    4. [gelöst]Fronius Adapter zeigt gelbes Dreieck und keine
      Chris777 last edited by
      Mein Fehler
      2024-01-28 15:57:02.965 - info: host.iOBrocker stopInstance system.adapter.fronius-solarweb.0 (force=false, process=true)
      2024-01-28 15:57:02.968 - info: fronius-solarweb.0 (24431) Got terminate signal TERMINATE_YOURSELF
      2024-01-28 15:57:02.970 - info: fronius-solarweb.0 (24431) terminating
      2024-01-28 15:57:02.971 - debug: fronius-solarweb.0 (24431) Plugin sentry destroyed
      2024-01-28 15:57:02.971 - info: fronius-solarweb.0 (24431) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2024-01-28 15:57:03.060 - info: host.iOBrocker stopInstance system.adapter.fronius-solarweb.0 send kill signal
      2024-01-28 15:57:03.472 - info: fronius-solarweb.0 (24431) terminating
      2024-01-28 15:57:03.520 - info: host.iOBrocker instance system.adapter.fronius-solarweb.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2024-01-28 15:57:06.125 - info: host.iOBrocker instance system.adapter.fronius-solarweb.0 started with pid 24507
      2024-01-28 15:57:06.762 - debug: fronius-solarweb.0 (24507) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2024-01-28 15:57:06.794 - debug: fronius-solarweb.0 (24507) Objects client ready ... initialize now
      2024-01-28 15:57:06.795 - debug: fronius-solarweb.0 (24507) Objects create System PubSub Client
      2024-01-28 15:57:06.796 - debug: fronius-solarweb.0 (24507) Objects create User PubSub Client
      2024-01-28 15:57:06.840 - debug: fronius-solarweb.0 (24507) Objects client initialize lua scripts
      2024-01-28 15:57:06.844 - debug: fronius-solarweb.0 (24507) Objects connected to redis: 127.0.0.1:9001
      2024-01-28 15:57:06.873 - debug: fronius-solarweb.0 (24507) Redis States: Use Redis connection: 127.0.0.1:9000
      2024-01-28 15:57:06.887 - debug: fronius-solarweb.0 (24507) States create System PubSub Client
      2024-01-28 15:57:06.888 - debug: fronius-solarweb.0 (24507) States create User PubSub Client
      2024-01-28 15:57:06.951 - debug: fronius-solarweb.0 (24507) States connected to redis: 127.0.0.1:9000
      2024-01-28 15:57:06.978 - debug: fronius-solarweb.0 (24507) Plugin sentry Initialize Plugin (enabled=true)
      2024-01-28 15:57:07.305 - info: fronius-solarweb.0 (24507) starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.fronius-solarweb, node: v16.19.0, js-controller: 5.0.17
        Thomas Braun Most Active @Chris777 last edited by
        @chris777
        iob nodejs-update
        ausführen, dann weiter schauen.
          Homoran Global Moderator Administrators @Chris777 last edited by
          @chris777 da steht nix neues drin.
          Hast du im admin versehentlich oder absichtlich einen Neustart eingestellt?
            Automatischer Neustart ist nicht aktiv.
            wie update ich nochmal node?
            Habe den iobrocker unter Synology im Container laufen
              Thomas Braun Most Active @Chris777 last edited by Thomas Braun
              @chris777 sagte in Fronius Adapter zeigt gelbes Dreieck und keine Werte mehr:
              Hab ich doch oben geschrieben.
              iob nodejs-update
              Unter Umständen zuvor den
              iob fix
              noch durchführen.
                Ich habe mist gebaut und über den container manager der synology geupdatet und jetzt soll ich iobrocker komplett neu aufsetzen.
                wie kann ich jetzt mein backup einlesen im iobrocker, um alle einstellungen etc. wieder zu bekommen?
                  so etwas gehört in den Eröffnungspost!
                    So das habe ich jetzt alle wieder in gange, aber fronius adapter läuft immer noch nicht
                      Wie kann ich im iobrocker (läuft über synology docker) die Fronius Adapter Version 0.0.3 auf 0.1.0 updaten?
                      Geht es auch manuell? Unter den Adaptern finde ich das update nicht.
                      Die Vesion 0.1.0 soll laufen hat einer im Solar Forum geschrieben
                        @chris777
                        github:	0.1.0
                        latest:	0.1.0 for 52 days
                        stable:	0.0.3 for 16 months
                        also zur Zeit nur als Beta verfügbar. Kann man über npm (im den Experten-Modus) installieren.
                        Ist deine Basis denn nun senkrecht?
                        iob diag
                        zeigen.
                          ich habe es installiert 0.1.0 und nun läuft es alles.
                            Chris777 @Thomas Braun last edited by
                            was meinst du mit "ist deine Basis nun senkrecht"?
                              @chris777
                              Ob die ioBroker-Installation und 'der Rest' jetzt okay sind.
                                Danke allen!
                                Ihr helft einen immer so weiter!
                                  @chris777
                                  Und wo ist jetzt der Output vom
                                  iob diag
                                  zu finden?
                                    Kannst du mir näher erklären was du meinst mit output etc. meinst?
                                      @chris777
                                      Na halt die Ausgabe des Befehls.
                                        @thomas-braun Du meinst die Ausgabe, wenn ich alles aktualisiert habe und dann die Instanz neu starte?
                                          @chris777
                                          Wie du meinst. Vorher/nachher... Egal.
                                          1013
