    4. Backup Lokal ok, CFIS Error
      berndsolar13 last edited by berndsolar13
      Bisher hab ich meine Backups Lokal gemacht, aber da immer dieser Hinweis kommt "Lokal nicht gut " 😄 hab ich mir einen USB Stick fürs Backup besorg, angestöpselt auf der Fritzbox alles eingerichtet.
      Das Update was Lokal ohne Probleme durch läuft, meckert bei fritz.nas/backup_iobroker.
      Das Problem ist, meiner Meinung das Javascript Backup.
      Das Iobroker Backup kommt auf dem Fritzbox USB Stick im Ordner an, ist 5 MB groß.
      Das Javascript Update ist 1 KB groß, das File ist beschädigt.
      Das selbe File im Ordner /opt/iobroker/backups
      -rw-rwxr--+ 1 iobroker iobroker    96725 Jan 29 11:29 javascripts_2024_01_29-11_29_30_backupiobroker.tar.gz
      Hier noch mal die komplette Backup Meldung
      Started iobroker ...
      [DEBUG] [mount] - mount activ... umount is started before mount!!
      [DEBUG] [mount] - umount successfully completed
      [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=iobackup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.0 //192.168.178.1/fritz.nas/backup_iobroker /opt/iobroker/backups"
      [DEBUG] [mount] - mount successfully completed
      [DEBUG] [mount] - done
      [DEBUG] [iobroker] - host.scan-FUTRO-S740 4326 states saved
      [DEBUG] [iobroker] - host.scan-FUTRO-S740 4090 objects saved
      [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2024_01_29-12_58_54_backupiobroker.tar.gz
      [DEBUG] [iobroker] - This backup can only be restored with js-controller version up from 4.1
      [DEBUG] [iobroker] - done
      [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
      [DEBUG] [javascripts] - found Script: 200_Watt_Schaltscript
      [DEBUG] [javascripts] - found Script: 2x_150_watt_infrarot
      [DEBUG] [javascripts] - found Script: Skript_2
      [DEBUG] [javascripts] - found Script: außen2
      [DEBUG] [javascripts] - found Script: dp_text
      [DEBUG] [javascripts] - found Script: original_Infrarot_1_script
      [DEBUG] [javascripts] - found Script: taupunkt
      [DEBUG] [javascripts] - found Script: lueften
      [DEBUG] [javascripts] - found Script: zahler-durchschnitt
      [DEBUG] [javascripts] - found Script: wasser_außen
      [DEBUG] [javascripts] - found Script: device_check
      [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
      [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
      [ERROR] [javascripts] - Error: Unknown system error -116: Unknown system error -116, open '/opt/iobroker/backups/tmpScripts/script.json'
      Das Backup Fenster schließt sich auch nicht mehr, egal wie lange ich warte.
      Hängt vermutlich mit der Error Meldung zusammen.
      So wie ich es sehe, löscht er das Temp Verzeichnis zu früh, und will dann das Java File kopieren, was aber dann schon gelöscht wurde, oder ?
      Lokal im /opt/iobroker/backups/ Ordner läuft es aber ohne Probleme
      So schauts dann im Ordner aus
        Hab mal den Hacken bei "Javasript Speichern" entfernt, dann läuft das Update ohne Probleme auf dem Fritzbox NAS Speicher durch.
        Kann es sein, das eines der Javasripte für die Probleme verantwortlich ist ?
        unter Protokolle gibt es 2 fette rote Meldungen
        backitup.0
        2024-01-29 13:25:13.372	error	umount: /opt/iobroker/backups: nicht eingehängt.
        backitup.0
        2024-01-29 13:23:13.432	error	Error: Command failed: sudo mount -t cifs -o username=iobackup,password=****,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.178.1/fritz.nas/backup_iobroker /opt/iobroker/backups mount error(16): Device or resource busy Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
          Thomas Braun Most Active @berndsolar13 last edited by
          @berndsolar13
          Und wie schauen die Einstellungen im Adapter bezüglich CIFS aus?
          Fritz.NAS ist etwas eigen. Da muss die Option 'noserverino' und bei aktuellen nodejs-Versionen auch 'cache loose' gesetzt sein. Der SMB-Dialekt ist 3.1.1.
            berndsolar13 @Thomas Braun last edited by
            hier die Einstellungen, hoffe die stimmen 🙂
              Homoran Global Moderator Administrators @berndsolar13 last edited by
              @berndsolar13 sagte in Backup Lokal ok, CFIS Error:
              was für welche?
              der Header ist nicht zu sehen
                Nein, wie bereits geschrieben:
                SMB-Typ 3.1.1
                noserverino: aktiv
                cache loose: aktiv
                  berndsolar13 @Homoran last edited by
                  hi ich dachte es wäre klar worum es geht, daher hab ich das oben weg gelassen, aber hier noch einmal
                    @thomas-braun sagte in Backup Lokal ok, CFIS Error:
                    SMB-Typ 3.1.1
                    noserverino: aktiv
                    cache loose: aktiv
                    ok, ich ändere es, und teste es sofort
                    • MartinP
                      MartinP @berndsolar13 last edited by MartinP
                      War da nicht vor einiger Zeit ein Problem mit Backups auf der Fritzbox von iobroker aus? Irgendein Node Problem mit CIFS Besonderheiten der Fritzbox...
                        kann es sein, weil ich Javasript extra aktiviert hab ? bekomme jetzt wenn ich es erneut an mache folgenden Hinweis
                          Nein.
                          Hast du die drei Punkte jetzt umgestellt?
                            berndsolar13 @Thomas Braun last edited by berndsolar13
                            dein Tipp war richtig, nun läuft es durch, danke
                            die roten Meldungen sind weg 🙂
                              Deswegen fragte ich danach welche Einstellungen das seien. ich suchte die js Backup Einstellungen
                                Thomas Braun Most Active @MartinP last edited by
                                @martinp sagte in Backup Lokal ok, CFIS Error:
                                Ja, gab/gibt es. Dafür ist nun die Option 'cache loose' da.
                                'noserverino' musste schon länger gesetzt sein.
                                  gleich noch mal eine Nachfrage
                                  Sollte ich mit dem Adaper auch täglich die Influx DB Werte speichern ?
                                  Oder das lieber 1x manuell alle 7 Tage ?
                                  462
