:35:48.503	info	terminating
                  frigate.0
                  2024-01-28 14:35:48.002	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  frigate.0
                  2024-01-28 14:35:48.002	info	terminating
                  frigate.0
                  2024-01-28 14:35:48.001	info	Got terminate signal TERMINATE_YOURSELF
                  Jetzt sind die Einträge erstellt worden!
                  • Q
                    QuesT @tombox last edited by QuesT
                    @tombox
                    2024-01-28 15:10:07.144 - error: pushover.0 (1040) Error from Pushover: message cannot be blank
                    2024-01-28 15:10:08.172 - error: pushover.0 (1040) Error from Pushover: message cannot be blank
                    2024-01-28 15:10:27.144 - error: pushover.0 (1040) Error from Pushover: SyntaxError: Unexpected token < in JSON at position 0
                    2024-01-28 15:10:27.639 - error: pushover.0 (1040) Error from Pushover: SyntaxError: Unexpected token < in JSON at position 0
                    Danach startet der ioBroker neu.
                      @quest bitte mal die GitHub version testen
                      • Q
                        @tombox
                        2024-01-28 17:16:45.523 - error: pushover.0 (4298) Error from Pushover: message cannot be blank
                        Stürzt aber nicht mehr ab.
                          @quest dann nochmal installieren
                          • Q
                            @tombox
                            Bild kommt nun an. Video noch nicht: pushover.0 (1051) Error from Pushover: SyntaxError: Unexpected token < in JSON at position 0
                              @quest für den clip wäre noch ein debug log gut auch gerne per PN
                              • Q
                                @tombox
                                Vergiss es Pushover kann nur jpg.
                                Danke für die schnelle Hilfe.
                                  MrHenker27 last edited by
                                  Also zum ersten mal danke für den neuen Adapter.
                                  Leider bekomm ich Warn Meldungen im Log -.-
                                    tombox @MrHenker27 last edited by
                                    @mrhenker27 kommt das mit der 1.0.2?
                                      MrHenker27 @tombox last edited by
                                      @tombox
                                      okay, war die 1.0.0 hab jetzt über GIT mal die 1.0.2 installiert. Scheint behoben zu sein.
                                        MarkA @MrHenker27 last edited by
                                        Leider geht mit dem neuen Adapter die Kombination von Frigate in Verbindung mit Touble-Take und Compreface zur Personenerkennung nicht mehr, da alle mit dem gleichen MQTT Server sprechen müssen.
                                          tombox @MarkA last edited by
                                          @marka Eigentlich sollte das gehen. Bitte mal die GitHub version installieren und einfach als mqtt host den iobroker eingeben
                                            MarkA @tombox last edited by
                                            das geht bei mir so leider nicht. So wie ich die neue Version verstanden habe, bringt sie einen eigenen MQTT Broker mit. Dies möchte ich nicht, da ich bereits den MQTT Adapter, sowie den SONOFF Adapter für MQTT laufen habe, mit jeweils vielen Integrationen, je nachdem wie die Daten ankommen.
                                            Dazu kommt noch, dass der Frigate Adapter MQTT keine Authentifizierung benutzt.
                                            1.0k
                                            367
                                            98602
