    4. KNX-Adapter - keine UDP-Verbindung - OpenKNX-Adapter i.O.
    • N
      Nubbbi @Glasfaser last edited by
      @glasfaser
      Danke.
      So eingestellt: 40e98791-01bd-443e-9fde-824289fa830e-image.png
      kommt:
      knx.0
      2024-01-21 17:15:10.769	info	Send : UDP Connection State Request : 06 10 02 07 00 10 00 00 08 01 00 00 00 00 95 30 sent from Port: to 192.168.178.50:3671
      knx.0
      2024-01-21 17:15:08.767	info	Send : UDP Connection State Request : 06 10 02 07 00 10 00 00 08 01 00 00 00 00 95 30 sent from Port: to 192.168.178.50:3671
      knx.0
      2024-01-21 17:15:06.766	info	Send : UDP Connection State Request : 06 10 02 07 00 10 00 00 08 01 00 00 00 00 95 30 sent from Port: to 192.168.178.50:3671
      knx.0
      2024-01-21 17:15:04.765	info	Send : UDP Connection State Request : 06 10 02 07 00 10 00 00 08 01 00 00 00 00 95 30 sent from Port: to 192.168.178.50:3671
      knx.0
      2024-01-21 17:15:02.763	info	Send : UDP Connection State Request : 06 10 02 07 00 10 00 00 08 01 00 00 00 00 95 30 sent from Port: to 192.168.178.50:3671
      knx.0
      2024-01-21 17:15:00.763	info	Send : UDP Connection State Request : 06 10 02 07 00 10 00 00 08 01 00 00 00 00 95 30 sent from Port: to 192.168.178.50:3671
      knx.0
      2024-01-21 17:14:58.761	info	Send : UDP Connection State Request : 06 10 02 07 00 10 00 00 08 01 00 00 00 00 95 30 sent from Port: to 192.168.178.50:3671
      knx.0
      2024-01-21 17:14:56.759	info	Send : UDP Connection State Request : 06 10 02 07 00 10 00 00 08 01 00 00 00 00 95 30 sent from Port: to 192.168.178.50:3671
      knx.0
      2024-01-21 17:14:54.758	info	Send : UDP Connection State Request : 06 10 02 07 00 10 00 00 08 01 00 00 00 00 95 30 sent from Port: to 192.168.178.50:3671
      knx.0
      2024-01-21 17:14:52.756	info	Send : UDP Connection State Request : 06 10 02 07 00 10 00 00 08 01 00 00 00 00 95 30 sent from Port: to 192.168.178.50:3671
      knx.0
      2024-01-21 17:14:50.755	info	Send : UDP Connection State Request : 06 10 02 07 00 10 00 00 08 01 00 00 00 00 95 30 sent from Port: to 192.168.178.50:3671
      knx.0
      2024-01-21 17:14:48.753	info	Send : UDP Connection State Request : 06 10 02 07 00 10 00 00 08 01 00 00 00 00 95 30 sent from Port: to 192.168.178.50:3671
      knx.0
      2024-01-21 17:14:46.753	info	Send : UDP Connection State Request : 06 10 02 07 00 10 00 00 08 01 00 00 00 00 95 30 sent from Port: to 192.168.178.50:3671
      knx.0
      2024-01-21 17:14:44.751	info	Send : UDP Connection State Request : 06 10 02 07 00 10 00 00 08 01 00 00 00 00 95 30 sent from Port: to 192.168.178.50:3671
      knx.0
      2024-01-21 17:14:42.749	info	Send : UDP Connection State Request : 06 10 02 07 00 10 00 00 08 01 00 00 00 00 95 30 sent from Port: to 192.168.178.50:3671
      knx.0
      2024-01-21 17:14:40.748	info	Send : UDP Connection State Request : 06 10 02 07 00 10 00 00 08 01 00 00 00 00 95 30 sent from Port: to 192.168.178.50:3671
      knx.0
      2024-01-21 17:14:38.746	info	Send : UDP Connection State Request : 06 10 02 07 00 10 00 00 08 01 00 00 00 00 95 30 sent from Port: to 192.168.178.50:3671
      knx.0
      2024-01-21 17:14:36.744	info	Send : UDP Connection State Request : 06 10 02 07 00 10 00 00 08 01 00 00 00 00 95 30 sent from Port: to 192.168.178.50:3671
      knx.0
      2024-01-21 17:14:34.742	info	Send : UDP Connection State Request : 06 10 02 07 00 10 00 00 08 01 00 00 00 00 95 30 sent from Port: to 192.168.178.50:3671
      knx.0
      2024-01-21 17:14:32.741	info	Send : UDP Connection State Request : 06 10 02 07 00 10 00 00 08 01 00 00 00 00 95 30 sent from Port: to 192.168.178.50:3671
      knx.0
      2024-01-21 17:14:30.741	info	STATE_CONNECTION_STATE_REQUEST : no defined handling for transition from State: STATE_DESCRIPTION_REQUEST(17) to STATE_CONNECTION_STATE_REQUEST(5).
      knx.0
      2024-01-21 17:14:30.740	info	Send : UDP Connection State Request : 06 10 02 07 00 10 00 00 08 01 00 00 00 00 95 30 sent from Port: to 192.168.178.50:3671
      knx.0
      2024-01-21 17:14:28.740	info	STATE_DESCRIPTION_REQUEST : no defined handling for transition from State: STATE_NOT_CONNECTED(0) to STATE_DESCRIPTION_REQUEST(17).
      knx.0
      2024-01-21 17:14:28.739	info	Send : description Request : 06 10 02 03 00 0e 08 01 7f 00 00 01 95 30 sent to 192.168.178.50:3671
      knx.0
      2024-01-21 17:14:28.739	info	STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_PORT_OPENED(2) to STATE_NOT_CONNECTED(0).
      knx.0
      2024-01-21 17:14:28.739	info	... not able to close connection, because already closed
      knx.0
      2024-01-21 17:14:28.738	info	Connection persists.....closing now
      knx.0
      2024-01-21 17:14:28.737	info	Connected - local UDP Server listening on 127.0.0.1:38192
      knx.0
      2024-01-21 17:14:28.734	info	Event : UDP - listening
      knx.0
      2024-01-21 17:14:28.733	info	Debuglevel: 2 3
      knx.0
      2024-01-21 17:14:28.729	info	Connecting to knx GW: 192.168.178.50:3671 with phy. Adr: 15.15.245
      knx.0
      2024-01-21 17:14:28.727	info	knx license is OK.
      knx.0
      2024-01-21 17:14:24.901	info	starting. Version 2.0.24 in /opt/iobroker/node_modules/iobroker.knx, node: v18.19.0, js-controller: 5.0.17
      knx.0
      2024-01-21 17:14:24.749	debug	Plugin sentry Initialize Plugin (enabled=true)
      knx.0
      2024-01-21 17:14:24.729	debug	States connected to redis: 127.0.0.1:9000
      knx.0
      2024-01-21 17:14:24.669	debug	States create User PubSub Client
      knx.0
      2024-01-21 17:14:24.668	debug	States create System PubSub Client
      knx.0
      2024-01-21 17:14:24.618	debug	Redis States: Use Redis connection: 127.0.0.1:9000
      knx.0
      2024-01-21 17:14:24.596	debug	Objects connected to redis: 127.0.0.1:9001
      knx.0
      2024-01-21 17:14:24.593	debug	Objects client initialize lua scripts
      knx.0
      2024-01-21 17:14:24.568	debug	Objects create User PubSub Client
      knx.0
      2024-01-21 17:14:24.568	debug	Objects create System PubSub Client
      knx.0
      2024-01-21 17:14:24.567	debug	Objects client ready ... initialize now
      knx.0
      2024-01-21 17:14:24.548	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
      knx.0
      2024-01-21 17:14:21.106	info	terminating
      knx.0
      2024-01-21 17:14:20.690	info	Send : description Request : 06 10 02 03 00 0e 08 01 ac 11 00 02 d5 72 sent to 192.168.178.50:3671
      knx.0
      So eingestellt:
      kommt:
      knx.0
      2024-01-21 17:13:08.601	info	Using UDP with local IP: 172.17.0.2
      knx.0
      2024-01-21 17:13:07.602	info	STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
      knx.0
      2024-01-21 17:13:07.602	info	... not able to close connection, because already closed
      knx.0
      2024-01-21 17:13:07.601	info	Connection persists.....closing now
      knx.0
      2024-01-21 17:13:07.601	info	...set STATE-NOT-CONNECTED
      knx.0
      2024-01-21 17:13:06.600	info	STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
      knx.0
      2024-01-21 17:13:06.600	info	... not able to close connection, because already closed
      knx.0
      2024-01-21 17:13:06.600	info	Connection persists.....closing now
      knx.0
      2024-01-21 17:13:06.599	info	STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECTION_STATE_RESPONSE(6) to STATE_DISCONNECT_REQUEST(15).
      knx.0
      2024-01-21 17:13:06.599	info	Received CONNECTIONSTATE_RESPONSE : 06 10 02 08 00 08 00 21 192.168.178.50:3671 ChID : 0 SeqCntIN : 0 SeqCntOUT : 0 msgCode : [object Object]
      knx.0
      2024-01-21 17:13:06.599	info	STATE_CONNECTION_STATE_REQUEST : no defined handling for transition from State: STATE_DESCRIPTION_REQUEST(17) to STATE_CONNECTION_STATE_REQUEST(5).
      knx.0
      2024-01-21 17:13:06.598	info	Send : UDP Connection State Request : 06 10 02 07 00 10 00 00 08 01 00 00 00 00 b3 bc sent from Port: to 192.168.178.50:3671
      knx.0
      2024-01-21 17:13:04.598	info	Send : description Request : 06 10 02 03 00 0e 08 01 ac 11 00 02 b3 bc sent to 192.168.178.50:3671
      knx.0
      2024-01-21 17:13:04.597	info	Connected - local UDP Server listening on 172.17.0.2:46012
      knx.0
      2024-01-21 17:13:04.597	info	Event : UDP - listening
      knx.0
      2024-01-21 17:13:04.596	info	Using UDP with local IP: 172.17.0.2
      knx.0
      2024-01-21 17:13:03.598	info	STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
      knx.0
      2024-01-21 17:13:03.598	info	... not able to close connection, because already closed
      knx.0
      2024-01-21 17:13:03.598	info	Connection persists.....closing now
      knx.0
      2024-01-21 17:13:03.597	info	...set STATE-NOT-CONNECTED
      knx.0
      2024-01-21 17:13:02.597	info	STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
      knx.0
      2024-01-21 17:13:02.597	info	... not able to close connection, because already closed
      knx.0
      2024-01-21 17:13:02.596	info	Connection persists.....closing now
      knx.0
      2024-01-21 17:13:02.596	info	STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECTION_STATE_RESPONSE(6) to STATE_DISCONNECT_REQUEST(15).
      knx.0
      2024-01-21 17:13:02.596	info	Received CONNECTIONSTATE_RESPONSE : 06 10 02 08 00 08 00 21 192.168.178.50:3671 ChID : 0 SeqCntIN : 0 SeqCntOUT : 0 msgCode : [object Object]
      knx.0
      2024-01-21 17:13:02.595	info	STATE_CONNECTION_STATE_REQUEST : no defined handling for transition from State: STATE_DESCRIPTION_REQUEST(17) to STATE_CONNECTION_STATE_REQUEST(5).
      knx.0
      2024-01-21 17:13:02.595	info	Send : UDP Connection State Request : 06 10 02 07 00 10 00 00 08 01 00 00 00 00 af be sent from Port: to 192.168.178.50:3671
      knx.0
      2024-01-21 17:13:00.594	info	Send : description Request : 06 10 02 03 00 0e 08 01 ac 11 00 02 af be sent to 192.168.178.50:3671
      knx.0
      2024-01-21 17:13:00.593	info	Connected - local UDP Server listening on 172.17.0.2:44990
      knx.0
      2024-01-21 17:13:00.593	info	Event : UDP - listening
      knx.0
      2024-01-21 17:13:00.592	info	Using UDP with local IP: 172.17.0.2
      knx.0
      2024-01-21 17:12:59.594	info	STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
      knx.0
      2024-01-21 17:12:59.594	info	... not able to close connection, because already closed
      knx.0
      2024-01-21 17:12:59.594	info	Connection persists.....closing now
      knx.0
      2024-01-21 17:12:59.593	info	...set STATE-NOT-CONNECTED
      knx.0
      2024-01-21 17:12:58.593	info	STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
      knx.0
      2024-01-21 17:12:58.593	info	... not able to close connection, because already closed
      knx.0
      2024-01-21 17:12:58.592	info	Connection persists.....closing now
      knx.0
      2024-01-21 17:12:58.592	info	STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECTION_STATE_RESPONSE(6) to STATE_DISCONNECT_REQUEST(15).
      knx.0
      2024-01-21 17:12:58.591	info	Received CONNECTIONSTATE_RESPONSE : 06 10 02 08 00 08 00 21 192.168.178.50:3671 ChID : 0 SeqCntIN : 0 SeqCntOUT : 0 msgCode : [object Object]
      knx.0
      2024-01-21 17:12:58.591	info	STATE_CONNECTION_STATE_REQUEST : no defined handling for transition from State: STATE_DESCRIPTION_REQUEST(17) to STATE_CONNECTION_STATE_REQUEST(5).
      knx.0
      2024-01-21 17:12:58.591	info	Send : UDP Connection State Request : 06 10 02 07 00 10 00 00 08 01 00 00 00 00 cd 1f sent from Port: to 192.168.178.50:3671
      knx.0
      2024-01-21 17:12:56.589	info	Send : description Request : 06 10 02 03 00 0e 08 01 ac 11 00 02 cd 1f sent to 192.168.178.50:3671
      knx.0
      2024-01-21 17:12:56.588	info	Connected - local UDP Server listening on 172.17.0.2:52511
      knx.0
      2024-01-21 17:12:56.588	info	Event : UDP - listening
      knx.0
      2024-01-21 17:12:56.588	info	Using UDP with local IP: 172.17.0.2
      knx.0
      2024-01-21 17:12:55.589	info	STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
      knx.0
      2024-01-21 17:12:55.589	info	... not able to close connection, because already closed
      knx.0
      2024-01-21 17:12:55.589	info	Connection persists.....closing now
      knx.0
      2024-01-21 17:12:55.588	info	...set STATE-NOT-CONNECTED
      knx.0
      2024-01-21 17:12:54.588	info	STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
      knx.0
      2024-01-21 17:12:54.588	info	... not able to close connection, because already closed
      knx.0
      2024-01-21 17:12:54.587	info	Connection persists.....closing now
      knx.0
      2024-01-21 17:12:54.587	info	STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECTION_STATE_RESPONSE(6) to STATE_DISCONNECT_REQUEST(15).
      knx.0
      2024-01-21 17:12:54.587	info	Received CONNECTIONSTATE_RESPONSE : 06 10 02 08 00 08 00 21 192.168.178.50:3671 ChID : 0 SeqCntIN : 0 SeqCntOUT : 0 msgCode : [object Object]
      knx.0
      2024-01-21 17:12:54.586	info	STATE_CONNECTION_STATE_REQUEST : no defined handling for transition from State: STATE_DESCRIPTION_REQUEST(17) to STATE_CONNECTION_STATE_REQUEST(5).
      knx.0
      2024-01-21 17:12:54.586	info	Send : UDP Connection State Request : 06 10 02 07 00 10 00 00 08 01 00 00 00 00 e8 f2 sent from Port: to 192.168.178.50:3671
      knx.0
      2024-01-21 17:12:52.584	info	Send : description Request : 06 10 02 03 00 0e 08 01 ac 11 00 02 e8 f2 sent to 192.168.178.50:3671
      knx.0
      2024-01-21 17:12:52.584	info	Connected - local UDP Server listening on 172.17.0.2:59634
      knx.0
      2024-01-21 17:12:52.584	info	Event : UDP - listening
      knx.0
      2024-01-21 17:12:52.582	info	Using UDP with local IP: 172.17.0.2
      knx.0
      2024-01-21 17:12:51.585	info	STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
      knx.0
      2024-01-21 17:12:51.585	info	... not able to close connection, because already closed
      knx.0
      2024-01-21 17:12:51.584	info	Connection persists.....closing now
      knx.0
      2024-01-21 17:12:51.583	info	...set STATE-NOT-CONNECTED
      knx.0
      2024-01-21 17:12:50.582	info	STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
      knx.0
      2024-01-21 17:12:50.582	info	... not able to close connection, because already closed
      knx.0
      2024-01-21 17:12:50.582	info	Connection persists.....closing now
      knx.0
      2024-01-21 17:12:50.582	info	STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECTION_STATE_RESPONSE(6) to STATE_DISCONNECT_REQUEST(15).
      knx.0
      2024-01-21 17:12:50.581	info	Received CONNECTIONSTATE_RESPONSE : 06 10 02 08 00 08 00 21 192.168.178.50:3671 ChID : 0 SeqCntIN : 0 SeqCntOUT : 0 msgCode : [object Object]
      knx.0
      2024-01-21 17:12:50.581	info	STATE_CONNECTION_STATE_REQUEST : no defined handling for transition from State: STATE_DESCRIPTION_REQUEST(17) to STATE_CONNECTION_STATE_REQUEST(5).
      knx.0
      2024-01-21 17:12:50.581	info	Send : UDP Connection State Request : 06 10 02 07 00 10 00 00 08 01 00 00 00 00 ca 18 sent from Port: to 192.168.178.50:3671
      knx.0
      2024-01-21 17:12:48.580	info	Send : description Request : 06 10 02 03 00 0e 08 01 ac 11 00 02 ca 18 sent to 192.168.178.50:3671
      knx.0
      2024-01-21 17:12:48.579	info	Connected - local UDP Server listening on 172.17.0.2:51736
      knx.0
      2024-01-21 17:12:48.579	info	Event : UDP - listening
      knx.0
      2024-01-21 17:12:48.578	info	Using UDP with local IP: 172.17.0.2
      knx.0
      2024-01-21 17:12:47.580	info	STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
      knx.0
      2024-01-21 17:12:47.580	info	... not able to close connection, because already closed
      knx.0
      2024-01-21 17:12:47.579	info	Connection persists.....closing now
      knx.0
      2024-01-21 17:12:47.579	info	...set STATE-NOT-CONNECTED
      knx.0
      2024-01-21 17:12:46.578	info	STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
      knx.0
      2024-01-21 17:12:46.577	info	... not able to close connection, because already closed
      knx.0
      2024-01-21 17:12:46.577	info	Connection persists.....closing now
      knx.0
      2024-01-21 17:12:46.577	info	STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECTION_STATE_RESPONSE(6) to STATE_DISCONNECT_REQUEST(15).
      knx.0
      2024-01-21 17:12:46.576	info	Received CONNECTIONSTATE_RESPONSE : 06 10 02 08 00 08 00 21 192.168.178.50:3671 ChID : 0 SeqCntIN : 0 SeqCntOUT : 0 msgCode : [object Object]
      knx.0
      2024-01-21 17:12:46.576	info	STATE_CONNECTION_STATE_REQUEST : no defined handling for transition from State: STATE_DESCRIPTION_REQUEST(17) to STATE_CONNECTION_STATE_REQUEST(5).
      knx.0
      2024-01-21 17:12:46.576	info	Send : UDP Connection State Request : 06 10 02 07 00 10 00 00 08 01 00 00 00 00 8e a7 sent from Port: to 192.168.178.50:3671
      knx.0
      2024-01-21 17:12:44.575	info	Send : description Request : 06 10 02 03 00 0e 08 01 ac 11 00 02 8e a7 sent to 192.168.178.50:3671
      knx.0
      2024-01-21 17:12:44.574	info	Connected - local UDP Server listening on 172.17.0.2:36519
      knx.0
      2024-01-21 17:12:44.574	info	Event : UDP - listening
      knx.0
      2024-01-21 17:12:44.573	info	Using UDP with local IP: 172.17.0.2
      knx.0
      2024-01-21 17:12:43.576	info	STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
      knx.0
      2024-01-21 17:12:43.575	info	... not able to close connection, because already closed
      knx.0
      2024-01-21 17:12:43.575	info	Connection persists.....closing now
      knx.0
      2024-01-21 17:12:43.575	info	...set STATE-NOT-CONNECTED
      knx.0
      2024-01-21 17:12:42.574	info	STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
      knx.0
      2024-01-21 17:12:42.574	info	... not able to close connection, because already closed
      knx.0
      2024-01-21 17:12:42.573	info	Connection persists.....closing now
      knx.0
      2024-01-21 17:12:42.573	info	STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECTION_STATE_RESPONSE(6) to STATE_DISCONNECT_REQUEST(15).
      knx.0
      2024-01-21 17:12:42.573	info	Received CONNECTIONSTATE_RESPONSE : 06 10 02 08 00 08 00 21 192.168.178.50:3671 ChID : 0 SeqCntIN : 0 SeqCntOUT : 0 msgCode : [object Object]
      knx.0
      2024-01-21 17:12:42.572	info	STATE_CONNECTION_STATE_REQUEST : no defined handling for transition from State: STATE_DESCRIPTION_REQUEST(17) to STATE_CONNECTION_STATE_REQUEST(5).
      knx.0
      2024-01-21 17:12:42.572	info	Send : UDP Connection State Request : 06 10 02 07 00 10 00 00 08 01 00 00 00 00 a0 d3 sent from Port: to 192.168.178.50:3671
      knx.0
      2024-01-21 17:12:40.571	info	Send : description Request : 06 10 02 03 00 0e 08 01 ac 11 00 02 a0 d3 sent to 192.168.178.50:3671
      knx.0
      2024-01-21 17:12:40.571	info	Connected - local UDP Server listening on 172.17.0.2:41171
      knx.0
      2024-01-21 17:12:40.570	info	Event : UDP - listening
      knx.0
      2024-01-21 17:12:40.570	info	Using UDP with local IP: 172.17.0.2
      knx.0
      2024-01-21 17:12:39.568	info	STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
      knx.0
      2024-01-21 17:12:39.568	info	... not able to close connection, because already closed
      knx.0
      2024-01-21 17:12:39.567	info	Connection persists.....closing now
      knx.0
      2024-01-21 17:12:39.566	info	...set STATE-NOT-CONNECTED
      knx.0
      2024-01-21 17:12:38.565	info	STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
      knx.0
      2024-01-21 17:12:38.565	info	... not able to close connection, because already closed
      knx.0
      2024-01-21 17:12:38.564	info	Connection persists.....closing now
      knx.0
      2024-01-21 17:12:38.564	info	STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECTION_STATE_RESPONSE(6) to STATE_DISCONNECT_REQUEST(15).
      knx.0
      2024-01-21 17:12:38.564	info	Received CONNECTIONSTATE_RESPONSE : 06 10 02 08 00 08 00 21 192.168.178.50:3671 ChID : 0 SeqCntIN : 0 SeqCntOUT : 0 msgCode : [object Object]
      knx.0
      2024-01-21 17:12:38.563	info	STATE_CONNECTION_STATE_REQUEST : no defined handling for transition from State: STATE_DESCRIPTION_REQUEST(17) to STATE_CONNECTION_STATE_REQUEST(5).
      knx.0
      2024-01-21 17:12:38.563	info	Send : UDP Connection State Request : 06 10 02 07 00 10 00 00 08 01 00 00 00 00 81 8f sent from Port: to 192.168.178.50:3671
      knx.0
      2024-01-21 17:12:36.562	info	Send : description Request : 06 10 02 03 00 0e 08 01 ac 11 00 02 81 8f sent to 192.168.178.50:3671
      knx.0
      2024-01-21 17:12:36.561	info	Connected - local UDP Server listening on 172.17.0.2:33167
      knx.0
      2024-01-21 17:12:36.561	info	Event : UDP - listening
      knx.0
      2024-01-21 17:12:36.560	info	Using UDP with local IP: 172.17.0.2
      knx.0
      2024-01-21 17:12:35.563	info	STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
      knx.0
      2024-01-21 17:12:35.562	info	... not able to close connection, because already closed
      knx.0
      2024-01-21 17:12:35.562	info	Connection persists.....closing now
      knx.0
      2024-01-21 17:12:35.561	info	...set STATE-NOT-CONNECTED
      knx.0
      2024-01-21 17:12:34.560	info	STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
      knx.0
      2024-01-21 17:12:34.560	info	... not able to close connection, because already closed
      knx.0
      2024-01-21 17:12:34.559	info	Connection persists.....closing now
      knx.0
      2024-01-21 17:12:34.559	info	STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECTION_STATE_RESPONSE(6) to STATE_DISCONNECT_REQUEST(15).
      knx.0
      2024-01-21 17:12:34.559	info	Received CONNECTIONSTATE_RESPONSE : 06 10 02 08 00 08 00 21 192.168.178.50:3671 ChID : 0 SeqCntIN : 0 SeqCntOUT : 0 msgCode : [object Object]
      knx.0
      2024-01-21 17:12:34.558	info	STATE_CONNECTION_STATE_REQUEST : no defined handling for transition from State: STATE_DESCRIPTION_REQUEST(17) to STATE_CONNECTION_STATE_REQUEST(5).
      knx.0
      2024-01-21 17:12:34.558	info	Send : UDP Connection State Request : 06 10 02 07 00 10 00 00 08 01 00 00 00 00 9e 59 sent from Port: to 192.168.178.50:3671
      knx.0
      2024-01-21 17:12:32.557	info	Send : description Request : 06 10 02 03 00 0e 08 01 ac 11 00 02 9e 59 sent to 192.168.178.50:3671
      knx.0
      2024-01-21 17:12:32.557	info	Connected - local UDP Server listening on 172.17.0.2:40537
      knx.0
      2024-01-21 17:12:32.556	info	Event : UDP - listening
      knx.0
      2024-01-21 17:12:32.555	info	Using UDP with local IP: 172.17.0.2
      knx.0
      2024-01-21 17:12:31.558	info	STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
      knx.0
      2024-01-21 17:12:31.558	info	... not able to close connection, because already closed
      knx.0
      2024-01-21 17:12:31.557	info	Connection persists.....closing now
      knx.0
      2024-01-21 17:12:31.556	info	...set STATE-NOT-CONNECTED
      knx.0
      2024-01-21 17:12:30.556	info	STATE_NOT_CONNECTED : Try to connect / reconnect : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
      knx.0
      2024-01-21 17:12:30.555	info	... not able to close connection, because already closed
      knx.0
      2024-01-21 17:12:30.555	info	Connection persists.....closing now
      knx.0
      2024-01-21 17:12:30.554	info	STATE_DISCONNECT_REQUEST : no defined handling for transition from State: STATE_CONNECTION_STATE_RESPONSE(6) to STATE_DISCONNECT_REQUEST(15).
      knx.0
      2024-01-21 17:12:30.554	info	Received CONNECTIONSTATE_RESPONSE : 06 10 02 08 00 08 00 21 192.168.178.50:3671 ChID : 0 SeqCntIN : 0 SeqCntOUT : 0 msgCode : [object Object]
      knx.0
      2024-01-21 17:12:30.552	info	STATE_CONNECTION_STATE_REQUEST : no defined handling for transition from State: STATE_DESCRIPTION_REQUEST(17) to STATE_CONNECTION_STATE_REQUEST(5).
      knx.0
      2024-01-21 17:12:30.551	info	Send : UDP Connection State Request : 06 10 02 07 00 10 00 00 08 01 00 00 00 00 b5 64 sent from Port: to 192.168.178.50:3671
      knx.0
      2024-01-21 17:12:28.550	info	Send : description Request : 06 10 02 03 00 0e 08 01 ac 11 00 02 b5 64 sent to 192.168.178.50:3671
      knx.0
      2024-01-21 17:12:28.549	info	Connected - local UDP Server listening on 172.17.0.2:46436
      knx.0
      2024-01-21 17:12:28.546	info	Event : UDP - listening
      knx.0
      2024-01-21 17:12:28.545	info	Debuglevel: 2 3
      knx.0
      2024-01-21 17:12:28.541	info	Connecting to knx GW: 192.168.178.50:3671 with phy. Adr: 15.15.245
      knx.0
      2024-01-21 17:12:28.539	info	knx license is OK.
      knx.0
      2024-01-21 17:12:24.719	info	starting. Version 2.0.24 in /opt/iobroker/node_modules/iobroker.knx, node: v18.19.0, js-controller: 5.0.17
      knx.0
      2024-01-21 17:12:24.559	debug	Plugin sentry Initialize Plugin (enabled=true)
      knx.0
      2024-01-21 17:12:24.538	debug	States connected to redis: 127.0.0.1:9000
      knx.0
      2024-01-21 17:12:24.482	debug	States create User PubSub Client
      knx.0
      2024-01-21 17:12:24.481	debug	States create System PubSub Client
      knx.0
      2024-01-21 17:12:24.427	debug	Redis States: Use Redis connection: 127.0.0.1:9000
      knx.0
      2024-01-21 17:12:24.402	debug	Objects connected to redis: 127.0.0.1:9001
      knx.0
      2024-01-21 17:12:24.399	debug	Objects client initialize lua scripts
      knx.0
      2024-01-21 17:12:24.370	debug	Objects create User PubSub Client
      knx.0
      2024-01-21 17:12:24.369	debug	Objects create System PubSub Client
      knx.0
      2024-01-21 17:12:24.368	debug	Objects client ready ... initialize now
      knx.0
      2024-01-21 17:12:24.351	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
      knx.0
      2024-01-21 17:12:20.885	info	terminating
      knx.0
      2024-01-21 17:12:20.386	info	STATE_NOT_CONNECTED : Stop connection : STATE_DISCONNECT_REQUEST(15) to STATE_NOT_CONNECTED(0).
      knx.0
      2024-01-21 17:12:20.386	info	... not able to close connection, because already closed
      knx.0
      2024-01-21 17:12:20.386	info	Connection persists.....closing now
      knx.0
      2024-01-21 17:12:20.386	info	STATE_DISCONNECT_REQUEST : Transition from State: STATE_NOT_CONNECTED(0) to STATE_DISCONNECT_REQUEST(15) not possible because of cancelled connection.
      knx.0
      2024-01-21 17:12:20.385	info	( END ) Sending DISCONNECT_REQUEST : 06 10 02 09 00 10 00 00 08 01 7f 00 00 01 d4 f6 ChID : 0 SeqCntIN : 0 SeqCntOUT : 0 msgCode : [object Object]
      knx.0
      2024-01-21 17:12:20.384	info	STATE_NOT_CONNECTED : Stop connection : STATE_NOT_CONNECTED(0) to STATE_NOT_CONNECTED(0).
      knx.0
      2024-01-21 17:12:20.384	info	... not able to close connection, because already closed
      knx.0
      2024-01-21 17:12:20.384	info	Connection persists.....closing now
      knx.0
      2024-01-21 17:12:20.383	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      knx.0
      2024-01-21 17:12:20.383	debug	Plugin sentry destroyed
      knx.0
      2024-01-21 17:12:20.383	info	terminating
      knx.0
      2024-01-21 17:12:20.383	debug	Adapter close
      k
      • N
        Nubbbi @Nubbbi last edited by
        @Glasfaser
        Anscheinend gibt es hierzu keine Lösung?
        Da der OpenKNX-Adapter mit den gleichen Einstellungen läuft, kann ich den KNX-Adapter damit also nicht mehr betreiben.
        Schade um das Geld für die Lizenz.
        • Glasfaser
          Glasfaser @Nubbbi last edited by
          @nubbbi
          Mein Vorschlag ... schon ganz oben
          Container im Host -Modus betreiben .
          • N
            @glasfaser Welche Einstellungen muss ich dazu bitte ändern im Container?
            Also Container anhalten, und dann etwas ändern und neu starten?
            Oder Container löschen und neu erstellen?
            • Glasfaser
              @nubbbi sagte in KNX-Adapter - keine UDP-Verbindung - OpenKNX-Adapter i.O.:
              Ja , würde das Empfehlen , ( den Ordner /opt/iobroker , denke ich mal hast du ein Mount erstellt )
              • Glasfaser
                Buanet Docker v 9.0.1
                Würde ich dann auch noch gleichzeit auf die neue Image Version aktualisieren !
                • N
                  @glasfaser Das habe ich gemacht.
                  Müssen dann neben dem Mounting von /docker/iobroker zu /opt/fhem noch Ports zugewiesen werden?
                  Ich habe 3671-3671-udp und 7234-8081-tcp eingestellt, aber der Container bricht beim Start bei Schritt 3 ab.
                  Glasfaser 3 Replies Last reply Reply Quote 0
                  • Glasfaser
                    Warum soll er abbrechen !?
                    Bei Host brauchen keine Ports gemappt werden .
                    Zeige mal das LOG , so kann ich nur raten
                    • Glasfaser
                      Glasfaser @Nubbbi last edited by Glasfaser
                      Das gleiche wie deine Einstellungen im alten Container , zu Ordner Mounts !
                      • Glasfaser
                        zusätzlich ... kann man hiermit mehr sehen :
                        Trage in der ENV ein
                        DEBUG = true
                        • N
                          @glasfaser
                          ![85b79597-054d-4765-be09-13b9ebbf71d3-image.png](/assets/uploads/files/1706468856325-85b79597-054d-4765-be09-13b9ebbf71d3-image.png) code_text
                          ```iobroker
                          date,stream,content
                          2024/01/28 19:33:12,stdout,This Script will exit now.
                          2024/01/28 19:31:23,stdout,[DEBUG] IoBroker is not running!
                          2024/01/28 19:31:23,stdout,[DEBUG] If you want to stop or restart your container you have to do it manually.
                          2024/01/28 19:31:23,stdout,[DEBUG] This enables you to investigate or fix your issue on the command line.
                          2024/01/28 19:31:23,stdout,[DEBUG] Debug mode prevents the container from exiting on errors.
                          2024/01/28 19:31:23,stdout,For more information see ioBroker Docker image docs (https://docs.buanet.de/iobroker-docker-image/docs).
                          2024/01/28 19:31:23,stdout,Please check your configuration and try again.
                          2024/01/28 19:31:23,stdout,[DEBUG] No connection to databases possible ...
                          2024/01/28 19:31:23,stdout,[DEBUG]  Could not connect to states database at 127.0.0.1:9000 (invalid protocol). Please make sure the configured IP and port points to a host running JS-Controller >= 2.0. and that the port is not occupied by other software!
                          2024/01/28 19:31:23,stdout,[DEBUG] Error message:
                          2024/01/28 19:31:23,stdout,Checking database connection... Failed.
                          2024/01/28 19:30:30,stdout,
                          2024/01/28 19:30:30,stdout,[DEBUG] Done.
                          2024/01/28 19:30:30,stdout,[DEBUG] No custom states db settings detected.
                          2024/01/28 19:30:30,stdout,[DEBUG] Checking custom states db settings...
                          2024/01/28 19:30:30,stdout,[DEBUG] No custom objects db settings detected.
                          2024/01/28 19:30:30,stdout,[DEBUG] Checking custom objects db settings...
                          2024/01/28 19:30:30,stdout,[DEBUG] No multihost settings detected.
                          2024/01/28 19:30:30,stdout,[DEBUG] Checking multihost settings...
                          2024/01/28 19:30:30,stdout,(Re)setting permissions (This might take a while! Please be patient!)... Done.
                          2024/01/28 19:30:30,stdout,--------------------------------------------------------------------------------
                          2024/01/28 19:30:30,stdout,-----             Step 3 of 5: Checking ioBroker Installation              -----
                          2024/01/28 19:30:30,stdout,Existing installation of ioBroker detected in "/opt/iobroker".
                          2024/01/28 19:30:30,stdout,-----             Step 2 of 5: Detecting ioBroker Installation             -----
                          2024/01/28 19:30:30,stdout,-----                   Step 1 of 5: Preparing Container                   -----
                          2024/01/28 19:30:30,stdout,!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                          2024/01/28 19:30:30,stdout,!!!!           https://docs.buanet.de/iobroker-docker-image/docs/           !!!!
                          2024/01/28 19:30:30,stdout,!!!!     For more information see ioBroker Docker image documentation:      !!!!
                          2024/01/28 19:30:30,stdout,!!!!          Please make sure to deactivate if no longer needed.           !!!!
                          2024/01/28 19:30:30,stdout,!!!! This will extend the logging output and may slow down container start. !!!!
                          2024/01/28 19:30:30,stdout,!!!!               Environment variable DEBUG is set to true.               !!!!
                          2024/01/28 19:30:30,stdout,!!!!                            DEBUG LOG ACTIVE                            !!!!
                          N Glasfaser 2 Replies Last reply Reply Quote 0
                          • N
                            @nubbbi
                            Kann es sein, dass der Port 9000, der hier erwartet wird, bereits anders genutzt wird? Nämlich bei mir von Portainer?
                            • Glasfaser
                              Zeige mal vom vorhanden Container , die Full Ausgabe von
                              iob diag
                              • Glasfaser
                                Richtig , den mußt du ändern !!!
                                • N
                                  @glasfaser Wenn ich den Port 9000 für den Container Portainer ändere, komme ich aber nicht mehr auf dessen Weboberfläche.
                                  • Glasfaser
                                    @nubbbi
                                    sieht dann so aus , also über den Port 8020 erreichbar :
                                    Portainer ist im Bridge Modus :
                                    .7572cd39-5cd1-482a-bf59-91ed9a451831-grafik.png .
                                    • N
                                      @glasfaser
                                      *** ioBroker-Installation ***
                                      ioBroker Status
                                       Could not connect to objects database at 127.0.0.1:9001 (invalid protocol). Plea
                                      Core adapters versions
                                      admin:          6.12.0
                                      javascript:     "javascript" not found
                                      Adapters from github:   0
                                      Adapter State
                                      • Glasfaser
                                        @nubbbi
                                        was hast du denn noch auf 9001
                                        • N
                                          @glasfaser Also, ich öffne die Einstellungen zum Container, gehe auf "Terminalfenster öffnen" und dann "Mit Befehl starten" und da gebe ich "iob diag" ein - soweit richtig?
                                          Mir gelingt es aber nicht, das Ergebnis per STRG-C zu kopieren.
                                          • Glasfaser
                                            Steht in der Beschreibung !!
                                            vorher STRG-A dann STRG-C
                                            3279
